Tuesday,19,April,2022,20:36:30:14602
VCDS Version: 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
Data version: 20220407 DS337.0
VIN: WAUZZZGY8NA001957 License Plate:
Chassis Type: GY-AU38 (5WA)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 42 44 4B 4B 52 5F 61
69 6C 75 A5 BB BC C4 CA CC D6 D7 DE C002 C003
VIN: WAUZZZGY8NA001957 Mileage: 4174km-2593miles
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
Address 01: Engine (J623-DFYA) Labels: None
Part No SW: 05E 906 012 Q HW: 05E 907 309 G
Component: R4 1.5l TFS H20 1131
Revision: 89H20000 CVN: 8D070E0A
Coding: 0225003223341D0830086000000000000000000000000000
ASAM Dataset: EV_ECM15TFS01105E906012Q 002004
ROD: EV_ECM15TFS01105E906012Q.rod
VCID: 2D0709FBBD92AEC3549-8078
VINID: 9D196AAAA5E921E4400012451C2D814C82
Readiness: 1110 0001
Address 02: Auto Trans (J743) Labels: None
Part No SW: 0CW 906 556 M HW: 0CW 300 051 N
Component: GSG DQ200G2.1 H07 0562
Serial number: CU502106087123 CVN: 7C4E8CA4
ASAM Dataset: EV_TCMDQ200022 001001
ROD: EV_TCMDQ200022.rod
VCID: 56F58617E884CD1BC53-8002
Subsystem 1 - Part No SW: 5WA 713 033 AM HW: 610 5
Component: ZSB_SB_AUTO H08 1034
Serial number: 20210526000067421798
Subsystem 2 - Part No SW: 8Y0 713 059 D HW: 8Y0 713 059 D
Component: ZSB_SB_mono H07 0152
Serial number: 01S20.05.21007500146
Part No SW: 5WA 614 517 BK HW: 5WA 614 517 P
Component: ESC H14 0131
Serial number: 61591000001435 CVN: C2AAA6F9
Coding: 240024A52220446D5280600506CAA185ADB558505A890308A1FC3851018A5141822814
ASAM Dataset: EV_Brake1ESCEPBMQB37W 013055
ROD: EV_Brake1ESCEPBMQB37W_013.rod
VCID: 127DBA0704EC113B69B-8046 SFD
Address 05: Acc/Start Auth. (J518) Labels: 5WA-959-436.clb
Part No SW: 5WA 959 436 H HW: 5WA 959 436 H
Component: Kessy IOBOX 100 0722
Serial number: ---------------
ASAM Dataset: EV_Kessy37w 004023
ROD: EV_Kessy37w_004.rod
VCID: 59EF8D2B999AE263E81-800C
Address 08: Auto HVAC (J979) Labels:* None
Part No SW: 5WA 907 007 P HW: 5WA 907 007 P
Component: AC Automat H30 3440
Coding: 006000110011320100100000111011010000012100100200000000000000
ASAM Dataset: EV_ACClimaPREVW38X 001100
ROD: EV_ACClimaPREVW38X_VW38.rod
VCID: 54F17C1FFE78DF0B3B7-8000
Air quality sensor:
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4H0 907 658 C HW: 4H0 907 658 C
Component: G935 MuFu H05 0010
Serial number: AB490C7400PAG0MUFU04
Front A/C control head:
Subsystem 3 - Part No SW: 8Y0 820 043 A HW: 8Y0 820 043 A
Component: AU38X KVA H05 0021
Serial number: 16 S12.06.2100930088
Interior temperature sensor:
Subsystem 4 - Part No SW: 5WA 907 527 A HW: 5WA 907 527 A
Component: E857 H01 0103
Serial number: 00001040621082817513
B10CD 00 [009] - -
[Function limitation due to energy management 03]
Reset counter: 40
Mileage: 4174 km
Date: 2022.04.19
Time: 20:32:56
Voltage terminal 30: 11.3 V
CAN input signal(s) status-Transport mode: OFF
CAN input signal(s) status-Back-up lamp: OFF
Blower reduction: No switch-off: no reduction
Part No SW: 5WA 937 086 L HW: 5WA 937 086 L
Component: BCM37w_M026 0174
Serial number: BXJ53F130621940
ASAM Dataset: EV_BCM37w 007001
ROD: EV_BCM37w_007.rod
VCID: 5AED92279C9CE97BE1B-800E SFD
Wiper motor control module:
Subsystem 1 - Part No SW: 8Y1 955 119 A HW: 8Y1 955 119
