- Mar 16, 2022
- 10
- 7
- Rochester, NY, USA
- C?ID=512474
AutoScan: WVWFB7CD8NW129409
blockmap-01-5H0-906-259-A_WVWFB7CD8NW129409-20220317-1138.CSV
blockmap-03-5WA-614-517-BL_WVWFB7CD8NW129409-20220317-1139.CSV
blockmap-05-5WA-959-436-J_WVWFB7CD8NW129409-20220317-1140.CSV
blockmap-08-5WA-907-007-Q_WVWFB7CD8NW129409-20220317-1140.CSV
blockmap-09-5WA-937-086-N_WVWFB7CD8NW129409-20220317-1141.CSV
blockmap-10-5WA-919-298-B_WVWFB7CD8NW129409-20220317-1146.CSV
blockmap-13-5WA-907-572-B_WVWFB7CD8NW129409-20220317-1147.CSV
blockmap-14-1EA-907-376-B_WVWFB7CD8NW129409-20220317-1147.CSV
blockmap-15-5WA-959-655-M_WVWFB7CD8NW129409-20220317-1147.CSV
blockmap-17-5H0-920-340-B_WVWFB7CD8NW129409-20220317-1135.CSV
blockmap-19-5WA-907-530-Q_WVWFB7CD8NW129409-20220317-1136.CSV
blockmap-23-5WA-909-059-K_WVWFB7CD8NW129409-20220317-1148.CSV
blockmap-2B-2Q0-905-861-B_WVWFB7CD8NW129409-20220317-1148.CSV
blockmap-36-5WA-959-760-H_WVWFB7CD8NW129409-20220317-1148.CSV
blockmap-3C-2Q0-907-686-E_WVWFB7CD8NW129409-20220317-1149.CSV
blockmap-42-5Q0-959-593-L_WVWFB7CD8NW129409-20220317-1149.CSV
blockmap-44-5WA-907-145-G_WVWFB7CD8NW129409-20220317-1150.CSV
blockmap-47-5H0-035-456-A_WVWFB7CD8NW129409-20220317-1150.CSV
blockmap-4B-5WA-907-338-B_WVWFB7CD8NW129409-20220317-1151.CSV
blockmap-4B-5WA-907-338-B_WVWFB7CD8NW129409-20220317-115135.CSV
blockmap-52-5Q0-959-592-L_WVWFB7CD8NW129409-20220317-1151.CSV
blockmap-5F-5H0-035-877_WVWFB7CD8NW129409-20220317-1152.CSV
blockmap-6C-5WA-980-556-C_WVWFB7CD8NW129409-20220317-1153.CSV
blockmap-75-5WA-035-285-A_WVWFB7CD8NW129409-20220317-1154.CSV
Thursday,17,March,2022,12:23:01:62242
VCDS Version: 22.3.0.1 HEX-V2 CB: 0.4613.4
Data version: 20220225 DS336.1
VIN: WVWFB7CD8NW129409 License Plate:
Chassis Type: CD-VW38 (5WA)
Scan: 01 03 05 08 09 10 13 14 15 17 19 23 2B 36 3C 42 44 47 4B 4B
52 5F 6C 75 82 A5 A9 CA D6 D7 811E 811F 8120 8121 8126 8127 C002 C003
VIN: WVWFB7CD8NW129409 Mileage: 3969km-2466miles
CA-Sunroof -- Status: OK 0000
8126-Trq distrib RearL axle -- Status: Malfunction 0010
8127-Trq distrib RearR axle -- Status: Malfunction 0010
Address 01: Engine (J623-DSFF) Labels: None
Part No SW: 5H0 906 259 A HW: 06K 907 425 N
Component: R4 2.0l TFSI H08 0001
CVN: 49368980
Coding: 091900322466000E30040000000000000000000000000000
ASAM Dataset: EV_ECM20TFS0205H0906259A 001002
ROD: EV_ECM20TFS0205H0906259A.rod
VCID: 2D0707FDFD9E0C43544-8078
VINID: 9E69D64874D421E9C108910024B5F37EE7
23043 - Implausible Data Received from Body Control Module (Central Electric)
U0422 00 {032} - -
Reset counter: 22
Mileage: 2996 km
Date: 2022.03.05
Time: 16:07:35
Engine RPM: 1197.25 /min
Normed load value: 2.7 %
Coolant temperature: 77 °C
Intake air temperature: 30 °C
Voltage terminal 30: 12.031 V
Unlearning counter according OBD: 22
LF_MVB_PDU_INTC_DIAG_15: 0
LF_MVB_PDU_INTC_DIAG_16: 0
LF_MVB_PDU_INTC_DIAG_17: 0
LF_MVB_PDU_INTC_DIAG_18: 0
LF_MVB_PDU_INTC_DIAG_19: 0
LF_MVB_PDU_INTC_DIAG_20: 0
LF_MVB_BUS_INTC_DIAG: 256
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 5WA 614 517 BL HW: 5WA 614 517 N
Component: ESC H13 0133
Serial number: 62101000000072 CVN: 55355CF4
Coding: 76FC6E9076226E75527B6E0076CC60064A525A50528803C02014B831018FF100002814
ASAM Dataset: EV_Brake1ESCEPBMQB37W 013056
ROD: EV_Brake1ESCEPBMQB37W_013.rod
VCID: 1373B1057BFABAB3620-8046 SFD
1905 - Transport Mode Active
U1105 00 {032} - -
{Transport_mode_active}
590080 - Release / Enable Active
B184C 00 {040} - -
{Unlock_protection_of_vehicle_diagnosis_active}
Reset counter: 38
Mileage: 1729 km
Date: 2022.02.25
Time: 14:37:11
Vehlicle_speed: 0.0 km/h
Resolution Mileage: 642 m
Voltage_value_KL.30_ESC_V: 12.4 V
Wake up EPB: not active
Wake up CAN: not active
Postrun_activ: not active
Comparison_pressure_sensor: completed successfully
Comparison_longitudinal_accleration: completed successfully
Comparison_transverse_accleration: not completed successfully
Comparison_yaw_rate_sensor: completed successfully
LWS_comparison: completed successfully
Internal_failure_code: 01 AE
00 00 40 00 04 0C 10 08 80 00 00 00 80 00 00 40 30 00 21 00 04
Address 05: Acc/Start Auth. (J518) Labels: 5WA-959-436.clb
Part No SW: 5WA 959 436 J HW: 5WA 959 436 J
Component: Kessy IOBOX 100 0723
Serial number: ---------------
ASAM Dataset: EV_Kessy37w 004023
ROD: EV_Kessy37w_004.rod
VCID: 5BE39925D3AAB2F3FA0-800E
Address 08: Auto HVAC (J979) Labels:* None
Part No SW: 5WA 907 007 Q HW: 5WA 907 007 Q
Component: AC Automat H31 3440
Coding: 002000110210120011101010111111110000131100200100000000000000
ASAM Dataset: EV_ACClimaPREVW38X 001100
ROD: EV_ACClimaPREVW38X_VW38.rod
VCID: 55F78F1DB58E6483CC4-8000
Air quality sensor:
Subsystem 1 - Part No SW: 5Q0 907 659 D HW: 5Q0 907 659 D
Component: G238 _AQS H02 0003
Serial number: 00000000010000011776
Rear A/C control head:
Subsystem 2 - Part No SW: 11A 907 049 A HW: 11A 907 049 A
Component: E265 KPH SH H02 0183
Serial number: G04S28.09.2100970591
Interior temperature sensor:
Subsystem 3 - Part No SW: 5WA 907 527 A HW: 5WA 907 527 A
Component: E857 H01 0103
Serial number: 00001060721160552510
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5WA 937 086 N HW: 5WA 937 086 N
Component: BCM37w_H026 0174
Serial number: BXJ53F020921940
ASAM Dataset: EV_BCM37w 007001
ROD: EV_BCM37w_007.rod
VCID: 5CE19A39D6A4B5CBF3A-8008 SFD
Subsystem 1 - Part No SW: 5H1 955 119 A HW: 5H1 955 119 A
Component: FWISCHER_MYJT 003 0051
Serial number: 907453F0302119007238
Subsystem 2 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 054 0206
Serial number: SBY21M08D12H15M26S50
Subsystem 3 - Part No SW: 5H0 941 193 AL HW: 5H0 941 193 AL
Component: LiSi H06 0008
Serial number: 92471UHI001C6
Subsystem 4 - Part No SW: 5H0 925 200 R HW: 5H0 925 200 R
Component: DiETa H07 0008
Serial number: 92471UG20007M
Subsystem 5 - Part No SW: 5H0 959 561 AS HW: 5H0 959 561 AS
Component: DACHKONSOLE 006 0007
Serial number: 92413UHN00501-------
Subsystem 6 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Component: SysNameFanLin 014 0102
Serial number: ESE2570087
Subsystem 7 - Part No SW: 3G0 963 345 A HW: 3G0 963 345 A
Component: SysNameFanLin 015 0102
Serial number: ESE2795934
Subsystem 8 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE2648308
Subsystem 9 - Part No SW: 3G0 963 345 A HW: 3G0 963 345 A
Serial number: ESE2795999
Steering Column Switch:
Subsystem 10 - Part No SW: 5Q1 953 507 GB HW: 5Q1 953 549 F
Component: J527 SMLS MQB 005 0080
Serial number: 00000001092108490625
1074443 - Electrical Steering Column Lock
B1248 F3 {040} - Terminal Release Implausible
Reset counter: 9
Mileage: 3568 km
Date: 2022.03.13
Time: 16:08:57
Terminal 15 status: OFF
Terminal 50 status: OFF
Engine run: OFF
Status of brake lamp switch: discrete: OFF
Brake lamp switch via CAN: status: OFF
Voltage: 12.5 V
Outside temperature: 17.0 °C
Light switch position: automatic
15403264 - Release / Enable Active
B184C 00 {040} - -
{Freischaltung aktiv}
Reset counter: 33
Mileage: 3705 km
Date: 2022.03.16
Time: 08:18:08
Terminal 15 status: On
Engine run: On
Voltage: 14.6 V
Outside temperature: 2.0 °C
Role of vehicle diagnostic to be protected: Basic
Type of vehicle diagnostic to be protected: Short: time-controlled
Status of vehicle diagnostic to be protected: SFD individualization feature set
Duration of vehicle diagnostic to be protected: 89 min
Address 10: Park/Steer Assist (J446) Labels:* None
Part No SW: 5WA 919 298 B HW: 5WA 919 298
Component: PLA 12 Kanal H05 0578
Serial number: 000030082194560
Coding: 0200026001
ASAM Dataset: EV_EPHBO2CVW3800000 002028
ROD: EV_EPHBO2CVW3800000_VW38.rod
13688835 - Databus
U1123 00 {040} - Received Error Message
{Steuergerät für Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen}
Reset counter: 20
Mileage: 3568 km
Date: 2022.03.13
Time: 17:30:12
13959169 - Parking Sensor(s); Front
B10FC F0 {040} - Function Limitation due to External Factors
{Geber für Einparkhilfe - Schmutz bzw. Eisbildung vorn}
Reset counter: 11
Mileage: 3478 km
Date: 2022.03.11
Time: 19:53:21
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 5WA 907 572 B HW: 5WA 907 572
Component: ACC Bosch MQB H20 0395
Coding: 06230096500680451247400000004004AE4020000000000000000000000000
ASAM Dataset: EV_FRONTRADARBOSCHVW380 004017
ROD: EV_FRONTRADARBOSCHVW380_004_VW38.rod
VCID: 4DC7677D9D5E2C43744-8018
17 Faults Found:
1089 - Databus
U1121 00 {040} - Missing Message
{FAULT_TIMEOUT_ESP_10}
Reset counter: 34
Mileage: 3568 km
Date: 2022.03.13
Time: 17:30:11
1092 - Databus
{FAULT_TIMEOUT_ESP_21}
Reset counter: 34
Mileage: 3568 km
Date: 2022.03.13
Time: 17:30:11
0110 - Transport Mode Active
U1105 00 {032} - -
1396 - Sensor for Automatic Distance Control
C110B F0 {040} - Limited Visibility
{FAULT_SENSOR_NO_FREE_SIGHT}
Reset counter: 10
1538 - Sensor for Automatic Distance Control
{FAULT_SENSOR_BLINDNESS}
Reset counter: 30
Mileage: 2238 km
Date: 2022.02.27
Time: 15:18:25
1561 - Databus
{FAULT_BV_AVAILABILITY_ERROR}
Reset counter: 34
Mileage: 3568 km
Date: 2022.03.13
Time: 17:30:11
209054 - Databus
{FAULT_BV_BLINDNESS_ERROR}
Reset counter: 29
Mileage: 920 km
Date: 2022.02.21
Time: 18:50:29
0522 - Databus
{FAULT_TIMEOUT_ESC_50}
Reset counter: 34
Mileage: 3568 km
Date: 2022.03.13
Time: 17:30:11
0523 - Databus
{FAULT_TIMEOUT_ESC_51}
Reset counter: 34
Mileage: 3568 km
Date: 2022.03.13
Time: 17:30:11
0534 - Databus
{FAULT_TIMEOUT_VMM_01}
Reset counter: 34
Mileage: 3568 km
Date: 2022.03.13
Time: 17:30:11
0535 - Databus
{FAULT_TIMEOUT_VMM_02}
Reset counter: 34
Mileage: 3568 km
Date: 2022.03.13
Time: 17:30:11
0578 - Databus
U1122 00 {040} - Implausible Message
{FAULT_APS_BLINDNESS_DETECTED}
Reset counter: 31
Mileage: 1704 km
Date: 2022.02.25
Time: 07:19:19
0616 - Databus
{FAULT_QBIT_TRANSVERSE_ACCELERATION_INVALID}
Reset counter: 34
Mileage: 2905 km
Date: 2022.03.04
Time: 11:58:31
0790 - Databus
{FAULT_RB_PER_HV_OOS_SERVICE}
Reset counter: 34
Mileage: 3568 km
Date: 2022.03.13
Time: 15:21:40
0800 - Databus
{FAULT_SWA_RELEVANT_ERROR}
Reset counter: 34
Mileage: 3568 km
Date: 2022.03.13
Time: 15:21:40
0822 - Databus
{FAULT_QBIT_LONGITUDINAL_ACCELERATION_INVALID}
Reset counter: 34
Mileage: 2905 km
Date: 2022.03.04
Time: 11:58:31
0828 - Databus
{FAULT_QBIT_YAW_RATE_INVALID}
Reset counter: 34
Mileage: 3568 km
Date: 2022.03.13
Time: 15:21:40
Address 14: Susp. Elect. (J250) Labels: 1EA-907-376.clb
Part No SW: 1EA 907 376 B HW: 1EA 907 376
Component: DAEMPFUNGS-SG H05 0456
Serial number: 2C7673241129042
ASAM Dataset: EV_DCC3CONTITEMIC 002006
ROD: EV_DCC3CONTITEMIC.rod
VCID: 392F23AD39D6A0E3C8C-806C
Address 15: Airbags (J234) Labels:* None
Part No SW: 5WA 959 655 M HW: 5WA 959 655 M
Component: AirbagVW40 007 0636
Serial number: 000000003C0J3R7
Coding: 8CCC000000FCC00000000000000000005100000000000000000036F800130065
ASAM Dataset: EV_AirbaVW40SMEVW38X 001032
ROD: EV_AirbaVW40SMEVW38X.rod
VCID: 619FABCDF1C69823A0C-8034 SFD
Component: ------------- H16 0022
Serial number: IBH00000000000GQV0ND
Subsystem 2 - Part No SW: ----------- HW: 480 400 809 21
Component: SideSensor_Dr 003 6149
Serial number: 3510001BEC5F15A8D91S
Subsystem 3 - Part No SW: ----------- HW: 480 400 809 21
Serial number: 35200019B05021A3428N
Subsystem 4 - Part No SW: ----------- HW: 480 001 008 21
Serial number: 35700000000C90A0A75P
Subsystem 5 - Part No SW: ----------- HW: 480 000 708 21
Serial number: 3580000000096281365D
Subsystem 6 - Part No SW: ----------- HW: 480 400 609 21
Component: FrontSensor_D 003 614A
Serial number: 3550001BEC5F15A5D94W
Subsystem 7 - Part No SW: ----------- HW: 480 400 609 21
Component: FrontSensor_P 003 614A
Serial number: 3560001A0C5C1B7558FK
1054208 - Databus
U1121 00 {008} - Missing Message
{NWD: 0x3C0 Klemmen_Status_01 Timeout}
Reset counter: 84
Mileage: 3486 km
Date: 2022.03.11
Time: 20:04:11
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 5H0 920 340 B HW: 5H0 920 340 B
Component: KOMBI 220 5350
Coding: 08BC02027B9CCF050280620B2000000810300000
ASAM Dataset: EV_DashBoardVDDMQB37W 003033
ROD: EV_DashBoardVDDMQB37W_003_VW38.rod
VCID: 211FEBCDB146D823E0C-8074
16777018 - Control unit for information electronics 1
U1054 00 {008} - No Communication
{Audio_0x31 communication error bap_error_timeout heartbeat}
Fault Frequency: 12
Reset counter: 93
Mileage: 9 km
Date: 2022.02.15
Time: 01:51:09
16777020 - Control unit for information electronics 1
{TEL_0x28 communication error bap_error_timeout heartbeat}
Reset counter: 63
Mileage: 9 km
Date: 2022.02.15
Time: 01:51:09
16777022 - Control unit for information electronics 1
{NAV_SD_0x32 communication error bap_error_timeout heartbeat}
Fault Frequency: 8
Reset counter: 70
Mileage: 9 km
Date: 2022.02.15
Time: 01:51:09
16711686 - Secure Onboard Communication
U14FE 00 {008} - Signature Verification Failed
{SOK_signature_verification_failed}
Fault Frequency: 34
Mileage: 10 km
Date: 2022.02.19
Time: 00:05:25
Part No SW: 5WA 907 530 Q HW: 5WA 907 530 G
Component: GW2020 High 756 7099
Revision: -------- Serial number: 771049050021301
Coding: 0000800D0E00000000000000010303307302610902000300030100000001010000000000000000000000000000000000
GVL: 3D080000020840DC800080824C00104000404002004000300200000000000044
ASAM Dataset: EV_GatewMQB2020 005011
ROD: EV_GatewMQB2020_VW38.rod
VCID: 56F58811A8886F9BC5E-8002 SFD
Generator:
Component: 5-00-14-00-04
Subsystem 2 - Part No SW: 5WA 915 181 C HW: 5WA 915 181 C
Component: J367-BDMHella H11 9080
Serial number: 5474838205
Subsystem 3 - Part No SW: 1EA 959 442 C HW: 1EA 959 442 C
Component: MFL H03 0217
Serial number: 17038315051762101091
Subsystem 4 - Part No SW: 5H0 959 542 J HW: 5H0 959 542 J
Component: KLR_JSS_1Zone 076 0022
Serial number: 3133020AB21234085803
9 Faults Found:
1049254 - Ethernet Databus Branch 6
U1231 00 {040} - No Communication
{Ethernet_databus_no_communication_branch_6_/_port_7}
Reset counter: 35
Mileage: 3650 km
Date: 2022.03.15
Time: 19:01:26
2494569 - Ethernet Module for Back-Up Cam
U1643 00 {100} - No Communication
{Rearview_camera_system_control_module_no_communication_vlan}
Fault Frequency: 0
Reset counter: 0
2498675 - Ethernet Module for Information Electronics 1
U1645 00 {032} - No Communication
{Information_electronics_control_module_1_no_communication_vlan}
Fault Frequency: 0
Reset counter: 0
12320 - Transport Mode Active
U1105 00 {032} - -
Fault Frequency: 0
Reset counter: 0
8397571 - LV Energy Management
B1802 F1 {032} - Warning Triggered
Fault Frequency: 0
Reset counter: 0
8397826 - Crash Shut-Down
B189C F0 {032} - Active
Fault Frequency: 0
Reset counter: 0
B184C 00 {040} - -
Reset counter: 34
Mileage: 3705 km
Date: 2022.03.16
Time: 08:18:34
8466689 - VKMS
B18B0 F0 {032} - Missing Adaptation
{VKMS_new_download_container_required_due_to_vehicle_change}
Fault Frequency: 0
Reset counter: 0
8398594 - Control unit for battery monitoring
U1050 00 {032} - No Communication
{BDMs_FuSi_no_communication}
Fault Frequency: 0
Reset counter: 0
Address 23: Brake Booster (J539) Labels: None
Part No SW: 5WA 909 059 K HW: 3Q0 909 059 D
Component: EBKV H09 0307
Serial number: BPA085170921013
Coding: 5003C5409B00009C73CE39E7000049922449922400
ASAM Dataset: EV_BrakeBoostG2BoschVW37W 016028
ROD: EV_BrakeBoostG2BoschVW37W_016.rod
VCID: 58E98629A29C59EBD72-800C SFD
1024304 - Release / Enable Active
B184C 00 {040} - -
{SECDIAG_ROLE_UNLOCKED}
Reset counter: 38
Mileage: 3568 km
Date: 2022.03.13
Time: 16:02:20
1024368 - Unknown Error Code
C1187 F6 {040} - Unknown Error Elaboration
{ActiveRestrictionDetected}
Reset counter: 16
Mileage: 3650 km
Date: 2022.03.15
Time: 08:06:33
Part No SW: 2Q0 905 861 B HW: 2Q0 905 861 B
Component: ELV-MQBB H09 0040
Serial number: 21000256365012
Coding: 0000000000000000
ROD: EV_ELVMarqMQBA0_VW27.rod
VCID: 323D1481E4A053BB096-8066
Part No SW: 5WA 959 760 H HW: 5WA 959 760 H
Component: MEM-FS 009 0362
Serial number: 2181601KA02625
Coding: 01589A40000020408803010101010000000000212100000000000000215000
ROD: EV_SCMDriveSideCONTIAU736_006.rod
VCID: 59EF832DD99640E3E8C-800C
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 E HW: 2Q0 907 686 E
Component: HRE_Master H25 0284
Serial number: 00000586091853
Coding: 569945D0
ASAM Dataset: EV_HREntryHellaGen3Mstr 001015
ROD: EV_HREntryHellaGen3Mstr.rod
VCID: 3C213AB936E495CBD3A-8068
Subsystem 1 - Part No SW: 2Q0 907 685 E HW: 2Q0 907 685 E
Component: HRE_Slave H25 0284
Serial number: 00000586400366
Lane change assistance display left:
Subsystem 2 - Part No SW: 5H1 949 145 HW: 5H1 949 145
Component: SWA LED VL H05 0005
Serial number: 00000000000016909060
Lane change assistance display right:
Subsystem 3 - Part No SW: 5H1 949 146 HW: 5H1 949 146
Component: SWA LED VR H05 0005
1245184 - Transport Mode Active
U1105 00 {032} - -
{The transportation mode is active}
2240563 - Databus
{databus error value received - ESC_50 - ESP_QBit_Gierrate}
Reset counter: 32
Mileage: 3568 km
Date: 2022.03.13
Time: 15:21:40
2236439 - Databus
U1121 00 {046} - Missing Message
{databus message missing - AMP_01}
Mileage: 3969 km
Date: 2022.03.17
Time: 11:29:13
Part No SW: 5Q0 959 593 L HW: 5Q0 959 593 F
Component: TSG FS003 0350
Serial number: YE007UJU17143
Coding: 003B13208200040000000000
VCID: 4ACD6C616C303B7B516-801E
Subsystem 1 - Part No SW: 5Q0 959 408 G HW: 5Q0 959 164 C
Component: FOND_FHSG_DRV 007 0011
Serial number: 00000000000053333748
Coding: 111000
Part No SW: 5WA 907 145 G HW: 5WA 907 145 C
Component: BASGEN1MQB37 502 1040
Serial number: 00636441
Coding: 0000000000000001000002010100010000000100010101
ROD: EV_SteerAssisBASGEN1MQB37_007_VW38.rod
VCID: 4EC560719058175B0DE-801A
1350 - Databus
U1123 00 {032} - Received Error Message
{DTC_ESP_QUERBESCHLEUNIGUNG_QBIT}
1356 - Databus
{DTC_ESP_GIERRATE_QBIT}
Part No SW: 5H0 035 456 A HW: 5H0 035 456 A
Component: AMPeth12C H06 4316
Serial number: A1129C00070995
Coding: 23000000000000000000000000000000000000000000000000
ASAM Dataset: EV_AMPEthMQB37w 001005
ROD: EV_AMPEthMQB37w_VW38.rod
VCID: 2517FFDDA56E34039C4-8070 SFD
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 5WA 907 338 B HW: 5WA 907 338
Component: FCM2020 Low 014 1447
Serial number: 250151221406327
Coding: 000000000900071206112310040003070300000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW38X 004012
ROD: EV_MultiModulContiVW38X.rod
VCID: 4DC7677D9D5E2C43744-8018 SFD
B184C 00 {008} - -
Mileage: 3705 km
Date: 2022.03.16
Time: 08:18:58
B184C 00 {008} - -
Mileage: 3705 km
Date: 2022.03.16
Time: 08:18:58
Part No SW: 5Q0 959 592 L HW: 5Q0 959 592 F
Component: TSG BFS003 0350
Serial number: YE007UJT0256B
Coding: 003B13208E00040000800000
VCID: 49CF536D6936306358C-801C
Subsystem 1 - Part No SW: 5Q0 959 407 G HW: 5Q0 959 163 C
Component: FOND_FHSG_PSG 007 0011
Serial number: 00000000000053197012
Coding: 091000
Part No SW: 5H0 035 877 HW: 5H0 035 877
Component: MU-O-NS-US H56 1880
Serial number: WG8LGM230721000
Coding: 23800000000100000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB37w 001002
ROD: EV_MUOIMQB37w_VW38.rod
VCID: 6B83C9E5030AC2730A0-803E SFD
Subsystem 1 - Part No SW: 5H0 919 605 B HW: 5H0 919 605 B
Component: ABT_W_10 H42 3080
Serial number: VDD02408082112210098
Address 6C: Back-up Cam. (J772) Labels:* None
Part No SW: 5WA 980 556 C HW: 5WA 980 556 B
Component: RV eCompact H26 0314
Serial number: FCLK20020921000
Coding: 02030004E43000
ASAM Dataset: EV_CamSysRVCCompaFicos 009023
ROD: EV_CamSysRVCCompaFicos_009.rod
VCID: 51FF7B0D816608A310C-8004
Part No SW: 5WA 035 285 A HW: 5WA 035 285 A
Component: OCU3HMQB37W H12 0015
Serial number: 0000000108VISM9
Coding: 023800209068AC209025460070502E07
ASAM Dataset: EV_OCU3HMQB37W 002012
ROD: EV_OCU3HMQB37W_002.rod
VCID: 45D75F5D452ED403BC4-8010 SFD
0082 - Databus
{Ethernet Databus missing message - Gateway}
Reset counter: 35
Mileage: 3650 km
Date: 2022.03.15
Time: 19:01:26
Voltage terminal 30: 12.8 V
Address 82: Head Up Display (J898) Labels:* None
Part No SW: 5H1 919 608 HW: 5H1 919 608
Component: HeadupDisplay H15 2045
Coding: 5740A0
ASAM Dataset: EV_HeadUpDisplMQB37W 001018
ROD: EV_HeadUpDisplMQB37W.rod
VCID: 6FBBDDF537123E53268-803A
16777040 - Function Restricted due to Interrupted Communications
U1110 00 {009} - -
{NAV_0x32_communication_error_bap_error_timeout_heartbeat}
Mileage: 3969 km
Date: 2022.03.17
Time: 11:29:11
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 5WA 980 653 C HW: 5WA 980 653
Component: MQB MFK 3.0 H06 3301
Serial number: E57830712212990
Coding: 00000A88216CC040109F00001020002000418000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 005050
ROD: EV_MFK3ValeoMQB_005_VW38.rod
VCID: 4FFB7D7597521E53068-801A
1122664 - Databus
{TIMEOUT_PSD_04}
Reset counter: 0
Mileage: 3969 km
Date: 2022.03.17
Time: 11:29:10
1126400 - Internal Fault
B200F F4 {008} - Unknown Error Elaboration
{Failure_fusion_internal_error}
Reset counter: 6
Mileage: 3568 km
Date: 2022.03.13
Time: 17:30:13
1126401 - Camera Interference
C1104 00 {008} - -
{Failure_fusion_external_error}
Reset counter: 0
Mileage: 3568 km
Date: 2022.03.13
Time: 17:30:11
Address A9: Struct. Borne Sound (J869) Labels: None
Part No SW: 5H0 907 159 A HW: 4K0 907 159
Component: SAS-GEN 2.5 H08 0001
Serial number: 210712291426
Address CA: Sunroof (J245) Labels:* None
Part No SW: 4K1 907 594 CB HW: 4K1 907 594
Component: SAD_STG_1 006 0040
Coding: 008000738001
VCID: 77ABE5954F427693FE8-8022
Slave 2:
Part No SW: 992 941 571 AE HW: 992 941 571 A
Component: LED1L H08 9202
ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
VCID: 6597BFDDE5EEF4035C4-8030
Component: LED1R H08 9202
Address 811E: Burglary Protection FL (J518) Labels: 5WA-962-133.clb
Part No SW: 5WA 962 133 B HW: 5WA 962 133 B
Component: Kessy RSAD 070 0636
ASAM Dataset: EV_RSADVL37w 002013
ROD: EV_RSADVL37w_002.rod
VCID: 47CB55557F22C6134E8-8012
Address 811F: Burglary Protection FR (J518) Labels: 5WA-962-133.clb
ASAM Dataset: EV_RSADVR37w 002013
ROD: EV_RSADHL37w_002.rod
Address 8120: Burglary Protection RL (J518) Labels: 5WA-962-133.clb
ASAM Dataset: EV_RSADHL37w 002013
Address 8121: Burglary Protection RR (J518) Labels: 5WA-962-133.clb
ASAM Dataset: EV_RSADHR37w 002013
Address 8126: Trq distrib RearL axle (J492) Labels: None
Part No SW: 08E 907 554 J HW: 08E 525 130
Component: 4Motion H05 0160
Serial number: 00XV839
Coding: 00010100
ASAM Dataset: EV_TorquSplitLeftMAGNA 001005
ROD: EV_TorquSplitLeftMAGNA_VW37.rod
VCID: 35372F9D15CE44832C4-8060
12290 - Databus
{Steering_angle_sensor_faulty_signal}
Reset counter: 17
Mileage: 2905 km
Date: 2022.03.04
Time: 11:58:31
Snapshot Record Number: 16
Number Of Identifiers: 18
DID: 64768
Major Version Number: 6
Minor Version Number: 0
Bugfix Version Number: 3
Patch version number: 22
Occurrence Counter TOC: 0
Occurrence Counter SLC: 1
Occurrence Counter TNCTOC: 0
Occurrence Counter SLF: 62
Occurrence Counter SFF: 62
Core Service State: 4
Error Event Number: 158
Event Triggers Current Backup Function: false
Origin System Up Counter: 113579
Most Recent System Up Counter: 0
Origin Operation Cycle Counter: 176
Most Recent Operation Cycle Counter: 0
Error specific Freeze Frame raw data: E3 19 10 00 40 48 00 00 00 00 28 FD 21 02 FE 00 02 1F 27 FF FD F6 00 FF 0A 00 03 00
Oil temperature: 23.50 °C
Clutch Input Speed: 567.5 /min
Estimated Transferred Clutch RPM: 8 /min
Battery voltage: 14.97 V
Vehicle speed: 67.38 km/h
Actuator current: -1.54 A
Actuator angle: 18.30 °
Engine speed: 2020.0 /min
Bridge Temperature: 22 °C
KL15 Status SW: 1
KL15Status HW: 1
KL15 Status Comb: 1
System Condition of error decision manager: 249
Status CSM: 3
stTC: 3
stTCExtdSec: 640
Address 8127: Trq distrib RearR axle (J492) Labels: None
Serial number: 00XV7T2
Coding: 00010100
ASAM Dataset: EV_TorquSplitRightMAGNA 001005
ROD: EV_TorquSplitRightMAGNA_VW37.rod
12290 - Databus
Reset counter: 17
Mileage: 2905 km
Date: 2022.03.04
Time: 11:58:31
DID: 64768
Origin Operation Cycle Counter: 178
Oil temperature: 25.19 °C
Estimated Transferred Clutch RPM: 0 /min
Battery voltage: 15.04 V
Actuator current: -3.10 A
Actuator angle: 21.61 °
Bridge Temperature: 24 °C
KL15 Status SW: 1
KL15Status HW: 1
KL15 Status Comb: 1
Status CSM: 3
stTC: 3
stTCExtdSec: 640
End----------(Elapsed Time: 02:00, VBatt start/end: 14.4V/14.4V)-----------
;SW:5H0-906-259-A HW:06K-907-425-N --- Engine
;Component:R4 2.0l TFSI H08 0001, Coding:091900322466000E30040000000000000000000000000000
;EV_ECM20TFS0205H0906259A,001002,EV_ECM20TFS0205H0906259A.rod
;Thursday,17,March,2022,11:38:14:62242
;VCDS Version: Release 22.3.0 Data version: 20220225 DS336.1
;VCID: 2D0707FDFD9E0C43544-8078
Group,Description,Actual,
IDE00011,Vehicle Identification Number (VIN),||WVWFB7CD8NW129409|,
IDE00018,Voltage terminal 15,13.105, V
IDE00019,Voltage terminal 30,13.261, V
IDE00021,Engine RPM,774, /min
IDE00025,Coolant temperature,106, °C
IDE00078,Time since engine start,645, s
IDE00083,Throttle valve position (absolute),12.2, %
IDE00084,Absolute load value,16, %
IDE00085,Normed load value,11.0, %
IDE00086,Accelerator pedal position,14.5, %
IDE00090,selected gear,Shifting process active,
IDE00097,OBD - requirements for which this vehicle is designed,OBD + OBD II,
IDE00102,Control Module temperature,71.0, °C
IDE00148,Mean injection time,0.6, ms
IDE00149,Ignition angle of current cylinder: actual value,2.25, °
IDE00150,Pressure in brake servo unit,0.100, bar
IDE00151,Oil fill level,50, mm
IDE00167,Exhaust temperature 1 bank 1,359.6, °C
IDE00172,A/C compressor torque,0.00, Nm
IDE00173,Cruise Control System: specified speed,0.00, km/h
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,0.0, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,0.0, °
IDE00178,Camshaft adjustment intake bank 1: specified value,15.0, °
IDE00179,Camshaft adjustment intake bank 1: actual value,14.8, °
IDE00182,Camshaft adaptation intake bank 1: phase position,3.3, °
IDE00184,Camshaft adaptation exhaust bank 1: phase position,-0.3, °
IDE00186,Fuel low pressure: actual value,2.224, bar
IDE00187,Coolant temperature at engine start,87.0, °C
IDE00188,Fuel high-pressure: actual value,72.3, bar
IDE00189,Activation of fuel pump electronics,33.31, %
IDE00190,Charge air pressure: specified value,1.999, bar
IDE00191,Charge air pressure: actual value,0.999, bar
IDE00192,Coolant temperature at radiator outlet: actual value,72.7, °C
IDE00193,Coolant temperature at engine outlet: specified value,106.5, °C
IDE00194,Coolant temperature at radiator output: specified value,-48.0, °C
IDE00195,Coolant temperature difference between engine and radiator,33.7, °C
IDE00196,Engine oil temperature,102.9, °C
IDE00199,Mean engine air mass,9, kg/h
IDE00200,Average vehicle speed,0.00, km/h
IDE00201,High fuel pressure: specified value,72.1, bar
IDE00202,Low fuel pressure: specified value,5.923, bar
IDE00252,Brake system vacuum pump,Pump off,
IDE00304,Fuel level,42, l
IDE00348,Intake air temperature,51, °C
IDE00349,Throttle valve position: normed,1.6, %
IDE00355,Cruise Control System (CCS): status,passive,
IDE00357,Fuel temperature,78.7, °C
IDE00358,Limitation: torque,223.1, Nm
IDE00371,Fuel consumption,0.83, l/h
IDE00375,Generator: load signal,48.40, %
IDE00380,Coolant fan 1: activation,12.11, %
IDE00381,Coolant fan 2: activation,11.72, %
IDE00392,Accelerator pedal: sensor voltage 1,0.726, V
IDE00393,Accelerator pedal: sensor voltage 2,0.363, V
IDE00400,Intake manifold Runner Control (IMRC): activation,100.00, %
IDE00401,Intake manifold Runner Control (IMRC): acknowledgment,100.00, %
IDE00404,Throttle valve: activation,14.90, %
IDE00405,Crankshaft speed (RPM),765, /min
IDE00406,Camshaft RPM,764, /min
IDE00407,Rail pressure regulation: status,Regulated operation via quantity control valve,
IDE00408,Engine mount 1,not active,
IDE00409,Engine mount 2,not active,
IDE00412,Starter control: terminal 50,not active,
IDE00413,Starter control: Interlock- or P/N-signal,01,
IDE00414,Starter control: relay 1,00,
IDE00415,Starter control: relay 2,00,
IDE00416,Starter control: terminal 50 feedback,01,
IDE00417,Starter control: shut-off conditions 1,01 01,
IDE00434,Particle filter: soot mass calculated,0.02, g
IDE00436,Particle filter: kilometers since last regeneration,3965.6,
IDE00451,Currently running routine,Unknown (0),
IDE00472,Mean injection quantity,7, mg/stroke
IDE00474,Ambient air pressure,99, kPa abs
IDE00476,Fuel Metering Valve,0.00, %
IDE00477,Torque request: sum of auxiliary aggregate,9.0, Nm
IDE00478,Engine-drag torque,14.3, Nm
IDE00482,Limitation: torque of clutch protection,1024.0, Nm
IDE00495,Calculated oil temperature,103.0, °C
IDE00497-MAS00627,Status of oil pressure switches-Oil pressure switch for high pressure,Open,
IDE00497-MAS00628,Status of oil pressure switches-Oil pressure switch for low pressure,closed,
IDE00556,Outside temperature,23, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),0.989 Lambda / -0.023 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.615, V
IDE00582,Specified value of equivalence ratio,0.995, Lambda
IDE00583,Throttle valve specified value,1.6, %
IDE00584,Distance driven since erasing DTC memory,3945, km
IDE00588,Fuel tank fill level,78.0, %
IDE00589,Fuel pressure,7120, kPa rel
IDE00592,Status of oxygen sensor control,Closed loop, / using O2 sensors
IDE00593,Ignition timing adjustment cylinder 1,1.0, Degrees
IDE00597,Long term adaptation of mixture formation bank 1,0.0, %
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00603,Number of driving cycles since erasing DTC memory,45,
IDE00604,Short term adaptation of mixture formation bank 1,-1.6, %
IDE00608,Fuel type,Gasoline,
IDE00612,Target position of EVAP canister valve,0.0, %
IDE00949-ENG98517,Hide cylinder-Cylinder 1,not active,
IDE00949-ENG98491,Hide cylinder-Cylinder 10,not active,
IDE00949-ENG98492,Hide cylinder-Cylinder 11,not active,
IDE00949-ENG98493,Hide cylinder-Cylinder 12,not active,
IDE00949-ENG98518,Hide cylinder-Cylinder 13,not active,
IDE00949-ENG98519,Hide cylinder-Cylinder 14,not active,
IDE00949-ENG98520,Hide cylinder-Cylinder 15,not active,
IDE00949-ENG98494,Hide cylinder-Cylinder 16,not active,
IDE00949-ENG98521,Hide cylinder-Cylinder 2,not active,
IDE00949-ENG98522,Hide cylinder-Cylinder 3,not active,
IDE00949-ENG98523,Hide cylinder-Cylinder 4,not active,
IDE00949-ENG98495,Hide cylinder-Cylinder 5,not active,
IDE00949-ENG98524,Hide cylinder-Cylinder 6,not active,
IDE00949-ENG98496,Hide cylinder-Cylinder 7,not active,
IDE00949-ENG98497,Hide cylinder-Cylinder 8,not active,
IDE00949-ENG98498,Hide cylinder-Cylinder 9,not active,
IDE01098,Test of knock sensors: short trip result,Test not started,
IDE01196,Dynamic factor O2 sensors bank 1 or bank 3 before cat. conv.,0.000,
IDE01377,Throttle valve adapter: actual value,2.2, °
IDE01378,Fuel high pressure: control deviation,0, bar
IDE01385,Wear index,0.00000020,
IDE01638,Result O2 sensor aging test bank 1 or 3 before cat. conv.,Test not started,
IDE01644,Oxygen sensor voltage B1 downstream CAT,0.610, V
IDE01649,Throttle valve position 1,0.609, V
IDE01650,Throttle valve position 2,12, %
IDE01665,Result of test of camshaft adjustment intake bank 1,Test not started,
IDE01667,Result of test of camshaft adjustment outlet bank 1,Test not started,
IDE01670,Short trip status for oil pressure control,Test not started,
IDE01671,Starter control: clutch switch,not depressed,
IDE01672,Starter control: automatic start,possible,
IDE01673-MAS05513,Starter control: readiness bits-Bit 0,Mechanical test of starter not complete,
IDE01673-MAS05514,Starter control: readiness bits-Bit 1,Test of starter relay switching contacts not complete,
IDE01673-MAS05515,Starter control: readiness bits-Bit 2,Test of starter relay activation not complete,
IDE01673-MAS05516,Starter control: readiness bits-Bit 3,Test of terminal 50R return measuring line not completed,
IDE01673-MAS05517,Starter control: readiness bits-Bit 4,Test of starter request double injection not complete,
IDE01673-MAS05518,Starter control: readiness bits-Bit 5,Test of PN signal not complete,
IDE01673-MAS05519,Starter control: readiness bits-Bit 6,Test of interlock switch not complete,
IDE01673-MAS05520,Starter control: readiness bits-Bit 7,Test of clutch pedal switch not complete,
IDE01677,Result: oxygen sensor test operational readiness B1 downstream CAT,Test not started,
IDE01685,Result of test of valve stroke switch AVS,Test not started,
IDE01773,Misfire totalizer,0,
IDE01774,Status misfire recognition,active,
IDE01870,Oxygen sensor after catalytic converter: operating status,Bank 1: sensor 1 OK,
IDE01873,Test of catalytic converter: measured value,0.008,
IDE01874,Test of catalytic converter: result,Test not started,
IDE01876,Adaptation of loss torque,0.0, Nm
IDE01878,Adaptation of throttle valve,Test of closing springs ended,
IDE01880,Accelerator pedal position 2,14.5, %
IDE01881,Adaptation of kick-down shifting point,4.126, V
IDE01884,Camshaft adjustment intake bank 1: activation,60.17, %
IDE01886,Number of high pressure incursions,0,
IDE01894,Charge press. ctrl.: adapt. higher than max. threshold,0.00, %
IDE01895,Charge pressure control: less than min. threshold adaptation,0.00, %
IDE01901,Lost torque adaptation: idle,1.2, Nm
IDE01905,Average of ignition timing angle delay adjustment,19.87, °
IDE01906,Dynamic average of ignition timing angle delay adjustment,2.25, °
IDE01913,Number of oxygen sensor dynamic tests: bank 1 sensor 1,0,
IDE01922,Vehicle distance driven,3969, km
IDE01923,Control module distance driven,3966, km
IDE01924,Load shift flaps: actual value,closed,
IDE01925,Load shift flaps: specified value,closed,
IDE01926,Adaptation of intake manifold runner flaps,Test not started,
IDE01928,Close cam shaft angle at quantity control valve,27.1, °
IDE01929,Open cam shaft angle at quantity control valve,5.6, °
IDE01931,High pressure pump injection volume control deviation,3, mg/stroke
IDE01932,High pressure pump injection volume,0, mg/stroke
IDE02116,Exhaust gas temperature before catalytic converter,332.7, °C
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
IDE02229,Exhaust gas temperature sensor 1,1110.0, °C
IDE02756,Number of manual engine starts,170,
IDE02757,Number of automatic engine starts,0,
IDE02832,Coolant circulation pump: activation,0.00, %
IDE03008-MAS04415,Stop process prevented-Ambient air pressure,not active,
IDE03008-MAS04416,Stop process prevented-Sporadic function prevention,not active,
IDE03008-MAS04417,Stop process prevented-Poor start detection,not active,
IDE03008-MAS04590,Stop process prevented-Mixture adaptation,not active,
IDE03008-MAS06602,Stop process prevented-Engine temperature,not active,
IDE03008-MAS06604,Stop process prevented-Start/stop sensors:,not active,
IDE03008-MAS06605,Stop process prevented-Regeneration Mode,not active,
IDE03008-MAS06606,Stop process prevented-Brake under pressure too low,not active,
IDE03010-IDE00924,Number of prevented stop processes-Steering angle,0,
IDE03010-MAS01627,Number of prevented stop processes-Steering,0,
IDE03010-MAS02040,Number of prevented stop processes-Anti-play protection,0,
IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
IDE03010-MAS04416,Number of prevented stop processes-Sporadic function prevention,0,
IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,0,
IDE03010-MAS04591,Number of prevented stop processes-Air system diagnosis,0,
IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery performance too low,0,
IDE03010-MAS04593,Number of prevented stop processes-Auxiliary equipment power consumption too high,0,
IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
IDE03010-MAS04870,Number of prevented stop processes-Thermostat testing not completed,0,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,0,
IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,0,
IDE03010-MAS06605,Number of prevented stop processes-Regeneration Mode,0,
IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,0,
IDE03010-MAS08032,Number of prevented stop processes-DTC memory entry in engine control module,0,
IDE03010-MAS09416,Number of prevented stop processes-Learning function active,0,
IDE03010-MAS11563,Number of prevented stop processes-hood open,0,
IDE03010-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE03010-MAS12864,Number of prevented stop processes-Slow traffic detected,0,
IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
IDE03010-MAS13644,Number of prevented stop processes-Engine protection active,0,
IDE03010-MAS13645,Number of prevented stop processes-Fuel gelling protection active,0,
IDE03010-MAS13661,Number of prevented stop processes-Exhaust treatment diagnosis,0,
IDE03010-MAS16918,Number of prevented stop processes-Restriction in start system,0,
IDE03011-MAS01627,Number of requested start processes-Steering,0,
IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
IDE03011-MAS04416,Number of requested start processes-Sporadic function prevention,0,
IDE03011-MAS04592,Number of requested start processes-Hybrid battery performance too low,0,
IDE03011-MAS04593,Number of requested start processes-Auxiliary equipment power consumption too high,0,
IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,0,
IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
IDE03011-MAS09730,Number of requested start processes-CAT heating,0,
IDE03011-MAS11563,Number of requested start processes-hood open,0,
IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,0,
IDE03011-MAS13644,Number of requested start processes-Engine protection active,0,
IDE03011-MAS13645,Number of requested start processes-Fuel gelling protection active,0,
IDE03011-MAS16918,Number of requested start processes-Restriction in start system,0,
IDE03108,Result of test of oxygen sensors bank 1,Test not started,
IDE03235,Neutral position sensor: current transmission angle,-0.28, °
IDE03236,Neutral position sensor: adapted transmission angle,-0.28, °
IDE03246,Neutral position sensor: upper adaptation value,2.977, V
IDE03247,Neutral position sensor: lower adaptation value,1.330, V
IDE03262,Adapt of angle sensor 1 f throttle valve,0.503, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.496, V
IDE03264,Adaptation of angle sensor 1 throttle valve: emerg. air gap,0.867, V
IDE03265,Adaptation of angle sensor 2 throttle valve: emerg. air gap,4.129, V
IDE03277,Intake manifold Runner Control (IMRC): unconditioned voltage,3.999, V
IDE03328,Transmission neutral position sensor voltage,1.978, V
IDE03361,Driver intention torque,23.4, Nm
IDE03377,Coolant temp at radiator output: unconditioned voltage,1.438, V
IDE03585,System status for the start/stop function master,System malfunction,
IDE03587-IDE02697,Stopping requirements for active participants-Multifunction unit control module,not active,
IDE03587-MAS00124,Stopping requirements for active participants-Air Conditioning,not active,
IDE03587-MAS00127,Stopping requirements for active participants-brakes,not active,
IDE03587-MAS00506,Stopping requirements for active participants-Adaptive Cruise Control,not active,
IDE03587-MAS00832,Stopping requirements for active participants-Convertible top control module,not active,
IDE03587-MAS01090,Stopping requirements for active participants-Transmission,not active,
IDE03587-MAS01106,Stopping requirements for active participants-Level control system,not active,
IDE03587-MAS01490,Stopping requirements for active participants-Energy management,not active,
IDE03587-MAS01627,Stopping requirements for active participants-Steering,not active,
IDE03587-MAS02237,Stopping requirements for active participants-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03587-MAS02569,Stopping requirements for active participants-All-wheel drive electronics,not active,
IDE03587-MAS03757,Stopping requirements for active participants-Quattro Sport,not active,
IDE03587-MAS05129,Stopping requirements for active participants-Motor,not active,
IDE03587-MAS06709,Stopping requirements for active participants-Keyless operation,not active,
IDE03587-MAS08785,Stopping requirements for active participants-Parking aid,not active,
IDE03587-MAS13018,Stopping requirements for active participants-Front sensor for drivers assistant systems,not active,
IDE03588-IDE02697,System malfunctions for active participants start/stop-Multifunction unit control module,not active,
IDE03588-MAS00124,System malfunctions for active participants start/stop-Air Conditioning,not active,
IDE03588-MAS00127,System malfunctions for active participants start/stop-brakes,not active,
IDE03588-MAS00506,System malfunctions for active participants start/stop-Adaptive Cruise Control,not active,
IDE03588-MAS00832,System malfunctions for active participants start/stop-Convertible top control module,not active,
IDE03588-MAS01090,System malfunctions for active participants start/stop-Transmission,not active,
IDE03588-MAS01106,System malfunctions for active participants start/stop-Level control system,not active,
IDE03588-MAS01490,System malfunctions for active participants start/stop-Energy management,not active,
IDE03588-MAS01627,System malfunctions for active participants start/stop-Steering,not active,
IDE03588-MAS02237,System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03588-MAS02569,System malfunctions for active participants start/stop-All-wheel drive electronics,not active,
IDE03588-MAS03757,System malfunctions for active participants start/stop-Quattro Sport,not active,
IDE03588-MAS05129,System malfunctions for active participants start/stop-Motor,not active,
IDE03588-MAS06709,System malfunctions for active participants start/stop-Keyless operation,not active,
IDE03588-MAS08785,System malfunctions for active participants start/stop-Parking aid,not active,
IDE03588-MAS13018,System malfunctions for active participants start/stop-Front sensor for drivers assistant systems,not active,
IDE03589-MAS01161,Error status for start-stop related sensors-Communication malfunction,not active,
IDE03589-MAS11563,Error status for start-stop related sensors-hood open,not active,
IDE03589-MAS11868,Error status for start-stop related sensors-Driver door status,not active,
IDE03589-MAS12097,Error status for start-stop related sensors-driver door open,not active,
IDE03589-MAS12098,Error status for start-stop related sensors-Start/Stop deactivated with button,not active,
IDE03589-MAS12099,Error status for start-stop related sensors-Clutch signal error,not active,
IDE03589-MAS12100,Error status for start-stop related sensors-Brake or speed signal error,not active,
IDE03589-MAS12101,Error status for start-stop related sensors-Steering signal error,not active,
IDE03711,Mass flow through throttle valve,8, kg/h
IDE03767,Engine status,Idle,
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,0.00, %
IDE03806,Oxygen sensor bank 1 sensor 1: status,1,
IDE03807,O2 Sensor B1-S2: Status,1,
IDE03816,Exhaust flap bank 1,closed,
IDE03818,Heated oxygen sensor bank 1: sensor 2: resistance,46, Ohm
IDE03819,Heated oxygen sensor bank 1: sensor 2: activation,53.52, %
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,61, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,22.27, %
IDE03836,Result of O2 sensor aging test bank 1 after cat. conv.,Test not started,
IDE03892,Fuel high pressure sensor: unconditioned voltage,4.995, V
IDE03920,Oxygen adaptation status,Condition not met,
IDE03921,Mixture adaptation factor at partial load,-1.33, %
IDE03922,Mixture adaptation factor at idle speed,0.63, %
IDE03923,Adaptive long-term value of mix. condition after cat. conv,0.00000,
IDE03924,Relay for reserve coolant pump: status,not activated,
IDE03928,Counter for fuel entry in oil,0,
IDE03930,Charge pressure actuator: operating status,Operating mode,
IDE03949,Air mass: actual value (mg/stroke),96.89, mg/stroke
IDE03953,Oxygen control: adaptation value at partial load: bank 1,-1.77, %
IDE03957,Throttle valve angle: specified value,2.2, °
IDE03963,Low fuel pressure adaptation value for EFP,0, mbar
IDE03966,Transmission neutral position sensor PWM signal,39.55, %
IDE04002,Charge air pressure control,BP_A act:99.4, kPa
IDE04010,Engine torque: normalized,6.0, %
IDE04011,Nominal torque,420, Nm
IDE04083,Coolant temperatures,ECT 1:106 °C / ECT 2:72 °C,
IDE04101,Intake pressure,MAP_A:27.09 kPa abs / MAP_B:--- ,
IDE04405,Mixture variation in adapted part load range 1,0.00, %
IDE04409,Intake manifold pressure: corrected,0.275, bar
IDE04410,Intake manifold pressure: specified value,0.277, bar
IDE04412,Pressure upstream of throttle valve: corrected,0.998, bar
IDE04634,AVS switch-over meter for reg activation of curr. drive cycle,0,
IDE04635,AVS switch-over meter: total,0,
IDE04636,AVS overflow meter for all switch-overs,3092,
IDE04638,Transmission coolant valve,Open,
IDE04677,Oxygen sensor 1 bank 1: lambda actual value,0,
IDE04680,Oxygen sensor 1 bank 1: voltage raw value O2 signal,1.982, V
IDE04713,Active brake system status,Not operated,
IDE04814,Transmission oil cooler valve,Open,
IDE04885,Hybrid batt charge cond act val standardized,0.00, %
IDE04913,Current speed of electric motor,0.0, /min
IDE04937,Sensor for engine block temperature: raw value,-48.0, °C
IDE05140,Intake manifold pressure raw value,0.275, bar
IDE05259,Gear position sensor: raw value,39.52, %
IDE05260,Gear position sensor: current value,Neutral,
IDE05310,Charge air pressure control valve position: target value,0.00, %
IDE05311,Charge air pressure control valve position: actual value,0.03, %
IDE05312,Charge air pressure control valve uncond voltage sensor,3.2385, V
IDE05313,Charge air pressure control valve activation pulse duty factor,-26.05, %
IDE05315,Charge air pressure control valve voltage: position closed,3.2391, V
IDE05316,Charge air pressure control valve voltage: position open,0.6693, V
IDE05317,Charge air pressure control valve adaptation performed,00000000 ,
IDE05508,Adaptation val cyl 1 with slow diagnosis,0.000,
IDE05509,Adaptation val cyl 3 with slow diagnosis,0.000,
IDE05510,Adaptation val cyl 4 with slow diagnosis,0.000,
IDE05511,Adaptation val cyl 2 with slow diagnosis,0.000,
IDE05512,Adaptation val cyl 1 with fast diagnosis,0.000,
IDE05513,Adaptation val cyl 3 with fast diagnosis,0.000,
IDE05514,Adaptation val cyl 4 with fast diagnosis,0.000,
IDE05515,Adaptation val cyl 2 with fast diagnosis,0.000,
IDE05593,Secondary air injection sensor 1,0.000, bar
IDE05622,Status of tank leak diagnosis with electrical diagnostic pump,Voltage error: content of RAM cell not invalid anymore,
IDE06006,Idle speed specified value,771, /min
IDE06059,Particulate filter: oil ash mass,0.42, g
IDE06192,Knock sensor: cylinder 2: voltage,0.493, V
IDE06193,Knock sensor: cylinder 3: voltage,0.526, V
IDE06194,Knock sensor: cylinder 4: voltage,0.496, V
IDE06195,Knock sensor: cylinder 1: voltage,0.474, V
IDE06307,Stop prevention history data,|Year,Month
IDE06308,Start request history data,|Year,Month
IDE06386,Oil level: static measurement,0, mm
IDE06387,Oil level: last valid dynamic value,0, mm
IDE06388,Oil level: condition for static measurement fulfilled,Condition not met,
IDE06389,Oil level: maximum value,0, mm
IDE06390,Oil level: minimum value,0, mm
IDE06391,Oil temperature sensor 2,103.0, °C
IDE06392,Oil temperature sensor 2: raw value,65.535, V
IDE06393,Oil level: dynamic average value,0, mm
IDE06394,Sensor 1 for secondary air pressure: unconditioned voltage,0.000, V
IDE06395,Fuel low pressure sensor: unconditioned voltage,0.000, V
IDE06396,Coolant temperature at engine outlet: unconditioned voltage,0.687, V
IDE06397,Temperature sensor for engine temp. management: target value,107.2, °C
IDE06398,Temperature sensor for engine temp. management: uncond. voltage,0.687, V
IDE06432,Oxygen sensor 1 bank 1 signal status,active,
IDE06444,Oxygen sensor before cat bank 1 (LSB) voltage,1.987, V
IDE06567,Frequency counter deactivate start/stop function,0,
IDE06568,Stop prevention by driver frequency counter,0,
IDE06569,Frequency counter vehicle standstill,0,
IDE06573,Long-term adaptation of intake manifold injection,0.00, %
IDE06574,Long-term adaptation of intake manifold injection in idle,0.00, mg/stroke
IDE06610,Frequency counter vehicle standstill with stop,0,
IDE06703-IDE12714,Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration,No,
IDE06703-MAS14977,Drivetrain coordinator: ACC fault status-ACC active: although TSK passive,No,
IDE06703-MAS14978,Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set,No,
IDE06703-MAS14979,Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously,No,
IDE06703-MAS14980,Drivetrain coordinator: ACC fault status-ACC active: although limiter active,No,
IDE06703-MAS14981,Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking,No,
IDE06703-MAS14982,Drivetrain coordinator: ACC fault status-ACC sends undefined signals,No,
IDE06703-MAS14983,Drivetrain coordinator: ACC fault status-ACC active although main switch off,No,
IDE06703-MAS14984,Drivetrain coordinator: ACC fault status-ACC is active despite driver braking,No,
IDE06703-MAS14985,Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling,No,
IDE06704-MAS14986,Drivetrain coordinator: brake fault status-Deceleration sensor not available,No,
IDE06704-MAS14987,Drivetrain coordinator: brake fault status-Deceleration sensor malfunction,No,
IDE06704-MAS14988,Drivetrain coordinator: brake fault status-ESP system error,No,
IDE06704-MAS14989,Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque,No,
IDE06704-MAS14990,Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error,No,
IDE06704-MAS14991,Drivetrain coordinator: brake fault status-TSK/ESP handshake error,No,
IDE06704-MAS14992,Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction,No,
IDE06704-MAS14993,Drivetrain coordinator: brake fault status-Brake light implausible,No,
IDE06705-MAS05179,Drivetrain coordinator: brake function status-ABS intervention,No,
IDE06705-MAS05180,Drivetrain coordinator: brake function status-ESP intervention,No,
IDE06705-MAS05181,Drivetrain coordinator: brake function status-EDL intervention,No,
IDE06705-MAS05186,Drivetrain coordinator: brake function status-ASR intervention,No,
IDE06705-MAS05187,Drivetrain coordinator: brake function status-MSR intervention,No,
IDE06705-MAS05192,Drivetrain coordinator: brake function status-Driver braking,No,
IDE06705-MAS05195,Drivetrain coordinator: brake function status-HDC active,No,
IDE06705-MAS15001,Drivetrain coordinator: brake function status-ESP invokes TSK braking,No,
IDE06705-MAS15002,Drivetrain coordinator: brake function status-EPB active,No,
IDE06705-MAS15003,Drivetrain coordinator: brake function status-ASP intervention,No,
IDE06705-MAS15004,Drivetrain coordinator: brake function status-ADS intervention,No,
IDE06705-MAS15006,Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt,No,
IDE06705-MAS15007,Drivetrain coordinator: brake function status-ESP sampled passive (ESP off),No,
IDE06705-MAS15008,Drivetrain coordinator: brake function status-ASR sampled passive (ASR off),No,
IDE06705-MAS15009,Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest,Yes,
IDE06705-MAS15010,Drivetrain coordinator: brake function status-ACC stopping distance control active,No,
IDE06706,ACC variants,ACC with Stop & Go,
IDE06707,CCS Switch,ACC operating unit,
IDE06709,ACC variants (coding),ACC with braking until standstill / Stop & Go,
IDE06710,Cruise control system: permanent deactivation,Implausible control switch signals,
IDE06726,Timing deviation after chain replacement: intake bank 1,0.00, °
IDE06728,Timing deviation after chain replacement: exhaust bank 1,-0.44, °
IDE06730,Timing deviation after other repairs: intake bank 1,0.00, °
IDE06732,Timing deviation after other repairs: exhaust bank 1,0.00, °
IDE06734,Timing deviation: current value intake bank 1,0.00, °
IDE06736,Timing deviation: current value exhaust bank 1,0.00, °
IDE06738,Chain elongation: no. of valid initial values: intake bank 1,0,
IDE06740,Chain elongation: no. of valid initial values: exhaust bank 1,4,
IDE06742,Chain elongation: initial values valid: intake bank 1,not active,
IDE06744,Chain elongation: initial values valid: exhaust bank 1,not active,
IDE07001,Piston-cooling jets: activation,On,
IDE07002,Exhaust flap: activation,10.00, %
IDE07003,Exhaust flap bank 2: activation,16.39, %
IDE07019,Number of ignitions direct injection,12391936,
IDE07020,Number of ignitions intake manifold injection,0,
IDE07023,Misfires per 1000 revolutions of cyl. 1 intake manif. injection,0,
IDE07024,Misfires per 1000 revolutions of cyl. 2 intake manif. injection,0,
IDE07025,Misfires per 1000 revolutions of cyl. 3 intake manif. injection,0,
IDE07026,Misfires per 1000 revolutions of cyl. 4 intake manif. injection,0,
IDE07027,Heat quantity that was transported via the catalytic converter,4.33e+008, J
IDE07031,Oil pressure switch for piston-cooling jets: status,Open,
IDE07242,Heater support pump: spec. value,10.00, %
IDE07254,Gasoline pressure tank refueling request button,not coded/not installed,
IDE07548,Engine temp. mangmt. actuator: specified value of angle,73.75, °
IDE07549,Engine temp. mangmt. actuator: actual value of angle,73.88, °
IDE07550,Engine temp. management actuator: raw value,1232,
IDE07551,Engine temp. management actuator: duty cycle activation,0.00, %
IDE07552,Engine temper.managem.actuator adaptation: result adaptation,Adaptation successfully finished,
IDE07553,Engine temperature management actuator: after-run stop,3947,
IDE07554,Engine temperature management actuator: stop open,146,
IDE07564,Required torque adjustment by idling regulator,0.3, Nm
IDE07571,Engine torque,9.8, Nm
IDE07574,Long-term fuel trim bank 1 at idle,0.06, mg/stroke
IDE07575,Driver intention torque,9.2, Nm
IDE07576,Lost torque adaptation driving mode,0.0, Nm
IDE07577,Lost torque adaptation A/C compressor and driving mode,3.2, Nm
IDE07598-MAS00320,Cruise control switch actuation-Main switch,operated,
IDE07598-MAS00325,Cruise control switch actuation-Set,Not operated,
IDE07598-MAS00326,Cruise control switch actuation-Resume,Not operated,
IDE07598-MAS01632,Cruise control switch actuation-Status,OK,
IDE07598-MAS02309,Cruise control switch actuation-Accelerate,Not operated,
IDE07598-MAS02310,Cruise control switch actuation-DELAY,Not operated,
IDE07598-MAS05172,Cruise control switch actuation-Cancel,Not operated,
IDE07598-MAS05806,Cruise control switch actuation-Main switch hardware,Not operated,
IDE07598-MAS05807,Cruise control switch actuation-Coding,plausible,
IDE07598-MAS05809,Cruise control switch actuation-Limit function,not selected,
IDE07598-MAS05812,Cruise control switch actuation-Limit button,Not operated,
IDE07598-MAS05813,Cruise control switch actuation-Main switch CAN,Not operated,
IDE07598-MAS05842,Cruise control switch actuation-Large increment,Not operated,
IDE07598-MAS05843,Cruise control switch actuation-Control component verified,Yes,
IDE07605,Cruise control system: temporary deactivation,ESP/ASR set to passive during ACC without brake intervention,
IDE07669,Oxygen sensor 2 Bank 1 after cat operation readiness Status,active,
IDE07901,Error counter bad fuel,0,
IDE07904-ENG118117,Brake test switch status-actuated__activated,Not operated,
IDE07904-ENG114825,Brake test switch status-Ident_32,0,
IDE07905-ENG118117,Brake light switch status-actuated__activated,Not operated,
IDE07905-ENG114825,Brake light switch status-Ident_32,0,
IDE07906-ENG118117,Upper clutch switch: status-actuated__activated,Not operated,
IDE07906-ENG114825,Upper clutch switch: status-Ident_32,0,
IDE08071,Remote start cancellation reason store 1,0,
IDE08072,Remote start cancellation reason store 2,0,
IDE08073,Remote start cancellation reason store 3,0,
IDE08074,Remote start cancellation reason store 4,0,
IDE08075,Remote start cancellation reason store 5,0,
IDE08805,EVAP valve diag. activation condition at minimal load,0.070, counts
IDE08806,EVAP valve diag. activation condition at maximum load,724, mbar
IDE10063-MAS00666,Engine oil level: current value-Warning,no warning,
IDE10063-MAS00900,Engine oil level: current value-Oil level,83.50, %
IDE10063-MAS09802,Engine oil level: current value-Odometer reading at entry,2998, km
IDE10063-MAS09803,Engine oil level: current value-Odometer reading when determining oil level,2987, km
IDE10063-MAS09804,Engine oil level: current value-Test method 1,OFF,
IDE10063-MAS09805,Engine oil level: current value-Test method 2,On,
IDE10063-MAS09806,Engine oil level: current value-Test method 3,OFF,
IDE10063-MAS09807,Engine oil level: current value-Qualification,7,
IDE10064-MAS00666,Engine oil level: history 1-Warning,no warning,
IDE10064-MAS00900,Engine oil level: history 1-Oil level,95.30, %
IDE10064-MAS09802,Engine oil level: history 1-Odometer reading at entry,1498, km
IDE10064-MAS09803,Engine oil level: history 1-Odometer reading when determining oil level,1484, km
IDE10064-MAS09804,Engine oil level: history 1-Test method 1,OFF,
IDE10064-MAS09805,Engine oil level: history 1-Test method 2,On,
IDE10064-MAS09806,Engine oil level: history 1-Test method 3,OFF,
IDE10064-MAS09807,Engine oil level: history 1-Qualification,7,
IDE10065-MAS00666,Engine oil level: history 2-Warning,no warning,
IDE10065-MAS00900,Engine oil level: history 2-Oil level,0.00, %
IDE10065-MAS09802,Engine oil level: history 2-Odometer reading at entry,0, km
IDE10065-MAS09803,Engine oil level: history 2-Odometer reading when determining oil level,0, km
IDE10065-MAS09804,Engine oil level: history 2-Test method 1,OFF,
IDE10065-MAS09805,Engine oil level: history 2-Test method 2,OFF,
IDE10065-MAS09806,Engine oil level: history 2-Test method 3,OFF,
IDE10065-MAS09807,Engine oil level: history 2-Qualification,0,
IDE10066-MAS00666,Engine oil level: history 3-Warning,no warning,
IDE10066-MAS00900,Engine oil level: history 3-Oil level,0.00, %
IDE10066-MAS09802,Engine oil level: history 3-Odometer reading at entry,0, km
IDE10066-MAS09803,Engine oil level: history 3-Odometer reading when determining oil level,0, km
IDE10066-MAS09804,Engine oil level: history 3-Test method 1,OFF,
IDE10066-MAS09805,Engine oil level: history 3-Test method 2,OFF,
IDE10066-MAS09806,Engine oil level: history 3-Test method 3,OFF,
IDE10066-MAS09807,Engine oil level: history 3-Qualification,0,
IDE10067-MAS00666,Engine oil level: history 4-Warning,no warning,
IDE10067-MAS00900,Engine oil level: history 4-Oil level,0.00, %
IDE10067-MAS09802,Engine oil level: history 4-Odometer reading at entry,0, km
IDE10067-MAS09803,Engine oil level: history 4-Odometer reading when determining oil level,0, km
IDE10067-MAS09804,Engine oil level: history 4-Test method 1,OFF,
IDE10067-MAS09805,Engine oil level: history 4-Test method 2,OFF,
IDE10067-MAS09806,Engine oil level: history 4-Test method 3,OFF,
IDE10067-MAS09807,Engine oil level: history 4-Qualification,0,
IDE10068-MAS00666,Engine oil level: history 5-Warning,no warning,
IDE10068-MAS00900,Engine oil level: history 5-Oil level,0.00, %
IDE10068-MAS09802,Engine oil level: history 5-Odometer reading at entry,0, km
IDE10068-MAS09803,Engine oil level: history 5-Odometer reading when determining oil level,0, km
IDE10068-MAS09804,Engine oil level: history 5-Test method 1,OFF,
IDE10068-MAS09805,Engine oil level: history 5-Test method 2,OFF,
IDE10068-MAS09806,Engine oil level: history 5-Test method 3,OFF,
IDE10068-MAS09807,Engine oil level: history 5-Qualification,0,
IDE10069-MAS00666,Engine oil level: history 6-Warning,no warning,
IDE10069-MAS00900,Engine oil level: history 6-Oil level,0.00, %
IDE10069-MAS09802,Engine oil level: history 6-Odometer reading at entry,0, km
IDE10069-MAS09803,Engine oil level: history 6-Odometer reading when determining oil level,0, km
IDE10069-MAS09804,Engine oil level: history 6-Test method 1,OFF,
IDE10069-MAS09805,Engine oil level: history 6-Test method 2,OFF,
IDE10069-MAS09806,Engine oil level: history 6-Test method 3,OFF,
IDE10069-MAS09807,Engine oil level: history 6-Qualification,0,
IDE10070-MAS00666,Engine oil level: history 7-Warning,no warning,
IDE10070-MAS00900,Engine oil level: history 7-Oil level,0.00, %
IDE10070-MAS09802,Engine oil level: history 7-Odometer reading at entry,0, km
IDE10070-MAS09803,Engine oil level: history 7-Odometer reading when determining oil level,0, km
IDE10070-MAS09804,Engine oil level: history 7-Test method 1,OFF,
IDE10070-MAS09805,Engine oil level: history 7-Test method 2,OFF,
IDE10070-MAS09806,Engine oil level: history 7-Test method 3,OFF,
IDE10070-MAS09807,Engine oil level: history 7-Qualification,0,
IDE10071-MAS00666,Engine oil level: history 8-Warning,no warning,
IDE10071-MAS00900,Engine oil level: history 8-Oil level,0.00, %
IDE10071-MAS09802,Engine oil level: history 8-Odometer reading at entry,0, km
IDE10071-MAS09803,Engine oil level: history 8-Odometer reading when determining oil level,0, km
IDE10071-MAS09804,Engine oil level: history 8-Test method 1,OFF,
IDE10071-MAS09805,Engine oil level: history 8-Test method 2,OFF,
IDE10071-MAS09806,Engine oil level: history 8-Test method 3,OFF,
IDE10071-MAS09807,Engine oil level: history 8-Qualification,0,
IDE10072-MAS00666,Engine oil level: history 9-Warning,no warning,
IDE10072-MAS00900,Engine oil level: history 9-Oil level,0.00, %
IDE10072-MAS09802,Engine oil level: history 9-Odometer reading at entry,0, km
IDE10072-MAS09803,Engine oil level: history 9-Odometer reading when determining oil level,0, km
IDE10072-MAS09804,Engine oil level: history 9-Test method 1,OFF,
IDE10072-MAS09805,Engine oil level: history 9-Test method 2,OFF,
IDE10072-MAS09806,Engine oil level: history 9-Test method 3,OFF,
IDE10072-MAS09807,Engine oil level: history 9-Qualification,0,
IDE10120,Chain elongation inlet: mileage of the last adaptation,0, km
IDE10121,Chain elongation outlet: mileage of the last adaptation,3278, km
IDE10300,OBD Driving Cycle detected,active,
IDE10366,Chg. press. ctrl. valve: sensor voltage max. value,3.290, V
IDE10380,Knock sensor average voltage bank 1,0.486, V
IDE10551-MAS05304,Pre-ignition counter for oxygen shift-Cylinder 1,0,
