Help 4523 - Fan Control Module 1 - Supply Voltage Malfunction
pauly40
ireland
C?ID=442007
Hi all looking for some guidance on this fan control module supply voltage malfunction issue thanks
Friday,11,March,2022,18:04:42:22536
VCDS Version: 22.3.0.1 (x64)  HEX-V2 CB: 0.4613.4
Data version: 20220225 DS336.1
VIN: WVWZZZAWZLU048278   License Plate: VW POLO R LINE
Mileage: 13932km-8656mi   Repair Order: 232
Chassis Type: AW-VW27 (2Q0)
Scan: 01 03 08 09 10 13 15 17 19 44 5F
VIN: WVWZZZAWZLU048278   Mileage: 13932km-8656miles
Address 01: Engine (J623-DKRF)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 025 AL    HW: 04C 907 309 BP
   Component: R3 1.0l TFS   H20 7054
   Revision: DGH20000    CVN: 3D899775
   Coding: 0119003223041D080000
   Shop #: WSC 31414 790 00200
   ASAM Dataset: EV_ECM10TFS01104C906025AL 003001
   ROD: EV_ECM10TFS01104C906025AK.rod
   VCID: 6A8DCBAA5CFA69DB716-803E
   VINID: 9E69EAAAA467A9C94010808720B1162752
          P2D89 00 [039] - Supply Voltage Malfunction
                    Mileage: 13932 km
                    Date: 2021.12.17
                    Time: 08:20:32
                    Engine RPM: 1460.00 /min
                    Normed load value: 37.3 %
                    Coolant temperature: 61 °C
                    Intake air temperature: 14 °C
                    Voltage terminal 30: 13.340 V
                    Outside temperature: 9 °C
                    Absolute intake pressure: 79 kPa abs
                    Engine torque: 43.5 Nm
                    Fuel: tank fill level: 4.0 l
                    Oxygen sensor B1: sensor 1: specified value: 1.0000
                    Particulate filter: loading stage: 0
                    Overrun cut-off-Bits 0-7: 0
          U0428 00 [039] - -
                    Mileage: 13932 km
                    Date: 2021.12.17
                    Time: 08:20:21
                    Engine RPM: 960.00 /min
                    Normed load value: 9.8 %
                    Coolant temperature: 60 °C
                    Voltage terminal 30: 13.360 V
                    Absolute intake pressure: 32 kPa abs
                    Engine torque: 15.2 Nm
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 2Q0 614 517 AG    HW: 2Q0 614 517 N
   Component: ESC_base_vFGS H23 0242
   Serial number: 08506781190912
   Coding: 09034C64354590B532FEAC1D24E242A649124526224A245844541254452442659248A2644452241A222A482AA251D64B3D8A6BD2BC
   ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004036
   ROD: EV_Brake1BOSCHESPMQBA0_004.rod
   VCID: 73B3D6CE0B30A813C20-8026
1360 - Implausible Data Received from Steering Angle Sensor Module (G85)
          U0428 00 [153] - -
          [LWI_SensorNotCalibrated]
          MIL ON - Confirmed - Not Tested Since Memory Clear
                    Reset counter: 236
                    Mileage: 13932 km
                    Date: 2021.12.11
                    Time: 23:22:11
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 2G2 820 045 K    HW: 2G2 820 045 K
   Component: SG_AC_Manuell H60 0505
   Coding: 012100000800010001000400020000000010000000000000000000000000
   ASAM Dataset: EV_ACManuePrehMQBA0 001013
   ROD: EV_ACManuePrehMQBA0_VW27.rod
   VCID: 290FF4A6997CA2C3B8C-807C
   Part No SW: 2Q0 937 089 B    HW: 2Q0 937 089
   Component: BCM A0 Std    H10 0934
   Serial number: 01101923301651
   ASAM Dataset: EV_BCMA0 205001
   ROD: EV_BCMA0_205.rod
   VCID: 392F24E669DC1243C8C-806C
   Subsystem 1 - Part No SW: 5Q0 955 559 C    HW: 5Q0 955 559 C  Labels: 5Q0-955-547.CLB
   Component: RLS  051 0206
   Serial number: S6Y19M08D21H18M41S16
   Coding: 0018DD
   Driver door control module:
   Subsystem 2 - Part No SW: 2Q2 959 405 B    HW: 2Q2 959 163 B
   Component: FHSG_DRV  002 0005
   Serial number: 00000000000033375710
   Coding: 1F0037
   Front passenger door control module:
   Subsystem 3 - Part No SW: 2Q2 959 406 B    HW: 2Q2 959 164 B
   Component: FHSG_PSG  002 0005
   Serial number: 00000000000033357036
   Coding: 058037
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY192301SKU
   Serial number: 00000000000047647558
   Subsystem 6 - Part No SW: 5Q0 959 408     HW: 5Q0 959 164
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000033753487
   Coding: 1F0000
   Subsystem 7 - Part No SW: 5Q0 959 407     HW: 5Q0 959 163
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000033862384
   Coding: 070000
8202 - Bulb for Left DRL
          B121D 15 [009] - Open or Short to Plus
                    Reset counter: 236
                    Mileage: 13932 km
                    Date: 2021.12.17
                    Time: 08:20:21
