Could not bleed fuel system
teppo
Finland
C?ID=58342
Hi, 2017 T6 with cxgb engine. I'm trying to bleed fuel system but vcds says "Service not supported in active session". Same thing with other basic setting options also. I could not even enter secure code.
hex v2 cable and newest version.
Westbury, UK
Please post an Auto-Scan (full and unedited using the English version of VCDS) so we can see how your T6 is equipped and configured.
teppo
Finland
C?ID=58342
Oh, i have hex+can cable. This might be too old for this ecu.
Friday,25,February,2022,10:00:16:09118
VCDS Version: 21.9.0.2 (x64)
VIN: WV1ZZZ7HZHH079615   License Plate: MARKO
Mileage: 150830km-93721mi   Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 13 15 17 18 19 25 5F 61 69 6E
VIN: WV1ZZZ7HZHH079615   Mileage: 150830km-93721miles
6E-Ctrl Head Roof -- Status: OK 0000
Address 01: Engine (2D2D2-CXGB)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 KA    HW: 04L 907 445
   Component: R4 2.0l TDI   H02 4047
   Revision: 23002001
   Coding: 0011401C633401090000
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_ECM20TDI03004L906056KA 004003
   ROD: EV_ECM20TDI03004L906056KA.rod
   VCID: 76E82590C9E4A3396B-8022
   VINID: 9E606AAAA1D8A986001C918114481E4CDC
13179 - Camshaft Position Sensor (G40)
          P0341 00 [100] - Implausible Signal
                    Mileage: 150780 km
                    Date: 2060.01.10
                    Time: 14:01:54
                    Engine RPM: 814.75 /min
                    Normed load value: 79.2 %
                    Coolant temperature: 87 °C
                    Intake air temperature: 0 °C
                    Voltage terminal 30: 11.742 V
                    P_L_Aps_learning_done_nvv: On
                    HWI_Aps_cam_index: 5
                    P_L_Aps_no_sync_speed: 971.75 /min
                    P_L_Aps_camshaft_drift_angle-Camshaft target wheel drift angle: 0.00 °
                    P_L_Aps_crank_event_num: 35
                    P_L_Aps_mode-APS working mode: P_L_APS_NORMAL
                    P_L_Aps_cam_state-APS cam state: P_L_APS_PATTERN_CONFIRMED
                    P_L_Aps_cam_edge_learn_done: 00
                    P_L_Aps_synchronised_origin-Sync_origin: P_L_APS_SYNC_GAP_CAM
                    P_L_Aps_sync_tasks_enabled: On
33262 - Reductant System Performance Bank 1
          P204F 00 [096] - Malfunction
31103 - SCR NOx Catalyst Bank 1
          P20EE 00 [108] - Efficiency too Low
                    Fault Frequency: 23
                    Mileage: 132680 km
                    Date: 2050.01.09
                    Time: 16:44:34
                    Engine RPM: 2394.25 /min
                    Normed load value: 58.8 %
                    Vehicle speed: 101 km/h
                    Coolant temperature: 91 °C
                    Intake air temperature: 5 °C
                    Voltage terminal 30: 14.890 V
                    Air mass at air mass meter 1: 198.0 kg/h
                    Outside temperature sensor 1: B1: raw value: 3.0 °C
                    Mass airflow sensor 1 bank 1 airflow: raw value: 698.0 mg/stroke
                    Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 0.00 %
                    NOx sensor before SCR cat conv: offset correction factor: 0 ppm
                    NOx sensor after SCR cat conv: offset correction factor: 195 ppm
                    Reducing agent quality sensor: urea concentration: 0.00 %
                    Reducing agent quality sensor: raw temperature value: 0.0 °C
Readiness: N/A
   Revision: 00000000    Serial number: 43026000000667
   Coding: 517E4098256984878A7B0277A48721E678F100
   Shop #: WSC 02739 790 50316
   VCID: 3F8680B4A65E227178-806A
   Serial number: 18101613471559
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF83DB0E1D4EB7933-802A
   Part No SW: 7E0 907 047 AG    HW: 7E0 907 047 AG
   Component: Climatic-T5   H22 0708
   Revision: 00001002
