How to activate Hold Assist A3 8Y
srengelink
C?ID=214660
Trowbridge, UK
Do we have an Auto-Scan of your 8Y A3?
If yes please post a link to it, if not please post an Auto-Scan.
srengelink
C?ID=214660
Apologize, forgot to add. See below Auto-Scan
Tuesday,19,April,2022,20:36:30:14602
VIN: WAUZZZGY8NA001957   License Plate:
Chassis Type: GY-AU38 (5WA)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 42 44 4B 4B 52 5F 61
          69 6C 75 A5 BB BC C4 CA CC D6 D7 DE C002 C003
VIN: WAUZZZGY8NA001957   Mileage: 4174km-2593miles
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
Address 01: Engine (J623-DFYA)       Labels: None
   Part No SW: 05E 906 012 Q    HW: 05E 907 309 G
   Component: R4 1.5l TFS   H20 1131
   Revision: 89H20000    CVN: 8D070E0A
   Coding: 0225003223341D0830086000000000000000000000000000
   ASAM Dataset: EV_ECM15TFS01105E906012Q 002004
   ROD: EV_ECM15TFS01105E906012Q.rod
   VCID: 2D0709FBBD92AEC3549-8078
   VINID: 9D196AAAA5E921E4400012451C2D814C82
Readiness: 1110 0001
Address 02: Auto Trans (J743)       Labels: None
   Part No SW: 0CW 906 556 M    HW: 0CW 300 051 N
   Component: GSG DQ200G2.1 H07 0562
   Serial number: CU502106087123  CVN: 7C4E8CA4
   ASAM Dataset: EV_TCMDQ200022 001001
   ROD: EV_TCMDQ200022.rod
   VCID: 56F58617E884CD1BC53-8002
   Subsystem 1 - Part No SW: 5WA 713 033 AM    HW: 610 5
   Component: ZSB_SB_AUTO    H08 1034
   Serial number: 20210526000067421798
   Subsystem 2 - Part No SW: 8Y0 713 059 D    HW: 8Y0 713 059 D
   Component: ZSB_SB_mono    H07 0152
   Serial number: 01S20.05.21007500146
   Part No SW: 5WA 614 517 BK    HW: 5WA 614 517 P
   Component: ESC           H14 0131
   Serial number: 61591000001435  CVN: C2AAA6F9
   Coding: 240024A52220446D5280600506CAA185ADB558505A890308A1FC3851018A5141822814
   ASAM Dataset: EV_Brake1ESCEPBMQB37W 013055
   ROD: EV_Brake1ESCEPBMQB37W_013.rod
   VCID: 127DBA0704EC113B69B-8046 SFD
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 H    HW: 5WA 959 436 H
   Component: Kessy IOBOX   100 0722
   Serial number: ---------------
   ASAM Dataset: EV_Kessy37w 004023
   ROD: EV_Kessy37w_004.rod
   VCID: 59EF8D2B999AE263E81-800C
Address 08: Auto HVAC (J979)       Labels:* None
   Part No SW: 5WA 907 007 P    HW: 5WA 907 007 P
   Component: AC Automat    H30 3440
   Coding: 006000110011320100100000111011010000012100100200000000000000
   ASAM Dataset: EV_ACClimaPREVW38X 001100
   ROD: EV_ACClimaPREVW38X_VW38.rod
   VCID: 54F17C1FFE78DF0B3B7-8000
   Air quality sensor:
   Humidity sensor: exterior:
   Subsystem 2 - Part No SW: 4H0 907 658 C    HW: 4H0 907 658 C
   Component: G935 MuFu      H05 0010
   Serial number: AB490C7400PAG0MUFU04
   Front A/C control head:
   Subsystem 3 - Part No SW: 8Y0 820 043 A    HW: 8Y0 820 043 A
   Component: AU38X KVA      H05 0021
   Serial number: 16 S12.06.2100930088
   Interior temperature sensor:
   Subsystem 4 - Part No SW: 5WA 907 527 A    HW: 5WA 907 527 A
   Component: E857           H01 0103
   Serial number: 00001040621082817513
