TSR does not update signs after sometime
nibose
Perth, Australia
C?ID=371170
Hi Everybody!
I have a VW Passat with Traffic Sign Assist. Recently I realised the traffic signs dont update after I've driven the car for about a hour or so. Even if it passes a new sign, it simply does not update but keeps showing the previously detected sign.
It works fine when I restart the car, and then the same repeats after I've driven for about an hour.
Any thoughts?
Westbury, UK
Normally TSA is in a 'fusion' mode that reads the signs using the camera and also expects some matching data on the internal sat nav maps.
Do you have up-to-date sat nav maps?
Please post an Auto-Scan of your Passat so we can see how it is equipped and configured.
siLc
Tallinn, Estonia
C?ID=330192
That sounds like the particular software fault of the 3Q0980654 front camera with suffix "L". But please, post an autoscan.
nibose
Perth, Australia
C?ID=371170
Monday,27,December,2021,17:50:26:34260
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 36 3C 42 44 4B 52 5F 6C
          A5 BB BC CA CF D6 D7
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CJSA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 3G0 906 264     HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0004
   Revision: --H13---    CVN: 2709B937
   Coding: 092500322464050B3000
   Shop #: WSC 05311 115 00311
   ASAM Dataset: EV_ECM18TFS0203G0906264 001007
   ROD: EV_ECM18TFS020_VW48.rod
   VCID: 6597B067C5E99B63347-8030
   VINID: 9E69EAAAA0D3A9B5401440C310C5CBE516
   Part No SW: 0CW 300 043 H    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1601
   Revision: 00005008    Serial number: CU501811136031 CVN: 9FE2D282
   Shop #: WSC 05311 115 00086
   ROD: EV_TCMDQ200021_VW26.rod
   VCID: 3C21350316E3FAABBB9-8068
   Part No SW: 5Q0 614 517 DH    HW: 5Q0 614 517 AH
   Component: ESC           H62 0754
   Revision: 00000000    Serial number: 63258000001330
   Coding: 0EEC928F34252370477A060360C74970492CC4E2600692753842F038C2A9420B00000012121212B835351919323200
   Shop #: WSC 00015 115 08193
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 7AADF31B5C57049BE95-802E
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0499916047
   Coding: 1F20000723
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   VCID: 43D34EFF6B1D8553FA3-8016
   Part No SW: 5G0 907 044 DP    HW: 5G0 907 044 DP
   Component: Climatronic   H04 2001
   Revision: 00001K10
   Coding: 1112001420010000111510401210182A
   VCID: 78A9E913625B168B9F1-802C
   Air quality sensor:
   Humidity sensor: exterior:
   Part No SW: 5Q0 937 086 BQ    HW: 5Q0 937 086 BQ
   Component: BCM PQ37BOSCH 036 0265
   Revision: --------    Serial number: 8658081118000S
   ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
   ROD: EV_BCMBOSCH_019.rod
   VCID: 0A4DA3DB0CB7141BF95-805E
   Subsystem 1 - Part No SW: 3G2 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    181104  043 0607
   Serial number:         181115102536
   Component: RLHS  052 0107
   Serial number: S7Y18M11D29H15M50S54
   Coding: 00A8DD
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Serial number: 25 09 2018  10000464
   Humidity sensor: interior:
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 521 AS    HW: 5Q1 953 569
   Component: Lenks.Modul  H03 0170
   Serial number: 0100241120180C301643
   Part No SW: 5QA 919 298 F    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0453
   Serial number: 000308417618311
   Coding: 0371167851
   ASAM Dataset: EV_EPHVA2CAU3700000 009037
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 53F37EBF9B7D15D34A3-8006
   Part No SW: 5Q0 907 572 S    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0780
   Coding: 331D7FF3DDFFCF28949E812481408300000000000099000000
   Shop #: WSC 19460 666 12345
   ASAM Dataset: EV_ACCBOSCHVW416 003015
   ROD: EV_ACCBOSCHVW416_003_VW48.rod
   VCID: 47CB5AEF5F25A97326B-8012
   Part No SW: 3Q0 959 655 BJ    HW: 3Q0 959 655 BJ
   Component: Airbag VW21   006 0712
   Revision: --------    Serial number: 003W5PN9QTH/
   Coding: 98FCC0C0000000005C540000008800000065
   Shop #: WSC 05311 000 08193
   VCID: 074B9AEF1FA56973E6B-8052
   Subsystem 1 - Part No SW: -----------    HW: 454 000 611 18
   Serial number: 35700000000162717231
   Subsystem 2 - Part No SW: -----------    HW: 454 000 611 18
   Serial number: 35800000000B5271723B
