Help coding MK60EC1 in scirocco
Dcp0228
Chichester, UK
C?ID=353554
Think some body has been playing around with the coding or swapped the abs module because it constantly states incorrectly coded in the abs module.
VCDS Version: 22.3.0.1 (x64)  HEX-NET CB: 0.4613.4
Data version: 20220225 DS336.1
VIN: WVWZZZ13Z9V004484   License Plate: SCIROCCO
Mileage: 156680km-97356mi   Repair Order:
Chassis Type: 13 (1K0)
Scan: 01 03 08 09 14 15 16 17 19 25 42 44 46 4C 52 53 62
VIN: WVWZZZ13Z9V004484   Mileage: 156680km-97356miles
04-Steering Angle -- Status: Not registered 0001
08-Auto HVAC -- Status: Not registered 0011
14-Susp. Elect. -- Status: Not registered 0011
15-Airbags -- Status: Not registered 0011
16-Steering wheel -- Status: Not registered 0011
25-Immobilizer -- Status: Not registered 0011
44-Steering Assist -- Status: Not registered 0011
46-Central Conv. -- Status: Not registered 0011
4C-Tire Pressure II -- Status: Cannot be reached 1100
53-Parking Brake -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Cannot be reached 1100
Address 01: Engine (CAW)       Labels:. 06J-906-026-CAW.clb
   Part No SW: 06J 906 026 AR    HW: 06J 906 026 D
   Component: MED17.5             2718
   Revision: A7H06---    Serial number: VWX7Z0H63NA0D8
   Coding: 0403000318070060
   Shop #: WSC 66565 257 00032
   VCID: 7AB8F6DD3556355F8C-802E
   VINID: 9E69EAAAA043A8998000410810CC588762
001378 - System Voltage
               P0562 - 000 - Too Low - Intermittent
                    Mileage: 156680 km
                    Time: 22:12:32
                    Speed: 255.0 km/h
                    Temperature: 31.0°C
                    Temperature: 24.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 8.382 V
Readiness: 0000 0001
   Part No SW: 1K0 907 379 CD    HW: 1K0 907 379 AD
   Revision: 00H35001
   Coding: 763B60F5092200FE6E0F06EC901D00813000
   Shop #: WSC 16650 210 00001
   VCID: 76A0E2EDC14E513FE8-8022
01486 - System Function Test Activated
                    Reset counter: 71
                    Mileage: 156680 km
                    Count: 3
                    Count: 2
                    Count: 12288
                    Count: 320
                    Count: 45056
                    Reset counter: 71
                    Mileage: 156680 km
                    Count: 3
                    Count: 2
                    Count: 12288
                    Count: 8192
                    Count: 45056
                    Fault Status: 01101000
                    Reset counter: 71
                    Mileage: 156680 km
                    Count: 3
                    Count: 2
                    Count: 12288
                    Count: 8234
                    Count: 45056
   Part No SW: 1K0 907 044 DA    HW: 1K0 907 044 DA
   Component: ClimatronicPQ35 130 1213
   Revision: 00130023    Serial number: 00000000000000
   VCID: 699AB99140F08EC775-803C
00716 - Air recirculation Flap Positioning Motor (V113)
   Revision: 00H54000    Serial number: 00000008671915
   Coding: ED8E8F0300041A0067960E001900000000087F075C400124000000000000
   Shop #: WSC 00020 790 00000
   VCID: 33261BF952BC04170F-8066
   Subsystem 1 - Part No: 1K8 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 190508 022  0602
   Coding: 00038805
   Shop #: WSC 00020
   Component: RLS     030708 054  0402
   Coding: 00208936
   Shop #: WSC 00020
                    Fault Status: 01101100
                    Reset counter: 71
                    Mileage: 156680 km
                    Voltage: 10.85 V
                    Reset counter: 71
                    Mileage: 156680 km
                    Voltage: 11.70 V
                    Reset counter: 71
                    Mileage: 156680 km
                    Voltage: 6.50 V
                    Reset counter: 111
                    Mileage: 156680 km
                    Voltage: 6.50 V
00154 - Windshield Wiper Motor;  Passenger Side (V217)
                    Reset counter: 111
                    Mileage: 156680 km
                    Voltage: 9.60 V
02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
                    Reset counter: 111
                    Mileage: 156680 km
                    Voltage: 9.60 V
Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
   Part No SW: 3C0 907 376     HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0069
   Revision: 00000000    Serial number: 03070800240001
   Coding: 000180
   VCID: 6680B2AD91EEA1BF58-8032
03264 - Functionalty Shut Off
                    Reset counter: 111
                    Mileage: 156680 km
                    Time: 21:46:05
                    Error Code: 9
                    Bin. Bits: 00000000
                    Reset counter: 111
                    Mileage: 156680 km
                    Time: 22:11:14
   Part No SW: 1K0 909 605 AE    HW: 1K0 909 605 AE
   Component: 0H AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 003D1D003GSY
   Coding: 0012360
   VCID: 6FAED7897E1460F72B-803A
   Subsystem 1 - Serial number: 6332MSME3D72386FS
   Subsystem 2 - Serial number: 6342MSME3161655ED
   Subsystem 3 - Serial number: 6352QSME7B2B4B0F
   Subsystem 4 - Serial number: 6362QSME7B2B427F.