Component: J400FRWISCH 067 0090
Serial number: 907453F0302111706208
Subsystem 2 - Part No SW: 81A 955 555 B HW: 81A 955 555
Component: G397_RLFSS H06 0004
Serial number: 20427997X81A955555B0
Subsystem 3 - Part No SW: 4K1 941 501 K HW: 4K1 941 501 K
Component: E1 - LTM H05 0010
Serial number: 92160UCI0017Z 10S
Steering Column Switch:
Subsystem 4 - Part No SW: 82A 953 521 NB HW: 5Q1 953 549 D
Component: J527 SMLS MQB 005 0080
Serial number: 00000004062104401136
left tail lamp 1:
Subsystem 5 - Part No SW: 8Y0 945 423 HW: 8Y0 945 423
Component: SHL_li1 H06 0005
Serial number: 0021355409L15421HD14
left tail lamp 2:
Subsystem 6 - Part No SW: 8Y0 945 429 HW: 8Y0 945 429
Component: SHL_li2 H06 0005
Serial number: 0021352607L14221D176
Right rear tail lamp 1:
Subsystem 7 - Part No SW: 8Y0 945 424 HW: 8Y0 945 424
Component: SHL_re1 H06 0005
Serial number: 0021363909R15321ED1E
Right rear tail lamp 2:
Subsystem 8 - Part No SW: 8Y0 945 430 HW: 8Y0 945 430
Component: SHL_re2 H06 0005
Serial number: 0021361407R15621KE01
8667165 - Adaptation
B17D7 F0 [047] - Invalid
[Vorgegebenen&vorgehaltenen Datensatz per Anpassung veraendert]
Reset counter: 40
Mileage: 4174 km
Date: 2022.04.19
Time: 20:33:01
Terminal 15 status: On
Terminal 50 status: OFF
Engine run: OFF
Status of brake lamp switch: discrete: OFF
Brake lamp switch via CAN: status: OFF
Voltage: 11.3 V
Outside temperature: 19.0 °C
Light switch position: 0
Data set ID: 72 0B
Terminal 15 status: OFF
Engine run: OFF
Voltage: 0.0 V
Outside temperature: -50.0 °C
Light switch position: Initialization
Engine run: OFF
Voltage: 0.0 V
Engine run: OFF
Voltage: 0.0 V
Address 10: Park/Steer Assist (J446) Labels:* None
Part No SW: 5WA 919 298 B HW: 5WA 919 298
Component: PLA 12 Kanal H05 0578
Serial number: 000029052194630
Coding: 8202022113
ASAM Dataset: EV_EPHBO2CVW3800000 002028
ROD: EV_EPHBO2CVW3800000_VW38.rod
VCID: 55F7811BF582C603CC9-8000
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 5WA 907 572 B HW: 5WA 907 572
Component: ACC Bosch MQB H20 0395
Coding: 2A8B007D0077604522474000000000C8564020000000000000000000000000
ASAM Dataset: EV_FRONTRADARBOSCHVW380 004017
ROD: EV_FRONTRADARBOSCHVW380_004_AU38.rod
VCID: 4DC7697BDD528EC3749-8018
Address 15: Airbags (J234) Labels:* None
Part No SW: 5WA 959 655 L HW: 5WA 959 655 L
Component: AirbagVW40 007 0636
Serial number: 000000003C0J2R7
Coding: 88CC008000CCC000000000400000000091540000205400004000F670001300C5
Shop #: WSC 15252 004 1048576
ASAM Dataset: EV_AirbaVW40SMEVW38X 001032
ROD: EV_AirbaVW40SMEVW38X.rod
VCID: 6099A0CFBAC033ABAFF-8034 SFD
Subsystem 1 - Part No SW: ----------- HW: 480 402 905 21
Component: SideSensor_Dr 003 6149
Serial number: 3510001BAC4D1157C79G
Subsystem 2 - Part No SW: ----------- HW: 480 400 106 21
Component: SideSensor_Pr 003 6149
Serial number: 3520001A0C3828962BD9
Subsystem 3 - Part No SW: ----------- HW: 480 000 906 21
Serial number: 35700000000E3758755Q
Subsystem 4 - Part No SW: ----------- HW: 480 000 906 21
Serial number: 35800000000B4758755P
Subsystem 5 - Part No SW: ----------- HW: 480 400 906 21
Component: FrontSensor_D 003 614A
Serial number: 3550001A0C4E4CB2E10C
Subsystem 6 - Part No SW: ----------- HW: 480 400 906 21
