- Mar 12, 2022
- 10
- 1
- Taranaki, New Zealand
- C?ID=511343
Hi
my DSG 02E 6sp has fault code 18148 clutch temp monitoring. it will not clear.
Twice in the past month the shift indicator on the DPI started flashing and lost forward drive after reversing then going to drive away.
I looked into Clutch temperature, Trans oil temp and Mecha Control unit temp in advance measure blocks and am able to get a measurement of around in the high 90s.
There was about 10 to 15 degrees difference momentarily between the Control unit and the Clutch when i accelerated hard but would return back to be within 0 to 7 degrees of each other in a relatively short time. My test drive was in city and motorway including hills, driven as I normally would. During my test drive the gearbox operated like normal.
I was looking for VW NAR TSB 37-06-07 (2012681) but am unable to find it.
I registered in erWin and paid for a session and was unable to find it.
I also tried to search in the forums but couldn't
I am trying to determine if it is the Temp sensor that is the cause of the fault or the if the Clutch is overheating.
Thursday,10,March,2022,22:26:17:27604
VCDS Version: 22.3.0.1 (x64) HEX-V2 CB: 0.4613.4
Data version: 20220225 DS336.1
VIN: WVWZZZ1KZ8M312366 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72
VIN: WVWZZZ1KZ8M312366 Mileage: 81640km-50728miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 Q HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial number: VWX7Z0G62460ME
Coding: 040300431C070160
Shop #: WSC 00066 000 00000
VCID: 343112F9623DD2EB1BA-8060
VINID: 9E69EAAAA05BA887430420C6187C92B32C
Readiness: 0110 0101
Part No SW: 02E 300 044 J HW: 02E 927 770 AE
Component: GSG DSG 081 1411
Revision: 04608010 Serial number: 00000705031412
VCID: 1C61DA59EAAD7AAB33A-8048
18148 - Clutch Temperature Monitoring
P1740 - 012 -
Fault Status: 01101100
Fault Frequency: 255
Mileage: 81643 km
Address 03: ABS Brakes Labels:. 1K0-614-517-MK60AT.clb
Part No SW: 1K0 614 517 AC HW: 1K0 614 517 AC
Component: ESP FRONT MK60-AT 0102
Revision: 00H14001
Coding: 0037506
VCID: 6889B6896E75660B672-803C
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BS HW: 1K0 907 044 BS
Component: ClimatronicPQ35 120 1111
Revision: 00120021 Serial number: 00000000000000
VCID: 79AFE3CD05DFEF8388C-802C
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000000654329
Coding: E78F8F2700041500470000001C00000000097F075C000100000000000000
VCID: 71BFDBED5DAFA7C330C-8024
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 100707 020 0501
Coding: 00038805
Shop #: WSC 00066
Subsystem 2 - Part No: 1K0 955 559 AB Labels: 1K0-955-559-AF.CLB
Component: RLS 070607 020 0105
Coding: 00208933
Shop #: WSC 00066
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 7F AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6M02C54M
Coding: 0014150
VCID: 6C81CA997A8D4A2B03A-8038
Subsystem 1 - Serial number: 6332MSME1A35270DC
Subsystem 2 - Serial number: 6342MSME173D4E60K
Subsystem 3 - Serial number: 6351HSME0E27612FE
Subsystem 4 - Serial number: 6361HSME0E276978L
Part No SW: 1K0 953 549 BK HW: 1K0 953 549 BK
Component: J0527 051 0101
Coding: 0012142
Shop #: WSC 73300 981 60702
VCID: 7CA1FAD90AEDDAAB93A-8028
Component: E0221 002 0010
Part No SW: 1K0 920 864 A HW: 1K0 920 864 A
Component: KOMBIINSTRUMENT 3HL 1212
Revision: V0002000 Serial number: VWX7Z0G62460ME
Coding: 0007503
Shop #: WSC 50109 001 1048576
VCID: 2A0D0C81B0F9941BB16-807E
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 030607F1000027
Coding: ED817F060002022003
VCID: 30391EE99625EECB7F2-8064
Reset counter: 114
Mileage: 74618 km
Time: 18:23:56
Component: IMMO 3HL 1212
Shop #: WSC 73300 981 109303
Part No SW: 1K0 959 701 Q HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1134
Revision: 31008001 Serial number: 00000532878601
Coding: 0000694
VCID: 3C213AD94A6D1AABD3A-8068
Fault Status: 00100101
Reset counter: 128
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.070 H08 1901
VCID: 363528F17441C0FB25E-8062
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CA HW: 1K0 959 433 CA
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 8090020052830C7F2D0484056008DF03E0FCA0
00332 - Control Circuit for Tank Flap
Fault Status: 00100111
Fault Frequency: 235
Reset counter: 152
Mileage: 74618 km
Time: 18:47:48
Part No SW: 1K0 959 702 AE HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1520
Revision: 71009005 Serial number: 00000503299111
Coding: 0005046
Shop #: WSC 73300 981 138083
VCID: 72BDD4E158A99CDBC96-8026
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74B1D2F922BD92EBDBA-8020
Address 56: Radio
Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
Component: J388 TUER-SG HL 1120
Revision: 11006001 Serial number: 00000001819074
Coding: 0000144
VCID: 3D2737DD517713A3E44-8068
Address 72: Door, Rear Right Labels: None
Part No SW: 3C0 959 704 B HW: 3C0 959 794 C
Component: J389 TUER-SG HR 1509
Revision: 11006001 Serial number: 00000005940961
Coding: 0000660
Shop #: WSC 50265 000 1048576
End----(Elapsed Time: 01:21, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
