Maps VW T-Cross (DLAC) maps
Maps
vwflappie
C?ID=970
Scan
Friday,04,March,2022,14:22:01:13091
VCDS Version: 22.3.0.1 (x64)  HEX-V2 CB: 0.4613.4
Data version: 20220225 DS336.1
Dealer/Shop Name:
Workshop Code: 123 12345 000001
VIN: WVGZZZC1ZMY15xxxx   License Plate:
Chassis Type: C1-VW27 (2Q0)
Scan: 01 03 08 09 10 13 15 17 19 44 5F 69 75 A5
VIN: WVGZZZC1ZMY15xxxx   Mileage: 9995km-6210miles
Address 01: Engine (2D2D2-DLAC)       Labels: None
   Part No SW: 05C 906 032 K    HW: 05C 907 394 D
   Component: R3 1.0l TFS   H01 1334
   Revision: 42101001
   Coding: 0111001223140D0800000000000000000000000000000000
   Shop #: WSC 86867 928 534987
   ASAM Dataset: EV_ECM10TFS03005C906032K 001008
   ROD: EV_ECM10TFS03005C906032K_001.rod
   VCID: 270B07450F6E2603AE8-8072
   VINID: 9E65EAAAA4C1A9DA411420C91C05A34F81
42941 - Camshaft Position Sensor -- Crankshaft Direction Incorrect
          P034B 00 [096] - -
38116 - Torque Limited due to Pre-Ignition
          P16D4 00 [096] - -
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 2Q0 614 517 AP    HW: 2Q0 614 517 N
   Component: ESC_base_vFGS H23 0262
   Serial number: 08507243210531
   Coding: 91054B3E3D4689AFD2FFBC1F12E111A649264D06224A244844546255454888659264B26044522412222A46AAA249D64B3F926BD2FC90AC90093509
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_Brake1BOSCHESPMQBA0 005001
   ROD: EV_Brake1BOSCHESPMQBA0_005.rod
   VCID: 7CA10829A66855DB93A-8028
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 2G1 820 045 M    HW: 2G1 820 045 M
   Component: SG_AC_Manuell H60 0505
   Coding: 612000000800010001000400020000000010000000000000000000000000
   ASAM Dataset: EV_ACManuePrehMQBA0 001013
   ROD: EV_ACManuePrehMQBA0_VW27.rod
   VCID: 2A0DFE711C7C1B6BB16-807E
   Part No SW: 2Q0 937 089 C    HW: 2Q0 937 089 C
   Component: BCM A0 Std    H11 0943
   Serial number: 01102115901804
   ASAM Dataset: EV_BCMA0 206001
   ROD: EV_BCMA0_206.rod
   VCID: 3A2DCE31ECDCABEBC16-806E
   Driver door control module:
   Subsystem 1 - Part No SW: 2Q2 959 405 C    HW: 2Q2 959 163 C
   Component: FHSG_DRV  002 0003
   Serial number: 00000000000051964860
   Coding: 030000
   Front passenger door control module:
   Subsystem 2 - Part No SW: 2Q2 959 406 C    HW: 2Q2 959 164 C
   Component: FHSG_PSG  002 0003
   Serial number: 00000000000051756114
   Coding: 190000
   Subsystem 3 - Part No SW: 5Q0 959 407 D    HW: 5Q0 959 163 C
   Component: FOND_FHSG_DRV  007 0011
   Serial number: 00000000000051883336
   Coding: 030000
   Subsystem 4 - Part No SW: 5Q0 959 408 D    HW: 5Q0 959 164 C
   Component: FOND_FHSG_PSG  007 0011
   Serial number: 00000000000052093513
   Coding: 1B0000
   Part No SW: 5QA 919 294 J    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0073
   Serial number: 000150058621159
   Coding: 8471051141
   ASAM Dataset: EV_EPHVA18AU3700000 009053
   ROD: EV_EPHVA18AU3700000.rod
   VCID: 53F383956B767AA3220-8006
   Part No SW: 2Q0 907 572 T    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H07 0383
   Coding: 2A04600A00FF8748949C810500508700000000000000000004
   ASAM Dataset: EV_ACCMRRCONTIVW376 003018
   ROD: EV_ACCMRRCONTIVW376_003.rod
   VCID: 45D7ADCD9522D413BC4-8010
   Part No SW: 2Q0 959 655 AJ    HW: 2Q0 959 655 AJ
   Component: VW22Airbag    016 0250
   Revision: --------
   Coding: 88CCC0C0000000005C5400CF000C40A80065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001014
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 05576DCDD5A21413FC4-8050
   Subsystem 1 - Part No SW: -----------    HW: 442 062 604 21
   Serial number: 3577Y50B3037CB834341
   Subsystem 2 - Part No SW: -----------    HW: 442 062 604 21
   Serial number: 3587Y50B3037CB83C1BF
   Subsystem 3 - Part No SW: -----------    HW: 442 0B1 605 21
   Serial number: 35177109B055C6765105
   Subsystem 4 - Part No SW: -----------    HW: 442 0B1 605 21
   Serial number: 3527711A5055C672F2AJ
   Subsystem 5 - Part No SW: -----------    HW: 442 130 106 21
   Component: FrontSensor_D  290 118A
   Serial number: 355AG53B0C4C01A7023N
   Part No SW: 2G0 920 740 J    HW: 2G0 920 740 J
   Component: KOMBI         204 8400
   Coding: 04A4110361800008018862031000000800600000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001044
   ROD: EV_DashBoardVDDMQBA0_VW27.rod
   VCID: 290F017D197A1073B8C-807C
   Part No SW: 2Q0 909 901 D    HW: 2Q0 937 089 C
   Component: GW MQB A0     H11 0943
   Coding: 030100046F08560022000048080F00010001070000000000000000000000
   GVL: 01443C0000000000C08080008000480000000000000000000000000000000000
   ASAM Dataset: EV_GatewA0 013026
   ROD: EV_GatewA0_VW27.rod
   VCID: 3333E315CBB65AA3020-8066
   Generator:
   Component: 5-00-14-00-04
   Subsystem 2 - Part No SW: 3G0 959 442 AH    HW: 3G0 959 442 AH  Labels: 3C8-959-537.CLB
   Component: E221__MFL-PR6  H50 0500
   Serial number: PR6-0440036137210008
   Coding: 280C00
   Subsystem 3 - Part No SW: 2Q0 915 181 B    HW: 2Q0 915 181 B
   Component: J367-BDMBOSCH  H02 2012
   Serial number: 101B849E
Address 44: Steering Assist (J792)       Labels:* 2Qx-909-144-V1.clb
   Part No SW: 2Q1 909 144 S    HW: 2Q1 909 144 S
   Component: TRW_G4L_MQBA0 612 6042
   Serial number: 02575829CP3M174
   Coding: 010000010100000001010201010001000000010101
   ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 011016
   ROD: EV_SteerAssisTRWG4LMQBA0.rod
   VCID: 42DDB6D1840CE32B996-8016
   Part No SW: 3G5 035 820 E    HW: 3G5 035 820 E
   Component: MU-O-ND-EU    H22 0278
   Serial number: VWZAZ2Y0646734
   Coding: 22160000000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB 001001
   ROD: EV_MUOIMQB_VW27.rod
   VCID: 26150A4108643F0B95E-8072
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  361 8214
   Serial number: VWZ6ZHY1700602
   Subsystem 2 - Part No: V03 959 809 CM
   Component: EU 2021        4031
   Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
   Component: Anheanger     H21 0203
   Serial number: 00006789559728
   Coding: 0100000202000000
   ROD: EV_TrailFunctGener2Hella_VW27.rod
   VCID: 3B23CB35E3E692E3DA0-806E
   Part No SW: 5WA 035 284 E    HW: 5WA 035 284 B
   Component: OCUGen3High   H20 0139
   Serial number: 0000000105VIZCA
   Coding: 022160001968A8009005460161002607
   ASAM Dataset: EV_OCUGen3High 003007
   ROD: EV_OCUGen3High_003_VW27.rod
   VCID: 48C9A4F9A230C97B472-801C
   Part No SW: 2Q0 980 653 B    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H14 1202
   Serial number: E78901611211520
   Coding: 0000089011504020409E00000000000000018000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
   VCID: 3431E009CEB85D9B1BA-8060
End----(Elapsed Time: 00:54, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
Adap-map 09
;SW:2Q0-937-089-C   HW:2Q0-937-089-C ---  Cent. Elect.