IDE10551-MAS05305,Pre-ignition counter for oxygen shift-Cylinder 2,0,
IDE10551-MAS05306,Pre-ignition counter for oxygen shift-Cylinder 3,0,
IDE10551-MAS05307,Pre-ignition counter for oxygen shift-Cylinder 4,0,
IDE10551-MAS05308,Pre-ignition counter for oxygen shift-Cylinder 5,0,
IDE10551-MAS05309,Pre-ignition counter for oxygen shift-Cylinder 6,0,
IDE10551-MAS05310,Pre-ignition counter for oxygen shift-Cylinder 7,0,
IDE10551-MAS05311,Pre-ignition counter for oxygen shift-Cylinder 8,0,
IDE10552-MAS05304,Pre-ignition counter for torque reduction-Cylinder 1,0,
IDE10552-MAS05305,Pre-ignition counter for torque reduction-Cylinder 2,0,
IDE10552-MAS05306,Pre-ignition counter for torque reduction-Cylinder 3,0,
IDE10552-MAS05307,Pre-ignition counter for torque reduction-Cylinder 4,0,
IDE10552-MAS05308,Pre-ignition counter for torque reduction-Cylinder 5,0,
IDE10552-MAS05309,Pre-ignition counter for torque reduction-Cylinder 6,0,
IDE10552-MAS05310,Pre-ignition counter for torque reduction-Cylinder 7,0,
IDE10552-MAS05311,Pre-ignition counter for torque reduction-Cylinder 8,0,
IDE10553-MAS05304,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 1,0,
IDE10553-MAS05305,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 2,0,
IDE10553-MAS05306,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 3,0,
IDE10553-MAS05307,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 4,0,
IDE10553-MAS05308,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 5,0,
IDE10553-MAS05309,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 6,0,
IDE10553-MAS05310,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 7,0,
IDE10553-MAS05311,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 8,0,
IDE10554-MAS05304,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 1,0,
IDE10554-MAS05305,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 2,0,
IDE10554-MAS05306,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 3,0,
IDE10554-MAS05307,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 4,0,
IDE10554-MAS05308,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 5,0,
IDE10554-MAS05309,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 6,0,
IDE10554-MAS05310,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 7,0,
IDE10554-MAS05311,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 8,0,
IDE10580,Engine oil level: test method 1,93.10, %
IDE10581,Engine oil level: test method 2,95.60, %
IDE10582,Engine oil level: test method 3,84.80, %
IDE10633,Clutch protection function: reduced torque,1023.9, Nm
IDE10634,Clutch protection function: slip speed of the clutch,769, /min
IDE10710-ENG125936,Exhaust warning light: triggering contr. module-Blinking_MIL_due_to_misfire_is_causing_catalyst_damage,No,
IDE10710-ENG130107,Exhaust warning light: triggering contr. module-MIL Request from Transmission Control Module,No,
IDE10710-ENG125937,Exhaust warning light: triggering contr. module-MIL_request_register_ident,0,
IDE10710-ENG130099,Exhaust warning light: triggering contr. module-MIL-Request from All Wheel Drive Control Module,No,
IDE10710-ENG130102,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module,No,
IDE10710-ENG06494,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module 48V,No,
IDE10710-ENG130110,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module,No,
IDE10710-ENG130100,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module 2,No,
IDE10710-ENG130103,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module,No,
IDE10710-ENG130109,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 2,No,
IDE10710-ENG06495,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 48V,No,
IDE10710-ENG130105,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module,No,
IDE10710-ENG130106,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module 2,No,
IDE10710-ENG130111,Exhaust warning light: triggering contr. module-MIL-Request from HVAC Control Module,No,
IDE10710-ENG130108,Exhaust warning light: triggering contr. module-MIL-Request from Transmission Control Module 2,No,
IDE10732,Engine oil level: factor volume,50.00,
IDE10848,Accelerator pedal position,0.00, %
IDE10970-MAS11563,Number of prevented stop processes-hood open,0,
IDE10970-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE10989,Immobilizer: historic data,|Year,Month
IDE10994,Poor start counter at start-stop,0,
IDE11115,Start/stop driver request: counter restart by starter,0,
IDE11116,Start/stop driver request: counter internal-motor restart,0,
IDE11267,Oil level: max. value: relative,108.70, %
IDE11268,Oil level: min. value: relative,67.10, %
IDE11302-MAS05513,Engine oil level: test method 1 qualification-Bit 0,2,
IDE11302,Engine oil level: test method 1 qualification,Engine hood was open,
IDE11303-MAS05513,Engine oil level: test method 3 qualification-Bit 0,2,
IDE11303,Engine oil level: test method 3 qualification,Engine hood was open,
IDE11331-MAS03057,Torque reduction: clutch protection history 1-Kilometers,0, km
IDE11331-MAS10499,Torque reduction: clutch protection history 1-Torque,0, Nm
IDE11332-MAS03057,Torque reduction: clutch protection history 2-Kilometers,0, km
IDE11332-MAS10499,Torque reduction: clutch protection history 2-Torque,0, Nm
IDE11333-MAS03057,Torque reduction: clutch protection history 3-Kilometers,0, km
IDE11333-MAS10499,Torque reduction: clutch protection history 3-Torque,0, Nm
IDE11334-MAS03057,Torque reduction: clutch protection history 4-Kilometers,0, km
IDE11334-MAS10499,Torque reduction: clutch protection history 4-Torque,0, Nm
IDE11335-MAS03057,Torque reduction: clutch protection history 5-Kilometers,0, km
IDE11335-MAS10499,Torque reduction: clutch protection history 5-Torque,0, Nm
IDE11336-MAS03057,Torque reduction: clutch protection history 6-Kilometers,0, km
IDE11336-MAS10499,Torque reduction: clutch protection history 6-Torque,0, Nm
IDE11337-MAS03057,Torque reduction: clutch protection history 7-Kilometers,0, km
IDE11337-MAS10499,Torque reduction: clutch protection history 7-Torque,0, Nm
IDE11338-MAS03057,Torque reduction: clutch protection history 8-Kilometers,0, km
IDE11338-MAS10499,Torque reduction: clutch protection history 8-Torque,0, Nm
IDE11339-MAS03057,Torque reduction: clutch protection history 9-Kilometers,0, km
IDE11339-MAS10499,Torque reduction: clutch protection history 9-Torque,0, Nm
IDE11340-MAS03057,Torque reduction: clutch protection history 10-Kilometers,0, km
IDE11340-MAS10499,Torque reduction: clutch protection history 10-Torque,0, Nm
IDE11493,Disengaging clutch actuator: act. position,0.00000, mm
IDE11494-MAS03359,Disengaging clutch actuator: status-Text,OFF,
IDE11495,Disengaging clutch actuator: current,-50.0, A
IDE11496,Disengaging clutch actuator: voltage,0.0, V
IDE11498,Decoupler actuator,0.00, °C
IDE11577-MAS04415,Stop process prevented 2-Ambient air pressure,not active,
IDE11577-MAS04416,Stop process prevented 2-Sporadic function prevention,not active,
IDE11577-MAS04417,Stop process prevented 2-Poor start detection,not active,
IDE11577-MAS04589,Stop process prevented 2-Diagnosis of exhaust system,not active,
IDE11577-MAS04590,Stop process prevented 2-Mixture adaptation,not active,
IDE11577-MAS04591,Stop process prevented 2-Air system diagnosis,not active,
IDE11577-MAS04870,Stop process prevented 2-Thermostat testing not completed,not active,
IDE11577-MAS06602,Stop process prevented 2-Engine temperature,not active,
IDE11577-MAS06604,Stop process prevented 2-Start/stop sensors:,not active,
IDE11577-MAS06605,Stop process prevented 2-Regeneration Mode,not active,
IDE11577-MAS06606,Stop process prevented 2-Brake under pressure too low,not active,
IDE11577-MAS08032,Stop process prevented 2-DTC memory entry in engine control module,not active,
IDE11577-MAS09416,Stop process prevented 2-Learning function active,not active,
IDE11577-MAS13644,Stop process prevented 2-Engine protection active,not active,
IDE11577-MAS13645,Stop process prevented 2-Fuel gelling protection active,not active,
IDE11577-MAS13661,Stop process prevented 2-Exhaust treatment diagnosis,not active,
IDE11577-MAS16918,Stop process prevented 2-Restriction in start system,not active,
IDE11598,Tank deaeration valve diagnosis: unweighted input value,0.000, counts
IDE11599,Tank deaeration valve diagnosis: weighted output value,0.000, counts
IDE11919,Lock time for cooling down of secondary air pump,0, s
IDE12099-MAS10949,Decoupler actuator: manufacturers code: block A-Manufacturer code 1,0,
IDE12099-MAS10950,Decoupler actuator: manufacturers code: block A-Manufacturer code 2,0,
IDE12100-MAS10951,Decoupler actuator: manufacturers code: block B-Manufacturer code 3,0,
IDE12100-MAS10952,Decoupler actuator: manufacturers code: block B-Manufacturer code 4,0,
IDE12137,Tank fill level diagnostic reference value,54.0, l
IDE12138,Fuel consumption per driving cycle,46.80, l/100km
IDE12210,Particle filter: water mass,0.0, g
IDE13084,Particle filter: high level moisture buildup,6553.5, g
IDE13085,Particle filter: high level of soot buildup,65.54, g
IDE13086,Particle filter: maximum soot build-up reached,65.54, g
IDE13087,Particle filter: maximum ash build-up reached,510.00, g
IDE13088,Particle filter: maximum ash loading ratio reached,6.000, counts
IDE13089,Particle filter: high soot accumulation ratio,51.199, counts
IDE13090,Particle filter: maximum soot loading ratio reached,51.199, counts
IDE13091,Particle filter: ash loading ratio,0.001, counts
IDE13092,Particle filter: soot accumulation ratio,1.000, counts
IDE13301-MAS06606,Drivetrain coordinator: brake fault status-Brake under pressure too low,No,
IDE13301-MAS14986,Drivetrain coordinator: brake fault status-Deceleration sensor not available,No,
IDE13301-MAS14987,Drivetrain coordinator: brake fault status-Deceleration sensor malfunction,No,
IDE13301-MAS14988,Drivetrain coordinator: brake fault status-ESP system error,No,
IDE13301-MAS14989,Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque,No,
IDE13301-MAS14990,Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error,No,
IDE13301-MAS14991,Drivetrain coordinator: brake fault status-TSK/ESP handshake error,No,
IDE13301-MAS14992,Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction,No,
IDE13301-MAS14993,Drivetrain coordinator: brake fault status-Brake light implausible,No,
IDE13301-MAS16114,Drivetrain coordinator: brake fault status-Deceleration management error,No,
IDE13301-MAS16115,Drivetrain coordinator: brake fault status-Deceleration management: restricted performance,No,
IDE13301-MAS16116,Drivetrain coordinator: brake fault status-Deceleration management not available,No,
IDE13336-MAS04795,Drive train coordinator reversible switch off conditions-main switch off,No,
IDE13336-MAS05192,Drive train coordinator reversible switch off conditions-Driver braking,No,
IDE13336-MAS05823,Drive train coordinator reversible switch off conditions-Speed signal error during initialization,No,
IDE13336-MAS05824,Drive train coordinator reversible switch off conditions-Emer. engine operation,No,
IDE13336-MAS05836,Drive train coordinator reversible switch off conditions-Acceleration monitoring error,No,
IDE13336-MAS05901,Drive train coordinator reversible switch off conditions-Trans. emerg. operation,No,
IDE13336-MAS12585,Drive train coordinator reversible switch off conditions-Speed threshold for reversible ACC shut-off,No,
IDE13336-MAS12586,Drive train coordinator reversible switch off conditions-Speed threshold for ending the brake torque shut-off ramp,No,
IDE13336-MAS12588,Drive train coordinator reversible switch off conditions-Speed cut-off active,No,
IDE13336-MAS12590,Drive train coordinator reversible switch off conditions-Reversible brake system error,No,
IDE13336-MAS12591,Drive train coordinator reversible switch off conditions-Engine off or drive is not ready,No,
IDE13336-MAS15049,Drive train coordinator reversible switch off conditions-Drive train open or no gear selected,Yes,
IDE13336-MAS16227,Drive train coordinator reversible switch off conditions-Stopping distance reduction 3 interventions,No,
IDE13336-MAS16228,Drive train coordinator reversible switch off conditions-Tracking system interface shutdown,No,
IDE13336-MAS16230,Drive train coordinator reversible switch off conditions-ESP safety-related message condition,No,
IDE13336-MAS16231,Drive train coordinator reversible switch off conditions-ACC switch off because of driver braking,No,
IDE13336-MAS16232,Drive train coordinator reversible switch off conditions-PCC sensor: reversible error,No,
IDE13336-MAS16235,Drive train coordinator reversible switch off conditions-Intelligent parking assistant reversible error,No,
IDE13336-MAS16246,Drive train coordinator reversible switch off conditions-ACC breaking only possible because of CAN bus,No,
IDE13336-MAS16247,Drive train coordinator reversible switch off conditions-Diagnostics fadeout due to identified malfunction,No,
IDE13336-MAS16248,Drive train coordinator reversible switch off conditions-Safety computer detects crash,No,
IDE13336-MAS16249,Drive train coordinator reversible switch off conditions-Electrical parking brake: braking,No,
IDE13336-MAS16253,Drive train coordinator reversible switch off conditions-GRA breaking intervention: switch off due to brake disc temperature,No,
IDE13336-MAS16254,Drive train coordinator reversible switch off conditions-Hill descent assistant active,No,
IDE13336-MAS16255,Drive train coordinator reversible switch off conditions-Locking by trailer shunting assistant,No,
IDE13336-MAS16256,Drive train coordinator reversible switch off conditions-Blocking by parking assistant,No,
IDE13337-MAS05814,Drive train coordinator irreversible switch off conditions-CAN communication error,No,
IDE13337-MAS05815,Drive train coordinator irreversible switch off conditions-CAN signal error,No,
IDE13337-MAS05818,Drive train coordinator irreversible switch off conditions-Transmission coding not plausible,No,
IDE13337-MAS05820,Drive train coordinator irreversible switch off conditions-ACC error,No,
IDE13337-MAS05821,Drive train coordinator irreversible switch off conditions-Braking intervention too weak,No,
IDE13337-MAS05824,Drive train coordinator irreversible switch off conditions-Emer. engine operation,No,
IDE13337-MAS05825,Drive train coordinator irreversible switch off conditions-Engine control module fault,No,
IDE13337-MAS05829,Drive train coordinator irreversible switch off conditions-Brake light fault,No,
IDE13337-MAS05830,Drive train coordinator irreversible switch off conditions-CCS deactivated due to fault in control component,No,
IDE13337-MAS05831,Drive train coordinator irreversible switch off conditions-ACC deactivated due to fault in control component,No,
IDE13337-MAS05832,Drive train coordinator irreversible switch off conditions-Coding error,No,
IDE13337-MAS05833,Drive train coordinator irreversible switch off conditions-ESC error,No,
IDE13337-MAS05835,Drive train coordinator irreversible switch off conditions-Clutch pedal fault,No,
IDE13337-MAS05836,Drive train coordinator irreversible switch off conditions-Acceleration monitoring error,No,
IDE13337-MAS15052,Drive train coordinator irreversible switch off conditions-Brake light actuation malfunction,No,
IDE13337-MAS16257,Drive train coordinator irreversible switch off conditions-Brake pedal implausible,No,
IDE13337-MAS16258,Drive train coordinator irreversible switch off conditions-Transport mode active,No,
IDE13337-MAS16259,Drive train coordinator irreversible switch off conditions-GRA looking due to software as product,No,
IDE13337-MAS16260,Drive train coordinator irreversible switch off conditions-Emergency assistant: actual acceleration error,No,
IDE13337-MAS16262,Drive train coordinator irreversible switch off conditions-Vehicle speed determination: substitute value,No,
IDE13337-MAS16263,Drive train coordinator irreversible switch off conditions-Intelligent parking assistant irreversible error,No,
IDE13845,Production mode status,not active,
IDE14753,Particulate filter: loading stage,0, counts
IDE14760,Particulate filter: oil ash load measured,0.0, %
IDE14761,Particulate filter: oil ash load calculated,0.0, %
IDE14763,Particulate filter: water load,0.0, %
IDE14765,Particulate filter: soot load measured,16.5, %
IDE14767,Particulate filter: soot load calculated,0.0, %
IDE14789-ENG121460,Currently selected and last used starter device-active start device selection - belt starter generator,not selected,
IDE14789-ENG121461,Currently selected and last used starter device-active start device selection - electrical machine,not selected,
IDE14789-ENG121462,Currently selected and last used starter device-active start device selection - pinion starter,not selected,
IDE14789-ENG121512,Currently selected and last used starter device-last used start device - belt starter generator,not active,
IDE14789-ENG121513,Currently selected and last used starter device-last used start device - electrical machine,not active,
IDE14789-ENG121514,Currently selected and last used starter device-last used start device - pinion starter,not active,
IDE15976-ENG13829,Particulate filter regeneration history-Endkilometer 1,0, km
IDE15976-ENG13830,Particulate filter regeneration history-Endkilometer 2,0, km
IDE15976-ENG13831,Particulate filter regeneration history-Endkilometer 3,0, km
IDE15976-ENG13827,Particulate filter regeneration history-Startkilometer 1,0, km
IDE15976-ENG13826,Particulate filter regeneration history-Startkilometer 2,0, km
IDE15976-ENG13828,Particulate filter regeneration history-Startkilometer 3,0, km
IDE15979,Service regeneration of particulate filter: advance,0, %
ENG102981,AC compressor: speed increase,00000000 ,
ENG103860,AC request: speed increase,00000000 ,
ENG103042,Accelerator pedal sender: learned end stop,4.126, V
ENG101488,ACF: load,0.01035,
ENG103474,Activation of oil pressure switching valve,00000001 ,
ENG121286,Active Powertrain Warm-up Features Off-cycle Credit Vehicle Data,|Active Engine Warm-up Timer (Recent),Active Engine Warm-up Timer (Lifetime)
ENG103323,Additional water pump,00000001 ,
ENG101828,Air mass,8.97, kg/h
ENG104264,Alternator load,750, W
ENG103910,Ambient temperature,18.00, °C
ENG112539,AR_THR_AD_ADD_MMV,0.0018, cm²
ENG103165,Battery voltage,13.3, V
ENG07601,Bypasstool_a2l_name,SCRF24,
ENG07600,Bypasstool_manipulation_bit,not active,
ENG101413,Calibration Identification,||5H0259A 0001AVAE|,
ENG99697,Calibration Verification Number,||49 36 89 80|,
ENG128780,CAM_DIF_VCP{EX_1},0.023, °
ENG128781,CAM_DIF_VCP{IN_1},-0.070, °
ENG112540,CAM_PHA_ENG{GES_EX}{CBK_1},0.039, °
ENG112541,CAM_PHA_ENG{GES_IN}{CBK_1},15.031, °
ENG101785,Cat. temperature: bank 1,355.7875, °C
ENG125189,CTR_CAM_IN_SP_PI_DET_REQ{0},0,
ENG125190,CTR_CAM_IN_SP_PI_DET_REQ{1},0,
ENG125191,CTR_CAM_IN_SP_PI_DET_REQ{2},0,
ENG125192,CTR_CAM_IN_SP_PI_DET_REQ{3},0,
ENG125193,CTR_LAMB_SP_PI_REQ{0},0,
ENG125194,CTR_LAMB_SP_PI_REQ{1},0,
ENG125195,CTR_LAMB_SP_PI_REQ{2},0,
ENG125196,CTR_LAMB_SP_PI_REQ{3},0,
ENG112554,CTR_MIS_DC_MMV_CYL_SAE{0},4,
ENG112555,CTR_MIS_DC_MMV_CYL_SAE{1},5,
ENG112556,CTR_MIS_DC_MMV_CYL_SAE{2},5,
ENG112557,CTR_MIS_DC_MMV_CYL_SAE{3},3,
ENG112558,CTR_MIS_TOT_NVMY_SAE,1724,
ENG125197,CTR_REQ_IV_OFF_PI_FAST{0},0,
ENG125198,CTR_REQ_IV_OFF_PI_FAST{1},0,
ENG125199,CTR_REQ_IV_OFF_PI_FAST{2},0,
ENG125200,CTR_REQ_IV_OFF_PI_FAST{3},0,
ENG125201,CTR_REQ_IV_OFF_PI_SLOW{0},0,
ENG125202,CTR_REQ_IV_OFF_PI_SLOW{1},0,
ENG125203,CTR_REQ_IV_OFF_PI_SLOW{2},0,
ENG125204,CTR_REQ_IV_OFF_PI_SLOW{3},0,
ENG128782,CTR_REQ_IV_OFF_PI_SLOW_TMP{0},0,
ENG128783,CTR_REQ_IV_OFF_PI_SLOW_TMP{1},0,
ENG128784,CTR_REQ_IV_OFF_PI_SLOW_TMP{2},0,
ENG128785,CTR_REQ_IV_OFF_PI_SLOW_TMP{3},0,
ENG100764,CTR_SUM_SRV_INTL,0.0,
ENG125205,CTR_TQI_POW_MAX_PI_REQ{0},0,
ENG125206,CTR_TQI_POW_MAX_PI_REQ{1},0,
ENG125207,CTR_TQI_POW_MAX_PI_REQ{2},0,
ENG125208,CTR_TQI_POW_MAX_PI_REQ{3},0,
ENG119929,CTR_VLD_CAT_GAP_AFL{1},0,
ENG119930,CTR_VLD_CAT_GAP_AFR{1},0,
ENG112559,CTR_VVL_LIH_ACT,0,
ENG101271,CTR_VVL_LIH_DEAC,0,
ENG101652,Cylinder shut-off: cylinder suppression,00000000 ,
ENG112560,DIST_ACT_MIL_SAE,0, km
ENG112561,DIST_DTC_CLR_SAE,3945, km
ENG100531,DIST_ST,3.9656e+006, m
ENG13501,Distance Traveled Since Evap Monitoring Decision,|Distance Traveled Since Evap Monitoring Decision|345|, km
ENG100131,ECU_STATE,SYN_ENG_IGK_ON,
ENG100152,ECUNAME,|ECU,ECUNAME|ECM
ENG100882,EFF_IGA_CST_QUO_IS_MAX,6, %
ENG99938,EFF_IGA_CST_QUO_PL_MAX,10, %
ENG115973,Engine Exhaust Flow Rate,9.4, kg/h
ENG20102,Engine Friction - Percent Torque,3.0, %
ENG104044,Engine load,10.5, %
ENG103667,ENVD_0_MON,0,
ENG99424,ENVD_1_MON,0,
ENG99790,ENVD_2_MON,0,
ENG99455,ENVD_3_MON,0,
ENG01743,ENVD_4_MON,0,
ENG01744,ENVD_5_MON,0,
ENG01745,ENVD_6_MON,0,
ENG114481,ENVD_MON_3{0},0,
ENG114482,ENVD_MON_3{1},0,
ENG114483,ENVD_MON_3{2},0,
ENG114484,ENVD_MON_3{3},0,
ENG114485,ENVD_MON_3{4},0,
ENG114486,ENVD_MON_3{5},0,
ENG114487,ENVD_MON_3{6},0,
ENG114488,ENVD_MON_3_CAN{0},0,
ENG114489,ENVD_MON_3_CAN{1},0,
ENG114490,ENVD_MON_3_CAN{2},0,
ENG114491,ENVD_MON_3_CAN{3},0,
ENG114492,ENVD_MON_3_CAN{4},0,
ENG114493,ENVD_MON_3_CAN{5},0,
ENG114494,ENVD_MON_3_CAN{6},0,
ENG114495,ENVD_MON_3_SW{0},0,
ENG114496,ENVD_MON_3_SW{1},0,
ENG114497,ENVD_MON_3_SW{2},0,
ENG114498,ENVD_MON_3_SW{3},0,
ENG114499,ENVD_MON_3_SW{4},0,
ENG114500,ENVD_MON_3_SW{5},0,
ENG114501,ENVD_MON_3_SW{6},0,
ENG114502,ENVD_MON_3_TMP{0},0,
ENG114503,ENVD_MON_3_TMP{1},0,
ENG114504,ENVD_MON_3_TMP{2},0,
ENG114505,ENVD_MON_3_TMP{3},0,
ENG114506,ENVD_MON_3_TMP{4},0,
ENG114507,ENVD_MON_3_TMP{5},0,
ENG114508,ENVD_MON_3_TMP{6},0,
ENG114509,ENVD_MON_3_VD{0},0,
ENG114510,ENVD_MON_3_VD{1},0,
ENG114511,ENVD_MON_3_VD{2},0,
ENG114512,ENVD_MON_3_VD{3},0,
ENG114513,ENVD_MON_3_VD{4},0,
ENG114514,ENVD_MON_3_VD{5},0,
ENG114515,ENVD_MON_3_VD{6},0,
ENG114516,ENVD_MON3_COD_PROT_COD_ADR{0},0,
ENG114517,ENVD_MON3_COD_PROT_COD_ADR{1},0,
ENG114518,ENVD_MON3_COD_PROT_COD_ADR{2},0,
ENG114519,ENVD_MON3_COD_PROT_COD_ADR{3},0,
ENG114520,ENVD_MON3_COD_PROT_COD_ADR{4},0,
ENG114521,ENVD_MON3_COD_PROT_COD_ADR{5},0,
ENG114522,ENVD_MON3_COD_PROT_COD_ADR{6},0,
ENG114523,ENVD_MON3_COD_PROT_COD_ADR{7},0,
ENG114524,ENVD_MON3_COD_PROT_COD_ADR{8},0,
ENG114525,ENVD_MON3_COD_PROT_COD_ADR{9},0,
ENG114526,ENVD_MON3_COD_PROT_IDF_CPU{0},0,
ENG114527,ENVD_MON3_COD_PROT_IDF_CPU{1},0,
ENG114528,ENVD_MON3_COD_PROT_IDF_CPU{2},0,
ENG114529,ENVD_MON3_COD_PROT_IDF_CPU{3},0,
ENG114530,ENVD_MON3_COD_PROT_IDF_CPU{4},0,
ENG114531,ENVD_MON3_COD_PROT_IDF_CPU{5},0,
ENG114532,ENVD_MON3_COD_PROT_IDF_CPU{6},0,
ENG114533,ENVD_MON3_COD_PROT_IDF_CPU{7},0,
ENG114534,ENVD_MON3_COD_PROT_IDF_CPU{8},0,
ENG114535,ENVD_MON3_COD_PROT_IDF_CPU{9},0,
ENG114536,ENVD_MON3_DATA_PROT_COD_ADR{0},0,
ENG114537,ENVD_MON3_DATA_PROT_COD_ADR{1},0,
ENG114538,ENVD_MON3_DATA_PROT_COD_ADR{2},0,
ENG114539,ENVD_MON3_DATA_PROT_COD_ADR{3},0,
ENG114540,ENVD_MON3_DATA_PROT_COD_ADR{4},0,
ENG114541,ENVD_MON3_DATA_PROT_COD_ADR{5},0,
ENG114542,ENVD_MON3_DATA_PROT_COD_ADR{6},0,
ENG114543,ENVD_MON3_DATA_PROT_COD_ADR{7},0,
ENG114544,ENVD_MON3_DATA_PROT_COD_ADR{8},0,
ENG114545,ENVD_MON3_DATA_PROT_COD_ADR{9},0,
ENG114546,ENVD_MON3_DATA_PROT_DATA_ADR{0},0,
ENG114547,ENVD_MON3_DATA_PROT_DATA_ADR{1},0,
ENG114548,ENVD_MON3_DATA_PROT_DATA_ADR{2},0,
ENG114549,ENVD_MON3_DATA_PROT_DATA_ADR{3},0,
ENG114550,ENVD_MON3_DATA_PROT_DATA_ADR{4},0,
ENG114551,ENVD_MON3_DATA_PROT_DATA_ADR{5},0,
ENG114552,ENVD_MON3_DATA_PROT_DATA_ADR{6},0,
ENG114553,ENVD_MON3_DATA_PROT_DATA_ADR{7},0,
ENG114554,ENVD_MON3_DATA_PROT_DATA_ADR{8},0,
ENG114555,ENVD_MON3_DATA_PROT_DATA_ADR{9},0,
ENG114556,ENVD_MON3_DATA_PROT_IDF_CPU{0},0,
ENG114557,ENVD_MON3_DATA_PROT_IDF_CPU{1},0,
ENG114558,ENVD_MON3_DATA_PROT_IDF_CPU{2},0,
ENG114559,ENVD_MON3_DATA_PROT_IDF_CPU{3},0,
ENG114560,ENVD_MON3_DATA_PROT_IDF_CPU{4},0,
ENG114561,ENVD_MON3_DATA_PROT_IDF_CPU{5},0,
ENG114562,ENVD_MON3_DATA_PROT_IDF_CPU{6},0,
ENG114563,ENVD_MON3_DATA_PROT_IDF_CPU{7},0,
ENG114564,ENVD_MON3_DATA_PROT_IDF_CPU{8},0,
ENG114565,ENVD_MON3_DATA_PROT_IDF_CPU{9},0,
ENG101942,ESI (extended service intervals) oil warning threshold,0.00, mm
ENG112562,FAC_AR_THR_AD,0.000, %
ENG114570,FAC_FQ_ST_AD_SAVE_RNG_1_H_RES,1.00000,
ENG114571,FAC_FQ_ST_AD_SAVE_RNG_2_H_RES,1.00000,
ENG114572,FAC_FQ_ST_AD_SAVE_RNG_3_H_RES,1.00000,
ENG114573,FAC_FQ_ST_AD_SAVE_RNG_4_H_RES,1.00000,
ENG100298,FAC_LAM_CP,-1.022, %
ENG100108,FAC_LAM_LIM{1},-1.039, %
ENG99722,FAC_LAM_TCO_A{1},0.000, %
ENG103521,FAC_LAM_TCO_B{1},0.000, %
ENG103641,FAC_LAM_TCO_C{1},0.000, %
ENG101578,FAC_LAM_TCO_D{1},0.000, %
ENG100685,FAC_LAM_TCO_E{1},0.000, %
ENG102306,FAC_TPS_1_SAE,12.1568629, %
ENG102292,FAC_TPS_1_SAE,11.7647061, %
ENG101437,Fan request from air conditioner,0.00, %
ENG103644,FRF_IMMO_SNAPSHOT_BYTE1,0,
ENG102892,FRF_IMMO_SNAPSHOT_BYTE2,0,
ENG100521,FRF_IMMO_SNAPSHOT_BYTE3,0,
ENG101852,FRF_IMMO_SNAPSHOT_BYTE4,0,
ENG99312,FRF_IMMO_SNAPSHOT_BYTE5,0,
ENG103956,FRF_IMMO_SNAPSHOT_BYTE6,0,
ENG128786,FTL_SAE,78.0, %
ENG104248,Fuel consumption signal,48696, µl
ENG115974-ENG55378,Fuel Rate-Engine Fuel Rate,0.16, g/s
ENG115974-ENG116137,Fuel Rate-Vehicle Fuel Rate,0.16, g/s
ENG101692,Fuel supply system: high-pressure regulator,-0.346654, hPa
ENG114828,FUP_EFP_MES,2223.52, hPa
ENG102108,FUP_H,0.0, hPa
ENG112563,FUP_H_SAE,7080, kPa
ENG99170,Height correction,999.49, hPa
ENG103575,High-pressure system: regulator,0.00, mg
ENG103879,High-pressure system: regulator: mobile part,2.46, mg
ENG101567,Idling speed stabilisation: duty cycle/AC compressor torque,0.00, Nm
ENG101946,Idling stabilisation: operating status,00000000 ,
ENG114578,IDX_FUEL_SYS_SAE{1},2,
ENG100345,IGA_ADJ_KNK{0},0.000, °
ENG103593,IGA_ADJ_KNK{1},0.000, °
ENG103360,IGA_ADJ_KNK{2},0.000, °
ENG99404,IGA_ADJ_KNK{3},0.000, °
ENG100425,IGA_IGC{0},2.625, °
ENG101655,IGA_IGC{1},3.375, °
ENG100410,IGA_IGC{2},3.375, °
ENG100407,IGA_IGC{3},2.625, °
ENG112564,IGA_IGC_SAE,2.5, °
ENG100634-ENG36978,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Com Enc Cou B 2-Counters 3-EOP,|Completion Condition Counts,Conditions Encountered Counts|70
ENG125209,KNKS_ERR_REL{0},0.0000, V
ENG99741,LAMB_DELTA_AD_LAM_ADJ{1},0.00104,
ENG112565,LAMB_DELTA_SUM_LAM_ADJ_AD{1},0.00104,
ENG99674,Lambda controller: bank 1 (averaged value),-1.237, %
ENG101381,Lambda probe 1: bank 1: status,00000001 ,
ENG101039,Lambda probe 1: bank 1: status,00000000 ,
ENG102886,Lambda probe 1: bank 1: status,00000000 ,
ENG104200,Lambda probe 2: bank 1: status,00000000 ,
ENG101336,Lambda probe 2: bank 1: status,00000001 ,
ENG101869,Lambda probe ageing: bank 1: probe 1: short trip result,333.6625, °C
ENG100478,Lambda probe correction: duty cycle offset: bank 1,0.00226,
ENG102763,Lambda probes actual: bank1,0.9932,
ENG114584,LF_COSI_CTL_ERR,0,
ENG114585,LF_DPS_CYC_ERR_RAW_BSW{CYL_0},0,
ENG114586,LF_DPS_CYC_ERR_RAW_BSW{CYL_1},0,
ENG114587,LF_DPS_CYC_ERR_RAW_BSW{CYL_2},0,
ENG114588,LF_DPS_CYC_ERR_RAW_BSW{CYL_3},0,
ENG114589,LF_DPS_CYC_ERR_VLD_BSW{CYL_0},2097151,
ENG114590,LF_DPS_CYC_ERR_VLD_BSW{CYL_1},2097151,
ENG114591,LF_DPS_CYC_ERR_VLD_BSW{CYL_2},2097151,
ENG114592,LF_DPS_CYC_ERR_VLD_BSW{CYL_3},2097151,
ENG112570,LF_DPS_INI_ERR_RAW_BSW{1},0,
ENG112571,LF_DPS_INI_ERR_RAW_BSW{2},0,
ENG114593,LF_IV_ERR_RAW_BSW{CYL_0},0,
ENG114594,LF_IV_ERR_RAW_BSW{CYL_1},0,
ENG114595,LF_IV_ERR_RAW_BSW{CYL_2},0,
ENG114596,LF_IV_ERR_RAW_BSW{CYL_3},0,
ENG114597,LF_IV_ERR_VLD_BSW{CYL_0},511,
ENG114598,LF_IV_ERR_VLD_BSW{CYL_1},511,
ENG114599,LF_IV_ERR_VLD_BSW{CYL_2},511,
ENG114600,LF_IV_ERR_VLD_BSW{CYL_3},511,
ENG07602,LF_MVB_BUS_INTC_DIAG,256,
ENG07603,LF_MVB_PDU_INTC_DIAG_1,0,
ENG07604,LF_MVB_PDU_INTC_DIAG_10,0,
ENG37770,LF_MVB_PDU_INTC_DIAG_11,8192,
ENG37771,LF_MVB_PDU_INTC_DIAG_12,13,
ENG07605,LF_MVB_PDU_INTC_DIAG_13,2,
ENG07607,LF_MVB_PDU_INTC_DIAG_15,0,
ENG07608,LF_MVB_PDU_INTC_DIAG_16,0,
ENG07609,LF_MVB_PDU_INTC_DIAG_17,0,
ENG07610,LF_MVB_PDU_INTC_DIAG_18,0,
ENG37772,LF_MVB_PDU_INTC_DIAG_19,0,
ENG07611,LF_MVB_PDU_INTC_DIAG_2,0,
ENG37773,LF_MVB_PDU_INTC_DIAG_20,0,
ENG37774,LF_MVB_PDU_INTC_DIAG_22,0,
ENG37775,LF_MVB_PDU_INTC_DIAG_23,0,
ENG37776,LF_MVB_PDU_INTC_DIAG_24,0,
ENG37777,LF_MVB_PDU_INTC_DIAG_25,0,
ENG37778,LF_MVB_PDU_INTC_DIAG_26,0,
ENG37779,LF_MVB_PDU_INTC_DIAG_27,0,
ENG07612,LF_MVB_PDU_INTC_DIAG_3,63,
ENG07613,LF_MVB_PDU_INTC_DIAG_4,0,
ENG07614,LF_MVB_PDU_INTC_DIAG_5,0,
ENG07615,LF_MVB_PDU_INTC_DIAG_6,0,
ENG07617,LF_MVB_PDU_INTC_DIAG_8,0,
ENG07618,LF_MVB_PDU_INTC_DIAG_9,0,
ENG118081,LF_TQ_PT_ACT_REQ,512,
ENG127734,Life_cycle_data_start_requirement_development,|Year,Month
ENG127735,Life_cycle_data_stop_prohibition_development,|Year,Month
ENG127733,Life_cycle_data_system_failure,|Year,Month
ENG114601,LOAD_CLC_SAE,10.6, %
ENG100402,LOIL_SUM_SRV_INTL,-0.06, mm
ENG99162,LV_ACC_RED_CMD,00000000 ,
ENG102235,LV_ATB_ACT_1,00000000 ,
ENG102541,LV_ATB_ACT_2,00000000 ,
ENG112584,LV_BPA_AD_REQ{0},00000000 ,
ENG114829,LV_BPA_LIH_REQ{0},00000000 ,
ENG128787,LV_CMD_RCL_OPEN,00000000 ,
ENG114605,LV_CRU_ENA_BRAKE_INTV,00000001 ,
ENG103049,LV_EFPPWM_AD_STOP,00000001 ,
ENG112471,LV_IGK,00000001 ,
ENG100044,LV_LOIL_L_WARN,00000000 ,
ENG103492,LV_LOIL_L_WARN_ACT,00000000 ,
ENG103908,LV_LOIL_L_WARN_TMP,00000000 ,
ENG114607,LV_PWR_RLY{ENG_RLY},00000001 ,
ENG102417,LV_TPS_AD_ACT,00000000 ,
ENG100842,LV_TPS_AD_DIAG_ERR,0,
ENG103996,LV_TPS_AD_REQ,00000000 ,
ENG112588,MAP_MES_SAE,27, kPa
ENG103501,MASS_SA_REL{0},0.000,
ENG100896,MASS_SA_REL_21_PHA,0.000,
ENG103045,MASS_SA_REL_22_PHA,0.000,
ENG126493,MFF_MPL_ADD_LAM_AD{1}{1},0.00, mg/stroke
ENG101360,Misfire detection active,00000000 ,
ENG102335,Misfires all cylinders per 1000 rpm,0,
ENG114614,N_SAE,769.8, /min
ENG128796,N_SP_IS_CLC,771, /min
ENG103004,N_TCHA,1239.01, /min
ENG112590,N_TOOTH,789, /min
ENG126111,NL_PRE{0},0.504, V
ENG126112,NL_PRE{1},0.780, V
ENG126113,NL_PRE{2},0.769, V
ENG126114,NL_PRE{3},0.573, V
ENG114615,NR_CYC_AD_DC_BAL_HOM{0},0,
ENG114616,NR_CYC_AD_DC_BAL_HOM{1},0,
ENG114617,NR_CYC_AD_DC_BAL_HOM{2},0,
ENG13563,NR_CYC_DIAG_BAL_HOM_AD_MAX{0},0,
ENG13564,NR_CYC_DIAG_BAL_HOM_AD_MAX{1},0,
ENG13565,NR_CYC_DIAG_BAL_HOM_AD_MAX{2},0,
ENG13566,NR_CYC_DIAG_BAL_HOM_AD_MAX{3},0,
ENG13567,NR_CYC_DIAG_BAL_HOM_AD_MIN{0},0,
ENG13568,NR_CYC_DIAG_BAL_HOM_AD_MIN{1},0,
ENG13569,NR_CYC_DIAG_BAL_HOM_AD_MIN{2},0,
ENG13570,NR_CYC_DIAG_BAL_HOM_AD_MIN{3},0,
ENG112589,NR_CYL_FIRST_VVL_SWI,0,
ENG119936,O2L_MAX_CAT_GAP_AFL_MV{1},0.00000, g
ENG119937,O2L_MAX_CAT_GAP_AFR_MV{1},0.00000, g
ENG99157,PRS_SA_DIF,0.00, hPa
ENG128797,PV,0.00, %
ENG102195,PV_AV_1,0.00, %
ENG99137,PV_AV_2,0.00, %
ENG101068,PV_AV_H,0.00, %
ENG112593,PWM_ACT_VCP{EX_1},100.000, %
ENG112594,PWM_ACT_VCP{IN_1},100.000, %
ENG112597,PWM_PAS_VCP{EX_1},0.000, %
ENG112598,PWM_PAS_VCP{IN_1},0.000, %
ENG101201,Radiator fan 1: run-on: status,600W,
ENG102359,Radiator fan 2: run-on: status,400W,
ENG119939,RATIO_O2L_LIM_CAT_GAP_AFL_MV{1},4.8284254,
ENG119940,RATIO_O2L_LIM_CAT_GAP_AFR_MV{1},0.0000000,
ENG103248,SEG_AD_MMV_ER{0},0.0000,
ENG101135,SEG_AD_MMV_ER{1},0.4573,
ENG99078,SEG_AD_MMV_ER{2},0.0370,
ENG103257,SEG_AD_MMV_ER{3},0.4973,
ENG103381,Shut-off time,87.70, s
ENG100919,Starter control: interlock switch,00000000 ,
ENG114637,STATE_CRU_DCC_REQ_CUS,2,
ENG114834,STATE_CRU_OFF_IRR_CUS,0,
ENG114835,STATE_CRU_OFF_REV_CUS,16924736,
ENG114638,STATE_CRU_PT_CUS,20680,
ENG114639,STATE_FRF_BYTE_IMMO_APP_1,0,
ENG114640,STATE_FRF_BYTE_IMMO_APP_2,0,
ENG114641,STATE_FRF_BYTE_IMMO_APP_3,0,
ENG114642,STATE_FRF_BYTE_IMMO_APP_4,0,
ENG114643,STATE_FRF_BYTE_IMMO_APP_5,0,
ENG114644,STATE_FRF_BYTE_IMMO_APP_6,0,
ENG114645,STATE_FRF_BYTE_IMMO_DEAC_1,0,
ENG114646,STATE_FRF_BYTE_IMMO_DEAC_2,0,
ENG114647,STATE_FRF_BYTE_IMMO_DEAC_3,0,
ENG114648,STATE_FRF_BYTE_IMMO_DEAC_4,0,
ENG114649,STATE_FRF_BYTE_IMMO_DEAC_5,0,
ENG114650,STATE_FRF_BYTE_IMMO_DEAC_6,0,
ENG114651,STATE_FRF_BYTE_IMMO_RST_SAFE_1,0,
ENG114652,STATE_FRF_BYTE_IMMO_RST_SAFE_2,0,
ENG114653,STATE_FRF_BYTE_IMMO_RST_SAFE_3,0,
ENG114654,STATE_FRF_BYTE_IMMO_RST_SAFE_4,0,
ENG114655,STATE_FRF_BYTE_IMMO_RST_SAFE_5,0,
ENG114656,STATE_FRF_BYTE_IMMO_RST_SAFE_6,0,
ENG112606,STATE_PWM_VCP{EX_1},HLD,
ENG112607,STATE_PWM_VCP{IN_1},pas,
ENG27138,STATE_T_ES_VLD_ATIC,1,
ENG114659,STATE_T_ES_VLD_ENVD,135444,
ENG112608,STATE_VCP,passive,
ENG114836,STATE_VCV_CLOSE_SL,OFF,
ENG112609,T_ACT_MIL_SAE,0, min
ENG112494,T_AST_SAE,712, s
ENG104148,T_COOL_LOIL,648.6, ms
ENG112613,T_DTC_CLR_SAE,2947, min
ENG120766,T_ECU_OFF_ENVD,415, s
ENG109299,T_ES,16, min
ENG27173,T_ES_ATIC,1717, s
ENG27178,T_ES_ATIC_OLD_ENVD,0, s
ENG114669,T_ES_ATIC_PLAUS_DEV,0, s
ENG120767,T_ES_ATIC_PLAUS_TMR_CHK,60.0, s
ENG112616,T_ES_DC,16, min
ENG99463,T_ES_H,960, s
ENG128802,T_IGK,655.35, s
ENG99398,T_POP_COC_INTER_1,0.0, s
ENG102747,T_PWL,0.0, s
ENG114670,T_PWL_END,0.0, s
ENG112636,T_SWI_VVL_ACR,55.3, ms
ENG101325,T_TEMP_SIG_LOIL,69.9, ms
ENG125440,TAA,18.000, °C
ENG102048,Tank breather valve: duty cycle,0.0, %
ENG101339,Tank breather valve: short trip result,0.0000, kg/h
ENG100439,Tank level,00000000 ,
ENG112610,TCO_1_FIRST_ST,87, °C
ENG112611,TCO_1_ST,87, °C
ENG112612,TCO_1_SYS,108, °C
ENG103434,TCO_A_LAM_AD_WUP{1},0.00, °C
ENG100381,TCO_B_LAM_AD_WUP{1},0.00, °C
ENG101581,TCO_C_LAM_AD_WUP{1},0.00, °C
ENG100354,TCO_D_LAM_AD_WUP{1},0.00, °C
ENG101973,TCO_E_LAM_AD_WUP{1},0.00, °C
ENG128800,TCO_MDL{STUCK_L_COOL_MON},58.883, °C
ENG124460,TCO_MDL{TH},69.734, °C
ENG100390,TCO_MIN_INTER_LAM_AD_WUP{1},108.00, °C
ENG100853,TCO_MIN_LAM_AD_WUP{1},0.00, °C
ENG102279,TCS/ESP: specified torque,24.2500, Nm
ENG99857,TCS: status,00000000 ,
ENG110436,TEG_DYN_LS_DOWN{1},353.9750, °C
ENG101941,TEMP_CAT_STAT_MDL{1},394.1625, °C
ENG112614,TEMP_CAT_UP_1_SAE,363.3, °C
ENG114837,TFPA,99, °C
ENG114838,TFU_HPP,51.75, °C
ENG101411,Throttle valve angle,2.217, °
ENG114677,TI_1_MES_MPI{CYL_0},0.000, ms
ENG114678,TI_1_MES_MPI{CYL_1},0.000, ms
ENG114679,TI_1_MES_MPI{CYL_2},0.000, ms
ENG114680,TI_1_MES_MPI{CYL_3},0.000, ms
ENG114681,TI_MES_4{PLS_1}{CYL_0},0.668, ms
ENG114682,TI_MES_4{PLS_1}{CYL_1},0.684, ms
ENG114683,TI_MES_4{PLS_1}{CYL_2},0.692, ms
ENG114684,TI_MES_4{PLS_1}{CYL_3},0.732, ms
ENG114685,TI_MES_4{PLS_2}{CYL_0},0.000, ms
ENG114686,TI_MES_4{PLS_2}{CYL_1},0.000, ms
ENG114687,TI_MES_4{PLS_2}{CYL_2},0.000, ms
ENG114688,TI_MES_4{PLS_2}{CYL_3},0.000, ms
ENG114689,TI_MES_4{PLS_3}{CYL_0},0.000, ms
ENG114690,TI_MES_4{PLS_3}{CYL_1},0.000, ms
ENG114691,TI_MES_4{PLS_3}{CYL_2},0.000, ms
ENG114692,TI_MES_4{PLS_3}{CYL_3},0.000, ms
ENG128801,TIA_CHA_DOWN_MV,75.896, °C
ENG125276,TIG_MES_SAE{IM},52, °C
ENG103351,Time since engine start,719.2, s
ENG112634,TLTS_MES{TCE},108.328, °C
ENG114693,TLTS_MES_SAE{TCE},108, °C
ENG112635,TMAG_VCP,103, °C
ENG110444,TPS_AD_CDN_MIS,36,
ENG128804,TQI_ADD_ACT,29.21875, Nm
ENG101426,TQI_GS_FAST_INC,0.00, Nm
ENG128805,TQI_N_TCHA_MAX,1023.96875, Nm
ENG115975-ENG116124,Transmission Actual Gear-Transmission Actual Gear Ratio,0.000,
ENG115975-ENG116108,Transmission Actual Gear-Transmission Actual Gear Ratio Supported,Not available,
ENG115975-ENG116105,Transmission Actual Gear-Transmission Actual Gear Status,NEUT,
ENG115975-ENG116116,Transmission Actual Gear-Transmission Actual Gear Status Supported,available.,
ENG102329,TTIP_MES_LS_UP{1},749.5625, °C
ENG114695,V_LS_SENS{1},0.5653, V
ENG114840,V_PVS_KD,0.000, V
ENG114696,VB_SAE,13.261, V
ENG99514,VBOOST,64.5, V
ENG103201,VCV_CLOSE_RNG,18.4, °
ENG115976,Vehicle Odometer,3969.3, km
ENG121352,Vehicle Operation Data - Distance/Fuel Used,|Total Distance Traveled (Recent),Total Distance Traveled (Lifetime)
ENG121353,Vehicle Operation Data - Engine Run/Idle Time,|Ignition Counter (Recent),Ignition Counter (Lifetime)
ENG121354,Vehicle Operation Data - PKE/EOE,|Positive Kinetic Energy (Recent),Positive Kinetic Energy (Lifetime)
ENG121355,Vehicle Operation Data - PSA,|Total Propulsion System Active Time (Recent),Total Propulsion System Active Time (Lifetime)
ENG112639,VLS_DOWN_SAE{1},0.585, V
ENG128806,VOL_FLOW_CHA_UP_RED_MV,0.002350, m³/s
ENG102985,VP_TPS_2,4.3860, V
ENG101674,VP_TPS_AD_LIH_1,0.8667, V
ENG99507,VP_TPS_AD_LIH_2,4.1293, V
ENG114700,VS_MAX_THD,237.00, km/h
ENG114701,VS_SAE,0, km/h
Elapsed Time: 01:15,,,
;SW:5WA-614-517-BL HW:5WA-614-517-N --- ABS Brakes
;Component:ESC H13 0133, Coding:76FC6E9076226E75527B6E0076CC60064A525A50528803C02014B831018FF100002814
;EV_Brake1ESCEPBMQB37W,013056,EV_Brake1ESCEPBMQB37W_013.rod
;Thursday,17,March,2022,11:39:38:62242
;VCDS Version: Release 22.3.0 Data version: 20220225 DS336.1
;VCID: 1373B1057BFABAB3620-8046
Group,Description,Actual,
IDE00019,Voltage terminal 30,13.281, V
IDE00021,Engine RPM,770, /min
IDE00025,Coolant temperature,108.0, °C
IDE00085,Normed load value,10.9804, %
IDE00086,Accelerator pedal position,14.5, %
IDE00097,OBD - requirements for which this vehicle is designed,OBD and OBD II,
IDE00601-ENG30035,Monitoring status since erasing DTC memory-MIL_Status,OFF,
IDE00601-ENG30057,Monitoring status since erasing DTC memory-Number_of_errors_Mode$03,0,
IDE00601-ENG30070,Monitoring status since erasing DTC memory-Readiness_State,00000000 ,
IDE00601-ENG30155,Monitoring status since erasing DTC memory-Supported_Info,00000000 ,
IDE00601-ENG30156,Monitoring status since erasing DTC memory-Supported_Info_Readiness,00000100 ,
IDE00602-ENG29982,Monitoring status in current driving cycle-Diagnostic_approval_and_Readiness_code_continous_diagnostics,00000100 ,
IDE00602-ENG29983,Monitoring status in current driving cycle-Diagnostic_approval_and_Readiness_code_non_continous_diagnostics,00000000 ,
IDE00602-ENG30069,Monitoring status in current driving cycle-Readiness_Code,00000000 ,
IDE02270-IDE02713,CAN input signal(s) status-Brake lamp switch,Not operated,
IDE02270-MAS00314,CAN input signal(s) status-Clutch Pedal Switch,Not operated,
IDE02270-MAS01281,CAN input signal(s) status-Back-up lamp,OFF,
IDE02270-MAS02357,CAN input signal(s) status-Vehicle identification,CD8NW129409,
IDE02270-MAS03992,CAN input signal(s) status-Clutch pedal switch: interlock position,not active,
IDE02271-IDE02070,CAN output signal(s) status-Wake-up cause,Bus communication,
IDE02986-IDE04431,Indicator lamps-ASR and ESP indicator lamp,OFF,
IDE02986-IDE04451,Indicator lamps-Tire press monitoring display indictor lamp,OFF,
IDE02986-IDE04498,Indicator lamps--AUTO HOLD- Indicator Lamp,OFF,
IDE02986-IDE04771,Indicator lamps-Indicator lamp for electro-mechanical parking brake malfunction,OFF,
IDE02986-MAS00253,Indicator lamps-ABS indicator lamp,OFF,
IDE02986-MAS00556,Indicator lamps-Electromechanical parking brake indicator lamp,On,
IDE02986-MAS01206,Indicator lamps-Hill descent control indicator lamp,On,
IDE02986-MAS02925,Indicator lamps-Brake system indicator lamp,OFF,
IDE02986-MAS03234,Indicator lamps-ESP_off indicator lamp,OFF,
IDE03008-IDE05181,Stop process prevented-Emerg.brake,not active,
IDE03008-MAS01299,Stop process prevented-Offroad,not active,
IDE03008-MAS01478,Stop process prevented-insufficient voltage,not active,
IDE03008-MAS04513,Stop process prevented-ABS control module pump running,not active,
IDE03008-MAS04515,Stop process prevented-Roll back detection,not active,
IDE03010-IDE04446,Number of prevented stop processes-Hill descent control,0,
IDE03010-IDE05181,Number of prevented stop processes-Emerg.brake,0,
IDE03010-IDE06139,Number of prevented stop processes-AUTO HOLD slippage recognition,0,
IDE03010-MAS01299,Number of prevented stop processes-Offroad,0,
IDE03010-MAS01478,Number of prevented stop processes-insufficient voltage,0,
IDE03010-MAS04485,Number of prevented stop processes-ESP function deactivation,0,
IDE03010-MAS04513,Number of prevented stop processes-ABS control module pump running,0,
IDE03010-MAS04515,Number of prevented stop processes-Roll back detection,0,
IDE03010-MAS07931,Number of prevented stop processes-Retaining function unavailable,0,
IDE03010-MAS07932,Number of prevented stop processes-Inclination limit,0,
IDE03011-IDE06139,Number of requested start processes-AUTO HOLD slippage recognition,0,
IDE03011-MAS02515,Number of requested start processes-System malfunction,0,
IDE03011-MAS04515,Number of requested start processes-Roll back detection,0,
IDE03310,Brake lamp,OFF,
IDE03310-MAS01167,Brake lamp-Actuation time,0 s,
IDE03310-ENG39349,Brake lamp-IoReached Status,Output diagnostic test not active,
IDE03680-IDE01232,Supply voltages-Supply voltage for external components,5.0, V
IDE03680-IDE04444,Supply voltages-Terminal 30 voltage for pump,13.3, V
IDE03680-IDE04445,Supply voltages-Terminal 30 voltage for valves,13.2, V
IDE03680-IDE04500,Supply voltages-Terminal 30 voltage for logic,13.4, V
IDE03680-MAS01468,Supply voltages-Terminal 15,On,
IDE04082-MAS00580,Instrument cluster text output-Electromechanical parking brake text 1,0,
IDE04082-MAS03359,Instrument cluster text output-Text,0,
IDE04422-IDE04450,Brake system sensor-Brake pressure sensor 1,0.00, bar
IDE04422-MAS00179,Brake system sensor-Brake lamp switch,Not operated,
IDE04422-MAS02152,Brake system sensor-EPB clutch pedal travel,11.0, %
IDE04425-IDE00920,Left front ABS wheel speed sensor-Front left wheel speed,0.00, km/h
IDE04425-IDE04435,Left front ABS wheel speed sensor-Air gap,Malfunction,
IDE04425-MAS01466,Left front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04425-MAS09580,Left front ABS wheel speed sensor-Sensor status,No malfunction,
IDE04426-IDE00921,Right front ABS wheel speed sensor-Wheel speed: right front,0.00, km/h
IDE04426-IDE04435,Right front ABS wheel speed sensor-Air gap,Malfunction,
IDE04426-MAS01466,Right front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04426-MAS09580,Right front ABS wheel speed sensor-Sensor status,No malfunction,
IDE04427-IDE00922,Left rear ABS wheel speed sensor-Left rear wheel speed,0.00, km/h
IDE04427-IDE04435,Left rear ABS wheel speed sensor-Air gap,Malfunction,
IDE04427-MAS01466,Left rear ABS wheel speed sensor-Direction of rotation,forward,
IDE04427-MAS09580,Left rear ABS wheel speed sensor-Sensor status,No malfunction,
IDE04428-IDE00923,Right rear ABS wheel speed sensor-Right rear wheel speed,0.00, km/h
IDE04428-IDE04435,Right rear ABS wheel speed sensor-Air gap,Malfunction,
IDE04428-MAS01466,Right rear ABS wheel speed sensor-Direction of rotation,forward,
IDE04428-MAS09580,Right rear ABS wheel speed sensor-Sensor status,No malfunction,
IDE04443-IDE02241,Slip control system sensor-Lateral acceleration sensor 1,-0.34335, m/s²
IDE04443-IDE02538,Slip control system sensor-Longitude Acceleration Sensor,0.28449, m/s²
IDE04443-IDE04429,Slip control system sensor-Lateral acceleration sensor 1: offset,-0.68670, m/s²
IDE04443-IDE04430,Slip control system sensor-Longitudinal acceleration sensor: offset,0.37500, m/s²
IDE04443-IDE04449,Slip control system sensor-Rotation rate sensor 1: Z-axis,-0.026, °/s
IDE04443-IDE04460,Slip control system sensor-Steering angle sensor: offset straight line running,-422.537, °
IDE04443-MAS00815,Slip control system sensor-Steering angle sensor,-421.356, °
IDE04446-IDE14988,Hill descent control-Incline,3, %
IDE04446-MAS01299,Hill descent control-Offroad,Off-road deactivated,
IDE04446-MAS03095,Hill descent control-Function status,not active,
IDE04446-MAS05585,Hill descent control-Standby,not active,
IDE04446-MAS12601,Hill descent control-HDC intervention,not active,
IDE04452-IDE03662,Brake system button-ASR/ESP button,Not operated,
IDE04452-IDE03663,Brake system button--AUTO HOLD- Button,Not available due to specific system,
IDE04452-IDE03664,Brake system button-Button for driving program,Not operated,
IDE04452-IDE04432,Brake system button-Tire Pressure Monitoring Display Button,Not operated,
IDE04452-IDE04769,Brake system button-Electro-mechanical parking brake button: status,Not operated,
IDE04456-IDE04775,Brake disk drying-Odometer reading of last activation,3669, km
IDE04461-MAS01481,Internal measured values-Temperature in control module,53.3, °C
IDE04461-MAS10973,Internal measured values-Hardware reset,7,
IDE04461-MAS10974,Internal measured values-Software reset,197,
IDE04461-MAS15830,Internal measured values-Data block description,Block 2,
IDE04461-MAS17870,Internal measured values-Number of resets,0,
IDE04461-ENG02359,Internal measured values-C1 Idle Task,42, %
IDE04461-ENG02365,Internal measured values-Ct mainloop,51, %
IDE04461-ENG02366,Internal measured values-Ct prc task,63, %
IDE04461-ENG02367,Internal measured values-Ct valve task,63, %
IDE04461-ENG126445,Internal measured values-Idle Task,29, %
IDE04461-ENG02405,Internal measured values-Idp Task,33, %
IDE04461-ENG02407,Internal measured values-Ipb main task,22, %
IDE04461-ENG02408,Internal measured values-Ipb safety task,42, %
IDE04461-ENG02519,Internal measured values-Task BAP 10ms,44, %
IDE04461-ENG02520,Internal measured values-Task C0 Com task 5ms AsilD,0, %
IDE04461-ENG02521,Internal measured values-Task C1 10ms AsilB,39, %
IDE04461-ENG02522,Internal measured values-Task C1 1ms AsilB,36, %
IDE04461-ENG02523,Internal measured values-Task Com task1 5ms AsilD,41, %
IDE04461-ENG02524,Internal measured values-Task Com task1 5ms Qm,47, %
IDE04461-ENG02525,Internal measured values-Task Com task2 5ms Qm,68, %
IDE04461-ENG02526,Internal measured values-Task mFDR 5ms_AsilD,59, %
IDE04461-ENG02527,Internal measured values-Task mFDR 5ms_Qm,64, %
IDE04461-ENG02528,Internal measured values-Task TPI 20ms,50, %
IDE04508-IDE02955,Hydraulic brake booster-System status,available.,
IDE04508-MAS03095,Hydraulic brake booster-Function status,not active,
IDE04644-IDE02955,Roll-over protection-System status,available.,
IDE04644-IDE04775,Roll-over protection-Odometer reading of last activation,0, km
IDE04645-IDE00003,Electromechanical parking brake-Coding,will be performed.,
IDE04645-IDE00902,Electromechanical parking brake-Automatic distance control: status,not activated,
IDE04645-IDE02652,Electromechanical parking brake-Start-stop status,not activated,
IDE04645-IDE02955,Electromechanical parking brake-System status,available.,
IDE04645-IDE04871,Electromechanical parking brake-Dynamic starting assist,activated,
IDE04645-IDE05711,Electromechanical parking brake-Automatic application during engine stalling,activated,
IDE04645-MAS03998,Electromechanical parking brake-Delay interface for electro-mechanical parking brake,0, m/s²
IDE04765-IDE02955,Counter steer support-System status,Not available due to specific system,
IDE04765-IDE04775,Counter steer support-Odometer reading of last activation,0, km
IDE04772,Indicator light in the button for electromech. parking brake,On,
IDE04772-MAS01167,Indicator light in the button for electromech. parking brake-Actuation time,Without time limit,
IDE04772-ENG39349,Indicator light in the button for electromech. parking brake-IoReached Status,Output diagnostic test not active,
IDE04774-IDE02955,Vehicle and trailer stabilization-System status,Not available due to specific system,
IDE04774-IDE04775,Vehicle and trailer stabilization-Odometer reading of last activation,0, km
IDE04939-IDE02763,Tire Pressure Monitoring System (TPMS)-System malfunction lamp: status,OFF,
IDE04939-IDE02765,Tire Pressure Monitoring System (TPMS)-Pressure warning lamp: status,OFF,
IDE04939-IDE04432,Tire Pressure Monitoring System (TPMS)-Tire Pressure Monitoring Display Button,Not operated,
IDE04939-IDE04946,Tire Pressure Monitoring System (TPMS)-Odometer reading at last adaptation,11, km
IDE04939-IDE04947,Tire Pressure Monitoring System (TPMS)-Odometer reading of last warning,0, km
IDE04939-IDE09286,Tire Pressure Monitoring System (TPMS)-Software version of tire monitoring display,R1906A26,
IDE04939-IDE09287,Tire Pressure Monitoring System (TPMS)-Param. set version tire press monitoring display,0,
IDE04939-IDE09288,Tire Pressure Monitoring System (TPMS)-Param. set tire press monitor display: checksum,35,
IDE04939-IDE09289,Tire Pressure Monitoring System (TPMS)-Tire press monitor.display: diagnosis status,00 00 00 20 00 30 00 00 A8 22,
IDE04939-IDE11039,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for fast press. loss: le. frt,252,
IDE04939-IDE11040,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for fast pres.loss: ri. frt.,252,
IDE04939-IDE11041,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.:counter for fast press. loss: le. rr.,252,
IDE04939-IDE11042,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for fast press. loss: ri. rr.,252,
IDE04939-IDE11043,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for slow press. loss: le. frt,187,
IDE04939-IDE11044,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for slow press. loss: ri. frt.,187,
IDE04939-IDE11045,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for slow press. loss: le. rr.,187,
IDE04939-IDE11046,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for slow press. loss: ri. rr.,187,
IDE04939-MAS00106,Tire Pressure Monitoring System (TPMS)-Year,2021,
IDE04939-MAS00106,Tire Pressure Monitoring System (TPMS)-Year,2000,
IDE04939-MAS00106,Tire Pressure Monitoring System (TPMS)-Year,2022,
IDE04939-MAS00107,Tire Pressure Monitoring System (TPMS)-Month,0,
IDE04939-MAS00107,Tire Pressure Monitoring System (TPMS)-Month,11,
IDE04939-MAS00107,Tire Pressure Monitoring System (TPMS)-Month,2,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,12,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,19,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,11,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,0,
IDE04939-MAS00109,Tire Pressure Monitoring System (TPMS)-Hours,0,
IDE04939-MAS00109,Tire Pressure Monitoring System (TPMS)-Hours,5,
IDE04939-MAS00109,Tire Pressure Monitoring System (TPMS)-Hours,20,
IDE04939-MAS00109,Tire Pressure Monitoring System (TPMS)-Hours,23,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,37,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,36,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,0,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,54,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,55,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,41,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,0,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,24,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,21,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,14,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,19,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,9,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,6,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,54,
IDE04939-MAS04538,Tire Pressure Monitoring System (TPMS)-Odometer reading two adaptations ago,0, km
IDE04939-MAS04539,Tire Pressure Monitoring System (TPMS)-Odometer reading three adaptations ago,0, km
IDE04939-MAS04540,Tire Pressure Monitoring System (TPMS)-Odometer reading four adaptations ago,0, km
IDE04939-MAS04541,Tire Pressure Monitoring System (TPMS)-Odometer reading of next-to-last warning,0, km
IDE04939-MAS04542,Tire Pressure Monitoring System (TPMS)-Odometer reading of third-to-last warning,0, km
IDE04939-MAS04543,Tire Pressure Monitoring System (TPMS)-Odometer reading of fourth-to-last warning,0, km
IDE04939-MAS14292,Tire Pressure Monitoring System (TPMS)-Analysis data of latest programming,00 00 00 00 00 00 00 00 00 10,
IDE04939-MAS14293,Tire Pressure Monitoring System (TPMS)-Analysis data of the second latest programming,00 00 00 00 00 00 00 00 00 10,
IDE04939-MAS14294,Tire Pressure Monitoring System (TPMS)-Analysis data of the third latest programming,00 00 00 00 00 00 00 00 00 00,
IDE04939-MAS14295,Tire Pressure Monitoring System (TPMS)-Analysis data of the fourth latest programming,00 00 00 00 00 00 00 00 00 00,
IDE04939-MAS14296,Tire Pressure Monitoring System (TPMS)-Analysis data of the latest warning,02 25 00 00 00 00 98 99 A9 22,
IDE04939-MAS14297,Tire Pressure Monitoring System (TPMS)-Analysis data of the second latest warning,02 25 00 00 00 00 00 00 00 10,
IDE04939-MAS14298,Tire Pressure Monitoring System (TPMS)-Analysis data of the third latest warning,02 25 00 00 00 00 98 99 A9 22,
IDE04939-MAS14299,Tire Pressure Monitoring System (TPMS)-Analysis data of the fourth latest warning,02 25 00 00 00 00 00 00 00 10,
IDE04939-MAS18039,Tire Pressure Monitoring System (TPMS)-Odometer reading at fifth most recent configuration,0, km
IDE04939-MAS18041,Tire Pressure Monitoring System (TPMS)-Analysis data from fifth most recent configuration,00 00 00 00 00 00 00 00 00 00,
IDE04939-MAS18042,Tire Pressure Monitoring System (TPMS)-Temperature at time of most recent warning,20, °C
IDE04939-MAS18066,Tire Pressure Monitoring System (TPMS)-Temperature at time of second to last warning,21, °C
IDE04939-MAS18067,Tire Pressure Monitoring System (TPMS)-Temperature at time of third most recent warning,20, °C
IDE04939-MAS18069,Tire Pressure Monitoring System (TPMS)-Temperature at time of fourth most recent warning,20, °C
IDE04939-MAS18070,Tire Pressure Monitoring System (TPMS)-Odometer reading of fifth most recent warning,0, km
IDE04939-MAS18072,Tire Pressure Monitoring System (TPMS)-Temperature at time of fifth most recent warning,20, °C
IDE04939-MAS18073,Tire Pressure Monitoring System (TPMS)-Analysis data of fifth most recent warning,02 25 00 00 00 00 98 99 A9 22,
IDE04939-MAS18074,Tire Pressure Monitoring System (TPMS)-Tire control display parameter set info,195,
IDE04939-MAS18076,Tire Pressure Monitoring System (TPMS)-Mean temperature calibration during most recent warning,20, °C
IDE04939-MAS18077,Tire Pressure Monitoring System (TPMS)-Mean temperature calibration during second most recent warning,21, °C
IDE04939-MAS18078,Tire Pressure Monitoring System (TPMS)-Mean temperature calibration during third most recent warning,20, °C
IDE04939-MAS18079,Tire Pressure Monitoring System (TPMS)-Mean temperature calibration during fourth most recent warning,20, °C
IDE04939-MAS18080,Tire Pressure Monitoring System (TPMS)-Mean temperature calibration during fifth most recent warning,20, °C
IDE04939-ENG04485,Tire Pressure Monitoring System (TPMS)-RKA_Config_Info,0 ,
IDE05053,Right parking brake motor: close gradually,Open,
IDE05053-MAS01167,Right parking brake motor: close gradually-Actuation time,Without time limit,
IDE05053-ENG39349,Right parking brake motor: close gradually-IoReached Status,Output diagnostic test not active,
IDE05054,Left parking brake motor: close gradually,Open,
IDE05054-MAS01167,Left parking brake motor: close gradually-Actuation time,Without time limit,
IDE05054-ENG39349,Left parking brake motor: close gradually-IoReached Status,Output diagnostic test not active,
IDE05333,Indicator light in AUTO HOLD button,OFF,
IDE05333-MAS01167,Indicator light in AUTO HOLD button-Actuation time,Without time limit,
IDE05333-ENG39349,Indicator light in AUTO HOLD button-IoReached Status,Output diagnostic test not active,
IDE06307,Stop prevention history data,Write only channel,
IDE06308,Start request history data,Write only channel,
IDE06422-ENG103176,IUMPR_1-General Denominator,42,
IDE06422-ENG102823,IUMPR_1-Ignition Cycle Counter,155,
IDE06422-ENG100120,IUMPR_1-Milage,3880,
IDE06422-ENG101622,IUMPR_1-Record Number,41,
IDE06423-ENG101817,IUMPR_2-Denominator,42,
IDE06423-ENG103772,IUMPR_2-DFCC Value,00 8B,
IDE06423-ENG99150,IUMPR_2-Numerator,111,
IDE06423-ENG101622,IUMPR_2-Record Number,1,
IDE06424-ENG101817,IUMPR_3-Denominator,42,
IDE06424-ENG103772,IUMPR_3-DFCC Value,10 BD,
IDE06424-ENG99150,IUMPR_3-Numerator,111,
IDE06424-ENG101622,IUMPR_3-Record Number,2,
IDE07183,Parking brake motors: close incrementally,Open,
IDE07183-MAS01167,Parking brake motors: close incrementally-Actuation time,Without time limit,
IDE07183-ENG39349,Parking brake motors: close incrementally-IoReached Status,Output diagnostic test not active,
IDE13239-IDE04947,Wheel loose detection-Odometer reading of last warning,0, km
IDE13239-MAS00106,Wheel loose detection-Year,2000,
IDE13239-MAS00107,Wheel loose detection-Month,0,
IDE13239-MAS00108,Wheel loose detection-Day,0,
IDE13239-MAS00109,Wheel loose detection-Hours,0,
IDE13239-MAS00110,Wheel loose detection-Minutes,0,
IDE13239-MAS00111,Wheel loose detection-Seconds,0,
IDE13239-MAS04541,Wheel loose detection-Odometer reading of next-to-last warning,0, km
IDE13239-MAS04542,Wheel loose detection-Odometer reading of third-to-last warning,0, km
IDE13239-MAS16487,Wheel loose detection-Wheels affected by the latest warning,no warning,
IDE13239-MAS16489,Wheel loose detection-Wheels affected by the penultimate warning,no warning,
IDE13239-MAS16491,Wheel loose detection-Wheels affected by the third last warning,no warning,
IDE14227-IDE02955,modular vehicle dynamic controller-System status,available.,
IDE14227-MAS18085,modular vehicle dynamic controller-Electronic Stability Program function status,mFDR_not_active_by_failure,
IDE14227-MAS18086,modular vehicle dynamic controller-Dynamic Chassis Control function status,mFDR_not_active_by_failure,
IDE14227-MAS18087,modular vehicle dynamic controller-Haldex function status,mFDR_active_haldex_not_configured,
IDE14227-MAS18088,modular vehicle dynamic controller-Min Haldex target locking rate,0.0, %
IDE14227-MAS18089,modular vehicle dynamic controller-Max Haldex target locking rate,50.0, %
IDE14227-ENG02417,modular vehicle dynamic controller-mFDR Sollfaktor DCC HL,100, %
IDE14227-ENG02418,modular vehicle dynamic controller-mFDR Sollfaktor DCC HR,100, %
IDE14227-ENG02419,modular vehicle dynamic controller-mFDR Sollfaktor DCC VL,100, %
IDE14227-ENG02420,modular vehicle dynamic controller-mFDR Sollfaktor DCC VR,100, %
IDE14479-IDE02657,Parking brake system status-Cut-off current: left: reached,0.00, A
IDE14479-IDE02658,Parking brake system status-Cut-off current: right: reached,0.00, A
IDE14479-IDE04496,Parking brake system status-Left parking brake motor: status,closed,
IDE14479-IDE04497,Parking brake system status-Right parking brake motor: status,closed,
IDE14479-IDE04506,Parking brake system status-Calculated left rear brake temperature,25.0, °C
IDE14479-IDE04507,Parking brake system status-Calculated right rear brake temperature,25.0, °C
IDE14479-IDE04647,Parking brake system status-Left parking brake motor: current,0.00, A
IDE14479-IDE04648,Parking brake system status-Right parking brake motor: current,0.00, A
IDE14479-IDE05048,Parking brake system status-Left parking brake motor: actuation counter,167,
IDE14479-IDE05049,Parking brake system status-Right parking brake motor: actuation counter,167,
IDE14623,Commutation test status,not active,
MAS00121-IDE04504,Electronic Differential Lock-Calculated left front brake temperature,18.0, °C
MAS00121-IDE04505,Electronic Differential Lock-Calculated right front brake temperature,18.0, °C
MAS00121-IDE04506,Electronic Differential Lock-Calculated left rear brake temperature,18.0, °C
MAS00121-IDE04507,Electronic Differential Lock-Calculated right rear brake temperature,18.0, °C
MAS00121-MAS01853,Electronic Differential Lock-Left front,available.,
MAS00121-MAS01854,Electronic Differential Lock-Right front,available.,
MAS00121-MAS01855,Electronic Differential Lock-Left rear,available.,
MAS00121-MAS01856,Electronic Differential Lock-Right rear,available.,
MAS00464-MAS00106,Standard - ambient data 1-Year,2022,
MAS00464-MAS00107,Standard - ambient data 1-Month,3,
MAS00464-MAS00108,Standard - ambient data 1-Day,17,
MAS00464-MAS00109,Standard - ambient data 1-Hours,11,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,39,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,46,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,3969, km
MAS00911-IDE02955,All Wheel Drive (AWD)-System status,available.,
MAS00911-IDE04502,All Wheel Drive (AWD)-Haldex clutch: status,No malfunction detected,
MAS00911-IDE04943,All Wheel Drive (AWD)-Haldex clutch,Fully open,
MAS00911-MAS04730,All Wheel Drive (AWD)-Degree of blockage,0.0, Nm
MAS02138-IDE02955,Hill-start assistant-System status,available.,
MAS02138-MAS00025,Hill-start assistant-Driver seat belt switch,not connected,
MAS02138-MAS00218,Hill-start assistant-Driver door,closed,
MAS02138-MAS03095,Hill-start assistant-Function status,not active,
MAS02286-MAS01167,Hydraulic pump-Actuation time,0 s,
MAS02286-MAS06857,Hydraulic pump-Speed,0, /min
MAS02286-ENG39349,Hydraulic pump-IoReached Status,Output diagnostic test not active,
MAS02426-MAS01167,Text display in instrument cluster-Actuation time,Without time limit,
MAS02426,Text display in instrument cluster,0,
MAS02426-ENG39349,Text display in instrument cluster-IoReached Status,Output diagnostic test not active,
MAS04012-IDE03297,Intake valves-Left front ABS inlet valve,OFF,
MAS04012-IDE03299,Intake valves-Right front ABS inlet valve,OFF,
MAS04012-IDE03301,Intake valves-left rear ABS intake valve,OFF,
MAS04012-IDE03303,Intake valves-right rear ABS intake valve,OFF,
MAS04012-MAS01167,Intake valves-Actuation time,0 s,
MAS04012-ENG39349,Intake valves-IoReached Status,Output diagnostic test not active,
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
ENG101413,Calibration Identification,5WA517BL01330070,
ENG99697,Calibration Verification Number,55 35 5C F4,
ENG100152,ECUNAME,BSCM-BrakeSystem,
ENG02301,Entwicklermesswert_08,|VZM_function_request,VZM_Participant
ENG02303-ENG04671,Entwicklermesswert_11-Left_Brake_Full_Clamping_Force,167,
ENG02303-ENG04669,Entwicklermesswert_11-Right_Brake_Full_Clamping_Force,167,
ENG02304,Entwicklermesswert_12,40081D,
ENG02305-ENG04693,Entwicklermesswert_13-Input_Signal_A_Belt_Error,No malfunction,
ENG02305-ENG04692,Entwicklermesswert_13-Input_Signal_A_Belt_Status,not selected,
ENG02305-ENG04695,Entwicklermesswert_13-Input_Signal_B_Door_Error,No malfunction,
ENG02305-ENG04694,Entwicklermesswert_13-Input_Signal_B_Door_Status,closed,
ENG02306-MAS01167,Entwicklerstellglied_01_status-Actuation time,0 s,
ENG02306-MAS11641,Entwicklerstellglied_01_status-OBD lamp,OFF,
ENG02306-ENG39349,Entwicklerstellglied_01_status-IoReached Status,Output diagnostic test not active,
Elapsed Time: 00:15,,,
;SW:5WA-959-436-J HW:5WA-959-436-J --- Acc/Start Auth.