          B10CD 00 [009] - -
          [Function limitation due to energy management 03]
                    Mileage: 4174 km
                    Date: 2022.04.19
                    Time: 20:32:56
                    Voltage terminal 30: 11.3 V
                    CAN input signal(s) status-Transport mode: OFF
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
                    CAN input signal(s) status-Back-up lamp: OFF
                    Blower reduction: No switch-off: no reduction
   Part No SW: 5WA 937 086 L    HW: 5WA 937 086 L
   Component: BCM37w_M026 0174
   Serial number: BXJ53F130621940
   ASAM Dataset: EV_BCM37w 007001
   ROD: EV_BCM37w_007.rod
   VCID: 5AED92279C9CE97BE1B-800E SFD
   Subsystem 1 - Part No SW: 8Y1 955 119 A    HW: 8Y1 955 119
   Component: J400FRWISCH    067 0090
   Serial number: 907453F0302111706208
   Component: G397_RLFSS     H06 0004
   Serial number: 20427997X81A955555B0
   Subsystem 3 - Part No SW: 4K1 941 501 K    HW: 4K1 941 501 K
   Component: E1 - LTM       H05 0010
   Serial number: 92160UCI0017Z    10S
   Steering Column Switch:
   Subsystem 4 - Part No SW: 82A 953 521 NB    HW: 5Q1 953 549 D
   Serial number: 00000004062104401136
   left tail lamp 1:
   Subsystem 5 - Part No SW: 8Y0 945 423     HW: 8Y0 945 423
   Component: SHL_li1        H06 0005
   Serial number: 0021355409L15421HD14
   left tail lamp 2:
   Subsystem 6 - Part No SW: 8Y0 945 429     HW: 8Y0 945 429
   Component: SHL_li2        H06 0005
   Serial number: 0021352607L14221D176
   Right rear tail lamp 1:
   Subsystem 7 - Part No SW: 8Y0 945 424     HW: 8Y0 945 424
   Component: SHL_re1        H06 0005
   Serial number: 0021363909R15321ED1E
   Right rear tail lamp 2:
   Subsystem 8 - Part No SW: 8Y0 945 430     HW: 8Y0 945 430
   Component: SHL_re2        H06 0005
   Serial number: 0021361407R15621KE01
8667165 - Adaptation
          B17D7 F0 [047] - Invalid
          [Vorgegebenen&vorgehaltenen Datensatz per Anpassung veraendert]
                    Mileage: 4174 km
                    Date: 2022.04.19
                    Time: 20:33:01
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    Engine run: OFF
                    Status of brake lamp switch: discrete: OFF
                    Brake lamp switch via CAN: status: OFF
                    Voltage: 11.3 V
                    Outside temperature: 19.0 °C
                    Light switch position: 0
                    Data set ID: 72 0B
                    Terminal 15 status: OFF
                    Engine run: OFF
                    Voltage: 0.0 V
                    Outside temperature: -50.0 °C
                    Light switch position: Initialization
                    Engine run: OFF
                    Voltage: 0.0 V
                    Engine run: OFF
                    Voltage: 0.0 V
   Part No SW: 5WA 919 298 B    HW: 5WA 919 298
   Component: PLA 12 Kanal  H05 0578
   Serial number: 000029052194630
   Coding: 8202022113
   ASAM Dataset: EV_EPHBO2CVW3800000 002028
   ROD: EV_EPHBO2CVW3800000_VW38.rod