   Coding: 0000000003
   ROD: EV_ClimaT5Basis.rod
   VCID: 6FE610F4B6BE92F1A8-803A
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 309163413
   Coding: A0A0303A0A613432922849742C2B8C548F94708F60444D60320400220840
   Shop #: WSC 02737 022 137743
   VCID: 2A50C1E045DCB7D93F-807E
   Subsystem 1 - Part No SW: 7E0 959 801 M    HW: 7E0 959 801 M
   Component: J386__TSG_FT  003 0653
   Serial number: KU0KU024101662984149
   Coding: 0400A0
   Subsystem 2 - Part No SW: 7E0 959 802 M    HW: 7E0 959 802 M
   Component: J387__TSG_BT  003 0653
   Serial number: KU0KU021101662954103
   Coding: 1400A0
   Subsystem 3 - Part No: 7E1 951 172
   Subsystem 5 - Part No: 7E1 951 172
   Subsystem 6 - Part No SW: 7E0 959 442     HW: 7E0 959 442
   Component: E221__MFL-DC1  H02 0103
   Serial number: 29160002065580086406
   Coding: B0FFFF
03304 - Response Closing Status of Rear Right Door
                    Reset counter: 25
                    Mileage: 141358 km
                    Date: 2021.08.25
                    Time: 14:41:57
   Part No SW: 7N0 907 572 C    HW: 7E0 907 572
   Serial number: 14101604391091
   Coding: 00004800FE0779
   Shop #: WSC 01383 790 50316
   ROD: EV_ACCBEGVW361.rod
   VCID: 3668E5908964E339AB-8062
          U1101 00 [008] - Active
                    Reset counter: 26
                    Mileage: 150832 km
                    Date: 2022.02.25
                    Time: 09:54:02
                    Control Module temperature: 4 °C
                    Voltage terminal 15: 11.3 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
1067 - Brake Temperature
          C10DF 00 [008] - -
                    Reset counter: 253
                    Mileage: 149964 km
                    Date: 2022.02.11
                    Time: 16:40:06
                    Control Module temperature: 24 °C
                    Voltage terminal 15: 14.4 V
                    Vehicle speed: 2.37 m/s
                    Acceleration: -0.80 m/s²
0077 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 26
                    Mileage: 150832 km
                    Date: 2022.02.24
                    Time: 17:45:58
                    Control Module temperature: 6 °C
                    Voltage terminal 15: 9.3 V
1132 - Sensor for Automatic Distance Control
          C110B F0 [008] - Limited Visibility
                    Fault Priority: 9
                    Reset counter: 7
                    Mileage: 150406 km
                    Date: 2022.02.17
                    Time: 06:40:15
                    Control Module temperature: 16 °C
                    Vehicle speed: 15.09 m/s
                    Acceleration: 0.08 m/s²
   Part No SW: 7E0 959 655 G    HW: 7E0 959 655 G
   Component: VW10Airbag020 H08 0018
   Revision: --------    Serial number: 003V3002R3K3
   Coding: 000000000000000000000000000000003230
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3A70F1A0BD7C07594F-806E
   Part No SW: 7E0 920 870 S    HW: 7E0 920 870 S
   Coding: 150B010300
   VCID: 3972EEACB87A0C4146-806C
Address 18: Aux. Heat (J364)       Labels:| 7E0-963-27X-18.clb
   Part No SW: 7E0 963 272 B    HW: 7E0 963 272 B
   Component: STH-T5GP2     003 0009
   Coding: 5C01
   ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
   ROD: EV_AuxilParkiHeateWOST5G2.rod
   VCID: 2B5EC4E44226AED1C4-807E
   Auxiliary heating remote control:
   Subsystem 1 - Part No SW: 3Q0 963 513     HW: 3Q0 963 513
   Component: R64 D208L  004 0401
   Serial number: 00000000000000115617
0036 - Fuel Level too Low
          P1250 00 [008] - -
                    Fault Frequency: 11
                    Reset counter: 17
                    Mileage: 149166 km
                    Date: 2022.02.01
                    Time: 09:41:36
                    Parking heater: operating condition: OFF
                    71
                    Coolant temperature of parking heater: 39 °C
                    Coolant temperature: 52 °C