;Component:Kessy IOBOX 100 0723, Coding:
;EV_Kessy37w,004023,EV_Kessy37w_004.rod
;Thursday,17,March,2022,11:40:10:62242
;VCID: 5BE39925D3AAB2F3FA0-800E
IDE00019,Voltage terminal 30,13.361, V
IDE02413,Door handle touch sensor: last operation,Driver door,
IDE02414-MAS00080,Driver exterior door handle touch sensor-Coding information,coded,
IDE02414-MAS02176,Driver exterior door handle touch sensor-Approach to the inside,not active,
IDE02414-MAS02177,Driver exterior door handle touch sensor-Actuation to the inside,not active,
IDE02414-MAS02178,Driver exterior door handle touch sensor-Approach to the outside,not active,
IDE02414-MAS02179,Driver exterior door handle touch sensor-Actuation to the outside,not active,
IDE02414-MAS02451,Driver exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02415-MAS00080,Front passenger exterior door handle touch sensor-Coding information,coded,
IDE02415-MAS02176,Front passenger exterior door handle touch sensor-Approach to the inside,not active,
IDE02415-MAS02177,Front passenger exterior door handle touch sensor-Actuation to the inside,not active,
IDE02415-MAS02178,Front passenger exterior door handle touch sensor-Approach to the outside,not active,
IDE02415-MAS02179,Front passenger exterior door handle touch sensor-Actuation to the outside,not active,
IDE02415-MAS02451,Front passenger exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02416-MAS00080,Left rear outside door handle touch sensor-Coding information,Not coded,
IDE02416-MAS02176,Left rear outside door handle touch sensor-Approach to the inside,not active,
IDE02416-MAS02177,Left rear outside door handle touch sensor-Actuation to the inside,not active,
IDE02416-MAS02178,Left rear outside door handle touch sensor-Approach to the outside,not active,
IDE02416-MAS02179,Left rear outside door handle touch sensor-Actuation to the outside,not active,
IDE02416-MAS02451,Left rear outside door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02417-MAS00080,Right rear outside door handle touch sensor-Coding information,Not coded,
IDE02417-MAS02176,Right rear outside door handle touch sensor-Approach to the inside,not active,
IDE02417-MAS02177,Right rear outside door handle touch sensor-Actuation to the inside,not active,
IDE02417-MAS02178,Right rear outside door handle touch sensor-Approach to the outside,not active,
IDE02417-MAS02179,Right rear outside door handle touch sensor-Actuation to the outside,not active,
IDE02417-MAS02451,Right rear outside door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02418,Proximity sensor driver door: number of triggers,507,
IDE02419,Proximity sensor frt.pass. door: number of triggers,237,
IDE02420,Proximity sensor left rear door: number of triggers,0,
IDE02421,Proximity sensor right rear door: number of triggers,0,
IDE02422-MAS01482,Driver door handle: version information-Hardware version,32,
IDE02422-MAS01483,Driver door handle: version information-Software version,43,
IDE02422-MAS04065,Driver door handle: version information-EEPROM,34,
IDE02422,Driver door handle: version information,CA 00 08 97 74,
IDE02423-MAS01482,ass. door handle: version information-Hardware version,32,
IDE02423-MAS01483,ass. door handle: version information-Software version,43,
IDE02423-MAS04065,ass. door handle: version information-EEPROM,34,
IDE02423,ass. door handle: version information,DB 00 08 5F 3A,
IDE02424-MAS01482,Left rear door handle: version information-Hardware version,0,
IDE02424-MAS01483,Left rear door handle: version information-Software version,0,
IDE02424-MAS04065,Left rear door handle: version information-EEPROM,0,
IDE02424,Left rear door handle: version information,00 00 00 00 00,
IDE02425-MAS01482,Right rear door handle: version information-Hardware version,0,
IDE02425-MAS01483,Right rear door handle: version information-Software version,0,
IDE02425-MAS04065,Right rear door handle: version information-EEPROM,0,
IDE02425,Right rear door handle: version information,00 00 00 00 00,
IDE02466,Play protection activation counter driver door,0,
IDE02466,Play protection activation counter driver door,not active,
IDE02467,Play protection activation counter frt.pass. door,not active,
IDE02467,Play protection activation counter frt.pass. door,0,
IDE02468,Play protection activation counter left rear door,not active,
IDE02468,Play protection activation counter left rear door,0,
IDE02469,Play protection activation counter right rear door,0,
IDE02469,Play protection activation counter right rear door,not active,
IDE02482,72h-Signaling counter driver door,0,
IDE02483,72-hour signaling counter frt.pass. door,0,
IDE02486,Data logger triggering,not initialized,
IDE04347-IDE00020,Expanded freeze frame conditions-Terminal 15 status,On,
IDE04347-MAS04121,Expanded freeze frame conditions-Voltage,13.3, V
IDE07359,Dimming of starter button lighting,9771,
IDE14837-MAS19401,Outer door handle switch: status-Driver Side Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19402,Outer door handle switch: status-Front Passenger Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19403,Outer door handle switch: status-Rear Passenger Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19404,Outer door handle switch: status-Rear Driver Side Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19612,Outer door handle switch: status-Rear Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19613,Outer door handle switch: status-Tank Exterior Door Handle Switch: status,Not operated,
IDE14924-MAS00218,Status of release conditions Passive Entry-Driver door,not enabled,
IDE14924-MAS00219,Status of release conditions Passive Entry-Front Passenger Door,not enabled,
IDE14924-MAS00220,Status of release conditions Passive Entry-Left rear door,not enabled,
IDE14924-MAS00221,Status of release conditions Passive Entry-Right rear door,not enabled,
IDE14924-MAS19581,Status of release conditions Passive Entry-Rear,not enabled,
IDE14924-MAS19611,Status of release conditions Passive Entry-Tank,not enabled,
IDE14925-MAS00218,Status of release conditions Passive Exit-Driver door,Enabled,
IDE14925-MAS00219,Status of release conditions Passive Exit-Front Passenger Door,Enabled,
IDE14925-MAS00220,Status of release conditions Passive Exit-Left rear door,not enabled,
IDE14925-MAS00221,Status of release conditions Passive Exit-Right rear door,not enabled,
IDE14925-MAS19581,Status of release conditions Passive Exit-Rear,not enabled,
IDE14925-MAS19611,Status of release conditions Passive Exit-Tank,not enabled,
IDE14926,Status of release conditions for key search,Key search: release activated,
IDE14927-MAS19605,History of range limiter for automatic functions-Reduction level,|Level_of_reduction,Year
IDE14928-MAS00080,Sensor for control section-Coding information,Not coded,
IDE14928-MAS02176,Sensor for control section-Approach to the inside,not active,
IDE14928-MAS02177,Sensor for control section-Actuation to the inside,not active,
IDE14928-MAS02178,Sensor for control section-Approach to the outside,not active,
IDE14928-MAS02179,Sensor for control section-Actuation to the outside,not active,
IDE14928-MAS02451,Sensor for control section-Pulling actuation: outside door handle,not active,
IDE14929-MAS00080,Sensor for fuel filler flap control section-Coding information,Not coded,
IDE14929-MAS02176,Sensor for fuel filler flap control section-Approach to the inside,not active,
IDE14929-MAS02177,Sensor for fuel filler flap control section-Actuation to the inside,not active,
IDE14929-MAS02178,Sensor for fuel filler flap control section-Approach to the outside,not active,
IDE14929-MAS02179,Sensor for fuel filler flap control section-Actuation to the outside,not active,
IDE14929-MAS02451,Sensor for fuel filler flap control section-Pulling actuation: outside door handle,not active,
IDE14930,Sensor fuel filler flap control section: number of triggers,0,
IDE14931,Sensor control section trunk: number of triggers,0,
IDE14932,Fuel filler flap control section: play protection,0,
IDE14932,Fuel filler flap control section: play protection,not active,
IDE14933,Trunk control section: play protection counter,not active,
IDE14933,Trunk control section: play protection counter,0,
IDE14934-MAS01482,Trunk control section: version information-Hardware version,0,
IDE14934-MAS01483,Trunk control section: version information-Software version,0,
IDE14934-MAS04065,Trunk control section: version information-EEPROM,0,
IDE14934,Trunk control section: version information,00 00 00 00 00,
IDE14935-MAS01482,Fuel filler cap control section: version information-Hardware version,0,
IDE14935-MAS01483,Fuel filler cap control section: version information-Software version,0,
IDE14935-MAS04065,Fuel filler cap control section: version information-EEPROM,0,
IDE14935,Fuel filler cap control section: version information,00 00 00 00 00,
ENG129040-ENG129151,History_of_last _reset_reason-Last_1_reset_reason,Power_On_Reset,
ENG129040-ENG129152,History_of_last _reset_reason-Last_2_reset_reason,Power_On_Reset,
ENG129040-ENG129153,History_of_last _reset_reason-Last_3_reset_reason,Power_On_Reset,
ENG129040-ENG129154,History_of_last _reset_reason-Last_4_reset_reason,Power_On_Reset,
ENG129040-ENG129155,History_of_last _reset_reason-Last_5_reset_reason,Power_On_Reset,
ENG129040-ENG129156,History_of_last _reset_reason-Last_6_reset_reason,Power_On_Reset,
ENG129040-ENG129157,History_of_last _reset_reason-Last_7_reset_reason,Default,
ENG129040-ENG129158,History_of_last _reset_reason-Last_8_reset_reason,Default,
ENG129040-ENG129159,History_of_last _reset_reason-Last_9_reset_reason,Default,
ENG129040-ENG124545,History_of_last _reset_reason-Last_reset_reason,Software_Request_Flashbootloader,
ENG123685-MAS00106,Lf_antenna_eight_detune_counter-Year,2000,
ENG123685-MAS00107,Lf_antenna_eight_detune_counter-Month,0,
ENG123685-MAS00108,Lf_antenna_eight_detune_counter-Day,0,
ENG123685-MAS00109,Lf_antenna_eight_detune_counter-Hours,0,
ENG123685-MAS00110,Lf_antenna_eight_detune_counter-Minutes,0,
ENG123685-MAS00111,Lf_antenna_eight_detune_counter-Seconds,0,
ENG123685-ENG124543,Lf_antenna_eight_detune_counter-Detune_counter,0,
ENG123686-MAS00106,Lf_antenna_five_detune_counter-Year,2000,
ENG123686-MAS00107,Lf_antenna_five_detune_counter-Month,0,
ENG123686-MAS00108,Lf_antenna_five_detune_counter-Day,0,
ENG123686-MAS00109,Lf_antenna_five_detune_counter-Hours,0,
ENG123686-MAS00110,Lf_antenna_five_detune_counter-Minutes,0,
ENG123686-MAS00111,Lf_antenna_five_detune_counter-Seconds,0,
ENG123686-ENG124543,Lf_antenna_five_detune_counter-Detune_counter,0,
ENG123687-MAS00106,Lf_antenna_four_detune_counter-Year,2000,
ENG123687-MAS00107,Lf_antenna_four_detune_counter-Month,0,
ENG123687-MAS00108,Lf_antenna_four_detune_counter-Day,0,
ENG123687-MAS00109,Lf_antenna_four_detune_counter-Hours,0,
ENG123687-MAS00110,Lf_antenna_four_detune_counter-Minutes,0,
ENG123687-MAS00111,Lf_antenna_four_detune_counter-Seconds,0,
ENG123687-ENG124543,Lf_antenna_four_detune_counter-Detune_counter,0,
ENG123688-MAS00106,Lf_antenna_one_detune_counter-Year,2000,
ENG123688-MAS00107,Lf_antenna_one_detune_counter-Month,0,
ENG123688-MAS00108,Lf_antenna_one_detune_counter-Day,0,
ENG123688-MAS00109,Lf_antenna_one_detune_counter-Hours,0,
ENG123688-MAS00110,Lf_antenna_one_detune_counter-Minutes,0,
ENG123688-MAS00111,Lf_antenna_one_detune_counter-Seconds,0,
ENG123688-ENG124543,Lf_antenna_one_detune_counter-Detune_counter,0,
ENG123689-MAS00106,Lf_antenna_seven_detune_counter-Year,2000,
ENG123689-MAS00107,Lf_antenna_seven_detune_counter-Month,0,
ENG123689-MAS00108,Lf_antenna_seven_detune_counter-Day,0,
ENG123689-MAS00109,Lf_antenna_seven_detune_counter-Hours,0,
ENG123689-MAS00110,Lf_antenna_seven_detune_counter-Minutes,0,
ENG123689-MAS00111,Lf_antenna_seven_detune_counter-Seconds,0,
ENG123689-ENG124543,Lf_antenna_seven_detune_counter-Detune_counter,0,
ENG123690-MAS00106,Lf_antenna_six_detune_counter-Year,2000,
ENG123690-MAS00107,Lf_antenna_six_detune_counter-Month,0,
ENG123690-MAS00108,Lf_antenna_six_detune_counter-Day,0,
ENG123690-MAS00109,Lf_antenna_six_detune_counter-Hours,0,
ENG123690-MAS00110,Lf_antenna_six_detune_counter-Minutes,0,
ENG123690-MAS00111,Lf_antenna_six_detune_counter-Seconds,0,
ENG123690-ENG124543,Lf_antenna_six_detune_counter-Detune_counter,0,
ENG123691-MAS00106,Lf_antenna_three_detune_counter-Year,2000,
ENG123691-MAS00107,Lf_antenna_three_detune_counter-Month,0,
ENG123691-MAS00108,Lf_antenna_three_detune_counter-Day,0,
ENG123691-MAS00109,Lf_antenna_three_detune_counter-Hours,0,
ENG123691-MAS00110,Lf_antenna_three_detune_counter-Minutes,0,
ENG123691-MAS00111,Lf_antenna_three_detune_counter-Seconds,0,
ENG123691-ENG124543,Lf_antenna_three_detune_counter-Detune_counter,0,
ENG123692-MAS00106,Lf_antenna_two_detune_counter-Year,2000,
ENG123692-MAS00107,Lf_antenna_two_detune_counter-Month,0,
ENG123692-MAS00108,Lf_antenna_two_detune_counter-Day,0,
ENG123692-MAS00109,Lf_antenna_two_detune_counter-Hours,0,
ENG123692-MAS00110,Lf_antenna_two_detune_counter-Minutes,0,
ENG123692-MAS00111,Lf_antenna_two_detune_counter-Seconds,0,
ENG123692-ENG124543,Lf_antenna_two_detune_counter-Detune_counter,0,
ENG123717-MAS00106,Over_temperature_counter_lf_driver-Year,2000,
ENG123717-MAS00107,Over_temperature_counter_lf_driver-Month,0,
ENG123717-MAS00108,Over_temperature_counter_lf_driver-Day,0,
ENG123717-MAS00109,Over_temperature_counter_lf_driver-Hours,0,
ENG123717-MAS00110,Over_temperature_counter_lf_driver-Minutes,0,
ENG123717-MAS00111,Over_temperature_counter_lf_driver-Seconds,0,
ENG123717-ENG125044,Over_temperature_counter_lf_driver-Over_temperature_counter,0, counts
ENG108452,Reset_counter,7,
ENG108926-ENG103300,Service_Key_Data_Previous_Page-Service_Data,58 9A 03 24 48 C0 16 03 11 0B 1E 22 81 0F 00 00 4C 30 4E 11 B0 30 BB 12 08 DF 9F A4 22 A2 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 4E FF FF 00 00 40 17,
ENG119884-ENG119837,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_0,0, d
ENG119884-ENG119867,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_1,0, d
ENG119884-ENG119868,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_2,0, d
ENG119884-ENG119866,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_3,0, d
ENG119884-ENG119870,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_0,0,
ENG119884-ENG119836,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_1,0,
ENG119884-ENG119850,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_2,0,
ENG119884-ENG119851,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_3,0,
ENG119884-ENG119869,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_0,2000,
ENG119884-ENG119835,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_1,2000,
ENG119884-ENG119845,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_2,2000,
ENG119884-ENG119846,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_3,2000,
ENG119884-ENG119834,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_0,0, km
ENG119884-ENG119839,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_1,0, km
ENG119884-ENG119840,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_2,0, km
ENG119884-ENG119841,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_3,24831, km
ENG108929-ENG99961,Service_Key_Pointer-Current_Bank,Bank_1,
ENG108929-ENG30183,Service_Key_Pointer-Write_Pointer_Adr_160,Write_Pointer_Adr,
ENG108929-ENG30184,Service_Key_Pointer-Write_Pointer_Adr_184,Write_Pointer_Adr,
ENG108929-ENG30185,Service_Key_Pointer-Write_Pointer_Adr_208,Write_Pointer_Adr,
ENG123783-MAS19582,WUP_measurement_historie-Learned wake pattern,0,
ENG123783-MAS19582,WUP_measurement_historie-Learned wake pattern,3210044952,
ENG123783-MAS19582,WUP_measurement_historie-Learned wake pattern,2006232112,
ENG123783-ENG103063,WUP_measurement_historie-Mileage,0, km
ENG123783-ENG103063,WUP_measurement_historie-Mileage,16777215, km
Elapsed Time: 00:08,,,
;SW:5WA-907-007-Q HW:5WA-907-007-Q --- Auto HVAC
;Component:AC Automat H31 3440, Coding:002000110210120011101010111111110000131100200100000000000000
;EV_ACClimaPREVW38X,001100,EV_ACClimaPREVW38X_VW38.rod
;Thursday,17,March,2022,11:40:27:62242
;VCID: 55F78F1DB58E6483CC4-8000
IDE00019,Voltage terminal 30,13.3, V
IDE00021,Engine RPM,768.00, /min
IDE00025,Coolant temperature,111, °C
IDE00198,Refrigerant pressure,6.8, bar
IDE00323-ENG127697,Security Access: Number of invalid keys-Counter_2,0,
IDE00374-MAS05377,Electric auxiliary heater: relay activation-Low heat output relay,not coded/not installed,
IDE00374-MAS05378,Electric auxiliary heater: relay activation-High heat output relay,not coded/not installed,
IDE00767,No. of unscheduled ECU resets,1,
IDE00965,Compressor shut-off condition,A/C off or fan control switch in 0 position,
IDE00966,Compressor current: actual value,0.000, A
IDE00967,Compressor current: specified value,0.000, A
IDE00968,Compressor speed,1000, /min
IDE00969,Compressor load,0.0, Nm
IDE00970,Coolant fan activation: actual value,26.8, %
IDE00971,Coolant fan activation: specified value,0.0, %
IDE00973,Outside temperature,25.0, °C
IDE00974,Outside air temperature internally calculated,17.5, °C
IDE00976,Left front vent temperature,28.5, °C
IDE00977,Right front vent temperature,26.0, °C
IDE00981,Footwell vent temperature,33.5, °C
IDE00982,Temperature downstream of evaporator,38.6, °C
IDE00983,Inside temperature,24.2, °C
IDE00984,Sun intensity left,30,
IDE00985,Sun intensity right,60,
IDE00987,Blower voltage: specified value,0.0, V
IDE00989,Blower status,active,
IDE00994,Actual value for fresh air/recirculation air flow flap,635,
IDE00994,Actual value for fresh air/recirculation air flow flap,67.0, %
IDE00995,Fresh air/recirculating air/back pressure door specified value,691,
IDE00996,Fresh air stop for fresh air/recirculation air flow flap,859,
IDE00997,Recirculated air stop for fresh air/recirc air flow flap,170,
IDE00998,Left temperature flap - actual value,0.0, %
IDE00998,Left temperature flap - actual value,111,
IDE00999,Temperature door left - Specified value,0,
IDE01040,Left Temperature Control Door - cold stop,123,
IDE01041,Left temperature flap: warm stop,914,
IDE01042,Right temperature flap: actual value,0.0, %
IDE01042,Right temperature flap: actual value,89,
IDE01043,Temperature door right - Specified value,0,
IDE01044,Right temperature flap: cold stop,100,
IDE01045,Right temperature flap: warm stop,903,
IDE01050,Front air distribution flap: actual value,0.0, %
IDE01050,Front air distribution flap: actual value,932,
IDE01051,Air distribution door front - Specified value,256,
IDE01052,Front air distribution flap: air outlet stop,926,
IDE01053,Front air distribution flap: footwell air outlet stop,98,
IDE01054,Defroster flap: actual value,0.0, %
IDE01054,Defroster flap: actual value,101,
IDE01055,Defrost door - Specified value,0,
IDE01056,Defroster flap: stop open,931,
IDE01057,Defroster flap: stop closed,103,
IDE01063,Status of recirculation air,Fresh air,
IDE01065,Rear vent temperature,22.5, °C
IDE01066,Convertible top status,to,
IDE01069,Rear blower voltage: specified value,0.0, V
IDE01076,Time since ignition off,15, min
IDE01088,Rear temperature flap: actual value,78,
IDE01088,Rear temperature flap: actual value,0.0, %
IDE01089,Rear temperature flap: specified value,0,
IDE01090,Rear temperature flap: cold stop,81,
IDE01091,Rear temperature flap: warm stop,941,
IDE01226,Blower voltage: actual value,0.1, V
IDE01227,Blower current,0.00, A
IDE01232,Supply voltage for external components,4.9, V
IDE01264,Remaining time of parking heater/ventilation operation,0, s
IDE01287-MAS01260,Counter of compressor switch-offs-Shut-off from Engine Control Module (ECM) via CAN,229,
IDE01287-MAS01265,Counter of compressor switch-offs-Speed shut-off,0,
IDE01419,Compressor shut-off condition: last,A/C off or fan control switch in 0 position,
IDE01420,Compressor shut-off requirement: penultimate,Shut-off of engine control module via CAN (T > 15 sec.),
IDE01421,Compressor shut-off requirement: antepenultimate,Shut-off from Engine Control Module (ECM) via CAN,
IDE01433,Air quality status,Clean air,
IDE01442-MAS01533,Pressing a button-Defrost,not active,
IDE01442-MAS01534,Pressing a button-Recirculating air,not active,
IDE01442-MAS01535,Pressing a button-Rear window defogger,not active,
IDE01442-MAS01550,Pressing a button-AC,not active,
IDE01442-MAS01554,Pressing a button-Left heated seat,not active,
IDE01442-MAS01556,Pressing a button-Right heated seat,not active,
IDE01442-MAS01560,Pressing a button-OFF,not active,
IDE01442-MAS01564,Pressing a button-Front windshield heater,not active,
IDE01442-MAS01577,Pressing a button-Parking heater,not active,
IDE01442-MAS02015,Pressing a button-AUTO,not active,
IDE01442-MAS02192,Pressing a button-SYNC,not active,
IDE01442-MAS03196,Pressing a button-Menu,not active,
IDE01442-MAS03830,Pressing a button-Footwell air distribution,not active,
IDE01442-MAS03831,Pressing a button-Upper body vent air distribution,not active,
IDE01442-MAS03832,Pressing a button-Air distribution up,not active,
IDE01442-MAS04605,Pressing a button-AC MAX,not active,
IDE01448,Actual value of heated front window,not coded/not installed,
IDE01449-IDE01011,Personalization 1 for climate control-Data record,active,
IDE01449-MAS01533,Personalization 1 for climate control-Defrost,0,
IDE01449-MAS01534,Personalization 1 for climate control-Recirculating air,0,
IDE01449-MAS01550,Personalization 1 for climate control-AC,0,
IDE01449-MAS01552,Personalization 1 for climate control-Left specified temperature,20.0,
IDE01449-MAS01553,Personalization 1 for climate control-Right specified temperature,20.0,
IDE01449-MAS01554,Personalization 1 for climate control-Left heated seat,0,
IDE01449-MAS01555,Personalization 1 for climate control-Left seat ventilation,0,
IDE01449-MAS01556,Personalization 1 for climate control-Right heated seat,0,
IDE01449-MAS01557,Personalization 1 for climate control-Right seat ventilation,0,
IDE01449-MAS01560,Personalization 1 for climate control-OFF,1,
IDE01449-MAS01562,Personalization 1 for climate control-Air quality sensor,0,
IDE01449-MAS01563,Personalization 1 for climate control-Auxiliary Air Heater,0,
IDE01449-MAS01566,Personalization 1 for climate control-Style,1,
IDE01449-MAS01567,Personalization 1 for climate control-Synchronization,0,
IDE01449-MAS02015,Personalization 1 for climate control-AUTO,0,
IDE01449-MAS02804,Personalization 1 for climate control-Manual fan speed increase,not installed,
IDE01449-MAS03830,Personalization 1 for climate control-Footwell air distribution,0,
IDE01449-MAS03831,Personalization 1 for climate control-Upper body vent air distribution,0,
IDE01449-MAS03832,Personalization 1 for climate control-Air distribution up,0,
IDE01449-MAS04620,Personalization 1 for climate control-Fan setting: absolute,3,
IDE01449-MAS04621,Personalization 1 for climate control-Left head area heater,not installed,
IDE01449-MAS04648,Personalization 1 for climate control-Right head area heater,not installed,
IDE01449-MAS06077,Personalization 1 for climate control-Manual blower stage during defrost active,0,
IDE01449-MAS06366,Personalization 1 for climate control-Display blower levels,00000000 ,
IDE01450-IDE01011,Personalization 2 for climate control-Data record,not active,
IDE01450-MAS01533,Personalization 2 for climate control-Defrost,0,
IDE01450-MAS01534,Personalization 2 for climate control-Recirculating air,0,
IDE01450-MAS01550,Personalization 2 for climate control-AC,1,
IDE01450-MAS01552,Personalization 2 for climate control-Left specified temperature,22.0,
IDE01450-MAS01553,Personalization 2 for climate control-Right specified temperature,22.0,
IDE01450-MAS01554,Personalization 2 for climate control-Left heated seat,0,
IDE01450-MAS01555,Personalization 2 for climate control-Left seat ventilation,0,
IDE01450-MAS01556,Personalization 2 for climate control-Right heated seat,0,
IDE01450-MAS01557,Personalization 2 for climate control-Right seat ventilation,0,
IDE01450-MAS01560,Personalization 2 for climate control-OFF,0,
IDE01450-MAS01562,Personalization 2 for climate control-Air quality sensor,0,
IDE01450-MAS01563,Personalization 2 for climate control-Auxiliary Air Heater,0,
IDE01450-MAS01566,Personalization 2 for climate control-Style,0,
IDE01450-MAS01567,Personalization 2 for climate control-Synchronization,1,
IDE01450-MAS02015,Personalization 2 for climate control-AUTO,1,
IDE01450-MAS02804,Personalization 2 for climate control-Manual fan speed increase,not installed,
IDE01450-MAS03830,Personalization 2 for climate control-Footwell air distribution,0,
IDE01450-MAS03831,Personalization 2 for climate control-Upper body vent air distribution,0,
IDE01450-MAS03832,Personalization 2 for climate control-Air distribution up,0,
IDE01450-MAS04620,Personalization 2 for climate control-Fan setting: absolute,3,
IDE01450-MAS04621,Personalization 2 for climate control-Left head area heater,not installed,
IDE01450-MAS04648,Personalization 2 for climate control-Right head area heater,not installed,
IDE01450-MAS06077,Personalization 2 for climate control-Manual blower stage during defrost active,0,
IDE01450-MAS06366,Personalization 2 for climate control-Display blower levels,00000000 ,
IDE01451-IDE01011,Personalization 3 for climate control-Data record,not active,
IDE01451-MAS01533,Personalization 3 for climate control-Defrost,0,
IDE01451-MAS01534,Personalization 3 for climate control-Recirculating air,0,
IDE01451-MAS01550,Personalization 3 for climate control-AC,1,
IDE01451-MAS01552,Personalization 3 for climate control-Left specified temperature,22.0,
IDE01451-MAS01553,Personalization 3 for climate control-Right specified temperature,22.0,
IDE01451-MAS01554,Personalization 3 for climate control-Left heated seat,0,
IDE01451-MAS01555,Personalization 3 for climate control-Left seat ventilation,0,
IDE01451-MAS01556,Personalization 3 for climate control-Right heated seat,0,
IDE01451-MAS01557,Personalization 3 for climate control-Right seat ventilation,0,
IDE01451-MAS01560,Personalization 3 for climate control-OFF,0,
IDE01451-MAS01562,Personalization 3 for climate control-Air quality sensor,0,
IDE01451-MAS01563,Personalization 3 for climate control-Auxiliary Air Heater,0,
IDE01451-MAS01566,Personalization 3 for climate control-Style,0,
IDE01451-MAS01567,Personalization 3 for climate control-Synchronization,1,
IDE01451-MAS02015,Personalization 3 for climate control-AUTO,1,
IDE01451-MAS02804,Personalization 3 for climate control-Manual fan speed increase,not installed,
IDE01451-MAS03830,Personalization 3 for climate control-Footwell air distribution,0,
IDE01451-MAS03831,Personalization 3 for climate control-Upper body vent air distribution,0,
IDE01451-MAS03832,Personalization 3 for climate control-Air distribution up,0,
IDE01451-MAS04620,Personalization 3 for climate control-Fan setting: absolute,3,
IDE01451-MAS04621,Personalization 3 for climate control-Left head area heater,not installed,
IDE01451-MAS04648,Personalization 3 for climate control-Right head area heater,not installed,
IDE01451-MAS06077,Personalization 3 for climate control-Manual blower stage during defrost active,0,
IDE01451-MAS06366,Personalization 3 for climate control-Display blower levels,00000000 ,
IDE01452-IDE01011,Personalization 4 for climate control-Data record,not active,
IDE01452-MAS01533,Personalization 4 for climate control-Defrost,0,
IDE01452-MAS01534,Personalization 4 for climate control-Recirculating air,0,
IDE01452-MAS01550,Personalization 4 for climate control-AC,0,
IDE01452-MAS01552,Personalization 4 for climate control-Left specified temperature,29.5,
IDE01452-MAS01553,Personalization 4 for climate control-Right specified temperature,29.5,
IDE01452-MAS01554,Personalization 4 for climate control-Left heated seat,0,
IDE01452-MAS01555,Personalization 4 for climate control-Left seat ventilation,0,
IDE01452-MAS01556,Personalization 4 for climate control-Right heated seat,0,
IDE01452-MAS01557,Personalization 4 for climate control-Right seat ventilation,0,
IDE01452-MAS01560,Personalization 4 for climate control-OFF,0,
IDE01452-MAS01562,Personalization 4 for climate control-Air quality sensor,0,
IDE01452-MAS01563,Personalization 4 for climate control-Auxiliary Air Heater,0,
IDE01452-MAS01566,Personalization 4 for climate control-Style,0,
IDE01452-MAS01567,Personalization 4 for climate control-Synchronization,0,
IDE01452-MAS02015,Personalization 4 for climate control-AUTO,0,
IDE01452-MAS02804,Personalization 4 for climate control-Manual fan speed increase,not installed,
IDE01452-MAS03830,Personalization 4 for climate control-Footwell air distribution,0,
IDE01452-MAS03831,Personalization 4 for climate control-Upper body vent air distribution,0,
IDE01452-MAS03832,Personalization 4 for climate control-Air distribution up,0,
IDE01452-MAS04620,Personalization 4 for climate control-Fan setting: absolute,3,
IDE01452-MAS04621,Personalization 4 for climate control-Left head area heater,not installed,
IDE01452-MAS04648,Personalization 4 for climate control-Right head area heater,not installed,
IDE01452-MAS06077,Personalization 4 for climate control-Manual blower stage during defrost active,0,
IDE01452-MAS06366,Personalization 4 for climate control-Display blower levels,00000000 ,
IDE01540-MAS06913,Left front heated seat-Backrest heating: activation,0, %
IDE01540-MAS06914,Left front heated seat-Seat cushion heating: activation,0, %
IDE01540-MAS07048,Left front heated seat-Target temperature backrest,OFF,
IDE01540-MAS07049,Left front heated seat-Target temperature seat cushion,OFF,
IDE01540-MAS07050,Left front heated seat-Actual temperature backrest,25.6, °C
IDE01540-MAS07051,Left front heated seat-Actual temperature seat cushion,25.6, °C
IDE01540-MAS07052,Left front heated seat-Setting,OFF,
IDE01540-MAS07071,Left front heated seat-Temperature sensor for seat cushion: resistance value,78.27, kOhm
IDE01540-MAS07072,Left front heated seat-Temperature sensor for backrest: resistance value,78.27, kOhm
IDE01540-MAS07921,Left front heated seat-Balance setting,Neutral,
IDE01540-MAS07929,Left front heated seat-Power quota setting by energy management,99, %
IDE01540-MAS07945,Left front heated seat-Spec temp: backrest with active overheating function,not coded/not installed,
IDE01540-MAS07946,Left front heated seat-Spec temp: seat cushion with active overheating function,not coded/not installed,
IDE01540-MAS07947,Left front heated seat-Backrest heater: status,not active,
IDE01540-MAS07950,Left front heated seat-Seat cushion heater: status,not active,
IDE01540-MAS07951,Left front heated seat-Automatic down-shift,not active,
IDE01540-MAS07968,Left front heated seat-Temp sensor offset in chassis ground,not coded/not installed,
IDE01540-MAS12630,Left front heated seat-Backrest heater: current draw (effective value),0.0, A
IDE01540-MAS12631,Left front heated seat-Seat cushion: current draw (effective value),0.0, A
IDE01541-MAS06913,Right front heated seat-Backrest heating: activation,0, %
IDE01541-MAS06914,Right front heated seat-Seat cushion heating: activation,0, %
IDE01541-MAS07048,Right front heated seat-Target temperature backrest,OFF,
IDE01541-MAS07049,Right front heated seat-Target temperature seat cushion,OFF,
IDE01541-MAS07050,Right front heated seat-Actual temperature backrest,22.0, °C
IDE01541-MAS07051,Right front heated seat-Actual temperature seat cushion,22.0, °C
IDE01541-MAS07052,Right front heated seat-Setting,OFF,
IDE01541-MAS07071,Right front heated seat-Temperature sensor for seat cushion: resistance value,92.39, kOhm
IDE01541-MAS07072,Right front heated seat-Temperature sensor for backrest: resistance value,92.39, kOhm
IDE01541-MAS07921,Right front heated seat-Balance setting,Neutral,
IDE01541-MAS07929,Right front heated seat-Power quota setting by energy management,99, %
IDE01541-MAS07945,Right front heated seat-Spec temp: backrest with active overheating function,not coded/not installed,
IDE01541-MAS07946,Right front heated seat-Spec temp: seat cushion with active overheating function,not coded/not installed,
IDE01541-MAS07947,Right front heated seat-Backrest heater: status,not active,
IDE01541-MAS07950,Right front heated seat-Seat cushion heater: status,not active,
IDE01541-MAS07951,Right front heated seat-Automatic down-shift,not active,
IDE01541-MAS07968,Right front heated seat-Temp sensor offset in chassis ground,not coded/not installed,
IDE01541-MAS12630,Right front heated seat-Backrest heater: current draw (effective value),0.0, A
IDE01541-MAS12631,Right front heated seat-Seat cushion: current draw (effective value),0.0, A
IDE01544-MAS05377,Auxiliary Air Heater-Low heat output relay,not coded/not installed,
IDE01544-MAS05378,Auxiliary Air Heater-High heat output relay,not coded/not installed,
IDE01544-MAS07914,Auxiliary Air Heater-Heating stage: spec value,not coded/not installed,
IDE01544-MAS12633,Auxiliary Air Heater-Relay for small heater output: current draw (effective value),0, mA
IDE01544-MAS12634,Auxiliary Air Heater-Relay for large heater output: current draw (effective value),0, mA
IDE01694-MAS01767,Left rear heated seat-Left rear seat heater stage,0,
IDE01694-MAS01768,Left rear heated seat-Left rear seat heater specified temperature,77.5, °C
IDE01694-MAS01769,Left rear heated seat-Left rear seat heater actual temperature,77.5, °C
IDE01694-MAS01770,Left rear heated seat-Left rear seat heater current,25.5, A
IDE01695-MAS01771,Right rear heated seat-Right rear seat heater stage,0,
IDE01695-MAS01772,Right rear heated seat-Right rear seat heater specified temperature,77.5, °C
IDE01695-MAS01773,Right rear heated seat-Right rear seat heater actual temperature,77.5, °C
IDE01695-MAS01774,Right rear heated seat-Right rear seat heater current,25.5, A
IDE02270-IDE01268,CAN input signal(s) status-Windshield wiper,OFF,
IDE02270-IDE01457,CAN input signal(s) status-Energy management deactivation stage,Deactivation stage 0,
IDE02270-MAS01281,CAN input signal(s) status-Back-up lamp,OFF,
IDE02270-MAS01283,CAN input signal(s) status-Actual value of windshield heater,OFF,
IDE02271-IDE00972,CAN output signal(s) status-Idle speed increase,not active,
IDE02271-MAS00130,CAN output signal(s) status-Compressor on,OFF,
IDE03008-IDE80251,Stop process prevented-Head area heater,not active,
IDE03008-MAS01564,Stop process prevented-Front windshield heater,not active,
IDE03008-MAS02802,Stop process prevented-Interior temperature difference to specifications,not active,
IDE03008-MAS02803,Stop process prevented-Blowout temperature difference to specifications,not active,
IDE03008-MAS02804,Stop process prevented-Manual fan speed increase,not active,
IDE03008-MAS05009,Stop process prevented-A/C request: auxil. heat mode,not active,
IDE03008-MAS05046,Stop process prevented-Evaporator temperature difference to specifications,not active,
IDE03008-MAS06551,Stop process prevented-Seat ventilation,not active,
IDE03008-MAS09538,Stop process prevented-max A/C,not active,
IDE03010-IDE80251,Number of prevented stop processes-Head area heater,0,
IDE03010-MAS01517,Number of prevented stop processes-Defrost active,0,
IDE03010-MAS01564,Number of prevented stop processes-Front windshield heater,0,
IDE03010-MAS02802,Number of prevented stop processes-Interior temperature difference to specifications,0,
IDE03010-MAS02803,Number of prevented stop processes-Blowout temperature difference to specifications,0,
IDE03010-MAS02804,Number of prevented stop processes-Manual fan speed increase,0,
IDE03010-MAS04353,Number of prevented stop processes-Fogging hazard (humidity sensor),0,
IDE03010-MAS04354,Number of prevented stop processes-Interior comfort humidity too high (humidity sensor),0,
IDE03010-MAS05009,Number of prevented stop processes-A/C request: auxil. heat mode,0,
IDE03010-MAS05046,Number of prevented stop processes-Evaporator temperature difference to specifications,0,
IDE03010-MAS05047,Number of prevented stop processes-Maximum cooling and heating set,0,
IDE03010-MAS06551,Number of prevented stop processes-Seat ventilation,0,
IDE03010-MAS09538,Number of prevented stop processes-max A/C,0,
IDE03011-IDE80251,Number of requested start processes-Head area heater,0,
IDE03011-MAS01517,Number of requested start processes-Defrost active,0,
IDE03011-MAS01564,Number of requested start processes-Front windshield heater,0,
IDE03011-MAS02802,Number of requested start processes-Interior temperature difference to specifications,0,
IDE03011-MAS02803,Number of requested start processes-Blowout temperature difference to specifications,0,
IDE03011-MAS02804,Number of requested start processes-Manual fan speed increase,0,
IDE03011-MAS03904,Number of requested start processes-Maximum permissible stop duration reached,0,
IDE03011-MAS04353,Number of requested start processes-Fogging hazard (humidity sensor),0,
IDE03011-MAS04354,Number of requested start processes-Interior comfort humidity too high (humidity sensor),0,
IDE03011-MAS05009,Number of requested start processes-A/C request: auxil. heat mode,0,
IDE03011-MAS05046,Number of requested start processes-Evaporator temperature difference to specifications,0,
IDE03011-MAS05047,Number of requested start processes-Maximum cooling and heating set,0,
IDE03011-MAS06551,Number of requested start processes-Seat ventilation,0,
IDE03011-MAS09538,Number of requested start processes-max A/C,0,
IDE03488,Driving time remaining for basic setting of compressor run in,60, s
IDE03527-ENG119301,CAN signals-BCM_01: BCM1_Rueckfahrlicht_Schalter,Not operated,
IDE03527-ENG119298,CAN signals-Dimmung_01: DI_KL_58xd,232,
IDE03527-ENG119297,CAN signals-Dimmung_01: DI_KL_58xs,0, %
IDE03527-ENG119296,CAN signals-Gateway_71: ESP_v_Signal,0.00, km/h
IDE03527-ENG119295,CAN signals-Gateway_73: MO_Drehzahl_01,768.00, /min
IDE03527-ENG119293,CAN signals-Klima_Sensor_02: BCM1_Aussen_Temp_ungef,25.0, °C
IDE03527-ENG119292,CAN signals-Kombi_02: KBI_Standzeit,952, s
IDE03527-ENG119346,CAN signals-Motor_07: MO_Absperrventil_oeffnen,Ventil_oeffnen_oder_geoeffnet,
IDE03527-ENG128338,CAN signals-Motor_07: MO_Heizungspumpenansteuerung,0, %
IDE03527-ENG119291,CAN signals-Motor_07: MO_Kuehlmittel_Temp,110.25, °C
IDE03527-ENG119349,CAN signals-Motor_14: MO_Klima_Eingr,no intervention,
IDE03527-ENG119348,CAN signals-Motor_14: MO_StartStopp_Fahrerwunsch,Init,
IDE03527-ENG119289,CAN signals-Motor_14: MO_StartStopp_Motorstopp,Motor_Stop_inaktiv,
IDE03527-ENG119347,CAN signals-Motor_14: MO_StartStopp_Status,System_in_diesem_KL15_Zyklus_nicht_verfuegbar,
IDE03527-ENG119290,CAN signals-Motor_14: MO_StartStopp_Wiederstart,Wiederstart_inaktiv,
IDE03527-ENG119287,CAN signals-Wischer_01: Waschen_vorne_aktiv,not active,
IDE03527-ENG119288,CAN signals-Wischer_01: Wischer_vorne_aktiv,not active,
IDE03527-ENG128339,CAN signals-ZV_02: ZV_Schluessel_Zugang,aktive_Funkschluessel_Nr_01,
IDE04312-IDE04095,System run time-Engine running time,253, s
IDE04312-MAS00084,System run time-Terminal 15 on,23, s
IDE04805-IDE02955,Driving profile selection-System status,Not available,
IDE04805-MAS01447,Driving profile selection-Act.val.,2,
IDE04805-MAS01448,Driving profile selection-Target value,0,
IDE04805-MAS05058,Driving profile selection-Compatibility,not calculated,
IDE05533,Heater for nozzles,OFF,
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,Yes,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,Yes,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,No,
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,25.4, °C
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,25.5, °C
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,29.0, %
IDE06091-MAS04647,Humidity sensor: interior-Dew point,6.0, °C
IDE06163-MAS04628,Humidity sensor: exterior-Air temperature,Initialization,
IDE06163-MAS04629,Humidity sensor: exterior-Sensor temperature,Initialization,
IDE06163-MAS04630,Humidity sensor: exterior-Relative humidity,Initialization,
IDE06163-MAS04647,Humidity sensor: exterior-Dew point,62.2, °C
IDE06219-IDE01011,Personalization 1 for climate control: top open-Data record,not active,
IDE06219-MAS01533,Personalization 1 for climate control: top open-Defrost,0,
IDE06219-MAS01534,Personalization 1 for climate control: top open-Recirculating air,0,
IDE06219-MAS01550,Personalization 1 for climate control: top open-AC,1,
IDE06219-MAS01552,Personalization 1 for climate control: top open-Left specified temperature,22.0,
IDE06219-MAS01553,Personalization 1 for climate control: top open-Right specified temperature,22.0,
IDE06219-MAS01554,Personalization 1 for climate control: top open-Left heated seat,0,
IDE06219-MAS01555,Personalization 1 for climate control: top open-Left seat ventilation,0,
IDE06219-MAS01556,Personalization 1 for climate control: top open-Right heated seat,0,
IDE06219-MAS01557,Personalization 1 for climate control: top open-Right seat ventilation,0,
IDE06219-MAS01560,Personalization 1 for climate control: top open-OFF,0,
IDE06219-MAS01562,Personalization 1 for climate control: top open-Air quality sensor,0,
IDE06219-MAS01563,Personalization 1 for climate control: top open-Auxiliary Air Heater,0,
IDE06219-MAS01566,Personalization 1 for climate control: top open-Style,0,
IDE06219-MAS01567,Personalization 1 for climate control: top open-Synchronization,1,
IDE06219-MAS02015,Personalization 1 for climate control: top open-AUTO,1,
IDE06219-MAS02804,Personalization 1 for climate control: top open-Manual fan speed increase,not installed,
IDE06219-MAS03830,Personalization 1 for climate control: top open-Footwell air distribution,0,
IDE06219-MAS03831,Personalization 1 for climate control: top open-Upper body vent air distribution,0,
IDE06219-MAS03832,Personalization 1 for climate control: top open-Air distribution up,0,
IDE06219-MAS04620,Personalization 1 for climate control: top open-Fan setting: absolute,3,
IDE06219-MAS04621,Personalization 1 for climate control: top open-Left head area heater,not installed,
IDE06219-MAS04648,Personalization 1 for climate control: top open-Right head area heater,not installed,
IDE06219-MAS06077,Personalization 1 for climate control: top open-Manual blower stage during defrost active,0,
IDE06219-MAS06366,Personalization 1 for climate control: top open-Display blower levels,00000000 ,
IDE06220-IDE01011,Personalization 2 for climate control: top open-Data record,not active,
IDE06220-MAS01533,Personalization 2 for climate control: top open-Defrost,0,
IDE06220-MAS01534,Personalization 2 for climate control: top open-Recirculating air,0,
IDE06220-MAS01550,Personalization 2 for climate control: top open-AC,1,
IDE06220-MAS01552,Personalization 2 for climate control: top open-Left specified temperature,22.0,
IDE06220-MAS01553,Personalization 2 for climate control: top open-Right specified temperature,22.0,
IDE06220-MAS01554,Personalization 2 for climate control: top open-Left heated seat,0,
IDE06220-MAS01555,Personalization 2 for climate control: top open-Left seat ventilation,0,
IDE06220-MAS01556,Personalization 2 for climate control: top open-Right heated seat,0,
IDE06220-MAS01557,Personalization 2 for climate control: top open-Right seat ventilation,0,
IDE06220-MAS01560,Personalization 2 for climate control: top open-OFF,0,
IDE06220-MAS01562,Personalization 2 for climate control: top open-Air quality sensor,0,
IDE06220-MAS01563,Personalization 2 for climate control: top open-Auxiliary Air Heater,0,
IDE06220-MAS01566,Personalization 2 for climate control: top open-Style,0,
IDE06220-MAS01567,Personalization 2 for climate control: top open-Synchronization,1,
IDE06220-MAS02015,Personalization 2 for climate control: top open-AUTO,1,
IDE06220-MAS02804,Personalization 2 for climate control: top open-Manual fan speed increase,not installed,
IDE06220-MAS03830,Personalization 2 for climate control: top open-Footwell air distribution,0,
IDE06220-MAS03831,Personalization 2 for climate control: top open-Upper body vent air distribution,0,
IDE06220-MAS03832,Personalization 2 for climate control: top open-Air distribution up,0,
IDE06220-MAS04620,Personalization 2 for climate control: top open-Fan setting: absolute,3,
IDE06220-MAS04621,Personalization 2 for climate control: top open-Left head area heater,not installed,
IDE06220-MAS04648,Personalization 2 for climate control: top open-Right head area heater,not installed,
IDE06220-MAS06077,Personalization 2 for climate control: top open-Manual blower stage during defrost active,0,
IDE06220-MAS06366,Personalization 2 for climate control: top open-Display blower levels,00000000 ,
IDE06221-IDE01011,Personalization 3 for climate control: top open-Data record,not active,
IDE06221-MAS01533,Personalization 3 for climate control: top open-Defrost,0,
IDE06221-MAS01534,Personalization 3 for climate control: top open-Recirculating air,0,
IDE06221-MAS01550,Personalization 3 for climate control: top open-AC,0,
IDE06221-MAS01552,Personalization 3 for climate control: top open-Left specified temperature,29.5,
IDE06221-MAS01553,Personalization 3 for climate control: top open-Right specified temperature,29.5,
IDE06221-MAS01554,Personalization 3 for climate control: top open-Left heated seat,0,
IDE06221-MAS01555,Personalization 3 for climate control: top open-Left seat ventilation,0,
IDE06221-MAS01556,Personalization 3 for climate control: top open-Right heated seat,0,
IDE06221-MAS01557,Personalization 3 for climate control: top open-Right seat ventilation,0,
IDE06221-MAS01560,Personalization 3 for climate control: top open-OFF,0,
IDE06221-MAS01562,Personalization 3 for climate control: top open-Air quality sensor,0,
IDE06221-MAS01563,Personalization 3 for climate control: top open-Auxiliary Air Heater,0,
IDE06221-MAS01566,Personalization 3 for climate control: top open-Style,0,
IDE06221-MAS01567,Personalization 3 for climate control: top open-Synchronization,0,
IDE06221-MAS02015,Personalization 3 for climate control: top open-AUTO,0,
IDE06221-MAS02804,Personalization 3 for climate control: top open-Manual fan speed increase,not installed,
IDE06221-MAS03830,Personalization 3 for climate control: top open-Footwell air distribution,0,
IDE06221-MAS03831,Personalization 3 for climate control: top open-Upper body vent air distribution,0,
IDE06221-MAS03832,Personalization 3 for climate control: top open-Air distribution up,0,
IDE06221-MAS04620,Personalization 3 for climate control: top open-Fan setting: absolute,3,
IDE06221-MAS04621,Personalization 3 for climate control: top open-Left head area heater,not installed,
IDE06221-MAS04648,Personalization 3 for climate control: top open-Right head area heater,not installed,
IDE06221-MAS06077,Personalization 3 for climate control: top open-Manual blower stage during defrost active,0,
IDE06221-MAS06366,Personalization 3 for climate control: top open-Display blower levels,00000000 ,
IDE06233-MAS01632,Auxiliary heater: controlled-Status,not active,
IDE06233-MAS03746,Auxiliary heater: controlled-Current: actual value,0, A
IDE06233-MAS04625,Auxiliary heater: controlled-Power: actual value,0, W
IDE06233-MAS04626,Auxiliary heater: controlled-Power: target value,0, W
IDE06234-IDE01270,Auxiliary heater: in stages-Enabling for auxiliary heater operation,No enabling,
IDE06234-MAS01447,Auxiliary heater: in stages-Act.val.,0,
IDE06234-MAS01448,Auxiliary heater: in stages-Target value,0,
IDE06234-MAS04992,Auxiliary heater: in stages-Specified value for control,0,
IDE06235,Potentiometer for rear vent temperature,Measuring value not available,
IDE06279-IDE00707,Parking heater: customer setting-Operating mode,Comfort function,
IDE06279-MAS00106,Parking heater: customer setting-Year,2000,
IDE06279-MAS00107,Parking heater: customer setting-Month,0,
IDE06279-MAS00108,Parking heater: customer setting-Day,0,
IDE06279-MAS00109,Parking heater: customer setting-Hours,0,
IDE06279-MAS00110,Parking heater: customer setting-Minutes,0,
IDE06279-MAS01379,Parking heater: customer setting-Operating time,30, min
IDE06279,Parking heater: customer setting,Time 2,
IDE06279,Parking heater: customer setting,Time 3,
IDE06279,Parking heater: customer setting,not active,
IDE06279,Parking heater: customer setting,Time 1,
IDE06307-MAS00106,Stop prevention history data-Year,2127, yr
IDE06307-MAS00107,Stop prevention history data-Month,15, m
IDE06307-MAS00108,Stop prevention history data-Day,31, d
IDE06307-MAS00109,Stop prevention history data-Hours,31, H
IDE06307-MAS00110,Stop prevention history data-Minutes,63, min
IDE06307-MAS00111,Stop prevention history data-Seconds,63, s
IDE06307-MAS01517,Stop prevention history data-Defrost active,not active,
IDE06307-MAS01564,Stop prevention history data-Front windshield heater,not active,
IDE06307-MAS02802,Stop prevention history data-Interior temperature difference to specifications,not active,
IDE06307-MAS02803,Stop prevention history data-Blowout temperature difference to specifications,not active,
IDE06307-MAS02804,Stop prevention history data-Manual fan speed increase,not active,
IDE06307-MAS04353,Stop prevention history data-Fogging hazard (humidity sensor),not active,
IDE06307-MAS04354,Stop prevention history data-Interior comfort humidity too high (humidity sensor),not active,
IDE06307-MAS05009,Stop prevention history data-A/C request: auxil. heat mode,not active,
IDE06307-MAS05046,Stop prevention history data-Evaporator temperature difference to specifications,not active,
IDE06307-MAS05047,Stop prevention history data-Maximum cooling and heating set,not active,
IDE06307-MAS06551,Stop prevention history data-Seat ventilation,not active,
IDE06307-MAS09538,Stop prevention history data-max A/C,not active,
IDE06308-MAS00106,Start request history data-Year,2127, yr
IDE06308-MAS00107,Start request history data-Month,15, m
IDE06308-MAS00108,Start request history data-Day,31, d
IDE06308-MAS00109,Start request history data-Hours,31, H
IDE06308-MAS00110,Start request history data-Minutes,63, min
IDE06308-MAS00111,Start request history data-Seconds,63, s
IDE06308-MAS01517,Start request history data-Defrost active,not active,
IDE06308-MAS01564,Start request history data-Front windshield heater,not active,
IDE06308-MAS02802,Start request history data-Interior temperature difference to specifications,not active,
IDE06308-MAS02803,Start request history data-Blowout temperature difference to specifications,not active,
IDE06308-MAS02804,Start request history data-Manual fan speed increase,not active,
IDE06308-MAS03904,Start request history data-Maximum permissible stop duration reached,not active,
IDE06308-MAS04353,Start request history data-Fogging hazard (humidity sensor),not active,
IDE06308-MAS04354,Start request history data-Interior comfort humidity too high (humidity sensor),not active,
IDE06308-MAS05009,Start request history data-A/C request: auxil. heat mode,not active,
IDE06308-MAS05046,Start request history data-Evaporator temperature difference to specifications,not active,
IDE06308-MAS05047,Start request history data-Maximum cooling and heating set,not active,
IDE06308-MAS06551,Start request history data-Seat ventilation,not active,
IDE06308-MAS09538,Start request history data-max A/C,not active,
IDE06545,Blower voltage for production routines,6.0, V
IDE06546,Interior specified temperature for production routines,22, °C
IDE06547,Air distribution for production routines,No effect,
IDE06593,Air recirculation for production routines,No effect,
IDE06750-IDE01011,Last customer settings-Data record,active,
IDE06750-MAS01533,Last customer settings-Defrost,0,
IDE06750-MAS01534,Last customer settings-Recirculating air,0,
IDE06750-MAS01550,Last customer settings-AC,0,
IDE06750-MAS01552,Last customer settings-Left specified temperature,20.0,
IDE06750-MAS01553,Last customer settings-Right specified temperature,20.0,
IDE06750-MAS01554,Last customer settings-Left heated seat,0,
IDE06750-MAS01555,Last customer settings-Left seat ventilation,0,
IDE06750-MAS01556,Last customer settings-Right heated seat,0,
IDE06750-MAS01557,Last customer settings-Right seat ventilation,0,
IDE06750-MAS01560,Last customer settings-OFF,1,
IDE06750-MAS01562,Last customer settings-Air quality sensor,0,
IDE06750-MAS01563,Last customer settings-Auxiliary Air Heater,0,
IDE06750-MAS01566,Last customer settings-Style,1,
IDE06750-MAS01567,Last customer settings-Synchronization,0,
IDE06750-MAS02015,Last customer settings-AUTO,0,
IDE06750-MAS02804,Last customer settings-Manual fan speed increase,not installed,
IDE06750-MAS03830,Last customer settings-Footwell air distribution,0,
IDE06750-MAS03831,Last customer settings-Upper body vent air distribution,0,
IDE06750-MAS03832,Last customer settings-Air distribution up,0,
IDE06750-MAS04620,Last customer settings-Fan setting: absolute,3,
IDE06750-MAS04621,Last customer settings-Left head area heater,not installed,
IDE06750-MAS04648,Last customer settings-Right head area heater,not installed,
IDE06750-MAS06077,Last customer settings-Manual blower stage during defrost active,0,
IDE06750-MAS06366,Last customer settings-Display blower levels,00000000 ,
IDE07991-MAS04446,A/C clutch-Relay activation status,not active,
IDE08500-MAS07921,Left front seat ventilation setting-Balance setting,Not available,
IDE08500-MAS07928,Left front seat ventilation setting-Ventilation stage,OFF,
IDE08500-MAS07929,Left front seat ventilation setting-Power quota setting by energy management,Not available,
IDE08501-MAS07921,Right front seat ventilation setting-Balance setting,Not available,
IDE08501-MAS07928,Right front seat ventilation setting-Ventilation stage,OFF,
IDE08501-MAS07929,Right front seat ventilation setting-Power quota setting by energy management,Not available,
IDE08961-MAS01554,Installation info: seat heater-Left heated seat,Parallel activation of backrest and seat cushion,
IDE08961-MAS01556,Installation info: seat heater-Right heated seat,Parallel activation of backrest and seat cushion,
IDE10300,OBD Driving Cycle detected,active,
IDE11698-MAS09216,Instrument panel temperature sensor-Sun intensity,0.0, W/m²
IDE11698-MAS13115,Instrument panel temperature sensor-Sunlight sensor: voltage,not coded/not installed,
IDE11698-MAS13116,Instrument panel temperature sensor-Temperature sensor 1: temperature,not coded/not installed,
IDE11698-MAS13117,Instrument panel temperature sensor-Temperature sensor 1: resistance value,not coded/not installed,
IDE11698-MAS13118,Instrument panel temperature sensor-Temperature sensor 2: temperature,not coded/not installed,
IDE11698-MAS13119,Instrument panel temperature sensor-Temperature sensor 2: resistance value,not coded/not installed,
IDE11698-MAS13179,Instrument panel temperature sensor-Temperature sensor 3: temperature,not coded/not installed,
IDE11698-MAS13180,Instrument panel temperature sensor-Temperature sensor 3: resistance value,not coded/not installed,
IDE11795,Supply voltage 2 for external components,3.2, V
IDE12141,History memory: parking heater,Write only channel,
IDE12141-MAS02526,History memory: parking heater-Activation,Write only channel,
IDE12141-MAS04390,History memory: parking heater-Active source,Write only channel,
IDE12499-IDE08704,A/C compressor initial running in: start prevention-Load management,not active,
IDE12499-MAS01250,A/C compressor initial running in: start prevention-Malfunction on fresh air blower,not active,
IDE12499-MAS01493,A/C compressor initial running in: start prevention-Engine running,Yes,
IDE12499-MAS10030,A/C compressor initial running in: start prevention-Adapt. of run-in time: compressor initial operation: written,Yes,
IDE12499-MAS14625,A/C compressor initial running in: start prevention-High-voltage vehicle electrical system,not active,
IDE12499-MAS14626,A/C compressor initial running in: start prevention-High-voltage current limitations,not active,
IDE12499-MAS14891,A/C compressor initial running in: start prevention-Flaps not calibrated,not active,
IDE12500-IDE08704,A/C compressor initial running in: interruption conditions-Load management,not active,
IDE12500-MAS01250,A/C compressor initial running in: interruption conditions-Malfunction on fresh air blower,not active,
IDE12500-MAS01254,A/C compressor initial running in: interruption conditions-AC button off,not active,
IDE12500-MAS01256,A/C compressor initial running in: interruption conditions-Outside air temperature too low,not active,
IDE12500-MAS01263,A/C compressor initial running in: interruption conditions-Compressor activation: malfunction in activation path,not active,
IDE12500-MAS01264,A/C compressor initial running in: interruption conditions-Malfunction at refrigerant pressure sensor,not active,
IDE12500-MAS01265,A/C compressor initial running in: interruption conditions-Speed shut-off,not active,
IDE12500-MAS01504,A/C compressor initial running in: interruption conditions-Supply voltage too high,not active,
IDE12500-MAS01508,A/C compressor initial running in: interruption conditions-High pressure event,not active,
IDE12500-MAS01509,A/C compressor initial running in: interruption conditions-Low pressure event,not active,
IDE12500-MAS14625,A/C compressor initial running in: interruption conditions-High-voltage vehicle electrical system,not active,
IDE12500-MAS14626,A/C compressor initial running in: interruption conditions-High-voltage current limitations,not active,
IDE12500-MAS14892,A/C compressor initial running in: interruption conditions-Pressure test not successful,not active,
IDE12500-MAS14893,A/C compressor initial running in: interruption conditions-Fault on the evaporator temperature sensor,not active,
IDE13845,Production mode status,not active,
IDE14095,Wiper park position heater,not coded/not installed,
IDE15414,Potentiometer for rear vent temperature - end stop cold,Measuring value not available,
IDE15415,Potentiometer for rear vent temperature - end stop warm,Measuring value not available,
IDE16797,Pre-ventilation: total elapsed time of the function,0, s
IDE16798,Pre-ventilation: number of functions performed,0,
IDE16799,Pre-ventilation: remaining time,1460, d
MAS00464-MAS00106,Standard - ambient data 1-Year,2022,
MAS00464-MAS00107,Standard - ambient data 1-Month,3,
MAS00464-MAS00108,Standard - ambient data 1-Day,17,
MAS00464-MAS00109,Standard - ambient data 1-Hours,11,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,40,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,42,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,56,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,3969, km
MAS11295,Refrigerant temperature,Measuring value not available,
ENG01580-ENG28628,Analysedaten Stellmotoren-saved_action_speed_control_motor_air_distribution_flap,6,
ENG01580-ENG119283,Analysedaten Stellmotoren-saved_action_speed_control_motor_air_recirculation_flap,7,
ENG01580-ENG28799,Analysedaten Stellmotoren-saved_action_speed_control_motor_defroster_flap,15,
ENG01580-ENG28626,Analysedaten Stellmotoren-saved_action_speed_control_motor_temperature_flap_left,15,
ENG01580-ENG28627,Analysedaten Stellmotoren-saved_action_speed_control_motor_temperature_flap_right,15,
ENG01581-MAS00106,Buzzer für Standheizung /Standlüftung-Year,2001,
ENG01581-MAS00107,Buzzer für Standheizung /Standlüftung-Month,1,
ENG01581-MAS00108,Buzzer für Standheizung /Standlüftung-Day,1,
ENG01581-MAS00109,Buzzer für Standheizung /Standlüftung-Hours,0,
ENG01581-MAS00110,Buzzer für Standheizung /Standlüftung-Minutes,0,
ENG01581-ENG30435,Buzzer für Standheizung /Standlüftung-buzzer_state,not active,
ENG01582-ENG119358,CAN Signale Standheizungsfunktion-Klima_03: STH_aktiv,0,
ENG01582-ENG119357,CAN Signale Standheizungsfunktion-Klima_03: STH_Ansteuerung,0,
ENG01582-ENG119359,CAN Signale Standheizungsfunktion-Klima_03: STL_aktiv,0,
ENG01582-ENG119355,CAN Signale Standheizungsfunktion-STH_01: STH_Fehlerstatus,0,
ENG01582-ENG119352,CAN Signale Standheizungsfunktion-STH_01: STH_Funk_aus,0,
ENG01582-ENG119351,CAN Signale Standheizungsfunktion-STH_01: STH_Funk_ein,0,
ENG01582-ENG119354,CAN Signale Standheizungsfunktion-STH_01: STH_Geblaese,0,
ENG01582-ENG119353,CAN Signale Standheizungsfunktion-STH_01: STH_LED,0,
ENG01582-ENG119356,CAN Signale Standheizungsfunktion-STH_01: STH_Texte,0,
ENG01583-ENG128249,CAN Signale Standklimatisierung 1-HVEM_04: HVEM_FreigabeKlimatisierung,0,
ENG01583-ENG128248,CAN Signale Standklimatisierung 1-HVEM_04: HVEM_KlimaMaxHVStrom,0,
ENG01583-ENG01668,CAN Signale Standklimatisierung 1-HVLM_05: HVLM_Standklima_Timer_Status,0,
ENG01583-ENG128251,CAN Signale Standklimatisierung 1-HVLM_05: HVLM_VK_Anf,0,
ENG01583-ENG128252,CAN Signale Standklimatisierung 1-HVLM_05: HVLM_VK_Modus,0,
ENG01583-ENG128250,CAN Signale Standklimatisierung 1-HVLM_05: HVLM_VK_STH_Einsatz,6,
ENG01583-ENG128253,CAN Signale Standklimatisierung 1-Motor_14: MO_HYB_Fahrbereitschaft,0,
ENG01583-ENG128254,CAN Signale Standklimatisierung 1-Motor_EV_01: HV_Bordnetz_aktiv,0,
ENG01584-ENG128287,CAN Signale Standklimatisierung 2-Klima_EV_03: KL_EKK_Strom,1.5, A
ENG01584-ENG128288,CAN Signale Standklimatisierung 2-Klima_EV_03: KL_HV_Heizer_Strom,1.5, A
ENG01584-ENG128283,CAN Signale Standklimatisierung 2-Klima_EV_04: KL_Standklima_RemoteModus,0,
ENG01584-ENG128282,CAN Signale Standklimatisierung 2-Klima_EV_04: KL_Standklima_Status_02,0,
ENG01584-ENG128286,CAN Signale Standklimatisierung 2-Klima_EV_04: KL_VK_Anf,6,
ENG01584-ENG128284,CAN Signale Standklimatisierung 2-Klima_EV_04: KL_VK_Betriebsdauer,0, min
ENG01584-ENG128285,CAN Signale Standklimatisierung 2-Klima_EV_04: KL_Vorkond_Strategie,1,
ENG01603-IDE01352,Speicherdaten allgemein-Temperature unit,°F,
ENG01603-MAS02289,Speicherdaten allgemein-Outside temperature,17.0, °C
Elapsed Time: 00:18,,,
;SW:5WA-937-086-N HW:5WA-937-086-N --- Cent. Elect.