;Component:BCM A0 Std    H11 0943, Coding:
;EV_BCMA0,206001,EV_BCMA0_206.rod
;Friday,04,March,2022,14:23:33:13091
;VCDS Version: Release 22.3.0 (x64)  Data version: 20220225 DS336.1
;VCID: 3A2DCE31ECDCABEBC16-806E
IDE00001-ENG130235-Production mode-Entry_control,not_active ,3
IDE00001-ENG115730-Production mode-Exterior lighting,not_active ,3
IDE00001-ENG112304-Production mode-Heckwischer,not_active ,3
IDE00001-ENG98647-Production mode-Interior lights,not_active ,3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung,not_active ,3
IDE00001-ENG130231-Production mode-Window_regulator_nr_1,not_active ,3
IDE00001-ENG130232-Production mode-Window_reversing_threshold,not_active ,3
IDE00002-Transport mode,active ,4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,DELAY ,5
IDE02269-ENG149191-Acknowledgement signals-Akustische_Rueckmeldung_entriegeln,not active ,5
IDE02269-ENG149190-Acknowledgement signals-Akustische_Rueckmeldung_global,not active ,5
IDE02269-ENG149195-Acknowledgement signals-Akustische_Rueckmeldung_Signalhorn,not active ,5
IDE02269-ENG149192-Acknowledgement signals-Akustische_Rueckmeldung_verriegeln,not active ,5
IDE02269-ENG149194-Acknowledgement signals-Dauer_der_Akustischen_Rueckmeldung_vom_Einfachhorn,normal ,5
IDE02269-ENG149193-Acknowledgement signals-Menuesteuerung_akustische_Rueckmeldung,not active ,5
IDE02269-ENG149189-Acknowledgement signals-Optische_Rueckmeldung_3.Bremsleuchte,not active ,5
IDE02269-ENG149188-Acknowledgement signals-Optische_Rueckmeldung_Komfortschliessen,active ,5
IDE02269-ENG130230-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Auf_Befehl,not active ,5
IDE02269-ENG130229-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Zu_Befehl,not active ,5
IDE02711-ENG149246-Rear wiper-Automatisches_Heckwischen,not active ,8
IDE02711-ENG112304-Rear wiper-Heckwischer,Keine_Spannungsanforderung ,8
IDE02711-ENG149248-Rear wiper-Heckwischer_Weiterlauf,not active ,8
IDE02711-ENG115850-Rear wiper-Komfortwischen_Heck,active ,8
IDE02711-ENG149251-Rear wiper-Komfortwischen_Heck_Intervallpausenzeit_Stufe_1,5 s,8
IDE02711-ENG149252-Rear wiper-Komfortwischen_Heck_Intervallpausenzeit_Stufe_2,3 s,8
IDE02711-ENG149250-Rear wiper-Komofortwischen_Heck_Intervallpausenzeit_Stufe_Automatik,7 s,8
IDE02711-ENG149249-Rear wiper-Komofortwischen_Heck_Intervallpausenzeit_Stufe_Intervall,7 s,8
IDE02711-ENG149245-Rear wiper-Menuesteuerung_Komfortwischen_HW,active ,8
IDE02711-ENG148996-Rear wiper-rear_window_wiper,nur Komfortwischen ,8
IDE02711-ENG149247-Rear wiper-Traenenwischen_Heck,active ,8
IDE02711-ENG154831-Rear wiper-Zeit_wasch_min_heck,0 ms,8
IDE02957-ENG154500-Ambient lighting-Ambience_borders_front,not installed ,8
IDE02957-ENG133384-Ambient lighting-Ambient_Farbliste_HMI,not active ,8
IDE02957-ENG154513-Ambient lighting-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,not active ,8
IDE02957-ENG154514-Ambient lighting-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,not active ,8
IDE02957-ENG149168-Ambient lighting-Ambientelicht_mit_raste_heckdeckel,Enabled ,8
IDE02957-ENG126836-Ambient lighting-Ambientemenue mit alle Zonen,not active ,8
IDE02957-ENG126835-Ambient lighting-Ambientemenue mit globalem aus,not active ,8
IDE02957-ENG154907-Ambient lighting-Applikationsleisten_Tuer,not installed ,8
IDE02957-ENG154995-Ambient lighting-Cupholderbeleuchtung,not installed ,8
IDE02957-ENG125648-Ambient lighting-Dachbeleuchtung,not installed ,8
IDE02957-ENG125029-Ambient lighting-Defaultwert Ambienteprofil Farbe,Cold white ,8
IDE02957-ENG149163-Ambient lighting-Defaultwert_Ambienteprofil_Fussraum,0 %,8
IDE02957-ENG149164-Ambient lighting-Defaultwert_Ambienteprofil_Tuer,0 %,8
IDE02957-ENG149165-Ambient lighting-Defaultwert_Ambienteprofil_Vorn,0 %,8
IDE02957-ENG125651-Ambient lighting-Farbwahl ueber Fahrprofil,not installed ,8
IDE02957-ENG125650-Ambient lighting-Farbwahl ueber HMI,not installed ,8
IDE02957-ENG114629-Ambient lighting-Footwell lighting,not installed ,8
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled ,8
IDE02957-ENG155264-Ambient lighting-Lautsprecherbeleuchtung,not installed ,8
IDE02957-ENG125647-Ambient lighting-Mittelkonsolenbeleuchtung,not installed ,8
IDE02957-ENG125649-Ambient lighting-Panoramaschiebedachbeleuchtung,not installed ,8
IDE02957-ENG149167-Ambient lighting-Tuerinnengriff_mit_Tuertafel,not installed ,8
IDE02957-ENG149166-Ambient lighting-Tuerinnengriffbeleuchtung_mit_I-Tafel,not installed ,8
IDE03638-IDE04231-Stationary cornering lamp-Steering wheel angle: offset,0.0 °,16
IDE03638-ENG116677-Stationary cornering lamp-Abdimmgeschwindigkeit,20.0 %/s,16
IDE03638-ENG149111-Stationary cornering lamp-bei_Rueckwaertsfahrt,both sides ,16
IDE03638-ENG116682-Stationary cornering lamp-Maximaltemperatur,120.0 °C,16
IDE03638-ENG149114-Stationary cornering lamp-Obere_Geschwindigkeitsschwelle,40.0 km/h,16
IDE03638-ENG149117-Stationary cornering lamp-obere_Grenztemperatur,100.0 °C,16
IDE03638-ENG149116-Stationary cornering lamp-Oberer_Lenkradwinkel,120 °,16
IDE03638-ENG149113-Stationary cornering lamp-Untere_Geschwindigkeitsschwelle,0.0 km/h,16
IDE03638-ENG149118-Stationary cornering lamp-untere_Grenztemperatur,80.0 °C,16
IDE03638-ENG149115-Stationary cornering lamp-Unterer_Lenkradwinkel,80 °,16
IDE03638-ENG116674-Stationary cornering lamp-Vorschrift,ECE_R119 ,16
IDE03638-ENG149112-Stationary cornering lamp-Zeitwert_Einschaltzeit_Abbiegelicht,15 min,16
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,9
IDE04927-MAS01535-Window heater-Rear window defogger,installed ,9
IDE04927-MAS01564-Window heater-Front windshield heater,not installed ,9
IDE04927-ENG142182-Window heater-Abschalttemperatur_fuer_Frontscheibenheizung,35.0 °C,9
IDE04927-ENG142181-Window heater-Abschalttemperatur_fuer_Heckscheibenheizung,35.0 °C,9
IDE04927-ENG126613-Window heater-Aussenspiegelheizung,600 s,9
IDE04927-ENG142180-Window heater-Heckscheibenheizung_Zeitwert,320 s,9
IDE04927-ENG142179-Window heater-Temperaturabhaengige_Einschaltzeit_FSH,active ,9
IDE04927-ENG142178-Window heater-Temperaturabhaengige_Einschaltzeit_HSH,active ,9
IDE05145-Light configuration,0C 34 00 14 02 00 64 00 00 00 00 00 00 00 00 00 0C 3E 00 15 04 00 64 00 00 00 00 00 00 00 00 00 2D 35 00 26 08 09 7F 00 00 00 00 00 00 00 00 00 2D 3F 00 27 08 0A 7F 00 00 00 00 00 00 00 00 00 2D 3A 00 20 14 00 7F 12 00 80 00 00 00 00 00 00 2D 44 00 21 14 00 7F 13 00 80 00 00 00 00 00 00 0B 36 00 1A 0B 1E 64 00 00 00 00 00 00 00 00 00 0B 40 00 1B 0C 1E 64 00 00 00 00 00 00 00 00 00 17 37 00 1C 0D 0F 64 00 00 00 00 00 00 00 00 00 17 41 00 1D 0E 0F 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,208
IDE05548-ENG149125-Additional interior light-Signal_mapping_ambient_lighting_doors_lin,0 ,38
IDE05548-ENG149126-Additional interior light-Signal_mapping_door_handle_lighting_lin,0 ,38
IDE05548-ENG149127-Additional interior light-Signal_mapping_puddle_light_lin,puddle light ,38
IDE06089-ENG149261-Seat heater level current consumption allocation-Art_der_Sitzheizungsregelung,Time-controlled ,36
IDE06089-ENG155386-Seat heater level current consumption allocation-Not_networked_seat_heater_rearseats,not connected ,36
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN,not installed ,36
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,36
IDE06089-ENG149262-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 1,0 %,36
IDE06089-ENG149263-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 2,20 %,36
IDE06089-ENG149264-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 3,0 %,36
IDE06089-ENG149265-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 4,100 %,36
IDE06089-ENG149266-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 5,0 %,36
IDE06089-ENG149267-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 6,100 %,36
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.05 ,36
IDE06089-ENG149271-Seat heater level current consumption allocation-Sitzheizung Stufe 0 Ansteuerzeit,2 min,36
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,24.00 °C,36