   VCID: 55F7811BF582C603CC9-8000
   Part No SW: 5WA 907 572 B    HW: 5WA 907 572
   Component: ACC Bosch MQB H20 0395
   Coding: 2A8B007D0077604522474000000000C8564020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARBOSCHVW380 004017
   ROD: EV_FRONTRADARBOSCHVW380_004_AU38.rod
   VCID: 4DC7697BDD528EC3749-8018
   Part No SW: 5WA 959 655 L    HW: 5WA 959 655 L
   Component: AirbagVW40    007 0636
   Serial number: 000000003C0J2R7
   Coding: 88CC008000CCC000000000400000000091540000205400004000F670001300C5
   Shop #: WSC 15252 004 1048576
   ASAM Dataset: EV_AirbaVW40SMEVW38X 001032
   ROD: EV_AirbaVW40SMEVW38X.rod
   VCID: 6099A0CFBAC033ABAFF-8034 SFD
   Subsystem 1 - Part No SW: -----------    HW: 480 402 905 21
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001BAC4D1157C79G
   Subsystem 2 - Part No SW: -----------    HW: 480 400 106 21
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001A0C3828962BD9
   Subsystem 3 - Part No SW: -----------    HW: 480 000 906 21
   Serial number: 35700000000E3758755Q
   Subsystem 4 - Part No SW: -----------    HW: 480 000 906 21
   Serial number: 35800000000B4758755P
   Subsystem 5 - Part No SW: -----------    HW: 480 400 906 21
   Component: FrontSensor_D  003 614A
   Serial number: 3550001A0C4E4CB2E10C
   Subsystem 6 - Part No SW: -----------    HW: 480 400 906 21
   Component: FrontSensor_P  003 614A
   Serial number: 3560001A0C4E4CB6F0BS
   Part No SW: 8Y0 920 700 B    HW: 8Y0 920 700 B
   Component: KOMBI         H11 5330
   Coding: 80A515406B94000C0D80E3402000000808000400
   ASAM Dataset: EV_DashBoardVDDMQB37W 003033
   ROD: EV_DashBoardVDDMQB37W_003_VW41.rod
   VCID: 3537219B55C2E6032C9-8060 SFD
   Part No SW: 5WA 907 530 G    HW: 5WA 907 530 G
   Component: GW2020 High   756 7097
   Revision: --------    Serial number: 771049050021172
   Coding: 0000810D6700000003000000012101565101211102000100030100010001010000000000000000000000000000000000
   GVL: 3D0000000208C28C80008002C800304000104002004000000000000000000044
   ASAM Dataset: EV_GatewMQB2020 005011
   ROD: EV_GatewMQB2020_VW41.rod
   VCID: 4CC1647F264887CB637-8018 SFD
   Subsystem 1 - Part No SW: 5WA 915 181 D    HW: 5WA 915 181 D
   Component: J367-BDMConti  H04 1070
   Serial number: 76407103002105170237
   Subsystem 2 - Part No SW: 82A 951 523 B    HW: 82A 951 523 B
   Component: E221__MFL      H08 0010
   Serial number: 13S08001073047521106
   Part No SW: 5WA 909 059 K    HW: 3Q0 909 059 C
   Component: EBKV          H09 0307
   Serial number: BPA085050621013
   Coding: 1302C104730000CE39E79C73000049922449922400
   ASAM Dataset: EV_BrakeBoostG2BoschVW37W 016028
   ROD: EV_BrakeBoostG2BoschVW37W_016.rod
   VCID: 58E9882FE290FB6BD7F-800C SFD
   Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
   Component: ELV-MQBB      H09 0040
   Serial number: 21000167573003
   Coding: 8800000000000000
   Shop #: WSC 00000 790 03045
   ROD: EV_ELVMarqMQBA0_VW27.rod
   VCID: 323D1A87A4ACF13B09B-8066
   Part No SW: 5Q0 959 593 L    HW: 5Q0 959 593 F