Component: FrontSensor_P 003 614A
Serial number: 3560001A0C4E4CB6F0BS
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 8Y0 920 700 B HW: 8Y0 920 700 B
Component: KOMBI H11 5330
Coding: 80A515406B94000C0D80E3402000000808000400
ASAM Dataset: EV_DashBoardVDDMQB37W 003033
ROD: EV_DashBoardVDDMQB37W_003_VW41.rod
VCID: 3537219B55C2E6032C9-8060 SFD
Part No SW: 5WA 907 530 G HW: 5WA 907 530 G
Component: GW2020 High 756 7097
Revision: -------- Serial number: 771049050021172
Coding: 0000810D6700000003000000012101565101211102000100030100010001010000000000000000000000000000000000
GVL: 3D0000000208C28C80008002C800304000104002004000000000000000000044
ASAM Dataset: EV_GatewMQB2020 005011
ROD: EV_GatewMQB2020_VW41.rod
VCID: 4CC1647F264887CB637-8018 SFD
Subsystem 1 - Part No SW: 5WA 915 181 D HW: 5WA 915 181 D
Component: J367-BDMConti H04 1070
Serial number: 76407103002105170237
Subsystem 2 - Part No SW: 82A 951 523 B HW: 82A 951 523 B
Component: E221__MFL H08 0010
Serial number: 13S08001073047521106
Address 23: Brake Booster (J539) Labels: None
Part No SW: 5WA 909 059 K HW: 3Q0 909 059 C
Component: EBKV H09 0307
Serial number: BPA085050621013
Coding: 1302C104730000CE39E79C73000049922449922400
ASAM Dataset: EV_BrakeBoostG2BoschVW37W 016028
ROD: EV_BrakeBoostG2BoschVW37W_016.rod
VCID: 58E9882FE290FB6BD7F-800C SFD
Part No SW: 2Q0 905 861 B HW: 2Q0 905 861 B
Component: ELV-MQBB H09 0040
Serial number: 21000167573003
Coding: 8800000000000000
Shop #: WSC 00000 790 03045
ASAM Dataset: EV_ELVMarqMQBA0 002004
ROD: EV_ELVMarqMQBA0_VW27.rod
VCID: 323D1A87A4ACF13B09B-8066
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 5Q0 959 593 L HW: 5Q0 959 593 F
Component: TSG FS003 0350
Serial number: YE007UF812629
Coding: 001C8B005000000000011000
Shop #: WSC 00000 790 03060
ROD: EV_DCU2DriveSideMAXHKLO.rod
VCID: 4ACD62672C3C99FB51B-801E
Part No SW: 5WA 907 144 G HW: 5WA 907 144 C
Component: BASGEN1MQB37 102 1040
Serial number: 00366338
Coding: 0000000000000100000102010100010000000101010101
ASAM Dataset: EV_SteerAssisBASGEN1MQB37 007046
ROD: EV_SteerAssisBASGEN1MQB37_007_VW38.rod
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 5WA 907 338 B HW: 5WA 907 338
Component: FCM2020 Low 014 1447
Serial number: 290151221223065
Coding: 000000000900256A00102B03020003000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW38X 004012
ROD: EV_MultiModulContiVW38X.rod
VCID: 4DC7697BDD528EC3749-8018 SFD
Address 52: Door Elect, Pass. (J387) Labels:* None
Part No SW: 5Q0 959 592 L HW: 5Q0 959 592 F
Component: TSG BFS003 0350
Serial number: YE007UEI00299
Coding: 001C8B005C00000000011000
ROD: EV_DCU2PasseSideMAXHKLO.rod
VCID: 49CF5D6B293A92E3581-801C
Part No SW: 8Y0 035 043 J HW: 8Y0 035 043 A
Component: MU-TH-ND-EU 044 3617
Serial number: GRO-63317.06.21
Coding: 13801010004000000000000000000000000000000000000000
ASAM Dataset: EV_MUTI 001010
ROD: EV_MUTI_AU37.rod
VCID: 3A2D32A77CDC097BC1B-806E SFD
Multimedia System 1:
Subsystem 1 - Part No SW: 8Y0 919 605 HW: 8Y0 919 605
Component: DU AU38x High H40 0138
Serial number: MA19X2AE0972899
Data carrier:
Subsystem 2 - Part No: V03 959 808 KJ
Component: MIB3_EU_2022. 0750
Compact disc data bank:
Component: Gracenote2 1008