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,22.00 °C,36
IDE06089-ENG149269-Seat heater level current consumption allocation-Sitzheizung Stufe 4 Ansteuerzeit,15 min,36
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,32.00 °C,36
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,30.00 °C,36
IDE06089-ENG149268-Seat heater level current consumption allocation-Sitzheizung Stufe 6 Ansteuerzeit,15 min,36
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,40.00 °C,36
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,38.00 °C,36
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Sollspannungsanforderung 14.7 ,36
IDE06089-ENG155904-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase LO,Keine_Spannungsanforderung ,36
IDE06096-ENG149157-Interior lights-Innenlicht_bei_offenem_Heckdeckel_einschalten,active ,8
IDE06096-ENG98648-Interior lights-Interior lighting,Keine_Spannungsanforderung ,8
IDE08786-MAS10528-Assistance light functions-Rain light sensor,brightness_sensor ,9
IDE08786-MAS10545-Assistance light functions-Humidity sensor,not installed ,9
IDE08786-MAS13782-Assistance light functions-Will Beam assistant: responsivity adjustable via BAP,not active ,9
IDE08786-ENG149124-Assistance light functions-AFL_Zeitverzoegerung,0 ms,9
IDE08786-ENG149123-Assistance light functions-Assistenzfahrlicht_bei_Regen,not active ,9
IDE08786-ENG124476-Assistance light functions-Sunlight photo sensor,not installed ,9
IDE10286-ENG130228-Configuration of light collective diagnostic line 1: instance 1-Defektbit,0 °,7
IDE10286-ENG127071-Configuration of light collective diagnostic line 1: instance 1-DTCDFCC,0 °,7
IDE10286-ENG130193-Configuration of light collective diagnostic line 1: instance 1-Leuchte_0,not active ,7
IDE10286-ENG130194-Configuration of light collective diagnostic line 1: instance 1-Leuchte_1,not active ,7
IDE10286-ENG130203-Configuration of light collective diagnostic line 1: instance 1-Leuchte_10,not active ,7
IDE10286-ENG130204-Configuration of light collective diagnostic line 1: instance 1-Leuchte_11,not active ,7
IDE10286-ENG130205-Configuration of light collective diagnostic line 1: instance 1-Leuchte_12,not active ,7
IDE10286-ENG130206-Configuration of light collective diagnostic line 1: instance 1-Leuchte_13,not active ,7
IDE10286-ENG130207-Configuration of light collective diagnostic line 1: instance 1-Leuchte_14,not active ,7
IDE10286-ENG130208-Configuration of light collective diagnostic line 1: instance 1-Leuchte_15,not active ,7
IDE10286-ENG130209-Configuration of light collective diagnostic line 1: instance 1-Leuchte_16,not active ,7
IDE10286-ENG130210-Configuration of light collective diagnostic line 1: instance 1-Leuchte_17,not active ,7
IDE10286-ENG130211-Configuration of light collective diagnostic line 1: instance 1-Leuchte_18,not active ,7
IDE10286-ENG130212-Configuration of light collective diagnostic line 1: instance 1-Leuchte_19,not active ,7
IDE10286-ENG130195-Configuration of light collective diagnostic line 1: instance 1-Leuchte_2,not active ,7
IDE10286-ENG130213-Configuration of light collective diagnostic line 1: instance 1-Leuchte_20,not active ,7
IDE10286-ENG130214-Configuration of light collective diagnostic line 1: instance 1-Leuchte_21,not active ,7
IDE10286-ENG130215-Configuration of light collective diagnostic line 1: instance 1-Leuchte_22,not active ,7
IDE10286-ENG130216-Configuration of light collective diagnostic line 1: instance 1-Leuchte_23,not active ,7
IDE10286-ENG130217-Configuration of light collective diagnostic line 1: instance 1-Leuchte_24,not active ,7
IDE10286-ENG130218-Configuration of light collective diagnostic line 1: instance 1-Leuchte_25,not active ,7
IDE10286-ENG130219-Configuration of light collective diagnostic line 1: instance 1-Leuchte_26,not active ,7
IDE10286-ENG130220-Configuration of light collective diagnostic line 1: instance 1-Leuchte_27,not active ,7
IDE10286-ENG130221-Configuration of light collective diagnostic line 1: instance 1-Leuchte_28,not active ,7
IDE10286-ENG130222-Configuration of light collective diagnostic line 1: instance 1-Leuchte_29,not active ,7
IDE10286-ENG130196-Configuration of light collective diagnostic line 1: instance 1-Leuchte_3,not active ,7
IDE10286-ENG130223-Configuration of light collective diagnostic line 1: instance 1-Leuchte_30,not active ,7
IDE10286-ENG130224-Configuration of light collective diagnostic line 1: instance 1-Leuchte_31,not active ,7
IDE10286-ENG130225-Configuration of light collective diagnostic line 1: instance 1-Leuchte_32,not active ,7
IDE10286-ENG130226-Configuration of light collective diagnostic line 1: instance 1-Leuchte_33,not active ,7
IDE10286-ENG130227-Configuration of light collective diagnostic line 1: instance 1-Leuchte_34,not active ,7
IDE10286-ENG130197-Configuration of light collective diagnostic line 1: instance 1-Leuchte_4,not active ,7
IDE10286-ENG130198-Configuration of light collective diagnostic line 1: instance 1-Leuchte_5,not active ,7
IDE10286-ENG130199-Configuration of light collective diagnostic line 1: instance 1-Leuchte_6,not active ,7
IDE10286-ENG130200-Configuration of light collective diagnostic line 1: instance 1-Leuchte_7,not active ,7
IDE10286-ENG130201-Configuration of light collective diagnostic line 1: instance 1-Leuchte_8,not active ,7
IDE10286-ENG130202-Configuration of light collective diagnostic line 1: instance 1-Leuchte_9,not active ,7
IDE10286-ENG127072-Configuration of light collective diagnostic line 1: instance 1-Wiederstand,0_Ohm ,7
IDE10288-ENG130228-Configuration of light collective diagnostic line 2: instance 1-Defektbit,0 °,7
IDE10288-ENG127071-Configuration of light collective diagnostic line 2: instance 1-DTCDFCC,0 °,7
IDE10288-ENG130193-Configuration of light collective diagnostic line 2: instance 1-Leuchte_0,not active ,7
IDE10288-ENG130194-Configuration of light collective diagnostic line 2: instance 1-Leuchte_1,not active ,7
IDE10288-ENG130203-Configuration of light collective diagnostic line 2: instance 1-Leuchte_10,not active ,7
IDE10288-ENG130204-Configuration of light collective diagnostic line 2: instance 1-Leuchte_11,not active ,7
IDE10288-ENG130205-Configuration of light collective diagnostic line 2: instance 1-Leuchte_12,not active ,7
IDE10288-ENG130206-Configuration of light collective diagnostic line 2: instance 1-Leuchte_13,not active ,7
IDE10288-ENG130207-Configuration of light collective diagnostic line 2: instance 1-Leuchte_14,not active ,7
IDE10288-ENG130208-Configuration of light collective diagnostic line 2: instance 1-Leuchte_15,not active ,7
IDE10288-ENG130209-Configuration of light collective diagnostic line 2: instance 1-Leuchte_16,not active ,7
IDE10288-ENG130210-Configuration of light collective diagnostic line 2: instance 1-Leuchte_17,not active ,7
IDE10288-ENG130211-Configuration of light collective diagnostic line 2: instance 1-Leuchte_18,not active ,7
IDE10288-ENG130212-Configuration of light collective diagnostic line 2: instance 1-Leuchte_19,not active ,7
IDE10288-ENG130195-Configuration of light collective diagnostic line 2: instance 1-Leuchte_2,not active ,7
IDE10288-ENG130213-Configuration of light collective diagnostic line 2: instance 1-Leuchte_20,not active ,7
IDE10288-ENG130214-Configuration of light collective diagnostic line 2: instance 1-Leuchte_21,not active ,7
IDE10288-ENG130215-Configuration of light collective diagnostic line 2: instance 1-Leuchte_22,not active ,7
IDE10288-ENG130216-Configuration of light collective diagnostic line 2: instance 1-Leuchte_23,not active ,7
IDE10288-ENG130217-Configuration of light collective diagnostic line 2: instance 1-Leuchte_24,not active ,7
IDE10288-ENG130218-Configuration of light collective diagnostic line 2: instance 1-Leuchte_25,not active ,7
IDE10288-ENG130219-Configuration of light collective diagnostic line 2: instance 1-Leuchte_26,not active ,7
IDE10288-ENG130220-Configuration of light collective diagnostic line 2: instance 1-Leuchte_27,not active ,7