;Component:BCM37w_H026 0174, Coding:
;EV_BCM37w,007001,EV_BCM37w_007.rod
;Thursday,17,March,2022,11:41:19:62242
;VCDS Version: Release 22.3.0 Data version: 20220225 DS336.1
;VCID: 5CE19A39D6A4B5CBF3A-8008
Group,Description,Actual,
IDE00001,Production mode,not active,
IDE00301,Mileage,3967, km
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,OFF,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,Not operated,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,Not operated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,Not operated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,Not operated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,Not operated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,none,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,Not operated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,Initialization,
IDE01992-SFT00009,Installation list: current installations-Electronic central electric,active,
IDE01992-SFT00183,Installation list: current installations-Interface for access/start system,active,
IDE01992-SFT00214,Installation list: current installations-Light Control Left 2,not active,
IDE01992-SFT00215,Installation list: current installations-Light Control Right 2,not active,
IDE01992-SFT33031,Installation list: current installations-Antenna module,not active,
IDE01992-SFT33054,Installation list: current installations-Burglary Protection Control Module FL,active,
IDE01992-SFT33055,Installation list: current installations-Burglary Protection Control Module FR,active,
IDE01992-SFT33056,Installation list: current installations-Burglary Protection Control Module RL,active,
IDE01992-SFT33057,Installation list: current installations-Burglary Protection Control Module RR,active,
IDE01992-SFT33058,Installation list: current installations-Burglary Protection Control Module interior,not active,
IDE01996-SFT00009,Installation list: specified installations-Electronic central electric,active,
IDE01996-SFT00183,Installation list: specified installations-Interface for access/start system,active,
IDE01996-SFT00214,Installation list: specified installations-Light Control Left 2,not active,
IDE01996-SFT00215,Installation list: specified installations-Light Control Right 2,not active,
IDE01996-SFT33031,Installation list: specified installations-Antenna module,not active,
IDE01996-SFT33054,Installation list: specified installations-Burglary Protection Control Module FL,active,
IDE01996-SFT33055,Installation list: specified installations-Burglary Protection Control Module FR,active,
IDE01996-SFT33056,Installation list: specified installations-Burglary Protection Control Module RL,active,
IDE01996-SFT33057,Installation list: specified installations-Burglary Protection Control Module RR,active,
IDE01996-SFT33058,Installation list: specified installations-Burglary Protection Control Module interior,not active,
IDE02711-IDE05228,Rear wiper-Operating hour counter,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE02711-MAS01632,Rear wiper-Status,not active,
IDE02711-MAS20299,Rear wiper-Wiper level: steering column switch module,switched off,
IDE02711-MAS20300,Rear wiper-Actual wiper level,not active,
IDE02745-IDE00096,Ignition Switch Key Lock Solenoid-Selector lever position,Initialization,
IDE02745-MAS08205,Ignition Switch Key Lock Solenoid-CAN ESP valid speed,Qualified,
IDE02745-MAS08206,Ignition Switch Key Lock Solenoid-CAN ESP speed,0.00, km/h
IDE02857-IDE03111,Activation current-Interior lighting,0, mA
IDE02857-IDE06012,Activation current-Background lighting,0, mA
IDE02857-ENG128458,Activation current-DWA_Einfachhorn,Measuring value not available,
IDE02857-ENG126436,Activation current-signal_horn,Measuring value not available,
IDE03150-SFT00009,Readiness for bus sleep mode-Electronic central electric,not ready for sleep,
IDE03150-SFT00183,Readiness for bus sleep mode-Interface for access/start system,not ready for sleep,
IDE03150-SFT00214,Readiness for bus sleep mode-Light Control Left 2,Ready For Sleep,
IDE03150-SFT00215,Readiness for bus sleep mode-Light Control Right 2,Ready For Sleep,
IDE03150-SFT33031,Readiness for bus sleep mode-Antenna module,Ready For Sleep,
IDE03150-SFT33054,Readiness for bus sleep mode-Burglary Protection Control Module FL,not ready for sleep,
IDE03150-SFT33055,Readiness for bus sleep mode-Burglary Protection Control Module FR,not ready for sleep,
IDE03150-SFT33056,Readiness for bus sleep mode-Burglary Protection Control Module RL,not ready for sleep,
IDE03150-SFT33057,Readiness for bus sleep mode-Burglary Protection Control Module RR,not ready for sleep,
IDE03150-SFT33058,Readiness for bus sleep mode-Burglary Protection Control Module interior,Ready For Sleep,
IDE03527-MAS05102,CAN signals-Driver information: emergency shutdown,not active,
IDE03527-MAS10895,CAN signals-Driver information key position copy workshop,not active,
IDE04347-IDE00020,Expanded freeze frame conditions-Terminal 15 status,On,
IDE04347-IDE01716,Expanded freeze frame conditions-Terminal 50 status,OFF,
IDE04347-IDE05742,Expanded freeze frame conditions-Light switch position,0,
IDE04347-MAS01957,Expanded freeze frame conditions-Outside temperature,25.0, °C
IDE04347-MAS04121,Expanded freeze frame conditions-Voltage,13.4, V
IDE04347-MAS09388,Expanded freeze frame conditions-Engine run,On,
IDE04347-MAS19766,Expanded freeze frame conditions-Status of brake lamp switch: discrete,OFF,
IDE04347-MAS19768,Expanded freeze frame conditions-Brake lamp switch via CAN: status,OFF,
IDE04639,Last wake-up cause,Comfort data bus,
IDE05042-MAS03873,Emergency flasher button-Duty cycle,15.5, %
IDE05045-IDE05183,Front wiper module-Malfunction left,No malfunction,
IDE05045-IDE05184,Front wiper module-Malfunction right,No malfunction,
IDE05045-MAS01364,Front wiper module-Stage 1,not active,
IDE05045-MAS01365,Front wiper module-Stage 2,not active,
IDE05045-MAS03638,Front wiper module-Wipe speed,0 revolutions per minute,
IDE05045-MAS05057,Front wiper module-Number of wiper cycles,2100,
IDE05045-MAS05878,Front wiper module-Stage,not coded/not installed,
IDE05719-IDE05534,Window washer system-Headlamp washer system,not coded/not installed,
IDE05719-MAS02341,Window washer system-Rear window washer system,not active,
IDE05834-MAS00212,Driver info-Insufficient washer fluid,not active,
IDE05834-MAS00214,Driver info-Brake pad wear,not coded/not installed,
IDE05836-MAS03637,Rain recognition sensor-Rain quantity,0,
IDE05838-MAS02248,Light recognition sensor-Signal state,active,
IDE05838-MAS02475,Light recognition sensor-Brightness infrared,3600, lx
IDE05838-MAS02851,Light recognition sensor-Brightness,2502, lx
IDE05838-MAS04809,Light recognition sensor-Darkness,OFF,
IDE05838-MAS04810,Light recognition sensor-Request for light activation,OFF,
IDE06507-MAS13127,Button in center console-Status of button 1,not coded/not installed,
IDE06507-MAS13128,Button in center console-Indicator lamp button 1,not coded/not installed,
IDE06507-MAS13130,Button in center console-Status of button 2,not coded/not installed,
IDE06507-MAS13131,Button in center console-Indicator lamp button 2,not coded/not installed,
IDE06507-MAS13133,Button in center console-Status of button 3,not coded/not installed,
IDE06507-MAS13134,Button in center console-Indicator lamp button 3,not coded/not installed,
IDE06507-MAS13136,Button in center console-Indicator lamp button 4,not coded/not installed,
IDE06507-MAS13137,Button in center console-Status of button 4,not coded/not installed,
IDE06566-IDE00008,Key identification-Software version,0602,
IDE06566-IDE00016,Key identification-Hardware version,H18,
IDE06566-MAS04970,Key identification-Part Number,5H0959753J ,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,05,
IDE07145-MAS06776,Component protection properties-Komponent protection role,WFS Master,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,00,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 01,
IDE08211-MAS03129,History data control module reset-Reset counter,0,
IDE08211,History data control module reset,|last cause of reset,Year
IDE08235-MAS00084,Status of immobilizer participant-Terminal 15 on,Yes,
IDE08235-MAS06798,Status of immobilizer participant-Key / terminal status,FC,
IDE08235-MAS06799,Status of immobilizer participant-Immobiliser status,00,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,F8,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,00,
IDE08235-MAS06804,Status of immobilizer participant-Status TCM,00,
IDE08235-MAS06805,Status of immobilizer participant-Status ESCL,F8,
IDE08235-MAS06806,Status of immobilizer participant-Status OCU,00,
IDE08235-MAS06807,Status of immobilizer participant-Status VTS,00,
IDE08235-MAS10135,Status of immobilizer participant-Terminal 15 on via login,No,
IDE08235-MAS10136,Status of immobilizer participant-Key in position terminal 15,Yes,
IDE08235-MAS10137,Status of immobilizer participant-Key in position S,Yes,
IDE08235-MAS10138,Status of immobilizer participant-Key locked,Yes,
IDE08235-MAS10139,Status of immobilizer participant-Key adapted,Yes,
IDE08235-MAS10140,Status of immobilizer participant-Key authorized,Yes,
IDE08235-MAS10141,Status of immobilizer participant-Immobilizer status bit 0,0,
IDE08235-MAS10142,Status of immobilizer participant-Immobilizer status bit 1,0,
IDE08235-MAS10143,Status of immobilizer participant-Debug mode,not active,
IDE08235-MAS10144,Status of immobilizer participant-Immobilizer status bit 3,0,
IDE08235-MAS10145,Status of immobilizer participant-Immobilizer status bit 4,0,
IDE08235-MAS10146,Status of immobilizer participant-Immobilizer status bit 5,0,
IDE08235-MAS10147,Status of immobilizer participant-Immobilizer status bit 6,0,
IDE08235-MAS10148,Status of immobilizer participant-Immobilizer status bit 7,0,
IDE08236-MAS06808,Status locking periods immobilizer-Lock time download,0, min
IDE08236-MAS06809,Status locking periods immobilizer-Reset lock time passwords,0, min
IDE08236-MAS06810,Status locking periods immobilizer-Lock time login terminal 15 on,0, min
IDE08236-MAS06811,Status locking periods immobilizer-Lock time login learn keys,0, min
IDE08236-MAS06812,Status locking periods immobilizer-Lock time login leave learn keys,0, min
IDE08236-MAS06813,Status locking periods immobilizer-Lock time login special functions,0, min
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,00 00 00 02,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,06,
IDE08238,Transponder ID current Key,AE 15 DB B0,
IDE08239,Transponder ID Key 1,AE 15 DB B0,
IDE08240,Transponder ID Key 2,6A 14 DB B0,
IDE08251-IDE80258,Configuration immobilizer-Immobilizer status,00 00,
IDE08251-MAS01159,Configuration immobilizer-Version number,00,
IDE08251-MAS01483,Configuration immobilizer-Software version,00 00 00,
IDE08251-MAS06847,Configuration immobilizer-Snapshot,00 00 00 00 00 00 00 00,
IDE08251-MAS06848,Configuration immobilizer-Power class 2,00,
IDE08251-MAS06849,Configuration immobilizer-Supported power classes,00,
IDE08251-MAS11095,Configuration immobilizer-Cause,00 00 00,
IDE08252-MAS06854,Test sum of adapted transponder-Version,81,
IDE08252-MAS06855,Test sum of adapted transponder-Test sum,68 70 72 84,
IDE08343,Immobilizer Challenge,8E 53 F6 7D,
IDE08356-IDE00102,Left seat backrest fan 1-Control Module temperature,26, °C
IDE08356-MAS01447,Left seat backrest fan 1-Act.val.,0, /min
IDE08356-MAS01634,Left seat backrest fan 1-Supply voltage,13, V
IDE08356-MAS09948,Left seat backrest fan 1-Pin coding. spec. value,7, bit
IDE08356-MAS09949,Left seat backrest fan 1-Pin coding. act. value,7, bit
IDE08356-MAS10342,Left seat backrest fan 1-No. of start-up attempts after blocking error,0, counts
IDE08358-IDE00102,Left seat cushion fan 1-Control Module temperature,27, °C
IDE08358-MAS01447,Left seat cushion fan 1-Act.val.,0, /min
IDE08358-MAS01634,Left seat cushion fan 1-Supply voltage,13, V
IDE08358-MAS09948,Left seat cushion fan 1-Pin coding. spec. value,6, bit
IDE08358-MAS09949,Left seat cushion fan 1-Pin coding. act. value,6, bit
IDE08358-MAS10342,Left seat cushion fan 1-No. of start-up attempts after blocking error,0, counts
IDE08360-IDE00102,Right seat backrest fan 1-Control Module temperature,26, °C
IDE08360-MAS01447,Right seat backrest fan 1-Act.val.,0, /min
IDE08360-MAS01634,Right seat backrest fan 1-Supply voltage,13, V
IDE08360-MAS09948,Right seat backrest fan 1-Pin coding. spec. value,3, bit
IDE08360-MAS09949,Right seat backrest fan 1-Pin coding. act. value,3, bit
IDE08360-MAS10342,Right seat backrest fan 1-No. of start-up attempts after blocking error,0, counts
IDE08362-IDE00102,Right seat cushion fan 1-Control Module temperature,25, °C
IDE08362-MAS01447,Right seat cushion fan 1-Act.val.,0, /min
IDE08362-MAS01634,Right seat cushion fan 1-Supply voltage,13, V
IDE08362-MAS09948,Right seat cushion fan 1-Pin coding. spec. value,2, bit
IDE08362-MAS09949,Right seat cushion fan 1-Pin coding. act. value,2, bit
IDE08362-MAS10342,Right seat cushion fan 1-No. of start-up attempts after blocking error,0, counts
IDE08949-MAS07869,Operating current: light driver-Conn. pin 2,0, mA
IDE08949-MAS07870,Operating current: light driver-Conn. pin 3,0, mA
IDE08949-MAS07871,Operating current: light driver-Conn. pin 4,0, mA
IDE08949-MAS07872,Operating current: light driver-Conn. pin 5,0, mA
IDE08949-MAS07873,Operating current: light driver-Conn. pin 6,0, mA
IDE08949-MAS07874,Operating current: light driver-Conn. pin 7,0, mA
IDE08949-MAS07875,Operating current: light driver-Conn. pin 8,0, mA
IDE08949-MAS07876,Operating current: light driver-Conn. pin 9,0, mA
IDE08949-MAS07877,Operating current: light driver-Conn. pin 10,0, mA
IDE08949-MAS07878,Operating current: light driver-Conn. pin 11,0, mA
IDE08949-MAS07879,Operating current: light driver-Conn. pin 12,0, mA
IDE08949-MAS07880,Operating current: light driver-Conn. pin 13,0, mA
IDE08949-MAS07890,Operating current: light driver-Conn. pin 23,0, mA
IDE08949-MAS07891,Operating current: light driver-Conn. pin 24,0, mA
IDE08949-MAS07892,Operating current: light driver-Conn. pin 25,0, mA
IDE08949-MAS07897,Operating current: light driver-Conn. pin 30,0, mA
IDE08949-MAS20146,Operating current: light driver-Conn. pin 35,0, mA
IDE08949-MAS20147,Operating current: light driver-Conn. pin 36,0, mA
IDE08949-MAS20148,Operating current: light driver-Conn. pin 37,0, mA
IDE08949-MAS20149,Operating current: light driver-Conn. pin 38,0, mA
IDE08949-MAS20150,Operating current: light driver-Conn. pin 39,0, mA
IDE08949-MAS20151,Operating current: light driver-Conn. pin 40,0, mA
IDE08949-MAS20152,Operating current: light driver-Conn. pin 41,0, mA
IDE08949-MAS21233,Operating current: light driver-Conn. pin 42,0, mA
IDE08949-MAS21234,Operating current: light driver-Conn. pin 43,0, mA
IDE08949-MAS21235,Operating current: light driver-Conn. pin 45,0, mA
IDE08949-MAS21236,Operating current: light driver-Conn. pin 44,136, mA
IDE10345-IDE00673,Roof electronics control module: button-Information Service Button -E450-,Not operated,
IDE10345-MAS08884,Roof electronics control module: button-Sunroof button,Not operated,
IDE10345-MAS08932,Roof electronics control module: button-Sunroof shade button,Not operated,
IDE10345-MAS10417,Roof electronics control module: button-Door contact switching button,Not operated,
IDE10345-MAS10426,Roof electronics control module: button-Roadside Assistance Button,Not operated,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,not coded/not installed,
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,not coded/not installed,
IDE11551-MAS03619,Status of identification data query on LIN-Bus-complete,Yes,
IDE11551-MAS11095,Status of identification data query on LIN-Bus-Cause,Terminal 15 on,
IDE11551-MAS12667,Status of identification data query on LIN-Bus-Specified installation of sub-bus users,10,
IDE11551-MAS12668,Status of identification data query on LIN-Bus-Actual installation of sub-bus users,11,
IDE11727-MAS13125,Function of the central console button-Function of button 1,not coded/not installed,
IDE11727-MAS13128,Function of the central console button-Indicator lamp button 1,installed,
IDE11727-MAS13129,Function of the central console button-Function of button 2,not coded/not installed,
IDE11727-MAS13131,Function of the central console button-Indicator lamp button 2,installed,
IDE11727-MAS13132,Function of the central console button-Function of button 3,not coded/not installed,
IDE11727-MAS13134,Function of the central console button-Indicator lamp button 3,installed,
IDE11727-MAS13135,Function of the central console button-Function of button 4,not coded/not installed,
IDE11727-MAS13136,Function of the central console button-Indicator lamp button 4,installed,
IDE12262-MAS14182,Virtual radio key: status-Master key coded,Yes,
IDE12262-MAS14183,Virtual radio key: status-Virtual radio key active,No,
IDE12262-MAS14184,Virtual radio key: status-Number of secure elements in the ticket table,0,
IDE12265-MAS06854,Virtual radio key: check sum-Version,C1,
IDE12265-MAS06879,Virtual radio key: check sum-Checksum,5B CE 9B 7A,
IDE12940-IDE01268,Lever functions of the steering column electronics-Windshield wiper,Intermittent operation,
IDE12940-IDE02335,Lever functions of the steering column electronics-Signal light switch position,Not operated,
IDE12940-IDE02711,Lever functions of the steering column electronics-Rear wiper,Not operated,
IDE12940-MAS00232,Lever functions of the steering column electronics-MFI button UP,Not operated,
IDE12940-MAS00233,Lever functions of the steering column electronics-MFI button DOWN,Not operated,
IDE12940-MAS00234,Lever functions of the steering column electronics-MFI button RESET / OK,Not operated,
IDE12940-MAS00242,Lever functions of the steering column electronics-Driver assistance systems button,Not operated,
IDE12940-MAS00243,Lever functions of the steering column electronics-Buttons for driver assistance systems: status,No malfunction detected,
IDE12940-MAS01288,Lever functions of the steering column electronics-Horn,Not operated,
IDE12940-MAS02338,Lever functions of the steering column electronics-Windshield wiper: intermittent stage,Stage 1,
IDE12940-MAS02339,Lever functions of the steering column electronics-Windshield washer system,Not operated,
IDE12940-MAS02341,Lever functions of the steering column electronics-Rear window washer system,Not operated,
IDE12940,Lever functions of the steering column electronics,Not operated,
IDE13750-IDE01351,Input signals: control of terminal-Terminal 75 status,On,
IDE13750-IDE01715,Input signals: control of terminal-Status terminal S,not coded/not installed,
IDE13750-IDE01716,Input signals: control of terminal-Terminal 50 status,OFF,
IDE13750-IDE02572,Input signals: control of terminal-Starter button: status,not active,
IDE13750-IDE13954,Input signals: control of terminal-Starter button: status redundant,not active,
IDE13750-MAS12787,Input signals: control of terminal-Terminal 15 ignition switch signal 1,not coded/not installed,
IDE13750-MAS12788,Input signals: control of terminal-Terminal 15 ignition switch signal 2,not coded/not installed,
IDE13750-MAS17227,Input signals: control of terminal-Starter button: error status,No malfunction detected,
IDE13750-MAS17233,Input signals: control of terminal-Terminal start command,not coded/not installed,
IDE13751-IDE00020,Output signals: control of terminal-Terminal 15 status,active,
IDE13751-IDE00773,Output signals: control of terminal-Terminal 15 status via CAN,active,
IDE13751-IDE06027,Output signals: control of terminal-Terminal S status via CAN,active,
IDE13751-ENG125330,Output signals: control of terminal-Status_Terminal_Startwunsch_BCM,not active,
IDE13751-ENG124149,Output signals: control of terminal-Terminal_50_CAN,not active,
IDE13752-IDE09059,Electrical Steering Column Lock-Request terminal release,not active,
IDE13752-MAS06711,Electrical Steering Column Lock-Terminal release,active,
IDE13752-MAS17234,Electrical Steering Column Lock-Steering column lock locked,not active,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVWFB7CD8NW129409,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,6,
IDE13956-IDE00075,Key position replication: input signals-Vehicle speed,0.00, km/h
IDE13956-IDE01715,Key position replication: input signals-Status terminal S,On,
IDE13956-MAS01493,Key position replication: input signals-Engine running,active,
IDE13956-MAS02248,Key position replication: input signals-Signal state,valid,
IDE13956-MAS03607,Key position replication: input signals-Engine stop active in Start/Stop mode,not active,
IDE13956-MAS03679,Key position replication: input signals-Terminal 15 status,On,
IDE13956-MAS05104,Key position replication: input signals-Driver request: start engine,not active,
IDE13956-MAS06711,Key position replication: input signals-Terminal release,not active,
IDE13956-MAS06793,Key position replication: input signals-Number of adapted keys,2,
IDE13956-MAS07719,Key position replication: input signals-Terminal 50 status,OFF,
IDE13956-MAS08136,Key position replication: input signals-Enabling Steering Column Lock,Condition not met,
IDE13956,Key position replication: input signals,0, s
IDE13956-ENG124460,Key position replication: input signals-clampcoordinator_approval,On,
IDE13956-ENG124553,Key position replication: input signals-diag_trigger_clampcoordinator_intern,OFF,
IDE13956-ENG125170,Key position replication: input signals-Powertrain_activation_permitted,Yes,
IDE13956-ENG129033,Key position replication: input signals-s_anf_klemmenfreigabe_wfs,not requested,
IDE13956-ENG126972,Key position replication: input signals-s_klemmenfreigabe_wfs,No enabling,
IDE13956-ENG129036,Key position replication: input signals-To_block_terminal_upshift,not active,
IDE13956-ENG125477,Key position replication: input signals-trigger_clampcoordinator_intern_for_ignition_off,OFF,
IDE13956-ENG125478,Key position replication: input signals-trigger_clampkoordinator_intern_for_ignition_on,OFF,
IDE13956-ENG125479,Key position replication: input signals-Trigger_terminal_15_shutoff,No,
IDE13956-ENG129038,Key position replication: input signals-Valid_time_control_section_diagnostics,0, s
IDE14015-MAS04970,Lock set part number-Part Number,,
IDE14016,Transponder type,00 36,
IDE14238-MAS02282,Wiper arm position-Position,0.0, °
IDE14238-MAS19580,Wiper arm position-Alternating park position,Alternating park position 1,
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 51 29 41 38 DF AA DA,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,4,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 07,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE14958-SFT00002,Recognized actual fitting list: adapt-Transmission Electronics,not detected,
IDE14958-SFT00005,Recognized actual fitting list: adapt-Access/start authorization,detected,
IDE14958-SFT00006,Recognized actual fitting list: adapt-Seat adjustment: passenger's side,not detected,
IDE14958-SFT00008,Recognized actual fitting list: adapt-Climate Control Module,detected,
IDE14958-SFT00023,Recognized actual fitting list: adapt-Instrument cluster,detected,
IDE14958-SFT00025,Recognized actual fitting list: adapt-Data Bus OBD Interface,detected,
IDE14958-SFT00038,Recognized actual fitting list: adapt-Convertible top operation,not detected,
IDE14958-SFT00043,Recognized actual fitting list: adapt-Steering column lock,detected,
IDE14958-SFT00054,Recognized actual fitting list: adapt-Seat adjustment: driver side,detected,
IDE14958-SFT00061,Recognized actual fitting list: adapt-Special Function,not detected,
IDE14958-SFT00096,Recognized actual fitting list: adapt-Trip recorder,not detected,
IDE14958-SFT00105,Recognized actual fitting list: adapt-Trailer Function,not detected,
IDE14958-SFT00106,Recognized actual fitting list: adapt-Automatic door: rear driver side,not detected,
IDE14958-SFT00109,Recognized actual fitting list: adapt-Rear lid electronics,not detected,
IDE14958-SFT00122,Recognized actual fitting list: adapt-Automatic door: rear passenger side,not detected,
IDE14958-SFT00165,Recognized actual fitting list: adapt-Front sensor for drivers assistant systems,detected,
IDE14958-SFT00202,Recognized actual fitting list: adapt-Sunroof control module,detected,
IDE14958-SFT00214,Recognized actual fitting list: adapt-Light Control Left 2,not detected,
IDE14958-SFT00215,Recognized actual fitting list: adapt-Light Control Right 2,not detected,
IDE14958-SFT33031,Recognized actual fitting list: adapt-Antenna module,not detected,
IDE14958-SFT33054,Recognized actual fitting list: adapt-Burglary Protection Control Module FL,detected,
IDE14958-SFT33055,Recognized actual fitting list: adapt-Burglary Protection Control Module FR,detected,
IDE14958-SFT33056,Recognized actual fitting list: adapt-Burglary Protection Control Module RL,detected,
IDE14958-SFT33057,Recognized actual fitting list: adapt-Burglary Protection Control Module RR,detected,
IDE14958-SFT33058,Recognized actual fitting list: adapt-Burglary Protection Control Module interior,not detected,
IDE14958-SFT09746,Recognized actual fitting list: adapt-Driver door control module,detected,
IDE14958-SFT09747,Recognized actual fitting list: adapt-Front passenger door control module,detected,
IDE14958-SFT09804,Recognized actual fitting list: adapt-Rear Driver Side Door Control Module,detected,
IDE14958-SFT09805,Recognized actual fitting list: adapt-Rear Passenger Door Control Module,detected,
IDE14958-SFT09963,Recognized actual fitting list: adapt-Antenna for short-range communication,not detected,
IDE14958-SFT09995,Recognized actual fitting list: adapt-Antenna 2 for short-range communication,not detected,
IDE14959,Tailgate opening: reason for non-availability,No release by access control,
IDE14993-MAS19447,Software composition list identification data-Versioning,01,
IDE14993-MAS20341,Software composition list identification data-Number of software composition,00 41,
IDE14993,Software composition list identification data,|Software Composition ID,System designation
IDE15048-ENG124753,Output signals: terminal coordinator-KST_Immobiliser_Level_Request_CAN,unrestricted,
IDE15048-ENG124754,Output signals: terminal coordinator-KST_Immobiliser_Level_Request_SR,unrestricted,
IDE15048-ENG124755,Output signals: terminal coordinator-KST_Request_Clamp_15,CL_15_HW_AND_CAN,
IDE15048-ENG124756,Output signals: terminal coordinator-KST_Specialstate_Request_CAN,Initialization,
IDE15048-ENG124757,Output signals: terminal coordinator-KST_Specialstate_Request_SR,Initialization,
IDE15048-ENG124758,Output signals: terminal coordinator-KST_Specialstate_Status_CAN,active,
IDE15048-ENG124759,Output signals: terminal coordinator-KST_Specialstate_Status_SR,active,
IDE15049-IDE09065,Input signals: terminal coordinator-Status: remote start,Initialization,
IDE15049-MAS20292,Input signals: terminal coordinator-Key position reproduction: status,active,
IDE15049-MAS20294,Input signals: terminal coordinator-Key position reproduction: terminal query,Terminal 15: discrete and CAN,
IDE15049-MAS20297,Input signals: terminal coordinator-Key position replication: immobilizer request,unrestricted,
IDE15049-MAS20298,Input signals: terminal coordinator-Terminal 15 via diagnostic: query status,Initialization,
IDE15049-ENG01615,Input signals: terminal coordinator-AAA_Request_Clamp_15,none,
IDE15049-ENG01616,Input signals: terminal coordinator-AAA_Request_Immobiliser_Level,none,
IDE15049-ENG01617,Input signals: terminal coordinator-AAA_Request_Status,Initialization,
IDE15049-ENG01618,Input signals: terminal coordinator-MWS_Request_Clamp_15,none,
IDE15049-ENG01619,Input signals: terminal coordinator-MWS_Request_Immobiliser_Level,none,
IDE15049-ENG01620,Input signals: terminal coordinator-MWS_Request_Status,Initialization,
IDE15049-ENG01621,Input signals: terminal coordinator-PHP_Request_Clamp_15,none,
IDE15049-ENG01622,Input signals: terminal coordinator-PHP_Request_Immobiliser_Level,none,
IDE15049-ENG01623,Input signals: terminal coordinator-PHP_Request_Status,Initialization,
IDE15049-ENG01624,Input signals: terminal coordinator-RPA_Request_Clamp_15,none,
IDE15049-ENG01625,Input signals: terminal coordinator-RPA_Request_Immobiliser_Level,none,
IDE15049-ENG01626,Input signals: terminal coordinator-RPA_Request_Status,Initialization,
IDE15049-ENG01627,Input signals: terminal coordinator-RST_Request_Clamp_15,none,
IDE15049-ENG01628,Input signals: terminal coordinator-RST_Request_Immobiliser_Level,none,
IDE15049-ENG01629,Input signals: terminal coordinator-RWK_Request_Clamp_15,none,
IDE15049-ENG01630,Input signals: terminal coordinator-RWK_Request_Immobiliser_Level,none,
IDE15049-ENG01631,Input signals: terminal coordinator-RWK_Request_Status,Initialization,
IDE15049-ENG01632,Input signals: terminal coordinator-ZAS_Request_Clamp_15,none,
IDE15049-ENG01633,Input signals: terminal coordinator-ZAS_Request_Immobiliser_Level,none,
IDE15049-ENG01634,Input signals: terminal coordinator-ZAS_Request_Status,Initialization,
MAS00043-IDE00019,Terminal 30 power supply-Voltage terminal 30,13.40, V
MAS00043-IDE05835,Terminal 30 power supply-Supply voltage for central locking,13.40, V
MAS00043-IDE05967,Terminal 30 power supply-Voltage terminal 30 left,13.40, V
MAS00043-IDE05968,Terminal 30 power supply-Voltage terminal 30 right,13.40, V
MAS00043-IDE08734,Terminal 30 power supply-Supply voltage for anti-theft alarm system,13.40, V
MAS00077-MAS02345,Immobilizer-Current condition,02,
MAS00077-MAS06790,Immobilizer-Identity counter,01,
MAS00077-MAS06791,Immobilizer-Mark detection,03,
MAS00077-MAS06792,Immobilizer-P class,BD,
MAS00077-MAS06793,Immobilizer-Number of adapted keys,02,
MAS00077-MAS06794,Immobilizer-Number of keys to be adapted via service download,00,
MAS00077-MAS06795,Immobilizer-Number of keys to be adapted adapt service keys,00,
MAS00077-MAS06796,Immobilizer-Remaining time to switch on terminal 15,0, min
MAS00077-MAS06797,Immobilizer-Status configuration,15 00,
MAS00077-MAS10131,Immobilizer-Status Download 3,invalid,
MAS00077-ENG36977,Immobilizer-Configuration_status_(interpreted),|Configuration Kessy coded,Configuration E vehicle
MAS00464-MAS00110,Standard - ambient data 1-Minutes,41,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,57,
MAS12666-SFT09729,SubSystemNodeAddress of sub bus participant-Wiper motor control module,0x0001,
MAS12666-SFT09730,SubSystemNodeAddress of sub bus participant-Rain/Light Recognition Sensor,0x0002,
MAS12666-SFT09731,SubSystemNodeAddress of sub bus participant-Light switch,0x0003,
MAS12666-SFT09732,SubSystemNodeAddress of sub bus participant-Garage door opener control module,0x0004,
MAS12666-SFT09750,SubSystemNodeAddress of sub bus participant-Anti-theft alarm system sensor,0x0016,
MAS12666-SFT09752,SubSystemNodeAddress of sub bus participant-Alarm horn,0x0018,
MAS12666-SFT09765,SubSystemNodeAddress of sub bus participant-left tail lamp 1,0x0025,
MAS12666-SFT09766,SubSystemNodeAddress of sub bus participant-Roof electronics control module,0x0026,
MAS12666-SFT09803,SubSystemNodeAddress of sub bus participant-Humidity sensor: interior,0x004B,
MAS12666-SFT09806,SubSystemNodeAddress of sub bus participant-Rear lid opener control module,0x004E,
MAS12666-SFT09822,SubSystemNodeAddress of sub bus participant-Left head area heater,0x005E,
MAS12666-SFT09823,SubSystemNodeAddress of sub bus participant-Right head area heater,0x005F,
MAS12666-SFT09865,SubSystemNodeAddress of sub bus participant-Steering Column Switch,0x0089,
MAS12666-SFT09870,SubSystemNodeAddress of sub bus participant-Control head for driving and comfort functions,0x008E,
MAS12666-SFT09913,SubSystemNodeAddress of sub bus participant-Valve block 1 in front seat driver side,0x00B9,
MAS12666-SFT09917,SubSystemNodeAddress of sub bus participant-Valve block 1 in front seat passenger side,0x00BD,
MAS12666-SFT09921,SubSystemNodeAddress of sub bus participant-Blower 1 for left front backrest,0x00C1,
MAS12666-SFT09923,SubSystemNodeAddress of sub bus participant-Blower 1 for left front seat cushion,0x00C3,
MAS12666-SFT09925,SubSystemNodeAddress of sub bus participant-Blower 1 for right front backrest,0x00C5,
MAS12666-SFT09927,SubSystemNodeAddress of sub bus participant-Blower 1 for right front seat cushion,0x00C7,
MAS12666-SFT09963,SubSystemNodeAddress of sub bus participant-Antenna for short-range communication,0x00EB,
MAS12666-SFT09977,SubSystemNodeAddress of sub bus participant-Control unit 2 for driving and convenience functions,0x00F9,
MAS12666-SFT09995,SubSystemNodeAddress of sub bus participant-Antenna 2 for short-range communication,0x010B,
MAS12666-SFT09998,SubSystemNodeAddress of sub bus participant-left tail lamp 2,0x010E,
MAS12666-SFT09999,SubSystemNodeAddress of sub bus participant-Right rear tail lamp 1,0x010F,
MAS12666-SFT10000,SubSystemNodeAddress of sub bus participant-Right rear tail lamp 2,0x0110,
MAS12666-SFT10077,SubSystemNodeAddress of sub bus participant-Radio receiver for remote start,0x015D,
MAS12666-SFT10094,SubSystemNodeAddress of sub bus participant-Wiper motor control unit 2,0x016E,
MAS12666-SFT10128,SubSystemNodeAddress of sub bus participant-Virtual pedal door opening: rear driver side,0x0190,
MAS12666-SFT10142,SubSystemNodeAddress of sub bus participant-Virtual pedal door opening: rear passenger side,0x019E,
MAS12667-SFT09729,Specified installation of sub-bus users-Wiper motor control module,available.,
MAS12667-SFT09730,Specified installation of sub-bus users-Rain/Light Recognition Sensor,available.,
MAS12667-SFT09731,Specified installation of sub-bus users-Light switch,available.,
MAS12667-SFT09732,Specified installation of sub-bus users-Garage door opener control module,Not available,
MAS12667-SFT09750,Specified installation of sub-bus users-Anti-theft alarm system sensor,Not available,
MAS12667-SFT09752,Specified installation of sub-bus users-Alarm horn,Not available,
MAS12667-SFT09765,Specified installation of sub-bus users-left tail lamp 1,Not available,
MAS12667-SFT09766,Specified installation of sub-bus users-Roof electronics control module,available.,
MAS12667-SFT09803,Specified installation of sub-bus users-Humidity sensor: interior,Not available,
MAS12667-SFT09806,Specified installation of sub-bus users-Rear lid opener control module,Not available,
MAS12667-SFT09822,Specified installation of sub-bus users-Left head area heater,Not available,
MAS12667-SFT09823,Specified installation of sub-bus users-Right head area heater,Not available,
MAS12667-SFT09865,Specified installation of sub-bus users-Steering Column Switch,available.,
MAS12667-SFT09870,Specified installation of sub-bus users-Control head for driving and comfort functions,available.,
MAS12667-SFT09913,Specified installation of sub-bus users-Valve block 1 in front seat driver side,Not available,
MAS12667-SFT09917,Specified installation of sub-bus users-Valve block 1 in front seat passenger side,Not available,
MAS12667-SFT09921,Specified installation of sub-bus users-Blower 1 for left front backrest,available.,
MAS12667-SFT09923,Specified installation of sub-bus users-Blower 1 for left front seat cushion,available.,
MAS12667-SFT09925,Specified installation of sub-bus users-Blower 1 for right front backrest,available.,
MAS12667-SFT09927,Specified installation of sub-bus users-Blower 1 for right front seat cushion,available.,
MAS12667-SFT09963,Specified installation of sub-bus users-Antenna for short-range communication,Not available,
MAS12667-SFT09977,Specified installation of sub-bus users-Control unit 2 for driving and convenience functions,Not available,
MAS12667-SFT09995,Specified installation of sub-bus users-Antenna 2 for short-range communication,Not available,
MAS12667-SFT09998,Specified installation of sub-bus users-left tail lamp 2,Not available,
MAS12667-SFT09999,Specified installation of sub-bus users-Right rear tail lamp 1,Not available,
MAS12667-SFT10000,Specified installation of sub-bus users-Right rear tail lamp 2,Not available,
MAS12667-SFT10077,Specified installation of sub-bus users-Radio receiver for remote start,Not available,
MAS12667-SFT10094,Specified installation of sub-bus users-Wiper motor control unit 2,Not available,
MAS12667-SFT10128,Specified installation of sub-bus users-Virtual pedal door opening: rear driver side,Not available,
MAS12667-SFT10142,Specified installation of sub-bus users-Virtual pedal door opening: rear passenger side,Not available,
MAS12668-SFT09729,Actual installation of sub-bus users-Wiper motor control module,available.,
MAS12668-SFT09730,Actual installation of sub-bus users-Rain/Light Recognition Sensor,available.,
MAS12668-SFT09731,Actual installation of sub-bus users-Light switch,available.,
MAS12668-SFT09732,Actual installation of sub-bus users-Garage door opener control module,Not available,
MAS12668-SFT09750,Actual installation of sub-bus users-Anti-theft alarm system sensor,Not available,
MAS12668-SFT09752,Actual installation of sub-bus users-Alarm horn,Not available,
MAS12668-SFT09765,Actual installation of sub-bus users-left tail lamp 1,Not available,
MAS12668-SFT09766,Actual installation of sub-bus users-Roof electronics control module,available.,
MAS12668-SFT09803,Actual installation of sub-bus users-Humidity sensor: interior,Not available,
MAS12668-SFT09806,Actual installation of sub-bus users-Rear lid opener control module,Not available,
MAS12668-SFT09822,Actual installation of sub-bus users-Left head area heater,Not available,
MAS12668-SFT09823,Actual installation of sub-bus users-Right head area heater,Not available,
MAS12668-SFT09865,Actual installation of sub-bus users-Steering Column Switch,available.,
MAS12668-SFT09870,Actual installation of sub-bus users-Control head for driving and comfort functions,available.,
MAS12668-SFT09913,Actual installation of sub-bus users-Valve block 1 in front seat driver side,Not available,
MAS12668-SFT09917,Actual installation of sub-bus users-Valve block 1 in front seat passenger side,Not available,
MAS12668-SFT09921,Actual installation of sub-bus users-Blower 1 for left front backrest,available.,
MAS12668-SFT09923,Actual installation of sub-bus users-Blower 1 for left front seat cushion,available.,
MAS12668-SFT09925,Actual installation of sub-bus users-Blower 1 for right front backrest,available.,
MAS12668-SFT09927,Actual installation of sub-bus users-Blower 1 for right front seat cushion,available.,
MAS12668-SFT09963,Actual installation of sub-bus users-Antenna for short-range communication,Not available,
MAS12668-SFT09977,Actual installation of sub-bus users-Control unit 2 for driving and convenience functions,Not available,
MAS12668-SFT09995,Actual installation of sub-bus users-Antenna 2 for short-range communication,Not available,
MAS12668-SFT09998,Actual installation of sub-bus users-left tail lamp 2,Not available,
MAS12668-SFT09999,Actual installation of sub-bus users-Right rear tail lamp 1,Not available,
MAS12668-SFT10000,Actual installation of sub-bus users-Right rear tail lamp 2,Not available,
MAS12668-SFT10077,Actual installation of sub-bus users-Radio receiver for remote start,Not available,
MAS12668-SFT10094,Actual installation of sub-bus users-Wiper motor control unit 2,Not available,
MAS12668-SFT10128,Actual installation of sub-bus users-Virtual pedal door opening: rear driver side,Not available,
MAS12668-SFT10142,Actual installation of sub-bus users-Virtual pedal door opening: rear passenger side,Not available,
MAS12669-SFT09729,Bus identification of sub-bus users-Wiper motor control module,Local data bus,
MAS12669-SFT09730,Bus identification of sub-bus users-Rain/Light Recognition Sensor,Local data bus,
MAS12669-SFT09731,Bus identification of sub-bus users-Light switch,Local data bus,
MAS12669-SFT09732,Bus identification of sub-bus users-Garage door opener control module,Local data bus 4,
MAS12669-SFT09750,Bus identification of sub-bus users-Anti-theft alarm system sensor,Local data bus 3,
MAS12669-SFT09752,Bus identification of sub-bus users-Alarm horn,Local data bus 2,
MAS12669-SFT09765,Bus identification of sub-bus users-left tail lamp 1,Local data bus 8,
MAS12669-SFT09766,Bus identification of sub-bus users-Roof electronics control module,Local data bus 3,
MAS12669-SFT09803,Bus identification of sub-bus users-Humidity sensor: interior,Local data bus,
MAS12669-SFT09806,Bus identification of sub-bus users-Rear lid opener control module,Local data bus 8,
MAS12669-SFT09822,Bus identification of sub-bus users-Left head area heater,Local data bus 4,
MAS12669-SFT09823,Bus identification of sub-bus users-Right head area heater,Local data bus 4,
MAS12669-SFT09865,Bus identification of sub-bus users-Steering Column Switch,Local data bus 6,
MAS12669-SFT09870,Bus identification of sub-bus users-Control head for driving and comfort functions,Local data bus,
MAS12669-SFT09913,Bus identification of sub-bus users-Valve block 1 in front seat driver side,Local data bus 4,
MAS12669-SFT09917,Bus identification of sub-bus users-Valve block 1 in front seat passenger side,Local data bus 4,
MAS12669-SFT09921,Bus identification of sub-bus users-Blower 1 for left front backrest,Local data bus 4,
MAS12669-SFT09923,Bus identification of sub-bus users-Blower 1 for left front seat cushion,Local data bus 4,
MAS12669-SFT09925,Bus identification of sub-bus users-Blower 1 for right front backrest,Local data bus 4,
MAS12669-SFT09927,Bus identification of sub-bus users-Blower 1 for right front seat cushion,Local data bus 4,
MAS12669-SFT09963,Bus identification of sub-bus users-Antenna for short-range communication,Data bus subCAN 1,
MAS12669-SFT09977,Bus identification of sub-bus users-Control unit 2 for driving and convenience functions,Local data bus 11,
MAS12669-SFT09995,Bus identification of sub-bus users-Antenna 2 for short-range communication,Data bus subCAN 1,
MAS12669-SFT09998,Bus identification of sub-bus users-left tail lamp 2,Local data bus 8,
MAS12669-SFT09999,Bus identification of sub-bus users-Right rear tail lamp 1,Local data bus 8,
MAS12669-SFT10000,Bus identification of sub-bus users-Right rear tail lamp 2,Local data bus 8,
MAS12669-SFT10077,Bus identification of sub-bus users-Radio receiver for remote start,Local data bus 6,
MAS12669-SFT10094,Bus identification of sub-bus users-Wiper motor control unit 2,Local data bus,
MAS12669-SFT10128,Bus identification of sub-bus users-Virtual pedal door opening: rear driver side,Local data bus 4,
MAS12669-SFT10142,Bus identification of sub-bus users-Virtual pedal door opening: rear passenger side,Local data bus 4,
MAS13141,Test voltage,0.00, V
MAS17268,Functions which can be activated: connection error counter,0,
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,available.,
MAS17521-IDE05814,Unlockable functions: activation status-Individualization characteristic,invalid,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 02 0E 00,
MAS17521-MAS01340,Unlockable functions: activation status-Functions,available.,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,OK,
MAS17521-MAS02934,Unlockable functions: activation status-Preconditions met,Condition not met,
MAS17521-MAS05616,Unlockable functions: activation status-Cancellation,No,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,3,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
MAS18843,SE references from last used digital key devices,|Secure_element_reference_state,Secure_element_reference
MAS18919-MAS17454,Engine hood contacts-Engine hood contact 2,active,
MAS18919-MAS18918,Engine hood contacts-Engine hood contact 1,active,
MAS25323,Ambient lighting: error locations,not installed,
ENG15455-MAS18508,ASIL_relevante_RDIDs-Number of nodes,41,
ENG15455,ASIL_relevante_RDIDs,|Adapted values/adaptation,Status of adaptation|0A 72
ENG117285-ENG115840,Cycle_Protection_Counter-general_cycle_protection_counter,1,
ENG117285-ENG124947,Cycle_Protection_Counter-last_wake_up,PIN A16_A17 Komfort CAN,
ENG01585,Dataset_download_written_rdids,|Data set ID,Number
ENG24420,Easy_open_HBFS_unavailable_reason,Sensor-controlled tailgate opening: not coded,
ENG24421,Easy_open_HFS_unavailable_reason,Sensor-controlled tailgate opening: not coded,
ENG116908-ENG115779,Ecu_Intern_Meas._Values_2-Betriebsstunden_Abblendlicht_an,20, H
ENG116908-ENG115778,Ecu_Intern_Meas._Values_2-Hours_of_operation,31, H
ENG116908-ENG115775,Ecu_Intern_Meas._Values_2-Hours_of_operation_front_window_wiper,2.0004, H
ENG116908-ENG115776,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_front_window_wiper,2100,
ENG116908-ENG115777,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_rear_window_wiper,12931,
ENG116813,Entwicklermesswerte_CONTI,|KurzSchlussZaehler|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|,
ENG48509-ENG49940,FoD_slave_operating_state-FoD_slave_state,02,
ENG48830-MAS17839,Function_On_Demand_Freischalt_ID_Status_Dev-Number of functions which can be activated,3,
ENG48830-MAS17983,Function_On_Demand_Freischalt_ID_Status_Dev-Last state,not active,
ENG48830,Function_On_Demand_Freischalt_ID_Status_Dev,|ID number,Authentication
ENG24472,Last_LIN_Message_BCM_VIP_HBFS,00 00 00 00 00 00 00 00,
ENG24473,Last_LIN_Message_BCM_VIP_HFS,00 00 00 00 00 00 00 00,
ENG121906,Last_LIN_Message_Kessy,00 00 00 00 00 00 00 00,
ENG121907,Last_LIN_Message_LIN,00 00 00 00 00 00 00 00,
ENG24474,Last_LIN_Message_VIP_HBFS,00 00 00 00 00 00 00 00,
ENG24475,Last_LIN_Message_VIP_HFS,00 00 00 00 00 00 00 00,
ENG116909-ENG107391,LIN activity-LIN 1,Communication,
ENG116909-ENG124951,LIN activity-LIN 10,Communication,
ENG116909-ENG124952,LIN activity-LIN 11,not coded/not installed,
ENG116909-ENG124953,LIN activity-LIN 12,not coded/not installed,
ENG116909-ENG124954,LIN activity-LIN 13,not coded/not installed,
ENG116909-ENG124955,LIN activity-LIN 14,not coded/not installed,
ENG116909-ENG107392,LIN activity-LIN 2,not coded/not installed,
ENG116909-ENG114948,LIN activity-LIN 3,Communication,
ENG116909-ENG114949,LIN activity-LIN 4,Communication,
ENG116909-ENG114950,LIN activity-LIN 5,Communication,
ENG116909-ENG114951,LIN activity-LIN 6,Communication,
ENG116909-ENG124958,LIN activity-LIN 7,not coded/not installed,
ENG116909-ENG124959,LIN activity-LIN 8,not coded/not installed,
ENG116909-ENG124960,LIN activity-LIN 9,Communication,
ENG122922-ENG121684,misc_wiper_values_1-wiper_counter_block,0,
ENG122922-ENG121680,misc_wiper_values_1-wiper_counter_cycles,2100,
ENG122922-ENG121681,misc_wiper_values_1-wiper_counter_operating_h,68.8471, H
ENG122922-ENG121682,misc_wiper_values_1-wiper_errors,00000000 00000000 ,
ENG122922-ENG121683,misc_wiper_values_1-wiper_speed_real,40, /min
ENG122924-ENG115787,misc_wiper_values_2-wiper_angle,655.27, °
ENG122924-ENG115788,misc_wiper_values_2-wiper_angle_corr_OWL,655.27, °
ENG122924-ENG115789,misc_wiper_values_2-wiper_angle_corr_UWL,655.27, °
ENG122924-ENG115790,misc_wiper_values_2-wiper_power_supply_Ubat,13.42, V
ENG123723,Personalized_Signals_2_0,|Current profile slot number for customization,Customization control command
ENG116792,Power up history,|Funktionsanforderung|0|0|0|0|0|0|0|0|0|0|,
ENG116803-ENG115714,RLS_Incidence_Counter-counter_asic,0,
ENG116803-ENG115715,RLS_Incidence_Counter-counter_cpu,0,
ENG116803-ENG115718,RLS_Incidence_Counter-counter_dew,0,
ENG116803-ENG115719,RLS_Incidence_Counter-counter_dew_com,0,
ENG116803-ENG115717,RLS_Incidence_Counter-counter_hum,0,
ENG116803-ENG115709,RLS_Incidence_Counter-counter_light,0,
ENG116803-ENG115711,RLS_Incidence_Counter-counter_memory,0,
ENG116803-ENG115710,RLS_Incidence_Counter-counter_program_sequence,0,
ENG116803-ENG115708,RLS_Incidence_Counter-counter_rain,0,
ENG116803-ENG115716,RLS_Incidence_Counter-counter_temp,0,
ENG116803-ENG115712,RLS_Incidence_Counter-counter_voltage_supply,0,
ENG116803-ENG115713,RLS_Incidence_Counter-counter_wdg,0,
ENG116789-ENG115644,RLS_Rain_Sensor_Off_Justage-Achsenabschnitt,19, s
ENG116789-ENG98937,RLS_Rain_Sensor_Off_Justage-Incline,-0.06, km/(hs)
ENG116789-ENG115643,RLS_Rain_Sensor_Off_Justage-Intervallpause,24, s
ENG122923-ENG115672,shadow_error_table-wiper_error_1_code,31,
ENG122923-ENG115673,shadow_error_table-wiper_error_1_count,8,
ENG122923-ENG115677,shadow_error_table-wiper_error_1_data_ec4,80,
ENG122923-ENG115678,shadow_error_table-wiper_error_1_data_ec5,255,
ENG122923-ENG115676,shadow_error_table-wiper_error_1_power_supply,12.7, V
ENG122923-ENG115675,shadow_error_table-wiper_error_1_temp,0, °C
ENG122923-ENG115674,shadow_error_table-wiper_error_1_timestamp,66.1402, min
ENG122923-ENG125592,shadow_error_table-wiper_error_10_code,0,
ENG122923-ENG125593,shadow_error_table-wiper_error_10_count,0,
ENG122923-ENG125594,shadow_error_table-wiper_error_10_data_ec4,0,
ENG122923-ENG125595,shadow_error_table-wiper_error_10_data_ec5,0,
ENG122923-ENG125596,shadow_error_table-wiper_error_10_power_supply,0.0, V
ENG122923-ENG125597,shadow_error_table-wiper_error_10_temp,0, °C
ENG122923-ENG125599,shadow_error_table-wiper_error_10_timestamp,0.0000, min
ENG122923-ENG115679,shadow_error_table-wiper_error_2_code,37,
ENG122923-ENG115680,shadow_error_table-wiper_error_2_count,15,
ENG122923-ENG115684,shadow_error_table-wiper_error_2_data_ec4,80,
ENG122923-ENG115685,shadow_error_table-wiper_error_2_data_ec5,15,
ENG122923-ENG115683,shadow_error_table-wiper_error_2_power_supply,12.6, V
ENG122923-ENG115682,shadow_error_table-wiper_error_2_temp,18, °C
ENG122923-ENG115681,shadow_error_table-wiper_error_2_timestamp,63.1414, min
ENG122923-ENG115686,shadow_error_table-wiper_error_3_code,27,
ENG122923-ENG115687,shadow_error_table-wiper_error_3_count,6,
ENG122923-ENG115691,shadow_error_table-wiper_error_3_data_ec4,11,
ENG122923-ENG115692,shadow_error_table-wiper_error_3_data_ec5,120,
ENG122923-ENG115690,shadow_error_table-wiper_error_3_power_supply,14.9, V
ENG122923-ENG115689,shadow_error_table-wiper_error_3_temp,9, °C
ENG122923-ENG115688,shadow_error_table-wiper_error_3_timestamp,38.6512, min
ENG122923-ENG115693,shadow_error_table-wiper_error_4_code,36,
ENG122923-ENG115694,shadow_error_table-wiper_error_4_count,1,
ENG122923-ENG115698,shadow_error_table-wiper_error_4_data_ec4,192,
ENG122923-ENG115699,shadow_error_table-wiper_error_4_data_ec5,255,
ENG122923-ENG115697,shadow_error_table-wiper_error_4_power_supply,12.7, V
ENG122923-ENG115695,shadow_error_table-wiper_error_4_temp,-6, °C
ENG122923-ENG115696,shadow_error_table-wiper_error_4_timestamp,36.3188, min
ENG122923-ENG115700,shadow_error_table-wiper_error_5_code,52,
ENG122923-ENG115701,shadow_error_table-wiper_error_5_count,1,
ENG122923-ENG115705,shadow_error_table-wiper_error_5_data_ec4,16,
ENG122923-ENG115706,shadow_error_table-wiper_error_5_data_ec5,0,
ENG122923-ENG115704,shadow_error_table-wiper_error_5_power_supply,12.8, V
ENG122923-ENG115703,shadow_error_table-wiper_error_5_temp,11, °C
ENG122923-ENG115702,shadow_error_table-wiper_error_5_timestamp,21.1582, min
ENG122923-ENG125604,shadow_error_table-wiper_error_6_code,29,
ENG122923-ENG125605,shadow_error_table-wiper_error_6_count,1,
ENG122923-ENG125606,shadow_error_table-wiper_error_6_data_ec4,192,
ENG122923-ENG125607,shadow_error_table-wiper_error_6_data_ec5,5,
ENG122923-ENG125608,shadow_error_table-wiper_error_6_power_supply,9.1, V
ENG122923-ENG125609,shadow_error_table-wiper_error_6_temp,-1, °C
ENG122923-ENG125611,shadow_error_table-wiper_error_6_timestamp,2.4990, min
ENG122923-ENG125612,shadow_error_table-wiper_error_7_code,34,
ENG122923-ENG125613,shadow_error_table-wiper_error_7_count,2,
ENG122923-ENG125614,shadow_error_table-wiper_error_7_data_ec4,64,
ENG122923-ENG125615,shadow_error_table-wiper_error_7_data_ec5,12,
ENG122923-ENG125616,shadow_error_table-wiper_error_7_power_supply,14.7, V
ENG122923-ENG125617,shadow_error_table-wiper_error_7_temp,18, °C
ENG122923-ENG125619,shadow_error_table-wiper_error_7_timestamp,0.8330, min
ENG122923-ENG125620,shadow_error_table-wiper_error_8_code,51,
ENG122923-ENG125621,shadow_error_table-wiper_error_8_count,11,
ENG122923-ENG125622,shadow_error_table-wiper_error_8_data_ec4,254,
ENG122923-ENG125623,shadow_error_table-wiper_error_8_data_ec5,0,
ENG122923-ENG125624,shadow_error_table-wiper_error_8_power_supply,12.4, V
ENG122923-ENG125625,shadow_error_table-wiper_error_8_temp,18, °C
ENG122923-ENG125627,shadow_error_table-wiper_error_8_timestamp,0.3332, min
ENG122923-ENG125628,shadow_error_table-wiper_error_9_code,50,
ENG122923-ENG125629,shadow_error_table-wiper_error_9_count,1,
ENG122923-ENG125630,shadow_error_table-wiper_error_9_data_ec4,65,
ENG122923-ENG125631,shadow_error_table-wiper_error_9_data_ec5,1,
ENG122923-ENG125632,shadow_error_table-wiper_error_9_power_supply,14.2, V
ENG122923-ENG125633,shadow_error_table-wiper_error_9_temp,9, °C
ENG122923-ENG125635,shadow_error_table-wiper_error_9_timestamp,0.0000, min
ENG123744,Snapshot_DTC_Notlaufpfad,No malfunction,
ENG119226-IDE00104,Specific_ambient_conditions-DTC,00 00 00,
ENG119226-IDE07836,Specific_ambient_conditions-Log data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG123753,steuergeraetinterne_Messwert,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116790-MAS00711,Supply voltage history-Odometer reading,2224, km
ENG116790-ENG115814,Supply voltage history-highest voltage ever measured,15.8, V
ENG116790-ENG115815,Supply voltage history-hoechste im letzten Fahrzyklus gemessen Batteriespannung,14.8, V
ENG116790-ENG115816,Supply voltage history-voltage measurement: intern,13.4, V
ENG122921-ENG121628,values_motorloads-mod_temp_fast,27, °C
ENG122921-ENG121627,values_motorloads-mod_temp_slow,30, °C
ENG122921-ENG121629,values_motorloads-temp_pcb,27, °C
ENG122921-ENG121631,values_motorloads-wiper_energymodel_load,0,
ENG122921-ENG121632,values_motorloads-wiper_energymodel_status,0,
ENG122921-ENG121633,values_motorloads-wiper_power_supply_PWM,0, %
ENG122921-ENG121630,values_motorloads-wiper_thermomodel_status,0,
ENG123782-ENG30408,Wischer_Flash_Historie-Betriebsstundenzaehler_1,0.000000, s
ENG123782-ENG30409,Wischer_Flash_Historie-Betriebsstundenzaehler_2,0.000000, s
ENG123782-ENG30410,Wischer_Flash_Historie-Betriebsstundenzaehler_3,0.000000, s
ENG123782-ENG30411,Wischer_Flash_Historie-Betriebsstundenzaehler_4,0.000000, s
ENG123782-ENG30412,Wischer_Flash_Historie-Betriebsstundenzaehler_5,0.000000, s
ENG123782-ENG31587,Wischer_Flash_Historie-geflashte_SW_Version_2,0,
ENG123782-ENG31588,Wischer_Flash_Historie-geflashte_SW_Version_3,0,
ENG123782-ENG31589,Wischer_Flash_Historie-geflashte_SW_Version_4,0,
ENG123782-ENG31590,Wischer_Flash_Historie-geflashte_SW_Version_5,0,
ENG123782-ENG31591,Wischer_Flash_Historie-geflashte_SW_Version1,0,
ENG123782-ENG32338,Wischer_Flash_Historie-Programmierdatum_1_Jahr,0,
ENG123782-ENG32339,Wischer_Flash_Historie-Programmierdatum_1_Monat,0,
ENG123782-ENG32340,Wischer_Flash_Historie-Programmierdatum_1_Tag,0,
ENG123782-ENG32341,Wischer_Flash_Historie-Programmierdatum_2_Jahr,0,
ENG123782-ENG32342,Wischer_Flash_Historie-Programmierdatum_2_Monat,0,
ENG123782-ENG32343,Wischer_Flash_Historie-Programmierdatum_2_Tag,0,
ENG123782-ENG32344,Wischer_Flash_Historie-Programmierdatum_3_Jahr,0,
ENG123782-ENG32345,Wischer_Flash_Historie-Programmierdatum_3_Monat,0,
ENG123782-ENG32346,Wischer_Flash_Historie-Programmierdatum_3_Tag,0,
ENG123782-ENG32347,Wischer_Flash_Historie-Programmierdatum_4_Jahr,0,
ENG123782-ENG32348,Wischer_Flash_Historie-Programmierdatum_4_Monat,0,
ENG123782-ENG32349,Wischer_Flash_Historie-Programmierdatum_4_Tag,0,
ENG123782-ENG32350,Wischer_Flash_Historie-Programmierdatum_5_Jahr,0,
ENG123782-ENG32351,Wischer_Flash_Historie-Programmierdatum_5_Monat,0,
ENG123782-ENG32352,Wischer_Flash_Historie-Programmierdatum_5_Tag,0,
ENG123782-ENG33133,Wischer_Flash_Historie-Tester_Seriennummer_1,00 00 00 00 00 00,
ENG123782-ENG33134,Wischer_Flash_Historie-Tester_Seriennummer_2,00 00 00 00 00 00,
ENG123782-ENG33135,Wischer_Flash_Historie-Tester_Seriennummer_3,00 00 00 00 00 00,
ENG123782-ENG33136,Wischer_Flash_Historie-Tester_Seriennummer_4,00 00 00 00 00 00,
ENG123782-ENG33137,Wischer_Flash_Historie-Tester_Seriennummer_5,00 00 00 00 00 00,
ENG123782-ENG33359,Wischer_Flash_Historie-Wischzyklenzaehler_1,0,
ENG123782-ENG33360,Wischer_Flash_Historie-Wischzyklenzaehler_2,0,
ENG123782-ENG33361,Wischer_Flash_Historie-Wischzyklenzaehler_3,0,
ENG123782-ENG33362,Wischer_Flash_Historie-Wischzyklenzaehler_4,0,
ENG123782-ENG33363,Wischer_Flash_Historie-Wischzyklenzaehler_5,0,
ENG02679-ENG124960,Wischermesswerte 1-aktuelle Schwelle (kalt oder warm),0,
ENG02679-ENG30347,Wischermesswerte 1-Anzahl Wischzyklen(aktueller Wert),2131,
ENG02679-ENG98439,Wischermesswerte 1-Battery voltage,13.4564, V
ENG02679-ENG124957,Wischermesswerte 1-Energiemodell Daten 1 gerechneter Wert,0,
ENG02679-ENG124958,Wischermesswerte 1-Energiemodell Daten 2 gerechneter Wert,0,
ENG02679-ENG124959,Wischermesswerte 1-Energiemodell Daten 3 gerechneter Wert,0,
ENG02679-ENG98786,Wischermesswerte 1-Engine angle,6553.5, °
ENG02679-ENG124964,Wischermesswerte 1-Motor PWM,0.000, %
ENG02679-ENG115795,Wischermesswerte 1-Operating Hours,247916.824, s
ENG02679-ENG115650,Wischermesswerte 1-PCB-Temperatur,59650.030, °C
ENG02679-ENG124961,Wischermesswerte 1-Schwellwert 'kalt',1348101225,
ENG02679-ENG124962,Wischermesswerte 1-Schwellwert 'warm',1687603450,
ENG02679-ENG16634,Wischermesswerte 1-Schwellwert zum loeschen,200,
ENG02679-ENG99062,Wischermesswerte 1-Wipe speed,0.00, /min
ENG02680-ENG124978,Wischermesswerte 2-aktuelle obere Wendelage,6553.5, °
ENG02680-ENG124973,Wischermesswerte 2-aktueller Wischwinkel des Wischerarmes Beifahrerseite,0.6210, °
ENG02680-ENG124972,Wischermesswerte 2-aktueller Wischwinkel des Wischerarmes Fahrerseite,0.5260, °
ENG02680-ENG124220,Wischermesswerte 2-aktueller_Motor_kurbelwinkel,6553.5, °
ENG02680-ENG124984,Wischermesswerte 2-Anstehende Wischmodus,31,
ENG02680-ENG124981,Wischermesswerte 2-Arbeitswinkel der Motorabtriebswelle bei Fehlereintritt,0.0, °
ENG02680-ENG16636,Wischermesswerte 2-Blockzaehler (Ueberlast),0,
ENG02680-ENG16637,Wischermesswerte 2-Fehlerzustaende (Errorstate),0,
ENG02680-ENG124982,Wischermesswerte 2-Funktion bei Fehlereintritt 1,0,
ENG02680-ENG124983,Wischermesswerte 2-Funktion bei Fehlereintritt 2,0,
ENG02680-ENG124976,Wischermesswerte 2-Ist-Wischgeschwindigkeit,0, /min
ENG02680-ENG124985,Wischermesswerte 2-Master-Botschaft,00 00 00 00 00 00 00 00,
ENG02680-ENG121977,Wischermesswerte 2-No. of wisher cycles,0,
ENG02680-ENG98396,Wischermesswerte 2-Operating time,238243.508, s
ENG02680-ENG124970,Wischermesswerte 2-OWL Obere Wendelage,163.7, °
ENG02680-ENG124986,Wischermesswerte 2-RLS-Botschaft,00 00 00 00 00 00 00 00,
ENG02680-ENG124975,Wischermesswerte 2-Soll-Wischgeschwindigkeit,0, /min
ENG02680-ENG99020,Wischermesswerte 2-Supply voltage,12.6998, V
ENG02680-ENG98969,Wischermesswerte 2-Temperature,0.044, °C
ENG02680-ENG124971,Wischermesswerte 2-UWL Untere Wendelage,24.0, °
ENG02671-ENG125002,Wischermesswerte 3-Chip number,00 00 00 00 00 00 00 00,
ENG02671-ENG124459,Wischermesswerte 3-Chip number Infineon,E7 E2 EF 7D 74 38 61 06 1F AF F3 FE,
ENG02671-ENG125000,Wischermesswerte 3-EOL number,30,
ENG02671-ENG125001,Wischermesswerte 3-Error state,0,
ENG02671-ENG124999,Wischermesswerte 3-ICT (NG) measurement value,0,
ENG02671-ENG124998,Wischermesswerte 3-ICT (OK) measurement value,0,
ENG02671-ENG98897,Wischermesswerte 3-Serial number,39 30 37 34 35 33 46 30 33 30 32 31 31 39 30 30 37 32 33 38,
ENG123784-ENG124281,WWS Historie-Anzahl Wischzyklen max MCU Temperatur,8,
ENG123784-ENG124282,WWS Historie-Anzahl Wischzyklen max. LIN Temperatur,1122,
ENG123784-ENG124284,WWS Historie-Anzahl Wischzyklen max. UBatt,47,
ENG123784-ENG01635,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_0,34,
ENG123784-ENG01636,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_1,1877,
ENG123784-ENG01637,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_2,68,
ENG123784-ENG01638,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_3,27,
ENG123784-ENG01639,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_4,45,
ENG123784-ENG01640,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_5,55,
ENG123784-ENG01641,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_6,3,
ENG123784-ENG01642,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_7,22,
ENG123784-ENG124321,WWS Historie-Betriebsstunden max MCU Temperatur,46.090044, s
ENG123784-ENG124322,WWS Historie-Betriebsstunden max. LIN Temperatur,1640.439785, s
ENG123784-ENG124324,WWS Historie-Betriebsstunden max. UBatt,128.477348, s
ENG123784-ENG27563,WWS Historie-extern_Temp,0, °C
ENG123784-ENG124740,WWS Historie-Kl_15_Zyklenzaehler,209,
ENG123784-ENG124741,WWS Historie-Kl_X_Zyklenzaehler,244,
ENG123784-ENG27578,WWS Historie-LIN_Signal_max_Exterior_Temp,-110, °C
ENG123784-ENG27560,WWS Historie-max_Intern_Temp,97, °C
ENG123784-ENG124974,WWS Historie-max_power_supply,15.5, V
ENG123784-ENG125248,WWS Historie-Sleep_Counter,0,
ENG123784-ENG125568,WWS Historie-Wakeup_Counter,476,
Elapsed Time: 01:27,,,
;SW:5WA-919-298-B HW:5WA-919-298 --- Park/Steer Assist
;Component:PLA 12 Kanal H05 0578, Coding:0200026001
;EV_EPHBO2CVW3800000,002028,EV_EPHBO2CVW3800000_VW38.rod
;Thursday,17,March,2022,11:46:58:62242
;VCDS Version: Release 22.3.0 Data version: 20220225 DS336.1
;VCID: 55F78F1DB58E6483CC4-8000
Group,Description,Actual,
IDE00018,Voltage terminal 15,13.2, V
IDE00957-MAS01632,Resulting distance of front sensors-Status,infinite,
IDE00958-MAS01632,Resulting distance of rear sensors-Status,34, cm
IDE00973,Outside temperature,23.00, °
IDE00974,Outside air temperature internally calculated,18.00, °
IDE01123-MAS01632,Distance of left rear park assist sensor-Status,infinite,
IDE01124-MAS01632,Distance of left rear center park assist sensors-Status,34, cm
IDE01125-MAS01632,Distance of right rear center park assist sensors-Status,35, cm
IDE01126-MAS01632,Distance of right rear park assist sensor-Status,infinite,
IDE01127-MAS01632,Distance sensor for left front park assist-Status,infinite,
IDE01128-MAS01632,Distance sensor for left front center park assist-Status,infinite,
IDE01129-MAS01632,Distance sensor for right front center park assist-Status,infinite,
IDE01130-MAS01632,Distance of right front park assist sensors-Status,infinite,
IDE01131-MAS01632,Oscillating time of left rear park assist sensors-Status,0.512, ms
IDE01132-MAS01632,Oscillating time of left rear center park assist sensors-Status,0.512, ms
IDE01133-MAS01632,Oscillating time of right rear center park assist sensors-Status,Malfunction,
IDE01134-MAS01632,Oscillating time of right rear park assist sensors-Status,0.512, ms
IDE01135-MAS01632,Decay time for left front park assist sensor-Status,0.512, ms
IDE01136-MAS01632,Decay time for left front center park assist sensor-Status,0.512, ms
IDE01137-MAS01632,Decay time for right front center park assist sensors-Status,0.512, ms
IDE01138-MAS01632,Decay time for right front park assist sensors-Status,Malfunction,
IDE01165,Park assist activation tone,OFF,
IDE01166,Supply voltage for park assist sensor,13.2, V
IDE01167,Convertible offset for volume level 1,1,
IDE01169,Audio lowering request,No,
IDE01175-MAS01632,Distance of side left rear parking aid sensors-Status,infinite,
IDE01176-MAS01632,Distance of side right rear parking aid sensors-Status,infinite,
IDE01177-MAS01632,Oscillating time of side left rear parking aid sensors-Status,0.560, ms
IDE01178-MAS01632,Oscillating time of side right rear parking aid sensors-Status,0.512, ms
IDE01185-MAS01632,Distance sensor for left front parking aid-Status,infinite,
IDE01186-MAS01632,Distance sensor for right front parking aid-Status,infinite,
IDE01187-MAS01632,Decay time for side left front parking aid sensor-Status,0.512, ms
IDE01188-MAS01632,Decay time for right side front parking aid sensor-Status,0.560, ms
IDE01588,Driving direction,not detected,
IDE03008-IDE03726,Stop process prevented-Parallel Parking Assistance,passive,
IDE03008-MAS00825,Stop process prevented-Parking Aid Control Module,active,
IDE03010-IDE03726,Number of prevented stop processes-Parallel Parking Assistance,0,
IDE03010-MAS00825,Number of prevented stop processes-Parking Aid Control Module,0,
IDE03011-IDE03726,Number of requested start processes-Parallel Parking Assistance,0,
IDE03011-MAS00825,Number of requested start processes-Parking Aid Control Module,0,
IDE03684,Vehicle stopped,Yes,
IDE06307-MAS00106,Stop prevention history data-Year,2000,
IDE06307-MAS00107,Stop prevention history data-Month,0,
IDE06307-MAS00108,Stop prevention history data-Day,0,
IDE06307-MAS00109,Stop prevention history data-Hours,0,
IDE06307-MAS00110,Stop prevention history data-Minutes,0,
IDE06307-MAS00111,Stop prevention history data-Seconds,0,
IDE06307,Stop prevention history data,not active,
IDE06308-MAS00106,Start request history data-Year,2000,
IDE06308-MAS00107,Start request history data-Month,0,
IDE06308-MAS00108,Start request history data-Day,0,
IDE06308-MAS00109,Start request history data-Hours,0,
IDE06308-MAS00110,Start request history data-Minutes,0,
IDE06308-MAS00111,Start request history data-Seconds,0,
IDE06308,Start request history data,not active,
IDE10300,OBD Driving Cycle detected,active,
IDE10925-MAS00106,ARA discharge reasons (ring memory)-Year,2000,
IDE10925-MAS00107,ARA discharge reasons (ring memory)-Month,0,
IDE10925-MAS00108,ARA discharge reasons (ring memory)-Day,0,
IDE10925-MAS00109,ARA discharge reasons (ring memory)-Hours,0,
IDE10925-MAS00110,ARA discharge reasons (ring memory)-Minutes,0,
IDE10925-MAS00111,ARA discharge reasons (ring memory)-Seconds,0,
IDE10925-MAS09002,ARA discharge reasons (ring memory)-Last reason,Unknown (0),
IDE10925-MAS09003,ARA discharge reasons (ring memory)-second last reasons,Unknown (0),
IDE10925-MAS09004,ARA discharge reasons (ring memory)-third last reason,Unknown (0),
IDE10925-MAS09005,ARA discharge reasons (ring memory)-fourth last reason,Unknown (0),
IDE10925-MAS09006,ARA discharge reasons (ring memory)-fifth last reason,Unknown (0),
IDE11152-MAS12261,Wheel circumferences-Right front wheel circumference,1013, mm
IDE11152-MAS12262,Wheel circumferences-Left front wheel circumference,0, mm
IDE11152-MAS12263,Wheel circumferences-Right rear wheel circumference,409, mm
IDE11152-MAS12264,Wheel circumferences-Left rear wheel circumference,0, mm
IDE12038-IDE00086,Brake requirements (ring buffer)-Accelerator pedal position,0, %/s
IDE12038-IDE02211,Brake requirements (ring buffer)-Brake pressure,0, bar
IDE12038-IDE02211,Brake requirements (ring buffer)-Brake pressure,31, bar
IDE12038-MAS00106,Brake requirements (ring buffer)-Year,2022,
IDE12038-MAS00106,Brake requirements (ring buffer)-Year,2000,
IDE12038-MAS00107,Brake requirements (ring buffer)-Month,0,
IDE12038-MAS00107,Brake requirements (ring buffer)-Month,3,
IDE12038-MAS00108,Brake requirements (ring buffer)-Day,0,
IDE12038-MAS00108,Brake requirements (ring buffer)-Day,15,
IDE12038-MAS00109,Brake requirements (ring buffer)-Hours,8,
IDE12038-MAS00109,Brake requirements (ring buffer)-Hours,0,
IDE12038-MAS00110,Brake requirements (ring buffer)-Minutes,0,
IDE12038-MAS00110,Brake requirements (ring buffer)-Minutes,6,
IDE12038-MAS00111,Brake requirements (ring buffer)-Seconds,0,
IDE12038-MAS00111,Brake requirements (ring buffer)-Seconds,32,
IDE12038-MAS00370,Brake requirements (ring buffer)-Vehicle speed,-20.0, km/h
IDE12038-MAS00370,Brake requirements (ring buffer)-Vehicle speed,-8.0, km/h
IDE12038-MAS11940,Brake requirements (ring buffer)-Brake electronics fault,not active,
IDE12038-MAS13914,Brake requirements (ring buffer)-Object horizontal position,0.0, m
IDE12038-MAS13914,Brake requirements (ring buffer)-Object horizontal position,-5.0, m
IDE12038-MAS13915,Brake requirements (ring buffer)-Object vertical position,-5.0, m
IDE12038-MAS13915,Brake requirements (ring buffer)-Object vertical position,0.0, m
MAS10122,ARA operating condition,Unknown (0),
MAS10122-MAS11700,ARA operating condition-ARA function request door control module,no request,
Elapsed Time: 00:06,,,
;SW:5WA-907-572-B HW:5WA-907-572 --- Auto Dist. Reg
;Component:ACC Bosch MQB H20 0395, Coding:06230096500680451247400000004004AE4020000000000000000000000000
;EV_FRONTRADARBOSCHVW380,004017,EV_FRONTRADARBOSCHVW380_004_VW38.rod
;Thursday,17,March,2022,11:47:11:62242
;VCID: 4DC7677D9D5E2C43744-8018
IDE00002,Transport mode,OFF,
IDE00102,Control Module temperature,68, °C
IDE00310,Outside temperature,24.0, °C
IDE00391,Adaptive distance regulation: status,ACC_StandBy,
IDE00924,Steering angle,0.000, °
IDE00925,Yaw rate,0.000, rad/s
IDE01268-MAS02506,Windshield wiper-Wiper active,not active,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,23 0A 4F 8F,
IDE02057-MAS02356,Dynamic calibration: status-Type of calibration,static,
IDE02057-MAS05634,Dynamic calibration: status-Progress,0, %
IDE02057-ENG17155,Dynamic calibration: status-Absolute_driving_distance,0, m
IDE02057-ENG17159,Dynamic calibration: status-Acceleration_out_of_range,Framework conditions currently not met,
IDE02057-ENG98465,Dynamic calibration: status-Calibration status,not started,
IDE02057-ENG17252,Dynamic calibration: status-Effective_driving_distance,0, m
IDE02057-ENG17266,Dynamic calibration: status-Fault_signal_active,Framework conditions currently not met,
IDE02057-ENG17267,Dynamic calibration: status-Few_locations,Framework conditions currently not met,
IDE02057-ENG17389,Dynamic calibration: status-Speed_out_of_range,Framework conditions currently not met,
IDE02057-ENG17428,Dynamic calibration: status-Yaw_rate_out_of_range,Framework conditions currently not met,
IDE02068-MAS00106,Time stamp-Year,2022,
IDE02068-MAS00107,Time stamp-Month,3,
IDE02068-MAS00108,Time stamp-Day,17,
IDE02068-MAS00109,Time stamp-Hours,11,
IDE02068-MAS00110,Time stamp-Minutes,47,
IDE02068-MAS00111,Time stamp-Seconds,11,
IDE03010-MAS12557,Number of prevented stop processes-Vehicle ahead starts driving: ACC active: automatic drive-off disabled,0,
IDE03010-MAS12559,Number of prevented stop processes-Vehicle ahead starts driving: ACC passive,0,
IDE03010-MAS12560,Number of prevented stop processes-Vehicle ahead starts driving: ACC off,0,
IDE03010-MAS16236,Number of prevented stop processes-Vehicle ahead approaching: ECC not coded,0,
IDE03011-MAS12557,Number of requested start processes-Vehicle ahead starts driving: ACC active: automatic drive-off disabled,0,
IDE03011-MAS12558,Number of requested start processes-Vehicle ahead starts driving: ACC active: automatic drive-off possible,0,
IDE03011-MAS12559,Number of requested start processes-Vehicle ahead starts driving: ACC passive,0,
IDE03011-MAS12560,Number of requested start processes-Vehicle ahead starts driving: ACC off,0,
IDE03011-MAS16236,Number of requested start processes-Vehicle ahead approaching: ECC not coded,0,
IDE03660,Longitudinal acceleration,0.00, m/s²
IDE04805-IDE02955,Driving profile selection-System status,Initialization,
IDE04805-MAS01447,Driving profile selection-Act.val.,4,
IDE04805-MAS01448,Driving profile selection-Target value,2,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,04,
IDE07145-MAS06785,Component protection properties-GFA key,Not Used,
IDE08343,Immobilizer Challenge,BA 09 D9 39,
IDE08936,Misalignment angle: horiz,0.010, °
IDE09906,Vertical deadjustment,0.701, °
IDE10902-IDE00018,Expanded ambient data 1-Voltage terminal 15,13.1, V
IDE10902-IDE00102,Expanded ambient data 1-Control Module temperature,68, °C
IDE10902-IDE00310,Expanded ambient data 1-Outside temperature,24.0, °C
IDE10902-IDE03660,Expanded ambient data 1-Longitudinal acceleration,0.00, m/s²
IDE10902-MAS00370,Expanded ambient data 1-Vehicle speed,0.00, m/s
IDE10902-MAS01632,Expanded ambient data 1-Status,ACC_StandBy,
IDE10903-IDE00924,Expanded ambient data 2-Steering angle,0.000, °
IDE10903-IDE00925,Expanded ambient data 2-Yaw rate,0.001, rad/s
IDE10903-IDE01268,Expanded ambient data 2-Windshield wiper,not active,
IDE10903-IDE08936,Expanded ambient data 2-Misalignment angle: horiz,0.010, °
IDE10903-IDE09906,Expanded ambient data 2-Vertical deadjustment,0.701, °
IDE10903-MAS00106,Expanded ambient data 2-Year,2022,
IDE10903-MAS00107,Expanded ambient data 2-Month,3,
IDE10903-MAS00108,Expanded ambient data 2-Day,17,
IDE10903-MAS00109,Expanded ambient data 2-Hours,11,
IDE10903-MAS00110,Expanded ambient data 2-Minutes,47,
IDE10903-MAS00111,Expanded ambient data 2-Seconds,14,
IDE10903-MAS00711,Expanded ambient data 2-Odometer reading,3969, km
IDE10903-MAS13429,Expanded ambient data 2-Horizontal correction angle: currently,0.000, °
IDE10903-MAS13430,Expanded ambient data 2-Vertical correction angle: currently,0.410, °
IDE10903-ENG124399,Expanded ambient data 2-Blindness_combined,0, %
IDE10903-ENG124404,Expanded ambient data 2-Blindness_indicator_1,0, %
IDE10903-ENG124405,Expanded ambient data 2-Blindness_indicator_2,100, %
IDE10903-ENG124406,Expanded ambient data 2-Blindness_indicator_3,0, %
IDE10903-ENG124407,Expanded ambient data 2-Blindness_indicator_4,100, %
IDE10903-ENG124408,Expanded ambient data 2-Blindness_indicator_5,0, %
IDE10903-ENG124409,Expanded ambient data 2-Blindness_indicator_6,0, %
IDE10903-ENG124556,Expanded ambient data 2-Distance_index,0.00, m
IDE10903-ENG125239,Expanded ambient data 2-Sensor_FRKL,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|2|2|2|2|2|2|2|2|2|2|,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|02 7D FA 00 57 00|02 7D FA 00 57 00|02 7D FA 00 57 00|02 7D FA 00 57 00|02 7D FA 00 57 00|,
IDE11924-MAS13429,Correction angle-Horizontal correction angle: currently,0.000, °
IDE11924-MAS13430,Correction angle-Vertical correction angle: currently,0.410, °
IDE12062,Counter for terminal 15 reset,209,
IDE12238,I network: discarded messages counter,0,
IDE13845,Production mode status,not active,
IDE14997,Number of events: sensor blind,0,
IDE14998,Number of events: misalignment,0,
IDE15000-IDE08936,History data sensor calibration-Misalignment angle: horiz,-0.200, °
IDE15000-IDE09906,History data sensor calibration-Vertical deadjustment,1.000, °
IDE15000-IDE14999,History data sensor calibration-Duration of calibration,0.20, s
IDE15000-IDE15022,History data sensor calibration-Result of calibration,OK,
IDE15000-MAS00106,History data sensor calibration-Year,2021,
IDE15000-MAS00107,History data sensor calibration-Month,11,
IDE15000-MAS00108,History data sensor calibration-Day,12,
IDE15000-MAS00109,History data sensor calibration-Hours,0,
IDE15000-MAS00110,History data sensor calibration-Minutes,36,
IDE15000-MAS00111,History data sensor calibration-Seconds,56,
IDE15000-MAS00711,History data sensor calibration-Odometer reading,0, km
IDE15000-MAS02356,History data sensor calibration-Type of calibration,static,
IDE15000-MAS13429,History data sensor calibration-Horizontal correction angle: currently,-0.190, °
IDE15000-MAS13430,History data sensor calibration-Vertical correction angle: currently,0.990, °
IDE15006,History data sensor 01,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15007,History data sensor 02,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15008,History data sensor 03,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15009,History data sensor 04,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15010,History data sensor 05,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15011,History data sensor 06,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15012,History data sensor 07,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15013,History data sensor 08,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15014,History data sensor 09,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15015,History data sensor 10,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15016,History data sensor 11,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15017,History data sensor 12,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15018,History data sensor 13,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15019,History data sensor 14,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15020,History data sensor 15,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
MAS00370,Vehicle speed,0.00, m/s
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 01 01 00,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,10,
ENG123646-MAS17839,Function_On_Demand_Unlock_ID_Status_Dev-Number of functions which can be activated,0A,
ENG123646-MAS17983,Function_On_Demand_Unlock_ID_Status_Dev-Last state,not active,
ENG123646-ENG36985,Function_On_Demand_Unlock_ID_Status_Dev-FoD_function_state,|ID number,Authentication
ENG08760,Sw_version_supplier,EV_FRONTRADARBOSCHVW38000401700¥Ø=03955WA907572B SysC_VWMQB37w_0395_RC1000,
Elapsed Time: 00:17,,,
;SW:1EA-907-376-B HW:1EA-907-376 --- Susp. Elect.
