Hello All,
New VCDS family member here .
I've a query on new battery registration process in VCDS using HEX-NET for my 2015 Audi Q5. I've experienced this in VCDS while trying to register new battery (EverStart AGM H8):
I don't see Address 61 - Battery regulation listed under installed addresses. Please see the image below.
[/img]https://imgur.com/iKQDyac[/img]
I did try to go to Address 19-CAN Gateway to see if I can click/toggle on Address 61 to make it visible under installed addresses. I don't see address 61 there either. I can only see 61-Battery Regulation under Drive train tab. [/img]https://imgur.com/5zo0siy[/img]
I can't use this, as when I try to access it, VCDS will time out. So, I did further dowsing and found there is a possibility of battery registration being slave to CAN gateway and that needs a different process to register the battery. Link to my read is http://wiki.ross-tech.com/wiki/index.php/Battery_Replacement. Following this article and some other articles from the past stating to trick the module by changing just one digit in battery serial number for a battery without peculiar codes like original battery that came with my car. I just changed one number in the battery serial number for battery registration. After step one of this registration, I checked measuring block groups for 017, 018, 019 and 020 and values look sensible, all may not be correct as original battery had less Ah, CCA, and reserve capacity. [/img]https://imgur.com/domUJQy[/img] [/img]https://imgur.com/p5LpLFy[/img]
Now, for the next step to manually change the values in Adaptation-10 how do I proceed? I don't see Adaptation-10 in CAN gateway, what I've in VCDS for my car is Long Adaptation-0A and options under Long Adaptation-0A are not similar to what adaptation videos states to change battery's technical details for correct charging and maintenance by ECM. [/img]https://imgur.com/6Wm4SPM[/img]
Here is the entire post link , just in case.
What is the process to be followed for the second part of battery registration?
Regards,
rps
Regards,
rps