IDE10288-ENG130221-Configuration of light collective diagnostic line 2: instance 1-Leuchte_28,not active ,7
IDE10288-ENG130222-Configuration of light collective diagnostic line 2: instance 1-Leuchte_29,not active ,7
IDE10288-ENG130196-Configuration of light collective diagnostic line 2: instance 1-Leuchte_3,not active ,7
IDE10288-ENG130223-Configuration of light collective diagnostic line 2: instance 1-Leuchte_30,not active ,7
IDE10288-ENG130224-Configuration of light collective diagnostic line 2: instance 1-Leuchte_31,not active ,7
IDE10288-ENG130225-Configuration of light collective diagnostic line 2: instance 1-Leuchte_32,not active ,7
IDE10288-ENG130226-Configuration of light collective diagnostic line 2: instance 1-Leuchte_33,not active ,7
IDE10288-ENG130227-Configuration of light collective diagnostic line 2: instance 1-Leuchte_34,not active ,7
IDE10288-ENG130197-Configuration of light collective diagnostic line 2: instance 1-Leuchte_4,not active ,7
IDE10288-ENG130198-Configuration of light collective diagnostic line 2: instance 1-Leuchte_5,not active ,7
IDE10288-ENG130199-Configuration of light collective diagnostic line 2: instance 1-Leuchte_6,not active ,7
IDE10288-ENG130200-Configuration of light collective diagnostic line 2: instance 1-Leuchte_7,not active ,7
IDE10288-ENG130201-Configuration of light collective diagnostic line 2: instance 1-Leuchte_8,not active ,7
IDE10288-ENG130202-Configuration of light collective diagnostic line 2: instance 1-Leuchte_9,not active ,7
IDE10288-ENG127072-Configuration of light collective diagnostic line 2: instance 1-Wiederstand,0_Ohm ,7
IDE11421-ENG116719-Leaving concept-Bedingungen zur Beendigung des Standlichtnachlaufs,not active ,6
IDE11421-ENG116720-Leaving concept-Standlicht-Nachlaufzeit,30 min,6
IDE11421-ENG179280-Leaving concept-VLK_Deaktivierung_der_Diagnose,not active ,6
IDE11421-ENG126843-Leaving concept-ZV verriegeln bei Klemme 15 Ein,not active ,6
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI,00000000  ,3
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00000000  ,3
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,00000000  ,3
IDE11944-MAS10510-Keyless access and start authorization-Kessy,not installed ,5
IDE11944-ENG174170-Keyless access and start authorization-central_locking_system_selective_sigle_door_kessy_NAR,not active ,5
IDE11944-ENG179141-Keyless access and start authorization-Kessy Bewegungsüberwachung IDGeber,not active ,5
IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit,not active ,5
IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit,not active ,5
IDE11944-ENG149273-Keyless access and start authorization-Kessy_Komfort_oeffnen,not active ,5
IDE11944-ENG149274-Keyless access and start authorization-Kessy_Komfort_schliessen,active ,5
IDE11944-ENG149275-Keyless access and start authorization-Oeffnung_Heckdeckel_bei_Wiederentriegelung,active ,5
IDE11944-ENG149000-Keyless access and start authorization-Steering_wheel_locking_system,not installed ,5
MAS01490-IDE08581-Energy management-Recuperation,active ,5
MAS01490-MAS12921-Energy management-Predictive energy management,not active ,5
MAS01490-ENG149047-Energy management-Eingriff_durch_Energiemanagement,active ,5
MAS01490-ENG98636-Energy management-Hybrid,No ,5
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,2000 lx,24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 32 ,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,4000 lx,24
MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rain,active ,24
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity,NOT-DEFINED ,24
MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF,active ,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,4300 mV,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,1400 mV,24
MAS16372-Security version number,1 ,2
ENG153709-ENG155626-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG_DTC,First_dtc ,9
ENG148492-MAS01577-Anti-theft protection-Parking heater,not installed ,5
ENG148492-ENG149232-Anti-theft protection-Akustischer_Alarm_Signalhorn,not active ,5
ENG148492-ENG115864-Anti-theft protection-Alarmsignal,frequency_modulated ,5
ENG148492-ENG148991-Anti-theft protection-anti_theft_alarm_system,not active ,5
ENG148492-ENG148992-Anti-theft protection-anti_theft_alarm_with_simple_horn,not installed ,5
ENG148492-ENG148993-Anti-theft protection-anti_theft_alarm_without_Thatcham,No ,5
ENG148492-ENG148990-Anti-theft protection-deactivation_button_anti_theft_alarm_sensor,not installed ,5
ENG148492-ENG154590-Anti-theft protection-Deaktivierung_DWA_ueber_MMI,not active ,5
ENG148492-ENG123016-Anti-theft protection-Diebstahlschutz_mit_Anhaenger,not active ,5
ENG148492-ENG149229-Anti-theft protection-DWA_Alarmverzoegerung,immidiat_driver_door_contact_thatcham ,5
ENG148492-ENG149230-Anti-theft protection-DWA_Camper_Modus,not active ,5
ENG148492-ENG148994-Anti-theft protection-interior_monitoring_sensor,No ,5
ENG148492-ENG149231-Anti-theft protection-Sirenen_Alarmzahl,10_Alarme ,5
ENG148492-ENG142008-Anti-theft protection-tilt_sensor,No ,5
ENG148492-ENG149228-Anti-theft protection-Verzoegerung_Panikalarm,2_sekunden_verzoegerung ,5
ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinken,active ,5
ENG141649-ENG130187-Außenlicht_Blinker-Blinkkontrolleuchte_fuer_Anhaenger,separte ,5
ENG141649-ENG115774-Außenlicht_Blinker-Komfortblinken,active ,5
ENG141649-ENG115854-Außenlicht_Blinker-Komfortblinken_Blinkzyklen,3 ,5
ENG141647-MAS10529-Außenlicht_Front-Low beam: bulb type,H7 ,9
ENG141647-ENG149099-Außenlicht_Front-Allwetterlicht_Ausschaltgrenze,350 km/h,9
ENG141647-ENG149098-Außenlicht_Front-Allwetterlicht_Einschaltgrenze,350 km/h,9
ENG141647-ENG149106-Außenlicht_Front-Fahrlicht_bei_Tag,Daytime running lamps ,9
ENG141647-ENG149097-Außenlicht_Front-Lichthupe_bei_Zuendung_aus_moeglich,active ,9
ENG141647-ENG126567-Außenlicht_Front-max_scheinwerfer_2limitieren,in_Betrieb_lassen ,9
ENG141647-ENG149100-Außenlicht_Front-Scheinwerferferreinigungsansteuerung_und_Abblendlichtanzeige_bei_Dauerfahrlicht,not active ,9
ENG141647-ENG149103-Außenlicht_Front-Standlicht_aktiviert_zusaetzlich_Tagfahrlicht,active ,9
ENG141647-ENG149101-Außenlicht_Front-Tagfahrlicht_Aktivierung_durch_BAP_oder_Bedienfolge_moeglich,not active ,9
ENG141647-ENG149104-Außenlicht_Front-Tagfahrlicht_Dauerfahrlicht_bei_Handbremse_abschalten,not active ,9
ENG141647-ENG149107-Außenlicht_Front-Tagfahrlicht_nur_in_Schalterstellung_AUTO,not active ,9
ENG141647-ENG149105-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht_aktiviert_zusaetzlich_Standlicht,not active ,9
ENG141647-ENG149102-Außenlicht_Front-Werkseinstellung_fuer_Tagfahrlicht_Freischaltung_BAP_/_Bedienfolge,active ,9
ENG141648-MAS10533-Aussenlicht_Heck-Brake light is turn signal,No ,5
ENG141648-ENG179109-Aussenlicht_Heck-Bremslicht_mit_Schlusslichtfunktion,not active ,5
ENG141648-ENG149110-Aussenlicht_Heck-Nebelschlusslicht_Warngeschwindigkeit,255 km/h,5
ENG141648-ENG115847-Aussenlicht_Heck-Notbremsanzeige_NBA,active ,5
ENG141648-ENG155652-Aussenlicht_Heck-Schlusslicht_mit_Brems_und_Blinklichtfunktion,not active ,5
ENG141648-ENG149109-Aussenlicht_Heck-Schlusslicht_mit_Bremslichtfunktion,not active ,5
ENG141656-MAS10538-Außenlicht_uebergreifend-Light rotary sw. connection,Discrete signal current ,16
ENG141656-MAS10541-Außenlicht_uebergreifend-Light rotary switch with fog light,No ,16
ENG141656-MAS10542-Außenlicht_uebergreifend-Light rotary switch with fog tail light,Yes ,16
ENG141656-MAS10543-Außenlicht_uebergreifend-Light rotary sw. with AFL,Yes ,16
ENG141656-MAS10544-Außenlicht_uebergreifend-Light rotary switch with park. light pos.,Yes ,16
ENG141656-ENG248495-Außenlicht_uebergreifend-ABL_off_ECE48_Rev6,No ,16
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung,Energy management ,16
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung,Energy management ,16
ENG141656-ENG126566-Außenlicht_uebergreifend-beidseitiges_dauerparklicht,active ,16
