B6 Passat Cruise Control after auto to manual swap
dspl1236
Akron, OH, USA
C?ID=59345
2009 B6 Passat Cruise Control after auto to manual swap. Just displays an exclamation mark ! Where cruse speed would be. Doesn't matter the position of the cruise stalk.
Clutch switch is working with the ecu no problem... But I do have it wired to a different fuse
Wednesday,20,April,2022,17:09:38:16872
VCDS Version: 22.3.1.1 (x64)
Data version: 20220401 DS337.0
VIN: WVWNL73C99E548140   License Plate:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 53 56 62 6D 72
          77
VIN: WVWNL73C99E548140   Mileage: 198910km-123596miles
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 06J 906 026 AF    HW: 06J 906 026 AF
   Component: MED17.5 TFSI 2,0    3318
   Revision: AAH03---    Serial number: VWZCZ000000000
   Coding: 0404010A18070160
   Shop #: WSC 05314 000 00000
   VCID: 6ED3D19279D6EDFF28-803A
   VINID: 9E69DE7070D32495451080440087FFBC68
053264 - Please Check Fault Codes in Control Module for Electrical Parking Brake
               U1010 - 000 -
                    Fault Frequency: 17
                    Mileage: 198291 km
                    Date: 2016.09.10
                    Time: 04:48:13
                    Temperature: 101.0°C
                    Temperature: 30.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 12.319 V
006439 - Relay for Aux Coolant Pump (J496)
               P1927 - 000 - Open Circuit
                    Mileage: 198291 km
                    Date: 2016.09.10
                    Time: 04:48:13
                    Temperature: 30.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 12.319 V
001056 - Catalyst System; Bank 1
               P0420 - 000 - Efficiency Below Threshold - MIL ON
                    Fault Status: 11100000
                    Mileage: 198298 km
                    Date: 2016.09.10
                    Time: 17:32:09
                    RPM: 2561 /min
                    Load: 31.0 %
                    Speed: 104.0 km/h
                    Temperature: 86.0°C
                    Temperature: 3.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 14.224 V
Readiness: 0000 0100
Address 03: ABS Brakes        Labels:. 3C0-614-109-C4.clb
   Part No SW: 3C0 614 109 AJ    HW: 3C0 614 109 AJ
   Component: J104    C4 440 V2   0016
   Revision: --025---    Serial number: 00000795168355
   Coding: 0000373
   Shop #: WSC 05311 000 00000
   VCID: 66C3A9B2512625BF50-8032
   Part No SW: 1K0 820 047 JJ    HW: 1K0 820 047 JJ
   Component: Climatic PQ35   143 1313
   Revision: 00143033    Serial number: 00000000000000
   VCID: 75E1FEFE1C80DE27E9-8020
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 00000009425857
   Coding: 048C8F2340041A004F0000000F0000000008F9435C000120000000000000
   Shop #: WSC 05124 123 12345
   VCID: 326B05E2AD6E891F0C-8066
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 091208 004  0206
   Coding: 00046997
   Shop #: WSC 05124
                    Fault Status: 00101100
                    Reset counter: 24
                    Mileage: 198399 km
                    Voltage: 11.75 V
                    Reset counter: 24
                    Mileage: 198399 km
                    Voltage: 11.70 V
01800 - Light Switch (E1)
                    Fault Frequency: 14
                    Reset counter: 244
                    Mileage: 198220 km
                    Voltage: 14.20 V
   Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
   Component: SDAR SIRIUS     H07 0150
   Revision: 00000000    Serial number: AUZ4Z7I0534927
   Coding: 0000100