   Component: TSG FS003 0350
   Serial number: YE007UF812629
   Coding: 001C8B005000000000011000
   Shop #: WSC 00000 790 03060
   VCID: 4ACD62672C3C99FB51B-801E
   Part No SW: 5WA 907 144 G    HW: 5WA 907 144 C
   Component: BASGEN1MQB37  102 1040
   Serial number: 00366338
   Coding: 0000000000000100000102010100010000000101010101
   ROD: EV_SteerAssisBASGEN1MQB37_007_VW38.rod
   Part No SW: 5WA 907 338 B    HW: 5WA 907 338
   Component: FCM2020 Low   014 1447
   Serial number: 290151221223065
   Coding: 000000000900256A00102B03020003000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW38X 004012
   ROD: EV_MultiModulContiVW38X.rod
   VCID: 4DC7697BDD528EC3749-8018 SFD
   Part No SW: 5Q0 959 592 L    HW: 5Q0 959 592 F
   Component: TSG BFS003 0350
   Serial number: YE007UEI00299
   Coding: 001C8B005C00000000011000
   VCID: 49CF5D6B293A92E3581-801C
   Part No SW: 8Y0 035 043 J    HW: 8Y0 035 043 A
   Component: MU-TH-ND-EU   044 3617
   Serial number: GRO-63317.06.21
   Coding: 13801010004000000000000000000000000000000000000000
   ASAM Dataset: EV_MUTI 001010
   ROD: EV_MUTI_AU37.rod
   VCID: 3A2D32A77CDC097BC1B-806E SFD
   Multimedia System 1:
   Subsystem 1 - Part No SW: 8Y0 919 605     HW: 8Y0 919 605
   Component: DU AU38x High  H40 0138
   Serial number: MA19X2AE0972899
   Subsystem 2 - Part No: V03 959 808 KJ
   Component: MIB3_EU_2022.  0750
   Compact disc data bank:
   Component: Gracenote2     1008
   Volume Control 1:
   Subsystem 4 - Part No SW: 8Y0 919 616 A    HW: 8Y0 919 616
   Component: Sensoric LSR   H31 0140
   Serial number: 12S21.05.21007400783
   Media socket:
Address 61: Battery Regul. (A6)       Labels: None
   Part No SW: 5WA 915 107     HW: 5WA 915 107
   Component: BMS_48V_LiIon H10 0455
   Serial number: 252100000680800
   ASAM Dataset: EV_BMSmHevCATL 003004
   ROD: EV_BMSmHevCATL_AU38.rod
   VCID: 04518C5F4E988F8BEB7-8050
Address 69: Trailer (J345)       Labels:| 5H0-907-383.clb
   Part No SW: 5H0 907 383     HW: 5H0 907 383
   Component: Anhaenger     H09 0040
   Serial number: 000000000005812
   Coding: 0100000202001200
   ASAM Dataset: EV_TrailFunctGener3Hella 001009
   ROD: EV_TrailFunctGener3Hella_VW27.rod
   VCID: 6B83C7E3430660F30AD-803E
Address 6C: Back-up Cam. (J772)       Labels:* None
   Part No SW: 5WA 980 556 C    HW: 5WA 980 556 B
   Component: RV eCompact   H26 0314
   Serial number: FCLK20160621000
   Coding: 01031100842000
   ASAM Dataset: EV_CamSysRVCCompaFicos 009023
   ROD: EV_CamSysRVCCompaFicos_009.rod
   VCID: 51FF750BC16AAA23101-8004
   Part No SW: 8Y0 035 282 B    HW: 8Y0 035 282 A
   Component: OCU3HMQB37W   H06 0138
   Serial number: 0000000105VIAXC
   Coding: 013801109FE92C8590054600314F2607
   ASAM Dataset: EV_OCU3HMQB37W 002012
   ROD: EV_OCU3HMQB37W_002.rod
   VCID: 372B2B934FCE14133E5-8062 SFD
   Part No SW: 5WA 980 653 C    HW: 5WA 980 653
   Component: MQB MFK 3.0   H06 3301
   Serial number: E57830712211620
   Coding: 000408882158C040509F04001020002000030000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005050