ENG141656-ENG149092-Außenlicht_uebergreifend-Coming_home_Leuchten,Low beam ,16
ENG141656-ENG149089-Außenlicht_uebergreifend-Coming_Home_Verbaustatus,manual ,16
ENG141656-ENG149093-Außenlicht_uebergreifend-Coming-home_Einschaltereignis,ignition ,16
ENG141656-ENG248654-Außenlicht_uebergreifend-ECE48_Rev6_aktiv,not active ,16
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,active ,16
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig,not_active ,16
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten ,16
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH,Keine_Spannungsanforderung ,16
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog lamp,Keine_Spannungsanforderung ,16
ENG141656-ENG149096-Außenlicht_uebergreifend-Helligkeitsschwelle_Forward-Messung,116 ,16
ENG141656-ENG149094-Außenlicht_uebergreifend-Helligkeitsschwelle_Infrarot-Messung,72 ,16
ENG141656-ENG155156-Außenlicht_uebergreifend-keine_LCM_blinker,false ,16
ENG141656-ENG149086-Außenlicht_uebergreifend-Kontrollleuchte_fuer_Begrenzungslicht,integriert_in_Suchbeleuchtung ,16
ENG141656-ENG149095-Außenlicht_uebergreifend-Leaving-Home_Verbausstatus,Enabled ,16
ENG141656-ENG126569-Außenlicht_uebergreifend-lho_aktiviert,active ,16
ENG141656-ENG126570-Außenlicht_uebergreifend-lho_zeit,30 seconds ,16
ENG141656-ENG149005-Außenlicht_uebergreifend-Lichtdrehschalter_mit_Nebellicht_bei_Assistenzfahrlicht,Yes ,16
ENG141656-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten,klemmenabhaengig ,16
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module,not installed ,16
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam,Keine_Spannungsanforderung ,16
ENG141656-ENG149088-Außenlicht_uebergreifend-Menueeinstellung_CHO_LHO,Menuesteuerung_Zeit_aktivieren ,16
ENG141656-ENG149091-Außenlicht_uebergreifend-Menueeinstellung_Cominghome,30 seconds ,16
ENG141656-ENG149090-Außenlicht_uebergreifend-Menuesteuerung_Coming_Home_Werkseinstellung,active ,16
ENG141656-ENG149087-Außenlicht_uebergreifend-Parklicht_ueber_LSS_aktiviert,One-sided ,16
ENG141656-ENG126565-Außenlicht_uebergreifend-standlicht_aus_bei_kl_s_aus_s_kontakt,active ,16
ENG141656-ENG137035-Außenlicht_uebergreifend-Standlicht-Verfuegbarkeit,24 s,16
ENG141656-ENG248823-Außenlicht_uebergreifend-TFL_off_ECE48_Rev6,No ,16
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal lamp,Keine_Spannungsanforderung ,16
ENG148494-MAS10534-Background lighting-Input medium: search illumination,HMI ,21
ENG148494-ENG142240-Background lighting-Daempfung Abdimmen KL 58xd PWM,0.00 s,21
ENG148494-ENG154582-Background lighting-Daempfung_Abdimmen_KL_58xs_PWM,0.00 s,21
ENG148494-ENG154583-Background lighting-Daempfung_Abdimmen_KL_58xt_PWM,0.00 s,21
ENG148494-ENG154584-Background lighting-Daempfung_Aufdimmen_KL_58xd_PWM,0.00 s,21
ENG148494-ENG154585-Background lighting-Daempfung_Aufdimmen_KL_58xt_PWM,0.00 s,21
ENG148494-ENG179120-Background lighting-Daempfung_Aufdimmen_KL58xs_PWM,0.00 s,21
ENG148494-ENG142242-Background lighting-Helligkeit_RLS_Daempfung_Abdimmen,1.1 s,21
ENG148494-ENG142241-Background lighting-Helligkeit_RLS_Daempfung_Aufdimmen,0.0 s,21
ENG148494-ENG149159-Background lighting-KL58_Einschalten_mit_Rampe,not active ,21
ENG148494-ENG149160-Background lighting-KL58_Verriegelungsausschalten,not_active ,21
ENG148494-ENG149161-Background lighting-Lichtsensor_wirkt_auf_Suchbeleuchtung,active ,21
ENG148494-ENG149162-Background lighting-Suchbeleuchtung_Festwert,100 %,21
ENG148494-ENG142234-Background lighting-Umgebungs_helligkeit_auswahl,Fotosensor_Kombi ,21
ENG148494-ENG130188-Background lighting-Warnblinktastersuchbeleuchtung_Aktivierung,always_active ,21
ENG148494-ENG130190-Background lighting-Warnblinktastersuchbeleuchtung_Faktor,0.100 ,21
ENG148494-ENG130189-Background lighting-Warnblinktastersuchbeleuchtung_Grundwert,6.0 %,21
ENG248426-ENG252093-Elektronische_Rückwandklappe-eRWK_Abbruchblinken_Heck,not active ,9
ENG248426-ENG248659-Elektronische_Rückwandklappe-eRWK_Abstand_Umfeld_frei,120 cm,9
ENG248426-ENG248660-Elektronische_Rückwandklappe-eRWK_Abstand_Umfeld_Nahbereich,20 cm,9
ENG248426-ENG248661-Elektronische_Rückwandklappe-eRWK_bei_eingeschraenkter_Oeffnungsweite,not active ,9
ENG248426-ENG248662-Elektronische_Rückwandklappe-eRWK_Heck_sperren_bei_Hindernis,not active ,9
ENG248426-ENG248663-Elektronische_Rückwandklappe-eRWK_Oeffnungsblinken_Heck,not active ,9
ENG248426-ENG248664-Elektronische_Rückwandklappe-eRWK_ohne_FFB_HDF,not active ,9
ENG248426-ENG252079-Elektronische_Rückwandklappe-eRWK_Pruefung_Umfelderkennung,1.6 s,9
ENG248426-ENG252068-Elektronische_Rückwandklappe-eRWK_Start_Umfelderkennung,2.0 s,9
ENG148609-ENG148997-Fahrerinformation-Cockpit_button_1,installed ,5
ENG148609-ENG148998-Fahrerinformation-Cockpit_button_2,not installed ,5
ENG148609-ENG148999-Fahrerinformation-Cockpit_button_3,not installed ,5
ENG148609-ENG149003-Fahrerinformation-Cockpit_button_4,not installed ,5
ENG141650-MAS10514-Fernlicht_assistent-Expanded high beam control,Halogen ,6
ENG141650-ENG149120-Fernlicht_assistent-Fernlichtassistent_Reset,active ,6
ENG141650-ENG149122-Fernlicht_assistent-Fernlichtassistent_Zeitverzoegerungswert,800 ms,6
ENG141650-ENG149119-Fernlicht_assistent-Menuesteuerung_Fernlichtassistent,present ,6
ENG141650-ENG149121-Fernlicht_assistent-Menuesteuerung_Fernlichtassistent_Werkseinstellung,present ,6
ENG248411-ENG248631-Front doors-cockpittaster2_funktion,not active ,1
ENG248411-ENG252063-Front doors-Deaktivierung_LS_mit_ext_Ver_Entriegelung,not active ,1
ENG248411-ENG248723-Front doors-Laderaumschließung Taster togglen,not active ,1
ENG248411-ENG248768-Front doors-NFZ_Schliessung,not active ,1
ENG248411-ENG248784-Front doors-pa_Schlosstyp_vorne,Einmotorenschloss ,1
ENG248411-ENG133390-Front doors-Wiederverriegelung_Laderaum,not installed ,1
ENG248444-ENG248688-Global-Freischaltung_der_Kisi_Auswurffunktion,No ,1
ENG248444-ENG248689-Global-Freischaltung_KiSi_Taster_bei_extern_verriegeltem_Fahrzeug,No ,1
ENG248444-ENG248691-Global-Funktion_SAFE,No ,1
ENG248444-ENG248774-Global-pa_eKiSi,No ,1
ENG248444-ENG248776-Global-pa_FFb_Sbt_Tausch_Seite,No ,1
ENG248444-ENG248809-Global-Schiebetuer_Auswurffunkion_bei_intern_verriegelt_aktiv,No ,1
ENG248444-ENG248810-Global-Schiebetuertaste_Armaturentafel_bei_extern_verriegelt_aktiv,No ,1
ENG248445-ENG248698-Heckklappe: Türen-HD_Innentaster_im_Heck,not installed ,1
ENG248445-ENG248782-Heckklappe: Türen-pa_Schlosstyp_Heck,Federsteller ,1
ENG248445-ENG248787-Heckklappe: Türen-pa_Typ_Heck,Klappe ,1
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid,not installed ,8
ENG141645-MAS06495-HW_Verbau-Engine hood contact switch,installed ,8
ENG141645-MAS10521-HW_Verbau-Exterior temp. sensor,installed ,8
ENG141645-ENG126574-HW_Verbau-auspraegung_Bremsfluessigkeitsschalter,Open ,8
ENG141645-ENG115848-HW_Verbau-Signalhorn_ohne_KL15,active ,8
ENG141645-ENG149002-HW_Verbau-Signalhorn_ueber_LIN,horn_via_LIN ,8
ENG141645-ENG142011-HW_Verbau-trunk_lid_conrol_unit,not installed ,8
ENG148603-ENG115658-Innen_beleuchtung_KL58_xd_max-x0,0 lx,10
ENG148603-ENG101574-Innen_beleuchtung_KL58_xd_max-X1,8 lx,10
ENG148603-ENG99557-Innen_beleuchtung_KL58_xd_max-X2,200 lx,10
ENG148603-ENG102140-Innen_beleuchtung_KL58_xd_max-X3,300 lx,10
ENG148603-ENG102936-Innen_beleuchtung_KL58_xd_max-X4,500 lx,10
ENG148603-ENG115659-Innen_beleuchtung_KL58_xd_max-y0,16.0 ,10
ENG148603-ENG99777-Innen_beleuchtung_KL58_xd_max-Y1,16.0 ,10
ENG148603-ENG100480-Innen_beleuchtung_KL58_xd_max-Y2,100.0 ,10
ENG148603-ENG100773-Innen_beleuchtung_KL58_xd_max-Y3,100.0 ,10
ENG148603-ENG100631-Innen_beleuchtung_KL58_xd_max-Y4,100.0 ,10
ENG148602-ENG115658-Innen_beleuchtung_KL58_xd_min-x0,0 lx,10
ENG148602-ENG101574-Innen_beleuchtung_KL58_xd_min-X1,8 lx,10
ENG148602-ENG99557-Innen_beleuchtung_KL58_xd_min-X2,220 lx,10
ENG148602-ENG102140-Innen_beleuchtung_KL58_xd_min-X3,300 lx,10
ENG148602-ENG102936-Innen_beleuchtung_KL58_xd_min-X4,500 lx,10
ENG148602-ENG115659-Innen_beleuchtung_KL58_xd_min-y0,6.0 ,10