;Component:DAEMPFUNGS-SG H05 0456, Coding:
;EV_DCC3CONTITEMIC,002006,EV_DCC3CONTITEMIC.rod
;Thursday,17,March,2022,11:47:36:62242
;VCID: 392F23AD39D6A0E3C8C-806C
IDE00019,Voltage terminal 30,13.4160, V
IDE00075,Vehicle speed,0.000, km/h
IDE02955,System status,System OK,
IDE03611-MAS01447,Left front dampening adjustment valve-Act.val.,0.0150, A
IDE03611-MAS01448,Left front dampening adjustment valve-Target value,0.0000, A
IDE03612-MAS01447,Right front dampening adjustment valve-Act.val.,0.0160, A
IDE03612-MAS01448,Right front dampening adjustment valve-Target value,0.0000, A
IDE03613-MAS01447,Left rear dampening adjustment valve-Act.val.,0.0160, A
IDE03613-MAS01448,Left rear dampening adjustment valve-Target value,0.0000, A
IDE03614-MAS01447,Right rear dampening adjustment valve-Act.val.,0.0170, A
IDE03614-MAS01448,Right rear dampening adjustment valve-Target value,0.0000, A
IDE04196,Left front level ctrl sys sensor: limit 1 (deflected),114.93, °
IDE04197,Left front level ctrl sys sensor: limit 2 (deflected),154.97, °
IDE04199,Right front level ctrl sys sensor: limit 1 (deflected),195.98, °
IDE04200,Right front level ctrl sys sensor: limit 2 (deflected),235.93, °
IDE04202,Left rear level ctrl sys sensor: limit 1 (deflected),128.92, °
IDE04203,Left rear level ctrl sys sensor: limit 2 (deflected),168.96, °
IDE04348,Right rear level control system sensor: limit 1 (deflected),360.18, °
IDE04349,Right rear level control system sensor: limit 2 (deflected),360.18, °
IDE04455,Adapted VIN,WVWFB7CD8NW129409,
IDE04805-IDE02955,Driving profile selection-System status,available.,
IDE04805-MAS01447,Driving profile selection-Act.val.,8,
IDE04805-MAS01448,Driving profile selection-Target value,8,
IDE04893-IDE01011,Adapting with deflected wheels-Data record,possible,
IDE04893-MAS01456,Adapting with deflected wheels-Speed,possible,
IDE04893-MAS01853,Adapting with deflected wheels-Left front,invalid value range,
IDE04893-MAS01854,Adapting with deflected wheels-Right front,invalid value range,
IDE04893-MAS01855,Adapting with deflected wheels-Left rear,invalid value range,
IDE04893-MAS01856,Adapting with deflected wheels-Right rear,possible,
IDE04893-MAS02397,Adapting with deflected wheels-Sensor malfunction,possible,
IDE06673,Initialization status,OK,
IDE07146-MAS01853,Dampening adjustment valve: resistance-Left front,255,
IDE07146-MAS01854,Dampening adjustment valve: resistance-Right front,255,
IDE07146-MAS01855,Dampening adjustment valve: resistance-Left rear,255,
IDE07146-MAS01856,Dampening adjustment valve: resistance-Right rear,255,
IDE14336-MAS01853,Vehicle inclination sensor: adaptation value (extended)-Left front,137.28, °
IDE14336-MAS01854,Vehicle inclination sensor: adaptation value (extended)-Right front,216.22, °
IDE14336-MAS01855,Vehicle inclination sensor: adaptation value (extended)-Left rear,146.08, °
IDE14336-MAS01856,Vehicle inclination sensor: adaptation value (extended)-Right rear,360.18, °
IDE14337-MAS01853,Vehicle inclination sensor: rotation angle-Left front,89.41, °
IDE14337-MAS01854,Vehicle inclination sensor: rotation angle-Right front,288.38, °
IDE14337-MAS01855,Vehicle inclination sensor: rotation angle-Left rear,98.56, °
IDE14337-MAS01856,Vehicle inclination sensor: rotation angle-Right rear,360.18, °
IDE14338-MAS01853,Damper path-Left front,87.00, mm
IDE14338-MAS01854,Damper path-Right front,51.25, mm
IDE14338-MAS01855,Damper path-Left rear,85.75, mm
IDE14338-MAS01856,Damper path-Right rear,513.25, mm
IDE14339-MAS01853,Vehicle inclination sensor: rotation speed-Left front,6.00, °/s
IDE14339-MAS01854,Vehicle inclination sensor: rotation speed-Right front,-2.00, °/s
IDE14339-MAS01855,Vehicle inclination sensor: rotation speed-Left rear,3.00, °/s
IDE14339-MAS01856,Vehicle inclination sensor: rotation speed-Right rear,60533.00, °/s
IDE80004-MAS06614,Analysis 4-Variant,0,
IDE80030,Analysis 30,4483,
IDE80030,Analysis 30,0,
IDE80030,Analysis 30,13110,
IDE80030,Analysis 30,4068,
IDE80031,Analysis 31,63 05 59 23 57 50 00 00,
IDE80031,Analysis 31,0,
IDE80031,Analysis 31,1,
IDE80031,Analysis 31,63 05 62 34 35 90 00 00,
IDE80031,Analysis 31,63 05 61 81 55 90 00 00,
IDE80031,Analysis 31,32,
IDE80031,Analysis 31,161,
IDE80031,Analysis 31,6,
IDE80031,Analysis 31,FF FF FF FF FF FF FF FF,
IDE80031,Analysis 31,72,
IDE80031,Analysis 31,5,
IDE80031,Analysis 31,255,
IDE80031,Analysis 31,10994,
IDE80031,Analysis 31,11027,
IDE80031,Analysis 31,11031,
IDE80031,Analysis 31,15,
IDE80031,Analysis 31,65535,
IDE80032,Analysis 32,-4,
IDE80032,Analysis 32,-8,
IDE80032,Analysis 32,0,
IDE80032,Analysis 32,-5,
IDE80033,Analysis 33,2,
IDE80033,Analysis 33,16,
IDE80033,Analysis 33,11046,
IDE80033,Analysis 33,32,
IDE80033,Analysis 33,6,
IDE80033,Analysis 33,00 2C 20 FD 04 12 88 06,
IDE80033,Analysis 33,00 2C 20 FD C0 D4 83 60,
IDE80033,Analysis 33,1,
IDE80033,Analysis 33,00 2C 20 FD C0 D6 8D 72,
IDE80033,Analysis 33,67,
IDE80033,Analysis 33,15,
IDE80033,Analysis 33,11048,
IDE80033,Analysis 33,255,
IDE80033,Analysis 33,FF FF FF FF FF FF FF FF,
IDE80033,Analysis 33,65535,
IDE80034,Analysis 34,-24,
IDE80034,Analysis 34,-35,
IDE80034,Analysis 34,0,
IDE80034,Analysis 34,3,
IDE80035,Analysis 35,63 05 59 23 57 50 00 00,
IDE80035,Analysis 35,6,
IDE80035,Analysis 35,5,
IDE80035,Analysis 35,1,
IDE80035,Analysis 35,32,
IDE80035,Analysis 35,63 05 62 34 35 90 00 00,
IDE80035,Analysis 35,255,
IDE80035,Analysis 35,161,
IDE80035,Analysis 35,FF FF FF FF FF FF FF FF,
IDE80035,Analysis 35,0,
IDE80035,Analysis 35,72,
IDE80035,Analysis 35,11027,
IDE80035,Analysis 35,63 05 61 81 55 90 00 00,
IDE80035,Analysis 35,11031,
IDE80035,Analysis 35,65535,
IDE80035,Analysis 35,10994,
IDE80035,Analysis 35,15,
IDE80037,Analysis 37,0.00, V
IDE80037,Analysis 37,6.31, V
IDE80037,Analysis 37,6.41, V
IDE80037,Analysis 37,17.10, mA
IDE80037,Analysis 37,16.50, mA
IDE80037,Analysis 37,30.00, mA
IDE80040-MAS01447,Analysis 40-Act.val.,5,
IDE80040-MAS01448,Analysis 40-Target value,5,
IDE80041-IDE06916,Analysis 41-Software_ID,12,
IDE80041-MAS06423,Analysis 41-Data set ID,12,
IDE80042-MAS01447,Analysis 42-Act.val.,9,
IDE80042-MAS01448,Analysis 42-Target value,9,
IDE80043-MAS01447,Analysis 43-Act.val.,13,
IDE80043-MAS01448,Analysis 43-Target value,13,
IDE80044-MAS01447,Analysis 44-Act.val.,3,
IDE80044-MAS01448,Analysis 44-Target value,3,
MAS11576-MAS01853,Body acceleration sensor-Left front,-0.262, m/s²
MAS11576-MAS01854,Body acceleration sensor-Right front,-0.164, m/s²
MAS11576-MAS01855,Body acceleration sensor-Left rear,-0.131, m/s²
MAS11576-MAS01856,Body acceleration sensor-Right rear,118.145, m/s²
Elapsed Time: 00:05,,,
;SW:5WA-959-655-M HW:5WA-959-655-M --- Airbags
;Component:AirbagVW40 007 0636, Coding:8CCC000000FCC00000000000000000005100000000000000000036F800130065
;EV_AirbaVW40SMEVW38X,001032,EV_AirbaVW40SMEVW38X.rod
;Thursday,17,March,2022,11:47:49:62242
;VCID: 619FABCDF1C69823A0C-8034
IDE00821-MAS01632,Seat belt switch 2nd row driver's side-Status,not installed,
IDE00821-MAS05030,Seat belt switch 2nd row driver's side-Resistance,no measured value present,
IDE00822-MAS01632,Safety belt switch 2nd row frt.passenger side-Status,not installed,
IDE00822-MAS05030,Safety belt switch 2nd row frt.passenger side-Resistance,no measured value present,
IDE00823-MAS01632,Seat belt switch 2nd row center-Status,not installed,
IDE00823-MAS05030,Seat belt switch 2nd row center-Resistance,no measured value present,
IDE00824-MAS01632,Seat belt switch 3rd row driver's side-Status,not installed,
IDE00824-MAS05030,Seat belt switch 3rd row driver's side-Resistance,no measured value present,
IDE00825-MAS01632,Passenger side 3rd row seat belt switch-Status,not installed,
IDE00825-MAS05030,Passenger side 3rd row seat belt switch-Resistance,no measured value present,
IDE00826-MAS01632,Seat belt switch 3rd row center-Status,not installed,
IDE00826-MAS05030,Seat belt switch 3rd row center-Resistance,no measured value present,
IDE00947-MAS01632,Driver side rear curtain airbag igniter-Status,not installed,
IDE00947-MAS05030,Driver side rear curtain airbag igniter-Resistance,no measured value present,
IDE00948-MAS01632,Frt.passenger side rear curtain airbag igniter-Status,not installed,
IDE00948-MAS05030,Frt.passenger side rear curtain airbag igniter-Resistance,no measured value present,
IDE00956,Occupation status: frt.passenger seat,Adult,
IDE01271,Number of rollover bar deployments,0,
IDE01357-MAS01632,Left pedestrian protection igniter-Status,no measured value present,
IDE01357-MAS05030,Left pedestrian protection igniter-Resistance,no measured value present,
IDE01358-MAS01632,Right pedestrian protection igniter-Status,no measured value present,
IDE01358-MAS05030,Right pedestrian protection igniter-Resistance,no measured value present,
IDE01555,Number of frontal crashes,0,
IDE02852-MAS01632,Battery Interrupt Igniter High-Voltage Battery-Status,not installed,
IDE02852-MAS05030,Battery Interrupt Igniter High-Voltage Battery-Resistance,no measured value present,
IDE03800-MAS01632,Driver airbag release valve igniter-Status,no measured value present,
IDE03800-MAS05030,Driver airbag release valve igniter-Resistance,no measured value present,
IDE03801-MAS01632,Frt.pass. airbag release valve igniter-Status,no measured value present,
IDE03801-MAS05030,Frt.pass. airbag release valve igniter-Resistance,no measured value present,
IDE03870,Seat occupied recognition malfunction status,0,
IDE03870,Seat occupied recognition malfunction status,|,
IDE06034-MAS01632,Rollover protection trigger: driver side-Status,not installed,
IDE06034-MAS05030,Rollover protection trigger: driver side-Resistance,no measured value present,
IDE06035-MAS01632,Rollover protection trigger: front passenger side-Status,not installed,
IDE06035-MAS05030,Rollover protection trigger: front passenger side-Resistance,no measured value present,
IDE06959,Seat occupant detection: diagnosis signal,21.0, %
IDE06960,Seat occupant detection: msmt. signal,9.0, %
IDE06961,Seat occupant detection: ref. signal,1.0, %
IDE07159-MAS05583,Control module switch-off: counter-Data bus,255,
IDE07190-MAS01632,Igniter for battery open circuit 2nd battery-Status,no measured value present,
IDE07190-MAS05030,Igniter for battery open circuit 2nd battery-Resistance,no measured value present,
IDE07192-MAS01632,Thorax airbag igniter-Status,not installed,
IDE07192-MAS05030,Thorax airbag igniter-Resistance,no measured value present,
IDE08436-MAS01632,Driver side seat belt tensioner igniter 3-Status,not installed,
IDE08436-MAS05030,Driver side seat belt tensioner igniter 3-Resistance,no measured value present,
IDE08437-MAS01632,Front passenger side third row seat belt tensioner igniter-Status,not installed,
IDE08437-MAS05030,Front passenger side third row seat belt tensioner igniter-Resistance,no measured value present,
IDE11715-MAS01632,Igniter 2 f. seat belt tensioner: 2nd row: front passenger side-Status,not installed,
IDE11715-MAS05030,Igniter 2 f. seat belt tensioner: 2nd row: front passenger side-Resistance,no measured value present,
IDE11716-MAS01632,Igniter 2 for seat belt tensioner: 2nd row: driver side-Status,not installed,
IDE11716-MAS05030,Igniter 2 for seat belt tensioner: 2nd row: driver side-Resistance,no measured value present,
IDE12056-MAS01632,Igniter for interaction airbag 2nd row: driver side-Status,not installed,
IDE12056-MAS05030,Igniter for interaction airbag 2nd row: driver side-Resistance,no measured value present,
IDE12057-MAS01632,Igniter for interaction airbag 2nd row: driver side-Status,not installed,
IDE12057-MAS05030,Igniter for interaction airbag 2nd row: driver side-Resistance,no measured value present,
IDE12208-MAS01632,Igniter for deactivation of A/C system 1-Status,not installed,
IDE12208-MAS05030,Igniter for deactivation of A/C system 1-Resistance,no measured value present,
IDE12209-MAS01632,Igniter for deactivation of A/C system 2-Status,not installed,
IDE12209-MAS05030,Igniter for deactivation of A/C system 2-Resistance,no measured value present,
IDE12257-IDE00821,Extended belts witch diagnostic-Seat belt switch 2nd row driver's side,0,
IDE12257-IDE00822,Extended belts witch diagnostic-Safety belt switch 2nd row frt.passenger side,0,
IDE12257-IDE00823,Extended belts witch diagnostic-Seat belt switch 2nd row center,0,
IDE12257-IDE00824,Extended belts witch diagnostic-Seat belt switch 3rd row driver's side,0,
IDE12257-IDE00825,Extended belts witch diagnostic-Passenger side 3rd row seat belt switch,0,
IDE12257-IDE00826,Extended belts witch diagnostic-Seat belt switch 3rd row center,0,
IDE12257-IDE14842,Extended belts witch diagnostic-Center seat belt switch,0,
IDE12257-IDE14843,Extended belts witch diagnostic-Seat belt switch: 4th row driver side,0,
IDE12257-IDE14844,Extended belts witch diagnostic-Seat belt switch: 4th row passenger side,0,
IDE12257-IDE14845,Extended belts witch diagnostic-Seat belt switch: 4th row center,0,
IDE12257-MAS00025,Extended belts witch diagnostic-Driver seat belt switch,0,
IDE12257-MAS00026,Extended belts witch diagnostic-Front passenger side safety belt switch,0,
IDE13284-MAS01632,Seat-occupied recognition: 3rd row driver side-Status,not installed,
IDE13284-MAS05030,Seat-occupied recognition: 3rd row driver side-Resistance,no measured value present,
IDE13586-MAS01632,Seat-occupied recognition: 3rd row front passenger side-Status,not installed,
IDE13586-MAS05030,Seat-occupied recognition: 3rd row front passenger side-Resistance,no measured value present,
IDE14239-MAS01632,Igniter for high-voltage battery 2 open circuit-Status,not installed,
IDE14239-MAS05030,Igniter for high-voltage battery 2 open circuit-Resistance,no measured value present,
IDE14240-MAS01632,Driver side seat occupancy detection-Status,not installed,
IDE14240-MAS05030,Driver side seat occupancy detection-Resistance,no measured value present,
IDE14842-MAS01632,Center seat belt switch-Status,not installed,
IDE14842-MAS05030,Center seat belt switch-Resistance,no measured value present,
IDE14846-MAS01632,Seat occupancy detection: center-Status,not installed,
IDE14846-MAS05030,Seat occupancy detection: center-Resistance,no measured value present,
MAS00001-MAS01632,Driver airbag igniter-Status,correct,
MAS00001-MAS05030,Driver airbag igniter-Resistance,3.2, Ohm
MAS00002-MAS01632,Driver's Airbag Igniter 2-Status,not installed,
MAS00002-MAS05030,Driver's Airbag Igniter 2-Resistance,no measured value present,
MAS00003-MAS01632,Front passenger airbag igniter-Status,correct,
MAS00003-MAS05030,Front passenger airbag igniter-Resistance,2.2, Ohm
MAS00004-MAS01632,Front passenger airbag igniter 2-Status,correct,
MAS00004-MAS05030,Front passenger airbag igniter 2-Resistance,2.3, Ohm
MAS00005-MAS01632,Driver thorax airbag igniter-Status,correct,
MAS00005-MAS05030,Driver thorax airbag igniter-Resistance,2.5, Ohm
MAS00006-MAS01632,Front passenger side airbag igniter-Status,correct,
MAS00006-MAS05030,Front passenger side airbag igniter-Resistance,2.5, Ohm
MAS00007-MAS01632,Driver side rear thorax airbag igniter-Status,no measured value present,
MAS00007-MAS05030,Driver side rear thorax airbag igniter-Resistance,no measured value present,
MAS00008-MAS01632,Passenger side rear thorax airbag igniter-Status,no measured value present,
MAS00008-MAS05030,Passenger side rear thorax airbag igniter-Resistance,no measured value present,
MAS00009-MAS01632,Driver head curtain airbag igniter-Status,correct,
MAS00009-MAS05030,Driver head curtain airbag igniter-Resistance,2.4, Ohm
MAS00010-MAS01632,Front passenger head curtain airbag igniter-Status,correct,
MAS00010-MAS05030,Front passenger head curtain airbag igniter-Resistance,2.5, Ohm
MAS00011-MAS01632,Driver knee airbag igniter-Status,no measured value present,
MAS00011-MAS05030,Driver knee airbag igniter-Resistance,no measured value present,
MAS00012-MAS01632,Front passenger knee airbag igniter-Status,no measured value present,
MAS00012-MAS05030,Front passenger knee airbag igniter-Resistance,no measured value present,
MAS00013-MAS01632,Driver side seat belt tension igniter-Status,correct,
MAS00013-MAS05030,Driver side seat belt tension igniter-Resistance,2.5, Ohm
MAS00014-MAS01632,Front passenger side seat belt tension igniter-Status,correct,
MAS00014-MAS05030,Front passenger side seat belt tension igniter-Resistance,2.3, Ohm
MAS00015-MAS01632,Driver's Safety Belt Tensioner Igniter 2-Status,correct,
MAS00015-MAS05030,Driver's Safety Belt Tensioner Igniter 2-Resistance,2.4, Ohm
MAS00016-MAS01632,Front passenger seat belt tensioner igniter 2-Status,correct,
MAS00016-MAS05030,Front passenger seat belt tensioner igniter 2-Resistance,2.4, Ohm
MAS00017-MAS01632,Driver's Belt Force Limiter-Status,correct,
MAS00017-MAS05030,Driver's Belt Force Limiter-Resistance,2.4, Ohm
MAS00018-MAS01632,Front passenger side belt force limiter igniter-Status,correct,
MAS00018-MAS05030,Front passenger side belt force limiter igniter-Resistance,2.4, Ohm
MAS00019-MAS01632,Driver side rear safety belt tension igniter-Status,correct,
MAS00019-MAS05030,Driver side rear safety belt tension igniter-Resistance,2.6, Ohm
MAS00020-MAS01632,Passenger side rear seat belt tensioner igniter-Status,correct,
MAS00020-MAS05030,Passenger side rear seat belt tensioner igniter-Resistance,2.5, Ohm
MAS00021-MAS01632,Center rear seat belt tensioner igniter-Status,not installed,
MAS00021-MAS05030,Center rear seat belt tensioner igniter-Resistance,no measured value present,
MAS00022-MAS01632,Battery Interrupt Igniter-Status,not installed,
MAS00022-MAS05030,Battery Interrupt Igniter-Resistance,no measured value present,
MAS00023-MAS01632,Driver side active head restraint igniter-Status,not installed,
MAS00023-MAS05030,Driver side active head restraint igniter-Resistance,no measured value present,
MAS00024-MAS01632,Igniter for active head restraint on frt. passenger side-Status,not installed,
MAS00024-MAS05030,Igniter for active head restraint on frt. passenger side-Resistance,no measured value present,
MAS00025-MAS01632,Driver seat belt switch-Status,not connected,
MAS00025-MAS05030,Driver seat belt switch-Resistance,0.0, Ohm
MAS00026-MAS01632,Front passenger side safety belt switch-Status,not connected,
MAS00026-MAS05030,Front passenger side safety belt switch-Resistance,0.0, Ohm
MAS00031,Airbag deactivation status,On,
MAS00032-MAS01632,Key switch terminal 1-Status,not installed,
MAS00032-MAS05030,Key switch terminal 1-Resistance,too large,
MAS00033-MAS01632,Key switch terminal 2-Status,not installed,
MAS00033-MAS05030,Key switch terminal 2-Resistance,too large,
MAS00035-MAS01632,Seat position sensor: driver side-Status,Rear,
MAS00035-MAS04136,Seat position sensor: driver side-Current,5.7, mA
MAS00036-MAS01632,Seat position sensor: front passenger side-Status,Rear,
MAS00036-MAS04136,Seat position sensor: front passenger side-Current,5.7, mA
MAS00037,Calibration status,0,
MAS00038-MAS01632,Seat occupied recognition: driver side: rear-Status,not installed,
MAS00038-MAS05030,Seat occupied recognition: driver side: rear-Resistance,no measured value present,
MAS00039-MAS01632,Seat occupied recognition: passenger side: rear-Status,not installed,
MAS00039-MAS05030,Seat occupied recognition: passenger side: rear-Resistance,no measured value present,
MAS00040-MAS01632,Seat occupied recognition: center: rear-Status,not installed,
MAS00040-MAS05030,Seat occupied recognition: center: rear-Resistance,no measured value present,
MAS00231-MAS01632,Seat occupied recognition passenger side-Status,assigned,
MAS00231-MAS05030,Seat occupied recognition passenger side-Resistance,no measured value present,
MAS01634-IDE00020,Supply voltage-Terminal 15 status,On,
MAS01634-IDE00773,Supply voltage-Terminal 15 status via CAN,On,
MAS01634-IDE02537,Supply voltage-Terminal 30 status,correct,
MAS01634-MAS06489,Supply voltage-Terminal 15 signal,13.3, V
MAS01634-MAS06982,Supply voltage-Terminal 15 status signal,On,
MAS01634-MAS15175,Supply voltage-Terminal 30,13.5, V
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
MAS18987-MAS01632,Seat occupancy detection: 3rd row center-Status,not installed,
MAS18987-MAS05030,Seat occupancy detection: 3rd row center-Resistance,no measured value present,
Elapsed Time: 00:18,,,
;SW:5H0-920-340-B HW:5H0-920-340-B --- Instruments
;Component:KOMBI 220 5350, Coding:08BC02027B9CCF050280620B2000000810300000
;EV_DashBoardVDDMQB37W,003033,EV_DashBoardVDDMQB37W_003_VW38.rod
;Thursday,17,March,2022,11:35:54:62242
;VCID: 211FEBCDB146D823E0C-8074
IDE00019,Voltage terminal 30,13.3, V
IDE00021,Engine RPM,768.00, /min
IDE00025,Coolant temperature,90.00, °C
IDE00196,Engine oil temperature,100, °C
IDE00316-IDE00500,Time-Hour,11, H
IDE00316-IDE00501,Time-Minute,35, min
IDE00316-MAS00111,Time-Seconds,54, s
IDE00317-IDE00502,Date-Year,2022, yr
IDE00317-IDE00503,Date-Month,3, Months
IDE00317-IDE00504,Date-Day,17, d
IDE00706,Fuel level gasoline,101.6, %
IDE00845-MAS03213,Wheel circumference-Average wheel circumference for trip distance,1957, mm
IDE00845-MAS03214,Wheel circumference-Maximum wheel circumference for speed,1957, mm
IDE01076,Time since ignition off,955, s
IDE01985-MAS06855,FAZIT identification test sum-Test sum,51 15 03 F2,
IDE02307,Parking brake status,Not operated,
IDE02642,Outside temp.: displayed value,18.0, °C
IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,253,
IDE03193-MAS02353,Terminal 58 status-Switch dimming terminal 58s,0,
IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,100,
IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,253,
IDE03471-IDE02383,Vehicle configuration-Dynamic steering,Correct coding,
IDE03471-IDE04525,Vehicle configuration-Wheel Damping Electronics,Correct coding,
IDE03471-IDE04939,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-IDE05830,Vehicle configuration-Rear Spoiler,Correct coding,
IDE03471-IDE07016,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-IDE07944,Vehicle configuration-electronic brake booster,Correct coding,
IDE03471-MAS01374,Vehicle configuration-Trailer,Correct coding,
IDE03471-MAS01891,Vehicle configuration-Lane assist,Correct coding,
IDE03471-MAS01938,Vehicle configuration-Traffic sign detection,Correct coding,
IDE03471-MAS02570,Vehicle configuration-Differential lock electronics,Correct coding,
IDE03471-MAS06008,Vehicle configuration-Internal noise sound actuator,Correct coding,
IDE03471-MAS08201,Vehicle configuration-Trailer maneuvering assistant,Correct coding,
IDE03471-MAS08940,Vehicle configuration-Collision warning,Correct coding,
IDE03471-MAS09196,Vehicle configuration-Rear Axle Steering,Correct coding,
IDE03471-MAS12422,Vehicle configuration-intelligent parking assistant,Correct coding,
IDE03471-ENG33312,Vehicle configuration-virtual_side_mirror,Correct coding,
IDE03471-ENG43637,Vehicle configuration-zFAS,Correct coding,
IDE03472-MAS03806,Volume after refueling-Last displayed quantity before refueling,0.0, l
IDE03472-MAS03807,Volume after refueling-Last displayed quantity after refueling,54.5, l
IDE03472-MAS03808,Volume after refueling-Last sensor final value at end of refueling,57.5, l
IDE03472-MAS03809,Volume after refueling-Last reference quantity,2.5, l
IDE03472-MAS03810,Volume after refueling-Penultimate displayed quantity before refueling,28.6, l
IDE03472-MAS03811,Volume after refueling-Penultimate displayed quantity after refueling,54.5, l
IDE03472-MAS03812,Volume after refueling-Penultimate sensor final value at end of refueling,57.1, l
IDE03472-MAS03813,Volume after refueling-Penultimate reference quantity,29.7, l
IDE03472-MAS03814,Volume after refueling-Third-last displayed volume before refueling,10.9, l
IDE03472-MAS03815,Volume after refueling-Third-last displayed volume after refueling,54.5, l
IDE03472-MAS03816,Volume after refueling-Third-last sensor final value at end of refueling,57.5, l
IDE03472-MAS03817,Volume after refueling-Third-last reference quantity,11.3, l
IDE03472-MAS03818,Volume after refueling-Fourth-last displayed volume before refueling,39.0, l
IDE03472-MAS03819,Volume after refueling-Fourth-last displayed volume after refueling,54.5, l
IDE03472-MAS03820,Volume after refueling-Fourth-last sensor final value at end of refueling,57.5, l
IDE03472-MAS03821,Volume after refueling-Fourth-last reference quantity,39.2, l
IDE03472-MAS03822,Volume after refueling-Last error status,00,
IDE03472-MAS03823,Volume after refueling-Penultimate error status,00,
IDE03472-MAS03824,Volume after refueling-Third-last error status,00,
IDE03472-MAS03825,Volume after refueling-Fourth-last error status,00,
IDE03472-MAS06153,Volume after refueling-Last distance,370.0, km
IDE03472-MAS06154,Volume after refueling-Penultimate distance,310.0, km
IDE03472-MAS06155,Volume after refueling-Third to last distance,290.0, km
IDE03472-MAS06156,Volume after refueling-Fourth to last distance,240.0, km
IDE03473-IDE00730,tank sensor-Fuel level sensor 1 including soiling resistance,79, Ohm
IDE03473-IDE00731,tank sensor-Fuel level sensor 2 including soiling resistance,157, Ohm
IDE03473-IDE00732,tank sensor-Fuel level sensor 1 soiling resistance,1, Ohm
IDE03473-IDE00733,tank sensor-Fuel level sensor 2 soiling resistance,2, Ohm
IDE03473-IDE03494,tank sensor-Fuel level sensor 3 including soiling resistance,65535, Ohm
IDE03473-IDE03495,tank sensor-Fuel level sensor 3 soiling resistance,32767, Ohm
IDE03473-IDE03496,tank sensor-Fuel level sensor 4 including soiling resistance,65535, Ohm
IDE03473-IDE03497,tank sensor-Fuel level sensor 4 soiling resistance,32767, Ohm
IDE03473-MAS03798,tank sensor-Raw value sensor 1 resistor 1,1182,
IDE03473-MAS03799,tank sensor-Raw value sensor 1 resistor 2,2336,
IDE03473-MAS03799,tank sensor-Raw value sensor 1 resistor 2,81,
IDE03473-MAS03800,tank sensor-Raw value sensor 2 resistor 1,1820,
IDE03473-MAS03801,tank sensor-Raw value sensor 2 resistor 2,1989,
IDE03473-MAS03801,tank sensor-Raw value sensor 2 resistor 2,265,
IDE03473-MAS03802,tank sensor-Raw value sensor 3 resistor 1,65535,
IDE03473-MAS03803,tank sensor-Raw value sensor 3 resistor 2,160,
IDE03473-MAS03803,tank sensor-Raw value sensor 3 resistor 2,65535,
IDE03473-MAS03804,tank sensor-Raw value sensor 4 resistor 1,65535,
IDE03473-MAS03805,tank sensor-Raw value sensor 4 resistor 2,188,
IDE03473-MAS03805,tank sensor-Raw value sensor 4 resistor 2,65535,
IDE03474-IDE00304,Calculated volume-Fuel level,42.9, l
IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,78, Ohm
IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,155, Ohm
IDE03474-IDE00308,Calculated volume-Fuel Level Sensor 3,65535, Ohm
IDE03474-IDE00309,Calculated volume-Fuel Level Sensor 4,65535, Ohm
IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,22.8, l
IDE03474-IDE00313,Calculated volume-Fuel level from sensor 2,18.0, l
IDE03474-IDE00314,Calculated volume-Fuel level from sensor 3,0.0, l
IDE03474-IDE00315,Calculated volume-Fuel level from sensor 4,0.0, l
IDE03474-IDE00802,Calculated volume-Full volume,54.5, l
IDE03474-MAS03827,Calculated volume-Quality sensor 2,10,
IDE03474-MAS10338,Calculated volume-Non-calibrated volume: sensor 1,23.0, l
IDE03474-MAS10339,Calculated volume-Non-calibrated volume: sensor 2,18.0, l
IDE03474-MAS10340,Calculated volume-Non-calibrated volume: sensor 3,3276.7, l
IDE03474-MAS10341,Calculated volume-Non-calibrated volume: sensor 4,3276.7, l
IDE03474-MAS18153,Calculated volume-Calculated volume unlimited: sensor 1,23.0, l
IDE03474-MAS18154,Calculated volume-Calculated volume unlimited: sensor 2,18.0, l
IDE03474-MAS18155,Calculated volume-Calculated volume unlimited: sensor 3,3276.7, l
IDE03474-MAS18156,Calculated volume-Calculated volume unlimited: sensor 4,3276.7, l
IDE03474-ENG103155,Calculated volume-accelerated_linking_x,1.0000000,
IDE03474-ENG103517,Calculated volume-accelerated_linking_y,1.0000000,
IDE03474-ENG102894,Calculated volume-averaged_volume,40.8, l
IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,40.8, l
IDE03474-ENG101619,Calculated volume-calibrated_volume_total,40.8, l
IDE03474-ENG126318,Calculated volume-gas_based_linking,1.0000000,
IDE03474-ENG101669,Calculated volume-prefiltered_acceleration_x,0.40625, m/s
IDE03474-ENG102339,Calculated volume-prefiltered_acceleration_y,-12.25000, m/s
IDE03474-ENG101623,Calculated volume-reference_volume,41.4, l
IDE03474-ENG102479,Calculated volume-speed_based_linking,0.0000000,
IDE03474-ENG99683,Calculated volume-version_of_application,116,
IDE03474-ENG102081,Calculated volume-volume_based_linking,0.0016661,
IDE03477-IDE00500,GPS time-Hour,11, H
IDE03477-IDE00501,GPS time-Minute,33, min
IDE03477-IDE00501,GPS time-Minute,35, min
IDE03477-IDE00502,GPS time-Year,2022, yr
IDE03477-IDE00503,GPS time-Month,3, Months
IDE03477-IDE00504,GPS time-Day,17, d
IDE03477-MAS00111,GPS time-Seconds,15, s
IDE03477-MAS00111,GPS time-Seconds,57, s
IDE03477-MAS03493,GPS time-last synchronization year,2022, yr
IDE03506,Distance: high resolution,00 3C 91 31,
IDE03911-MAS01390,Service -interval- display: history 1-Block 1,4F F0 00 5F,
IDE03911-MAS01391,Service -interval- display: history 1-Block 2,0F F0 00 09,
IDE03911-MAS01392,Service -interval- display: history 1-Block 3,8F F0 00 09,
IDE03911-MAS01393,Service -interval- display: history 1-Block 4,CF F0 00 5F,
IDE03911-MAS01394,Service -interval- display: history 1-Block 5,4F F0 00 5F,
IDE03911-MAS01395,Service -interval- display: history 1-Block 6,0F F0 00 09,
IDE03911-MAS01396,Service -interval- display: history 1-Block 7,8F F0 00 09,
IDE03911-MAS01397,Service -interval- display: history 1-Block 8,CF F0 00 5F,
IDE03911-MAS01398,Service -interval- display: history 1-Block 9,FF FF FF FF,
IDE03911-MAS01399,Service -interval- display: history 1-Block 10,FF FF FF FF,
IDE03911-MAS01400,Service -interval- display: history 1-Block 11,FF FF FF FF,
IDE03911-MAS01401,Service -interval- display: history 1-Block 12,FF FF FF FF,
IDE03911-MAS01402,Service -interval- display: history 1-Block 13,FF FF FF FF,
IDE03911-MAS01403,Service -interval- display: history 1-Block 14,FF FF FF FF,
IDE03911-MAS01404,Service -interval- display: history 1-Block 15,FF FF FF FF,
IDE03911-ENG01075,Service -interval- display: history 1-Block_16,FF FF FF FF,
IDE03912-MAS01390,Service -interval- display: history 2-Block 1,FF FF FF FF,
IDE03912-MAS01391,Service -interval- display: history 2-Block 2,FF FF FF FF,
IDE03912-MAS01392,Service -interval- display: history 2-Block 3,FF FF FF FF,
IDE03912-MAS01393,Service -interval- display: history 2-Block 4,FF FF FF FF,
IDE03912-MAS01394,Service -interval- display: history 2-Block 5,FF FF FF FF,
IDE03912-MAS01395,Service -interval- display: history 2-Block 6,FF FF FF FF,
IDE03912-MAS01396,Service -interval- display: history 2-Block 7,FF FF FF FF,
IDE03912-MAS01397,Service -interval- display: history 2-Block 8,FF FF FF FF,
IDE03912-MAS01398,Service -interval- display: history 2-Block 9,FF FF FF FF,
IDE03912-MAS01399,Service -interval- display: history 2-Block 10,FF FF FF FF,
IDE03912-MAS01400,Service -interval- display: history 2-Block 11,FF FF FF FF,
IDE03912-MAS01401,Service -interval- display: history 2-Block 12,FF FF FF FF,
IDE03912-MAS01402,Service -interval- display: history 2-Block 13,FF FF FF FF,
IDE03912-MAS01403,Service -interval- display: history 2-Block 14,FF FF FF FF,
IDE03912-MAS01404,Service -interval- display: history 2-Block 15,FF FF FF FF,
IDE03912-ENG01075,Service -interval- display: history 2-Block_16,FF FF FF FF,
IDE03913-MAS01390,Service -interval- display: history 3-Block 1,FF FF FF FF,
IDE03913-MAS01391,Service -interval- display: history 3-Block 2,FF FF FF FF,
IDE03913-MAS01392,Service -interval- display: history 3-Block 3,FF FF FF FF,
IDE03913-ENG01075,Service -interval- display: history 3-Block_16,FF FF FF FF,
IDE03914-ENG01075,Service -interval- display: history 4-Block_16,FF FF FF FF,
IDE06592-MAS18012,Status: special functions-Vehicle locking and unlocking via mobile online service,lock,
IDE06592-MAS18013,Status: special functions-Deactivation of extended start authentication,OFF,
IDE06924,Performance display,0,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,08,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,80,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 6,
IDE08343,Immobilizer Challenge,CB D2 BC 7D,
IDE10779,Ethernet signal quality,good: link available,
IDE10780,Ethernet counter connection interruptions,0,
IDE10781,Ethernet counter checksum malfunction,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 05 00 00 00 00 00 00 00 14|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 31|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 32|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 46|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 28|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 29|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0C|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 04|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|5|,
IDE11756,IP network: counter messages with inadmissible VLANs,0,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,9,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|02 7D FA 00 14 00|,
IDE11869,IP network: NDP cache,|MAC address,IPv6 address
IDE12238,I network: discarded messages counter,1358,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73
IDE12972,Oil: theoretical service interval,25600.00, km
IDE12973,Oil: service interval exceeded in km,0, km
IDE12974,Oil service interval exceeded in days,0, d
IDE12975,Oil: remaining driving distance,12140, km
IDE12976,Oil: remaining running time,334, d
IDE12977-MAS07266,Oil status-Oil change: unit of dist. travelled,miles,
IDE12977-MAS07267,Oil status-Oil change: dist. travelled,7600,
IDE12977-MAS07268,Oil status-Oil change: stat. of dist. travelled,Service in,
IDE12977-MAS07269,Oil status-Oil change: stat. of time,Service in,
IDE12977-MAS07270,Oil status-Inspection: stat. of dist. travelled,Service in,
IDE12977-MAS07271,Oil status-Inspection: unit of dist. travelled,miles,
IDE12977-MAS07272,Oil status-Inspection: dist. travelled,17600,
IDE12977-MAS07273,Oil status-Inspection: time,699,
IDE12977-MAS07274,Oil status-Oil change warning,no warning,
IDE12977-MAS07277,Oil status-Inspections warning,no warning,
IDE12977-MAS07305,Oil status-Oil change: time,334,
IDE12977-MAS07308,Oil status-Inspection: status time,Service in,
IDE12977-MAS10768,Oil status-Daily mileage,125,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVWFB7CD8NW129409,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,11,
IDE14124-IDE03840,Gong status-Volume of actuator test,0, %
IDE14124-MAS01167,Gong status-Actuation time,Unknown (0),
IDE14124-MAS05781,Gong status-Acoustics,all_acoustics,
IDE14124-ENG130459,Gong status-IO Reached Status,Output diagnostic test not active,
IDE14126-MAS01167,Other function lights status-Actuation time,Unknown (0),
IDE14126-MAS01168,Other function lights status-Start parameter,00 00 00,
IDE14126-ENG130459,Other function lights status-IO Reached Status,Output diagnostic test not active,
IDE14127-MAS01167,Lights status-Actuation time,Unknown (0),
IDE14127-MAS01168,Lights status-Start parameter,00 00 00,
IDE14127-ENG130459,Lights status-IO Reached Status,Output diagnostic test not active,
IDE14129-IDE04290,Segment test status-Color code,White,
IDE14129-MAS01167,Segment test status-Actuation time,Unknown (0),
IDE14129-ENG130459,Segment test status-IO Reached Status,Output diagnostic test not active,
IDE14130-MAS01167,Test image in center display status-Actuation time,Unknown (0),
IDE14130-MAS01168,Test image in center display status-Start parameter,Unknown (0),
IDE14130-ENG130459,Test image in center display status-IO Reached Status,Output diagnostic test not active,
IDE14132-MAS01167,Indicator lamp status-Actuation time,Unknown (0),
IDE14132-MAS01168,Indicator lamp status-Start parameter,00 00 00,
IDE14132-ENG130459,Indicator lamp status-IO Reached Status,Output diagnostic test not active,
IDE14185-IDE00301,Gas systems test-Mileage,0, km
IDE14185-IDE00502,Gas systems test-Year,2001, yr
IDE14185-IDE00503,Gas systems test-Month,1, Months
IDE14185-IDE00504,Gas systems test-Day,1, d
IDE14185-MAS17869,Gas systems test-Time since last reset,0, d
IDE14185-MAS17870,Gas systems test-Number of resets,0,
IDE14212-ENG103300,Service Key Master daily data-Service_Data,58 9A 03 24 48 C0 16 03 11 0B 1E 22 81 0F 00 00 4C 30 4E 11 B0 30 BB 12 08 DF 9F A4 22 A2 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 4E FF FF 00 00 40 17,
IDE14213-ENG103300,Service Key Master current data-Service_Data,B8 EA 03 24 48 D0 16 03 11 0B 1E 23 81 0F 00 00 4C 30 4E 11 B0 30 BB 12 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 4E FF FF 00 00 40 17,
IDE14214-ENG01100,Service Key Master write counter-Counter_current_clamp_15,2,
IDE14214-ENG01101,Service Key Master write counter-Counter_current_total,277,
IDE14214-ENG01102,Service Key Master write counter-Counter_daily_clamp_15,2,
IDE14214-ENG01103,Service Key Master write counter-Counter_daily_total,178,
IDE14214-ENG119822,Service Key Master write counter-Error_Counter,0,
IDE14214-ENG01154,Service Key Master write counter-state_current,Wait_Trigger,
IDE14214-ENG01155,Service Key Master write counter-State_daily,Wait_Trigger,
IDE14214-ENG01077,Service Key Master write counter-transponder_id,00 00 00 00,
IDE14214-ENG01076,Service Key Master write counter-Transponder_type,00 00,
IDE14236-MAS00106,Authentic time: last confirmed time-Year,1970, yr
IDE14236-MAS00107,Authentic time: last confirmed time-Month,1, Months
IDE14236-MAS00108,Authentic time: last confirmed time-Day,1, d
IDE14236-MAS00109,Authentic time: last confirmed time-Hours,0, H
IDE14236-MAS00110,Authentic time: last confirmed time-Minutes,0, min
IDE14236-MAS00111,Authentic time: last confirmed time-Seconds,0, s
IDE14236-MAS03617,Authentic time: last confirmed time-Time zone,0, H
IDE14237-MAS00106,Authentic time: actual time-Year,1970, yr
IDE14237-MAS00107,Authentic time: actual time-Month,1, Months
IDE14237-MAS00108,Authentic time: actual time-Day,1, d
IDE14237-MAS00109,Authentic time: actual time-Hours,0, H
IDE14237-MAS00110,Authentic time: actual time-Minutes,0, min
IDE14237-MAS00111,Authentic time: actual time-Seconds,0, s
IDE14237-MAS03617,Authentic time: actual time-Time zone,0, H
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,00,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,|Verification failed|00 00|,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,|failed signature creation|00 00|,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,00,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,00,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 51 29 41 38 DF 9D 67,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,00,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,7,
IDE14496-ENG103935,Secure Onboard Communication: Freshness Values information-Parameter,|SOC PDU ID to which this freshness information is assigned,Freshness Value query status
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,|Missing key|00 00|,
IDE15081,Authentic time: status of distribution signal trigger,0,
MAS00902-ENG99140,Extended Service Intervals (ESI)-advance_warning_fixed_days,not active,
MAS00902-ENG100265,Extended Service Intervals (ESI)-advance_warning_fixed_km,not active,
MAS00902-ENG101600,Extended Service Intervals (ESI)-advance_warning_WIV_days,not active,
MAS00902-ENG102887,Extended Service Intervals (ESI)-advance_warning_WIV_km,not active,
MAS00902-ENG99971,Extended Service Intervals (ESI)-in_calculation,active,
MAS00902-ENG101015,Extended Service Intervals (ESI)-no_calculation_available,not active,
MAS00902-ENG101477,Extended Service Intervals (ESI)-service_warning_fixed_days,not active,
MAS00902-ENG101550,Extended Service Intervals (ESI)-service_warning_fixed_km,not active,
MAS00902-ENG101709,Extended Service Intervals (ESI)-service_warning_WIV_days,not active,
MAS00902-ENG102993,Extended Service Intervals (ESI)-service_warning_WIV_km,not active,
MAS10768,Daily mileage,125, km
ENG55049,Authentic_time_current_counter_kl15_since_last_sync,211,
ENG00802,Authentic_time_last_backend_response,|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||,
ENG55051,Authentic_time_last_client_response,1970-01-01T00:00:00Z,
ENG55051,Authentic_time_last_client_response,211,
ENG105830-ENG104002,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC,0.0,
ENG105830-ENG119807,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial,100, %
ENG105830-ENG100577,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial_day,0.0,
ENG105830-ENG01104,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial_night,0, %
ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,0, %
ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,100, %
ENG105830-ENG01105,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights_blue,0.0,
ENG105830-ENG01106,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights_green,0.0,
ENG105830-ENG01107,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights_red,0.0,
ENG105830-ENG01108,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights_yellow,0.0,
ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,70, %
ENG105830-ENG130458,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_internal characteristic_phototransistor,2452,
ENG99439,Instrument_recorder,07 23 50 00 4D 51 42 32 30 32 30 32 31 53 31 46 41 43 47 33 38 64 64 66 64 66 78 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 06 FF FF FF FF FF FF FF FF FF 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 2E 00 03 00 00 00 04 00 04 00 02 00 01 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 02 00 8C FF B7 00 00 10 1B 00 8C FF FF FF 00 00 C8 8C C8 C8 C8 C8 C8 B3 00 00 00 09 4A D7 FF B7 00 00 00 00 00 00 54 41 A8 48 80 00 40 00 07 24 0B 00 00 00 A8,
ENG128745,Instrument_recorder_graphic,05 23 50 00 4D 51 42 32 30 32 30 32 31 53 31 46 47 43 5F 56 57 63 D9 05 00 6F 62 FC 6F 9A 04 00 00 66 00 00 00 55 01 01 00 00 00 00 00 57 01 00 00 05 00 00 00 02 00 00 00 68 DA 05 00 52 E0 B4 5D B2 02 00 00 3E 00 00 00 7B 00 00 00 00 00 00 00 C0 01 00 00 65 01 00 00 02 00 00 00 68 DA 05 00 CC E2 B4 5D F0 00 00 00 0F 00 00 00 88 01 00 00 00 00 00 00 C0 01 00 00 65 01 00 80 02 00 00 00 68 DA 05 00 1C EE 2F 04 75 00 00 00 06 00 00 00 46 01 0F 00 00 00 00 00 BF 01 00 00 63 00 00 00 02 00 00 00 41 D9 05 00 F1 FD 1B 5C EB 00 00 00 0E 00 00 00 0E 04 00 00 01 00 00 00 4A 01 00 00 00 00 00 00 02 00 00 00 66 DA 05 00 11 70 67 EA F1 04 00 00 6D 00 00 00 8A 00 5F 00 00 00 00 00 BD 01 00 00 00 00 00 00 02 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 00 00 7E 00 00 00 9D 01 00 00 62 11 13 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 61 61 31 37 63 33 62 78 02 00 00 00 C0 01 00 00 02 00 00 00 A1 FB FF FF 00 00 00 00 57 C6 FF FF 06 00 00 00 19 93 5B 09 01 FF FF FF,
ENG02308,Instrument_recorder_graphic_3,||05|23|50|00|4D|51|42|32|30|32|30|32|31|53|31|46|47|43|5F|56|57|63|D9|05|00|6F|62|FC|6F|9A|04|00|00|66|00|00|00|55|01|01|00|00|00|00|00|57|01|00|00|05|00|00|00|02|00|00|00|68|DA|05|00|98|DB|7D|27|B2|02|00|00|3E|00|00|00|7B|00|00|00|00|00|00|00|BF|01|00|00|63|01|00|00|02|00|00|00|68|DA|05|00|76|21|7E|27|F0|00|00|00|0F|00|00|00|88|01|00|00|00|00|00|00|BF|01|00|00|63|01|00|80|02|00|00|00|68|DA|05|00|1C|EE|2F|04|75|00|00|00|06|00|00|00|46|01|0F|00|00|00|00|00|BF|01|00|00|63|00|00|00|02|00|00|00|41|D9|05|00|F1|FD|1B|5C|EB|00|00|00|0E|00|00|00|0E|04|00|00|01|00|00|00|4A|01|00|00|00|00|00|00|02|00|00|00|66|DA|05|00|11|70|67|EA|F1|04|00|00|6D|00|00|00|8A|00|5F|00|00|00|00|00|BD|01|00|00|00|00|00|00|02|00|00|00|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|00|00|00|00|7E|00|00|00|9D|01|00|00|62|11|16|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|61|61|31|37|63|33|62|78|02|00|00|00|BF|01|00|00|02|00|00|00|A2|FB|FF|FF|00|00|00|00|57|C6|FF|FF|06|00|00|00|2F|59|C9|75|02|FF|FF|FF|,
ENG107953-ENG99788,outside_temp_algorithm_group-engine_running_detection_MSG,active,
ENG107953-ENG99520,outside_temp_algorithm_group-no_blockage_active,not active,
ENG107953-ENG99784,outside_temp_algorithm_group-outside_temperature_filtered,136,
Elapsed Time: 00:16,,,
;SW:5WA-907-530-Q HW:5WA-907-530-G --- CAN Gateway
;Component:GW2020 High 756 7099, Coding:0000800D0E00000000000000010303307302610902000300030100000001010000000000000000000000000000000000
;EV_GatewMQB2020,005011,EV_GatewMQB2020_VW38.rod
;Thursday,17,March,2022,11:36:52:62242
;VCDS Version: Release 22.3.0 Data version: 20220225 DS336.1
;VCID: 56F58811A8886F9BC5E-8002
Group,Description,Actual,
IDE00356,Cruise Control System (CCS): switch position,OFF,
IDE00356-IDE15905,Cruise Control System (CCS): switch position-Travel Assist,Not operated,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,Not operated,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,Not operated,
IDE00356-MAS00324,Cruise Control System (CCS): switch position-Tap acceleration,Not operated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,Not operated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,Not operated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,Not operated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,6,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,Not operated,
IDE00356-MAS04522,Cruise Control System (CCS): switch position-Tap deceleration stage 2,Not operated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,Cruise control switch with ACC,
IDE00356-MAS05812,Cruise Control System (CCS): switch position-Limit button,not installed,
IDE00356-MAS06029,Cruise Control System (CCS): switch position-MFL message counter,13,
IDE00356-MAS06879,Cruise Control System (CCS): switch position-Checksum,237,
IDE00634,Vehicle electrical system current,35.640, A
IDE00767-ENG18474,No. of unscheduled ECU resets-FCCU_RF_S0_Status,00 04 00 00,
IDE00767-ENG18475,No. of unscheduled ECU resets-FCCU_RF_S1_Status,00 00 00 00,
IDE00767-ENG18476,No. of unscheduled ECU resets-FCCU_RF_S2_Status,00 00 00 00,
IDE00767-ENG18477,No. of unscheduled ECU resets-FCCU_RF_S3_Status,00 00 00 00,
IDE00767-ENG05080,No. of unscheduled ECU resets-KL30_Reset_Counter,6,
IDE00767-ENG18512,No. of unscheduled ECU resets-Muc_Reset_Counter,0,
IDE00767-ENG18534,No. of unscheduled ECU resets-Reason_of_2th_last_reset,0,
IDE00767-ENG18535,No. of unscheduled ECU resets-Reason_of_3th_last_reset,0,
IDE00767-ENG18536,No. of unscheduled ECU resets-Reason_of_4th_last_reset,4,
IDE00767-ENG18537,No. of unscheduled ECU resets-Reason_of_5th_last_reset,0,
IDE00767-ENG18538,No. of unscheduled ECU resets-Reason_of_latest_reset,0,
IDE00767-ENG18624,No. of unscheduled ECU resets-Watchdog_Reset_Counter,2,
IDE01807-IDE07142,History data 21-Time since terminal 15 off,0.5, H
IDE01807-MAS00106,History data 21-Year,2022,
IDE01807-MAS00107,History data 21-Month,2,
IDE01807-MAS00108,History data 21-Day,20,
IDE01807-MAS00109,History data 21-Hours,22, H
IDE01807-MAS00110,History data 21-Minutes,45, min
IDE01807-MAS14375,History data 21-Cycle counter,88,
IDE01807-MAS14376,History data 21-ECU 1,00 0E,
IDE01807-MAS14377,History data 21-Alert maintenance time for ECU 1,0.5, H
IDE01807-MAS14378,History data 21-Repetition counter for ECU 1,0,
IDE01807-MAS14379,History data 21-ECU 2,00 00,
IDE01807-MAS14380,History data 21-Alert maintenance time for ECU 2,0.0, H
IDE01807-MAS14381,History data 21-Repetition counter for ECU 2,0,
IDE01807-MAS14382,History data 21-ECU 3,00 00,
IDE01807-MAS14383,History data 21-Alert maintenance time for ECU 3,0.0, H
IDE01807-MAS14384,History data 21-Repetition counter for ECU 3,0,
IDE01807-MAS14385,History data 21-ECU 4,00 00,
IDE01807-MAS14386,History data 21-Alert maintenance time for ECU 4,0.0, H
IDE01807-MAS14387,History data 21-Repetition counter for ECU 4,0,
IDE01807-MAS14388,History data 21-ECU 5,00 00,
IDE01807-MAS14389,History data 21-Alert maintenance time for ECU 5,0.0, H
IDE01807-MAS14390,History data 21-Repetition counter for ECU 5,0,
IDE01807-ENG28833,History data 21-Bus_ECU_1,Comfort data bus,
IDE01807-ENG28836,History data 21-Bus_ECU_2,Unknown,
IDE01807-ENG28839,History data 21-Bus_ECU_3,Unknown,
IDE01807-ENG28842,History data 21-Bus_ECU_4,Unknown,
IDE01807-ENG28845,History data 21-Bus_ECU_5,Unknown,
IDE01808-MAS03173,History data 22-Powertrain data bus,0.0, H
IDE01808-MAS03174,History data 22-Comfort data bus,1.0, H
IDE01808-MAS03177,History data 22-Infotainment data bus,0.2, H
IDE01808-MAS03178,History data 22-Suspension data bus,0.0, H
IDE01808-MAS03179,History data 22-Local data bus 2,0.0, H
IDE01808-MAS03180,History data 22-Local data bus,0.0, H
IDE01808-MAS05686,History data 22-Data bus diagnostics,0.0, H
IDE01808-MAS05972,History data 22-Local data bus 3,0.0, H
IDE01808-MAS12185,History data 22-Hybrid data bus,0.0, H
IDE01808-MAS14373,History data 22-All BUS systems,1.2, H
IDE01808-MAS16909,History data 22-Data bus driver assistance systems,0.0, H
IDE01808-MAS16910,History data 22-Migration data bus,0.0, H
IDE01808-MAS16912,History data 22-VLAN_FAS,0.0, H
IDE01808-MAS16913,History data 22-VLAN_Infotainment,0.0, H
IDE01808-MAS16915,History data 22-VLAN_Komfort,0.0, H
IDE01808-MAS16916,History data 22-VLAN_Powertrain,0.0, H
IDE01808-MAS16917,History data 22-VLAN_Diagnose,0.0, H
IDE01808-MAS18934,History data 22-VLAN_Connect,0.0, H
IDE01809-IDE07142,History data 23-Time since terminal 15 off,0.0, H
IDE01809-MAS00106,History data 23-Year,2000,
IDE01809-MAS00107,History data 23-Month,1,
IDE01809-MAS00108,History data 23-Day,1,
IDE01809-MAS00109,History data 23-Hours,0, H
IDE01809-MAS00110,History data 23-Minutes,0, min
IDE01809-MAS14375,History data 23-Cycle counter,0,
IDE01809-MAS14395,History data 23-Bus with maximum number of post alarms,Unknown,
IDE01809-MAS14396,History data 23-Post alerts in current cycle,0,
IDE01809-MAS14397,History data 23-Rousing ECU 1,00 00,
IDE01809-MAS14398,History data 23-Number of post alerts for control module 1,0,
IDE01809-MAS14399,History data 23-CarWakeUp bit 1,0,
IDE01809-MAS14400,History data 23-Rousing ECU 2,00 00,
IDE01809-MAS14401,History data 23-Number of post alerts for control module 2,0,
IDE01809-MAS14402,History data 23-CarWakeUp bit 2,0,
IDE01809-MAS14403,History data 23-Rousing ECU 3,00 00,
IDE01809-MAS14404,History data 23-Number of post alerts for control module 3,0,
IDE01809-MAS14405,History data 23-CarWakeUp bit 3,0,
IDE01809-MAS14406,History data 23-Rousing ECU 4,00 00,
IDE01809-MAS14407,History data 23-Number of post alerts for control module 4,0,
IDE01809-MAS14408,History data 23-CarWakeUp bit 4,0,
IDE01809-MAS14409,History data 23-Rousing ECU 5,00 00,
IDE01809-MAS14410,History data 23-Number of post alerts for control module 5,0,
IDE01809-MAS14411,History data 23-CarWakeUp bit 5,0,
IDE01809-ENG124425,History data 23-Bus_Waking_ECU_1,Unknown,
IDE01809-ENG124426,History data 23-Bus_Waking_ECU_2,Unknown,
IDE01809-ENG124427,History data 23-Bus_Waking_ECU_3,Unknown,
IDE01809-ENG124428,History data 23-Bus_Waking_ECU_4,Unknown,
IDE01809-ENG124429,History data 23-Bus_Waking_ECU_5,Unknown,
IDE01810-IDE07142,History data 24-Time since terminal 15 off,0.8, H
IDE01810-MAS00106,History data 24-Year,2022,
IDE01810-MAS00107,History data 24-Month,2,
IDE01810-MAS00108,History data 24-Day,23,
IDE01810-MAS00109,History data 24-Hours,20, H
IDE01810-MAS00110,History data 24-Minutes,3, min
IDE01810-MAS14375,History data 24-Cycle counter,107,
IDE01810-MAS14392,History data 24-CarWakeUp Bit,0,
IDE01810-MAS14393,History data 24-ID of the alerting message,1A 55 55 A8,
IDE01810-MAS14394,History data 24-Bus of the alerting message,Comfort data bus,
IDE01810-MAS14412,History data 24-Bus with maximum number of alerts,Comfort data bus,
IDE01810-MAS14413,History data 24-Alert events in current cycle,53,
IDE01810-MAS20473,History data 24-Alerting message counter,17,
IDE01812-MAS01468,History data 26-Terminal 15,213,
IDE01812-MAS03173,History data 26-Powertrain data bus,7,
IDE01812-MAS03174,History data 26-Comfort data bus,465,
IDE01812-MAS03177,History data 26-Infotainment data bus,4,
IDE01812-MAS03178,History data 26-Suspension data bus,3,
IDE01812-MAS03180,History data 26-Local data bus,3,
IDE01812-MAS05686,History data 26-Data bus diagnostics,0,
IDE01812-MAS12185,History data 26-Hybrid data bus,0,
IDE01812-MAS14374,History data 26-Totals,485,
IDE01812-MAS16909,History data 26-Data bus driver assistance systems,3,
IDE01812-MAS16910,History data 26-Migration data bus,0,
IDE01812-MAS16917,History data 26-VLAN_Diagnose,0,
IDE01813-MAS03173,History data 27-Powertrain data bus,0,
IDE01813-MAS03174,History data 27-Comfort data bus,105,
IDE01813-MAS03177,History data 27-Infotainment data bus,339,
IDE01813-MAS03178,History data 27-Suspension data bus,24,
IDE01813-MAS12185,History data 27-Hybrid data bus,0,
IDE01813-MAS14374,History data 27-Totals,468,
IDE01813-MAS16909,History data 27-Data bus driver assistance systems,0,
IDE01813-MAS16910,History data 27-Migration data bus,0,
IDE01813-MAS16912,History data 27-VLAN_FAS,0,
IDE01813-MAS16913,History data 27-VLAN_Infotainment,0,
IDE01813-MAS16915,History data 27-VLAN_Komfort,0,
IDE01813-MAS16916,History data 27-VLAN_Powertrain,0,
IDE01813-MAS18934,History data 27-VLAN_Connect,0,
IDE01814-MAS03173,History data 28-Powertrain data bus,11,
IDE01814-MAS03174,History data 28-Comfort data bus,2221,
IDE01814-MAS03177,History data 28-Infotainment data bus,337,
IDE01814-MAS03178,History data 28-Suspension data bus,23,
IDE01814-MAS12185,History data 28-Hybrid data bus,0,
IDE01814-MAS14374,History data 28-Totals,2592,
IDE01814-MAS16909,History data 28-Data bus driver assistance systems,0,
IDE01814-MAS16910,History data 28-Migration data bus,0,
IDE01814-MAS16912,History data 28-VLAN_FAS,0,
IDE01814-MAS16913,History data 28-VLAN_Infotainment,0,
IDE01814-MAS16915,History data 28-VLAN_Komfort,0,
IDE01814-MAS16916,History data 28-VLAN_Powertrain,0,
IDE01814-MAS18934,History data 28-VLAN_Connect,0,
IDE01816-IDE07142,History data 30-Time since terminal 15 off,0.1, H
IDE01816-MAS00106,History data 30-Year,2022,
IDE01816-MAS00107,History data 30-Month,3,
IDE01816-MAS00108,History data 30-Day,4,
IDE01816-MAS00109,History data 30-Hours,7, H
IDE01816-MAS00110,History data 30-Minutes,58, min
IDE01816-MAS14375,History data 30-Cycle counter,148,
IDE01816-ENG20570,History data 30-Bus_1,Comfort data bus,
IDE01816-ENG20572,History data 30-Bus_2,Infotainment data bus,
IDE01816-ENG20574,History data 30-Bus_3,Unknown,
IDE01816-ENG20576,History data 30-Bus_4,Unknown,
IDE01816-ENG20578,History data 30-Bus_5,Unknown,
IDE01816-ENG20571,History data 30-Bus_Active_Time_1,1.6, H
IDE01816-ENG20573,History data 30-Bus_Active_Time_2,0.3, H
IDE01816-ENG20575,History data 30-Bus_Active_Time_3,0.0, H
IDE01816-ENG20577,History data 30-Bus_Active_Time_4,0.0, H
IDE01816-ENG20579,History data 30-Bus_Active_Time_5,0.0, H
IDE01817-IDE07142,History data 31-Time since terminal 15 off,0.5, H
IDE01817-MAS00106,History data 31-Year,2022,
IDE01817-MAS00107,History data 31-Month,2,
IDE01817-MAS00108,History data 31-Day,20,
IDE01817-MAS00109,History data 31-Hours,22, H
IDE01817-MAS00110,History data 31-Minutes,45, min
IDE01817-MAS14375,History data 31-Cycle counter,88,
IDE01817-MAS14376,History data 31-ECU 1,00 0E,
IDE01817-MAS14377,History data 31-Alert maintenance time for ECU 1,0.5, H
IDE01817-MAS14378,History data 31-Repetition counter for ECU 1,0,
IDE01817-MAS14379,History data 31-ECU 2,00 00,
IDE01817-MAS14380,History data 31-Alert maintenance time for ECU 2,0.0, H
IDE01817-MAS14381,History data 31-Repetition counter for ECU 2,0,
IDE01817-MAS14382,History data 31-ECU 3,00 00,
IDE01817-MAS14383,History data 31-Alert maintenance time for ECU 3,0.0, H
IDE01817-MAS14384,History data 31-Repetition counter for ECU 3,0,
IDE01817-MAS14385,History data 31-ECU 4,00 00,
IDE01817-MAS14386,History data 31-Alert maintenance time for ECU 4,0.0, H
IDE01817-MAS14387,History data 31-Repetition counter for ECU 4,0,
IDE01817-MAS14388,History data 31-ECU 5,00 00,
IDE01817-MAS14389,History data 31-Alert maintenance time for ECU 5,0.0, H
IDE01817-MAS14390,History data 31-Repetition counter for ECU 5,0,
IDE01817-ENG28833,History data 31-Bus_ECU_1,Comfort data bus,
IDE01817-ENG28836,History data 31-Bus_ECU_2,Unknown,
IDE01817-ENG28839,History data 31-Bus_ECU_3,Unknown,
IDE01817-ENG28842,History data 31-Bus_ECU_4,Unknown,
IDE01817-ENG28845,History data 31-Bus_ECU_5,Unknown,
IDE01818-IDE07142,History data 32-Time since terminal 15 off,0.0, H
IDE01818-MAS00106,History data 32-Year,2000,
IDE01818-MAS00107,History data 32-Month,1,
IDE01818-MAS00108,History data 32-Day,1,
IDE01818-MAS00109,History data 32-Hours,0, H
IDE01818-MAS00110,History data 32-Minutes,0, min
IDE01818-MAS14375,History data 32-Cycle counter,0,
IDE01818-MAS14391,History data 32-Alerting ECU,00 00,
IDE01818-MAS14392,History data 32-CarWakeUp Bit,0,
IDE01818-MAS20474,History data 32-Cluster,00 00 00,
IDE01819-IDE07142,History data 33-Time since terminal 15 off,0.8, H
IDE01819-MAS00106,History data 33-Year,2022,
IDE01819-MAS00107,History data 33-Month,2,
IDE01819-MAS00108,History data 33-Day,23,
IDE01819-MAS00109,History data 33-Hours,20, H
IDE01819-MAS00110,History data 33-Minutes,3, min
IDE01819-MAS14375,History data 33-Cycle counter,107,
IDE01819-MAS14393,History data 33-ID of the alerting message,1A 55 55 A8,
IDE01819-MAS14394,History data 33-Bus of the alerting message,Comfort data bus,
IDE01819-MAS20474,History data 33-Cluster,00 00 00,
IDE01820-IDE07142,History data 34-Time since terminal 15 off,0.0, H
IDE01820-MAS00106,History data 34-Year,2022,
IDE01820-MAS00107,History data 34-Month,3,
IDE01820-MAS00108,History data 34-Day,17,
IDE01820-MAS00109,History data 34-Hours,11, H
IDE01820-MAS00110,History data 34-Minutes,26, min
IDE01820-MAS14375,History data 34-Cycle counter,212,
IDE01820-MAS14393,History data 34-ID of the alerting message,1B 00 00 67,
IDE01823-IDE07142,History data 37-Time since terminal 15 off,0.0, H
IDE01823-MAS00106,History data 37-Year,2011,
IDE01823-MAS00107,History data 37-Month,1,
IDE01823-MAS00108,History data 37-Day,1,
IDE01823-MAS00109,History data 37-Hours,0, H
IDE01823-MAS00110,History data 37-Minutes,0, min
IDE01823-MAS01632,History data 37-Status,activated,
IDE01823-MAS14375,History data 37-Cycle counter,213,
IDE01823-MAS14429,History data 37-Time in current cycle,0.1, H
IDE01831-MAS03159,Generator variant-Manufacturer,Robert Bosch GmbH,
IDE01831-MAS06310,Generator variant-Generator identifier,82A - 140A,
IDE01831-MAS06311,Generator variant-ASIC manufacturer,0,
IDE01831-MAS06312,Generator variant-ASIC variant,4,
IDE01831-MAS21176,Generator variant-Generator model,5,
IDE01847,Auxiliary heater activation restriction request,Permitted,
IDE01847-MAS06319,Auxiliary heater activation restriction request-Allowed parking heater runtime,60, min
IDE01848,Energy balance of last driving cycle,3.9, Ah
IDE01848-IDE01849,Energy balance of last driving cycle-Previous journey duration,0.1, H
IDE01985-MAS06855,FAZIT identification test sum-Test sum,B4 33 1B 24,
IDE01992-ENG100904,Installation list: current installations-ECUs present,|ECU present Bit 0,ECU present Bit 1
IDE01995-ENG103538,Control module protocol information-ECUs DiagProt,|ISO-TP,TP 2.0
IDE02384-ENG102478,Status of event memory-ECU Dtcs,|ECU Dtc Bit 0,ECU Dtc Bit 1
IDE03008-IDE01838,Stop process prevented-Battery temperature,not active,
IDE03008-IDE01844,Stop process prevented-Increase idle speed request,not active,
IDE03008-MAS04054,Stop process prevented-Consumer/component current too high,not active,
IDE03008-MAS04055,Stop process prevented-Withdrawable battery charge too low,not active,
IDE03008-MAS04056,Stop process prevented-Battery state of charge too low,not active,
IDE03008-MAS04062,Stop process prevented-Possible standing time too short,not active,
IDE03008-MAS06001,Stop process prevented-Energy management special veto,not active,
IDE03008-MAS06002,Stop process prevented-DC/DC converter Veto,not active,
IDE03008-MAS19121,Stop process prevented-Successful restart done through freight quota,not active,
IDE03150-ENG36946,Readiness for bus sleep mode-ECU_Sleepindication,|Sleep-Bit 0,Sleep-Bit 1
IDE03588-MAS05683,System malfunctions for active participants start/stop-Battery fault,0,
IDE03588-MAS06321,System malfunctions for active participants start/stop-System malfunction generator,0,
IDE03588-MAS06323,System malfunctions for active participants start/stop-Start/stop coordinator implausible,0,
IDE03588-MAS06326,System malfunctions for active participants start/stop-Communication malfunction battery data module,0,
IDE03588-MAS06327,System malfunctions for active participants start/stop-Battery data module defective,0,
IDE04329-ENG118721,Status of all SWaP functions-SWaP_function_state array,|ID number,Release code for a SWaP function
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04343-ENG36947,Bus identification-ECU_databus_identification,|bus_number,bus_type|TNF 167462
IDE04806-ENG06028,Driving profile selection button-Driving_Profile_Selection_Button_1,Not operated,
IDE04806-ENG06029,Driving profile selection button-Driving_Profile_Selection_Button_2,Not operated,
IDE04806-ENG06030,Driving profile selection button-Driving_Profile_Selection_Button_3,Not operated,
IDE04806-ENG06031,Driving profile selection button-Driving_Profile_Selection_Button_4,Not operated,
IDE04806-ENG06032,Driving profile selection button-Driving_Profile_Selection_Button_5,Not operated,
IDE04806-ENG06033,Driving profile selection button-Driving_Profile_Selection_Button_6,Not operated,
IDE04806-ENG06034,Driving profile selection button-Driving_Profile_Selection_Button_7,Not operated,
IDE04806-ENG06035,Driving profile selection button-Driving_Profile_Selection_Button_8,Not operated,
IDE05740-MAS05376,Driving profile selection: system status-Coordinator status,active,
IDE05740-ENG124962,Driving profile selection: system status-link_state,not engaged,
IDE05740-ENG125035,Driving profile selection: system status-operation_state,engaged,
IDE05740-ENG124115,Driving profile selection: system status-profile_state,engaged,
IDE05814,Individualization characteristic,EA 07 BB E0 6D,
IDE05960-IDE01827,Generator-Specified generator voltage,13.5, V
IDE05960-IDE01828,Generator-Generator DF Signal,51.625, %
IDE05960-IDE01829,Generator-Generator exciter current,2.750, A
IDE05960-IDE01830,Generator-Generator Status,On,
IDE05960-IDE01855,Generator-Generator current,44.1, A
IDE05960-MAS06306,Generator-Status generator release by engine,Request by Engine Control Module,
IDE05960-MAS06307,Generator-Status of battery charging function,not active,
IDE05960-MAS11758,Generator-Identification,Yes,
IDE05960-MAS14589,Generator-mechanical power,800, W
IDE05960-MAS21174,Generator-Generator reserve current,82.9, A
IDE05960-MAS21325,Generator-Ramp time,3, s
IDE06011-ENG118665,Selected driving profile-driving_profile,Dynamic,
IDE06011-ENG124961,Selected driving profile-link_profile,link_profile_1,
IDE06011-ENG26214,Selected driving profile-Operation_mode,Unknown (0),
IDE06165-MAS06193,Driving profile selection statistics-Profile 1,1223, min
IDE06165-MAS06194,Driving profile selection statistics-Profile 2,0, min
IDE06165-MAS06195,Driving profile selection statistics-Profile 3,1951, min
IDE06165-MAS06196,Driving profile selection statistics-Profile 4,0, min
IDE06165-MAS06197,Driving profile selection statistics-Profile 5,0, min
IDE06165-MAS06198,Driving profile selection statistics-Profile 6,2, min
IDE06165-MAS06199,Driving profile selection statistics-Profile 7,0, min
IDE06165-MAS06200,Driving profile selection statistics-Profile 8,8, min
IDE06165-MAS08875,Driving profile selection statistics-Profile 9,0, min
IDE06165-MAS08876,Driving profile selection statistics-Profile 10,0, min
IDE06165-MAS08877,Driving profile selection statistics-Profile 11,0, min
IDE06165-MAS08878,Driving profile selection statistics-Profile 12,0, min
IDE06230-MAS00106,Break recommend.: last message-Year,2001,
IDE06230-MAS00107,Break recommend.: last message-Month,1,
IDE06230-MAS00108,Break recommend.: last message-Day,1,
IDE06230-MAS00109,Break recommend.: last message-Hours,0,
IDE06230-MAS00110,Break recommend.: last message-Minutes,0,
IDE06230-MAS00111,Break recommend.: last message-Seconds,0,
IDE06230-MAS03095,Break recommend.: last message-Function status,Initialization,
IDE06230-MAS04622,Break recommend.: last message-Break recommend. message,No message,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,04,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Master,
IDE07184-MAS06023,MFL button for freely assignable function-Parameter actuation of Joker FPA button,Not operated,
IDE07184-MAS06024,MFL button for freely assignable function-Parameter programming of Joker FPA button,not active,
IDE07628-IDE07629,Status power receptacle-Function release power receptacle,locked,
IDE07628-IDE07630,Status power receptacle-Pre-warning power receptacle,not active,
IDE07628-MAS01581,Status power receptacle-Power consumption,0, W
IDE07628-MAS06331,Status power receptacle-Enabling self-contained operation,locked,
IDE07628-MAS06332,Status power receptacle-Status function readiness,locked,
IDE07628-MAS06333,Status power receptacle-Status function,OFF,
IDE07628-MAS06334,Status power receptacle-Status overtemperature,in correct range,
IDE07628-MAS06341,Status power receptacle-After-run for power receptacle,not active,
IDE07628,Status power receptacle,---,
IDE07636-MAS06335,Status hybrid DC/DC converter-Voltage low voltage side DCDC - converter,14.3, V
IDE07636-MAS06336,Status hybrid DC/DC converter-Current current DCDC - converter,0, A
IDE07636-MAS06337,Status hybrid DC/DC converter-DCDC converter reserve current,0, A
IDE07640-MAS06344,Analysis of start voltage behavior-Minimum voltage at last engine start,9.80,
IDE07640-MAS06345,Analysis of start voltage behavior-Minimum voltage at last engine start recognized,not detected,
IDE07640-MAS06346,Analysis of start voltage behavior-Voltage drop through engine start recognized,not detected,
IDE07640-MAS06347,Analysis of start voltage behavior-Current voltage drop last start,0.00, V
IDE07640-MAS06348,Analysis of start voltage behavior-Normed voltage drop,0.00, V
IDE07640-MAS11064,Analysis of start voltage behavior-Current last engine start,864, A
IDE07640-MAS11065,Analysis of start voltage behavior-Current delta last engine start,856, A
IDE07640,Analysis of start voltage behavior,---,
IDE08343,Immobilizer Challenge,C1 6C FF 66,
IDE08346-MAS06117,Generator Analysis-Specified voltage,16.0, V
IDE08346-MAS06864,Generator Analysis-Generator actual voltage,13.3, V
IDE08346-MAS06865,Generator Analysis-Voltage difference generator battery,0.0, V
IDE08346-MAS06866,Generator Analysis-Generator speed,1870, /min
IDE08346-MAS06867,Generator Analysis-Generator chip temperature,64, °C
IDE08794-MAS06106,Battery cell analysis-Battery technology,Unknown,
IDE08794-MAS07703,Battery cell analysis-Cell voltage,0.0000, V
IDE08794-MAS07704,Battery cell analysis-Cell temp.,-40, °C
IDE08794-MAS07705,Battery cell analysis-Cell limit voltage (binary coded),0,
IDE08794-MAS07706,Battery cell analysis-Can be analyzed,Initialization,
IDE08794-MAS07707,Battery cell analysis-Health condition acc. to calendar,100, %
IDE08794-MAS07708,Battery cell analysis-Cut-off element,closed,
IDE08794,Battery cell analysis,---,
IDE09058-IDE06233,Energy management: consumer releases-Auxiliary heater: controlled,0, W
IDE09058-IDE06234,Energy management: consumer releases-Auxiliary heater: in stages,not enabled,
IDE09058-IDE80251,Energy management: consumer releases-Head area heater,Enabling stage 3,
IDE09058-MAS01490,Energy management: consumer releases-Energy management,not active,
IDE09058-MAS01535,Energy management: consumer releases-Rear window defogger,Enabled,
IDE09058-MAS01564,Energy management: consumer releases-Front windshield heater,Enabled,
IDE09058-MAS05213,Energy management: consumer releases-Mirror heater,Enabled,
IDE09058-MAS05214,Energy management: consumer releases-Steering wheel heating,Enabled,
IDE09058-MAS05795,Energy management: consumer releases-Rear seat heater,Enabling stage 3,
IDE09058-MAS05887,Energy management: consumer releases-Battery cut out relay 2,not enabled,
IDE09058-MAS06551,Energy management: consumer releases-Seat ventilation,Enabling stage 3,
IDE09058-MAS06552,Energy management: consumer releases-Front seat heating,Enabling stage 3,
IDE09058-MAS06553,Energy management: consumer releases-Display consumer switch-off,not active,
IDE09058-MAS21177,Energy management: consumer releases-Shut-off status,not active,
IDE09074-MAS01078,Vehicle properties-Vehicle model,Conventional combustion engine,
IDE09074-MAS08256,Vehicle properties-Max energy content,327400, Wh
IDE09074-MAS08262,Vehicle properties-Vehicle type recognition,performed without error,
IDE09075-MAS08266,Calculation: basic average values-Average consumption:BMS electrical (prognosis limit),14.0, kWh/100 km
IDE09075-MAS08267,Calculation: basic average values-Range average consumption: combustion engine,7.5, l/100km
IDE09075-MAS08268,Calculation: basic average values-Range average consumption: electrical,13.0, kWh/100 km
IDE09075-MAS08269,Calculation: basic average values-Calculated average speed: electrical trip,33.8, km/h
IDE09075-MAS08271,Calculation: basic average values-Calculated power: component A/C,0, W
IDE09075-MAS08272,Calculation: basic average values-Calculated power: low voltage basic consumer,400, W
IDE09075-MAS09165,Calculation: basic average values-medium forecast error performance air-conditioning interior,0, W
IDE09075-MAS10152,Calculation: basic average values-Range average consumption CNG,10.0, l/100km
IDE09075-MAS10153,Calculation: basic average values-Range average consumption LPG,0.0, kWh/100 km
IDE09076-MAS08273,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining the range: combustion engine,540, km
IDE09076-MAS08274,Calculated filtered remaining ranges (internal)-Calculated and filtered electrical remaining range,0, km
IDE09076-MAS08275,Calculated filtered remaining ranges (internal)-Average current load profile provided by battery,13, A
IDE09076-MAS10154,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: CNG,0, km
IDE09076-MAS10155,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: LPG,0, km
IDE09077-MAS08276,Calculated filtered remaining ranges (CAN)-Total remaining range,540, km
IDE09077-MAS08277,Calculated filtered remaining ranges (CAN)-Filtered remaining range: combustion engine,540, km
IDE09077-MAS08278,Calculated filtered remaining ranges (CAN)-Filtered remaining range: electric motor,0, km
IDE09077-MAS10156,Calculated filtered remaining ranges (CAN)-Filtered remaining range CNG,2047, km
IDE09077-MAS10157,Calculated filtered remaining ranges (CAN)-Filtered remaining range LPG,0, km
IDE09078-MAS08279,Calculated remaining ranges (display values)-Total remaining range: displayed value,340,
IDE09078-MAS08280,Calculated remaining ranges (display values)-Remaining range: displayed value: primary drive,340,
IDE09078-MAS08281,Calculated remaining ranges (display values)-Remaining range: displayed value: secondary drive,2045,
IDE09078-MAS08282,Calculated remaining ranges (display values)-Remaining range display value units,miles,
IDE09079-MAS10158,Calculated street class consumptions-Average fuel consumption on street class 0,5.0, l/100km
IDE09079-MAS10159,Calculated street class consumptions-Average fuel consumption on street class 1,5.0, l/100km
IDE09079-MAS10160,Calculated street class consumptions-Average fuel consumption on street class 2,5.0, l/100km
IDE09079-MAS10161,Calculated street class consumptions-Average fuel consumption on street class 3,5.0, l/100km
IDE09079-MAS10162,Calculated street class consumptions-Average fuel consumption on street class 4,5.0, l/100km
IDE09079-MAS10163,Calculated street class consumptions-Average fuel consumption on street class 5,5.0, l/100km
IDE09079-MAS10164,Calculated street class consumptions-Average fuel consumption on street class 6,0.0, l/100km
IDE09079-MAS10165,Calculated street class consumptions-Electrical average consumption on Street Class 0,13.0, kWh/100 km
IDE09079-MAS10166,Calculated street class consumptions-Electrical average consumption on Street Class 1,13.0, kWh/100 km
IDE09079-MAS10167,Calculated street class consumptions-Electrical average consumption on Street Class 2,13.0, kWh/100 km
IDE09079-MAS10168,Calculated street class consumptions-Electrical average consumption on Street Class 3,13.0, kWh/100 km
IDE09079-MAS10169,Calculated street class consumptions-Electrical average consumption on Street Class 4,13.0, kWh/100 km
IDE09079-MAS10170,Calculated street class consumptions-Electrical average consumption on Street Class 5,13.0, kWh/100 km
IDE09079-MAS10171,Calculated street class consumptions-Electrical average consumption on Street Class 6,0.0, kWh/100 km
IDE09080-MAS08264,Energy storage unit-Tank contents: conventional fuel including RWB-internal deduct,40.4, l
IDE09080-MAS08265,Energy storage unit-Energy content of HV battery: RWB-internal deduction,0, Wh
IDE09080-MAS10150,Energy storage unit-CNG tank volume incl. RWB inter. deduct. value,0.0, kg
IDE09080-MAS10151,Energy storage unit-LPG tank volume incl. RWB inter. deduct. value,0.0, l
IDE10300,OBD Driving Cycle detected,active,
IDE10674-MAS11055,Extended battery diagnosis-Pulse interior resistance,3.2, mOhm
IDE10674-MAS11056,Extended battery diagnosis-Counter battery warning,0,
IDE10674-MAS11059,Extended battery diagnosis-Power state LV battery singular operation,OK,
IDE10739-IDE04447,Status: driving profile selection for oper. mode selection-Function status,not engaged,
IDE10739-IDE06260,Status: driving profile selection for oper. mode selection-ID number,81,
IDE10739-MAS01156,Status: driving profile selection for oper. mode selection-Communication status,OK,
IDE10739-MAS01447,Status: driving profile selection for oper. mode selection-Act.val.,0,
IDE11127-IDE04332,Error-causing FS ID with status-Release code for a SWaP function,Not available,