   ROD: EV_MFK3ValeoMQB_005_AU38.rod
   VCID: 4FFB7373D75EBCD3065-801A
   Part No SW: 5Q0 959 595 L    HW: 8W1 959 595 D
   Component: TSG HFS005 0350
   Serial number: YE007UEF09118
   Coding: 000C89004000000000001000
   Component: TSG HBFS005 0350
   Serial number: YE007UEF09297
Address C4: DC/DC Converter (A7)       Labels: None
   Part No SW: 5WA 959 663 A    HW: 5WA 959 663 A
   Component: DCDC_GEN_2 H23 0208
   Serial number: DC21222001239
   ASAM Dataset: EV_DCDC48VFLEXAU581 005013
   ROD: EV_DCDC48VFLEXAU581_005_VW38.rod
Address CA: Sunroof (J245)       Labels:* None
   Part No SW: 4K1 907 594 CB    HW: 4K1 907 594
   Component: SAD_STG_1     006 0040
   Coding: 428008038011
   ROD: EV_SunRoofCONTIAU736_009_AU58.rod
   VCID: 77ABEB930F4ED413FE5-8022
   Slave 2:
Address CC: Starter-Generator (C29)       Labels: None
   Part No SW: 05E 903 018 G    HW: 05E 903 018 G
   Component: iBSG4U_000    H16 0224
   Serial number: 5210619045432
   ASAM Dataset: EV_SGCM600210005E903018G 002004
   ROD: EV_SGCM600210005E903018G_A02_VW38.rod
   VCID: 2615F6D798649D9B953-8072
   Part No SW: 4K0 941 572 CS    HW: 4K0 941 572 C
   Component: LMS_MQB       H06 0044
   ASAM Dataset: EV_LMSLeftHELLAAU58X 001015
   ROD: EV_LMSLeftHELLAAU58X.rod
   VCID: 015F854B518A9AA3C01-8054
   ASAM Dataset: EV_LMSRightHELLAAU58X 001015
Address DE: Charger 1 for mobile dev (J1146)       Labels:* 4N0-035-502.clb
   Part No SW: 4N0 035 502 B    HW: 4N0 035 502 B
   Component: WLC Front     H14 0061
   Coding: 400080
   VCID: 2313EFC3EB5668B3F2D-8076
End----(Elapsed Time: 01:46, VBatt start/end: 11.3V/11.3V. VIgn 11.2V)-----
AINils
Germany (AIB)
C?ID=56975
Try to set your Byte 25 to value "FF" or "FE". It should work in my opinion as coding is in most case similar to MK100IPB from MQB Cars
srengelink
C?ID=214660
Unfortunately FF and FE is not working. Standard is this value FC
AINils
Germany (AIB)
C?ID=56975
What happen if you try my values?
srengelink
C?ID=214660
A lot of beeps…restart the car, no beeps. Put seatbelt on a drive a little but no auto hold or whatsoever. Fyi, when I code to FE / FF and rescan
again with VCDS, no fault codes.
AINils
Germany (AIB)
C?ID=56975
Okay then I think we need to find another thing. Will check that later
srengelink
C?ID=214660
Thanks, appreciated!
AINils
Germany (AIB)
C?ID=56975
Tried some things on a RS3 which is Model 2022, also didn't succeeded, will investigate more in next days as have some adaption maps for now. But RS3 seems to have different ABS
Trowbridge, UK
IIRC from when I was active on RS246.com the early RS3's had a different ABS module to later ones also.
AINils
Germany (AIB)
C?ID=56975
This RS3 has Special Version of MK100 I have never seen before:
Teilenummer SW: 8Y0 614 517 D HW: 8Y0 614 517 D
Bauteil: ESC MK100 EVO H13 0073
Trying to get more information from my contact at concern
srengelink
C?ID=214660
At the end I bought the OBDAPP as well and it’s working now. Later I will check the admaps and post the different values here.