                    Zusaetzliche Umgebungsdaten-Terminal 15 status: On
                    Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
                    Zusaetzliche Umgebungsdaten-Low beam: Not operated
                    Zusaetzliche Umgebungsdaten-OFF: Not operated
                    Zusaetzliche Umgebungsdaten-Outside temperature: -50.0 °C
                    Zusaetzliche Umgebungsdaten-Automatic high beam assist: Not operated
                    Zusaetzliche Umgebungsdaten-Position lamps: Not operated
                    Zusaetzliche Umgebungsdaten-Parking light left: Not operated
                    Zusaetzliche Umgebungsdaten-Parking light right: Not operated
                    Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
                    Zusaetzliche Umgebungsdaten-last wakeup: keine Stoerschutzursache
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
                    Zusaetzliche Umgebungsdaten-voltage measurement: 13.4 V
8458 - Bulb for Right DRL
          B121E 15 [009] - Open or Short to Plus
                    Reset counter: 236
                    Mileage: 13932 km
                    Date: 2021.12.17
                    Time: 08:20:21
   Part No SW: 5QA 919 294 G    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0061
   Serial number: 000150058419256
   Coding: 0471051001
   ASAM Dataset: EV_EPHVA18AU3700000 009046
   ROD: EV_EPHVA18AU3700000.rod
   VCID: 50F97942DA66B30B1F2-8004
13637426 - Databus
                    Reset counter: 236
                    Mileage: 13932 km
                    Date: 2021.12.17
                    Time: 08:20:19
   Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0372
   Coding: 2A04600200FF8748949C810500408700000000000000000004
   ROD: EV_ACCMRRCONTIVW376_003.rod
   VCID: 43D3460E1B105893920-8016
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Reset counter: 236
                    Mileage: 13932 km
                    Date: 2021.12.17
                    Time: 08:20:18
                    Voltage terminal 15: 13.4 V
                    Control Module temperature: 28 °C
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: -0.16 m/s²
                    Adaptive distance regulation: status: ACC_reversible_error
2055 - Databus
          [FAULT_ALP_STEERINGWHEEL_INIT]
                    Reset counter: 236
                    Mileage: 13932 km
                    Date: 2021.12.17
                    Time: 08:20:18
   Part No SW: 2Q0 959 655 AG    HW: 2Q0 959 655 AG
   Component: VW22Airbag    010 0248
   Revision: --------
   Coding: 88CCC0C0000000005C5400CF008800000065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001010
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 025D830A448A919BD96-8056
   Subsystem 1 - Part No SW: -----------    HW: 442 062 510 19
   Serial number: 3577Y50B13251E51120L
   Subsystem 2 - Part No SW: -----------    HW: 442 062 210 19
   Serial number: 3587Y5099331F37251B2
   Subsystem 3 - Part No SW: -----------    HW: 442 0B2 908 19
   Serial number: 3517781BD33B2852812F
   Subsystem 4 - Part No SW: -----------    HW: 442 0B0 609 19
   Serial number: 3527782B133A3551A1DE
   Subsystem 5 - Part No SW: -----------    HW: 442 132 812 19
   Component: FrontSensor_D  290 118A
   Serial number: 355AG11AB30C15E256F$
   Part No SW: 2G0 920 940 C    HW: 2G0 920 940 C
   Component: KOMBI         202 6700
   Coding: 24A4010021802600018822011001000000000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001040
   ROD: EV_DashBoardVDDMQBA0_VW27.rod
   VCID: 2411E592FE5E7FAB8BA-8070
   Part No SW: 2Q0 909 901 C    HW: 2Q0 937 089
   Component: GW MQB A0     H10 0934
   Coding: 030100046F08560022000048080F00010001070000000000000000000000
   GVL: 01443C0000000000400080000000480000000000000000000000000000000000
   ASAM Dataset: EV_GatewA0 013026
   ROD: EV_GatewA0_VW27.rod
   VCID: 323D13CAB4AAE11B096-8066
   Generator:
   Component: 2-01-14-01-04
   Subsystem 2 - Part No SW: 2G0 959 442 N    HW: 2G0 959 442 N
   Component: E221__MFL-MD9  H04 0052
   Serial number: 29190001324640099295
   Coding: 24FFFF
   Subsystem 3 - Part No SW: 2Q0 915 181 B    HW: 2Q0 915 181 B
   Component: J367-BDMBOSCH  H02 2012
   Serial number: 10029C65
Address 44: Steering Assist (J792)       Labels:* 2Qx-909-144-V1.clb
   Part No SW: 2Q2 909 144 M    HW: 2Q2 909 144 F
   Component: TRW_G4L_MQBA0 621 6041
   Serial number: 1445222CB4K2681
   Coding: 010000000000000001010201010001000000010001
   ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 011016
   ROD: EV_SteerAssisTRWG4LMQBA0.rod
   VCID: 3D2730F67DF42E63E44-8068
10531840 - Steering angle sensor