   VCID: 336500E65274801707-8066
                    Reset counter: 230
                    Mileage: 198199 km
                    Date: 2016.09.10
                    Time: 02:11:24
   Part No SW: 5N0 959 655 H    HW: 5N0 959 655 H
   Component: J234__00F VW10 HI   1916
   Revision: 20013000    Serial number: 003E1P6H3Y5M
   Coding: 0012358
   VCID: 428B55221DCE399F9C-8016
   Subsystem 1 - Part No: 3C0 959 339 D
   Component: BF-Gewichtsens. 001 0002
   Subsystem 2 - Serial number: 000000000020FJ
   Subsystem 3 - Serial number: 0018.10.080000100000640077ÿ†63
   Subsystem 4 - Serial number: 640077ÿ†6332MTS639180799 ÿ†63
   Subsystem 5 - Serial number: 80799 ÿ†6342MTS622270809 ÿ†63
   Subsystem 6 - Serial number: 70809 ÿ†6351HTS6GQT516KJ ÿ†63
   Subsystem 7 - Serial number: 516KJ ÿ†6361HTS6IOQO06KJ ÿ†63
   Subsystem 8 - Serial number: O06KJ ÿ†63727TS66MVS06KJ ÿ†63
   Subsystem 9 - Serial number: S06KJ ÿ†63827TS6QRTS06KR ÿ
   Subsystem 10 - Serial number: S06KR ÿ
   Part No SW: 3C0 953 549 AC    HW: 3C0 953 549 AC
   Component: J0527               0020
   Revision: 00026000    Serial number: 3C9953507CN
   Coding: 0000312
   VCID: 6DD1D69E74D016E711-8038
   Component: E0221           002 0030
   Part No SW: 3C0 920 971 S    HW: 3C0 920 971 S
   Component: KOMBI         H05 0110
   Coding: 261E00
   Shop #: WSC 05314 115 12345
   VCID: 35613EFE94009E2729-8060
Address 19: CAN Gateway        Labels:. 3C0-907-530-V3.clb
   Part No SW: 3C0 907 530 L    HW: 3C0 907 951
   Component: J533__Gateway   H13 0152
   Revision:   H13       Serial number: 3300P094080169
   Coding: F9807F06021702002002
   Shop #: WSC 05314 123 12345
   VCID: 2A5B1D8285BEC1DFB4-807E
   Part No SW: 3C8 919 965     HW: 3C8 919 965
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1614128T0LK202
   Coding: 0000002
   Part No SW: 3C0 959 433 AP    HW: 3C0 959 433 AP
   Component:    IMMO         052 0383
   Revision: 00052000    Serial number: VWZCZ000000000
   Shop #: WSC 06479 444 101354
   VCID: 78FFF7CA0B92A34FF2-802C
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1517
   Revision: 72009005    Serial number: 00000883298305
   Coding: 0001205
   VCID: 6FEDCC967EDCE4F723-803A
                    Fault Status: 00100101
                    Reset counter: 19
                    Mileage: 198199 km
                    Date: 2016.09.10
                    Time: 01:06:11
   Part No SW: 5N1 909 144 N    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.0   1101
   Revision: 1AH03735    Serial number: 00122610397701
   Coding: 0000258
   Shop #: WSC 05666 444 123985
   VCID: 3D7126DE64304667E1-8068
00566 - Steering Assistance Operation
            008 - Implausible Signal - MIL ON
                    Fault Status: 11101000
                    Reset counter: 230
                    Mileage: 198199 km
                    Date: 2016.09.10
                    Time: 01:06:11
                    Hex Value: 0x7301
                    Hex Value: 0x7601
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0000
   Component:    KSG PQ46 RDK 052 0412
   Coding: 1B900E80D10340767404141FF08A0F0E087C01
   Shop #: WSC 05311 123 12345
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1517
   Revision: 72009005    Serial number: 00000630498326
   Coding: 0001204
   VCID: 70EFCFEA63E2FB0F3A-8024
   Part No SW: 3C8 907 801 A    HW: 3C8 907 801 B
   Component: J540 EPB3  VW-10498 0003
   Revision:   010       Serial number: 00000000050336
   Coding: 0000057
   VCID: 285FE78A9BB2F3CFA2-807C
03182 - Clutch Position Sensor (G476)
                    Fault Status: 11111010