            002 - Lower Limit Exceeded - Intermittent - MIL ON
   Part No SW: 1K0 953 549 CB    HW: 1K0 953 549 CB
   Coding: 0002002
   VCID: 74A4D8E51732432FD6-8020
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
   Part No SW: 1K8 920 970 FX    HW: 1K8 920 970 FX
   Component: KOMBIINSTRUMENT VDD 2444
   Revision: V0005000    Serial number: VWX7Z0H63NA0D8
   Coding: 0007403
   Shop #: WSC 00011 888 06946
   VCID: 0D52AD0114D832E7B9-8058
                    Reset counter: 111
                    Mileage: 156680 km
                    Time: 22:12:15
00003 - Control Module
            014 - Defective
                    Fault Status: 01101110
                    Mileage: 153597 km
                    Time: 00:01:46
   Component: J533__Gateway   H16 0202
   Revision:   H16       Serial number: 0000K087220287
   Coding: 19903A000000020002
   VCID: 352225E15CC81A2721-8060
                    Reset counter: 71
                    Mileage: 156680 km
                    Time: 22:12:39
                    Reset counter: 71
                    Mileage: 156680 km
                    Time: 22:13:43
03109 - Tire Pressure Monitoring Control Module 2 (J793)
                    Reset counter: 71
                    Mileage: 156680 km
                    Time: 22:13:48
                    Reset counter: 71
                    Mileage: 156680 km
                    Time: 22:13:48
   Component: IMMO            VDD 2444
   Shop #: WSC 26432 001 1048576
            014 - Defective
                    Mileage: 139212 km
                    Time: 16:45:47
   Part No SW: 1Q0 959 701 F    HW: 1Q0 959 701 F
   Component: Tuer-SG         008 2018
   Coding: 0016949
   VCID: 373E2FE946C4E83733-8062
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 185    2301
   Revision: 00H15000
   VCID: 2A18069D857645DFBC-807E
00750 - Warning Lamp
                    Fault Status: 11101101
                    Voltage: 8.13 V
                        PD
                    Temperature: 23.0°C
                    RPM: 170 /min
                    Speed: 50.0 km/h
                    Speed: 50.0 km/h
   Component:    KSG PQ35 G2  020 0205
   Coding: 81900A0002830C7F3F04840570085ACE903C00
   VCID: 03468B39429C7497DF-8056
   Subsystem 2 - Part No: 1K8 951 171
   Component: DWA-Sensor      001 0104
                    Fault Status: 01100101
                    Reset counter: 71
                    Mileage: 156680 km
                    Time: 21:31:55
                    Reset counter: 71
                    Mileage: 156680 km
                    Time: 21:31:57
                    Reset counter: 71
                    Mileage: 156680 km
                    Time: 22:12:53
   Part No SW: 1Q0 959 702 H    HW: 1Q0 959 702 H
   Component: Tuer-SG         009 2124
   Coding: 0016948
   Shop #: WSC 00712 210 88117
   VCID: 3A3836DD75D6F55FCC-806E
Address 53: Parking Brake
Address 62: Door, Rear Left
End----------(Elapsed Time: 01:07, VBatt start/end: 13.8V/13.8V)-----------
Dcp0228
Chichester, UK
C?ID=353554
Forgot to ask if some body can supply the correct coding please.
