Audi TT (8J) ABS Address-03 Wiki Page is Missing Recommended Links
SwissJetPilot
Switzerland
C?ID=317276
Can anyone from Ross Tech provide the two missing hyperlinks on this Wiki page? We're trying to track down the fault code 18055 and ran into this problem -
Both links for the Audi TT (8J) are missing any information. Should we assume the information for the A6, A4 and Q7 should be followed and we just contact Ross Tech?
1649278721956-png.484752
Who is "we"?
Is this the other party?
If so, tell us what's in those channels.
If you're working on a different car, please post an Auto-Scan for context.
SwissJetPilot
Switzerland
C?ID=317276
Hi Uwe - The "we" is me trying to help someone in the Audi TT UK Forum who is new to VCDS. :) And yes, it looks like the same person.
I pointed them to this Forum since they have a VCDS but wanted to ask this as a preemptive question.
The original post is linked below along with their auto scan -
Wednesday,06,April,2022,09:11:01:07718
VCDS Version: 22.3.1.1 (x64)
Data version: 20220401 DS337.0
VIN: TRUZZZ8JXXXXXXXXX License Plate:
Mileage: 107540km-66822mi Repair Order:
Chassis Type: 8J (1K0)
Scan: 01 03 08 09 15 16 17 19 25 26 42 44 46 47 52 56 76
VIN: TRUZZZ8JXXXXXXXXX Mileage: 107540km-66822miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 8J0 907 115 N HW: 8J0 907 115
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial number: AUX7Z0G6FN30KE
Coding: 0113000318070160
Shop #: WSC 01236 785 00200
VCID: 377A8A644653A2373B-8062
VINID: 92296AAAA21A108040042040009A20B93B
001393 - Brake Switch (F)
P0571 - 008 - Implausible Signal - Intermittent
Mileage: 104835 km
Date: 2021.03.04
Time: 00:46:36
RPM: 2058 /min
Load: 25.5 %
Speed: 82.0 km/h
Temperature: 51.0°C
Temperature: 10.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 14.224 V
001089 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow
Fault Status: 01100010
Mileage: 107539 km
Date: 2022.03.02
Time: 17:28:30
RPM: 758 /min
Load: 14.9 %
Temperature: 66.0°C
Temperature: 24.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.224 V
049441 - No Communication with ABS Brake Control Module
U0121 - 008 - - Intermittent
Mileage: 107542 km
Temperature: 9.0°C
Temperature: 11.0°C
Voltage: 11.938 V
Address 03: ABS Brakes Labels: 8J0-614-517.clb
Part No SW: 8J0 614 517 HW: 8J0 614 517
Component: ESP MK60E1 0130
Revision: 00H52001
Coding: 0017425
Shop #: WSC 12583 004 1048576
VCID: 6ADC63104561CFDF74-803E
18055 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 000 -
Reset counter: 146
Mileage: 107543 km
Date: 2022.03.28
Time: 17:12:00
Count: 128
Count: 12545
Count: 197
Count: 41472
Address 08: Auto HVAC Labels: None
Part No SW: 8J0 820 043 AG HW: 8J0 820 043 AG
Component: J255 Klima 1 Zone 0080
Revision: 00H07003 Serial number: 00000001045236
Coding: 1574148
VCID: 6BD266144A9BD6D70F-803E
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
Component: Bordnetz-SG H54 2501
Revision: 00H54000 Serial number: 00000007304196
Coding: 01040E8280141C00471800001800000000085E075C210802000000000000
VCID: 4586F0AC0CBFC0A7B9-8010
Subsystem 1 - Part No: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: Wischer AU354 H08 0060
Coding: 00064784
Shop #: WSC 01236
Address 15: Airbags Labels: 8J0-959-655.lbl
Part No SW: 8J0 959 655 HW: 8J0 959 655
Component: -t Airbag 9.43 H02 0020
Revision: 93H02002 Serial number: 0036K001JUTM
Coding: 0011636
VCID: 79FE4C5C30C774478D-802C
Subsystem 1 - Serial number: 6332DRB4056D4B29X
Subsystem 2 - Serial number: 6342DRB4056D889D3
Subsystem 3 - Serial number: 63729RB40292BC41O
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0000041
VCID: 418EE4BC1897EC8785-8014
Address 17: Instruments Labels: 8J0-920-xxx-17-MY8.clb
Part No SW: 8J0 920 980 E HW: 8J0 920 980 E
Component: KOMBIINSTR. VDO H22 0130
Revision: D0H22001 Serial number: 2246G001000851
Coding: 0004428
VCID: 3362BE74522B4E1707-8066
00003 - Control Module
014 - Defective
Fault Status: 01101110
Mileage: 91834 km
Date: 2017.10.04
Time: 01:33:13
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K07625831C
Coding: E9801F2E1002025101
VCID: 3068B178A33D750F7A-8064
Revision: D0H22001 Serial number: AUX7Z0G6FN30KE
Address 26: Auto Roof Labels: 8J7-959-255.lbl
Part No: 8J7 959 255 B
Component: 256 VSG TT H14 0110
VCID: 3E749F406969937FF8-806A
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX1.lbl
Part No: 8J7 959 801 C
Component: Tuer-SG H02 0060
Coding: 0000565
VCID: 3C7095487F75816FD6-8068
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 8J2 909 143 C
Component: EPS_ZFLS Kl.157 H08 1903
VCID: 316EB47CA8377C0775-8064
Address 46: Central Conv. Labels:. 8J0-959-433.lbl
Part No: 8J0 959 433 B
Component: KSG H10 0080
Coding: 1890300241182D098505489AD633
VCID: 3566806C5C5F502729-8060
Subsystem 2 - Part No: 8J0 951 177
Component: DWA-Sensor H03 0020
Address 47: Sound System Labels: 8J0-035-223.lbl
Part No SW: 8J0 035 223 B HW: 8J0 035 223 B
Component: J525 Amp Std H03 0120
Revision: 00H03001 Serial number: 93802002853806
Coding: 0106137
VCID: 23424E34E2CBDE97F7-8076
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MAX1.lbl
Part No: 8J7 959 802 C
Coding: 0000565
VCID: 3D76984C646F8867E1-8068
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8J0 035 186 J HW: 8J0 035 186 J
Component: R Concert2+ H04 0240
Revision: 00H04000 Serial number: AUZ1Z3G1842592
Coding: 0010101
Address 76: Park Assist Labels: 8P0-919-283.lbl
Part No SW: 8P0 919 283 D HW: 8P0 919 283 D
Component: Parkhilfe 4-Kan H09 0070
Revision: 00H09000 Serial number: 00067824820717
Coding: 0000021
End-------------------------(Elapsed Time: 01:46)--------------------------
SwissJetPilot
Switzerland
C?ID=317276
Any further updates on this...??
Reactions: JMR