                    Reset counter: 230
                    Mileage: 198199 km
                    Date: 2016.09.10
                    Time: 01:06:11
                    Voltage: 13.80 V
                    Count: 57
                    Hex Value: 0x1271
                    Hex Value: 0x0001
                    Hex Value: 0x1010
                    Fault Frequency: 36
                    Reset counter: 24
                    Mileage: 198199 km
                    Date: 2016.09.10
                    Time: 02:11:13
                    Voltage: 12.20 V
                    Count: 75
                    Hex Value: 0x12F1
                    Hex Value: 0x0001
                    Hex Value: 0x1010
            000 - - - MIL ON
                    Fault Status: 11110000
                    Reset counter: 229
                    Mileage: 198199 km
                    Date: 2016.09.10
                    Time: 21:45:22
                    Voltage: 14.10 V
                    Count: 103
                    Hex Value: 0x1271
                    Hex Value: 0x0001
                    Hex Value: 0x1010
   Part No SW: 3AD 035 190 A    HW: 3AD 035 190 A
   Component: RCD510USBRVC  003 0003
   Revision: -----001    Serial number: VWZ4Z3P8134451
   Coding: 01010024010011
   Shop #: WSC 00079 790 12345
   VCID: 2B5518864A44D8D74F-807E
   Part No SW: 1K0 959 703 AD    HW: 1K0 959 795 P
   Component: J388   TUER-SG HL   0307
   Revision: 42004101    Serial number: 00000000727164
   Coding: 0001168
   VCID: 72EBC5E26DEEC91FCC-8026
Address 6D: Trunk Elect.        Labels: 3C9-827-383.clb
   Part No SW: 3C9 827 383 F    HW: 3C9 827 383 F
   Component: J605  HECKDECKEL    0720
   Revision: 00H27001
   VCID: 346703FA577A872F1E-8060
   Subsystem 1 - Part No: 3C9 827 384 F
   Component: J756  HECKDECKEL    0720
   Subsystem 2 - Serial number: 0900H27001001A0048ÿ
   Part No SW: 1K0 959 704 AD    HW: 1K0 959 794 P
   Component: J389   TUER-SG HR   0307
   Revision: 42004101    Serial number: 00000000728785
   Coding: 0001168
   VCID: 73E5C0E612F4C017C7-8026
Address 77: Telephone        Labels: 5P0-862-335.lbl
   Part No SW: 1Z0 035 729 D    HW: 1Z0 035 729 D
   Component: FSE_2P8x        H35 0160
   Revision: 00000000    Serial number: 00000005028795
   Coding: 0004077
   VCID: 397932CE70187A47CD-806C
End-------------------------(Elapsed Time: 02:32)--------------------------
Hi and welcome.
An Auto to Manual transmission upgrade isn't a Tweak, it's a Retrofit. Thread moved. :)
What have you done to convince the ECU to work with a manual?
The Parking Brake is still looking for data from the TCU, but is also upset about the Clutch sensor at the same time. That's confusing... :confused:
dspl1236
Akron, OH, USA
C?ID=59345
Thanks for moving this.
The ECU. I grabbed a Manual ECU from a CC and I immo defeated it. That solved a cascade of codes from recoding all the modules and allowed me to pass emissions.
At this point the parking brake code for the clutch switch seem to be the issue.
TCU fuses are pulled and removed from the Can Gateway
dspl1236
Akron, OH, USA
C?ID=59345
I am not certain if the signal from the clutch switch needs to go to any other module other than the ECU.
If it does...I'll be happy to wire it in.
The O2 code just popped up today lol 😂
What year CC? I'm thinking the CC it came from used a different parking brake module, and the ECU and the EPB aren't quite compatible, but that's just a guess.
kamold
Australia
C?ID=241363
EPB also expects clutch position sensor (T5j/3) to be wired to T30/1.
  • Informative