JMR
Romania
C?ID=432218
try this one , but you might have to change something in the coding helper to get it right for the RHD
743B40F5092200FE2E0F02EC901D00423000
Dcp0228
Chichester, UK
C?ID=353554
Thanks. I’ll give it a go
Reactions: JMR
etz2k
C?ID=69430
@JMR this Scirocco has a 2.0TSI (CAW) engine, why shoud he code for the D288mm brake if he has the D312mm? Please stop posting things where you have no knowledge, this is bullshit.
@Dcp0228 the coding of your gateway is wrong. You have no J540 (Address 53), no J793 (Address 4C) and no rear doors (Address 62). Correct this, clear all DTCs and scan again.
There are many things wrong, but your ABS coding seems to be correct. :thumbs: You have VCDS, start using it.
JMR
Romania
C?ID=432218
@etz2k - now listen man, i ve just about had it with your attitude and i am not willing to take it anymore. I have told you in a previous post that i am using a website which is available free for all VCDS registered users here :
https://diagnostics.vis4vag.com/.
Some users don't register with the site, be it from no knowledge of it or not having the time to do so.
I am here willing to help where possible with my little bit of knowledge and if i can help someone i am happy ! If the site calculates a wrong coding , there is no harm in trying it. I've been able to give a correct coding to few users using that site regarding mk60ec1..... SOMETIMES THE CODING IS NOT CORRECT AND IT'S NOT MY FAULT ! If a user tries it and it is incorrect , then there is no harm done. I am willing to try and help and give time from my time to this forum when it's possible. Nobody pays me for it, i do it along just like any other users, i am learning stuff , other users are learning stuff, it's called exchange of information. I believe that i've helped few users so far but sometimes I cannot know it all . . Now you can take your attitude and stuff it where the sun don't shine ..you are completely devoid of any respect towards my intentions and it's not cool. Please spare me of your know it all attitude, ok ? This is like the 3rd or 4th time where you have been a complete asshat but i just played it cool and did not say anything about it..furthermore i even mentioned your name in couple posts to have your input/experience in abs coding while giving you the credit for your knowledge. I call that respect ! Have the courtesy to extend the same respect for my intentions even it the coding provided was not correct. Please do not reply to my posts anymore, just provide your help if you can and ignore me and my advice if you are feeling that it's wrong.
etz2k
C?ID=69430
@JMR you are a very friendly guy, who wants to help everyone, that is very nice. But there is a saying in germany "Schuster bleib bei deinen Leisten". And i think that codings for a safety part like the ABS should not so easy posted if it doesn't fit the car. The ABS do not check all things of the code. If the vin depend digits are ok and some simple coding rules are observed, it will accept it. But this doesn't mean it fits the car. And if in a critical situation the ABS/ESP isn't working like it should can influence the healthiness of the driver and other people (the car is no track toy and the driver is not Sebastien Orgier)
@PetrolDave maybe my words are a little harsh (sorry), but if people don't think about possible negativ consequences, is what's me feeling sad. And if the posted v4v codings are not correct is not my fault.
Nice weekend guys
JMR
Romania
C?ID=432218
Based on your saying then this forum should be closed . We should all stick to whatever and take the car to dealerships.
My point is ...we are all here to help each other and sometimes the help is "precise "and sometimes the help "is in the area of". All i am asking is that you should refrain from 'talking down' a user and if you have something to say /help just do it without being arrogant. As i've mentioned, sometimes V4V gives correct codings and sometimes does not. I'd say about 50/50 good/bad codings , but hey...it's a work in progress on their part and a work in progress on our part.
I'd take 50/50 odds anyday over no odds being presented. Thanks, i hope you understand my point of view while i respect and i understand your point of view . We can't all be experts but from many heads comes the right answer.
As a matter of fact, since you have such a good expertise in abs coding/retrofit abs parts , you should open a paid site and provide codings for a cost , it'll bring you monetary satisfaction and at the same time perhaps even a " feel good about being able to help with correct info " satisfaction. I am sure that some users will gladly pay 5-10 USD/euros for a first correct abs/whatever system coding.