ENG148602-ENG99777-Innen_beleuchtung_KL58_xd_min-Y1,6.0 ,10
ENG148602-ENG100480-Innen_beleuchtung_KL58_xd_min-Y2,100.0 ,10
ENG148602-ENG100773-Innen_beleuchtung_KL58_xd_min-Y3,100.0 ,10
ENG148602-ENG100631-Innen_beleuchtung_KL58_xd_min-Y4,100.0 ,10
ENG148607-ENG115658-Innen_beleuchtung_KL58_xd_PWM-x0,0 ,12
ENG148607-ENG101574-Innen_beleuchtung_KL58_xd_PWM-X1,10 ,12
ENG148607-ENG99557-Innen_beleuchtung_KL58_xd_PWM-X2,100 ,12
ENG148607-ENG102140-Innen_beleuchtung_KL58_xd_PWM-X3,150 ,12
ENG148607-ENG102936-Innen_beleuchtung_KL58_xd_PWM-X4,220 ,12
ENG148607-ENG103548-Innen_beleuchtung_KL58_xd_PWM-X5,253 ,12
ENG148607-ENG115659-Innen_beleuchtung_KL58_xd_PWM-y0,3.0 %,12
ENG148607-ENG99777-Innen_beleuchtung_KL58_xd_PWM-Y1,3.0 %,12
ENG148607-ENG100480-Innen_beleuchtung_KL58_xd_PWM-Y2,11.0 %,12
ENG148607-ENG100773-Innen_beleuchtung_KL58_xd_PWM-Y3,40.0 %,12
ENG148607-ENG100631-Innen_beleuchtung_KL58_xd_PWM-Y4,82.0 %,12
ENG148607-ENG102174-Innen_beleuchtung_KL58_xd_PWM-Y5,100.0 %,12
ENG148599-ENG115658-Innen_beleuchtung_KL58_xs_max-x0,0 lx,8
ENG148599-ENG101574-Innen_beleuchtung_KL58_xs_max-X1,8 lx,8
ENG148599-ENG99557-Innen_beleuchtung_KL58_xs_max-X2,50 lx,8
ENG148599-ENG102140-Innen_beleuchtung_KL58_xs_max-X3,500 lx,8
ENG148599-ENG115659-Innen_beleuchtung_KL58_xs_max-y0,100.0 ,8
ENG148599-ENG99777-Innen_beleuchtung_KL58_xs_max-Y1,100.0 ,8
ENG148599-ENG100480-Innen_beleuchtung_KL58_xs_max-Y2,100.0 ,8
ENG148599-ENG100773-Innen_beleuchtung_KL58_xs_max-Y3,100.0 ,8
ENG148605-ENG115658-Innen_beleuchtung_KL58_xs_PWM-x0,0.0 %,6
ENG148605-ENG101574-Innen_beleuchtung_KL58_xs_PWM-X1,50.0 %,6
ENG148605-ENG99557-Innen_beleuchtung_KL58_xs_PWM-X2,100.0 %,6
ENG148605-ENG115659-Innen_beleuchtung_KL58_xs_PWM-y0,0.0 %,6
ENG148605-ENG99777-Innen_beleuchtung_KL58_xs_PWM-Y1,50.0 %,6
ENG148605-ENG100480-Innen_beleuchtung_KL58_xs_PWM-Y2,100.0 %,6
ENG148601-ENG115658-Innen_beleuchtung_KL58_xt_max-x0,0 lx,8
ENG148601-ENG101574-Innen_beleuchtung_KL58_xt_max-X1,8 lx,8
ENG148601-ENG99557-Innen_beleuchtung_KL58_xt_max-X2,50 lx,8
ENG148601-ENG102140-Innen_beleuchtung_KL58_xt_max-X3,500 lx,8
ENG148601-ENG115659-Innen_beleuchtung_KL58_xt_max-y0,100.0 ,8
ENG148601-ENG99777-Innen_beleuchtung_KL58_xt_max-Y1,100.0 ,8
ENG148601-ENG100480-Innen_beleuchtung_KL58_xt_max-Y2,100.0 ,8
ENG148601-ENG100773-Innen_beleuchtung_KL58_xt_max-Y3,100.0 ,8
ENG148600-ENG115658-Innen_beleuchtung_KL58_xt_min-x0,0 lx,8
ENG148600-ENG101574-Innen_beleuchtung_KL58_xt_min-X1,8 lx,8
ENG148600-ENG99557-Innen_beleuchtung_KL58_xt_min-X2,50 lx,8
ENG148600-ENG102140-Innen_beleuchtung_KL58_xt_min-X3,500 lx,8
ENG148600-ENG115659-Innen_beleuchtung_KL58_xt_min-y0,6.0 ,8
ENG148600-ENG99777-Innen_beleuchtung_KL58_xt_min-Y1,6.0 ,8
ENG148600-ENG100480-Innen_beleuchtung_KL58_xt_min-Y2,100.0 ,8
ENG148600-ENG100773-Innen_beleuchtung_KL58_xt_min-Y3,100.0 ,8
ENG148606-ENG115658-Innen_beleuchtung_KL58_xt_PWM-x0,0.0 %,6
ENG148606-ENG101574-Innen_beleuchtung_KL58_xt_PWM-X1,50.0 %,6
ENG148606-ENG99557-Innen_beleuchtung_KL58_xt_PWM-X2,100.0 %,6
ENG148606-ENG115659-Innen_beleuchtung_KL58_xt_PWM-y0,0.0 %,6
ENG148606-ENG99777-Innen_beleuchtung_KL58_xt_PWM-Y1,50.0 %,6
ENG148606-ENG100480-Innen_beleuchtung_KL58_xt_PWM-Y2,100.0 %,6
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx,8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx,8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx,8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,500 lx,8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.0 ,8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.0 ,8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.0 ,8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.0 ,8
ENG148597-ENG115658-Innenbeleuchtung_Abdimmen-x0,0 ms,22
ENG148597-ENG101574-Innenbeleuchtung_Abdimmen-X1,100 ms,22
ENG148597-ENG115664-Innenbeleuchtung_Abdimmen-x10,1000 ms,22
ENG148597-ENG99557-Innenbeleuchtung_Abdimmen-X2,200 ms,22
ENG148597-ENG102140-Innenbeleuchtung_Abdimmen-X3,300 ms,22
ENG148597-ENG102936-Innenbeleuchtung_Abdimmen-X4,400 ms,22
ENG148597-ENG103548-Innenbeleuchtung_Abdimmen-X5,500 ms,22
ENG148597-ENG113992-Innenbeleuchtung_Abdimmen-X6,600 ms,22
ENG148597-ENG115661-Innenbeleuchtung_Abdimmen-x7,700 ms,22
ENG148597-ENG115662-Innenbeleuchtung_Abdimmen-x8,800 ms,22
ENG148597-ENG115663-Innenbeleuchtung_Abdimmen-x9,900 ms,22
ENG148597-ENG115659-Innenbeleuchtung_Abdimmen-y0,100.0 %,22
ENG148597-ENG99777-Innenbeleuchtung_Abdimmen-Y1,78.0 %,22
ENG148597-ENG115668-Innenbeleuchtung_Abdimmen-y10,0.0 %,22
ENG148597-ENG100480-Innenbeleuchtung_Abdimmen-Y2,59.0 %,22
ENG148597-ENG100773-Innenbeleuchtung_Abdimmen-Y3,44.0 %,22
ENG148597-ENG100631-Innenbeleuchtung_Abdimmen-Y4,33.0 %,22
ENG148597-ENG102174-Innenbeleuchtung_Abdimmen-Y5,24.0 %,22
ENG148597-ENG113993-Innenbeleuchtung_Abdimmen-Y6,17.0 %,22
ENG148597-ENG115665-Innenbeleuchtung_Abdimmen-y7,12.0 %,22
ENG148597-ENG115666-Innenbeleuchtung_Abdimmen-y8,7.0 %,22
ENG148597-ENG115667-Innenbeleuchtung_Abdimmen-y9,3.0 %,22
ENG148598-ENG115658-Innenbeleuchtung_Fotosensor-x0,0 ,22
ENG148598-ENG101574-Innenbeleuchtung_Fotosensor-X1,50 ,22
ENG148598-ENG99557-Innenbeleuchtung_Fotosensor-X2,100 ,22
ENG148598-ENG102140-Innenbeleuchtung_Fotosensor-X3,200 ,22
ENG148598-ENG102936-Innenbeleuchtung_Fotosensor-X4,253 ,22
ENG148598-ENG115659-Innenbeleuchtung_Fotosensor-y0,0 lx,22
ENG148598-ENG99777-Innenbeleuchtung_Fotosensor-Y1,50 lx,22
ENG148598-ENG100480-Innenbeleuchtung_Fotosensor-Y2,100 lx,22
ENG148598-ENG100773-Innenbeleuchtung_Fotosensor-Y3,200 ,22
ENG148598-ENG100631-Innenbeleuchtung_Fotosensor-Y4,500 ,22
ENG148596-ENG115658-Innenbeleuchtung_Hochdimmen-x0,0 ms,22
ENG148596-ENG101574-Innenbeleuchtung_Hochdimmen-X1,100 ms,22
ENG148596-ENG115664-Innenbeleuchtung_Hochdimmen-x10,1000 ms,22
ENG148596-ENG99557-Innenbeleuchtung_Hochdimmen-X2,200 ms,22
ENG148596-ENG102140-Innenbeleuchtung_Hochdimmen-X3,300 ms,22
ENG148596-ENG102936-Innenbeleuchtung_Hochdimmen-X4,400 ms,22
ENG148596-ENG103548-Innenbeleuchtung_Hochdimmen-X5,500 ms,22
ENG148596-ENG113992-Innenbeleuchtung_Hochdimmen-X6,600 ms,22
ENG148596-ENG115661-Innenbeleuchtung_Hochdimmen-x7,700 ms,22
ENG148596-ENG115662-Innenbeleuchtung_Hochdimmen-x8,800 ms,22
ENG148596-ENG115663-Innenbeleuchtung_Hochdimmen-x9,900 ms,22
ENG148596-ENG115659-Innenbeleuchtung_Hochdimmen-y0,0.0 %,22
ENG148596-ENG99777-Innenbeleuchtung_Hochdimmen-Y1,3.0 %,22
ENG148596-ENG115668-Innenbeleuchtung_Hochdimmen-y10,100.0 %,22
ENG148596-ENG100480-Innenbeleuchtung_Hochdimmen-Y2,7.0 %,22
ENG148596-ENG100773-Innenbeleuchtung_Hochdimmen-Y3,12.0 %,22
ENG148596-ENG100631-Innenbeleuchtung_Hochdimmen-Y4,17.0 %,22
ENG148596-ENG102174-Innenbeleuchtung_Hochdimmen-Y5,24.0 %,22
ENG148596-ENG113993-Innenbeleuchtung_Hochdimmen-Y6,33.0 %,22
ENG148596-ENG115665-Innenbeleuchtung_Hochdimmen-y7,44.0 %,22
ENG148596-ENG115666-Innenbeleuchtung_Hochdimmen-y8,59.0 %,22
ENG148596-ENG115667-Innenbeleuchtung_Hochdimmen-y9,78.0 %,22
ENG148604-ENG115658-Innenbeleuchtung_KL58xd_log_Bus-x0,0.0 %,12
ENG148604-ENG101574-Innenbeleuchtung_KL58xd_log_Bus-X1,6.0 %,12
ENG148604-ENG99557-Innenbeleuchtung_KL58xd_log_Bus-X2,16.0 %,12
ENG148604-ENG102140-Innenbeleuchtung_KL58xd_log_Bus-X3,30.0 %,12
ENG148604-ENG102936-Innenbeleuchtung_KL58xd_log_Bus-X4,60.0 %,12
ENG148604-ENG103548-Innenbeleuchtung_KL58xd_log_Bus-X5,100.0 %,12
ENG148604-ENG115659-Innenbeleuchtung_KL58xd_log_Bus-y0,10 ,12
ENG148604-ENG99777-Innenbeleuchtung_KL58xd_log_Bus-Y1,10 ,12
ENG148604-ENG100480-Innenbeleuchtung_KL58xd_log_Bus-Y2,100 ,12
ENG148604-ENG100773-Innenbeleuchtung_KL58xd_log_Bus-Y3,150 ,12
ENG148604-ENG100631-Innenbeleuchtung_KL58xd_log_Bus-Y4,220 ,12
ENG148604-ENG102174-Innenbeleuchtung_KL58xd_log_Bus-Y5,253 ,12
ENG148595-ENG149169-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x0,0 ms,10
ENG148595-ENG149170-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x1,2000 ms,10
ENG148595-ENG149171-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x2,3000 ms,10
ENG148595-ENG149172-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x3,4000 ms,10