IDE11127-IDE05814,Error-causing FS ID with status-Individualization characteristic,invalid,
IDE11127-IDE06260,Error-causing FS ID with status-ID number,00 00 00 00,
IDE11127-MAS01340,Error-causing FS ID with status-Functions,Not available,
IDE11127-MAS01903,Error-causing FS ID with status-Configuration,not OK,
IDE11127-MAS02934,Error-causing FS ID with status-Preconditions met,Condition not met,
IDE11127-MAS05616,Error-causing FS ID with status-Cancellation,Yes,
IDE11127-MAS05617,Error-causing FS ID with status-Authentication,Condition not met,
IDE11673-MAS02246,Battery Management 2: prohibition on turning-on 48V-Timeout,not active,
IDE11673-MAS03123,Battery Management 2: prohibition on turning-on 48V-Reduced performance,not active,
IDE11673-MAS09519,Battery Management 2: prohibition on turning-on 48V-Message error,not active,
IDE11673-MAS09541,Battery Management 2: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11673-MAS09542,Battery Management 2: prohibition on turning-on 48V-Error status init. error,not active,
IDE11673-MAS09543,Battery Management 2: prohibition on turning-on 48V-Operating mode error,not active,
IDE11673-MAS09544,Battery Management 2: prohibition on turning-on 48V-No component function,not active,
IDE11673-MAS09545,Battery Management 2: prohibition on turning-on 48V-Sequence error,not active,
IDE11674-MAS02246,Voltage transformer: prohibition on turning-on 48V-Timeout,not active,
IDE11674-MAS09519,Voltage transformer: prohibition on turning-on 48V-Message error,not active,
IDE11674-MAS09541,Voltage transformer: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11674-MAS09542,Voltage transformer: prohibition on turning-on 48V-Error status init. error,not active,
IDE11674-MAS09543,Voltage transformer: prohibition on turning-on 48V-Operating mode error,not active,
IDE11674-MAS09544,Voltage transformer: prohibition on turning-on 48V-No component function,not active,
IDE11674-MAS09545,Voltage transformer: prohibition on turning-on 48V-Sequence error,not active,
IDE11676-MAS00799,Airbag: prohibition on turning-on 48V-Airbag control module,not active,
IDE11676-MAS02246,Airbag: prohibition on turning-on 48V-Timeout,not active,
IDE11676-MAS09519,Airbag: prohibition on turning-on 48V-Message error,not active,
IDE11676-MAS09521,Airbag: prohibition on turning-on 48V-Light accident detected,not active,
IDE11676-MAS09522,Airbag: prohibition on turning-on 48V-Severe accident detected,not active,
IDE11678-MAS02246,Engine electronics: prohibition on turning-on 48V-Timeout,not active,
IDE11678-MAS09519,Engine electronics: prohibition on turning-on 48V-Message error,not active,
IDE11678-MAS09541,Engine electronics: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11678-MAS09545,Engine electronics: prohibition on turning-on 48V-Sequence error,not active,
IDE11678-MAS09547,Engine electronics: prohibition on turning-on 48V-Error status drive motor: init. error,not active,
IDE11678-MAS09548,Engine electronics: prohibition on turning-on 48V-Error status drive: init. error,not active,
IDE11678-MAS09549,Engine electronics: prohibition on turning-on 48V-Drive condition: init. error,not active,
IDE11678-MAS09554,Engine electronics: prohibition on turning-on 48V-no component function drive,not active,
IDE11678-MAS13413,Engine electronics: prohibition on turning-on 48V-No component function of starter generator,not active,
IDE11678-MAS13415,Engine electronics: prohibition on turning-on 48V-48 V shut-down due to operating strategy,not active,
IDE11681-MAS03182,Monitoring line disconnection: prohibition on turning-on 48V-Branch 1,not active,
IDE11681-MAS03183,Monitoring line disconnection: prohibition on turning-on 48V-Branch 2,not active,
IDE11683-MAS13705,Engine electronics: status of 48V network-Error status of starter generator,No malfunction detected,
IDE11683-MAS13716,Engine electronics: status of 48V network-Error status of drive,No malfunction detected,
IDE11683-MAS13717,Engine electronics: status of 48V network-State of drive,OFF,
IDE11683-MAS13718,Engine electronics: status of 48V network-Handshake,0,
IDE11684-MAS02832,Battery management 2: status for 48V power-Malfunction status,Initialization,
IDE11684-MAS03001,Battery management 2: status for 48V power-Mode,Initialization,
IDE11685-MAS02832,Voltage converter: status for 48V power-Malfunction status,Initialization,
IDE11685-MAS03001,Voltage converter: status for 48V power-Mode,Initialization,
IDE11728,Ethernet signal quality: branch 1,good: link available,
IDE11729,Ethernet signal quality: branch 2,good: link available,
IDE11730,Ethernet signal quality: branch 3,good: link available,
IDE11731,Ethernet signal quality: branch 4,good: link available,
IDE11732,Ethernet signal quality: branch 5,good: link available,
IDE11733,Ethernet signal quality: branch 6,good: link available,
IDE11736,Ethernet counter connection interruptions: branch 1,0,
IDE11737,Ethernet counter connection interruptions: branch 2,2,
IDE11738,Ethernet counter connection interruptions: branch 3,2,
IDE11739,Ethernet counter connection interruptions: branch 4,3,
IDE11740,Ethernet counter connection interruptions: branch 5,8,
IDE11741,Ethernet counter connection interruptions: branch 6,2,
IDE11744,Ethernet counter checksum error: branch 1,0,
IDE11745,Ethernet counter checksum error: branch 2,0,
IDE11746,Ethernet counter checksum error: branch 3,0,
IDE11747,Ethernet counter checksum error: branch 4,0,
IDE11748,Ethernet counter checksum error: branch 5,0,
IDE11749,Ethernet counter checksum error: branch 6,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 10|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 10|FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 10|FD 53 7C B8 03 83 00 05 00 00 00 00 00 00 00 10|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 08|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 61|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 37|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 50|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 5B|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 09|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 31|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 32|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 46|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 29|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 28|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0C|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 03|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 04|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 2D|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 08|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 10|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0F|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0E|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 02|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 06|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 19|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0D|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0B|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0C|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 1D|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 1B|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 1C|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 1A|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|2|3|4|5|,
IDE11756,IP network: counter messages with inadmissible VLANs,3252,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,1970,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|00 36 F8 63 EE 08|,
IDE11762-IDE02766,Information break recommendation-Malfunction status,not installed,
IDE11762-MAS03095,Information break recommendation-Function status,not installed,
IDE11762-MAS04622,Information break recommendation-Break recommend. message,No message,
IDE11762-MAS13162,Information break recommendation-Icon deactivated,No,
IDE11869,IP network: NDP cache,|MAC address,IPv6 address
IDE11911-MAS00799,48V activation restriction-Airbag control module,not active,
IDE11911-MAS09516,48V activation restriction-Engine Electronics,not active,
IDE11911-MAS13411,48V activation restriction-48 V activation restriction due to open circuit,not active,
IDE11911-MAS13412,48V activation restriction-48 V activation restriction due to deactivation,not active,
IDE11911-SFT00033,48V activation restriction-Battery management 2,not active,
IDE11911-SFT00196,48V activation restriction-Voltage converter,not active,
IDE11988-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 1-MAC address,Write only channel,
IDE11989-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 2-MAC address,Write only channel,
IDE11990-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 3-MAC address,|MAC address|02 7D FA 00 14 00|,
IDE11991-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 4-MAC address,|MAC address|44 3C 88 14 10 A5|,
IDE11992-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 5-MAC address,|MAC address|30 B4 B8 B5 82 D0|00 13 43 CA 87 AE|,
IDE11993-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 6-MAC address,|MAC address|30 B4 B8 C6 B7 10|,
IDE12084-IDE02185,Component protection participant status-IKA key,stored,
IDE12084-IDE10163,Component protection participant status-Authorization status,valid authentication,
IDE12084-MAS06772,Component protection participant status-Component protection generation,Generation 2,
IDE12084-MAS13795,Component protection participant status-Node address,00 0E,
IDE12084-MAS16977,Component protection participant status-Shut-off of the start authentication,locked,
IDE12084-MAS16978,Component protection participant status-Start authentication,switched on,
IDE12084-MAS18011,Component protection participant status-Query message,Sent,
IDE12084-ENG26234,Component protection participant status-Status_of_component_protection_slaves,|Node address,IKA key
IDE12133-MAS01896,Freewheel - energy-Free run,45, A
IDE12133-MAS14352,Freewheel - energy-Auxiliary store current,0, A
IDE12133-MAS14353,Freewheel - energy-Loading release for additional memory,Reduced charge DC/DC converter,
IDE12133-MAS14357,Freewheel - energy-Generator start mode,First start,
IDE12133-MAS14362,Freewheel - energy-Voltage limit boost mode,6.0, V
IDE12134-MAS14344,Freewheel - condition-Status of coasting release,Release,
IDE12134-MAS14348,Freewheel - condition-Status of freewheel engine off release,Release,
IDE12134-MAS14349,Freewheel - condition-Freewheel engine off block,0,
IDE12134-MAS14350,Freewheel - condition-Store request,no request,
IDE12134-MAS14351,Freewheel - condition-Freewheel engine off restart,0,
IDE12230-MAS14856,IP network: VLANs of Ethernet switch ports branch 1-VLAN,Write only channel,
IDE12231-MAS14856,IP network: VLANs of Ethernet switch ports branch 2-VLAN,|VLAN|5|,
IDE12232-MAS14856,IP network: VLANs of Ethernet switch ports branch 3-VLAN,|VLAN|5|,
IDE12233-MAS14856,IP network: VLANs of Ethernet switch ports branch 4-VLAN,|VLAN|2|,
IDE12234-MAS14856,IP network: VLANs of Ethernet switch ports branch 5-VLAN,|VLAN|3|,
IDE12235-MAS14856,IP network: VLANs of Ethernet switch ports branch 6-VLAN,|VLAN|4|,
IDE12238,I network: discarded messages counter,1984,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73
IDE12609-MAS02832,Steering wheel touch recognition: status-Malfunction status,No malfunction detected,
IDE12609-MAS14836,Steering wheel touch recognition: status-Touch intensity sensor 1,0,
IDE12609-MAS14837,Steering wheel touch recognition: status-Touch intensity sensor 2,0,
IDE12609-MAS14838,Steering wheel touch recognition: status-Touch intensity sensor 3,0,
IDE12609-MAS14839,Steering wheel touch recognition: status-Touch status,not touching,
IDE12625,IP network: current link deceleration: branch 1,65535, µs
IDE12626,IP network: current link deceleration: branch 2,65535, µs
IDE12627,IP network: current link deceleration: branch 3,65535, µs
IDE12628,IP network: current link deceleration: branch 4,65535, µs
IDE12629,IP network: current link deceleration: branch 5,65535, µs
IDE12630,IP network: current link deceleration: branch 6,65535, µs
IDE12633,IP Network maximum correction of the synchronized clock,-1, µs
IDE12806-ENG36980,Diagnostic capability of the bus interface-Diag_paths,|Diag_path Bit 0,Diag_path Bit 1
IDE12807-ENG36983,Participant authenticity-Ecu_authentications,|Ecu_authentication Bit 0,Ecu_authentication Bit 1
IDE12844-ENG36948,Installation list of the 10 bit node addresses-Node_addresses,|Node address,ECU Name
IDE12939-MAS02643,Public key for SWaP function (3072)-Key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
IDE13679-MAS01461,Power generator status-Electrical malfunction,electrically OK,
IDE13679-MAS01574,Power generator status-Mechanical malfunction,Mechanical OK,
IDE13679-MAS06304,Power generator status-Status overvoltage diagnosis,not active,
IDE13679-MAS06305,Power generator status-Status of diagnosis for energy balance,not active,
IDE13679-MAS21175,Power generator status-Generator temperature error,Thermal OK,
IDE13679-ENG124632,Power generator status-error_primary_circuit,not active,
IDE13754-IDE04447,Diagnosis filter: status-Function status,Function active,
IDE13754-MAS16866,Diagnosis filter: status-Odometer,20, km
IDE13754-MAS16867,Diagnosis filter: status-Reason for deactivation,hood open,
IDE13754-MAS16875,Diagnosis filter: status-Filter status,Filter is not active,
IDE13755-IDE00056,Diagnosis filter: history data-History data 1,00003969*2022-03-17-11:33:15*1*,
IDE13755-IDE00057,Diagnosis filter: history data-History data 2,00003969*2022-03-17-11:25:59*0*,
IDE13755-IDE00058,Diagnosis filter: history data-History data 3,00003958*2022-03-17-10:57:09*0*,
IDE13755-IDE00059,Diagnosis filter: history data-History data 4,00003952*2022-03-17-10:28:26*0*,
IDE13755-IDE00060,Diagnosis filter: history data-History data 5,00003786*2022-03-17-08:30:19*0*,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVWFB7CD8NW129409,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,12,
IDE13845,Production mode status,not active,
IDE14151-MAS13098,Route-based range calculation-Power drawn by thermal management,650, W
IDE14151-MAS14375,Route-based range calculation-Cycle counter,0,
IDE14151-MAS17899,Route-based range calculation-Route-based range calculation status,not active,
IDE14151-MAS17900,Route-based range calculation-Classified consumption,30.0, kWh/100 km
IDE14151-MAS17901,Route-based range calculation-Classified consumption 2,22.5, kWh/100 km
IDE14151-MAS17902,Route-based range calculation-Classified consumption 3,20.0, kWh/100 km
IDE14151-MAS17903,Route-based range calculation-Classified consumption 4,17.0, kWh/100 km
IDE14151-MAS17904,Route-based range calculation-Classified consumption 5,16.5, kWh/100 km
IDE14151-MAS17905,Route-based range calculation-Classified consumption 6,17.0, kWh/100 km
IDE14151-MAS17906,Route-based range calculation-Classified consumption 7,17.5, kWh/100 km
IDE14151-MAS17907,Route-based range calculation-Classified consumption 8,18.0, kWh/100 km
IDE14151-MAS17908,Route-based range calculation-Classified consumption 9,20.0, kWh/100 km
IDE14151-MAS17909,Route-based range calculation-Classified consumption 10,22.0, kWh/100 km
IDE14151-MAS17910,Route-based range calculation-Calculated consumption,30.0, kWh/100 km
IDE14151-MAS17911,Route-based range calculation-Calculated consumption 2,22.5, kWh/100 km
IDE14151-MAS17912,Route-based range calculation-Calculated consumption 3,20.0, kWh/100 km
IDE14151-MAS17913,Route-based range calculation-Calculated consumption 4,17.0, kWh/100 km
IDE14151-MAS17914,Route-based range calculation-Calculated consumption 5,16.5, kWh/100 km
IDE14151-MAS17915,Route-based range calculation-Calculated consumption 6,17.0, kWh/100 km
IDE14151-MAS17916,Route-based range calculation-Calculated consumption 7,17.5, kWh/100 km
IDE14151-MAS17917,Route-based range calculation-Calculated consumption 8,18.0, kWh/100 km
IDE14151-MAS17918,Route-based range calculation-Calculated consumption 9,20.0, kWh/100 km
IDE14151-MAS17919,Route-based range calculation-Calculated consumption 10,22.0, kWh/100 km
IDE14151-MAS17921,Route-based range calculation-Comfort consumers power consumption,650, W
IDE14151-MAS17922,Route-based range calculation-Route-based range raw value with comfort consumers,0,
IDE14151-MAS17923,Route-based range calculation-Route-based range raw value without comfort consumers,0,
IDE14151-MAS17924,Route-based range calculation-Residual energy content without comfort consumers,0.00,
IDE14151-MAS17925,Route-based range calculation-Residual energy content with comfort consumers,0.00,
IDE14151-MAS17926,Route-based range calculation-Type of route,OFF,
IDE14151-MAS17927,Route-based range calculation-Range reference,65533,
IDE14151-MAS17928,Route-based range calculation-Maximum range,65533,
IDE14151-MAS17929,Route-based range calculation-Total coverage,65532,
IDE14151-MAS17930,Route-based range calculation-Range from destination,65532,
IDE14151-MAS17931,Route-based range calculation-Route-based range,65532,
IDE14151-MAS17932,Route-based range calculation-Recalculation status,not performed,
IDE14169-IDE08660,Autonomous recharging-Recharging the NV battery,no request,
IDE14169-MAS07409,Autonomous recharging-Status automatic recharging of low-voltage battery,Malfunction,
IDE14260-MAS12984,12V lead battery test pulse: low-voltage energy management-Reason for rejection,0,
IDE14260-MAS21182,12V lead battery test pulse: low-voltage energy management-Bad counter,0,
IDE14260-MAS21183,12V lead battery test pulse: low-voltage energy management-Test pulse counter not OK,134,
IDE14260-MAS21184,12V lead battery test pulse: low-voltage energy management-Counter increase not OK,150,
IDE14260-ENG124430,12V lead battery test pulse: low-voltage energy management-BZE_test_pulse_request,3,
IDE14260-ENG124431,12V lead battery test pulse: low-voltage energy management-BZE_test_pulse_result,3,
IDE14265,Battery display: source of initiation,0,
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC time server,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 51 29 41 38 DF A0 AC,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,4,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 2E,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE15027-MAS21296,Low-voltage EM on middle-voltage EM signals-48V electrical system charging approval,No,
IDE15027-MAS21297,Low-voltage EM on middle-voltage EM signals-Low-voltage energy management status,System active: driving mode,
IDE15027-MAS21328,Low-voltage EM on middle-voltage EM signals-Low-voltage EM request for lowering medium-voltage EM,No,
IDE15027-MAS21329,Low-voltage EM on middle-voltage EM signals-Low-voltage EM approval for increasing medium-voltage EM,Yes,
IDE15027-MAS21330,Low-voltage EM on middle-voltage EM signals-Low-voltage EM approval for increasing medium-voltage EM,No,
IDE15027-MAS21331,Low-voltage EM on middle-voltage EM signals-Low-voltage EM approved charge capacity for medium-voltage EM,0, W
IDE15101,Status of lithium-ion battery,OK,
MAS00464-MAS00106,Standard - ambient data 1-Year,2114,
MAS00464-MAS00107,Standard - ambient data 1-Month,15,
MAS00464-MAS00108,Standard - ambient data 1-Day,2,
MAS00464-MAS00109,Standard - ambient data 1-Hours,5,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,21,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,58,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,56,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,3969, km
MAS00769-IDE02717,Multifunction steering wheel control module-Tiptronic upshift,Not operated,
MAS00769-IDE02718,Multifunction steering wheel control module-Tiptronic downshift,Not operated,
MAS00769-IDE07668,Multifunction steering wheel control module-MFL Variant code,10,
MAS00769-MAS01065,Multifunction steering wheel control module-Brand,VW,
MAS00769-MAS01288,Multifunction steering wheel control module-Horn,Not operated,
MAS00769-MAS02317,Multifunction steering wheel control module-Button code 1,Not operated,
MAS00769-MAS02318,Multifunction steering wheel control module-Button code 2,Not operated,
MAS00769-MAS02319,Multifunction steering wheel control module-Event code 1,No result,
MAS00769-MAS02320,Multifunction steering wheel control module-Event code 2,No result,
MAS00769-MAS06029,Multifunction steering wheel control module-MFL message counter,1,
MAS00769-MAS06030,Multifunction steering wheel control module-MFL Toggle Bit,1,
MAS00769-MAS06034,Multifunction steering wheel control module-MFL Local active,not active,
MAS00769-MAS06035,Multifunction steering wheel control module-MFL M button,Not operated,
MAS02672-IDE03212,Start-stop-Start/stop conditions,Stop release,
MAS02672-IDE03213,Start-stop-Start/stop enable,System malfunction,
MAS02672-IDE03214,Start-stop-Engine stop using start-stop function,not active,
MAS02672-IDE07621,Start-stop-Permitted engine stop time,max.value,
MAS02672-IDE07622,Start-stop-Power consumption during idle phase,155, A
MAS04447-IDE06339,Engine running status-Hybrid readiness: status,not active,
MAS04447-MAS03023,Engine running status-Driving mode,active,
MAS04447-MAS05129,Engine running status-Motor,Engine running,
MAS04447-MAS20972,Engine running status-Redundant supply target mode,active,
MAS12666-ENG36960,SubSystemNodeAddress of sub bus participant-SubSystem Node Addresses,|SubSystem Node Address,Subsystem designation|00 1D
MAS12668-ENG36961,Actual installation of sub-bus users-SubSystems present,|SubSystem present Bit 0,SubSystem present Bit 1
MAS12669-ENG36959,Bus identification of sub-bus users-SubSystem Bus IDs,|Bus ID|81|81|81|0|0|0|0|0|82|82|0|0|0|0|0|0|83|83|0|0|0|0|0|0|0|0|0|0|0|0|0|0|,
MAS16744-IDE01836,12V battery-Battery current,9.861, A
MAS16744-IDE01837,12V battery-Temperature of battery sensor,48, °C
MAS16744-IDE01838,12V battery-Battery temperature,32, °C
MAS16744-IDE01839,12V battery-Battery charge level,89, %
MAS16744-IDE01841,12V battery-Battery internal resistance,3.4, mOhm
MAS16744-IDE01842,12V battery-Usable battery charge,91, Ah
MAS16744-IDE01948,12V battery-Battery internal resistance not normed,3.2, mOhm
MAS16744-IDE04186,12V battery-Battery terminal recognition,connected,
MAS16744-IDE08347,12V battery-adapted battery capacity,108, Ah
MAS16744-MAS00362,12V battery-Battery voltage,13.406, V
MAS16744-MAS06086,12V battery-Total re-charge,284.0, Ah
MAS16744-MAS06087,12V battery-Entire energy throughput,266.8, Ah
MAS16744-MAS22232,12V battery-Battery aging: charge-related,100, %
MAS16744-MAS22233,12V battery-Battery aging: performance-related,100, %
MAS16744,12V battery,---,
MAS16745-IDE01839,Quiescent current management-Battery charge level,140,
MAS16745-IDE01843,Quiescent current management-Battery voltage at rest,12.6, V
MAS16745-IDE01846,Quiescent current management-Static current shut-off stage,Deactivation stage 0,
MAS16745-IDE01852,Quiescent current management-Static current measurement: result,4094, mA
MAS16745-IDE01853,Quiescent current management-Static current measurement: status,Initialization,
MAS16745-IDE07623,Quiescent current management-Open-circuit voltage gateway,invalid,
MAS16745-IDE07907,Quiescent current management-Bus communication,active,
MAS16745-IDE09561,Quiescent current management-Static current last LIN sleep phase,-1.026, A
MAS16745,Quiescent current management,Initialization,
MAS17522-IDE04332,Unlockable functions: central activation status-Release code for a SWaP function,Not available,
MAS17522-IDE05814,Unlockable functions: central activation status-Individualization characteristic,invalid,
MAS17522-IDE06260,Unlockable functions: central activation status-ID number,10 00 03 00,
MAS17522-MAS01340,Unlockable functions: central activation status-Functions,available.,
MAS17522-MAS01903,Unlockable functions: central activation status-Configuration,OK,
MAS17522-MAS02934,Unlockable functions: central activation status-Preconditions met,Condition not met,
MAS17522-MAS05616,Unlockable functions: central activation status-Cancellation,No,
MAS17522-MAS05617,Unlockable functions: central activation status-Authentication,Condition not met,
MAS17522-MAS17839,Unlockable functions: central activation status-Number of functions which can be activated,31,
MAS17522-MAS17965,Unlockable functions: central activation status-Maximum at receiver control module per activation ID,8,
MAS17522-MAS17967,Unlockable functions: central activation status-Type of customization feature,00,
MAS17522-MAS18610,Unlockable functions: central activation status-Control module to be activated 1,00 19,
MAS17522-MAS18611,Unlockable functions: central activation status-Control module to be activated 2,00 00,
MAS17522-MAS18612,Unlockable functions: central activation status-Control module to be activated 3,00 00,
MAS17522-MAS18613,Unlockable functions: central activation status-Control module to be activated 4,00 00,
MAS17522-MAS18614,Unlockable functions: central activation status-Control module to be activated 5,00 00,
MAS17522-MAS18615,Unlockable functions: central activation status-Control module to be activated 6,00 00,
MAS17522-MAS18616,Unlockable functions: central activation status-Control module to be activated 7,00 00,
MAS17522-MAS18617,Unlockable functions: central activation status-Control module to be activated 8,00 00,
MAS17522-MAS18618,Unlockable functions: central activation status-Activation of SWaP function for control module 1,Not available,
MAS17522-MAS18619,Unlockable functions: central activation status-Activation of SWaP function for control module 2,Not available,
MAS17522-MAS18620,Unlockable functions: central activation status-Activation of SWaP function for control module 3,Not available,
MAS17522-MAS18621,Unlockable functions: central activation status-Activation of SWaP function for control module 4,Not available,
MAS17522-MAS18622,Unlockable functions: central activation status-Activation of SWaP function for control module 5,Not available,
MAS17522-MAS18623,Unlockable functions: central activation status-Activation of SWaP function for control module 6,Not available,
MAS17522-MAS18624,Unlockable functions: central activation status-Activation of SWaP function for control module 7,Not available,
MAS17522-MAS18625,Unlockable functions: central activation status-Activation of SWaP function for control module 8,Not available,
MAS17522-MAS18626,Unlockable functions: central activation status-Cancellation for control module 1,Yes,
MAS17522-MAS18627,Unlockable functions: central activation status-Cancellation for control module 2,Yes,
MAS17522-MAS18628,Unlockable functions: central activation status-Cancellation for control module 3,Yes,
MAS17522-MAS18629,Unlockable functions: central activation status-Cancellation for control module 4,Yes,
MAS17522-MAS18630,Unlockable functions: central activation status-Cancellation for control module 5,Yes,
MAS17522-MAS18631,Unlockable functions: central activation status-Cancellation for control module 6,Yes,
MAS17522-MAS18632,Unlockable functions: central activation status-Cancellation for control module 7,Yes,
MAS17522-MAS18633,Unlockable functions: central activation status-Cancellation for control module 8,Yes,
MAS17522-MAS18634,Unlockable functions: central activation status-Individualization feature for control module 1,invalid,
MAS17522-MAS18635,Unlockable functions: central activation status-Individualization feature for control module 2,invalid,
MAS17522-MAS18636,Unlockable functions: central activation status-Individualization feature for control module 3,invalid,
MAS17522-MAS18637,Unlockable functions: central activation status-Individualization feature for control module 4,invalid,
MAS17522-MAS18638,Unlockable functions: central activation status-Individualization feature for control module 5,invalid,
MAS17522-MAS18639,Unlockable functions: central activation status-Individualization feature for control module 6,invalid,
MAS17522-MAS18640,Unlockable functions: central activation status-Individualization feature for control module 7,invalid,
MAS17522-MAS18641,Unlockable functions: central activation status-Individualization feature for control module 8,invalid,
MAS17522-MAS18642,Unlockable functions: central activation status-Conditions met for control module 1,Condition not met,
MAS17522-MAS18643,Unlockable functions: central activation status-Conditions met for control module 2,Condition not met,
MAS17522-MAS18644,Unlockable functions: central activation status-Conditions met for control module 3,Condition not met,
MAS17522-MAS18645,Unlockable functions: central activation status-Conditions met for control module 4,Condition not met,
MAS17522-MAS18646,Unlockable functions: central activation status-Conditions met for control module 5,Condition not met,
MAS17522-MAS18647,Unlockable functions: central activation status-Conditions met for control module 6,Condition not met,
MAS17522-MAS18648,Unlockable functions: central activation status-Conditions met for control module 7,Condition not met,
MAS17522-MAS18649,Unlockable functions: central activation status-Conditions met for control module 8,Condition not met,
MAS17522-MAS18650,Unlockable functions: central activation status-Configuration for control module 1,OK,
MAS17522-MAS18651,Unlockable functions: central activation status-Configuration for control module 2,not OK,
MAS17522-MAS18652,Unlockable functions: central activation status-Configuration for control module 3,not OK,
MAS17522-MAS18653,Unlockable functions: central activation status-Configuration for control module 4,not OK,
MAS17522-MAS18654,Unlockable functions: central activation status-Configuration for control module 5,not OK,
MAS17522-MAS18655,Unlockable functions: central activation status-Configuration for control module 6,not OK,
MAS17522-MAS18656,Unlockable functions: central activation status-Configuration for control module 7,not OK,
MAS17522-MAS18657,Unlockable functions: central activation status-Configuration for control module 8,not OK,
MAS17522-MAS18658,Unlockable functions: central activation status-Functions in control module 1,available.,
MAS17522-MAS18659,Unlockable functions: central activation status-Functions in control module 2,Not available,
MAS17522-MAS18660,Unlockable functions: central activation status-Functions in control module 3,Not available,
MAS17522-MAS18661,Unlockable functions: central activation status-Functions in control module 4,Not available,
MAS17522-MAS18662,Unlockable functions: central activation status-Functions in control module 5,Not available,
MAS17522-MAS18663,Unlockable functions: central activation status-Functions in control module 6,Not available,
MAS17522-MAS18664,Unlockable functions: central activation status-Functions in control module 7,Not available,
MAS17522-MAS18665,Unlockable functions: central activation status-Functions in control module 8,Not available,
MAS17522-MAS18666,Unlockable functions: central activation status-Authentication for control module 1,Condition not met,
MAS17522-MAS18667,Unlockable functions: central activation status-Authentication for control module 2,Condition not met,
MAS17522-MAS18668,Unlockable functions: central activation status-Authentication for control module 3,Condition not met,
MAS17522-MAS18669,Unlockable functions: central activation status-Authentication for control module 4,Condition not met,
MAS17522-MAS18670,Unlockable functions: central activation status-Authentication for control module 5,Condition not met,
MAS17522-MAS18671,Unlockable functions: central activation status-Authentication for control module 6,Condition not met,
MAS17522-MAS18672,Unlockable functions: central activation status-Authentication for control module 7,Condition not met,
MAS17522-MAS18673,Unlockable functions: central activation status-Authentication for control module 8,Condition not met,
MAS17522,Unlockable functions: central activation status,00 00 00 00 00 00 00 00,
MAS17523-MAS17968,Unlockable functions: date of last activation-Date of last function activation,61 8D 0E 46,
MAS17523-MAS17969,Unlockable functions: date of last activation-Date of last key exchange,00 00 00 00,
MAS17523-MAS17970,Unlockable functions: date of last activation-Date of last reset,00 00 00 00,
MAS17524-MAS17977,Unlockable functions: version info-Supported activation version,Support from FSC version 0x12,
MAS17524-MAS17978,Unlockable functions: version info-Supported encryption procedure,RSA3072 Exp. 17,
MAS17524-MAS18453,Unlockable functions: version info-FoD metadata version,No version of FoD metadata is supported,
MAS17524-MAS18456,Unlockable functions: version info-KeyIdent (Key project identification),1644,
MAS17524-MAS18457,Unlockable functions: version info-Generation of function activation,Activation via FoD,
MAS17524-MAS18460,Unlockable functions: version info-FoD partner diagnostic address,00 75,
MAS17526-MAS17971,Unlockable functions: status of transfer-Transfer status,Valid transmission,
MAS17526-MAS17972,Unlockable functions: status of transfer-Number of slave control modules,5,
MAS17526-MAS17973,Unlockable functions: status of transfer-Transfer status in slave control module,Valid transmission,
MAS17526-MAS17974,Unlockable functions: status of transfer-Slave number,1,
MAS17526-MAS17975,Unlockable functions: status of transfer-Slave node address,14,
MAS17526-MAS17976,Unlockable functions: status of transfer-Slave diagnostic address,00 09,
MAS17833,Remaining period of test activation,4294967295, s
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
ENG55051-ENG56247,Authentic_time_last_client_response-Counter_kl15_since_last_sync,211,
ENG55051-ENG124488,Authentic_time_last_client_response-Current_time_ used,1970-01-01T00:00:00Z,
ENG55051-ENG55667,Authentic_time_last_client_response-Last_valid_timestamp_from_Backend,1970-01-01T00:00:00Z,
ENG123545-ENG36981,DoIP_Status-DoIP_Status_ECU,|Node_address,number_tcp_connections_ecu
ENG118786-ENG06057,Driv._Prof._Sel._Dr._Op.-Drehsteller_Ist_Modus,0,
ENG118786-ENG06058,Driv._Prof._Sel._Dr._Op.-Drehsteller_Modus,0,
ENG118786-ENG06061,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_HVEM,0,
ENG118786-ENG06063,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Mo_BZS,0,
ENG118786-ENG06062,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Step_Reduction,0,
ENG118786-ENG06060,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Trailer,0,
ENG118786-ENG06059,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Modus,not detected,
ENG118786-ENG118748,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile,not detected,
ENG118783-ENG118728,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Coordinator_Sub_State_Value,5,
ENG118783-ENG118729,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Startup_State,active,
ENG118766,eASS_operation_status,Emergency running mode,
ENG06005-ENG06085,EHR_pool_load-ehr_attribute_pool_load,0.0, %
ENG06005-ENG06084,EHR_pool_load-ehr_segment_pool_load,0.0, %
ENG06005-ENG124624,EHR_pool_load-ehr_speedlimit_pool_load,0.0, %
ENG123549-ENG124430,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-BZE_test_pulse_request,3,
ENG123549-ENG124431,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-BZE_test_pulse_result,3,
ENG123549-ENG124432,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-BZE_test_pulse_status,3,
ENG123549-ENG124473,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Consumer_test_pulse_request,0,
ENG123549-ENG124479,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Counter_increase_not_ok,150,
ENG123549-ENG124481,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Counter_test_pulse_not_ok,134,
ENG123549-ENG124485,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Current_battery_BEM,9.732, A
ENG123549-ENG124486,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Current_DcDc_test_pulse_actual,0, A
ENG123549-ENG124487,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Current_test_pulse_target_value,0, A
ENG123549-ENG124972,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Max_current_last_start,864, A
ENG123549-ENG124992,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Min_voltage_last_start,9.80,
ENG123549-ENG125029,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV_EM_test_pulse_status,3,
ENG123549-ENG125025,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV-EM_/_HV-EM_test_pulse_enabled,3,
ENG123549-ENG125026,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV-EM_/_HV-EM_test_pulse_request,3,
ENG123549-ENG125027,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV-EM_/_MV-EM_test_pulse_enabled,0,
ENG123549-ENG125028,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV-EM_/_MV-EM_test_pulse_request,3,
ENG123549-ENG125198,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Reduction_internal_fan_by_request_test_pulse,0,
ENG123549-ENG125548,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Voltage_battery_BEM,475.3, V
ENG123550-MAS21178,Energy_management_dashboard_display-Battery reports,0,
ENG123550-MAS21179,Energy_management_dashboard_display-Energy generator reports,0,
ENG123550-MAS21180,Energy_management_dashboard_display-Battery service,0,
ENG123550-MAS21181,Energy_management_dashboard_display-Vehicle system diagnostic,0,
ENG118782-ENG36986,Gateway app. software identification-Gateway_applikation_software_identifikation,|nf_name,SW_VERSION|routing_gateway
ENG123653-ENG124625,HV-EM_consumer_contingent-Enabling_climate_aggregates,No enabling,
ENG123653-ENG124973,HV-EM_consumer_contingent-max_power_climate_aggregates,0, A
ENG123653-ENG20971,HV-EM_consumer_contingent-RWV_reduction_level,no request,
ENG123653-ENG124133,HV-EM_consumer_contingent-shutdown_request_low_voltage_systems,none,
ENG123655-ENG20957,HV-EM_energy_specification-High_voltage_battery_energy_information,102350,
ENG123655-ENG20960,HV-EM_energy_specification-HV-EM_high_voltage_battery_energy_information,102300, Wh
ENG123655-ENG20967,HV-EM_energy_specification-NV_energy_requirement,2550, W
ENG123656-ENG20958,HV-EM_high_voltage_activation-HV_system_error,No malfunction,
ENG123656-ENG20961,HV-EM_high_voltage_activation-HV-EM_HV_requirement,no request,
ENG123656-ENG20964,HV-EM_high_voltage_activation-HV-EM_recharging_requirement,no request,
ENG123656-ENG20965,HV-EM_high_voltage_activation-HV-LM_HV_requirement,not_requested,
ENG123657-ENG124461,HV-EM_operation_data-climate_power,0, W
ENG123657-ENG124509,HV-EM_operation_data-dcdc_power,0, W
ENG123657-ENG125881,HV-EM_operation_data-HV-EM_operation_mode,OFF,
ENG123658-ENG20956,HV-EM_operation_limitation-High_voltage_battery_current_limitation,0, A
ENG123658-ENG124134,HV-EM_operation_limitation-High_voltge_battery_state_of_charge,127.0, %
ENG123658-ENG01115,HV-EM_operation_limitation-HV-EM_approval_dcdc_converter,No enabling,
ENG123658-ENG20962,HV-EM_operation_limitation-HV-EM_NV_power_limitation,0, W
ENG123658-ENG20963,HV-EM_operation_limitation-HV-EM_power_limitation,0, W
ENG123705,Middle_voltage_energy_management_to_low_voltage_energy_management_function_support,Unknown (0),
ENG118666,MKE_HFC_filtrated,1.0,
ENG126247-ENG126257,MKE_TTNR-TTNR_DS,60021,
ENG126247-ENG126256,MKE_TTNR-TTNR_SW,60054,
ENG20113-ENG09374,MV-EM_48V_electrical_system_components-48V_Rsg_installed,not installed,
ENG20113-ENG09370,MV-EM_48V_electrical_system_components-DcDc_installed,not installed,
ENG20113-ENG09369,MV-EM_48V_electrical_system_components-LiIon_battery_installed,not installed,
ENG20113-ENG09368,MV-EM_48V_electrical_system_components-sCap_installed,not installed,
ENG20114-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_1-Measurement,not OK.,
ENG20114,MV-EM_48V_electrical_system_diagnosis_typ_1,---,
ENG20114-ENG09348,MV-EM_48V_electrical_system_diagnosis_typ_1-48V_electrical_system_diagnosis_request,not requested,
ENG20114-ENG09349,MV-EM_48V_electrical_system_diagnosis_typ_1-Bms_48V_actual_current,0, A
ENG20115-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_2-Measurement,not OK.,
ENG20115,MV-EM_48V_electrical_system_diagnosis_typ_2,Initialization,
ENG20115,MV-EM_48V_electrical_system_diagnosis_typ_2,---,
ENG20115-ENG09351,MV-EM_48V_electrical_system_diagnosis_typ_2-48V_electrical_system_active,not active,
ENG20115-ENG09344,MV-EM_48V_electrical_system_diagnosis_typ_2-Bms_48V_actual_voltage,0.00, V
ENG20115-ENG09352,MV-EM_48V_electrical_system_diagnosis_typ_2-DcDc_48V_actual_voltage,63.50, V
ENG20115-ENG125229,MV-EM_48V_electrical_system_diagnosis_typ_2-Rsg_48V_actual_voltage,1023.50, mV
ENG20116-MAS01867,MV-EM_48V_overvoltage_check-Measurement,not OK.,
ENG20116,MV-EM_48V_overvoltage_check,---,
ENG20116-ENG09344,MV-EM_48V_overvoltage_check-Bms_48V_actual_voltage,0.00, V
ENG20116-ENG09345,MV-EM_48V_overvoltage_check-Bms_48V_Soc,0, %
ENG20117-MAS11874,MV-EM_48V_Zero_potential_status-Overall status,Initialization,
ENG20118-ENG09366,MV-EM_coldstart_requirement_engine-requirement_12V_start,not active,
ENG20118-ENG09367,MV-EM_coldstart_requirement_engine-requirement_48V_start,not active,
ENG20119,MV-EM_dc_current_Mv,0.0, A
ENG20120,MV-EM_dc_power_desired,0, W
ENG20121,MV-EM_DC_voltage_desired,0.00, V
ENG20122,MV-EM_dc_voltage_Mv,0.00, V
ENG20123-ENG09198,MV-EM_Derating_voltage-Derating_group_A,0.00, V
ENG20123-ENG09199,MV-EM_Derating_voltage-Derating_group_B,0.00, V
ENG20123-ENG09200,MV-EM_Derating_voltage-Derating_group_C,0.00, V
ENG20123-ENG09337,MV-EM_Derating_voltage-Derating_Umax_feedback,0.00, V
ENG20124,MV-EM_EMG_level_of_capacity,0.025, %
ENG20125,MV-EM_Mv_current,0, A
ENG20126-ENG09342,MV-EM_recommendation_Dcdc-Dcdc_boost_mode,active,
ENG20126-ENG09343,MV-EM_recommendation_Dcdc-Dcdc_buck_mode,not active,
ENG20127-ENG09338,MV-EM_release-12V_coldstart_release,No enabling,
ENG20127-ENG09339,MV-EM_release-12V_warmstart_release,No enabling,
ENG20127-ENG09340,MV-EM_release-48V_coldstart_release,No enabling,
ENG20127-ENG09341,MV-EM_release-start_stopp_support_release,No enabling,
ENG20128,MV-EM_RSG_maximal_current,0, A
ENG20129,MV-EM_RSG_maximal_voltage,0.00, V
ENG123711-ENG115189,NVEM_12V_Rekuperation-48V_emergency_run,0,
ENG123711-ENG12115,NVEM_12V_Rekuperation-Batterie_Ladezustand,1,
ENG123711-ENG12116,NVEM_12V_Rekuperation-Batterie_Regeneration,1,
ENG123711-ENG12117,NVEM_12V_Rekuperation-Batterie_Spannung,1,
ENG123711-ENG12118,NVEM_12V_Rekuperation-Batterie_Temperatur,1,
ENG123711-ENG124307,NVEM_12V_Rekuperation-Batteriealterung_Ladung,1,
ENG123711-ENG124308,NVEM_12V_Rekuperation-Batteriealterung_Leistung,1,
ENG123711-ENG124628,NVEM_12V_Rekuperation-Energienetz,1,
ENG123711-ENG124631,NVEM_12V_Rekuperation-Entnehmbare_Ladung,1,
ENG123711-ENG124665,NVEM_12V_Rekuperation-Freigabe_KFG,1,
ENG123711-ENG124666,NVEM_12V_Rekuperation-Freigabe_Klima,1,
ENG123711-ENG99756,NVEM_12V_Rekuperation-Generatordiagnose,1,
ENG123711-ENG100106,NVEM_12V_Rekuperation-Leerlaufanhebung,1,
ENG123711-ENG121521,NVEM_12V_Rekuperation-limited_by_48V_consumer,0,
ENG123711-ENG104009,NVEM_12V_Rekuperation-LIN-Kommunikation,1,
ENG123711-ENG125004,NVEM_12V_Rekuperation-Modus_Rekuperation_Motor,Acc.,
ENG123711-ENG125034,NVEM_12V_Rekuperation-opening_recuperation_by_BCM,Yes,
ENG123711-ENG124093,NVEM_12V_Rekuperation-Parallel Parking Assistance,0,
ENG123711-ENG125201,NVEM_12V_Rekuperation-Rekuperation_light,0,
ENG123711-ENG125234,NVEM_12V_Rekuperation-Saeureschichtung,1,
ENG123711-ENG101873,NVEM_12V_Rekuperation-Sonderveto,1,
ENG123711-ENG125292,NVEM_12V_Rekuperation-Spannungsanforderung_BCM,0,
ENG123711-ENG125293,NVEM_12V_Rekuperation-Spannungsanforderung_Bremse,0,
ENG123711-ENG125294,NVEM_12V_Rekuperation-Spannungsanforderung_KFG,0,
ENG123711-ENG125295,NVEM_12V_Rekuperation-Spannungsanforderung_Klima,0,
ENG123711-ENG125296,NVEM_12V_Rekuperation-Spannungsanforderung_Lenkung,0,
ENG123711-ENG125297,NVEM_12V_Rekuperation-Spannungsanforderung_Motor,0,
ENG123711-ENG125327,NVEM_12V_Rekuperation-Status_Rekuperation,active,
ENG123711-ENG125328,NVEM_12V_Rekuperation-Status_Stromregelung,not active,
ENG123712-ENG124214,NVEM_Analoge_Batterieueberwachung-Aktuelle_Differenzspannung,0.000, V
ENG123712-ENG124226,NVEM_Analoge_Batterieueberwachung-Analoge_Batteriespannung,0.000, V
ENG123712-ENG124107,NVEM_Analoge_Batterieueberwachung-Difference limit voltage,0.00, V
ENG123712-ENG124682,NVEM_Analoge_Batterieueberwachung-Gefilterte_Batteriespannung,13.500, V
ENG123712-ENG125326,NVEM_Analoge_Batterieueberwachung-Status_internes_BatterieAb,connected,
ENG123712-ENG125648,NVEM_Analoge_Batterieueberwachung-Zaehler_BatterieAb,0,
ENG119298,NVEM_Grund_BEM_falsch_codiert,0,
ENG123714-ENG124236,NVEM_HLR_Kurzstreckenprofil-Anteil_Entladung_aktuelle Fahrt,0, %
ENG123714-ENG124137,NVEM_HLR_Kurzstreckenprofil-Number_of_short_tracks,0,
ENG123715-ENG124227,NVEM_HLR_Master-Anforderung_Leerlaufanhebung,no request,
ENG123715-ENG124228,NVEM_HLR_Master-Anforderung_Reduzierung_Innengeblaese,no request,
ENG123715-ENG124707,NVEM_HLR_Master-Heizleistungskontingent,1000, W
ENG123715-ENG124708,NVEM_HLR_Master-Heizleistungskontingent_Stufe,Stage 1,
ENG123716-ENG124297,NVEM_Zustand_HLR-BA2_ZuendungEin,0,
ENG123716-ENG124298,NVEM_Zustand_HLR-BA3_ZuendungAus,0,
ENG123716-ENG125351,NVEM_Zustand_HLR-TabA_StartStopp,0,
ENG123716-ENG125352,NVEM_Zustand_HLR-TabB_Fahrtbetrieb,0,
ENG123716-ENG125353,NVEM_Zustand_HLR-TabD_Kurzzeitverbraucher,0,
ENG123716-ENG125354,NVEM_Zustand_HLR-TabE_Crash,0,
ENG123716-ENG125355,NVEM_Zustand_HLR-TabK_Kontingent_geregelt,0,
ENG123716-ENG125356,NVEM_Zustand_HLR-TabM_Leistungsgefuehrt_praediktiv,0,
ENG123716-ENG125357,NVEM_Zustand_HLR-TabNQ,0,
ENG18232,Reason_nvem_vehicle_electrical_system_state_diagnosis,0,
ENG18237-ENG18371,Status_12V_lithium_ion_starter_battery-12V_LiIon_starter_battery_emergency_strategy,0,
ENG18237-ENG18372,Status_12V_lithium_ion_starter_battery-12V_LiIon_starter_battery_failure_warning,not active,
ENG18237-ENG18373,Status_12V_lithium_ion_starter_battery-12V_LiIon_starter_battery_operating_quadrant,Normal operating mode,
ENG18237-ENG18374,Status_12V_lithium_ion_starter_battery-12V_LiIon_starter_battery_operational_restriction,not active,
ENG18237-ENG18375,Status_12V_lithium_ion_starter_battery-12V_LiIon_starter_battery_service_information,OK,
Elapsed Time: 00:53,,,
;SW:5WA-909-059-K HW:3Q0-909-059-D --- Brake Booster
;Component:EBKV H09 0307, Coding:5003C5409B00009C73CE39E7000049922449922400
;EV_BrakeBoostG2BoschVW37W,016028,EV_BrakeBoostG2BoschVW37W_016.rod
;Thursday,17,March,2022,11:48:22:62242
;VCDS Version: Release 22.3.0 Data version: 20220225 DS336.1
;VCID: 58E98629A29C59EBD72-800C
Group,Description,Actual,
IDE05816-IDE00075,Input signals from data bus-Vehicle speed,28.000, km/h
IDE05816-IDE00773,Input signals from data bus-Terminal 15 status via CAN,Terminal 15 on,
IDE05816-IDE02211,Input signals from data bus-Brake pressure,0.90000, bar
IDE05816-IDE09696,Input signals from data bus-Charisma driving program: CAN output value,Program 2,
IDE05816-MAS01078,Input signals from data bus-Vehicle model,Combustion engine,
IDE05816-MAS02357,Input signals from data bus-Vehicle identification,00 32 39 34 30 39,
IDE05816-MAS08111,Input signals from data bus-OBD std.,US OBD,
IDE05816-MAS19863,Input signals from data bus-Status of parking brake: electromechanical,Bremse_geschl_(Spannkraft_voll/reduziert),
IDE07159-MAS01155,Control module switch-off: counter-Control module,0, min
IDE07159-MAS05583,Control module switch-off: counter-Data bus,0, min
IDE08586-IDE02955,Status: electromechanical power brake-System status,ready,
IDE08587-MAS08097,Power brake displays-Status: OBD lamp,OFF,
IDE08588-IDE00020,Sensor signals for electromechanical power brake-Terminal 15 status,Terminal 15 on,
IDE08588-IDE00102,Sensor signals for electromechanical power brake-Control Module temperature,56.0, °C
IDE08588-IDE02222,Sensor signals for electromechanical power brake-Driver brakes: qualification,OFF,
IDE08588-IDE02713,Sensor signals for electromechanical power brake-Brake lamp switch,OFF,
IDE08588-IDE02714,Sensor signals for electromechanical power brake-Brake test switch,On,
IDE08588-IDE11037,Sensor signals for electromechanical power brake-Brake light switch: qualification,On,
IDE08588-MAS00043,Sensor signals for electromechanical power brake-Terminal 30 power supply,13.3, V
IDE08588-MAS05192,Sensor signals for electromechanical power brake-Driver braking,OFF,
IDE08588-MAS06928,Sensor signals for electromechanical power brake-Supply voltage pedal travel sensor,5.0, V
IDE08588-MAS10345,Sensor signals for electromechanical power brake-Position of booster,0.3476562500, mm
IDE08588-MAS10346,Sensor signals for electromechanical power brake-Engine torque,0.00000, Nm
IDE08588-MAS11639,Sensor signals for electromechanical power brake-Input rod travel,0.000000, mm
IDE08588-MAS18095,Sensor signals for electromechanical power brake-Output rod,0.296875, mm
IDE08588-MAS18096,Sensor signals for electromechanical power brake-Brake pedal travel,Initialization,
IDE08588-MAS18097,Sensor signals for electromechanical power brake-Brake test switch: qualification,On,
IDE08588-MAS18098,Sensor signals for electromechanical power brake-Driver brakes clearly,OFF,
IDE08623-MAS02163,OBD configuration-coded,US OBD,
IDE08623-MAS08097,OBD configuration-Status: OBD lamp,OFF,
IDE08623-MAS14472,OBD configuration-calculated,US OBD,
IDE08623-MAS19862,OBD configuration-Status of generic scan tool,OFF,
IDE13138-MAS03034,Sluggishness test-Pressure,0.00000, bar
IDE13138-MAS10346,Sluggishness test-Engine torque,0.00000000000, Nm
IDE13138-MAS19863,Sluggishness test-Status of parking brake: electromechanical,Open,
IDE13138-MAS19866,Sluggishness test-Travel pressure rod,0.0000000, mm
IDE14229-MAS18099,Brake booster control status-Control mode,No activation,
IDE14229-MAS18101,Brake booster control status-Actuator Position,0.26554, mm
IDE14229-MAS18102,Brake booster control status-Actuator torque,0.00000, Nm
IDE14229-MAS18103,Brake booster control status-Actuator speed,0.00000, mm/s
IDE14229-MAS18104,Brake booster control status-Remaining hold time,0, s
IDE14696-MAS03458,Leakage test-Differential pressure,0.0000, bar
IDE14696-MAS19863,Leakage test-Status of parking brake: electromechanical,Open,
IDE14696-MAS19864,Leakage test-Brake pressure 1,0, bar
IDE14696-MAS19865,Leakage test-Brake pressure 2,0, bar
IDE80221-ENG121381,Analysis 221-Driver On Pedal,false,
IDE80221-ENG121382,Analysis 221-iBooster Ready for Actuation,OFF,
IDE80221-ENG121385,Analysis 221-iBooster System Mode,actuated,
IDE80221-ENG121383,Analysis 221-Pedal Apply Recognition HW Output,false,
IDE80221-ENG121386,Analysis 221-Thermal Limitation,not_active,
IDE80221-ENG121380,Analysis 221-Wakeup Information HW,On,
IDE80221-ENG121384,Analysis 221-Wakeup Information NET,On,
IDE80222,Analysis 222,00 0D 69,
IDE80223,Analysis 223,40.7421875, mm
IDE80223,Analysis 223,0.0000000, mm
IDE80223,Analysis 223,102.8750000, mm/s
IDE80223,Analysis 223,1.7578125, mm/s
IDE80223,Analysis 223,2.08251953125, Nm
IDE80223,Analysis 223,0.00000000000, Nm
IDE80225,Analysis 225,not active,
IDE80225,Analysis 225,2,
IDE80225,Analysis 225,0,
IDE80226-ENG118230,Analysis 226-Umgesetztes Charisma-Fahrprogramm_Wert,2,
MAS10409-MAS00106,Time stamp-Year,2022,
MAS10409-MAS00107,Time stamp-Month,3,
MAS10409-MAS00108,Time stamp-Day,17,
MAS10409-MAS00109,Time stamp-Hours,11,
MAS10409-MAS00110,Time stamp-Minutes,48,
MAS10409-MAS00111,Time stamp-Seconds,23,
Elapsed Time: 00:02,,,
;SW:2Q0-905-861-B HW:2Q0-905-861-B --- Steer. Col. Lock
;Component:ELV-MQBB H09 0040, Coding:0000000000000000
;EV_ELVMarqMQBA0,002004,EV_ELVMarqMQBA0_VW27.rod
;Thursday,17,March,2022,11:48:35:62242
;VCID: 323D1481E4A053BB096-8066
IDE00019,Voltage terminal 30,13.2,
IDE00021,Engine RPM,774.00, /min
IDE00021-MAS00058,Engine RPM-Implausible,No,
IDE00021-MAS00103,Engine RPM-invalid,No,
IDE00021-MAS02239,Engine RPM-outdated,No,
IDE00021-MAS02246,Engine RPM-Timeout,No,
IDE00075-MAS00058,Vehicle speed-Implausible,No,
IDE00075-MAS00103,Vehicle speed-invalid,No,
IDE00075-MAS02246,Vehicle speed-Timeout,No,
IDE00096-MAS02239,Selector lever position-outdated,Yes,
IDE00096-MAS02246,Selector lever position-Timeout,No,
IDE00096,Selector lever position,Not available,
IDE00660-MAS02246,Drive readiness-Timeout,No,
IDE00660,Drive readiness,not active,
IDE01766-MAS03714,Distance impulses-Left front wheel,1,
IDE01766-MAS03715,Distance impulses-Right front wheel,0,
IDE01766-MAS03716,Distance impulses-Left rear wheel,0,
IDE01766-MAS03717,Distance impulses-Right rear wheel,0,
IDE01766-MAS11907,Distance impulses-Left front wheel signal state timeout,No,
IDE01766-MAS11908,Distance impulses-Right front wheel signal state timeout,No,
IDE01766-MAS11909,Distance impulses-Left rear wheel signal state timeout,No,
IDE01766-MAS11910,Distance impulses-Right rear wheel signal state timeout,No,
IDE01766-MAS11911,Distance impulses-Left front wheel invalid signal state,No,
IDE01766-MAS11912,Distance impulses-Right front wheel invalid signal state,No,
IDE01766-MAS11913,Distance impulses-Left rear wheel invalid signal state,No,
IDE01766-MAS11914,Distance impulses-Right rear wheel invalid signal state,No,
IDE02569-MAS02242,Terminal S: line status-Electronic central electric actual value,On,
IDE02569-MAS02246,Terminal S: line status-Timeout,No,
IDE02570-MAS02242,Terminal 15: line status-Electronic central electric actual value,On,
IDE02570-MAS02246,Terminal 15: line status-Timeout,No,
IDE02573,End switch for steering column: unlocked: status,operated,
IDE02574,End switch for steering column: locked: status,Not operated,
IDE02575,Unlocking motor: activation status,not activated,
IDE02576,Locking motor: activation status,not activated,
IDE02577,Steering column twisting: status,not twisted,
IDE02579-MAS02246,Park selector lever position-Timeout,No,
IDE02579,Park selector lever position,not locked,
IDE02580,Number of unlocks,187,
IDE02588,Terminal signals and start release,not enabled,
IDE02589-MAS02246,Rotary latch status-Timeout,No,
IDE02589,Rotary latch status,to,
IDE02590-MAS02246,External vehicle locking: SPECIFIED condition-Timeout,No,
IDE02590-MAS02257,External vehicle locking: SPECIFIED condition-SPECIFIED condition of fuse per remote/key,Vehicle not secured,
IDE02590,External vehicle locking: SPECIFIED condition,unlocked,
IDE02759-MAS02345,Steering column lock current condition/learn mode-Current condition,Immobilizer download obtained,
IDE02759-MAS02349,Steering column lock current condition/learn mode-Learn mode,Adapted,
IDE03527-IDE03411,CAN signals-Red warning lamp,not active,
IDE03527-MAS04444,CAN signals-Wake-up,not active,
IDE03527-MAS05099,CAN signals-Driver information: steering column lock defective,not active,
IDE03527-MAS05100,CAN signals-Driver information: steering column lock: workshop,not active,
IDE03527-MAS05101,CAN signals-Driver information: move steering,not active,
IDE06746-IDE00020,Locking requirements-Terminal 15 status,Condition not met,
IDE06746-IDE00021,Locking requirements-Engine RPM,Condition not met,
IDE06746-IDE00075,Locking requirements-Vehicle speed,Condition met,
IDE06746-IDE00660,Locking requirements-Drive readiness,Condition met,
IDE06746-IDE01715,Locking requirements-Status terminal S,Condition not met,
IDE06746-IDE01766,Locking requirements-Distance impulses,Condition met,
IDE06746-IDE02052,Locking requirements-Malfunction message in instrument panel,Condition met,
IDE06746-IDE02579,Locking requirements-Park selector lever position,Condition met,
IDE06746-MAS02349,Locking requirements-Learn mode,Adapted,
IDE06746-MAS08251,Locking requirements-Vehicle speed signals: communication status,Condition met,
IDE06746-MAS08252,Locking requirements-Terminal status signal: communication status,Condition not met,
IDE06746-MAS08441,Locking requirements-Test of locking requirements,not active,
IDE06746-MAS08791,Locking requirements-Vehicle speed signals: cyclical reception,Condition met,
IDE06746-MAS08792,Locking requirements-Signals for distance pulses: cyclical reception,Condition met,
IDE06746-MAS08794,Locking requirements-Terminal status signal: cyclical reception,Condition met,
IDE06746-MAS11697,Locking requirements-Signals for distance pulses: communication status,Condition met,
IDE09059-MAS02246,Request terminal release-Timeout,No,
IDE09059,Request terminal release,No,
IDE09064,Status: unlock trigger,No,
IDE09065-MAS02246,Status: remote start-Timeout,No,
IDE09065,Status: remote start,not active,
IDE09066-MAS02246,ID sensor exiting vehicle-Timeout,No,
IDE09066,ID sensor exiting vehicle,No,
MAS00464-MAS00106,Standard - ambient data 1-Year,2022,
MAS00464-MAS00107,Standard - ambient data 1-Month,3,
MAS00464-MAS00108,Standard - ambient data 1-Day,17,
MAS00464-MAS00109,Standard - ambient data 1-Hours,11,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,48,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,36,
ENG111213-ENG128873,Activated_Fault_Reactions-Locking disabled,No,
ENG128821-ENG111184,Errorcounter lifetime-AD-Converter corrupt,0,
ENG128821-ENG128856,Errorcounter lifetime-AD-Converter corrupt unlocking cycle,No,
ENG128821-ENG128851,Errorcounter lifetime-Areacheck highside,0,
ENG128821-ENG128852,Errorcounter lifetime-Areacheck highside unlocking cycle,No,
ENG128821-ENG128853,Errorcounter lifetime-Areacheck lowside,0,
ENG128821-ENG128854,Errorcounter lifetime-Areacheck lowside unlocking cycle,No,
ENG128821-ENG111176,Errorcounter lifetime-CoCo RAM-Check,0,
ENG128821-ENG128846,Errorcounter lifetime-CoCo RAM-Check unlocking cycle,No,
ENG128821-ENG111177,Errorcounter lifetime-CoCo ROM-Check,0,
ENG128821-ENG128847,Errorcounter lifetime-CoCo ROM-Check unlocking cycle,No,
ENG128821-ENG111194,Errorcounter lifetime-CPU-Test CoCo,0,
ENG128821-ENG128848,Errorcounter lifetime-CPU-Test CoCo unlocking cycle,No,
ENG128821-ENG111192,Errorcounter lifetime-CPU-Test HaCo,0,
ENG128821-ENG128844,Errorcounter lifetime-CPU-Test HaCo unlocking cycle,No,
ENG128821-ENG111187,Errorcounter lifetime-Enable CoCo incorrect active locking,0,
ENG128821-ENG128858,Errorcounter lifetime-Enable CoCo incorrect active locking unlocking cycle,No,
ENG128821-ENG111181,Errorcounter lifetime-Endposition switches implausible,0,
ENG128821-ENG128855,Errorcounter lifetime-Endposition switches implausible unlocking cycle,No,
ENG128821-ENG128872,Errorcounter lifetime-Endposition_Button_Unlocked_Change_To_Not_Activated_While_Driving,0,
ENG128821-ENG128870,Errorcounter lifetime-Endposition_Locked_Not_Reached,0,
ENG128821-ENG128871,Errorcounter lifetime-Endposition_Locked_Not_Reached unlocking cycle,No,
ENG128821-ENG31613,Errorcounter lifetime-HaCo CAN-Cell-Check,0,
ENG128821-ENG31614,Errorcounter lifetime-HaCo CAN-Cell-Check unlocking cycle,No,
ENG128821-ENG111185,Errorcounter lifetime-HaCo CoCo communication disturbed,0,
ENG128821-ENG128857,Errorcounter lifetime-HaCo CoCo communication disturbed unlocking cycle,No,
ENG128821-ENG111175,Errorcounter lifetime-HaCo EEPROM-Check,0,
ENG128821-ENG128845,Errorcounter lifetime-HaCo EEPROM-Check unlocking cycle,No,
ENG128821-ENG111173,Errorcounter lifetime-HaCo RAM-Check,0,
ENG128821-ENG128842,Errorcounter lifetime-HaCo RAM-Check unlocking cycle,No,
ENG128821-ENG111174,Errorcounter lifetime-HaCo ROM-Check,0,
ENG128821-ENG128843,Errorcounter lifetime-HaCo ROM-Check unlocking cycle,No,
ENG128821-ENG128868,Errorcounter lifetime-Invalid eeprom data immobilizer,0,
ENG128821-ENG128869,Errorcounter lifetime-Invalid eeprom data immobilizer unlocking cycle,No,
ENG128821-ENG111189,Errorcounter lifetime-No CoCo enable locking,0,
ENG128821-ENG128859,Errorcounter lifetime-No CoCo enable locking unlocking cycle,No,
ENG128821-ENG111195,Errorcounter lifetime-Program sequence CoCo,0,
ENG128821-ENG128863,Errorcounter lifetime-Program sequence CoCo unlocking cycle,No,
ENG128821-ENG111193,Errorcounter lifetime-Program sequence HaCo,0,
ENG128821-ENG128862,Errorcounter lifetime-Program sequence HaCo unlocking cycle,No,
ENG128821-ENG111190,Errorcounter lifetime-Reset HaCo CoCo failed,0,
ENG128821-ENG128860,Errorcounter lifetime-Reset HaCo CoCo failed unlocking cycle,No,
ENG128821-ENG111191,Errorcounter lifetime-Reset SBC HaCo failed,0,
ENG128821-ENG128861,Errorcounter lifetime-Reset SBC HaCo failed unlocking cycle,No,
ENG128821-ENG119956,Errorcounter lifetime-Return address,00 00 00 00,
ENG128821-ENG128866,Errorcounter lifetime-SDA-Error CoCo,0,
ENG128821-ENG128867,Errorcounter lifetime-SDA-Error CoCo unlocking cycle,No,
ENG128821-ENG128864,Errorcounter lifetime-SDA-Error HaCo,0,
ENG128821-ENG128865,Errorcounter lifetime-SDA-Error HaCo unlocking cycle,No,
ENG128821-ENG111179,Errorcounter lifetime-Shortcut motor driver highside,0,
ENG128821-ENG128849,Errorcounter lifetime-Shortcut motor driver highside unlocking cycle,No,
ENG128821-ENG111180,Errorcounter lifetime-Shortcut motor driver lowside,0,
ENG128821-ENG128850,Errorcounter lifetime-Shortcut motor driver lowside unlocking cycle,No,
ENG128820,Free_Releases_Numbers,256,
ENG128822-ENG128823,functional_check-functional_check_manufacturer,Confirmed,
ENG128822-ENG128824,functional_check-functional_check_steering_column_supplier,Not confirmed,
ENG128822-ENG124678,functional_check-Functional_Check_VW_EOL,Confirmed,
Elapsed Time: 00:04,,,
;SW:5WA-959-760-H HW:5WA-959-760-H --- Seat Mem. Drvr
;Component:MEM-FS 009 0362, Coding:01589A40000020408803010101010000000000212100000000000000215000
;EV_SCMDriveSideCONTIAU736,006013,EV_SCMDriveSideCONTIAU736_006.rod
;Thursday,17,March,2022,11:48:44:62242
;VCID: 59EF832DD99640E3E8C-800C
IDE00019-MAS00043,Voltage terminal 30-Terminal 30 power supply,13.40, V
IDE00102,Control Module temperature,45,
IDE00787,Cause for cancellation,none,
IDE01277-IDE09268,Counter of compressor activations-Switch on occurrences of compressor,0, counts
IDE01277-MAS06166,Counter of compressor activations-Current operation time,0, s
IDE01457,Energy management deactivation stage,Deactivation stage 0,
IDE05738-MAS12801,Subssystem diagnosis classes-DK0 systems supported,DK0 systems not supported,
IDE05738-MAS12803,Subssystem diagnosis classes-DK1 systems supported,DK1 systems not supported,
IDE05738-MAS12805,Subssystem diagnosis classes-DK2/DK2F systems supported,DK2/DK2F systems not supported,
IDE05738-MAS12807,Subssystem diagnosis classes-DK3 or DK4 high/low systems supported,DK3 or DK4 high/low systems not supported,
IDE06510-MAS01390,Adjustment for backrest angle-Block 1,34343,
IDE06510-MAS01391,Adjustment for backrest angle-Block 2,32760,
IDE06510-MAS02282,Adjustment for backrest angle-Position,33049,
IDE06510-MAS02955,Adjustment for backrest angle-Engine temperature,25, °C
IDE06510-MAS03129,Adjustment for backrest angle-Reset counter,24,
IDE06510-MAS04160,Adjustment for backrest angle-Load change,25,
IDE06510-MAS04337,Adjustment for backrest angle-Engine current,0, A
IDE06510-MAS05370,Adjustment for backrest angle-Direction of movement,Not operated,
IDE06510-MAS05563,Adjustment for backrest angle-Norming,standardized,
IDE06510-MAS05719,Adjustment for backrest angle-Maximum travel,1583,
IDE06510-MAS12838,Adjustment for backrest angle-Standardization flag,standardized,
IDE06511-MAS01390,Seat height adjustment-Block 1,32791,
IDE06511-MAS01391,Seat height adjustment-Block 2,32212,
IDE06511-MAS02282,Seat height adjustment-Position,32781,
IDE06511-MAS02955,Seat height adjustment-Engine temperature,25, °C
IDE06511-MAS03129,Seat height adjustment-Reset counter,22,
IDE06511-MAS04160,Seat height adjustment-Load change,24,
IDE06511-MAS04337,Seat height adjustment-Engine current,0, A
IDE06511-MAS05370,Seat height adjustment-Direction of movement,Not operated,
IDE06511-MAS05563,Seat height adjustment-Norming,standardized,
IDE06511-MAS05719,Seat height adjustment-Maximum travel,579,
IDE06511-MAS12838,Seat height adjustment-Standardization flag,standardized,
IDE06512-MAS01390,Adjustment for seat forward/back position-Block 1,33187,
IDE06512-MAS01391,Adjustment for seat forward/back position-Block 2,32525,
IDE06512-MAS02282,Adjustment for seat forward/back position-Position,32913,
IDE06512-MAS02955,Adjustment for seat forward/back position-Engine temperature,25, °C
IDE06512-MAS03129,Adjustment for seat forward/back position-Reset counter,250,
IDE06512-MAS04160,Adjustment for seat forward/back position-Load change,522,
IDE06512-MAS04337,Adjustment for seat forward/back position-Engine current,0, A
IDE06512-MAS05370,Adjustment for seat forward/back position-Direction of movement,Not operated,
IDE06512-MAS05563,Adjustment for seat forward/back position-Norming,standardized,
IDE06512-MAS05719,Adjustment for seat forward/back position-Maximum travel,662,
IDE06512-MAS12838,Adjustment for seat forward/back position-Standardization flag,standardized,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not active,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not active,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not active,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not active,
IDE06614-MAS01601,Memory seat adjustment control head-storing,not active,
IDE06683-MAS01390,Seat inclination adjustment-Block 1,32928,
IDE06683-MAS01391,Seat inclination adjustment-Block 2,32652,
IDE06683-MAS02282,Seat inclination adjustment-Position,32905,
IDE06683-MAS02955,Seat inclination adjustment-Engine temperature,25, °C
IDE06683-MAS03129,Seat inclination adjustment-Reset counter,1,
IDE06683-MAS04160,Seat inclination adjustment-Load change,11,
IDE06683-MAS04337,Seat inclination adjustment-Engine current,0, A
IDE06683-MAS05370,Seat inclination adjustment-Direction of movement,Not operated,
IDE06683-MAS05563,Seat inclination adjustment-Norming,standardized,
IDE06683-MAS05719,Seat inclination adjustment-Maximum travel,276,
IDE06683-MAS12838,Seat inclination adjustment-Standardization flag,standardized,
IDE06684-MAS01390,Lumbar support height adjustment-Block 1,32013,
IDE06684-MAS01391,Lumbar support height adjustment-Block 2,33079,
IDE06684-MAS02282,Lumbar support height adjustment-Position,32083,
IDE06684-MAS02955,Lumbar support height adjustment-Engine temperature,25, °C
IDE06684-MAS03129,Lumbar support height adjustment-Reset counter,1,
IDE06684-MAS04160,Lumbar support height adjustment-Load change,3,
IDE06684-MAS04337,Lumbar support height adjustment-Engine current,0, A
IDE06684-MAS05370,Lumbar support height adjustment-Direction of movement,Not operated,
IDE06684-MAS05563,Lumbar support height adjustment-Norming,standardized,
IDE06684-MAS05719,Lumbar support height adjustment-Maximum travel,1066,
IDE06684-MAS12838,Lumbar support height adjustment-Standardization flag,standardized,
IDE06685-MAS01390,Lumbar support longitudinal position adjustment-Block 1,32746,
IDE06685-MAS01391,Lumbar support longitudinal position adjustment-Block 2,33219,
IDE06685-MAS02282,Lumbar support longitudinal position adjustment-Position,32975,
IDE06685-MAS02955,Lumbar support longitudinal position adjustment-Engine temperature,25, °C
IDE06685-MAS03129,Lumbar support longitudinal position adjustment-Reset counter,2,
IDE06685-MAS04160,Lumbar support longitudinal position adjustment-Load change,4,
IDE06685-MAS04337,Lumbar support longitudinal position adjustment-Engine current,0, A
IDE06685-MAS05370,Lumbar support longitudinal position adjustment-Direction of movement,Not operated,
IDE06685-MAS05563,Lumbar support longitudinal position adjustment-Norming,standardized,
IDE06685-MAS05719,Lumbar support longitudinal position adjustment-Maximum travel,473,
IDE06685-MAS12838,Lumbar support longitudinal position adjustment-Standardization flag,standardized,
IDE06871-IDE06510,Seat adjustment control head-Adjustment for backrest angle,Not operated,
IDE06871-IDE06511,Seat adjustment control head-Seat height adjustment,Not operated,
IDE06871-IDE06512,Seat adjustment control head-Adjustment for seat forward/back position,Not operated,
IDE06871-IDE06683,Seat adjustment control head-Seat inclination adjustment,Not operated,
IDE06871-IDE06684,Seat adjustment control head-Lumbar support height adjustment,Not operated,
IDE06871-IDE06685,Seat adjustment control head-Lumbar support longitudinal position adjustment,Not operated,
IDE06871-IDE08989,Seat adjustment control head-Seat depth adjustment,Not operated,
IDE06871-IDE08990,Seat adjustment control head-Backrest top adjustment,Not operated,
IDE06871-IDE08991,Seat adjustment control head-Belt height adjustment,Not operated,
IDE06871-IDE11024,Seat adjustment control head-Headrest height adjustment,Not operated,
IDE06871-IDE11025,Seat adjustment control head-Headrest length adjustment,Not operated,
IDE07159,Control module switch-off: counter,0,
IDE07347-IDE06510,Memory setting 1 for seat adjustment-Adjustment for backrest angle,0,
IDE07347-IDE06511,Memory setting 1 for seat adjustment-Seat height adjustment,0,
IDE07347-IDE06512,Memory setting 1 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07347-IDE06683,Memory setting 1 for seat adjustment-Seat inclination adjustment,0,
IDE07347-IDE06684,Memory setting 1 for seat adjustment-Lumbar support height adjustment,0,
IDE07347-IDE06685,Memory setting 1 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07347-IDE08989,Memory setting 1 for seat adjustment-Seat depth adjustment,0,
IDE07347-IDE08990,Memory setting 1 for seat adjustment-Backrest top adjustment,0,
IDE07347-IDE08991,Memory setting 1 for seat adjustment-Belt height adjustment,0,
IDE07347-IDE11024,Memory setting 1 for seat adjustment-Headrest height adjustment,0,
IDE07348-IDE06510,Memory setting 2 for seat adjustment-Adjustment for backrest angle,0,
IDE07348-IDE06511,Memory setting 2 for seat adjustment-Seat height adjustment,0,
IDE07348-IDE06512,Memory setting 2 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07348-IDE06683,Memory setting 2 for seat adjustment-Seat inclination adjustment,0,
IDE07348-IDE06684,Memory setting 2 for seat adjustment-Lumbar support height adjustment,0,
IDE07348-IDE06685,Memory setting 2 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07348-IDE08989,Memory setting 2 for seat adjustment-Seat depth adjustment,0,
IDE07348-IDE08990,Memory setting 2 for seat adjustment-Backrest top adjustment,0,
IDE07348-IDE08991,Memory setting 2 for seat adjustment-Belt height adjustment,0,
IDE07348-IDE11024,Memory setting 2 for seat adjustment-Headrest height adjustment,0,
IDE07349-IDE06510,Memory setting 3 for seat adjustment-Adjustment for backrest angle,0,
IDE07349-IDE06511,Memory setting 3 for seat adjustment-Seat height adjustment,0,
IDE07349-IDE06512,Memory setting 3 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07349-IDE06683,Memory setting 3 for seat adjustment-Seat inclination adjustment,0,
IDE07349-IDE06684,Memory setting 3 for seat adjustment-Lumbar support height adjustment,0,
IDE07349-IDE06685,Memory setting 3 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07349-IDE08989,Memory setting 3 for seat adjustment-Seat depth adjustment,0,
IDE07349-IDE08990,Memory setting 3 for seat adjustment-Backrest top adjustment,0,
IDE07349-IDE08991,Memory setting 3 for seat adjustment-Belt height adjustment,0,
IDE07349-IDE11024,Memory setting 3 for seat adjustment-Headrest height adjustment,0,
IDE07350-IDE06510,Memory setting 4 for seat adjustment-Adjustment for backrest angle,0,
IDE07350-IDE06511,Memory setting 4 for seat adjustment-Seat height adjustment,0,
IDE07350-IDE06512,Memory setting 4 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07350-IDE06683,Memory setting 4 for seat adjustment-Seat inclination adjustment,0,
IDE07350-IDE06684,Memory setting 4 for seat adjustment-Lumbar support height adjustment,0,
IDE07350-IDE06685,Memory setting 4 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07350-IDE08989,Memory setting 4 for seat adjustment-Seat depth adjustment,0,
IDE07350-IDE08990,Memory setting 4 for seat adjustment-Backrest top adjustment,0,
IDE07350-IDE08991,Memory setting 4 for seat adjustment-Belt height adjustment,0,
IDE07350-IDE11024,Memory setting 4 for seat adjustment-Headrest height adjustment,0,
IDE07351-IDE06510,Memory setting 1: remote master key for seat adjustment-Adjustment for backrest angle,33049,
IDE07351-IDE06511,Memory setting 1: remote master key for seat adjustment-Seat height adjustment,32781,
IDE07351-IDE06512,Memory setting 1: remote master key for seat adjustment-Adjustment for seat forward/back position,32902,
IDE07351-IDE06683,Memory setting 1: remote master key for seat adjustment-Seat inclination adjustment,32905,
IDE07351-IDE06684,Memory setting 1: remote master key for seat adjustment-Lumbar support height adjustment,32083,
IDE07351-IDE06685,Memory setting 1: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,32975,
IDE07351-IDE08989,Memory setting 1: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07351-IDE08990,Memory setting 1: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07351-IDE08991,Memory setting 1: remote master key for seat adjustment-Belt height adjustment,0,
IDE07351-IDE11024,Memory setting 1: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07352-IDE06510,Memory setting 2: remote master key for seat adjustment-Adjustment for backrest angle,0,
IDE07352-IDE06511,Memory setting 2: remote master key for seat adjustment-Seat height adjustment,0,
IDE07352-IDE06512,Memory setting 2: remote master key for seat adjustment-Adjustment for seat forward/back position,0,
IDE07352-IDE06683,Memory setting 2: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07352-IDE06684,Memory setting 2: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07352-IDE06685,Memory setting 2: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07352-IDE08989,Memory setting 2: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07352-IDE08990,Memory setting 2: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07352-IDE08991,Memory setting 2: remote master key for seat adjustment-Belt height adjustment,0,