Next goal is getting animated tail light working.
AINils
Germany (AIB)
C?ID=56975
I know Byte/Bit since yesterday. Got a hand on ZDC of this car ;-)
But please give us a new Autoscan after change, as iam interested in changes in Byte 23, too ;-)
Did you have capable lights for animation? If yes do this change:
STG09 > Adaption> Intelligente Heckleuchten-Verbau > Version set to value “5”
srengelink
C?ID=214660
At the office now so later I will post a scan.
For the animation, I have standard led light (no animation) but understood there is no difference in tail lights so it should be a ‘software matter’ in my opinion. Tried all values in ‘Intelligente Heckleuchten-Verbau’ already but no succes unfortunately (yet).
srengelink
C?ID=214660
Tuesday,10,May,2022,10:12:30:14602
VIN: WAUZZZGY8NA001957   Mileage: 5042km-3132miles
DE-Charger 1 for mobile dev -- Status: Cannot be reached 0100
   Coding: 240024A52220446D5280600506CAA185ADB558505AC94708A1FC3853018A5141822814
   Air quality sensor:
   left tail lamp 1:
   left tail lamp 2:
                    Mileage: 5019 km
                    Date: 2022.05.07
                    Time: 21:57:07
                    Engine run: OFF
                    Voltage: 11.8 V
                    Outside temperature: 16.0 ∞C
                    Data set ID: 72 0B
                    Engine run: OFF
                    Voltage: 0.0 V
                    Outside temperature: -50.0 ∞C
                    Engine run: OFF
                    Voltage: 0.0 V
                    Engine run: OFF
                    Voltage: 0.0 V
   Coding: 8202022113
   Coding: 2A8B007F0077604522474000000000C8564020000000000000000000000000
   Coding: 80A515406B94000C0D80E3402000000808000600
16711686 - Secure Onboard Communication
          U14FE 00 [008] - Signature Verification Failed
          [SOK_signature_verification_failed]
                    Mileage: 5019 km
                    Date: 2022.05.08
                    Time: 20:11:22
8466689 - VKMS
          B18B0 F0 [046] - Missing Adaptation
          [VKMS_new_download_container_required_due_to_vehicle_change]
                    Mileage: 5019 km
                    Date: 2022.05.09
                    Time: 16:55:23
   Coding: 0000000001000100000102010100010000000101010101
131080 - Databus Front Lights
          U1504 00 [008] - No Communications
          [Databus AFS no communication]
                    Mileage: 5042 km
                    Date: 2022.05.10
                    Time: 10:10:18
                    Mileage: 5042 km
                    Date: 2022.05.10
                    Time: 10:10:18
   Volume Control 1:
   Media socket:
   Coding: 000408882158C040909F04001020002000330000000000000000000000000000
   Slave 2:
   Coding: 400080
End----(Elapsed Time: 01:43, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
AINils
Germany (AIB)
C?ID=56975
Will compare later at home the difference in your ABS. There's more and other changes then Zieldatencontainer of ABS is telling. Will post my findings after checking this
hmm..........changes to hex03 module long-code string:
  • Byte 21, Bit 6 =1
  • Byte 22, Bit 2=1, Bit 6=1
  • Byte 27, Bit 1=1
AINils
Germany (AIB)
C?ID=56975
This is Audi bit description for the changes, but all related to Auto-Hold. Iam a little bit confused in these changes
Byte 21 > Bit 6 Autohold
Byte 22 > Bit 2 c_AH_switchOffWarning
Byte 22 > Bit 6 c_AH_LED
Byte 27 > Bit 1 BAP-Bedienungen (AVH-Taster)
@AINils :Thanks for the info - but Byte 27 > Bit 1 BAP-Bedienungen (AVH-Taster) ??
Forgive my abysmal understanding of your native tongue - "Bedienungen" =waitresses according to my translator??
And what is "AVH"