   Subsystem 3 - Part No SW: -----------    HW: 454 800 810 18
   Serial number: 35100F6C57A16000000S
   Subsystem 4 - Part No SW: -----------    HW: 454 801 211 18
   Serial number: 35200E660D916000000M
   Subsystem 5 - Part No SW: -----------    HW: 454 802 510 18
   Serial number: 35500E5619C16000000O
   Part No SW: 3G0 920 791 D    HW: 3G0 920 791 D
   Component: KOMBI         403 4191
   Coding: 27A501186F8C000801887B0B1001000080000000
   VCID: 2A0D035BEC77741BD95-807E
   Serial number: 29111810804595
   Coding: 030300347F085900FB00025A1C0F00010001070000000000000000000000
   GVL: 01463C000000060040DC80000002C80010040000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E85CF4B101F583B45D-803A
   Generator:
   Component: 0-00-03-00-04
   Subsystem 2 - Part No SW: 5G0 959 442 AE    HW: 5G0 959 442 AE  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0052
   Serial number: 29180002805690098475
   Coding: 2DFFFF
   Serial number: 75886002001811091A89
   Analog clock:
   Subsystem 4 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  111 1004
   Serial number: 1311201800010362
   Serial number: 18000349925013
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 33331E3F3BBD35D36A3-8066
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 3Q0 959 760 D    HW: 3Q0 959 760 D
   Component: Sitzmemory    H06 0024
   Serial number: Y0006RKR13119
   Coding: 001400020000050081C280808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   Part No SW: 3Q0 907 566 G    HW: 3Q0 907 566
   Component: MRR1Rear      H23 0530
   Revision: --------
   Coding: 44C002
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS001 0287
   Serial number: YE007RKG05581
   Coding: 003F1B20D201020000000000
   ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
   VCID: 44D14DE36E13826BC39-8010
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Coding: 93170000
   Shop #: WSC 00015 115 00311
   ROD: EV_SteerAssisMQB_015.rod
   Component: FCM MQB Low   002 0345
   Serial number: 23111810521586
   Coding: 000000060900034E01005F05020000040000000000000000000000000000
   Shop #: WSC 05311 123 08193
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW41.rod
   VCID: 3537202735C92BE3447-8060
   Subsystem 1 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
   Component: Leimo links  H02 0003
   Coding: E02400
   Subsystem 2 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
   Component: Leimo rechts  H02 0003
   Coding: E02400
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS001 0287
   Serial number: YE007RKG17817
   Coding: 003F1120DE01020000000000
   ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
   Part No SW: 5NA 035 045 C    HW: 5NA 035 045
   Component: MU-H-N-RW     H55 1161
   Serial number: A849K0JS036922
   Coding: 02840108FF00000051510001000808001F0106E601200402DF
   VCID: 3829291322DBD68B5F1-806C
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H52 9130
   Serial number: VWZ6ZJV3280358
   Subsystem 2 - Part No SW: V03 959 809 PF    HW: -----------
   Component: ROW 2022  --- 0099
   Compact disc data bank:
   Component: Gracenote2  --- 4013
   Coding: 0184010162002017000040
   VCID: 392F2C1719D1CF83A0F-806C
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 0610
   Serial number: 20081815P12294
   Coding: 000408010000010100022346C156890098000E33004000
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40D941F37A0B9E4BE71-8014
   Part No SW: 8W1 959 595 D    HW: 8W1 959 595 D
   Component: TSG HFS003 0187
   Serial number: YE007RKD22815
   Coding: 000E11200101020000000000
   ROD: EV_DCU2RearDriveMAXHKLO_VW37.rod
   VCID: 4EC56FCBB05F783B65D-801A
   Component: TSG HBFS003 0187
   Serial number: YE007RKD22811
   ROD: EV_DCU2RearPasseMAXHKLO_VW37.rod
   Part No SW: 4M0 907 594 K    HW: 4M0 907 594
   Component: SAD_STG_1     014 0005
   Coding: 508000748101
   ROD: EV_SunRoofCONTIAU736_006.rod
   VCID: 3E253F0B00FFE8BB95D-806A
   Part No SW: 3Q0 907 590 G    HW: 3Q0 907 590
   Revision: --------
   Coding: 44C002
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   VCID: 1675C7AB480FC0FB6DD-8042
   Component: LED1R         H09 0003
End----------(Elapsed Time: 02:13, VBatt start/end: 12.5V/12.5V)-----------
Please find the autoscan attached
nibose
Perth, Australia
C?ID=371170
What is the current best firmware for the above camera?