Volume Control 1:
Subsystem 4 - Part No SW: 8Y0 919 616 A HW: 8Y0 919 616
Component: Sensoric LSR H31 0140
Serial number: 12S21.05.21007400783
Media socket:
Address 61: Battery Regul. (A6) Labels: None
Part No SW: 5WA 915 107 HW: 5WA 915 107
Component: BMS_48V_LiIon H10 0455
Serial number: 252100000680800
ASAM Dataset: EV_BMSmHevCATL 003004
ROD: EV_BMSmHevCATL_AU38.rod
VCID: 04518C5F4E988F8BEB7-8050
Address 69: Trailer (J345) Labels:| 5H0-907-383.clb
Part No SW: 5H0 907 383 HW: 5H0 907 383
Component: Anhaenger H09 0040
Serial number: 000000000005812
Coding: 0100000202001200
ASAM Dataset: EV_TrailFunctGener3Hella 001009
ROD: EV_TrailFunctGener3Hella_VW27.rod
VCID: 6B83C7E3430660F30AD-803E
Address 6C: Back-up Cam. (J772) Labels:* None
Part No SW: 5WA 980 556 C HW: 5WA 980 556 B
Component: RV eCompact H26 0314
Serial number: FCLK20160621000
Coding: 01031100842000
ASAM Dataset: EV_CamSysRVCCompaFicos 009023
ROD: EV_CamSysRVCCompaFicos_009.rod
VCID: 51FF750BC16AAA23101-8004
Address 75: Telematics (J949) Labels:* None
Part No SW: 8Y0 035 282 B HW: 8Y0 035 282 A
Component: OCU3HMQB37W H06 0138
Serial number: 0000000105VIAXC
Coding: 013801109FE92C8590054600314F2607
ASAM Dataset: EV_OCU3HMQB37W 002012
ROD: EV_OCU3HMQB37W_002.rod
VCID: 372B2B934FCE14133E5-8062 SFD
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 5WA 980 653 C HW: 5WA 980 653
Component: MQB MFK 3.0 H06 3301
Serial number: E57830712211620
Coding: 000408882158C040509F04001020002000030000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 005050
ROD: EV_MFK3ValeoMQB_005_AU38.rod
VCID: 4FFB7373D75EBCD3065-801A
Part No SW: 5Q0 959 595 L HW: 8W1 959 595 D
Component: TSG HFS005 0350
Serial number: YE007UEF09118
Coding: 000C89004000000000001000
ASAM Dataset: EV_DCU2RearDriveMAXHKLO 001018
Component: TSG HBFS005 0350
Serial number: YE007UEF09297
ASAM Dataset: EV_DCU2RearPasseMAXHKLO 001018
Address C4: DC/DC Converter (A7) Labels: None
Part No SW: 5WA 959 663 A HW: 5WA 959 663 A
Component: DCDC_GEN_2 H23 0208
Serial number: DC21222001239
ASAM Dataset: EV_DCDC48VFLEXAU581 005013
ROD: EV_DCDC48VFLEXAU581_005_VW38.rod
Address CA: Sunroof (J245) Labels:* None
Part No SW: 4K1 907 594 CB HW: 4K1 907 594
Component: SAD_STG_1 006 0040
Coding: 428008038011
ASAM Dataset: EV_SunRoofCONTIAU736 009015
ROD: EV_SunRoofCONTIAU736_009_AU58.rod
VCID: 77ABEB930F4ED413FE5-8022
Slave 2:
Address CC: Starter-Generator (C29) Labels: None
Part No SW: 05E 903 018 G HW: 05E 903 018 G
Component: iBSG4U_000 H16 0224
Serial number: 5210619045432
ASAM Dataset: EV_SGCM600210005E903018G 002004
ROD: EV_SGCM600210005E903018G_A02_VW38.rod
VCID: 2615F6D798649D9B953-8072
Part No SW: 4K0 941 572 CS HW: 4K0 941 572 C
Component: LMS_MQB H06 0044
ASAM Dataset: EV_LMSLeftHELLAAU58X 001015
ROD: EV_LMSLeftHELLAAU58X.rod
VCID: 015F854B518A9AA3C01-8054
ASAM Dataset: EV_LMSRightHELLAAU58X 001015
ROD: EV_LMSRightHELLAAU58X.rod
Address DE: Charger 1 for mobile dev (J1146) Labels:* 4N0-035-502.clb
Part No SW: 4N0 035 502 B HW: 4N0 035 502 B
Component: WLC Front H14 0061
Coding: 400080
ROD: EV_Charg1MobilDevicAU651.rod
VCID: 2313EFC3EB5668B3F2D-8076
End----(Elapsed Time: 01:46, VBatt start/end: 11.3V/11.3V. VIgn 11.2V)-----