                    Engine running status: detected
                    Fuel level: 13 l
                    Heating performance: 0 W
0169 - Coolant temperature
          B138E 4B [008] - Over Temperature
                    Reset counter: 20
                    Mileage: 150029 km
                    Date: 2022.02.11
                    Time: 17:53:06
                    Parking heater: operating condition: After-run - burnout
                    92
                    Coolant temperature of parking heater: 88 °C
                    Coolant temperature: 85 °C
                    Fuel level: 65 l
                    Heating performance: 5000 W
   Part No SW: 7E0 909 901     HW: 7E0 937 090
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 042205
   VCID: 68D47BE89B5045C9E9-803C
   Component: IMMO          H03 1104
   VCID: 6AD001E08D5C77D9FF-803E
   Part No SW: 1K8 035 150 H    HW: 1K8 035 150 H
   Component: MU-E--ER      055 7085
   Serial number: 21101600010984
   Coding: 065700003C00000041110001000000001F0000C40000010001
   ROD: EV_MUEnt4CGen2LGE_VW32.rod
   VCID: 2A50C1E04DDCB7D93F-807E
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H81 0744
   Coding: 330B1A73
   Shop #: WSC 02739 790 00000
   Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
   Serial number: 75410903001610181228
   Part No SW: 1K0 907 383 H    HW: 1K0 907 383 G
   Component: Anhaenger     H12 0130
   Revision: 3B001001    Serial number: 00000420071334
   Coding: 410D000103000000
   VCID: 3260D9806D0CFF1987-8066
Address 6E: Ctrl Head Roof (J702)       Labels:. 7E5-919-037-W2.clb
   Part No SW: 7E5 919 037 G    HW: 7E5 919 037 G
   Component: Dachdisplay   H15 0200
   Revision: 10100012    Serial number: 457789
   Coding: 000103
   Shop #: WSC 02759 790 00000
   VCID: 356AE29C9C62E821A2-8060
End-------------------------(Elapsed Time: 03:46)--------------------------
Westbury, UK
A newer interface will give you more complete diagnostics, but your HEX-CAN shows some significant problems on 01, 09, 13 and 18.
What exactly are you trying to do to make this happen?
Have you tried clearing fault codes in the Engine first?
Nah, it should work for this.
teppo
Finland
C?ID=58342
yes, there was errors but i cant bleed fuel system.
Westbury, UK
It is possible that the errors in 01 need to be cleared/solved first?
morecombe
C?ID=156827
Thanks for the info.The access code did not work.I tried the basic setting and got the reply.(controller refused to send a seed).And when i tried the output settings i got (Refused by control module )7F 2F 7F
teppo
Finland
C?ID=58342
For me this code works after i copied that file. Bleeding works but car didnt.
Car wouldnt start after short brake. Timing belt has popped 2 tooth and i have changed belt, waterpump, high pressure pump, filter, diesel tanks was drained and filled with new diesel and meny sensors. Inmjectors has tested and all works fine. Camshaft and rockers are good and no error codes at all. Engine cranks, rail pipe pressure is about 350bar but doesnt run. cxgb engine, 150 000km driven.
Westbury, UK
Have you checked the compression on all cylinders after replacing the timing belt?
Fred's Imports
Vermont, USA
C?ID=16454
Try firing it on propane or a tiny touch of carb cleaner, if it fires then your cam/crank timing should be good, if it doesn't start back at timing.
teppo
Finland
C?ID=58342
Engine runs nice with brake cleaner. I quess ecu doesnt give permission to run and injectors wont open. Couldnt understand why.
Rail presure sensor and both camshaft and crankshaft sensors changed and tested also with originals.
Fred's Imports
Vermont, USA
C?ID=16454
Not being familiar with that engine code have you double, triple checked the high pressure fuel pump timing for accuracy on the timing belt?
teppo
Finland
C?ID=58342
Timing is done with locking tools and couldnt be done wrong. Of course, checked 3 times.