IDE07352-IDE11024,Memory setting 2: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07353-IDE06510,Memory setting 3: remote master key for seat adjustment-Adjustment for backrest angle,0,
IDE07353-IDE06511,Memory setting 3: remote master key for seat adjustment-Seat height adjustment,0,
IDE07353-IDE06512,Memory setting 3: remote master key for seat adjustment-Adjustment for seat forward/back position,0,
IDE07353-IDE06683,Memory setting 3: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07353-IDE06684,Memory setting 3: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07353-IDE06685,Memory setting 3: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07353-IDE08989,Memory setting 3: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07353-IDE08990,Memory setting 3: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07353-IDE08991,Memory setting 3: remote master key for seat adjustment-Belt height adjustment,0,
IDE07353-IDE11024,Memory setting 3: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07354-IDE06510,Memory setting 4: remote master key for seat adjustment-Adjustment for backrest angle,0,
IDE07354-IDE06511,Memory setting 4: remote master key for seat adjustment-Seat height adjustment,0,
IDE07354-IDE06512,Memory setting 4: remote master key for seat adjustment-Adjustment for seat forward/back position,0,
IDE07354-IDE06683,Memory setting 4: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07354-IDE06684,Memory setting 4: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07354-IDE06685,Memory setting 4: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07354-IDE08989,Memory setting 4: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07354-IDE08990,Memory setting 4: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07354-IDE08991,Memory setting 4: remote master key for seat adjustment-Belt height adjustment,0,
IDE07354-IDE11024,Memory setting 4: remote master key for seat adjustment-Headrest height adjustment,0,
IDE08989-MAS01390,Seat depth adjustment-Block 1,0,
IDE08989-MAS01391,Seat depth adjustment-Block 2,0,
IDE08989-MAS02282,Seat depth adjustment-Position,0,
IDE08989-MAS02955,Seat depth adjustment-Engine temperature,0, °C
IDE08989-MAS03129,Seat depth adjustment-Reset counter,0,
IDE08989-MAS04160,Seat depth adjustment-Load change,0,
IDE08989-MAS04337,Seat depth adjustment-Engine current,0, A
IDE08989-MAS05370,Seat depth adjustment-Direction of movement,Not operated,
IDE08989-MAS05563,Seat depth adjustment-Norming,not normed,
IDE08989-MAS05719,Seat depth adjustment-Maximum travel,0,
IDE08989-MAS12838,Seat depth adjustment-Standardization flag,never normed,
IDE08990-MAS01390,Backrest top adjustment-Block 1,0,
IDE08990-MAS01391,Backrest top adjustment-Block 2,0,
IDE08990-MAS02282,Backrest top adjustment-Position,0,
IDE08990-MAS02955,Backrest top adjustment-Engine temperature,0, °C
IDE08990-MAS03129,Backrest top adjustment-Reset counter,0,
IDE08990-MAS04160,Backrest top adjustment-Load change,0,
IDE08990-MAS04337,Backrest top adjustment-Engine current,0, A
IDE08990-MAS05370,Backrest top adjustment-Direction of movement,Not operated,
IDE08990-MAS05563,Backrest top adjustment-Norming,not normed,
IDE08990-MAS05719,Backrest top adjustment-Maximum travel,0,
IDE08990-MAS12838,Backrest top adjustment-Standardization flag,never normed,
IDE08991-MAS01390,Belt height adjustment-Block 1,0,
IDE08991-MAS01391,Belt height adjustment-Block 2,0,
IDE08991-MAS02282,Belt height adjustment-Position,0,
IDE08991-MAS02955,Belt height adjustment-Engine temperature,0, °C
IDE08991-MAS03129,Belt height adjustment-Reset counter,0,
IDE08991-MAS04160,Belt height adjustment-Load change,0,
IDE08991-MAS04337,Belt height adjustment-Engine current,0, A
IDE08991-MAS05370,Belt height adjustment-Direction of movement,Not operated,
IDE08991-MAS05563,Belt height adjustment-Norming,not normed,
IDE08991-MAS05719,Belt height adjustment-Maximum travel,0,
IDE08991-MAS12838,Belt height adjustment-Standardization flag,never normed,
IDE09081-MAS08291,Seat switch module-Plate: vertical actuation direction,Not operated,
IDE09081-MAS08292,Seat switch module-Plate: horizontal actuation direction,Not operated,
IDE09081-MAS08293,Seat switch module-Paddle,Not operated,
IDE09082,Massage button,Not operated,
IDE09083-MAS08294,Entry assistance button-Entry assistance button: actuation direction forward,Not operated,
IDE09083-MAS08295,Entry assistance button-Entry assistance button: actuation direction backward,Not operated,
IDE09084-MAS08296,Backrest lock switch-Switch state normally closed,operated,
IDE09084-MAS08297,Backrest lock switch-Switch state normally open,Not operated,
IDE09085,Backrest limit switch,Not operated,
IDE10995-IDE06510,Calibrating the motors: status-Adjustment for backrest angle,standardized,
IDE10995-IDE06511,Calibrating the motors: status-Seat height adjustment,standardized,
IDE10995-IDE06512,Calibrating the motors: status-Adjustment for seat forward/back position,standardized,
IDE10995-IDE06683,Calibrating the motors: status-Seat inclination adjustment,standardized,
IDE10995-IDE06684,Calibrating the motors: status-Lumbar support height adjustment,standardized,
IDE10995-IDE06685,Calibrating the motors: status-Lumbar support longitudinal position adjustment,standardized,
IDE10995-IDE08988,Calibrating the motors: status-Head restraint adjustment,not normed,
IDE10995-IDE08989,Calibrating the motors: status-Seat depth adjustment,not normed,
IDE10995-IDE08990,Calibrating the motors: status-Backrest top adjustment,not normed,
IDE10995-IDE08991,Calibrating the motors: status-Belt height adjustment,not normed,
IDE10995-IDE11957,Calibrating the motors: status-Display unit adjustment,not normed,
IDE10995-IDE11969,Calibrating the motors: status-Adjustment of foot rest,not normed,
IDE10995-IDE11986,Calibrating the motors: status-Adjustment 2 of visual display unit,not normed,
IDE10995-MAS11869,Calibrating the motors: status-Headrest adjustment: horizontal,standardized,
IDE10995-MAS11890,Calibrating the motors: status-Headrest adjustment: vertical,not normed,
IDE10996-MAS11891,Excessive force limit: status-Seat forward/back position adjustment: forwards,Adapted,
IDE10996-MAS11892,Excessive force limit: status-Seat forward/back position adjustment: backwards,Adapted,
IDE10996-MAS11895,Excessive force limit: status-Backrest inclination adjustment: forwards,Not adapted,
IDE10996-MAS11896,Excessive force limit: status-Backrest inclination adjustment: backwards,Not adapted,
IDE10996-MAS11959,Excessive force limit: status-Seat height adjustment higher,Not adapted,
IDE10996-MAS11960,Excessive force limit: status-Seat height adjustment lower,Not adapted,
IDE11024-MAS01390,Headrest height adjustment-Block 1,0,
IDE11024-MAS01391,Headrest height adjustment-Block 2,0,
IDE11024-MAS02282,Headrest height adjustment-Position,0,
IDE11024-MAS02955,Headrest height adjustment-Engine temperature,0, °C
IDE11024-MAS03129,Headrest height adjustment-Reset counter,0,
IDE11024-MAS04160,Headrest height adjustment-Load change,0,
IDE11024-MAS04337,Headrest height adjustment-Engine current,0, A
IDE11024-MAS05370,Headrest height adjustment-Direction of movement,Not operated,
IDE11024-MAS05563,Headrest height adjustment-Norming,not normed,
IDE11024-MAS05719,Headrest height adjustment-Maximum travel,0,
IDE11024-MAS12838,Headrest height adjustment-Standardization flag,never normed,
IDE11025-MAS01390,Headrest length adjustment-Block 1,32013,
IDE11025-MAS01391,Headrest length adjustment-Block 2,33079,
IDE11025-MAS02282,Headrest length adjustment-Position,32083,
IDE11025-MAS02955,Headrest length adjustment-Engine temperature,25, °C
IDE11025-MAS03129,Headrest length adjustment-Reset counter,1,
IDE11025-MAS04160,Headrest length adjustment-Load change,3,
IDE11025-MAS04337,Headrest length adjustment-Engine current,0, A
IDE11025-MAS05370,Headrest length adjustment-Direction of movement,Not operated,
IDE11025-MAS05563,Headrest length adjustment-Norming,standardized,
IDE11025-MAS05719,Headrest length adjustment-Maximum travel,1066,
IDE11025-MAS12838,Headrest length adjustment-Standardization flag,standardized,
IDE11957-MAS01390,Display unit adjustment-Block 1,32013,
IDE11957-MAS01391,Display unit adjustment-Block 2,33079,
IDE11957-MAS02282,Display unit adjustment-Position,32083,
IDE11957-MAS02955,Display unit adjustment-Engine temperature,25, °C
IDE11957-MAS03129,Display unit adjustment-Reset counter,1,
IDE11957-MAS04160,Display unit adjustment-Load change,3,
IDE11957-MAS04337,Display unit adjustment-Engine current,0, A
IDE11957-MAS05370,Display unit adjustment-Direction of movement,Not operated,
IDE11957-MAS05563,Display unit adjustment-Norming,standardized,
IDE11957-MAS05719,Display unit adjustment-Maximum travel,1066,
IDE11957-MAS12838,Display unit adjustment-Standardization flag,standardized,
IDE11969-MAS01390,Adjustment of foot rest-Block 1,32746,
IDE11969-MAS01391,Adjustment of foot rest-Block 2,33219,
IDE11969-MAS02282,Adjustment of foot rest-Position,32975,
IDE11969-MAS02955,Adjustment of foot rest-Engine temperature,25, °C
IDE11969-MAS03129,Adjustment of foot rest-Reset counter,2,
IDE11969-MAS04160,Adjustment of foot rest-Load change,4,
IDE11969-MAS04337,Adjustment of foot rest-Engine current,0, A
IDE11969-MAS05370,Adjustment of foot rest-Direction of movement,Not operated,
IDE11969-MAS05563,Adjustment of foot rest-Norming,standardized,
IDE11969-MAS05719,Adjustment of foot rest-Maximum travel,473,
IDE11969-MAS12838,Adjustment of foot rest-Standardization flag,standardized,
IDE11986-MAS01390,Adjustment 2 of visual display unit-Block 1,32746,
IDE11986-MAS01391,Adjustment 2 of visual display unit-Block 2,33219,
IDE11986-MAS02282,Adjustment 2 of visual display unit-Position,32975,
IDE11986-MAS02955,Adjustment 2 of visual display unit-Engine temperature,25, °C
IDE11986-MAS03129,Adjustment 2 of visual display unit-Reset counter,2,
IDE11986-MAS04160,Adjustment 2 of visual display unit-Load change,4,
IDE11986-MAS04337,Adjustment 2 of visual display unit-Engine current,0, A
IDE11986-MAS05370,Adjustment 2 of visual display unit-Direction of movement,Not operated,
IDE11986-MAS05563,Adjustment 2 of visual display unit-Norming,standardized,
IDE11986-MAS05719,Adjustment 2 of visual display unit-Maximum travel,473,
IDE11986-MAS12838,Adjustment 2 of visual display unit-Standardization flag,standardized,
IDE12083-MAS13890,Switch for lateral backrest support adjustment-Adjustment for lateral support backrest,Not operated,
IDE12083-MAS13891,Switch for lateral backrest support adjustment-Adjustment for lateral support seat cushion,Not operated,
MAS12838-IDE06510,Standardization flag-Adjustment for backrest angle,standardized,
MAS12838-IDE06511,Standardization flag-Seat height adjustment,standardized,
MAS12838-IDE06512,Standardization flag-Adjustment for seat forward/back position,standardized,
MAS12838-IDE06683,Standardization flag-Seat inclination adjustment,standardized,
MAS12838-IDE06684,Standardization flag-Lumbar support height adjustment,standardized,
MAS12838-IDE06685,Standardization flag-Lumbar support longitudinal position adjustment,standardized,
MAS12838-IDE08988,Standardization flag-Head restraint adjustment,never normed,
MAS12838-IDE08989,Standardization flag-Seat depth adjustment,never normed,
MAS12838-IDE08990,Standardization flag-Backrest top adjustment,never normed,
MAS12838-IDE08991,Standardization flag-Belt height adjustment,never normed,
MAS12838-IDE11957,Standardization flag-Display unit adjustment,never normed,
MAS12838-IDE11969,Standardization flag-Adjustment of foot rest,never normed,
MAS12838-IDE11986,Standardization flag-Adjustment 2 of visual display unit,never normed,
MAS12838-MAS11869,Standardization flag-Headrest adjustment: horizontal,standardized,
MAS12838-MAS11890,Standardization flag-Headrest adjustment: vertical,never normed,
ENG08879-IDE06510,Account_1-Adjustment for backrest angle,33049,
ENG08879-IDE06511,Account_1-Seat height adjustment,32781,
ENG08879-IDE06512,Account_1-Adjustment for seat forward/back position,32902,
ENG08879-IDE06683,Account_1-Seat inclination adjustment,32905,
ENG08879-IDE06684,Account_1-Lumbar support height adjustment,32083,
ENG08879-IDE06685,Account_1-Lumbar support longitudinal position adjustment,32975,
ENG08879-IDE08989,Account_1-Seat depth adjustment,0,
ENG08879-IDE08990,Account_1-Backrest top adjustment,0,
ENG08879-IDE08991,Account_1-Belt height adjustment,0,
ENG08879-IDE11024,Account_1-Headrest height adjustment,0,
ENG08880-IDE06510,Account_2-Adjustment for backrest angle,0,
ENG08880-IDE06511,Account_2-Seat height adjustment,0,
ENG08880-IDE06512,Account_2-Adjustment for seat forward/back position,0,
ENG08880-IDE06683,Account_2-Seat inclination adjustment,0,
ENG08880-IDE06684,Account_2-Lumbar support height adjustment,0,
ENG08880-IDE06685,Account_2-Lumbar support longitudinal position adjustment,0,
ENG08880-IDE08989,Account_2-Seat depth adjustment,0,
ENG08880-IDE08990,Account_2-Backrest top adjustment,0,
ENG08880-IDE08991,Account_2-Belt height adjustment,0,
ENG08880-IDE11024,Account_2-Headrest height adjustment,0,
ENG08881-IDE06510,Account_3-Adjustment for backrest angle,0,
ENG08881-IDE06511,Account_3-Seat height adjustment,0,
ENG08881-IDE06512,Account_3-Adjustment for seat forward/back position,0,
ENG08881-IDE06683,Account_3-Seat inclination adjustment,0,
ENG08881-IDE06684,Account_3-Lumbar support height adjustment,0,
ENG08881-IDE06685,Account_3-Lumbar support longitudinal position adjustment,0,
ENG08881-IDE08989,Account_3-Seat depth adjustment,0,
ENG08881-IDE08990,Account_3-Backrest top adjustment,0,
ENG08881-IDE08991,Account_3-Belt height adjustment,0,
ENG08881-IDE11024,Account_3-Headrest height adjustment,0,
ENG08882-IDE06510,Account_4-Adjustment for backrest angle,0,
ENG08882-IDE06511,Account_4-Seat height adjustment,0,
ENG08882-IDE06512,Account_4-Adjustment for seat forward/back position,0,
ENG08882-IDE06683,Account_4-Seat inclination adjustment,0,
ENG08882-IDE06684,Account_4-Lumbar support height adjustment,0,
ENG08882-IDE06685,Account_4-Lumbar support longitudinal position adjustment,0,
ENG08882-IDE08989,Account_4-Seat depth adjustment,0,
ENG08882-IDE08990,Account_4-Backrest top adjustment,0,
ENG08882-IDE08991,Account_4-Belt height adjustment,0,
ENG08882-IDE11024,Account_4-Headrest height adjustment,0,
ENG08883-IDE06510,Account_5-Adjustment for backrest angle,0,
ENG08883-IDE06511,Account_5-Seat height adjustment,0,
ENG08883-IDE06512,Account_5-Adjustment for seat forward/back position,0,
ENG08883-IDE06683,Account_5-Seat inclination adjustment,0,
ENG08883-IDE06684,Account_5-Lumbar support height adjustment,0,
ENG08883-IDE06685,Account_5-Lumbar support longitudinal position adjustment,0,
ENG08883-IDE08989,Account_5-Seat depth adjustment,0,
ENG08883-IDE08990,Account_5-Backrest top adjustment,0,
ENG08883-IDE08991,Account_5-Belt height adjustment,0,
ENG08883-IDE11024,Account_5-Headrest height adjustment,0,
ENG08884-IDE06510,Account_6-Adjustment for backrest angle,0,
ENG08884-IDE06511,Account_6-Seat height adjustment,0,
ENG08884-IDE06512,Account_6-Adjustment for seat forward/back position,0,
ENG08884-IDE06683,Account_6-Seat inclination adjustment,0,
ENG08884-IDE06684,Account_6-Lumbar support height adjustment,0,
ENG08884-IDE06685,Account_6-Lumbar support longitudinal position adjustment,0,
ENG08884-IDE08989,Account_6-Seat depth adjustment,0,
ENG08884-IDE08990,Account_6-Backrest top adjustment,0,
ENG08884-IDE08991,Account_6-Belt height adjustment,0,
ENG08884-IDE11024,Account_6-Headrest height adjustment,0,
ENG08885-IDE06510,Account_7-Adjustment for backrest angle,0,
ENG08885-IDE06511,Account_7-Seat height adjustment,0,
ENG08885-IDE06512,Account_7-Adjustment for seat forward/back position,0,
ENG08885-IDE06683,Account_7-Seat inclination adjustment,0,
ENG08885-IDE06684,Account_7-Lumbar support height adjustment,0,
ENG08885-IDE06685,Account_7-Lumbar support longitudinal position adjustment,0,
ENG08885-IDE08989,Account_7-Seat depth adjustment,0,
ENG08885-IDE08990,Account_7-Backrest top adjustment,0,
ENG08885-IDE08991,Account_7-Belt height adjustment,0,
ENG08885-IDE11024,Account_7-Headrest height adjustment,0,
ENG08878-IDE06510,BAP_Seat_Adjustment_Button_Status-Adjustment for backrest angle,Not operated,
ENG08878-IDE06511,BAP_Seat_Adjustment_Button_Status-Seat height adjustment,Not operated,
ENG08878-IDE06512,BAP_Seat_Adjustment_Button_Status-Adjustment for seat forward/back position,Not operated,
ENG08878-IDE06683,BAP_Seat_Adjustment_Button_Status-Seat inclination adjustment,Not operated,
ENG08878-IDE06684,BAP_Seat_Adjustment_Button_Status-Lumbar support height adjustment,Not operated,
ENG08878-IDE06685,BAP_Seat_Adjustment_Button_Status-Lumbar support longitudinal position adjustment,Not operated,
ENG08878-IDE08989,BAP_Seat_Adjustment_Button_Status-Seat depth adjustment,Not operated,
ENG08878-IDE08990,BAP_Seat_Adjustment_Button_Status-Backrest top adjustment,Not operated,
ENG08878-IDE08991,BAP_Seat_Adjustment_Button_Status-Belt height adjustment,Not operated,
ENG08878-IDE11024,BAP_Seat_Adjustment_Button_Status-Headrest height adjustment,Not operated,
ENG08878-IDE11025,BAP_Seat_Adjustment_Button_Status-Headrest length adjustment,Not operated,
ENG08878-IDE11957,BAP_Seat_Adjustment_Button_Status-Display unit adjustment,Not operated,
ENG08878-IDE11969,BAP_Seat_Adjustment_Button_Status-Adjustment of foot rest,Not operated,
ENG08878-IDE11986,BAP_Seat_Adjustment_Button_Status-Adjustment 2 of visual display unit,Not operated,
ENG08878-ENG09596,BAP_Seat_Adjustment_Button_Status-backrest_side_bolster,Not operated,
ENG08878-ENG09597,BAP_Seat_Adjustment_Button_Status-footmat,Not operated,
ENG08878-ENG09595,BAP_Seat_Adjustment_Button_Status-side_bolster,Not operated,
ENG05253-ENG101098,crash_precrash-Crash,not active,
ENG05253-ENG00891,crash_precrash-Precrash,not active,
ENG05258-ENG05268,Entnormierursache-Axis_1,Normierroutine,
ENG05258-ENG05277,Entnormierursache-Axis_10,Normierroutine,
ENG05258-ENG05269,Entnormierursache-Axis_2,Normierroutine,
ENG05258-ENG05270,Entnormierursache-Axis_3,Normierroutine,
ENG05258-ENG05271,Entnormierursache-Axis_4,Normierroutine,
ENG05258-ENG05272,Entnormierursache-Axis_5,Achse decodiert,
ENG05258-ENG05273,Entnormierursache-Axis_6,Achse decodiert,
ENG05258-ENG05274,Entnormierursache-Axis_7,Achse decodiert,
ENG05258-ENG05275,Entnormierursache-Axis_8,Achse decodiert,
ENG05258-ENG05276,Entnormierursache-Axis_9,Normierroutine,
ENG116729-ENG117054,info_developer-ax_da,80 91 7F 0D 81 A3 00 07 81 19 7F F8 86 27 00 07 80 0D 7D D4 80 17 00 07 80 89 7F 8C 80 A0 00 07 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 CF 7F EA 81 C3 00 07 7D 53 7D 0D 81 37 00 07,
ENG116729-ENG117006,info_developer-gl_lo,35 57 41 39 35 39 37 36 30 48 20 00 00 00 00 00 30 33 36 32 00 00 00 00 32 35 33 35 00 00 00 00 53 43 58 58 4D 51 42 56 57 33 38 58 00 00 00 00 0D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116729-ENG116875,info_developer-gl_pr,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 03 03 03 03 03 03 04 04 00 00 00 00,
ENG116729-ENG117035,info_developer-pne,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116729-ENG116968,info_developer-so_deb,00 00 00 00 00 00 00 00 6D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG05278-ENG05354,key_memory_activated-mmi_key_memory_activated,active,
ENG26210-ENG30378,Maximum travel-Axis_1_current,662,
ENG26210-ENG30379,Maximum travel-Axis_1_last,0,
ENG26210-ENG30380,Maximum travel-Axis_10_current,1066,
ENG26210-ENG30381,Maximum travel-Axis_10_last,0,
ENG26210-ENG30382,Maximum travel-Axis_2_current,1583,
ENG26210-ENG30383,Maximum travel-Axis_2_last,0,
ENG26210-ENG30384,Maximum travel-Axis_3_current,579,
ENG26210-ENG30385,Maximum travel-Axis_3_last,0,
ENG26210-ENG30386,Maximum travel-Axis_4_current,276,
ENG26210-ENG30387,Maximum travel-Axis_4_last,0,
ENG26210-ENG30388,Maximum travel-Axis_5_current,65535,
ENG26210-ENG30389,Maximum travel-Axis_5_last,0,
ENG26210-ENG30390,Maximum travel-Axis_6_current,65535,
ENG26210-ENG30391,Maximum travel-Axis_6_last,0,
ENG26210-ENG30392,Maximum travel-Axis_7_current,65535,
ENG26210-ENG30393,Maximum travel-Axis_7_last,0,
ENG26210-ENG30394,Maximum travel-Axis_8_current,65535,
ENG26210-ENG30395,Maximum travel-Axis_8_last,0,
ENG26210-ENG30396,Maximum travel-Axis_9_current,473,
ENG26210-ENG30397,Maximum travel-Axis_9_last,0,
ENG05251-IDE06842,Memory_ID_CAN_1-Status - Button 1,not active,
ENG05251-IDE06843,Memory_ID_CAN_1-Status - Button 2,not active,
ENG05251-IDE06844,Memory_ID_CAN_1-Status - Button 3,not active,
ENG05251-IDE06845,Memory_ID_CAN_1-Status - Button 4,not active,
ENG05251-ENG123088,Memory_ID_CAN_1-FFB_Close_Button,not active,
ENG05251-ENG123087,Memory_ID_CAN_1-FFB_Open_Button,not active,
ENG05251-ENG123089,Memory_ID_CAN_1-FT_lock,not active,
ENG05251-ENG123090,Memory_ID_CAN_1-FT_locked,not active,
ENG05252-MAS03679,Memory_ID_CAN_2-Terminal 15 status,active,
ENG05252-ENG123091,Memory_ID_CAN_2-DoorContact_more_than_10min_opened,not active,
ENG05252-ENG123092,Memory_ID_CAN_2-DoorContact_NotActive_Active,not active,
ENG05252-ENG09278,Memory_ID_CAN_2-FFB_HDF_Button,not active,
ENG05252-ENG05263,Memory_ID_CAN_2-Hardware_onoff,active,
ENG05252-ENG123093,Memory_ID_CAN_2-Memory_Adjustment,not active,
ENG05252-ENG123094,Memory_ID_CAN_2-MemoryButton_Pressed,not active,
ENG05252-ENG116986,Memory_ID_CAN_2-v_signal_less_v_threshold,active,
ENG26976-MAS03760,missing_pre_conditions-Wind deflector position,not active,
ENG26976-ENG116860,missing_pre_conditions-_reserviert,0,
ENG26976-ENG30399,missing_pre_conditions-backrest_locked,active,
ENG26976-ENG30400,missing_pre_conditions-backrest_unlocked,active,
ENG26976-ENG30434,missing_pre_conditions-button_pressed,not active,
ENG26976-ENG30644,missing_pre_conditions-coded_axes_not_normalized,not active,
ENG26976-ENG32216,missing_pre_conditions-other_adjustment_already_active,not active,
ENG26976-ENG100589,missing_pre_conditions-Reserviert 2,0,
ENG26976-ENG32451,missing_pre_conditions-reset_problem,not active,
ENG26976-ENG32661,missing_pre_conditions-speed_above_5kmh,not active,
ENG26976-ENG28397,missing_pre_conditions-Voltage_supply,not active,
ENG27030-ENG30602,personalization_last_function-cause_of_termination,0,
ENG27030,personalization_last_function,none,
ENG27030-ENG99298,personalization_last_function-State,none,
ENG05256-ENG05265,pwm_generator-pwm_generator_group_1_overload,not active,
ENG05256-ENG05266,pwm_generator-pwm_generator_group_2_overload,not active,
ENG05254-ENG99389,Resets-Resetcounter,5,
ENG05257-ENG05267,sbc-sbc_overload,not active,
ENG05279-ENG05366,Seat_Actual_Positions-Current_Position_fsv,32975,
ENG05279-ENG05362,Seat_Actual_Positions-Current_Position_ghv,32768,
ENG05279-ENG05369,Seat_Actual_Positions-Current_Position_kks,32768,
ENG05279-ENG05365,Seat_Actual_Positions-Current_Position_ksv_x,32083,
ENG05279-ENG05359,Seat_Actual_Positions-Current_Position_ksv_z,32768,
ENG05279-ENG05364,Seat_Actual_Positions-Current_Position_ldh,32083,
ENG05279-ENG05363,Seat_Actual_Positions-Current_Position_ldw,32975,
ENG05279-ENG05361,Seat_Actual_Positions-Current_Position_lkv,32768,
ENG05279-ENG05356,Seat_Actual_Positions-Current_Position_lnv,33049,
ENG05279-ENG05367,Seat_Actual_Positions-Current_Position_rse1,32083,
ENG05279-ENG05368,Seat_Actual_Positions-Current_Position_rse2,32975,
ENG05279-ENG05357,Seat_Actual_Positions-Current_Position_shv,32781,
ENG05279-ENG05355,Seat_Actual_Positions-Current_Position_slv,32913,
ENG05279-ENG05358,Seat_Actual_Positions-Current_Position_snv,32905,
ENG05279-ENG05360,Seat_Actual_Positions-Current_Position_stv,32768,
ENG123054-ENG05349,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_1,not active,
ENG123054-ENG05350,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_2,not active,
ENG123054-ENG05351,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_3,not active,
ENG123054-ENG05352,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_4,not active,
ENG123054-ENG05353,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_SET,not active,
ENG123054-ENG123084,Seat_Adjustment_Memory_Info_CAN-MMB_glob_Stop,not active,
ENG123054-ENG123077,Seat_Adjustment_Memory_Info_CAN-MMB_storage_0,not active,
ENG123054-ENG123078,Seat_Adjustment_Memory_Info_CAN-MMB_storage_1,not active,
ENG123054-ENG123079,Seat_Adjustment_Memory_Info_CAN-MMB_storage_2,not active,
ENG123054-ENG123080,Seat_Adjustment_Memory_Info_CAN-MMB_storage_3,not active,
ENG123054-ENG123083,Seat_Adjustment_Memory_Info_CAN-MMB_store,not active,
ENG123054-ENG123082,Seat_Adjustment_Memory_Info_CAN-MMB_tast,not active,
ENG123054-ENG123081,Seat_Adjustment_Memory_Info_CAN-MMB_tipp,not active,
ENG123055-ENG123086,Seat_Adjustment_Remote_Control_Locking_Info_CAN-Active_Remote_Control_Key,not active,
ENG123055-ENG123085,Seat_Adjustment_Remote_Control_Locking_Info_CAN-Remote_Control_Key_Signal,Key 1,
ENG123053-ENG05345,Seat_Adjustment_State_Info_CAN-FSM_Backrest_Head_Movement,not active,
ENG123053-ENG05340,Seat_Adjustment_State_Info_CAN-FSM_Backrest_Inclination_Movement,not active,
ENG123053-ENG05346,Seat_Adjustment_State_Info_CAN-FSM_Belt_Height_Movement,not active,
ENG123053-ENG05343,Seat_Adjustment_State_Info_CAN-FSM_Headrest_Movement,not active,
ENG123053-ENG123076,Seat_Adjustment_State_Info_CAN-FSM_KD_Error,not active,
ENG123053-ENG05348,Seat_Adjustment_State_Info_CAN-FSM_Lumbar_Height_Movement,not active,
ENG123053-ENG05347,Seat_Adjustment_State_Info_CAN-FSM_Lumbar_Longitudial_Movement,not active,
ENG123053-ENG05344,Seat_Adjustment_State_Info_CAN-FSM_Seat_Depth_Movement,not active,
ENG123053-ENG05341,Seat_Adjustment_State_Info_CAN-FSM_Seat_Height_Movement,not active,
ENG123053-ENG05342,Seat_Adjustment_State_Info_CAN-FSM_Seat_Inclination_Movement,not active,
ENG123053-ENG05339,Seat_Adjustment_State_Info_CAN-FSM_Seat_Longitudial_Movement,not active,
ENG123053-ENG123075,Seat_Adjustment_State_Info_CAN-FSM_SeatMovement,not active,
ENG27116-IDE06510,Seat_Position_Memory_Remote_Control_5-Adjustment for backrest angle,0,
ENG27116-IDE06511,Seat_Position_Memory_Remote_Control_5-Seat height adjustment,0,
ENG27116-IDE06512,Seat_Position_Memory_Remote_Control_5-Adjustment for seat forward/back position,0,
ENG27116-IDE06683,Seat_Position_Memory_Remote_Control_5-Seat inclination adjustment,0,
ENG27116-IDE06684,Seat_Position_Memory_Remote_Control_5-Lumbar support height adjustment,0,
ENG27116-IDE06685,Seat_Position_Memory_Remote_Control_5-Lumbar support longitudinal position adjustment,0,
ENG27116-IDE08989,Seat_Position_Memory_Remote_Control_5-Seat depth adjustment,0,
ENG27116-IDE08990,Seat_Position_Memory_Remote_Control_5-Backrest top adjustment,0,
ENG27116-IDE08991,Seat_Position_Memory_Remote_Control_5-Belt height adjustment,0,
ENG27116-IDE11024,Seat_Position_Memory_Remote_Control_5-Headrest height adjustment,0,
ENG27117-IDE06510,Seat_Position_Memory_Remote_Control_6-Adjustment for backrest angle,0,
ENG27117-IDE06511,Seat_Position_Memory_Remote_Control_6-Seat height adjustment,0,
ENG27117-IDE06512,Seat_Position_Memory_Remote_Control_6-Adjustment for seat forward/back position,0,
ENG27117-IDE06683,Seat_Position_Memory_Remote_Control_6-Seat inclination adjustment,0,
ENG27117-IDE06684,Seat_Position_Memory_Remote_Control_6-Lumbar support height adjustment,0,
ENG27117-IDE06685,Seat_Position_Memory_Remote_Control_6-Lumbar support longitudinal position adjustment,0,
ENG27117-IDE08989,Seat_Position_Memory_Remote_Control_6-Seat depth adjustment,0,
ENG27117-IDE08990,Seat_Position_Memory_Remote_Control_6-Backrest top adjustment,0,
ENG27117-IDE08991,Seat_Position_Memory_Remote_Control_6-Belt height adjustment,0,
ENG27117-IDE11024,Seat_Position_Memory_Remote_Control_6-Headrest height adjustment,0,
ENG27118-IDE06510,Seat_Position_Memory_Remote_Control_7-Adjustment for backrest angle,0,
ENG27118-IDE06511,Seat_Position_Memory_Remote_Control_7-Seat height adjustment,0,
ENG27118-IDE06512,Seat_Position_Memory_Remote_Control_7-Adjustment for seat forward/back position,0,
ENG27118-IDE06683,Seat_Position_Memory_Remote_Control_7-Seat inclination adjustment,0,
ENG27118-IDE06684,Seat_Position_Memory_Remote_Control_7-Lumbar support height adjustment,0,
ENG27118-IDE06685,Seat_Position_Memory_Remote_Control_7-Lumbar support longitudinal position adjustment,0,
ENG27118-IDE08989,Seat_Position_Memory_Remote_Control_7-Seat depth adjustment,0,
ENG27118-IDE08990,Seat_Position_Memory_Remote_Control_7-Backrest top adjustment,0,
ENG27118-IDE08991,Seat_Position_Memory_Remote_Control_7-Belt height adjustment,0,
ENG27118-IDE11024,Seat_Position_Memory_Remote_Control_7-Headrest height adjustment,0,
ENG05255-ENG116986,Source_Last_Reset-Low_Voltage,not active,
ENG05255-ENG123073,Source_Last_Reset-Low_Voltage_At_Run_Up,not active,
ENG05255-ENG123072,Source_Last_Reset-Power_On_Reset,active,
ENG05255-ENG123071,Source_Last_Reset-Software_Reset_by_diagnosis,not active,
ENG05255-ENG110107,Source_Last_Reset-Watchdog_reset,not active,
ENG05255-ENG123074,Source_Last_Reset-Watchdog_Reset_At_Run_Up,not active,
Elapsed Time: 00:21,,,
;SW:2Q0-907-686-E HW:2Q0-907-686-E --- Lane Change
;Component:HRE_Master H25 0284, Coding:569945D0
;EV_HREntryHellaGen3Mstr,001015,EV_HREntryHellaGen3Mstr.rod
;Thursday,17,March,2022,11:49:26:62242
;VCID: 3C213AB936E495CBD3A-8068
IDE00018,Voltage terminal 15,13.12, V
IDE00020,Terminal 15 status,OFF,
IDE00102,Control Module temperature,49.0, °C
IDE00925,Yaw rate,0.08, °/s
IDE01441,Back-up lamp,OFF,
IDE01766-MAS01853,Distance impulses-Left front,1,
IDE01766-MAS01854,Distance impulses-Right front,0,
IDE01766-MAS01855,Distance impulses-Left rear,0,
IDE01766-MAS01856,Distance impulses-Right rear,0,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,19 0A 04 1B,
IDE02049,Trailer detected,not detected,
IDE02057-MAS10062,Dynamic calibration: status-Auto. calibration: distance travelled,2327.00, km
IDE02057-MAS10063,Dynamic calibration: status-Auto. calibration: percent. progress Master,100, %
IDE02057-MAS10064,Dynamic calibration: status-Auto. calibration: percent. progress Slave,100, %
IDE02057,Dynamic calibration: status,OFF,
IDE02219-MAS02471,Steering wheel angle: sign-Sign,Negative,
IDE02219,Steering wheel angle: sign,419.20, °
IDE02486,Data logger triggering,not initialized,
IDE03619,System condition,On,
IDE05064,lane change assist. 2: supply voltage,13.12, V
IDE05065,lane change assist. 2: temperature,47.0, °C
IDE05067-MAS03385,Functional status of lane change assist.-Lane change assistance,passive,
IDE05067-MAS08213,Functional status of lane change assist.-Blind spot detection,OFF,
IDE05067-MAS10332,Functional status of lane change assist.-Rear Cross Traffic Alert,passive,
IDE05067-MAS15693,Functional status of lane change assist.-Exit warning,OFF,
IDE05070,Curve radius,32640, m
IDE05077-MAS02475,Rain/light recognition sensor via data bus-Brightness infrared,1,
IDE05077-MAS02477,Rain/light recognition sensor via data bus-Front brightness,409,
IDE05077,Rain/light recognition sensor via data bus,installed,
IDE05078-MAS04108,Distance of object 1-Distance in X-direction,25.25, m
IDE05078-MAS04109,Distance of object 1-Distance in Y-direction,15.88, m
IDE05079-MAS02465,Relative speed of object 1-Speed in y-direction,8.03, m/s
IDE05079-MAS02469,Relative speed of object 1-Speed in x-direction,90.25, m/s
IDE05080-MAS04108,Distance of object 2-Distance in X-direction,25.25, m
IDE05080-MAS04109,Distance of object 2-Distance in Y-direction,15.88, m
IDE05081-MAS02465,Relative speed of object 2-Speed in y-direction,8.03, m/s
IDE05081-MAS02469,Relative speed of object 2-Speed in x-direction,90.25, m/s
IDE05082-MAS04108,Distance of object 3-Distance in X-direction,25.25, m
IDE05082-MAS04109,Distance of object 3-Distance in Y-direction,15.88, m
IDE05083-MAS02465,Relative speed of object 3-Speed in y-direction,56.03, m/s
IDE05083-MAS02469,Relative speed of object 3-Speed in x-direction,90.25, m/s
IDE05084,Closest object left lane,No_Object,
IDE05085,Closest object right lane,No_Object,
IDE05086,Closest object lane used,No_Object,
IDE05087,Dynamic angle offset lane change assist. 1,1.50, °
IDE05088,Dynamic angle offset lane change assist. 2,-0.20, °
IDE05090,Measured receiving power lane change assist. 1,0, %
IDE05091,Measured receiving power lane change assist. 2,0, %
IDE05092,Measured angle lane change assist. 1,-20.48, °
IDE05093,Measured angle lane change assist. 2,-20.48, °
IDE05094,Static angle offset lane change assist. 1,10.24, °
IDE05095,Static angle offset lane change assist. 2,10.24, °
IDE06199-MAS01167,Indicator light for lane change assist. in instrument cluster-Actuation time,no control,
IDE06199-ENG39349,Indicator light for lane change assist. in instrument cluster-IoReached Status,Output diagnostic test not active,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,05,
IDE07145-MAS06785,Component protection properties-GFA key,Not Used,
IDE07145-MAS09610,Component protection properties-Status GFA Key,invalid,
IDE07145-MAS09611,Component protection properties-Status Master ECU Key,not stored,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 01,
IDE10102,Right warning light flashing cycle,OFF,
IDE10103,Left warning light flashing cycle,OFF,
IDE10104,Left warning light status,OFF,
IDE10106,Right warning light status,OFF,
IDE10107,Dimming value of left warning light: warning algorithm,0, %
IDE10108,Status of left warning light: warning algorithm,---,
IDE10109,Dimming value of right warning light: warning algorithm,0, %
IDE10110,Status of right warning light: warning algorithm,---,
IDE10229-IDE10101,Warning light for blind spot assistant in left exterior mirror-Dimming value of left warning light,0, %
IDE10229-MAS01167,Warning light for blind spot assistant in left exterior mirror-Actuation time,no control,
IDE10229-ENG39349,Warning light for blind spot assistant in left exterior mirror-IoReached Status,Output diagnostic test not active,
IDE10230-IDE10105,Warning light for blind spot assistant in right exterior mirror-Dimming value of right warning light,0, %
IDE10230-MAS01167,Warning light for blind spot assistant in right exterior mirror-Actuation time,no control,
IDE10230-ENG39349,Warning light for blind spot assistant in right exterior mirror-IoReached Status,Output diagnostic test not active,
IDE10235-IDE10233,Status night design-Night design,not activated,
IDE10235-IDE10234,Status night design-Day design,activated,
IDE10235,Status night design,OFF,
IDE10236-MAS01487,Lane keeping warning system-LED,yellow,
IDE10236-MAS10041,Lane keeping warning system-Distance to lane,1.25, m
IDE10236-MAS10042,Lane keeping warning system-Time to lane crossing,3.0, s
IDE10236-MAS10043,Lane keeping warning system-Vehicle side,Right,
IDE11133-MAS01167,Output of parking assistant warning-Actuation time,no control,
IDE11133-ENG39349,Output of parking assistant warning-IoReached Status,Output diagnostic test not active,
IDE13096,Rear cross traffic assistant: left warning level,cannot be assessed,
IDE13107,Rear cross traffic assistant: right warning level,cannot be assessed,
IDE13845,Production mode status,not active,
IDE80001,Analysis 1,No display,
IDE80002,Analysis 2,keine_Anzeige,
IDE80003,Analysis 3,No display,
IDE80004,Analysis 4,keine_Anzeige,
MAS00370,Vehicle speed,0.00, km/h
MAS05108-MAS10050,ESP-Delay regulation,Feedback: delay regulation not available,
MAS05108-MAS10059,ESP-Blind spot warning: message,consistent,
MAS05108-MAS10669,ESP-Delay regulation: brake jolt,Not available,
MAS08785-IDE02679,Parking aid-Tone sensor,Measuring value not available,
MAS08785-IDE03619,Parking aid-System condition,active,
MAS10065-MAS04108,Distance of object 4-Distance in X-direction,25.25, m
MAS10065-MAS04109,Distance of object 4-Distance in Y-direction,15.88, m
MAS10066-MAS04108,Distance of object 5-Distance in X-direction,25.25, m
MAS10066-MAS04109,Distance of object 5-Distance in Y-direction,15.88, m
MAS10067-MAS02465,Relative speed of object 4-Speed in y-direction,8.03, m/s
MAS10067-MAS02469,Relative speed of object 4-Speed in x-direction,90.25, m/s
MAS10068-MAS02465,Relative speed of object 5-Speed in y-direction,8.03, m/s
MAS10068-MAS02469,Relative speed of object 5-Speed in x-direction,90.25, m/s
MAS18838,Auto-calibration: adaptive angle correction characteristic curve (slave),0, %
MAS18839,Auto-calibration: adaptive angle correction characteristic curve,0, %
MAS18840-MAS04108,Distance of object 6-Distance in X-direction,25.25, m
MAS18840-MAS04109,Distance of object 6-Distance in Y-direction,15.88, m
MAS18841-MAS02465,Relative speed of object 6-Speed in y-direction,8.03, m/s
MAS18841-MAS02469,Relative speed of object 6-Speed in x-direction,90.25, m/s
Elapsed Time: 00:08,,,
;SW:5Q0-959-593-L HW:5Q0-959-593-F --- Door Elect, Driver
;Component:TSG FS003 0350, Coding:003B13208200040000000000
;EV_DCU2DriveSideMAXHKLO,001018,EV_DCU2DriveSideMAXHKLO.rod
;Thursday,17,March,2022,11:49:42:62242
;VCDS Version: Release 22.3.0 Data version: 20220225 DS336.1
;VCID: 4ACD6C616C303B7B516-801E
Group,Description,Actual,
IDE00310,Outside temperature,23.00, °C
IDE01766-MAS02248,Distance impulses-Signal state,Not available,
IDE01992-MAS12276,Installation list: current installations-Front door control module,can be reached,
IDE01992-MAS12277,Installation list: current installations-Rear door control module,not attainable,
IDE01993-MAS12276,Control module reference number-Front door control module,Driver door control module,
IDE01993-MAS12277,Control module reference number-Rear door control module,Not assigned,
IDE02260-IDE00773,Supply voltage for door control module: rear: left-Terminal 15 status via CAN,active,
IDE02260-IDE01715,Supply voltage for door control module: rear: left-Status terminal S,active,
IDE02260-IDE05835,Supply voltage for door control module: rear: left-Supply voltage for central locking,13.40, V
IDE02262,synchronous mirror adjustment,not installed,
IDE02267-IDE05835,Supply voltage for door control module: front: driver side-Supply voltage for central locking,13.10, V
IDE02384-MAS12276,Status of event memory-Front door control module,No malfunctions in DTC memory,
IDE02384-MAS12277,Status of event memory-Rear door control module,No malfunctions in DTC memory,
IDE03150-MAS12276,Readiness for bus sleep mode-Front door control module,active,
IDE03150-MAS12277,Readiness for bus sleep mode-Rear door control module,Bus sleep mode,
IDE04215-MAS02428,Mirror adjustment switch-Switch positions,Right,
IDE04216-MAS01458,Mirror heater-Operating condition,not active,
IDE04216-MAS02965,Mirror heater-Performance percentage,0, %
IDE04216-MAS04247,Mirror heater-Button,Not operated,
IDE04217,Fuel filler door release button,not installed,
IDE04218,Turn signal in exterior rear-view mirror,not active,
IDE04219-IDE02266,Window regulator control unit: driver side-Passenger side rear power window button,Not operated,
IDE04219-IDE04220,Window regulator control unit: driver side-Driver power window button,Not operated,
IDE04219-IDE06621,Window regulator control unit: driver side-Driver side rear power window button,Not operated,
IDE04219-IDE06872,Window regulator control unit: driver side-Front passenger power window button,Not operated,
IDE04220,Driver power window button,Not operated,
IDE04343-MAS03180,Bus identification-Local data bus,Not assigned,
IDE04343-MAS12276,Bus identification-Front door control module,Bus master,
IDE04411,Child safety button,Not operated,
IDE04539-MAS01634,Mirror memory-Supply voltage,active,
IDE04539-MAS02228,Mirror memory-X coordinate,50, %
IDE04539-MAS02229,Mirror memory-Y coordinate,53, %
IDE04539-MAS02476,Mirror memory-installed,installed,
IDE04540,Mirror adjustment (X/Y direction),Position center,
IDE04580,Dimming of inside door handle lighting,0, %
IDE04581,Dimming for interior ambient lighting,0, %
IDE04586,Mirror fold-in activation,not installed,
IDE05071-MAS02594,Lane change assistance button-Indicator light in switch,not installed,
IDE05071-MAS07693,Lane change assistance button-Button Status,Implausible,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,closed,
IDE05720-IDE04213,Front driver side door status-Central locking button,Not operated,
IDE05725,Dimmer terminal 58xs,0, %
IDE05726,Dimmer terminal 58xd,83, %
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,No,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,No,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,Yes,
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,not coded/not installed,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not coded/not installed,
IDE06206-MAS01453,Front window regulator status: driver side-Blocking detection,active,
IDE06206-MAS02097,Front window regulator status: driver side-Window position,0.00, %
IDE06206-MAS02098,Front window regulator status: driver side-Window regulator standardized,Yes,
IDE06206-MAS04642,Front window regulator status: driver side-Before upper stop,active,
IDE06206-MAS05370,Front window regulator status: driver side-Direction of movement,Position top,
IDE06208-MAS01453,Rear window regulator status: driver side-Blocking detection,active,
IDE06208-MAS02039,Rear window regulator status: driver side-Force limitation,not active,
IDE06208-MAS02097,Rear window regulator status: driver side-Window position,0.00, %
IDE06208-MAS02098,Rear window regulator status: driver side-Window regulator standardized,Yes,
IDE06208-MAS03548,Rear window regulator status: driver side-Motor current,Not available,
IDE06208-MAS04642,Rear window regulator status: driver side-Before upper stop,active,
IDE06208-MAS05370,Rear window regulator status: driver side-Direction of movement,Position top,
IDE06469,Ambient illumination for speaker,Not available,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not installed,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not installed,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not installed,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not installed,
IDE06621,Driver side rear power window button,Not operated,
IDE06931-MAS01159,Ident. of rear window regulator programming: driver side-Version number,BM06,
IDE06935,Rear window regulator relay: driver side,Open,
IDE06937-MAS02545,Front window regulator reversing position: driver side-Last,127.50, %
IDE06937-MAS02546,Front window regulator reversing position: driver side-Second to last,127.50, %
IDE06937-MAS02547,Front window regulator reversing position: driver side-Third to last,127.50, %
IDE06937-MAS02548,Front window regulator reversing position: driver side-Fourth to last,127.50, %
IDE06937-MAS05380,Front window regulator reversing position: driver side-fifth to last,127.50, %
IDE06939-MAS02545,Rear window regulator reversing position: driver side-Last,0.00, %
IDE06939-MAS02546,Rear window regulator reversing position: driver side-Second to last,0.00, %
IDE06939-MAS02547,Rear window regulator reversing position: driver side-Third to last,127.50, %
IDE06939-MAS02548,Rear window regulator reversing position: driver side-Fourth to last,127.50, %
IDE06939-MAS05380,Rear window regulator reversing position: driver side-fifth to last,127.50, %
IDE06940,Rear window regulator child lock: driver side,not active,
IDE07405-MAS02447,Enable driver front window regulator relay-Release,Yes,
IDE07407-IDE03114,Enable driver-side rear window regulator-Comfort function,No,
IDE07407-MAS02447,Enable driver-side rear window regulator-Release,Yes,
IDE07409-MAS02955,Excessive temper. disconnect: front window regulator: driv.side-Engine temperature,15, °C
IDE07411-MAS01632,Excess.temp.disconnect: rear window regulator: driver side-Status,not active,
IDE07411-MAS02955,Excess.temp.disconnect: rear window regulator: driver side-Engine temperature,Not available,
IDE07415,Comfort function for rear window regulator: driver side,not active,
IDE07543,Vehicle speed,0.00, km/h
IDE08205-MAS01453,Closing assistance-Blocking detection,not active,
IDE08205-MAS02103,Closing assistance-Signal from door lock: catch,Implausible,
IDE08205-MAS05370,Closing assistance-Direction of movement,Not available,
IDE08205-MAS08613,Closing assistance-Return contact,closed,
IDE08205-MAS08614,Closing assistance-Closing assist motor current,Not available,
IDE08205-MAS09346,Closing assistance-Door position,closed,
IDE08205-MAS09347,Closing assistance-Redundant door contact,not installed,
IDE08697-MAS07302,Number of driving cycles without opening door-Max. number of driving cycles without opening door,0,
IDE08795,Rear shade button,not installed,
IDE09071-MAS00030,Seat belt positioner-Seat occupied recognition,not active,
IDE09071-MAS02666,Seat belt positioner-Seat belt buckle scan,Open,
IDE09071-MAS05370,Seat belt positioner-Direction of movement,Not available,
IDE09071-MAS08502,Seat belt positioner-Standardized belt feeder,No,
IDE09071-MAS08503,Seat belt positioner-End stop of Hall sensor,not detected,
IDE09071-MAS08504,Seat belt positioner-Position of belt feeder,Not available,
IDE09071-MAS08505,Seat belt positioner-Motor current of belt feeder,Not available,
IDE09335,Mirror fold-in: current consumption,Not available,
IDE09798,Play protection: mirror fold-in,not active,
IDE10158,Window lift: switch-over from front to rear,not installed,
IDE10164-MAS01632,Automatically dimming exterior mirrors-Status,not installed,
IDE10164-MAS03691,Automatically dimming exterior mirrors-Dimming,0, %
IDE12335-IDE12338,Door heating element 1-Sensor for door heating element 1,not installed,
IDE12335-MAS03095,Door heating element 1-Function status,not installed,
IDE12335-MAS04136,Door heating element 1-Current,not installed,
IDE12335-MAS09022,Door heating element 1-PWM value,not installed,
IDE12336-IDE12474,Door heating element 2-Sensor for door heating element 2,not installed,
IDE12336-MAS03095,Door heating element 2-Function status,not installed,
IDE12336-MAS04136,Door heating element 2-Current,not installed,
IDE12336-MAS09022,Door heating element 2-PWM value,not installed,
IDE12422-IDE02266,Driver side front door control head-Passenger side rear power window button,Not operated,
IDE12422-IDE04220,Driver side front door control head-Driver power window button,Not operated,
IDE12422-IDE04411,Driver side front door control head-Child safety button,Not operated,
IDE12422-IDE04540,Driver side front door control head-Mirror adjustment (X/Y direction),Position bottom,
IDE12422-IDE06621,Driver side front door control head-Driver side rear power window button,Not operated,
IDE12422-IDE06872,Driver side front door control head-Front passenger power window button,Not operated,
IDE12422-IDE10158,Driver side front door control head-Window lift: switch-over from front to rear,not installed,
IDE12422-IDE11140,Driver side front door control head-Mirror folding position,not installed,
IDE12422-MAS14179,Driver side front door control head-Child safety lock rear driver side: status,not active,
IDE12422-MAS14180,Driver side front door control head-Child safety lock rear passenger side: status,not active,
IDE12422-MAS15309,Driver side front door control head-Mirror selector switch: left,Not operated,
IDE12422-MAS15310,Driver side front door control head-Mirror selection switch: right,operated,
IDE12422-MAS15311,Driver side front door control head-Button: open rear lid,not installed,
IDE12422-MAS15312,Driver side front door control head-Close rear lid button,not installed,
IDE12422-MAS15313,Driver side front door control head-Bus signal: open rear lid,Not operated,
IDE12422-MAS15314,Driver side front door control head-Close rear lid bus signal,Not operated,
IDE13421-IDE06842,Memory seat adjustment control panel-Status - Button 1,not installed,
IDE13421-IDE06843,Memory seat adjustment control panel-Status - Button 2,not installed,
IDE13421-IDE06844,Memory seat adjustment control panel-Status - Button 3,not installed,
IDE13421-IDE06845,Memory seat adjustment control panel-Status - Button 4,not installed,
IDE13421-MAS05766,Memory seat adjustment control panel-Status of button for seat position storing,not installed,
IDE13865-MAS02099,Exterior door handle actuator-Switch for inside door handle,not installed,
IDE13865-MAS02100,Exterior door handle actuator-Switch for outside door handle,not installed,
IDE13865-MAS09598,Exterior door handle actuator-Request on CAN,Unknown (6),
IDE13865-MAS11741,Exterior door handle actuator-CAN Status,Initialization,
IDE13865-MAS17088,Exterior door handle actuator-Contact: exterior door handle retracted,not installed,
IDE13865-MAS17089,Exterior door handle actuator-Contact: exterior door handle extended,not installed,
IDE13865-MAS17090,Exterior door handle actuator-Actuator activation status,not installed,
IDE14109-MAS14614,Excess temperature shutdown of close assist-Switch-on threshold,Not available,
IDE14109-MAS15599,Excess temperature shutdown of close assist-Counter reading,Not available,
IDE14109,Excess temperature shutdown of close assist,not active,
IDE15336,Light output 1 pin D8 target brightness on front driver side,0, %
IDE15338,Light output 3 pin C1/B3 target brightness on front driver side,0, %
IDE15339,Light output 4 pin D16 target brightness on front driver side,Not available,
IDE15636,Light output 2 pin D3 target brightness on front driver side,0, %
IDE16389-MAS25781,Front ambient Lighting configuration - light output 1-Malfunction location:,Driver side exterior door handle lamp,
IDE16390-MAS25781,Front ambient Lighting configuration - light output 2-Malfunction location:,Driver side exterior door handle lamp,
IDE16391-MAS25781,Front ambient Lighting configuration - light output 3-Malfunction location:,Mirror welcome light on driver side,
IDE16392-MAS25781,Front ambient Lighting configuration - light output 4-Malfunction location:,Unknown (255),
MAS01872,Rear lid remote control lock switch,not installed,
MAS02101,Child safety lock,not active,
MAS06010,Ambient light,0, %
ENG117315-ENG32834,Window_Regulator_Driver_Side_Rear_VW_Workshop_System_Name-System_short_sign,J926 ,
;SW:5WA-907-145-G HW:5WA-907-145-C --- Steering Assist
;Component:BASGEN1MQB37 502 1040, Coding:0000000000000001000002010100010000000100010101
;EV_SteerAssisBASGEN1MQB37,007046,EV_SteerAssisBASGEN1MQB37_007_VW38.rod
;Thursday,17,March,2022,11:50:02:62242
;VCID: 4EC560719058175B0DE-801A
IDE00019,Voltage terminal 30,13.37, V
IDE00020,Terminal 15 status,On,
IDE00021,Engine RPM,777, /min
IDE00323-IDE01022,Security Access: Number of invalid keys-Counter: incorrect inputs of key-code,0,
IDE00323-MAS01155,Security Access: Number of invalid keys-Control module,Not blocked,
IDE00323-MAS02913,Security Access: Number of invalid keys-Remaining running time,0,
IDE02202,End stage temperature,34, °C
IDE02955,System status,Driving mode,
IDE03682-IDE04457,motor position sensor-Electric motor speed,-18000.1, /min
IDE03682-MAS02961,motor position sensor-Engine angle,65535, °
IDE03735,Steering torque,-0.2, Nm
IDE04183,Steering assistance: target engine torque,0.0, Nm
IDE04184,Steering assistance: engine output,100, %
IDE04448,Steering angle sensor: angle,-422, °
IDE04454,Steering angle sensor: angle speed,0, °/s
IDE04458,Steering angle sensor: mechanical steering stroke,161, mm
IDE04459,Steering angle sensor: offset index mark mechanical middle,235, mm
IDE04460,Steering angle sensor: offset straight line running,-0.1, °
IDE04510-MAS03732,Steering angle sensor: slope detection index-Steering angle speed negative dropping slope on curve,not detected,
IDE04510-MAS03733,Steering angle sensor: slope detection index-Steering angle speed negative rising slope on curve,not detected,
IDE04510-MAS03734,Steering angle sensor: slope detection index-Steering angle speed positive dropping slope on curve,not detected,
IDE04510-MAS03735,Steering angle sensor: slope detection index-Steering angle speed positive rising slope on curve,not detected,
IDE04510-MAS03736,Steering angle sensor: slope detection index-Index mark,not detected,
IDE05155,Power steering current consumption,0.0, A
IDE05162-IDE03723,Software end stop-End stops for steering,Adapted,
IDE05162-MAS03095,Software end stop-Function status,active,
IDE05162-MAS11513,Software end stop-End stop left,80.71, mm
IDE05162-MAS11514,Software end stop-End stop right,-80.32, mm
IDE05162-MAS12179,Software end stop-Validation of end stops: left and right,Condition met,
IDE05162-MAS12180,Software end stop-Validation of end stops: steering stroke,not performed,
IDE05162-MAS12181,Software end stop-Validation of end stops: center,not performed,
IDE05713-IDE01864,Network diagnosis-Status of current bus communication,active,
IDE05713-MAS04460,Network diagnosis-Validity,No,
IDE05713-MAS06528,Network diagnosis-Release status,No,
IDE07543,Vehicle speed,0, km/h
IDE10300,OBD Driving Cycle detected,active,
IDE11591-IDE11629,Result of basic setting of steering angle-Status of the active routine,Finish routine: routine OK,
IDE11591-MAS05584,Result of basic setting of steering angle-Result,Preconditions met,
IDE11591-MAS14036,Result of basic setting of steering angle-Number of iterations,2,
IDE11591-MAS14037,Result of basic setting of steering angle-RESTRICTION,no restriction,
IDE11591-MAS14038,Result of basic setting of steering angle-Type of restriction,Precondition,
IDE11602-IDE11629,Result of steering angle sensor: initialization-Status of the active routine,Finish routine: routine OK,
IDE11602-MAS05584,Result of steering angle sensor: initialization-Result,Preconditions met,
IDE11602-MAS14036,Result of steering angle sensor: initialization-Number of iterations,2,
IDE11602-MAS14037,Result of steering angle sensor: initialization-RESTRICTION,no restriction,
IDE11602-MAS14038,Result of steering angle sensor: initialization-Type of restriction,Precondition,
IDE11603-IDE11629,Result of steering angle sensor: move to mechanical center-Status of the active routine,Finish routine: routine OK,
IDE11603-MAS05584,Result of steering angle sensor: move to mechanical center-Result,Preconditions met,
IDE11603-MAS14036,Result of steering angle sensor: move to mechanical center-Number of iterations,2,
IDE11603-MAS14037,Result of steering angle sensor: move to mechanical center-RESTRICTION,no restriction,
IDE11603-MAS14038,Result of steering angle sensor: move to mechanical center-Type of restriction,Precondition,
IDE11604-IDE11629,Result of steer.angle sens.: zero calibr.steer.wheel balance-Status of the active routine,Finish routine: routine OK,
IDE11604-MAS05584,Result of steer.angle sens.: zero calibr.steer.wheel balance-Result,Preconditions met,
IDE11604-MAS14036,Result of steer.angle sens.: zero calibr.steer.wheel balance-Number of iterations,2,
IDE11604-MAS14037,Result of steer.angle sens.: zero calibr.steer.wheel balance-RESTRICTION,no restriction,
IDE11604-MAS14038,Result of steer.angle sens.: zero calibr.steer.wheel balance-Type of restriction,Precondition,
IDE11605-IDE11629,Result of resetting of all adaptation values-Status of the active routine,Finish routine: routine OK,
IDE11605-MAS05584,Result of resetting of all adaptation values-Result,Preconditions met,
IDE11605-MAS14036,Result of resetting of all adaptation values-Number of iterations,2,
IDE11605-MAS14037,Result of resetting of all adaptation values-RESTRICTION,no restriction,
IDE11605-MAS14038,Result of resetting of all adaptation values-Type of restriction,Precondition,
IDE11606-IDE11629,Result of resetting of all adjustments-Status of the active routine,Finish routine: routine OK,
IDE11606-MAS05584,Result of resetting of all adjustments-Result,Preconditions met,
IDE11606-MAS14036,Result of resetting of all adjustments-Number of iterations,2,
IDE11606-MAS14037,Result of resetting of all adjustments-RESTRICTION,no restriction,
IDE11606-MAS14038,Result of resetting of all adjustments-Type of restriction,Precondition,
IDE11607-IDE11629,Result of resetting all software end-stops-Status of the active routine,Finish routine: routine OK,
IDE11607-MAS05584,Result of resetting all software end-stops-Result,Preconditions met,
IDE11607-MAS14036,Result of resetting all software end-stops-Number of iterations,2,
IDE11607-MAS14037,Result of resetting all software end-stops-RESTRICTION,no restriction,
IDE11607-MAS14038,Result of resetting all software end-stops-Type of restriction,Precondition,
IDE11608-IDE11629,Result of resetting to factory setting-Status of the active routine,Finish routine: routine OK,
IDE11608-MAS05584,Result of resetting to factory setting-Result,Preconditions met,
IDE11608-MAS14036,Result of resetting to factory setting-Number of iterations,2,
IDE11608-MAS14037,Result of resetting to factory setting-RESTRICTION,no restriction,
IDE11608-MAS14038,Result of resetting to factory setting-Type of restriction,Precondition,
IDE11609-IDE11629,Result of steering angle sensor: software end-stops-Status of the active routine,Finish routine: routine OK,
IDE11609-MAS05584,Result of steering angle sensor: software end-stops-Result,Preconditions met,
IDE11609-MAS14036,Result of steering angle sensor: software end-stops-Number of iterations,2,
IDE11609-MAS14037,Result of steering angle sensor: software end-stops-RESTRICTION,no restriction,
IDE11609-MAS14038,Result of steering angle sensor: software end-stops-Type of restriction,Precondition,
IDE11863,Support power reduction,100.0, %
IDE11865-IDE00021,Reason for engagement steering support-Engine RPM,Met,
IDE11865-IDE00075,Reason for engagement steering support-Vehicle speed,Met,
IDE11865-MAS01737,Reason for engagement steering support-Diagnosis,not met,
IDE11865-MAS08112,Reason for engagement steering support-Drive readiness,not met,
MAS02126-IDE05744,Steering angle sensor: status-Steering angle sensor: initialization,initialized,
MAS02126-MAS01632,Steering angle sensor: status-Status,active,
MAS02126-MAS02247,Steering angle sensor: status-CAN message,invalid,
MAS02126-MAS10118,Steering angle sensor: status-Steering angle sensor: status of calibration,calibrated,
MAS08112,Drive readiness,not active,
ENG26640,Current_gradient_limiting,11.9, %
ENG26641,Current_limiting,0.0, %
Elapsed Time: 00:06,,,
;SW:5H0-035-456-A HW:5H0-035-456-A --- Sound System
;Component:AMPeth12C H06 4316, Coding:23000000000000000000000000000000000000000000000000
;EV_AMPEthMQB37w,001005,EV_AMPEthMQB37w_VW38.rod
;Thursday,17,March,2022,11:50:17:62242
;VCID: 2517FFDDA56E34039C4-8070
IDE00019,Voltage terminal 30,13.30, V
IDE00021,Engine RPM,774.00, /min
IDE00767,No. of unscheduled ECU resets,0,
IDE00916-ENG118373,Speaker status-loudspeaker_config_channel_1,Left rear speaker,
IDE00916-ENG118408,Speaker status-loudspeaker_config_channel_10,Right front treble speaker,
IDE00916-ENG118446,Speaker status-loudspeaker_config_channel_11,Not available,
IDE00916-ENG118414,Speaker status-loudspeaker_config_channel_12,Center speaker,
IDE00916-ENG118269,Speaker status-loudspeaker_config_channel_13,Not available,
IDE00916-ENG118335,Speaker status-loudspeaker_config_channel_14,Not available,
IDE00916-ENG118384,Speaker status-loudspeaker_config_channel_15,Not available,
IDE00916-ENG118443,Speaker status-loudspeaker_config_channel_16,Not available,
IDE00916-ENG118435,Speaker status-loudspeaker_config_channel_17,Not available,
IDE00916-ENG118380,Speaker status-loudspeaker_config_channel_18,Not available,
IDE00916-ENG118394,Speaker status-loudspeaker_config_channel_19,Not available,
IDE00916-ENG118383,Speaker status-loudspeaker_config_channel_2,Right rear speaker,
IDE00916-ENG118362,Speaker status-loudspeaker_config_channel_20,Not available,
IDE00916-ENG118344,Speaker status-loudspeaker_config_channel_21,Not available,
IDE00916-ENG118455,Speaker status-loudspeaker_config_channel_22,Not available,
IDE00916-ENG118417,Speaker status-loudspeaker_config_channel_23,Not available,
IDE00916-ENG118448,Speaker status-loudspeaker_config_channel_24,Not available,
IDE00916-ENG118216,Speaker status-loudspeaker_config_channel_3,Double subwoofer speaker 1,
IDE00916-ENG118437,Speaker status-loudspeaker_config_channel_4,Double subwoofer speaker 2,
IDE00916-ENG118290,Speaker status-loudspeaker_config_channel_5,Double bass speaker 1: left front,
IDE00916-ENG118419,Speaker status-loudspeaker_config_channel_6,Double bass speaker 2: left front,
IDE00916-ENG118338,Speaker status-loudspeaker_config_channel_7,Double bass speaker 1: right front,
IDE00916-ENG118268,Speaker status-loudspeaker_config_channel_8,Double bass speaker 2: right front,
IDE00916-ENG118398,Speaker status-loudspeaker_config_channel_9,Left front treble speaker,
IDE00916-ENG118339,Speaker status-loudspeaker_state_channel_1,Measuring value not available,
IDE00916-ENG118357,Speaker status-loudspeaker_state_channel_10,Measuring value not available,
IDE00916-ENG118392,Speaker status-loudspeaker_state_channel_11,Measuring value not available,
IDE00916-ENG118379,Speaker status-loudspeaker_state_channel_12,Measuring value not available,
IDE00916-ENG118364,Speaker status-loudspeaker_state_channel_13,Measuring value not available,
IDE00916-ENG118375,Speaker status-loudspeaker_state_channel_14,Measuring value not available,
IDE00916-ENG118354,Speaker status-loudspeaker_state_channel_15,Measuring value not available,
IDE00916-ENG118245,Speaker status-loudspeaker_state_channel_16,Measuring value not available,
IDE00916-ENG118456,Speaker status-loudspeaker_state_channel_17,Measuring value not available,
IDE00916-ENG118420,Speaker status-loudspeaker_state_channel_18,Measuring value not available,
IDE00916-ENG118337,Speaker status-loudspeaker_state_channel_19,Measuring value not available,
IDE00916-ENG118233,Speaker status-loudspeaker_state_channel_2,Measuring value not available,
IDE00916-ENG118363,Speaker status-loudspeaker_state_channel_20,Measuring value not available,
IDE00916-ENG118345,Speaker status-loudspeaker_state_channel_21,Measuring value not available,
IDE00916-ENG118332,Speaker status-loudspeaker_state_channel_22,Measuring value not available,
IDE00916-ENG118247,Speaker status-loudspeaker_state_channel_23,Measuring value not available,
IDE00916-ENG118336,Speaker status-loudspeaker_state_channel_24,Measuring value not available,
IDE00916-ENG118218,Speaker status-loudspeaker_state_channel_3,Measuring value not available,
IDE00916-ENG118240,Speaker status-loudspeaker_state_channel_4,Measuring value not available,
IDE00916-ENG118231,Speaker status-loudspeaker_state_channel_5,Measuring value not available,
IDE00916-ENG118327,Speaker status-loudspeaker_state_channel_6,Measuring value not available,
IDE00916-ENG118436,Speaker status-loudspeaker_state_channel_7,Measuring value not available,
IDE00916-ENG118263,Speaker status-loudspeaker_state_channel_8,Measuring value not available,
IDE00916-ENG118310,Speaker status-loudspeaker_state_channel_9,Measuring value not available,
IDE01716,Terminal 50 status,OFF,
IDE04640,Over-temperature protection for amplifier,0,
IDE05713-MAS01632,Network diagnosis-Status,Enabled,
IDE06517-MAS01424,Temperature: audio amplifier-max.value,39, °C
IDE06517-MAS01425,Temperature: audio amplifier-min.value,30, °C
IDE06517-MAS02238,Temperature: audio amplifier-Up-to-date,39, °C
IDE08343,Immobilizer Challenge,8E A5 D3 FC,
IDE10300,OBD Driving Cycle detected,not active,
IDE10779,Ethernet signal quality,good: link available,
IDE10780,Ethernet counter connection interruptions,8,
IDE10781,Ethernet counter checksum malfunction,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 6F|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 2D|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 02|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 05|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|3|,
IDE11756,IP network: counter messages with inadmissible VLANs,0,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,0,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|00 13 43 CA 87 AE|,
IDE11869,IP network: NDP cache,|MAC address,IPv6 address
IDE12238,I network: discarded messages counter,0,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE12633,IP Network maximum correction of the synchronized clock,0, ns
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,dont care,
ENG118082-MAS18871,Loudspeaker_Test_acoustic_extended_actual_loudspeaker-Current channel,OFF,
ENG118082-MAS18921,Loudspeaker_Test_acoustic_extended_actual_loudspeaker-Current loudspeaker,Not available,
Elapsed Time: 00:39,,,
;SW:5WA-907-338-B HW:5WA-907-338 --- Multifunc. Module
;Component:FCM2020 Low 014 1447, Coding:000000000900071206112310040003070300000000000000000000000000
;EV_MultiModulContiVW38X,004012,EV_MultiModulContiVW38X.rod
;Thursday,17,March,2022,11:51:15:62242
;VCID: 4DC7677D9D5E2C43744-8018
IDE00019,Voltage terminal 30,13.2, V
IDE00075,Vehicle speed,0.0, km/h
IDE00326,Steering wheel angle,-421.20, °
IDE00767-MAS03945,No. of unscheduled ECU resets-Watchdog Reset,1,
IDE01714,Status reverse gear,OFF,
IDE01717-ENG30211,Processor load-Software_component_AFS_MXB,18, %
IDE01717-ENG30223,Processor load-Total_system_FCM,55, %
IDE01943,Turn signal lamp,Not operated,
IDE01946,ESP intervention,not active,
IDE01992-ENG16230,Installation list: current installations-ECU present Bit 0,installed,
IDE01992-ENG45410,Installation list: current installations-ECU present Bit 1,installed,
IDE01992-ENG45396,Installation list: current installations-ECU present Bit 2,installed,
IDE01995-ENG16990,Control module protocol information-Ethernet,No,
IDE01995-ENG16987,Control module protocol information-ISO-TP,Yes,
IDE01995-ENG16989,Control module protocol information-K Line,No,
IDE01995-ENG16988,Control module protocol information-TP 1.6,No,
IDE01995-ENG16991,Control module protocol information-TP 2.0,No,
IDE02384-ENG16210,Status of event memory-ECU Dtc Bit 0,OK,
IDE02384-ENG45352,Status of event memory-ECU Dtc Bit 1,OK,
IDE02384-ENG45386,Status of event memory-ECU Dtc Bit 2,OK,
IDE02389,Ambient brightness,2448, lx
IDE02515,Low beam,OFF,
IDE02743,High Beam,OFF,
IDE03150-ENG16256,Readiness for bus sleep mode-Sleep Bit 0,System_not_ready_to_sleep,
IDE03150-ENG45492,Readiness for bus sleep mode-Sleep Bit 1,System_ready_to_sleep_or_sleeping,
IDE03150-ENG45491,Readiness for bus sleep mode-Sleep Bit 2,System_ready_to_sleep_or_sleeping,
IDE03214,Engine stop using start-stop function,OFF,
IDE03215,Engine start using start-stop function,OFF,
IDE03616,Motor status,On,
IDE03620,Front jounce travel,13.8, mm
IDE03621,Rear jounce travel,-33.0, mm
IDE03622,Left headlight beam adjusting motor: status,No malfunction,
IDE03623,Right headlight beam adjusting motor: status,No malfunction,
IDE03624,Left dynamic AFS light motor: specified value,32.000000, °
IDE03625,Right dynamic AFS light motor: specified value,32.000000, °
IDE03626,Left dynamic AFS light motor: status,No malfunction,
IDE03627,Right dynamic AFS light motor: status,No malfunction,
IDE03628,Adjusting motor for variable left front lighting: status,No malfunction,
IDE03629,Adjusting motor for variable right front lighting: status,No malfunction,
IDE03630,Left headlight beam adjusting motor: specified value,-178.0, mm
IDE03631,Right headlight beam adjusting motor: specified value,-178.0, mm
IDE03632,Left-/right hand driving switch-over,OFF,
IDE03638-IDE03717,Stationary cornering lamp-Dim static left AFS light,101.6, %
IDE03638-IDE03718,Stationary cornering lamp-Dim static right AFS light,101.6, %
IDE03640,Dynamic AFS light,OFF,
IDE03669,Status of light distribution,not activated,
IDE03727,Variable left front lighting specified position,204.70, %
IDE03728,Variable right front lighting specified position,204.70, %
IDE03788,Status of basic headlamp setting,no request,
IDE04343-ENG124117,Bus identification-bus_number,1,
IDE04343-ENG124117,Bus identification-bus_number,10,
IDE04343-ENG124116,Bus identification-bus_type,CAN,
IDE04343-ENG124116,Bus identification-bus_type,Bus master,
IDE04805-IDE02955,Driving profile selection-System status,Not available,
IDE04805-MAS01447,Driving profile selection-Act.val.,0,
IDE04805-MAS01448,Driving profile selection-Target value,2,
IDE04805-MAS05058,Driving profile selection-Compatibility,No,
IDE08447,Driving axis angle,5,
IDE08516-IDE02743,LED headlights: light distribution requirement-High Beam,not requested,
IDE08516-IDE06864,LED headlights: light distribution requirement-Daytime running lamps,not requested,
IDE08516-MAS02922,LED headlights: light distribution requirement-City light,not requested,
IDE08516-MAS02923,LED headlights: light distribution requirement-Highway light,not requested,
IDE08516-MAS02931,LED headlights: light distribution requirement-Rural highway light,not requested,
IDE08516-MAS02946,LED headlights: light distribution requirement-static AFS light,not requested,
IDE08516-MAS07013,LED headlights: light distribution requirement-All-weather light,not requested,
IDE08516-MAS07014,LED headlights: light distribution requirement-Tourist light,not requested,
IDE08516-MAS07015,LED headlights: light distribution requirement-Running light,not requested,
IDE08516-MAS07234,LED headlights: light distribution requirement-Eco mode 1,not requested,
IDE08516-MAS07235,LED headlights: light distribution requirement-Eco mode 2,not requested,
IDE08706-MAS17323,Actual angle of ref. segments-Horizontal angle reference segment left: in angular minutes,0,
IDE08706-MAS17324,Actual angle of ref. segments-Horizontal angle reference segment left: in degrees,-0.00,
IDE08706-MAS17325,Actual angle of ref. segments-Horizontal angle reference segment left: as a percentage,-0.00,
IDE08706-MAS17326,Actual angle of ref. segments-Horizontal angle reference segment right: in angular minutes,0,
IDE08706-MAS17327,Actual angle of ref. segments-Horizontal angle reference segment right: in degrees,-0.00,
IDE08706-MAS17328,Actual angle of ref. segments-Horizontal angle reference segment right: as a percentage,-0.00,
IDE08706-MAS17329,Actual angle of ref. segments-Vertical angle reference segment left: in angular minutes,0,
IDE08706-MAS17330,Actual angle of ref. segments-Vertical angle reference segment left: in degrees,-0.00,
IDE08706-MAS17331,Actual angle of ref. segments-Vertical angle reference segment left: as a percentage,-0.00,
IDE08706-MAS17332,Actual angle of ref. segments-Vertical angle reference segment right: in angular minutes,0,
IDE08706-MAS17333,Actual angle of ref. segments-Vertical angle reference segment right: in degrees,-0.00,
IDE08706-MAS17334,Actual angle of ref. segments-Vertical angle reference segment right: as a percentage,-0.00,
IDE08713-MAS17335,Matrix light: calculated offset values-Horizontal offset: left headlight in angular minutes,95,
IDE08713-MAS17336,Matrix light: calculated offset values-Horizontal offset: left headlight in degrees,1.58,
IDE08713-MAS17337,Matrix light: calculated offset values-Horizontal: left headlight as a percentage,2.76,
IDE08713-MAS17338,Matrix light: calculated offset values-Horizontal offset: right headlight in angular minutes,141,
IDE08713-MAS17339,Matrix light: calculated offset values-Horizontal offset: right headlight in degrees,2.35,
IDE08713-MAS17340,Matrix light: calculated offset values-Horizontal offset: right headlight as a percentage,4.11,
IDE08713-MAS17341,Matrix light: calculated offset values-Vertical offset: left headlight in angular minutes,0,
IDE08713-MAS17342,Matrix light: calculated offset values-Vertical offset: left headlight in degrees,-0.00,
IDE08713-MAS17343,Matrix light: calculated offset values-Vertical offset: left headlight as a percentage,-0.00,
IDE08713-MAS17344,Matrix light: calculated offset values-Vertical offset: right headlight in angular minutes,0,
IDE08713-MAS17345,Matrix light: calculated offset values-Vertical offset: right headlight in degrees,-0.00,
IDE08713-MAS17346,Matrix light: calculated offset values-Vertical offset: right headlight as a percentage,-0.00,
IDE08714-MAS06929,Axle offsets-Axle offset front,-11.4, mm
IDE08714-MAS06930,Axle offsets-Axle offset rear,-5.8, mm
IDE08715,Func. status matrix high beam,not active,
IDE12806-ENG124545,Diagnostic capability of the bus interface-Diag_path Bit 0,Control module/bus interface diagnostics capable,
IDE12806-ENG124546,Diagnostic capability of the bus interface-Diag_path Bit 1,Control module/bus interface diagnostics capable,
IDE12806-ENG124547,Diagnostic capability of the bus interface-Diag_path Bit 2,Control module/bus interface diagnostics capable,
IDE12807-ENG124572,Participant authenticity-Ecu_authentication Bit 0,Control module/bus interface authentic,
IDE12807-ENG124573,Participant authenticity-Ecu_authentication Bit 1,Control module/bus interface authentic,
IDE12807-ENG124574,Participant authenticity-Ecu_authentication Bit 2,Control module/bus interface authentic,
IDE12844-ENG124114,Installation list of the 10 bit node addresses-Node address,00 A9,
IDE12844-ENG124114,Installation list of the 10 bit node addresses-Node address,00 97,
IDE12844-ENG124114,Installation list of the 10 bit node addresses-Node address,00 96,
IDE14337-MAS01853,Vehicle inclination sensor: rotation angle-Left front,63,
IDE14337-MAS01855,Vehicle inclination sensor: rotation angle-Left rear,70,
IDE14770-MAS01853,Vehicle inclination sensor: adaptation value-Left front,58,
IDE14770-MAS01855,Vehicle inclination sensor: adaptation value-Left rear,78,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
ENG101323,Headlight leveling control state,static,
ENG107365,Left dynamic cornering light value,32.000000, °
ENG26446-ENG30212,Multifunction_Module_Application_Software_Version-Software_Version_AFS/MXB,0140,
ENG26446-ENG30225,Multifunction_Module_Application_Software_Version-Version_Routing_FCM,9070,
ENG124613,Predictive_Route_Data_Intown_Flag,Not available,
ENG124610,Predictive_Route_Data_Number_Of_Lanes,Not available,
ENG124612,Predictive_Route_Data_Placename_Sign,Not available,
ENG124611,Predictive_Route_Data_Speed_Limit,Not available,
ENG124609,Predictive_Route_Data_Street_Class,Not available,
ENG108468,Right dynamic cornering light value,32.000000, °
Elapsed Time: 00:07,,,
;Thursday,17,March,2022,11:51:35:62242
IDE02389,Ambient brightness,2430, lx
;SW:5Q0-959-592-L HW:5Q0-959-592-F --- Door Elect, Pass.