siLc
Tallinn, Estonia
C?ID=330192
The overall best firmware is considered to be older "H" but downgrading firmware can brick the camera. You can only upgrade it to "S" but that doesn't have parameters for the B8 and has its own host of issues. IMO only real option is to buy a another used camera with software "H", have it parameterized and calibrated.
nibose
Perth, Australia
C?ID=371170
Is there a chance a newer firmware will be released after "S"?
How easy/difficult is it to swap the camera? I've got basic to intermediate skills hence asking.
siLc
Tallinn, Estonia
C?ID=330192
Can't really predict whether VW will release a newer version - because in their newer models, VW has already moved on to newer front camera models (2Q0980653 etc). Physically swapping and coding the new 3Q0 camera to match the one installed is quite easy. Parameterization and calibration is what requires factory tool ODIS, VAS6430 calibration board and some appropriate knowledge. Perhaps @kamold can help with that?
kamold
Australia
C?ID=241363
S firmware works, but there are few considerations:
1. the lane assist indicator in the cluster no longer works in the same way. When you turn it on, it no longer goes orange for inactive, then green for active. It stays dark, then it goes orange when it CAN engage, but hasn't got the lines locked yet, then goes to green when active.
2. you cannot downgrade to an earlier version. Camera will be bricked. There are some ways around this however it's not common knowledge (at least to me) and a non-trivial recovery.
3. it DOES fix the camera reboot after 45mins operation bug with HL sw.
2Q0 camera doesn't support PQ, messaging is different.
It's possible there might be a newer 3Q0 camera that supports PQ as the NMS is still being sold. Wouldn't hold your breath but it's a possibity.
nibose
Perth, Australia
C?ID=371170
Whats the difference between a 3QD and 3Q0 camera?
langers2k
C?ID=224085
Sorry for the slight hijack but on the subject of A5 camera firmware etc, I have an Octavia vRS with:
   Part No SW: 3QD 980 654     HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H08 1272
I've seen online there are these files:
- FL_3QD980654_1611_S.odx
- A5_3QD980654A_1611_V03935294WM_0001_Octavia_RS_noTJA.xml
Assuming that a valid update, is there any benefit to 1611 vs 1272? I haven't noticed a TPI/TSB about this firmware version.
That being said, I can't say I've noticed any major issues on 1272 :)
siLc
Tallinn, Estonia
C?ID=330192
This here's a B8 - MQB ;) 2Q0 isn't a real option anyway as that requires a windscreen change as the camera mounting is different.
Supposedly the difference between 3Q0 and 3QD is that the latter is "Made in China" and has a different software index. Also, it was used mainly in Škodas.
kamold
Australia
C?ID=241363
Yeah in this case update to S is probably OK.
But of course at own risk as there is no easy return to previous revision.
nibose
Perth, Australia
C?ID=371170
The funny part is that every other camera related function works fine e.g. DLA, lane assist, pACC etc., Its just the TSR that simply shows the same sign.
The firmware was upgraded to the "L" version because the previous version was not detecting lanes correctly, which meant lane assist wont work as effectively. That's now fixed.
This issue did not exist after the upgrade but after about 1 year. So still related to firmware bug?