Have a nice weekend too.
etz2k
C?ID=69430
@JMR please don't be so offended.
There are many things i have no clue and where i can't help and you know it much better. I only have spend a lot of time coding the MK60EC1, because i needed it for my project. My intention is to help people that also have problems with the MK60EC1 coding, as good as i can. Where did i write i wll earn money with it, please don't write so stupid things, only because you are a little bit angry. I only think that the coding for ABS should be a bit more precise than 50/50, because of the safety aspect, maybe i'm wrong and you are right. I will hold back.
JMR
Romania
C?ID=432218
I think that my suggestion for you to use your expertise and make some money outside of this forum if you so wish got lost in translation or you misintepreted what i said. I blame it either on my bad command of the english language or on your bad command of the english language though i am affraid it is the latter part of it. Anyway , i don t condone 50/50 codings , there is no such thing. If a coding is not correct it will not stick . I said that the site will give 50 /50 bad or good codings. Anyway , let s drop the matter before we both get banned from this forum.
Westbury, UK
Nor is it the fault of JMR.
In many cases the codings provided by v4v are correct, but as no system/person/organisation is perfect they cannot be guaranteed. Even Ross-Tech's own most experienced generator of ABS codings (Dana) doesn't get it right 100% of the time. Given the way that VAG feel the need to protect the coding information it's not surprising that it can take a few attempts to get the coding right in every case.
As JMR says "If a coding is not correct it will not stick" so a wrong coding leaves the member in no better or worse a situation than they were before.
Anyway, time to return to the original subject - generating an ABS coding for Dcp0228 ...
  • Agree
Reactions: JMR
etz2k
C?ID=69430
Like i write, i don't think Dcp0228 has a problem with the ABS coding. There are so many faults in his scan that should be eleminated before searching the problem in the ABS coding.
Anyway, because we write about the MK60EC1.
JMR says it, but that's unfortunately not right. I tested many things on the MK60EC1.
Please read my text.
There e ABS do not check all things of the code. If the vin depend digits are ok and some simple coding rules are observed, it will accept it.
For example, the ABS can't check if you select the correct brake system parts.
As long as you don't get in an situation where the ABS,ESC,etc becomes active you won't notice a difference. You only get an error if it check for a sensor or modul that is not available. That's also the problem if you want to find out which Byte/Bit has which function. Very often you get no DTC because it's a "intern" function.
In the next days i try to post my LBL, with the things i find out. I hope WE can sort some uncertainties out, because not all seems PR-CODE related or i only don't see the correlation. The coding is also different with other ABS SW/HW version.
Westbury, UK
OK this is my last post in this thread as IT"S GOING TOO FAR OFF TOPIC AND NOT HELPING Dcp0228 with his Scirocco.
If we accept that the quote above is correct then generating coding for the MK60EC1 should be fairly simple, but even a cursory glance on this forum will show that is not the case as almost every thread asking for MK60EC1 coding needs multiple attempts to get a coding that is accepted.
I'm sure we all look forward to you sharing your findings with the community, especially if it results in a 'right first time' generation of MK60EC1 codings.
Sharing helps everyone, some of the language in earlier posts in this thread does not help anyone. Let's ALL move on...
  • Agree
Reactions: JMR
I concur. Just because the module accepts a coding and doesn't complain that it's incorrectly coded doesn't mean that coding is correct for the module -- and that assumes the module is correct for the car.
Then we get into further complications with people throwing some random, used MK60EC1 from the scrap yard into their car with no regard for whether that module is appropriate for their car or not.
It sure would be nice if VW was more open with info. Give us a website that accepts a VIN and tells us what ABS module part numbers are appropriate and what the coding should be for that car. This wouldn't be difficult for them to do.
JMR
Romania
C?ID=432218
So..i shouldn't try and provide anymore codings by v4v ? Or should pe.provided with a disclaimer ? Whatever you feel it s right..i ll abide by it.
I think a disclaimer would be appropriate. :thumbs:
etz2k
C?ID=69430
VAG is not nice and open !;)
My Cousin is working for a company group which made and test prototyp cars for VAG (Golf GTI W12), but with the MK60EC1 he can't help me, because today everything is only online with access rights and every access will be registerd, he says.
Yes, I am painfully aware of this. They give us only what they think they absolutely have to. :(