          B1168 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 236
                    Mileage: 13932 km
                    Date: 2021.12.17
                    Time: 08:20:19
                    Engine RPM: 954 /min
                    System status: Driving mode
                    Voltage terminal 30: 13.41 V
                    Power steering current consumption: 0.5 A
                    max.value: 0.5 A
                    End stage temperature: 15 °C
                    Steering assistance: engine output: 100 %
                    Engine angle: 0 °
                    Electric motor speed: 0 /min
                    Steering assistance: target engine torque: 0.0 Nm
                    Steering torque: 0.0 Nm
10551552 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [DEM_CODING_PLA_FAULT]
                    Reset counter: 236
                    Mileage: 13932 km
                    Date: 2021.12.17
                    Time: 08:20:24
                    Voltage terminal 30: 13.44 V
                    max.value: 0.5 A
                    Engine angle: 7 °
                    Electric motor speed: -1 /min
   Part No SW: 3Q0 035 842 C    HW: 3Q0 035 842 C
   Component: MU-S-D-ER     724 0891
   Coding: 02720000BE00000041110101008808001F0506C60120010003
   ROD: EV_MUStd4CDELP_VW27.rod
   VCID: 2D0700B6AD94BEE3544-8078
   Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
   Component: ABT_Std-2  H61 8214
   Serial number: VWZ6ZJW2550280
End----------(Elapsed Time: 00:56, VBatt start/end: 13.3V/13.3V)-----------
JMR
Romania
C?ID=432218
need to start by checking fuses and wiring.
pauly40
ireland
C?ID=442007
Hi JMR i’v check all fuse and wiring to fan they are all ok.just can’t get my head around why supply voltage malfunction try to do output test on the fan been refused by control module.
EuroX
Northern NJ USA
C?ID=208579
Check power and ground at fan module. Make sure you have good power and good ground. You can also test trigger wire see if ecu is sending signal out to turn on the fan. However You should be able to do so with output test or worst case scenario power probe that can do pwm signal like power probe 4. If your getting power to fan and trigger wire is ok and sending signal to fan its possible fan is faulty.
pauly40
ireland
C?ID=442007
I’ll try that tomorrow thanks for help EuroX keep u undated how I get on
stylers
Ireland
C?ID=330936
As others have said, you would start by checking the supply to the fan module.. they normally have a permanent supply (2 heavy wires red/red black positive and brown earth). put a good load (headlamp bulb) across it and measure the voltage.
However.. this is a mk6 polo ? so.. not sure exactly what setup this uses but I wonder how the engine ECU knows that there is an issue with the fan module voltage ? there may be a CAN bus or LIN bus connection to it if its able to report a fault.. and that would explain the output test failing. what happens (i.e. what fault codes occur) if you disconnect the fan module entirely ? if it shows loss of communications or not present then it may very well be that the module has intelligence and it may be just faulty.
If there is A/C, what happens when you turn it on.. does the fan start ?
pauly40
ireland
C?ID=442007
Hi styleres and EuroX I’v finally got around to doing the tests yous said to do today everything work down to the connector to fan no fuse gone did the headlight bulb test voltage was great disconnect the fan module and vcds says
4527 - Coolant Fan Control Circuit 1
P0480 00 [039] - Electrical Malfunction
Took fan out check the wires all where ok put power to fan nothing happen no fan movement so I take it down to broken or faulty fan control module. I’ll just replace it with new one..thanks for guidance really appreciate it help
Reactions: JMR
EuroX
Northern NJ USA
C?ID=208579
I suspected that be the issue. Normally if you do output test and fan does not run its a bad FCM/Fan. I think in this car FCM is part of fan motor assembly. I don't wanna say its common but I have seen fans fail on a number of vag vehicles over the year more recently now then in the past.
pauly40
ireland
C?ID=442007
Hi Just a update before I order a new FCM/FAN and your right EuroX it is part of fan motor assembly.I disassembled the fan module and found it had pin from a connector on the inside disconnect it was the power supply so fixed it and everything is working perfect.was able to do a output test fan working 100% now thanks guys for all your help
EuroX
Northern NJ USA
C?ID=208579
Do you have any pictures?? Was is a cold solder joint or a physical connector or connection with solder??