ENG148595-ENG149173-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x4,5100 ms,10
ENG148595-ENG149174-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y0,1.0 %,10
ENG148595-ENG149175-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y1,5.0 ,10
ENG148595-ENG149176-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y2,15.0 ,10
ENG148595-ENG149177-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y3,40.0 ,10
ENG148595-ENG149178-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y4,100.0 ,10
ENG248447-ENG248714-Inszenierung CHoLHo-Inszenierung CHo/LHo Aktivieren,not active ,36
ENG248447-ENG115658-Inszenierung CHoLHo-x0,0 ms,36
ENG248447-ENG101574-Inszenierung CHoLHo-X1,200 ms,36
ENG248447-ENG115664-Inszenierung CHoLHo-x10,2000 ms,36
ENG248447-ENG248838-Inszenierung CHoLHo-x11,200 ms,36
ENG248447-ENG248839-Inszenierung CHoLHo-x12,400 ms,36
ENG248447-ENG248840-Inszenierung CHoLHo-x13,600 ms,36
ENG248447-ENG248841-Inszenierung CHoLHo-x14,800 ms,36
ENG248447-ENG248842-Inszenierung CHoLHo-x15,1000 ms,36
ENG248447-ENG99557-Inszenierung CHoLHo-X2,400 ms,36
ENG248447-ENG102140-Inszenierung CHoLHo-X3,600 ms,36
ENG248447-ENG102936-Inszenierung CHoLHo-X4,800 ms,36
ENG248447-ENG103548-Inszenierung CHoLHo-X5,1000 ms,36
ENG248447-ENG113992-Inszenierung CHoLHo-X6,1200 ms,36
ENG248447-ENG115661-Inszenierung CHoLHo-x7,1400 ms,36
ENG248447-ENG115662-Inszenierung CHoLHo-x8,1600 ms,36
ENG248447-ENG115663-Inszenierung CHoLHo-x9,1800 ms,36
ENG248447-ENG115659-Inszenierung CHoLHo-y0,0.0 %,36
ENG248447-ENG99777-Inszenierung CHoLHo-Y1,3.0 %,36
ENG248447-ENG115668-Inszenierung CHoLHo-y10,100.0 %,36
ENG248447-ENG136987-Inszenierung CHoLHo-Y11,3.0 %,36
ENG248447-ENG136988-Inszenierung CHoLHo-Y12,7.0 %,36
ENG248447-ENG136989-Inszenierung CHoLHo-Y13,12.0 %,36
ENG248447-ENG136990-Inszenierung CHoLHo-Y14,17.0 %,36
ENG248447-ENG136991-Inszenierung CHoLHo-Y15,24.0 %,36
ENG248447-ENG100480-Inszenierung CHoLHo-Y2,7.0 %,36
ENG248447-ENG100773-Inszenierung CHoLHo-Y3,12.0 %,36
ENG248447-ENG100631-Inszenierung CHoLHo-Y4,17.0 %,36
ENG248447-ENG102174-Inszenierung CHoLHo-Y5,24.0 %,36
ENG248447-ENG113993-Inszenierung CHoLHo-Y6,33.0 %,36
ENG248447-ENG115665-Inszenierung CHoLHo-y7,44.0 %,36
ENG248447-ENG115666-Inszenierung CHoLHo-y8,59.0 %,36
ENG248447-ENG115667-Inszenierung CHoLHo-y9,78.0 %,36
ENG148608-ENG148900-Lenkradhebel-Art des Lenkstockschalters,LSS ohne Elektronik ,5
ENG148608-ENG149233-Lenkradhebel-Aussenspiegelheizung_aktivierungssignal,Hardwaresignal ,5
ENG148608-ENG155105-Lenkradhebel-FAS-Taster,not installed ,5
ENG148608-ENG149006-Lenkradhebel-Fernlichtstellung,FL tastend ,5
ENG148608-ENG148901-Lenkradhebel-GRA-Bedienung,MFL-Bedienung ,5
ENG148608-ENG149001-Lenkradhebel-heated_mirror,installed with mirror switch ,5
ENG148608-ENG149004-Lenkradhebel-speed_limiter,not installed ,5
ENG148608-ENG179276-Lenkradhebel-Umschaltung GRA zu SL,Direct ,5
ENG148608-ENG154803-Lenkradhebel-Verbauort_Lenkstockschalter,CAN ,5
ENG148608-ENG149234-Lenkradhebel-Versorgung_Lenkstockschalters_KL30,installed ,5
ENG124861-ENG115018-Leuchte 0 BLK VL B35-Dimming_AB_0,100 ,16
ENG124861-ENG115022-Leuchte 0 BLK VL B35-Dimming_CD_0,0 ,16
ENG124861-ENG115023-Leuchte 0 BLK VL B35-Dimming_Direction_CD_0,maximize ,16
ENG124861-ENG115027-Leuchte 0 BLK VL B35-Dimming_Direction_EF_0,maximize ,16
ENG124861-ENG115031-Leuchte 0 BLK VL B35-Dimming_Direction_GH_0,maximize ,16
ENG124861-ENG115026-Leuchte 0 BLK VL B35-Dimming_EF_0,0 ,16
ENG124861-ENG115030-Leuchte 0 BLK VL B35-Dimming_GH_0,0 ,16
ENG124861-ENG126576-Leuchte 0 BLK VL B35-Fehlerort_mittleres_Byte_DTC-DFCC_0,20 ,16
ENG124861-ENG115751-Leuchte 0 BLK VL B35-Lampendefektbit_Position_0,52 ,16
ENG124861-ENG115019-Leuchte 0 BLK VL B35-Light_Control_HD_AB_0,Always ,16
ENG124861-ENG115016-Leuchte 0 BLK VL B35-Light_Function_A_0,Blinken_links_Hellphase ,16
ENG124861-ENG115017-Leuchte 0 BLK VL B35-Light_Function_B_0,not_activ ,16
ENG124861-ENG115020-Leuchte 0 BLK VL B35-Light_Function_C_0,not_activ ,16
ENG124861-ENG115021-Leuchte 0 BLK VL B35-Light_Function_D_0,not_activ ,16
ENG124861-ENG115024-Leuchte 0 BLK VL B35-Light_Function_E_0,not_activ ,16
ENG124861-ENG115025-Leuchte 0 BLK VL B35-Light_Function_F_0,not_activ ,16
ENG124861-ENG115028-Leuchte 0 BLK VL B35-Light_Function_G_0,not_activ ,16
ENG124861-ENG115029-Leuchte 0 BLK VL B35-Light_Function_H_0,not_activ ,16
ENG124861-ENG115013-Leuchte 0 BLK VL B35-Type_Of_Load_0,Blinkleuchten ,16
ENG124872-ENG115193-Leuchte11WARNBLK TASTERC54-Dimming_AB_11,100 ,16
ENG124872-ENG115197-Leuchte11WARNBLK TASTERC54-Dimming_CD_11,0 ,16
ENG124872-ENG115198-Leuchte11WARNBLK TASTERC54-Dimming_Direction_CD_11,maximize ,16
ENG124872-ENG115202-Leuchte11WARNBLK TASTERC54-Dimming_Direction_EF_11,maximize ,16
ENG124872-ENG115206-Leuchte11WARNBLK TASTERC54-Dimming_Direction_GH_11,maximize ,16
ENG124872-ENG115201-Leuchte11WARNBLK TASTERC54-Dimming_EF_11,0 ,16
ENG124872-ENG115205-Leuchte11WARNBLK TASTERC54-Dimming_GH_11,0 ,16
ENG124872-ENG126586-Leuchte11WARNBLK TASTERC54-Fehlerort_mittleres_Byte_DTC-DFCC_11,0 ,16
ENG124872-ENG115735-Leuchte11WARNBLK TASTERC54-Lampendefektbit_Position_11,0 ,16
ENG124872-ENG115194-Leuchte11WARNBLK TASTERC54-Light_Control_HD_AB_11,Always ,16
ENG124872-ENG115191-Leuchte11WARNBLK TASTERC54-Light_Function_A_11,Warnblink_taster ,16
ENG124872-ENG115192-Leuchte11WARNBLK TASTERC54-Light_Function_B_11,not_activ ,16
ENG124872-ENG115195-Leuchte11WARNBLK TASTERC54-Light_Function_C_11,not_activ ,16
ENG124872-ENG115196-Leuchte11WARNBLK TASTERC54-Light_Function_D_11,not_activ ,16
ENG124872-ENG115199-Leuchte11WARNBLK TASTERC54-Light_Function_E_11,not_activ ,16
ENG124872-ENG115200-Leuchte11WARNBLK TASTERC54-Light_Function_F_11,not_activ ,16
ENG124872-ENG115203-Leuchte11WARNBLK TASTERC54-Light_Function_G_11,not_activ ,16
ENG124872-ENG115204-Leuchte11WARNBLK TASTERC54-Light_Function_H_11,not_activ ,16
ENG124872-ENG115188-Leuchte11WARNBLK TASTERC54-Type_Of_Load_11,LED_Kleinleistung_ohne_OL_mitUeberspg_absch ,16
ENG124873-ENG115212-Leuchte12NL LB40-Dimming_AB_12,0 ,16
ENG124873-ENG115216-Leuchte12NL LB40-Dimming_CD_12,0 ,16
ENG124873-ENG115217-Leuchte12NL LB40-Dimming_Direction_CD_12,maximize ,16
ENG124873-ENG115221-Leuchte12NL LB40-Dimming_Direction_EF_12,maximize ,16
ENG124873-ENG115225-Leuchte12NL LB40-Dimming_Direction_GH_12,maximize ,16
ENG124873-ENG115220-Leuchte12NL LB40-Dimming_EF_12,0 ,16
ENG124873-ENG115224-Leuchte12NL LB40-Dimming_GH_12,0 ,16
ENG124873-ENG126587-Leuchte12NL LB40-Fehlerort_mittleres_Byte_DTC-DFCC_12,0 ,16
ENG124873-ENG115750-Leuchte12NL LB40-Lampendefektbit_Position_12,0 ,16
ENG124873-ENG115213-Leuchte12NL LB40-Light_Control_HD_AB_12,Always ,16
ENG124873-ENG115210-Leuchte12NL LB40-Light_Function_A_12,not_activ ,16
ENG124873-ENG115211-Leuchte12NL LB40-Light_Function_B_12,not_activ ,16
ENG124873-ENG115214-Leuchte12NL LB40-Light_Function_C_12,not_activ ,16
ENG124873-ENG115215-Leuchte12NL LB40-Light_Function_D_12,not_activ ,16
ENG124873-ENG115218-Leuchte12NL LB40-Light_Function_E_12,not_activ ,16
ENG124873-ENG115219-Leuchte12NL LB40-Light_Function_F_12,not_activ ,16
ENG124873-ENG115222-Leuchte12NL LB40-Light_Function_G_12,not_activ ,16
ENG124873-ENG115223-Leuchte12NL LB40-Light_Function_H_12,not_activ ,16
ENG124873-ENG115207-Leuchte12NL LB40-Type_Of_Load_12,not_active ,16
ENG124874-ENG114958-Leuchte13NL RB3-Dimming_AB_13,0 ,16
ENG124874-ENG114962-Leuchte13NL RB3-Dimming_CD_13,0 ,16
ENG124874-ENG114963-Leuchte13NL RB3-Dimming_Direction_CD_13,maximize ,16
ENG124874-ENG114967-Leuchte13NL RB3-Dimming_Direction_EF_13,maximize ,16
ENG124874-ENG114971-Leuchte13NL RB3-Dimming_Direction_GH_13,maximize ,16
ENG124874-ENG114966-Leuchte13NL RB3-Dimming_EF_13,0 ,16
ENG124874-ENG114970-Leuchte13NL RB3-Dimming_GH_13,0 ,16
ENG124874-ENG126588-Leuchte13NL RB3-Fehlerort_mittleres_Byte_DTC-DFCC_13,0 ,16
ENG124874-ENG114955-Leuchte13NL RB3-Lampendefektbit_Position_13,0 ,16
ENG124874-ENG114959-Leuchte13NL RB3-Light_Control_HD_AB_13,Always ,16
ENG124874-ENG114956-Leuchte13NL RB3-Light_Function_A_13,not_activ ,16