;Component:TSG BFS003 0350, Coding:003B13208E00040000800000
;EV_DCU2PasseSideMAXHKLO,001018,EV_DCU2PasseSideMAXHKLO.rod
;Thursday,17,March,2022,11:51:55:62242
;VCID: 49CF536D6936306358C-801C
IDE00310,Outside temperature,24.00, °C
IDE01993-MAS12276,Control module reference number-Front door control module,Front passenger door control module,
IDE02261-IDE00773,Supply voltage for door control module: rear: frt.pass. side-Terminal 15 status via CAN,active,
IDE02261-IDE01715,Supply voltage for door control module: rear: frt.pass. side-Status terminal S,active,
IDE02261-IDE05835,Supply voltage for door control module: rear: frt.pass. side-Supply voltage for central locking,13.30, V
IDE02266,Passenger side rear power window button,Not operated,
IDE02268-IDE00773,Supply voltage for door control module: front: frt.pass. side-Terminal 15 status via CAN,active,
IDE02268-IDE01715,Supply voltage for door control module: front: frt.pass. side-Status terminal S,active,
IDE02268-IDE05835,Supply voltage for door control module: front: frt.pass. side-Supply voltage for central locking,13.10, V
IDE04216-MAS04247,Mirror heater-Button,not installed,
IDE04539-MAS02228,Mirror memory-X coordinate,57, %
IDE04539-MAS02229,Mirror memory-Y coordinate,46, %
IDE04540,Mirror adjustment (X/Y direction),not installed,
IDE05726,Dimmer terminal 58xd,81, %
IDE05727-IDE04213,Front passenger side door status-Central locking button,Not operated,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,not installed,
IDE06207-MAS01453,Front window regulator status: frt.pass. side-Blocking detection,active,
IDE06207-MAS02039,Front window regulator status: frt.pass. side-Force limitation,not active,
IDE06207-MAS02097,Front window regulator status: frt.pass. side-Window position,0.00, %
IDE06207-MAS02098,Front window regulator status: frt.pass. side-Window regulator standardized,Yes,
IDE06207-MAS03548,Front window regulator status: frt.pass. side-Motor current,0, A
IDE06207-MAS04642,Front window regulator status: frt.pass. side-Before upper stop,active,
IDE06207-MAS05370,Front window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06209-MAS01453,Rear window regulator status: frt.pass. side-Blocking detection,active,
IDE06209-MAS02039,Rear window regulator status: frt.pass. side-Force limitation,not active,
IDE06209-MAS02097,Rear window regulator status: frt.pass. side-Window position,0.00, %
IDE06209-MAS02098,Rear window regulator status: frt.pass. side-Window regulator standardized,Yes,
IDE06209-MAS03548,Rear window regulator status: frt.pass. side-Motor current,Not available,
IDE06209-MAS04642,Rear window regulator status: frt.pass. side-Before upper stop,active,
IDE06209-MAS05370,Rear window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06872,Front passenger power window button,Not operated,
IDE06932-MAS01159,Ident. of rear window regulator programming: frt.pass. side-Version number,BM06,
IDE06934,Front window regulator relay: frt.pass. side,Open,
IDE06936,Rear window regulator relay: frt.pass. side,Open,
IDE06938-MAS02545,Front window regulator reversing position: frt. pass. side-Last,127.50, %
IDE06938-MAS02546,Front window regulator reversing position: frt. pass. side-Second to last,127.50, %
IDE06938-MAS02547,Front window regulator reversing position: frt. pass. side-Third to last,127.50, %
IDE06938-MAS02548,Front window regulator reversing position: frt. pass. side-Fourth to last,127.50, %
IDE06938-MAS05380,Front window regulator reversing position: frt. pass. side-fifth to last,127.50, %
IDE06941,Rear window regulator child lock: frt.pass. side,not active,
IDE07223,Window regulator child lock: frt.pass. side,Not available,
IDE07406-IDE03114,Enable front passenger window regulator relay-Comfort function,No,
IDE07406-MAS02447,Enable front passenger window regulator relay-Release,Yes,
IDE07408-IDE03114,Enable frt.pass.-side rear window regulator-Comfort function,No,
IDE07408-MAS02447,Enable frt.pass.-side rear window regulator-Release,Yes,
IDE07410-MAS01632,Excess.temp. disconnect: front window regulator: frt.pass. side-Status,not active,
IDE07410-MAS02955,Excess.temp. disconnect: front window regulator: frt.pass. side-Engine temperature,15, °C
IDE07412-MAS01632,Excess.temp.disconnect for rear window regulator: frt.pass.side-Status,not active,
IDE07412-MAS02955,Excess.temp.disconnect for rear window regulator: frt.pass.side-Engine temperature,Not available,
IDE07414,Comfort function for front window regulator: frt.pass. side,not active,
IDE07416,Comfort function for rear window regulator: frt.pass. side,not active,
IDE07417-MAS02545,Rear window regulator reversing position: frt.pass. side-Last,0.00, %
IDE07417-MAS02546,Rear window regulator reversing position: frt.pass. side-Second to last,0.00, %
IDE07417-MAS02547,Rear window regulator reversing position: frt.pass. side-Third to last,0.00, %
IDE07417-MAS02548,Rear window regulator reversing position: frt.pass. side-Fourth to last,127.50, %
IDE07417-MAS05380,Rear window regulator reversing position: frt.pass. side-fifth to last,127.50, %
IDE10930-IDE02266,Window regulator control unit: front passenger side-Passenger side rear power window button,not installed,
IDE10930-IDE04220,Window regulator control unit: front passenger side-Driver power window button,not installed,
IDE10930-IDE06621,Window regulator control unit: front passenger side-Driver side rear power window button,not installed,
IDE10930-IDE06872,Window regulator control unit: front passenger side-Front passenger power window button,not installed,
IDE15340,Light output 1 pin D8 target brightness on front passenger side,0, %
IDE15341,Light output 2 pin D3 target brightness on front passenger side,0, %
IDE15342,Light output 3 pin C1/B3 target brightness on front passenger side,0, %
IDE15343,Light output 4 pin D16 target brightness on front passenger side,Not available,
IDE16389-MAS25781,Front ambient Lighting configuration - light output 1-Malfunction location:,Front passenger side exterior door handle lamp,
IDE16390-MAS25781,Front ambient Lighting configuration - light output 2-Malfunction location:,Front passenger side exterior door handle lamp,
IDE16391-MAS25781,Front ambient Lighting configuration - light output 3-Malfunction location:,Mirror welcome light on front passenger side,
ENG117316-ENG32834,Window_Regulator_Passenger_Side_Rear_VW_Workshop_System_Name-System_short_sign,J927 ,
;SW:5H0-035-877 HW:5H0-035-877 --- Information Electr.
;Component:MU-O-NS-US H56 1880, Coding:23800000000100000000000000000000000000000000000000
;EV_MUOIMQB37w,001002,EV_MUOIMQB37w_VW38.rod
;Thursday,17,March,2022,11:52:15:62242
;VCID: 6B83C9E5030AC2730A0-803E
IDE00019,Voltage terminal 30,13.40, V
IDE00021,Engine RPM,777.00, /min
IDE00655-MAS01424,Temperature of processor circuit board-max.value,59, °C
IDE00655-MAS01425,Temperature of processor circuit board-min.value,-15, °C
IDE00655-MAS02238,Temperature of processor circuit board-Up-to-date,54, °C
IDE00916-ENG118373,Speaker status-loudspeaker_config_channel_1,Not available,
IDE00916-ENG118408,Speaker status-loudspeaker_config_channel_10,Not available,
IDE00916-ENG118414,Speaker status-loudspeaker_config_channel_12,Not available,
IDE00916-ENG118383,Speaker status-loudspeaker_config_channel_2,Not available,
IDE00916-ENG118216,Speaker status-loudspeaker_config_channel_3,Not available,
IDE00916-ENG118437,Speaker status-loudspeaker_config_channel_4,Not available,
IDE00916-ENG118290,Speaker status-loudspeaker_config_channel_5,Not available,
IDE00916-ENG118419,Speaker status-loudspeaker_config_channel_6,Not available,
IDE00916-ENG118338,Speaker status-loudspeaker_config_channel_7,Not available,
IDE00916-ENG118268,Speaker status-loudspeaker_config_channel_8,Not available,
IDE00916-ENG118398,Speaker status-loudspeaker_config_channel_9,Not available,
IDE01285-ENG101364,Counter of component protection malfunctions-Theft Protection Error Counter,0,
IDE01351,Terminal 75 status,On,
IDE01627-MAS01167,Search for Bluetooth devices-Actuation time,0 s,
IDE01627-ENG39349,Search for Bluetooth devices-IoReached Status,Output diagnostic test not active,
IDE01628-MAS01167,Establish connection to last Bluetooth device-Actuation time,0 s,
IDE01628-ENG39349,Establish connection to last Bluetooth device-IoReached Status,Output diagnostic test not active,
IDE01700-MAS01763,Status of tuner for digital radio (DAB)-Signal Strength,0,
IDE01700-MAS02572,Status of tuner for digital radio (DAB)-Mute,not active,
IDE01700-MAS02949,Status of tuner for digital radio (DAB)-Frequency,0,
IDE01700-MAS03786,Status of tuner for digital radio (DAB)-Audio Codec,MPEG Audio Layer 2,
IDE01700-MAS06242,Status of tuner for digital radio (DAB)-Signal quality,0,
IDE01700-MAS19004,Status of tuner for digital radio (DAB)-DAB fault bit rate FIC,0.00,
IDE01700-MAS19005,Status of tuner for digital radio (DAB)-DAB fault bit rate NET,0.00,
IDE01700-MAS19006,Status of tuner for digital radio (DAB)-DAB fault bit rate MSC,0.00,
IDE01700-MAS19007,Status of tuner for digital radio (DAB)-TP traffic data,Not available,
IDE01700-MAS19010,Status of tuner for digital radio (DAB)-TPEG,Not available,
IDE01700-MAS19011,Status of tuner for digital radio (DAB)-Ensemble ID,0,
IDE01700-MAS19012,Status of tuner for digital radio (DAB)-Ensemble Label,,
IDE01700-MAS19013,Status of tuner for digital radio (DAB)-Ensemble label mask,0,
IDE01700-MAS19014,Status of tuner for digital radio (DAB)-Ensemble country code,0,
IDE01700-MAS19018,Status of tuner for digital radio (DAB)-Bit rate,0,
IDE01700-MAS19019,Status of tuner for digital radio (DAB)-Sample Rate,0,
IDE01700-MAS19020,Status of tuner for digital radio (DAB)-Audio mode,00,
IDE01700-MAS19022,Status of tuner for digital radio (DAB)-DAB transfer mode,0,
IDE01700-MAS19023,Status of tuner for digital radio (DAB)-SYNC / OFDM Lock,not active,
IDE01700-MAS19024,Status of tuner for digital radio (DAB)-Audio quality,0,
IDE01700-MAS19041,Status of tuner for digital radio (DAB)-Protection level,1_A_equal_protection_level,
IDE01700-ENG117346,Status of tuner for digital radio (DAB)-Charset,00,
IDE01700-ENG118358,Status of tuner for digital radio (DAB)-Count_Audio_Services,0,
IDE01700-ENG118224,Status of tuner for digital radio (DAB)-Count_Services,0,
IDE01700-ENG117340,Status of tuner for digital radio (DAB)-Data_Service_Identifier,00 00 00 00,
IDE01700-ENG117341,Status of tuner for digital radio (DAB)-Data_Service_Label,,
IDE01700-ENG117345,Status of tuner for digital radio (DAB)-Data_Service_Label_Mask,00 00,
IDE01700-ENG117335,Status of tuner for digital radio (DAB)-Program_Service_Identifier,Service deactivated,
IDE01700-ENG117336,Status of tuner for digital radio (DAB)-Service_Component_Identifier,0,
IDE01700-ENG117338,Status of tuner for digital radio (DAB)-Service_Label,,
IDE01700-ENG117343,Status of tuner for digital radio (DAB)-Service_Label_Mask,00 00,
IDE01700-ENG117337,Status of tuner for digital radio (DAB)-Sub_Channel_Identifier,0,
IDE01700-ENG117339,Status of tuner for digital radio (DAB)-Sub_Service_Label,,
IDE01700-ENG117344,Status of tuner for digital radio (DAB)-Sub_Service_Label_Mask,00 00,
IDE01712-MAS01779,GPS Position-Length,Redacted by Ross-Tech for User Privacy,
IDE01712-MAS01780,GPS Position-Width,Redacted by Ross-Tech for User Privacy,
IDE01713-MAS01632,Status GPS reception-Status,GPS data is being received: position completely determined,
IDE01713-MAS01785,Status GPS reception-Number of visible satellites,16,
IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,16,
IDE01767-MAS00940,Status of telephone-Antenna diagnostic,OK,
IDE01768-MAS01808,Status of antenna 1 for radio-Antenna current,68, mA
IDE01768-MAS03938,Status of antenna 1 for radio-Connection between radio and antenna amplifier,electrically OK,
IDE01768-MAS03939,Status of antenna 1 for radio-Connection between antenna amplifier and antenna,electrically OK,
IDE01769-MAS01808,Status of antenna 2 for radio-Antenna current,48, mA
IDE01769-MAS03938,Status of antenna 2 for radio-Connection between radio and antenna amplifier,electrically OK,
IDE01769-MAS03939,Status of antenna 2 for radio-Connection between antenna amplifier and antenna,electrically OK,
IDE01770-MAS01632,Status of GPS antenna-Status,Not available,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,Not available,
IDE01771-MAS01808,Status of digital radio antenna 1-Antenna current,0, mA
IDE01771-MAS03938,Status of digital radio antenna 1-Connection between radio and antenna amplifier,electrically OK,
IDE01771-MAS03939,Status of digital radio antenna 1-Connection between antenna amplifier and antenna,electrically OK,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,EB E1 15 A5,
IDE02178-MAS01167,Status remote control-Actuation time,0 s,
IDE02178-ENG39349,Status remote control-IoReached Status,Output diagnostic test not active,
IDE02179-MAS01167,Remote control for selecting the audio source-Actuation time,0 s,
IDE02179-ENG39349,Remote control for selecting the audio source-IoReached Status,Output diagnostic test not active,
IDE02180-MAS01167,Remote control for FM frequency selection-Actuation time,0 s,
IDE02180-ENG39349,Remote control for FM frequency selection-IoReached Status,Output diagnostic test not active,
IDE02181-MAS01167,Remote control for AM frequency selection-Actuation time,0 s,
IDE02181-ENG39349,Remote control for AM frequency selection-IoReached Status,Output diagnostic test not active,
IDE02326-MAS17347,GPS signal strength-Satellite 1: identification,0,
IDE02326-MAS17348,GPS signal strength-Satellite 1: signal strength,63, dBµV
IDE02326-MAS17349,GPS signal strength-Satellite 2: signal strength,63, dBµV
IDE02326-MAS17350,GPS signal strength-Satellite 3: signal strength,63, dBµV
IDE02326-MAS17351,GPS signal strength-Satellite 4: signal strength,63, dBµV
IDE02326-MAS17352,GPS signal strength-Satellite 2: identification,0,
IDE02326-MAS17353,GPS signal strength-Satellite 3: identification,0,
IDE02326-MAS17354,GPS signal strength-Satellite 4: identification,0,
IDE02449-MAS01167,Remote control for satellite radio station selection-Actuation time,0 s,
IDE02449-ENG39349,Remote control for satellite radio station selection-IoReached Status,Output diagnostic test not active,
IDE02452-IDE02451,Satellite radio tuner status-Satellite radio antenna status,electrically OK,
IDE02452-IDE02453,Satellite radio tuner status-Channel selection for satellite radio,38,
IDE02452-MAS01765,Satellite radio tuner status-Audio Signal,available.,
IDE02452-MAS01808,Satellite radio tuner status-Antenna current,113, mA
IDE02452-MAS02573,Satellite radio tuner status-Reception quality,Good signal,
IDE02452-MAS13343,Satellite radio tuner status-Satellite radio tuner: pre-activation status,factory_activation_successful,
IDE02452-MAS13344,Satellite radio tuner status-Satellite radio tuner: pre-activation value,05,
IDE02454-MAS01167,Remote control for digital radio service selection (DSB)-Actuation time,0 s,
IDE02454-ENG39349,Remote control for digital radio service selection (DSB)-IoReached Status,Output diagnostic test not active,
IDE02470-MAS01167,Remote control frequency selection digital radio (band III)-Actuation time,0 s,
IDE02470-ENG39349,Remote control frequency selection digital radio (band III)-IoReached Status,Output diagnostic test not active,
IDE02475-MAS01167,Acoustic check of loudspeakers-Actuation time,0 s,
IDE02475-ENG39349,Acoustic check of loudspeakers-IoReached Status,Output diagnostic test not active,
IDE02476-MAS01167,Electrical test of speakers-Actuation time,0 s,
IDE02476-ENG39349,Electrical test of speakers-IoReached Status,Output diagnostic test not active,
IDE02501-MAS01167,Remote control for voice operation-Actuation time,0 s,
IDE02501-ENG39349,Remote control for voice operation-IoReached Status,Output diagnostic test not active,
IDE02505-MAS01763,Status of tuner 2 for digital radio (DAB)-Signal Strength,0,
IDE02505-MAS02949,Status of tuner 2 for digital radio (DAB)-Frequency,0,
IDE02505-MAS06242,Status of tuner 2 for digital radio (DAB)-Signal quality,0,
IDE02505-MAS19004,Status of tuner 2 for digital radio (DAB)-DAB fault bit rate FIC,0.00,
IDE02505-MAS19005,Status of tuner 2 for digital radio (DAB)-DAB fault bit rate NET,0.00,
IDE02505-MAS19006,Status of tuner 2 for digital radio (DAB)-DAB fault bit rate MSC,0.00,
IDE02505-MAS19011,Status of tuner 2 for digital radio (DAB)-Ensemble ID,00 00 00 00,
IDE02505-MAS19012,Status of tuner 2 for digital radio (DAB)-Ensemble Label,,
IDE02505-MAS19023,Status of tuner 2 for digital radio (DAB)-SYNC / OFDM Lock,not active,
IDE02508-MAS00951,Bluetooth: Visibility-Bluetooth,On,
IDE02508-MAS03001,Bluetooth: Visibility-Mode,Bluetooth available,
IDE02766,Malfunction status,00 00,
IDE02766-ENG118228,Malfunction status-amount_communication_errors,0,
IDE03477-MAS00106,GPS time-Year,2022,
IDE03477-MAS00107,GPS time-Month,3,
IDE03477-MAS00108,GPS time-Day,17,
IDE03477-MAS00109,GPS time-Hours,15,
IDE03477-MAS00110,GPS time-Minutes,52,
IDE03477-MAS00111,GPS time-Seconds,0,
IDE03477-MAS01632,GPS time-Status,valid,
IDE03610-MAS02573,Voice operation: last detected command-Reception quality,0, %
IDE03610-MAS03874,Voice operation: last detected command-last detected command,0,
IDE03610-MAS03875,Voice operation: last detected command-Reliability,0, %
IDE04312-MAS00109,System run time-Hours,0, H
IDE04312-MAS00110,System run time-Minutes,21, min
IDE04317-MAS00108,Total system run time-Day,2, d
IDE04317-MAS00109,Total system run time-Hours,13, H
IDE04317-MAS00110,Total system run time-Minutes,15, min
IDE04329-ENG118721,Status of all SWaP functions-SWaP_function_state array,|ID number,Release code for a SWaP function
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04546-IDE00301,Calibration of navigation-Mileage,609.36, mm
IDE04546-MAS03647,Calibration of navigation-Calibration condition,complete,
IDE04548-MAS00106,Electronic toll collection-Year,2000,
IDE04548-MAS00107,Electronic toll collection-Month,0,
IDE04548-MAS00108,Electronic toll collection-Day,OFF,
IDE04548-MAS00109,Electronic toll collection-Hours,0,
IDE04548-MAS00110,Electronic toll collection-Minutes,0,
IDE04548-MAS00111,Electronic toll collection-Seconds,0,
IDE04548-MAS01156,Electronic toll collection-Communication status,not OK,
IDE04548-MAS01161,Electronic toll collection-Communication malfunction,0,
IDE04548-MAS01758,Electronic toll collection-Date / time,invalid,
IDE04548-MAS04385,Electronic toll collection-Authorization,not OK,
IDE04548-MAS04386,Electronic toll collection-Write card,not OK,
IDE04548-MAS04387,Electronic toll collection-Read card,not OK,
IDE04548-MAS04388,Electronic toll collection-Card type,no card available,
IDE04548-MAS04389,Electronic toll collection-Number of repeat attempts,0,
IDE04548-MAS04394,Electronic toll collection-Connection status,not connected,
IDE04548-MAS04460,Electronic toll collection-Validity,not OK,
IDE04649-MAS01968,Activation for housing fan-Fan,Stage 1,
IDE04649-MAS06857,Activation for housing fan-Speed,1980, /min
IDE04767-MAS01240,Update software via medium-Programming status,not active,
IDE04767-MAS02111,Update software via medium-Data consistency,invalid,
IDE04767-MAS02112,Update software via medium-Programmability,Waiting for data transmission,
IDE04768,Bluetooth: device address,E8 4F 25 8E 50 94,
IDE05040-MAS01632,Video input status-Status,Not available,
IDE05040-MAS04390,Video input status-Active source,Not available,
IDE05107-MAS01167,Test image display unit 1 for multimedia system-Actuation time,0 s,
IDE05107-ENG39349,Test image display unit 1 for multimedia system-IoReached Status,Output diagnostic test not active,
IDE05535-MAS01632,Traffic data antenna-Status,not OK,
IDE05570-MAS01632,DSRC antenna-Status,Unknown (0),
IDE05595-MAS00106,Last time GPS without satellite reception-Year,2000,
IDE05595-MAS00107,Last time GPS without satellite reception-Month,0,
IDE05595-MAS00108,Last time GPS without satellite reception-Day,OFF,
IDE05595-MAS00109,Last time GPS without satellite reception-Hours,0,
IDE05595-MAS00110,Last time GPS without satellite reception-Minutes,0,
IDE05595-MAS00111,Last time GPS without satellite reception-Seconds,0,
IDE05596-MAS00106,Last time GPS position outside map-Year,2022,
IDE05596-MAS00107,Last time GPS position outside map-Month,3,
IDE05596-MAS00108,Last time GPS position outside map-Day,17,
IDE05596-MAS00109,Last time GPS position outside map-Hours,15,
IDE05596-MAS00110,Last time GPS position outside map-Minutes,51,
IDE05596-MAS00111,Last time GPS position outside map-Seconds,58,
IDE05602-IDE03615,Bluetooth: connected device 1-Variant,,
IDE05602-IDE04768,Bluetooth: connected device 1-Bluetooth: device address,00 30 74 67 30 66,
IDE05602-MAS01483,Bluetooth: connected device 1-Software version,,
IDE05602-MAS02159,Bluetooth: connected device 1-Remote SIM Access Profile (rSAP),0,
IDE05602-MAS02160,Bluetooth: connected device 1-Hands free profile (HFP),0,
IDE05602-MAS03159,Bluetooth: connected device 1-Manufacturer,a,
IDE05602-MAS04326,Bluetooth: connected device 1-Device name,&Benjamin's S22 Ultr,
IDE05602-MAS17538,Bluetooth: connected device 1-Received Signal Strength Indicator (RSSI),0,
IDE05602-MAS17539,Bluetooth: connected device 1-Determining the existing profile (SDP),0,
IDE05602-MAS17540,Bluetooth: connected device 1-Serial data transfer (SPP),0,
IDE05602-MAS17541,Bluetooth: connected device 1-Streaming audio data (A2DP),0,
IDE05602-MAS17542,Bluetooth: connected device 1-Remote control for audio/video (AVRCP),0,
IDE05602-MAS17543,Bluetooth: connected device 1-Network connections (PAN),0,
IDE05602-MAS17544,Bluetooth: connected device 1-Message exchange between devices (MAP),0,
IDE05602-MAS17545,Bluetooth: connected device 1-Generic data transfer between two devices (OBEX),0,
IDE05602-MAS17546,Bluetooth: connected device 1-Sending individual files (OPP),0,
IDE05602-MAS17547,Bluetooth: connected device 1-File transfer (FTP),0,
IDE05602-MAS17548,Bluetooth: connected device 1-Read-only access to telephone directory (PBAP),0,
IDE05602-MAS17549,Bluetooth: connected device 1-Telephone directory download (AT),0,
IDE05602-MAS17550,Bluetooth: connected device 1-Sharing calendars or notes between two devices (CTN),0,
IDE05602-MAS17551,Bluetooth: connected device 1-iAP protocol (iAP),0,
IDE05603-IDE03615,Bluetooth: connected device 2-Variant,,
IDE05603-IDE04768,Bluetooth: connected device 2-Bluetooth: device address,00 00 00 00 00 00,
IDE05603-MAS01483,Bluetooth: connected device 2-Software version,,
IDE05603-MAS02159,Bluetooth: connected device 2-Remote SIM Access Profile (rSAP),0,
IDE05603-MAS02160,Bluetooth: connected device 2-Hands free profile (HFP),0,
IDE05603-MAS03159,Bluetooth: connected device 2-Manufacturer,,
IDE05603-MAS04326,Bluetooth: connected device 2-Device name,,
IDE05603-MAS17538,Bluetooth: connected device 2-Received Signal Strength Indicator (RSSI),0,
IDE05603-MAS17539,Bluetooth: connected device 2-Determining the existing profile (SDP),0,
IDE05603-MAS17540,Bluetooth: connected device 2-Serial data transfer (SPP),0,
IDE05603-MAS17541,Bluetooth: connected device 2-Streaming audio data (A2DP),0,
IDE05603-MAS17542,Bluetooth: connected device 2-Remote control for audio/video (AVRCP),0,
IDE05603-MAS17543,Bluetooth: connected device 2-Network connections (PAN),0,
IDE05603-MAS17544,Bluetooth: connected device 2-Message exchange between devices (MAP),0,
IDE05603-MAS17545,Bluetooth: connected device 2-Generic data transfer between two devices (OBEX),0,
IDE05603-MAS17546,Bluetooth: connected device 2-Sending individual files (OPP),0,
IDE05603-MAS17547,Bluetooth: connected device 2-File transfer (FTP),0,
IDE05603-MAS17548,Bluetooth: connected device 2-Read-only access to telephone directory (PBAP),0,
IDE05603-MAS17549,Bluetooth: connected device 2-Telephone directory download (AT),0,
IDE05603-MAS17550,Bluetooth: connected device 2-Sharing calendars or notes between two devices (CTN),0,
IDE05603-MAS17551,Bluetooth: connected device 2-iAP protocol (iAP),0,
IDE05604-IDE03615,Bluetooth: connected device 3-Variant,,
IDE05604-IDE04768,Bluetooth: connected device 3-Bluetooth: device address,00 00 00 00 00 00,
IDE05604-MAS01483,Bluetooth: connected device 3-Software version,,
IDE05604-MAS02159,Bluetooth: connected device 3-Remote SIM Access Profile (rSAP),0,
IDE05604-MAS02160,Bluetooth: connected device 3-Hands free profile (HFP),0,
IDE05604-MAS03159,Bluetooth: connected device 3-Manufacturer,,
IDE05604-MAS04326,Bluetooth: connected device 3-Device name,,
IDE05604-MAS17538,Bluetooth: connected device 3-Received Signal Strength Indicator (RSSI),0,
IDE05604-MAS17539,Bluetooth: connected device 3-Determining the existing profile (SDP),0,
IDE05604-MAS17540,Bluetooth: connected device 3-Serial data transfer (SPP),0,
IDE05604-MAS17541,Bluetooth: connected device 3-Streaming audio data (A2DP),0,
IDE05604-MAS17542,Bluetooth: connected device 3-Remote control for audio/video (AVRCP),0,
IDE05604-MAS17543,Bluetooth: connected device 3-Network connections (PAN),0,
IDE05604-MAS17544,Bluetooth: connected device 3-Message exchange between devices (MAP),0,
IDE05604-MAS17545,Bluetooth: connected device 3-Generic data transfer between two devices (OBEX),0,
IDE05604-MAS17546,Bluetooth: connected device 3-Sending individual files (OPP),0,
IDE05604-MAS17547,Bluetooth: connected device 3-File transfer (FTP),0,
IDE05604-MAS17548,Bluetooth: connected device 3-Read-only access to telephone directory (PBAP),0,
IDE05604-MAS17549,Bluetooth: connected device 3-Telephone directory download (AT),0,
IDE05604-MAS17550,Bluetooth: connected device 3-Sharing calendars or notes between two devices (CTN),0,
IDE05604-MAS17551,Bluetooth: connected device 3-iAP protocol (iAP),0,
IDE05605-IDE03615,Bluetooth: connected device 4-Variant,,
IDE05605-IDE04768,Bluetooth: connected device 4-Bluetooth: device address,00 00 00 00 00 00,
IDE05605-MAS01483,Bluetooth: connected device 4-Software version,,
IDE05605-MAS02159,Bluetooth: connected device 4-Remote SIM Access Profile (rSAP),0,
IDE05605-MAS02160,Bluetooth: connected device 4-Hands free profile (HFP),0,
IDE05605-MAS03159,Bluetooth: connected device 4-Manufacturer,,
IDE05605-MAS04326,Bluetooth: connected device 4-Device name,,
IDE05605-MAS17538,Bluetooth: connected device 4-Received Signal Strength Indicator (RSSI),0,
IDE05605-MAS17539,Bluetooth: connected device 4-Determining the existing profile (SDP),0,
IDE05605-MAS17540,Bluetooth: connected device 4-Serial data transfer (SPP),0,
IDE05605-MAS17541,Bluetooth: connected device 4-Streaming audio data (A2DP),0,
IDE05605-MAS17542,Bluetooth: connected device 4-Remote control for audio/video (AVRCP),0,
IDE05605-MAS17543,Bluetooth: connected device 4-Network connections (PAN),0,
IDE05605-MAS17544,Bluetooth: connected device 4-Message exchange between devices (MAP),0,
IDE05605-MAS17545,Bluetooth: connected device 4-Generic data transfer between two devices (OBEX),0,
IDE05605-MAS17546,Bluetooth: connected device 4-Sending individual files (OPP),0,
IDE05605-MAS17547,Bluetooth: connected device 4-File transfer (FTP),0,
IDE05605-MAS17548,Bluetooth: connected device 4-Read-only access to telephone directory (PBAP),0,
IDE05605-MAS17549,Bluetooth: connected device 4-Telephone directory download (AT),0,
IDE05605-MAS17550,Bluetooth: connected device 4-Sharing calendars or notes between two devices (CTN),0,
IDE05605-MAS17551,Bluetooth: connected device 4-iAP protocol (iAP),0,
IDE05606-IDE03615,Bluetooth: connected device 5-Variant,,
IDE05606-IDE04768,Bluetooth: connected device 5-Bluetooth: device address,00 00 00 00 00 00,
IDE05606-MAS01483,Bluetooth: connected device 5-Software version,,
IDE05606-MAS02159,Bluetooth: connected device 5-Remote SIM Access Profile (rSAP),0,
IDE05606-MAS02160,Bluetooth: connected device 5-Hands free profile (HFP),0,
IDE05606-MAS03159,Bluetooth: connected device 5-Manufacturer,,
IDE05606-MAS04326,Bluetooth: connected device 5-Device name,,
IDE05606-MAS17538,Bluetooth: connected device 5-Received Signal Strength Indicator (RSSI),0,
IDE05606-MAS17539,Bluetooth: connected device 5-Determining the existing profile (SDP),0,
IDE05606-MAS17540,Bluetooth: connected device 5-Serial data transfer (SPP),0,
IDE05606-MAS17541,Bluetooth: connected device 5-Streaming audio data (A2DP),0,
IDE05606-MAS17542,Bluetooth: connected device 5-Remote control for audio/video (AVRCP),0,
IDE05606-MAS17543,Bluetooth: connected device 5-Network connections (PAN),0,
IDE05606-MAS17544,Bluetooth: connected device 5-Message exchange between devices (MAP),0,
IDE05606-MAS17545,Bluetooth: connected device 5-Generic data transfer between two devices (OBEX),0,
IDE05606-MAS17546,Bluetooth: connected device 5-Sending individual files (OPP),0,
IDE05606-MAS17547,Bluetooth: connected device 5-File transfer (FTP),0,
IDE05606-MAS17548,Bluetooth: connected device 5-Read-only access to telephone directory (PBAP),0,
IDE05606-MAS17549,Bluetooth: connected device 5-Telephone directory download (AT),0,
IDE05606-MAS17550,Bluetooth: connected device 5-Sharing calendars or notes between two devices (CTN),0,
IDE05606-MAS17551,Bluetooth: connected device 5-iAP protocol (iAP),0,
IDE05700-MAS01456,USB connection-Speed,Low speed,
IDE05700-MAS01632,USB connection-Status,not OK.,
IDE05700-MAS03159,USB connection-Manufacturer,0,
IDE05700-MAS04393,USB connection-USB device class,0,
IDE05700-MAS04394,USB connection-Connection status,not connected,
IDE05700-MAS04436,USB connection-USB device sub-class,0,
IDE05700-MAS06173,USB connection-Protocol,0,
IDE05700-MAS06174,USB connection-Product ID,0,
IDE05725,Dimmer terminal 58xs,0, %
IDE05726,Dimmer terminal 58xd,93.62, %
IDE05814,Individualization characteristic,FF FF FF FF FF,
IDE06028-MAS02317,Control head button operation-Button code 1,0,
IDE06028-MAS02318,Control head button operation-Button code 2,0,
IDE06028-MAS04151,Control head button operation-Joystick,0,
IDE06028-MAS04413,Control head button operation-Push-and rotary knob for selection,-127,
IDE06028-MAS04414,Control head button operation-Volume control,-127,
IDE06516-MAS01424,Temperature: optical drive-max.value,Not available,
IDE06516-MAS01425,Temperature: optical drive-min.value,Not available,
IDE06516-MAS02238,Temperature: optical drive-Up-to-date,Not available,
IDE06517-MAS01424,Temperature: audio amplifier-max.value,69, °C
IDE06517-MAS01425,Temperature: audio amplifier-min.value,-7, °C
IDE06517-MAS02238,Temperature: audio amplifier-Up-to-date,57, °C
IDE06519-MAS01424,Temperature of MOST transceiver-max.value,Not available,
IDE06519-MAS01425,Temperature of MOST transceiver-min.value,Not available,
IDE06519-MAS02238,Temperature of MOST transceiver-Up-to-date,Not available,
IDE06521-MAS01424,Temperature of MMX PC boards-max.value,61, °C
IDE06521-MAS01425,Temperature of MMX PC boards-min.value,-16, °C
IDE06521-MAS02238,Temperature of MMX PC boards-Up-to-date,58, °C
IDE06522-MAS01424,Temperature of phone unit-max.value,62, °C
IDE06522-MAS01425,Temperature of phone unit-min.value,-17, °C
IDE06522-MAS02238,Temperature of phone unit-Up-to-date,58, °C
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,03,
IDE07145-MAS06785,Component protection properties-GFA key,Not Used,
IDE07174,Connection for extern. audio sources (USB): overcurrent detect.,OK,
IDE07364,GPS reception status,GPS data available,
IDE07543,Vehicle speed,0.00, km/h
IDE07589-IDE07590,Update programming: status-Currently processed module,0,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,0,
IDE07589-MAS01632,Update programming: status-Status,not active,
IDE07589-MAS10948,Update programming: status-control,Diagnosis,
IDE08531-MAS07133,Connection status online license services-No. of license serv.,0,
IDE08531-ENG98502,Connection status online license services-Data,|ID services,Activation status
IDE09544-MAS01167,Locking information electronic 1 operation-Actuation time,0 s,
IDE09544-ENG39349,Locking information electronic 1 operation-IoReached Status,Output diagnostic test not active,
IDE09563-MAS09154,Proximity detection for touchscreen 1-Proximity sensor 1,No object in sector,
IDE10478-MAS01632,Interface for external media: status-Status,OK,
IDE10481-MAS01167,Interface for external media: diagnosis-Actuation time,0 s,
IDE10481-ENG39349,Interface for external media: diagnosis-IoReached Status,Output diagnostic test not active,
IDE10600-MAS01632,Status of the navigation database-Status,valid,
IDE10600-ENG98502,Status of the navigation database-Data,|Country Code,Region Code
IDE10843-ENG98502,Function module: identification-Data,|Device name,Module Name
IDE10857-MAS02476,Touchless loading of mobile phone: status-installed,available.,
IDE10857-MAS11500,Touchless loading of mobile phone: status-Foreign object,No,
IDE10857-MAS11501,Touchless loading of mobile phone: status-Charging,No,
IDE11034-MAS01482,Satellite radio: module information-Hardware version,1.0.1,
IDE11034-MAS11961,Satellite radio: module information-Serial number,YMX7UD84,
IDE11034-MAS11962,Satellite radio: module information-Pre-activation key,8E D0 BF 00 59 4D 58 37 55 44 38 34 00 02 98 05 8A 38 64 68 F5 31 71 89 CD BF 18 05 84 D2 E8 8B 1B D3 C6 E5 1B DB 03 41 00 66 03 41 00 07 00 66 00 07,
IDE11034-MAS11963,Satellite radio: module information-Firmware version,11.46.1,
IDE11034-MAS11964,Satellite radio: module information-Satellite Module Services Version,,
IDE11034-MAS11965,Satellite radio: module information-SiriusXM Interconnect Version,4.1.0,
IDE11034-MAS11966,Satellite radio: module information-Database Version,474,
IDE11034-ENG118382,Satellite radio: module information-apogee_traffic,,
IDE11034-ENG118254,Satellite radio: module information-canadian_fuel,,
IDE11034-ENG118272,Satellite radio: module information-channel_arts,,
IDE11034-ENG118219,Satellite radio: module information-ev_stations,,
IDE11034-ENG118418,Satellite radio: module information-fuel_stations,,
IDE11034-ENG118421,Satellite radio: module information-internal_sxm,1.6.6.10.1,
IDE11034-ENG118296,Satellite radio: module information-movies,,
IDE11034-ENG118196,Satellite radio: module information-Parking,,
IDE11034-ENG118386,Satellite radio: module information-phonetics,,
IDE11034-ENG118424,Satellite radio: module information-safety_alerts,,
IDE11034-ENG45748,Satellite radio: module information-States,,
IDE11034-ENG118391,Satellite radio: module information-stocks,,
IDE11034-ENG118359,Satellite radio: module information-sxm_pics,,
IDE11034-ENG118427,Satellite radio: module information-tabular_weather,,
IDE11034-ENG118395,Satellite radio: module information-weather_alerts,,
IDE11127-IDE04332,Error-causing FS ID with status-Release code for a SWaP function,Not available,
IDE11127-IDE05814,Error-causing FS ID with status-Individualization characteristic,invalid,
IDE11127-IDE06260,Error-causing FS ID with status-ID number,0,
IDE11127-MAS01340,Error-causing FS ID with status-Functions,Not available,
IDE11127-MAS01903,Error-causing FS ID with status-Configuration,not OK,
IDE11127-MAS02934,Error-causing FS ID with status-Preconditions met,Condition not met,
IDE11127-MAS05616,Error-causing FS ID with status-Cancellation,Yes,
IDE11127-MAS05617,Error-causing FS ID with status-Authentication,Condition not met,
IDE11504,Satellite radio tuner: pre-activated subscription,Yes,
IDE11728,Ethernet signal quality: branch 1,good: link available,
IDE11729,Ethernet signal quality: branch 2,no link,
IDE11730,Ethernet signal quality: branch 3,good: link available,
IDE11731,Ethernet signal quality: branch 4,no link,
IDE11736,Ethernet counter connection interruptions: branch 1,0,
IDE11737,Ethernet counter connection interruptions: branch 2,0,
IDE11738,Ethernet counter connection interruptions: branch 3,0,
IDE11739,Ethernet counter connection interruptions: branch 4,0,
IDE11744,Ethernet counter checksum error: branch 1,0,
IDE11745,Ethernet counter checksum error: branch 2,0,
IDE11746,Ethernet counter checksum error: branch 3,0,
IDE11747,Ethernet counter checksum error: branch 4,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FE 80 00 00 00 00 00 00 32 B4 B8 FF FE B5 82 D0|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73|FE 80 00 00 00 00 00 00 32 B4 B8 FF FE B5 82 D0|FD 53 7C B8 03 83 00 07 00 00 00 00 00 00 00 73|FE 80 00 00 00 00 00 00 32 B4 B8 FF FE B5 82 D0|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 10|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 50|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 46|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 32|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 31|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 29|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 09|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 28|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 07|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 2D|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 06|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|3|4|5|0|0|0|0|0|0|0|,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,71,
IDE11988-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 1-MAC address,|MAC address|00 36 F8 63 EE 08|00 36 F8 63 EE 08|30 B4 B8 C6 B7 10|30 B4 B8 C6 B7 10|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|,
IDE11989-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 2-MAC address,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|,
IDE11990-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 3-MAC address,|MAC address|00 13 43 CA 87 AE|00 13 43 CA 87 AE|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|,
IDE11991-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 4-MAC address,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|,
IDE12230-MAS14856,IP network: VLANs of Ethernet switch ports branch 1-VLAN,|VLAN|3|3|3|3|3|3|3|3|3|3|,
IDE12231-MAS14856,IP network: VLANs of Ethernet switch ports branch 2-VLAN,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE12232-MAS14856,IP network: VLANs of Ethernet switch ports branch 3-VLAN,|VLAN|3|3|3|3|3|3|3|3|3|3|,
IDE12233-MAS14856,IP network: VLANs of Ethernet switch ports branch 4-VLAN,|VLAN|3|3|3|3|3|3|3|3|3|3|,
IDE12238,I network: discarded messages counter,71,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 10
IDE12625,IP network: current link deceleration: branch 1,5118, ns
IDE12626,IP network: current link deceleration: branch 2,0, ns
IDE12627,IP network: current link deceleration: branch 3,5118, ns
IDE12628,IP network: current link deceleration: branch 4,5118, ns
IDE12633,IP Network maximum correction of the synchronized clock,-989943737, ns
IDE12939-MAS02643,Public key for SWaP function (3072)-Key,B7 C6 05 35 E7 BA B7 F0 AE 46 68 8C E0 D5 60 6A EC 96 8D 37 EC D7 6D A9 2F 66 32 43 A5 51 50 F6 7F 2D 6A 98 FD 25 4F 19 60 53 8C 8D 1E E7 64 40 D5 FB 59 13 08 24 FC DC 00 8E B2 70 34 4C 57 4C 22 34 34 A6 E5 A5 00 00 5F 9E 6F EE 10 A4 11 D5 AC 96 CD 03 7B 35 6B 62 22 66 E4 87 E7 E0 3B 4F 64 A9 91 72 6D BC 58 1F 5C 7C 6F 44 40 36 44 C1 13 4D 50 FD 39 C9 22 90 89 9E 89 C1 7F 00 0D EF 0D 2A E8 51 06 E7 37 E6 D4 57 91 85 E4 98 9C 67 60 57 BB 6E EE E5 12 79 4C 6C 08 3A CB E6 BF 4F DD 8B 1A 3F B1 D7 79 84 B6 E0 BE 24 65 04 9D 0F 64 2D A0 97 EF 4E 88 C0 E4 BC 57 2C 49 23 04 DF C1 F7 52 C6 72 D3 F4 98 E9 C8 CE 5B 0A 92 0F D3 B7 4F BE 3C 34 95 36 3A F7 41 36 AE 76 B8 8A DA 01 81 2D 5B 28 B7 18 12 04 86 23 47 C6 47 8B 00 07 86 4A 0D 62 D1 5C 59 44 C9 56 E2 D2 23 9C FB 88 51 87 01 83 E4 7B FB CF 41 F2 26 D4 CC E6 B6 2F 48 2B 39 F9 59 B2 20 1C C8 0F BF 19 29 56 D2 C7 50 73 07 B3 C7 C2 32 4F BD 10 57 A0 05 B9 93 4E 3D 58 A2 93 F9 FF 79 49 13 A5 4F 8A CE 4F 20 DB 1E F7 E2 32 AB 06 71 C7 D4 09 B9 43 E2 61 B3 EA 59 A3 CF 97 7B B0 37 94 25 A3 5A 77 2F D9 41 AC F2 57 0D 17 C1 23 B7 81 CF 1D 98 2B B7 76 D0 CB CE 85 FE 08 8E 81 D2 07 7C 8F FD 0C 79 EC 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 11,
IDE13323-MAS13737,Acceleration sensor for navigation-Acceleration on the X axis,0.00, m/s²
IDE13323-MAS13738,Acceleration sensor for navigation-Acceleration on the Y axis,0.00, m/s²
IDE13323-MAS13739,Acceleration sensor for navigation-Acceleration on the Z axis,0.00, m/s²
IDE13344-MAS01167,Acoustic check of loudspeakers: sequential analysis-Actuation time,0 s,
IDE13344-ENG39349,Acoustic check of loudspeakers: sequential analysis-IoReached Status,Output diagnostic test not active,
IDE13737-MAS01763,Status of tuner for digital radio 1b (DAB)-Signal Strength,0,
IDE13737-MAS19004,Status of tuner for digital radio 1b (DAB)-DAB fault bit rate FIC,0.00,
IDE13737-MAS19005,Status of tuner for digital radio 1b (DAB)-DAB fault bit rate NET,0.00,
IDE13737-MAS19006,Status of tuner for digital radio 1b (DAB)-DAB fault bit rate MSC,0.00,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVWFB7CD8NW129409,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,10,
IDE14128-MAS01167,Activation for blower housing status-Actuation time,0 s,
IDE14128-ENG39349,Activation for blower housing status-IoReached Status,Output diagnostic test not active,
IDE14344,Automotive audio bus (A2B): status,|Node number,Node name
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant (challenge response only),
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,1,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 31,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE14715-MAS18871,Acoustic test of loudspeakers: status-Current channel,OFF,
IDE14715-MAS18921,Acoustic test of loudspeakers: status-Current loudspeaker,Not available,
IDE14733-MAS00106,SDARS subscription status-Year,2000,
IDE14733-MAS00107,SDARS subscription status-Month,0, Months
IDE14733-MAS00108,SDARS subscription status-Day,Not available,
IDE14733-MAS00109,SDARS subscription status-Hours,0, H
IDE14733-MAS00110,SDARS subscription status-Minutes,3, min
IDE14733-MAS00111,SDARS subscription status-Seconds,Not available,
IDE14733-MAS10690,SDARS subscription status-Activation condition,active,
IDE14733-MAS19035,SDARS subscription status-Procedure status,not expired,
IDE14733-MAS19036,SDARS subscription status-Expiration warning,Not available,
IDE14734-MAS01766,SDARS Service Status-Traffic data,not active,
IDE14734-MAS19037,SDARS Service Status-Audio Service,active,
IDE14734-MAS19040,SDARS Service Status-Travel link,not active,
IDE14743-MAS01167,Control panel simulation of button key codes-Actuation time,0 s,
IDE14743-ENG39349,Control panel simulation of button key codes-IoReached Status,Output diagnostic test not active,
MAS00778-IDE03619,Multimedia System 1-System condition,On,
MAS00778-IDE05228,Multimedia System 1-Operating hour counter,57, H
MAS00778-MAS00110,Multimedia System 1-Minutes,7, min
MAS00778-MAS01634,Multimedia System 1-Supply voltage,13.30, V
MAS00778-MAS02200,Multimedia System 1-Highest measured temperature,56, °C
MAS00778-MAS02201,Multimedia System 1-Temperature,53, °C
MAS00778-MAS03691,Multimedia System 1-Dimming,100, %
MAS00951-MAS04325,Bluetooth-Bluetooth: Paired devices,0,
MAS01760-MAS01765,Radio Tuner 1-Audio Signal,Analog,
MAS01760-MAS02949,Radio Tuner 1-Frequency,0.00, MHz
MAS01760-MAS03991,Radio Tuner 1-Reception level antenna 1,0,
MAS01760-MAS04344,Radio Tuner 1-Reception level antenna 2,0,
MAS01760-MAS04345,Radio Tuner 1-Frequency (AM),0,
MAS01760-MAS19025,Radio Tuner 1-IBOC fault rate,0, %
MAS01760-MAS19026,Radio Tuner 1-IBOC audio signal:,Not available,
MAS01760-MAS19028,Radio Tuner 1-IBOC DRM Service,0,
MAS01760-MAS19030,Radio Tuner 1-IBOC DRM counter,OFF,
MAS01761-MAS01763,Radio Tuner 2-Signal Strength,76,
MAS03782-MAS17355,WLAN-MAC address 2: tethering,EA 4F 25 4E 74 7F,
MAS03782-MAS17356,WLAN-MAC address 1,E8 4F 25 8E 74 7F,
MAS03782-MAS17357,WLAN-MAC address 2,00 00 00 00 00 00,
MAS03782-MAS17559,WLAN-MAC address 1: tethering,EA 4F 25 2E 74 7F,
MAS17523-MAS17968,Unlockable functions: date of last activation-Date of last function activation,00 00 00 00,
MAS17523-MAS17969,Unlockable functions: date of last activation-Date of last key exchange,00 00 00 00,
MAS17523-MAS17970,Unlockable functions: date of last activation-Date of last reset,00 00 00 00,
MAS17524-MAS17977,Unlockable functions: version info-Supported activation version,Support from FSC version 0x12,
MAS17524-MAS17978,Unlockable functions: version info-Supported encryption procedure,RSA3072 Exp. 17,
MAS17524-MAS18453,Unlockable functions: version info-FoD metadata version,No version of FoD metadata is supported,
MAS17524-MAS18456,Unlockable functions: version info-KeyIdent (Key project identification),1690,
MAS17524-MAS18457,Unlockable functions: version info-Generation of function activation,Activation via SWaP,
MAS17524-MAS18460,Unlockable functions: version info-FoD partner diagnostic address,BF FF,
MAS17833,Remaining period of test activation,4294967295, s
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,OK,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,dont care,
ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,dont care,
ENG117872-ENG117789,Byte_Coding_Condition-byte_11_condition,dont care,
ENG117872-ENG117790,Byte_Coding_Condition-byte_12_condition,dont care,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,dont care,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,dont care,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,dont care,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,dont care,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,dont care,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,dont care,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,dont care,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,dont care,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,dont care,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,dont care,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,dont care,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,dont care,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,dont care,
ENG117872-ENG117803,Byte_Coding_Condition-byte_25_condition,dont care,
ENG117872-ENG117804,Byte_Coding_Condition-byte_26_condition,dont care,
ENG117872-ENG117805,Byte_Coding_Condition-byte_27_condition,dont care,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,dont care,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,OK,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,dont care,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,dont care,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,dont care,
ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,dont care,
ENG117872-ENG117787,Byte_Coding_Condition-byte_9_condition,dont care,
ENG117866-ENG117457,DAB_FM_linking-dab_mute_status,No,
ENG117866-ENG117456,DAB_FM_linking-DAB_quality,0, %
ENG117866-ENG117455,DAB_FM_linking-fm_quality,0, %
ENG117866-ENG117458,DAB_FM_linking-service_linking_status,no_link,
ENG118092-MAS09154,Proximity_Sensor_slider_1-Proximity sensor 1,No object in sector,
ENG118096-MAS01167,Remote_Seek_Activation_status-Actuation time,0 s,
ENG118096-ENG39349,Remote_Seek_Activation_status-IoReached Status,Output diagnostic test not active,
ENG118097-MAS01167,Remote_Set_AF_status-Actuation time,0 s,
ENG118097-ENG39349,Remote_Set_AF_status-IoReached Status,Output diagnostic test not active,
ENG118098-MAS01167,Remote_Set_Concealment_Level_status-Actuation time,0 s,
ENG118098-ENG39349,Remote_Set_Concealment_Level_status-IoReached Status,Output diagnostic test not active,
ENG118099-MAS01167,Remote_Set_DAB_Announcement_status-Actuation time,0 s,
ENG118099-ENG39349,Remote_Set_DAB_Announcement_status-IoReached Status,Output diagnostic test not active,
ENG118100-MAS01167,Remote_Set_DAB_Default_status-Actuation time,0 s,
ENG118100-ENG39349,Remote_Set_DAB_Default_status-IoReached Status,Output diagnostic test not active,
ENG118101-MAS01167,Remote_Set_DAB_Linking_status-Actuation time,0 s,
ENG118101-ENG39349,Remote_Set_DAB_Linking_status-IoReached Status,Output diagnostic test not active,
ENG118102-MAS01167,Remote_Set_DAB_Mute_status-Actuation time,0 s,
ENG118102-ENG39349,Remote_Set_DAB_Mute_status-IoReached Status,Output diagnostic test not active,
ENG118103-MAS01167,Remote_Set_Hidden_Tune_status-Actuation time,0 s,
ENG118103-ENG39349,Remote_Set_Hidden_Tune_status-IoReached Status,Output diagnostic test not active,
ENG118104-MAS01167,Remote_Set_IBOC_Service_status-Actuation time,0 s,
ENG118104-ENG39349,Remote_Set_IBOC_Service_status-IoReached Status,Output diagnostic test not active,
ENG118105-MAS01167,Remote_Set_TP_status-Actuation time,0 s,
ENG118105-ENG39349,Remote_Set_TP_status-IoReached Status,Output diagnostic test not active,
ENG118106-MAS01167,Remote_Shift_Frequency_AM_Activation_status-Actuation time,0 s,
ENG118106-ENG39349,Remote_Shift_Frequency_AM_Activation_status-IoReached Status,Output diagnostic test not active,
ENG118107-MAS01167,Remote_Shift_Frequency_DAB_Activation_status-Actuation time,0 s,
ENG118107-ENG39349,Remote_Shift_Frequency_DAB_Activation_status-IoReached Status,Output diagnostic test not active,
ENG118108-MAS01167,Remote_Shift_Frequency_FM_Activation_status-Actuation time,0 s,
ENG118108-ENG39349,Remote_Shift_Frequency_FM_Activation_status-IoReached Status,Output diagnostic test not active,
ENG118125-MAS01167,set_amfm_measurement_mode_status-Actuation time,0 s,
ENG118125-ENG39349,set_amfm_measurement_mode_status-IoReached Status,Output diagnostic test not active,
ENG118126-MAS01167,set_tuner_mode_status-Actuation time,0 s,
ENG118126-ENG39349,set_tuner_mode_status-IoReached Status,Output diagnostic test not active,
ENG118133-MAS01632,Status_Position_Touch_Slider_1-Status,operated,
ENG118133-ENG117402,Status_Position_Touch_Slider_1-calibrate_delta_x,0,
ENG118133-ENG117396,Status_Position_Touch_Slider_1-position_x1,0,
ENG117864-MAS01632,Status_Position_Touchscreen_1-Status,Not operated,
ENG117864-ENG117402,Status_Position_Touchscreen_1-calibrate_delta_x,0,
ENG117864-ENG117403,Status_Position_Touchscreen_1-calibrate_delta_y,0,
ENG117864-ENG117396,Status_Position_Touchscreen_1-position_x1,0,
ENG117864-ENG117397,Status_Position_Touchscreen_1-position_x2,0,
ENG117864-ENG117398,Status_Position_Touchscreen_1-position_x3,0,
ENG117864-ENG117399,Status_Position_Touchscreen_1-position_y1,0,
ENG117864-ENG117400,Status_Position_Touchscreen_1-position_y2,0,
ENG117864-ENG117401,Status_Position_Touchscreen_1-position_y3,0,
ENG117870-MAS00106,VICS_Infrared_Beacon_State-Year,2000,
ENG117870-MAS00107,VICS_Infrared_Beacon_State-Month,0,
ENG117870-MAS00108,VICS_Infrared_Beacon_State-Day,OFF,
ENG117870-MAS00109,VICS_Infrared_Beacon_State-Hours,0,
ENG117870-MAS00110,VICS_Infrared_Beacon_State-Minutes,0,
ENG117870-MAS00111,VICS_Infrared_Beacon_State-Seconds,0,
ENG117870-MAS01632,VICS_Infrared_Beacon_State-Status,Not available,
ENG117870-ENG117771,VICS_Infrared_Beacon_State-vics_id,0,
ENG117871-MAS00106,VICS_Radio_Beacon_State-Year,2000,
ENG117871-MAS00107,VICS_Radio_Beacon_State-Month,0,
ENG117871-MAS00108,VICS_Radio_Beacon_State-Day,0,
ENG117871-MAS00109,VICS_Radio_Beacon_State-Hours,0,
ENG117871-MAS00110,VICS_Radio_Beacon_State-Minutes,0,
ENG117871-MAS00111,VICS_Radio_Beacon_State-Seconds,0,
ENG117871-MAS01632,VICS_Radio_Beacon_State-Status,Not available,
ENG117871-ENG117771,VICS_Radio_Beacon_State-vics_id,0,
Elapsed Time: 00:41,,,
;SW:5WA-980-556-C HW:5WA-980-556-B --- Back-up Cam.
;Component:RV eCompact H26 0314, Coding:02030004E43000
;EV_CamSysRVCCompaFicos,009023,EV_CamSysRVCCompaFicos_009.rod
;Thursday,17,March,2022,11:53:53:62242
;VCDS Version: Release 22.3.0 Data version: 20220225 DS336.1
;VCID: 51FF7B0D816608A310C-8004
Group,Description,Actual,
IDE00019,Voltage terminal 30,13.11, V
IDE00303-MAS00222,Status: doors/lids 1-Rear lid,closed,
IDE00303-MAS01374,Status: doors/lids 1-Trailer,not detected,
IDE00924-IDE08941,Steering angle-Rack position,0.00,
IDE00924-MAS02471,Steering angle-Sign,Negative,
IDE00924-MAS02983,Steering angle-Steering wheel angle,421.2,
IDE00924,Steering angle,30.7250,
IDE00924-MAS10998,Steering angle-Rear-wheel drive: steering angle,0.00,
IDE00924-MAS10999,Steering angle-Rear-wheel drive: sign,Positive,
IDE00924-MAS11000,Steering angle-Rack: sign,Positive,
IDE06449-MAS05746,Camera system calibration-Rearview camera calibration status,Calibration ended,
IDE06449-MAS05748,Camera system calibration-Rearview camera calibration progress,0, %
IDE06449-MAS05750,Camera system calibration-Rearview camera calibration repeat attempts,0,
IDE06449-MAS05753,Camera system calibration-Cause of rearview camera calibration error,calibrated,
IDE06449-MAS05803,Camera system calibration-Rearview camera calibration resumption,No resumption,
IDE07402-MAS10858,External activation-Rear camera,not active,
IDE10300,OBD Driving Cycle detected,not active,
IDE10589-MAS10858,Temperature of the camera-Rear camera,53, °C
IDE10740-IDE03619,System state area view-System condition,active,
IDE10779,Ethernet signal quality,good: link available,
IDE10780-MAS11932,Ethernet counter connection interruptions-Counter open circuit,0, dB
IDE10781-MAS11933,Ethernet counter checksum malfunction-Counter CRC error,0, dB
IDE11010-MAS00106,Rear camera: calibration time-Year,2021, yr
IDE11010-MAS00107,Rear camera: calibration time-Month,10, Months
IDE11010-MAS00108,Rear camera: calibration time-Day,12, d
IDE11010-MAS00109,Rear camera: calibration time-Hours,0, H
IDE11010-MAS00110,Rear camera: calibration time-Minutes,6, min
IDE11010-MAS00111,Rear camera: calibration time-Seconds,0, s
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE11756,IP network: counter messages with inadmissible VLANs,0,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,0,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|,
IDE11869,IP network: NDP cache,|MAC address,IPv6 address
IDE12238,I network: discarded messages counter,0,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE12625,IP network: current link deceleration: branch 1,0, µs
IDE12633,IP Network maximum correction of the synchronized clock,-1e+007,
IDE13845,Production mode status,No function restriction,
MAS02356-MAS10858,Type of calibration-Rear camera,TopView: calibration with calibration panel,
Elapsed Time: 00:05,,,
;SW:5WA-035-285-A HW:5WA-035-285-A --- Telematics
;Component:OCU3HMQB37W H12 0015, Coding:023800209068AC209025460070502E07
;EV_OCU3HMQB37W,002012,EV_OCU3HMQB37W_002.rod
;Thursday,17,March,2022,11:54:06:62242
;VCID: 45D75F5D452ED403BC4-8010
IDE00019,Voltage terminal 30,13.2, V
IDE00020,Terminal 15 status,On,
IDE00102,Control Module temperature,50, °C
IDE00608,Fuel type,Gas,
IDE00672,Roadside Assistance Button,Not available,
IDE00673,Information Service Button -E450-,Not available,
IDE00767,No. of unscheduled ECU resets,0,
IDE01215,Dimmer terminal 58d,96.47, %
IDE01216,Dimmer terminal 58s,100, %
IDE01588,Driving direction,0, °
IDE01588-MAS01632,Driving direction-Status,available.,
IDE01625,Muting of radio/radio navigation system via control wire,not active,
IDE01630-MAS01167,Key illumination in telephone operating unit-Actuation time,0 s,
IDE01630-ENG39349,Key illumination in telephone operating unit-IoReached Status,Output diagnostic test not active,
IDE01631-MAS01167,Output of variable test tones via radio/radio navigation system-Actuation time,0 s,
IDE01631-ENG39349,Output of variable test tones via radio/radio navigation system-IoReached Status,Output diagnostic test not active,
IDE01712-IDE06673,GPS Position-Initialization status,initialized,
IDE01712-MAS02230,GPS Position-Height,156, m
IDE01718,Crash signal,No crash recognized,
IDE01770-MAS01632,Status of GPS antenna-Status,OK,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,24, mA
IDE01971,Lowest recorded control module temperature,-16, °C
IDE01972,Highest recorded control module temperature,51, °C
IDE02067-IDE00690,Antenna for telephone status-Connection to antenna,electrically OK,
IDE02067-MAS01808,Antenna for telephone status-Antenna current,38, µA
IDE02067-MAS03991,Antenna for telephone status-Reception level antenna 1,4, %
IDE02326-ENG117459,GPS signal strength-ID_GPS_satellite_no_1,4,
IDE02326-ENG117461,GPS signal strength-ID_GPS_satellite_no_2,7,
IDE02326-ENG117463,GPS signal strength-ID_GPS_satellite_no_3,8,
IDE02326-ENG117465,GPS signal strength-ID_GPS_satellite_no_4,9,
IDE02326-ENG117460,GPS signal strength-S/N_GPS_satellite_no_1,40, dBµV
IDE02326-ENG117462,GPS signal strength-S/N_GPS_satellite_no_2,43, dBµV
IDE02326-ENG117464,GPS signal strength-S/N_GPS_satellite_no_3,42, dBµV
IDE02326-ENG117466,GPS signal strength-S/N_GPS_satellite_no_4,43, dBµV
IDE03477-MAS00110,GPS time-Minutes,54,
IDE03477-MAS00111,GPS time-Seconds,8,
IDE04293,Operating state for emer call module,registerstate_registered,
IDE04750-MAS03876,SIM card-active SIM card,internal,
IDE04750-MAS03878,SIM card-SIM IMSI,310260843266126,
IDE04750-MAS04226,SIM card-Telephone number, ,
IDE04750-MAS08401,SIM card-SIM intern,operational,
IDE04750-MAS08402,SIM card-SIM extern,Unknown,
IDE04750-MAS11003,SIM card-ICCID,8901260840232661269,
IDE04750-MAS11004,SIM card-UICCID,89033023312150000000005920060263,
IDE04790,Call for help button,Not operated,
IDE05430,Telephone serial number,015446000192243,
IDE05431-MAS01167,Lock for high-voltage charging connector-Actuation time,0 s,
IDE05431-ENG39349,Lock for high-voltage charging connector-IoReached Status,Output diagnostic test not active,
IDE07007-MAS01167,Air conditioning/heating function via remote control-Actuation time,0 s,
IDE07007-ENG39349,Air conditioning/heating function via remote control-IoReached Status,Output diagnostic test not active,
IDE07589-IDE07590,Update programming: status-Currently processed module,27,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,28,
IDE07589-MAS00106,Update programming: status-Year,2000,
IDE07589-MAS00107,Update programming: status-Month,0,
IDE07589-MAS00108,Update programming: status-Day,0,
IDE07589-MAS00109,Update programming: status-Hours,0,
IDE07589-MAS00110,Update programming: status-Minutes,0,
IDE07589-MAS00111,Update programming: status-Seconds,0,
IDE07911-MAS01167,Microphone signal via audio output-Actuation time,0 s,
IDE07911-ENG39349,Microphone signal via audio output-IoReached Status,Output diagnostic test not active,
IDE07975-MAS01167,Remote control for charging function of high-voltage battery-Actuation time,0 s,
IDE07975-ENG39349,Remote control for charging function of high-voltage battery-IoReached Status,Output diagnostic test not active,
IDE08156-MAS01167,Transmission of configuration for online services-Actuation time,0 s,
IDE08156-ENG39349,Transmission of configuration for online services-IoReached Status,Output diagnostic test not active,
IDE08235-MAS06798,Status of immobilizer participant-Key / terminal status,04,
IDE08235-MAS06799,Status of immobilizer participant-Immobiliser status,00,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,00,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,00,
IDE08235-MAS06804,Status of immobilizer participant-Status TCM,00,
IDE08235-MAS06805,Status of immobilizer participant-Status ESCL,00,
IDE08235-MAS06806,Status of immobilizer participant-Status OCU,00,
IDE08235-MAS06807,Status of immobilizer participant-Status VTS,00,
IDE08236-MAS06808,Status locking periods immobilizer-Lock time download,00,
IDE08236-MAS06809,Status locking periods immobilizer-Reset lock time passwords,00,
IDE08236-MAS06810,Status locking periods immobilizer-Lock time login terminal 15 on,00,
IDE08236-MAS06811,Status locking periods immobilizer-Lock time login learn keys,00,
IDE08236-MAS06812,Status locking periods immobilizer-Lock time login leave learn keys,00,
IDE08236-MAS06813,Status locking periods immobilizer-Lock time login special functions,00,
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,00 00 01 01,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,6, s
IDE08251-MAS06847,Configuration immobilizer-Snapshot,53 00 00 00 00 00 00 00 05 BD 00 00 00 00 00 0C 03 00 3C,
IDE08343,Immobilizer Challenge,63 15 39 FE,
IDE09293-IDE00690,Status of antenna 2 for phone-Connection to antenna,electrically OK,
IDE09293-MAS01808,Status of antenna 2 for phone-Antenna current,39, µA
IDE09293-MAS03991,Status of antenna 2 for phone-Reception level antenna 1,4, %
IDE10300,OBD Driving Cycle detected,active,
IDE11307-IDE01839,eCall battery status-Battery charge level,98, %
IDE11307-MAS08415,eCall battery status-Battery status,normal,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FE 80 00 00 00 00 00 00 32 B4 B8 FF FE C6 B7 10|FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 67|FD 53 7C B8 03 83 00 07 00 00 00 00 00 00 00 67|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 02 00 00 00 00 00 00 00 00 00 01 FF 00 00 00|FF 02 00 00 00 00 00 00 00 00 00 01 FF C6 B7 10|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 02|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 01 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 09|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 50|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 02 00 00 00 00 00 00 00 00 00 01 FF 00 00 67|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|4|7|,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,65535,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|30 B4 B8 C6 B7 10|,
IDE11988-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 1-MAC address,|MAC address|00 36 F8 63 EE 08|30 B4 B8 B5 82 D0|,
IDE11989-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 2-MAC address,Write only channel,
IDE12230-MAS14856,IP network: VLANs of Ethernet switch ports branch 1-VLAN,|VLAN|4|7|,
IDE12231-MAS14856,IP network: VLANs of Ethernet switch ports branch 2-VLAN,|VLAN|4|,
IDE12238,I network: discarded messages counter,65535,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73
IDE12732,Button for ERA/Glonass test,Not available,
IDE13159-MAS01167,Loudspeaker test for emergency call module-Actuation time,0 s,
IDE13159-ENG39349,Loudspeaker test for emergency call module-IoReached Status,Output diagnostic test not active,
IDE13593-MAS07135,Emergency call SIM profile-Activation status,not activated,
IDE13593-MAS07967,Emergency call SIM profile-profile,Not available,
IDE13593-MAS11003,Emergency call SIM profile-ICCID,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,17,
IDE13957-MAS00106,Mobile Online Service: connection status-Year,2022, yr
IDE13957-MAS00107,Mobile Online Service: connection status-Month,2, Months
IDE13957-MAS00108,Mobile Online Service: connection status-Day,15, d
IDE13957-MAS00109,Mobile Online Service: connection status-Hours,2, H
IDE13957-MAS00110,Mobile Online Service: connection status-Minutes,22, min
IDE13957-MAS00111,Mobile Online Service: connection status-Seconds,12, s
IDE13957-MAS00976,Mobile Online Service: connection status-Counter,0,
IDE13957-MAS07131,Mobile Online Service: connection status-ID steps,0,
IDE13957-MAS07132,Mobile Online Service: connection status-Code status,30,
IDE13957-MAS16770,Mobile Online Service: connection status-Year (UTC: universal time coordinated),2022, yr
IDE13957-MAS16772,Mobile Online Service: connection status-Month (UTC: universal time coordinated),2, Months
IDE13957-MAS16773,Mobile Online Service: connection status-Day (UTC: universal time coordinated),14, d
IDE13957-MAS16774,Mobile Online Service: connection status-Hour (UTC: universal time coordinated),19, H
IDE13957-MAS16775,Mobile Online Service: connection status-Minute (UTC: universal time coordinated),21, min
IDE13957-MAS16776,Mobile Online Service: connection status-Seconds (UTC: universal time coordinated),0, s
IDE13957-ENG20907,Mobile Online Service: connection status-Server_HTTP_Status_Code_Textual,Data connection established,
IDE13958-MAS00106,Mobile Online Service: service status-Year,2255, yr
IDE13958-MAS00107,Mobile Online Service: service status-Month,255, Months
IDE13958-MAS00108,Mobile Online Service: service status-Day,255, d
IDE13958-MAS00109,Mobile Online Service: service status-Hours,255, H
IDE13958-MAS00110,Mobile Online Service: service status-Minutes,255, min
IDE13958-MAS00111,Mobile Online Service: service status-Seconds,255, s
IDE13958-MAS07134,Mobile Online Service: service status-ID services,cc_breakdown_v2,
IDE13958-MAS07135,Mobile Online Service: service status-Activation status,No expiry,
IDE13958-MAS07136,Mobile Online Service: service status-Exp. year,2000, yr
IDE13958-MAS07137,Mobile Online Service: service status-Exp. month,1, Months
IDE13958-MAS07138,Mobile Online Service: service status-Exp. day,1, d
IDE13958-MAS16770,Mobile Online Service: service status-Year (UTC: universal time coordinated),2255, yr
IDE13958-MAS16772,Mobile Online Service: service status-Month (UTC: universal time coordinated),255, Months
IDE13958-MAS16773,Mobile Online Service: service status-Day (UTC: universal time coordinated),255, d
IDE13958-MAS16774,Mobile Online Service: service status-Hour (UTC: universal time coordinated),255, H
IDE13958-MAS16775,Mobile Online Service: service status-Minute (UTC: universal time coordinated),255, min
IDE13958-MAS16776,Mobile Online Service: service status-Seconds (UTC: universal time coordinated),255, s
IDE13958-ENG115012,Mobile Online Service: service status-status_last_fail,65535,
IDE13958-ENG115183,Mobile Online Service: service status-status_last_ok,65535,
IDE13958-ENG115048,Mobile Online Service: service status-status_second_last_fail,65535,
IDE13958-ENG115207,Mobile Online Service: service status-status_second_last_ok,65535,
IDE14344-MAS18506,Automotive audio bus (A2B): status-Node name,Microphone module in roof,
IDE14344-MAS18507,Automotive audio bus (A2B): status-Node number,0,
IDE14344-MAS18509,Automotive audio bus (A2B): status-Node status,electrically OK,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 00 00 00 00 00 00 00,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 2F,
MAS00077-MAS02345,Immobilizer-Current condition,02,
MAS00077-MAS06790,Immobilizer-Identity counter,01,
MAS00077-MAS06791,Immobilizer-Mark detection,03,
MAS00077-MAS06792,Immobilizer-P class,BD,
MAS00077-MAS06793,Immobilizer-Number of adapted keys,00,
MAS00077-MAS06794,Immobilizer-Number of keys to be adapted via service download,00,
MAS00077-MAS06795,Immobilizer-Number of keys to be adapted adapt service keys,00,
MAS00077-MAS06796,Immobilizer-Remaining time to switch on terminal 15,00,
MAS00077-MAS06797,Immobilizer-Status configuration,04,
MAS00464-MAS00106,Standard - ambient data 1-Year,2022,
MAS00464-MAS00107,Standard - ambient data 1-Month,3,
MAS00464-MAS00108,Standard - ambient data 1-Day,17,
MAS00464-MAS00109,Standard - ambient data 1-Hours,11,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,54,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,23,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,56,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,3969, km
MAS01490-MAS08403,Energy management-Remaining short term energy budget,1000, mAh
MAS01490-MAS08404,Energy management-Remaining long term energy budget,3600, mAh
MAS01490-MAS08405,Energy management-Wake up cycles counter,209,
MAS03615-MAS01167,Connection setup-Actuation time,0 s,
MAS03615-ENG39349,Connection setup-IoReached Status,Output diagnostic test not active,
MAS04394-IDE03580,Connection status-Country recognition for mobile network,310,
MAS04394-IDE07699,Connection status-Mobile network operator,260,
MAS04394-MAS03991,Connection status-Reception level antenna 1,8, %
MAS04394-MAS04460,Connection status-Validity,valid,
MAS04394-MAS08406,Connection status-Network type,LTE,
MAS04394-MAS08407,Connection status-Data connection,active,
MAS04394-ENG123307,Connection status-Radio_Cell_Number,12161282,
MAS04394-ENG123308,Connection status-TCP_Connection_State,active,
MAS08178-IDE05253,Crash information-Front crash,No,
MAS08178-IDE05254,Crash information-Side crash on driver side,No,
MAS08178-IDE05255,Crash information-Side crash on frt.pass.side,No,
MAS08178-IDE05256,Crash information-Rear crash,No,
MAS08178-IDE05257,Crash information-Rollover crash,No,
MAS08178-MAS08636,Crash information-Automatic emergency call activated:Accident sensor,No,
MAS08200,Emergency call speaker status,electrically OK,
MAS08374-MAS01167,Remote control for lights and horn-Actuation time,0 s,
MAS08374-ENG39349,Remote control for lights and horn-IoReached Status,Output diagnostic test not active,
MAS10430,Indicator light for emerg. call,Emergency call function not available,
MAS13076-MAS12732,Error valid: error path traversed-Dataset download,full working order,
MAS13076,Error valid: error path traversed,Active diagnosis,
MAS16678-MAS01167,Test mode for emergency call-Actuation time,0 s,
MAS16678-ENG39349,Test mode for emergency call-IoReached Status,Output diagnostic test not active,
MAS17524-MAS18453,Unlockable functions: version info-FoD metadata version,Support from metadata version 0x10,
MAS17524-MAS18456,Unlockable functions: version info-KeyIdent (Key project identification),1644,
MAS17524-MAS18457,Unlockable functions: version info-Generation of function activation,Activation via FoD,
MAS17524-MAS18460,Unlockable functions: version info-FoD partner diagnostic address,00 19,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
MAS18461-MAS18463,FoD product list-Product number,0,
MAS18461-MAS18464,FoD product list-Function ID,,
MAS18461-MAS18465,FoD product list-Import regulation,No Info,
MAS18461-MAS18471,FoD product list-Product regulation,No Info,
MAS18461-MAS18474,FoD product list-Change information regulation,No Info,
MAS18461-MAS18477,FoD product list-Notification control,No Info,
MAS18461-MAS18481,FoD product list-Activate regulation,No Info,
MAS18461-MAS18484,FoD product list-Deactivate regulation,No Info,
MAS18461-MAS18487,FoD product list-Warning interval,0,
MAS18461-MAS18488,FoD product list-additional meta info 1,00,
MAS18461-MAS18489,FoD product list-additional meta info 2,00,
MAS18490-IDE06260,Read FoD assignment products on FSIDs-ID number,00 00 00 00,
MAS18490-MAS18463,Read FoD assignment products on FSIDs-Product number,0,
MAS18799-MAS01167,Radio / radio navigation system muting test-Actuation time,0 s,
MAS18799-ENG39349,Radio / radio navigation system muting test-IoReached Status,Output diagnostic test not active,
MAS18800,Version of audio dataset used,W101,
MAS19234,Status of user-related refresh tokens,invalid,
MAS19235,Back end (MBB) active user ID,#anonymousGuest# ,
MAS19236-MAS00106,Expiration date of user-related refresh tokens-Year,2000,
MAS19236-MAS00107,Expiration date of user-related refresh tokens-Month,0,
MAS19236-MAS00108,Expiration date of user-related refresh tokens-Day,0,
MAS19237,Status of user-related safety pin in vehicle,locked,
MAS19245-MAS19246,Safety mode-Safety mode status,OFF,
MAS19247-MAS19256,Authentication stage-User-related instantaneous authentication stage,0,
MAS19248-MAS19257,User role-User role for active user,Main user,
MAS19255-MAS19238,Status of user image for current user-Image reference value,00 00,
MAS19270,Parameter list,|Parameter ID,Data description
MAS19273,Shadow drive metadata,|User ID,Year
MAS19295,Historical memory for synchronization,Write only channel,
MAS19313,BAP historical memory,|Year,Month
MAS19326,CAN signals for OCU customization,|Year,Month
ENG123206,Antenna_Switch,LTE antenna 1,
ENG55051-ENG56247,Authentic_time_last_client_response-Counter_kl15_since_last_sync,211,
ENG55051-ENG56597,Authentic_time_last_client_response-Current_time_used,1970-01-01T00:00:00Z,
ENG55051-ENG55667,Authentic_time_last_client_response-Last_valid_timestamp_from_Backend,1970-01-01T00:00:00Z,
ENG123492-ENG124418,Backup_Battery_SoH-BUB_ci,74.046,
ENG123492-ENG124985,Backup_Battery_SoH-mcharge_time,3381, s
ENG123492-ENG125013,Backup_Battery_SoH-mSoH,90,
ENG123492-ENG125230,Backup_Battery_SoH-rSoH,90,
ENG125913,Hybrid_Type,no_Hybrid_Car,
ENG123205,Incoming_call_line_state,Idle,
ENG117422,IP_Address,100.239.243.223,
ENG123203-ENG123321,Network_Statistics-CRC_Errors,11568,
ENG123203-ENG123320,Network_Statistics-DNS_Resolution,14128,
ENG123203-ENG123324,Network_Statistics-DNS_Resolution_Error,No malfunction,
ENG123203-ENG124655,Network_Statistics-Duration_Of_Voice_Calls,4096, min
ENG123203-ENG123319,Network_Statistics-Established_TCP_Connections,12601,
ENG123203-ENG123326,Network_Statistics-HTTP_Transmission_Error,Malfunction,
ENG123203-ENG123317,Network_Statistics-Interrupted_TCP_Connections,14896,
ENG123203-ENG123323,Network_Statistics-Network_Timeout_Error,No malfunction,
ENG123203-ENG123315,Network_Statistics-Number_Of_Events,12850,
ENG123203-ENG123330,Network_Statistics-Number_Of_Failed_DNS_Requests,12336,
ENG123203-ENG123332,Network_Statistics-Number_Of_Failed_HTTP_Requests,12346,
ENG123203-ENG123331,Network_Statistics-Number_Of_Failed_PDP_Connections,14896,
ENG123203-ENG123333,Network_Statistics-Number_Of_Failed_Secure_Connections,12336,
ENG123203-ENG123328,Network_Statistics-Number_Of_Failed_Transport_Protocol_Connections,11568,
ENG123203-ENG123314,Network_Statistics-Number_Of_Jobs,13102,
ENG123203-ENG123329,Network_Statistics-Number_Of_Network_Timeouts,12628,
ENG123203-ENG123316,Network_Statistics-Number_Of_Packet_Data_Connection_Failures,13104,
ENG123203-ENG123311,Network_Statistics-Number_Of_Voice_Calls,12592,
ENG123203-ENG123325,Network_Statistics-PDP_Connection_Error,No malfunction,
ENG123203-ENG123318,Network_Statistics-Rejected_TCP_Connections,12378,
ENG123203-ENG123334,Network_Statistics-Round_Trip_Time,23040, ms
ENG123203-ENG123327,Network_Statistics-Secure_Connection_Error,Malfunction,
ENG123203-ENG123313,Network_Statistics-Service_Data_Volume,959328820, B
ENG123203-ENG123335,Network_Statistics-SMS_Counter,54016,
ENG123203-ENG123312,Network_Statistics-Total_Data_Volume,808333875, B
ENG123203-ENG123322,Network_Statistics-Transport_Protocol_Connection_Error,Malfunction,
ENG114618,OCU_Internal_Status_Field,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG123204,Outgoing_call_line_state,Idle,
ENG116737,Position_Confidence,36, m
ENG116750-ENG28257,Third_Last_Position-Latitude, 43° 3'32.6"N,
ENG116750-ENG28256,Third_Last_Position-Longitude, 77°29'22.9"W ,
Elapsed Time: 01:17,,,