ENG124874-ENG114957-Leuchte13NL RB3-Light_Function_B_13,not_activ ,16
ENG124874-ENG114960-Leuchte13NL RB3-Light_Function_C_13,not_activ ,16
ENG124874-ENG114961-Leuchte13NL RB3-Light_Function_D_13,not_activ ,16
ENG124874-ENG114964-Leuchte13NL RB3-Light_Function_E_13,not_activ ,16
ENG124874-ENG114965-Leuchte13NL RB3-Light_Function_F_13,not_activ ,16
ENG124874-ENG114968-Leuchte13NL RB3-Light_Function_G_13,not_activ ,16
ENG124874-ENG114969-Leuchte13NL RB3-Light_Function_H_13,not_activ ,16
ENG124874-ENG114954-Leuchte13NL RB3-Type_Of_Load_13,not_active ,16
ENG124876-ENG115252-Leuchte15 SAFE LED C55-Dimming_AB_15,127 ,16
ENG124876-ENG115256-Leuchte15 SAFE LED C55-Dimming_CD_15,0 ,16
ENG124876-ENG115257-Leuchte15 SAFE LED C55-Dimming_Direction_CD_15,maximize ,16
ENG124876-ENG115261-Leuchte15 SAFE LED C55-Dimming_Direction_EF_15,maximize ,16
ENG124876-ENG115265-Leuchte15 SAFE LED C55-Dimming_Direction_GH_15,maximize ,16
ENG124876-ENG115260-Leuchte15 SAFE LED C55-Dimming_EF_15,0 ,16
ENG124876-ENG115264-Leuchte15 SAFE LED C55-Dimming_GH_15,0 ,16
ENG124876-ENG126590-Leuchte15 SAFE LED C55-Fehlerort_mittleres_Byte_DTC-DFCC_15,0 ,16
ENG124876-ENG115800-Leuchte15 SAFE LED C55-Lampendefektbit_Position_15,0 ,16
ENG124876-ENG115253-Leuchte15 SAFE LED C55-Light_Control_HD_AB_15,Always ,16
ENG124876-ENG115250-Leuchte15 SAFE LED C55-Light_Function_A_15,Safe_LED ,16
ENG124876-ENG115251-Leuchte15 SAFE LED C55-Light_Function_B_15,not_activ ,16
ENG124876-ENG115254-Leuchte15 SAFE LED C55-Light_Function_C_15,not_activ ,16
ENG124876-ENG115255-Leuchte15 SAFE LED C55-Light_Function_D_15,not_activ ,16
ENG124876-ENG115258-Leuchte15 SAFE LED C55-Light_Function_E_15,not_activ ,16
ENG124876-ENG115259-Leuchte15 SAFE LED C55-Light_Function_F_15,not_activ ,16
ENG124876-ENG115262-Leuchte15 SAFE LED C55-Light_Function_G_15,not_activ ,16
ENG124876-ENG115263-Leuchte15 SAFE LED C55-Light_Function_H_15,not_activ ,16
ENG124876-ENG115247-Leuchte15 SAFE LED C55-Type_Of_Load_15,LED_Kleinleistung_ohne_OL_mitUeberspg_absch ,16
ENG124877-ENG115271-Leuchte16BLK SLC11-Dimming_AB_16,100 ,16
ENG124877-ENG115275-Leuchte16BLK SLC11-Dimming_CD_16,0 ,16
ENG124877-ENG115276-Leuchte16BLK SLC11-Dimming_Direction_CD_16,maximize ,16
ENG124877-ENG115280-Leuchte16BLK SLC11-Dimming_Direction_EF_16,maximize ,16
ENG124877-ENG115284-Leuchte16BLK SLC11-Dimming_Direction_GH_16,maximize ,16
ENG124877-ENG115279-Leuchte16BLK SLC11-Dimming_EF_16,0 ,16
ENG124877-ENG115283-Leuchte16BLK SLC11-Dimming_GH_16,0 ,16
ENG124877-ENG126591-Leuchte16BLK SLC11-Fehlerort_mittleres_Byte_DTC-DFCC_16,0 ,16
ENG124877-ENG115649-Leuchte16BLK SLC11-Lampendefektbit_Position_16,0 ,16
ENG124877-ENG115272-Leuchte16BLK SLC11-Light_Control_HD_AB_16,Always ,16
ENG124877-ENG115269-Leuchte16BLK SLC11-Light_Function_A_16,Blinken_links_Hellphase ,16
ENG124877-ENG115270-Leuchte16BLK SLC11-Light_Function_B_16,not_activ ,16
ENG124877-ENG115273-Leuchte16BLK SLC11-Light_Function_C_16,not_activ ,16
ENG124877-ENG115274-Leuchte16BLK SLC11-Light_Function_D_16,not_activ ,16
ENG124877-ENG115277-Leuchte16BLK SLC11-Light_Function_E_16,not_activ ,16
ENG124877-ENG115278-Leuchte16BLK SLC11-Light_Function_F_16,not_activ ,16
ENG124877-ENG115281-Leuchte16BLK SLC11-Light_Function_G_16,not_activ ,16
ENG124877-ENG115282-Leuchte16BLK SLC11-Light_Function_H_16,not_activ ,16
ENG124877-ENG115266-Leuchte16BLK SLC11-Type_Of_Load_16,LED_Kleinleistung_ohne_OL_mitUeberspg_absch ,16
ENG124878-ENG115290-Leuchte17 BLK SR A72-Dimming_AB_17,100 ,16
ENG124878-ENG115294-Leuchte17 BLK SR A72-Dimming_CD_17,0 ,16
ENG124878-ENG115295-Leuchte17 BLK SR A72-Dimming_Direction_CD_17,maximize ,16
ENG124878-ENG115299-Leuchte17 BLK SR A72-Dimming_Direction_EF_17,maximize ,16
ENG124878-ENG115303-Leuchte17 BLK SR A72-Dimming_Direction_GH_17,maximize ,16
ENG124878-ENG115298-Leuchte17 BLK SR A72-Dimming_EF_17,0 ,16
ENG124878-ENG115302-Leuchte17 BLK SR A72-Dimming_GH_17,0 ,16
ENG124878-ENG126592-Leuchte17 BLK SR A72-Fehlerort_mittleres_Byte_DTC-DFCC_17,0 ,16
ENG124878-ENG115799-Leuchte17 BLK SR A72-Lampendefektbit_Position_17,0 ,16
ENG124878-ENG115291-Leuchte17 BLK SR A72-Light_Control_HD_AB_17,Always ,16
ENG124878-ENG115288-Leuchte17 BLK SR A72-Light_Function_A_17,Blinken_rechts_Hellphase ,16
ENG124878-ENG115289-Leuchte17 BLK SR A72-Light_Function_B_17,not_activ ,16
ENG124878-ENG115292-Leuchte17 BLK SR A72-Light_Function_C_17,not_activ ,16
ENG124878-ENG115293-Leuchte17 BLK SR A72-Light_Function_D_17,not_activ ,16
ENG124878-ENG115296-Leuchte17 BLK SR A72-Light_Function_E_17,not_activ ,16
ENG124878-ENG115297-Leuchte17 BLK SR A72-Light_Function_F_17,not_activ ,16
ENG124878-ENG115300-Leuchte17 BLK SR A72-Light_Function_G_17,not_activ ,16
ENG124878-ENG115301-Leuchte17 BLK SR A72-Light_Function_H_17,not_activ ,16
ENG124878-ENG115285-Leuchte17 BLK SR A72-Type_Of_Load_17,LED_Kleinleistung_ohne_OL_mitUeberspg_absch ,16
ENG124879-ENG115309-Leuchte18BLK HLA71-Dimming_AB_18,100 ,16
ENG124879-ENG115313-Leuchte18BLK HLA71-Dimming_CD_18,0 ,16
ENG124879-ENG115314-Leuchte18BLK HLA71-Dimming_Direction_CD_18,maximize ,16
ENG124879-ENG115318-Leuchte18BLK HLA71-Dimming_Direction_EF_18,maximize ,16
ENG124879-ENG115322-Leuchte18BLK HLA71-Dimming_Direction_GH_18,maximize ,16
ENG124879-ENG115317-Leuchte18BLK HLA71-Dimming_EF_18,0 ,16
ENG124879-ENG115321-Leuchte18BLK HLA71-Dimming_GH_18,0 ,16
ENG124879-ENG126593-Leuchte18BLK HLA71-Fehlerort_mittleres_Byte_DTC-DFCC_18,22 ,16
ENG124879-ENG115651-Leuchte18BLK HLA71-Lampendefektbit_Position_18,8 ,16
ENG124879-ENG115310-Leuchte18BLK HLA71-Light_Control_HD_AB_18,Always ,16
ENG124879-ENG115307-Leuchte18BLK HLA71-Light_Function_A_18,Blinken_links_Hellphase ,16
ENG124879-ENG115308-Leuchte18BLK HLA71-Light_Function_B_18,not_activ ,16
ENG124879-ENG115311-Leuchte18BLK HLA71-Light_Function_C_18,not_activ ,16
ENG124879-ENG115312-Leuchte18BLK HLA71-Light_Function_D_18,not_activ ,16
ENG124879-ENG115315-Leuchte18BLK HLA71-Light_Function_E_18,not_activ ,16
ENG124879-ENG115316-Leuchte18BLK HLA71-Light_Function_F_18,not_activ ,16
ENG124879-ENG115319-Leuchte18BLK HLA71-Light_Function_G_18,not_activ ,16
ENG124879-ENG115320-Leuchte18BLK HLA71-Light_Function_H_18,not_activ ,16
ENG124879-ENG115304-Leuchte18BLK HLA71-Type_Of_Load_18,Blinkleuchten ,16
ENG124880-ENG115328-Leuchte19BLK HRC8-Dimming_AB_19,100 ,16
ENG124880-ENG115332-Leuchte19BLK HRC8-Dimming_CD_19,0 ,16
ENG124880-ENG115333-Leuchte19BLK HRC8-Dimming_Direction_CD_19,maximize ,16
ENG124880-ENG115337-Leuchte19BLK HRC8-Dimming_Direction_EF_19,maximize ,16
ENG124880-ENG115341-Leuchte19BLK HRC8-Dimming_Direction_GH_19,maximize ,16
ENG124880-ENG115336-Leuchte19BLK HRC8-Dimming_EF_19,0 ,16
ENG124880-ENG115340-Leuchte19BLK HRC8-Dimming_GH_19,0 ,16
ENG124880-ENG126594-Leuchte19BLK HRC8-Fehlerort_mittleres_Byte_DTC-DFCC_19,24 ,16
ENG124880-ENG115785-Leuchte19BLK HRC8-Lampendefektbit_Position_19,24 ,16
ENG124880-ENG115329-Leuchte19BLK HRC8-Light_Control_HD_AB_19,Always ,16
ENG124880-ENG115326-Leuchte19BLK HRC8-Light_Function_A_19,Blinken_rechts_Hellphase ,16
ENG124880-ENG115327-Leuchte19BLK HRC8-Light_Function_B_19,not_activ ,16
ENG124880-ENG115330-Leuchte19BLK HRC8-Light_Function_C_19,not_activ ,16
ENG124880-ENG115331-Leuchte19BLK HRC8-Light_Function_D_19,not_activ ,16
ENG124880-ENG115334-Leuchte19BLK HRC8-Light_Function_E_19,not_activ ,16
ENG124880-ENG115335-Leuchte19BLK HRC8-Light_Function_F_19,not_activ ,16
ENG124880-ENG115338-Leuchte19BLK HRC8-Light_Function_G_19,not_activ ,16
ENG124880-ENG115339-Leuchte19BLK HRC8-Light_Function_H_19,not_activ ,16
ENG124880-ENG115323-Leuchte19BLK HRC8-Type_Of_Load_19,Blinkleuchten ,16
ENG124862-ENG115037-Leuchte1BLK VRB23-Dimming_AB_1,100 ,16
ENG124862-ENG115041-Leuchte1BLK VRB23-Dimming_CD_1,0 ,16
ENG124862-ENG115042-Leuchte1BLK VRB23-Dimming_Direction_CD_1,maximize ,16
ENG124862-ENG115046-Leuchte1BLK VRB23-Dimming_Direction_EF_1,maximize ,16
ENG124862-ENG115050-Leuchte1BLK VRB23-Dimming_Direction_GH_1,maximize ,16
ENG124862-ENG115045-Leuchte1BLK VRB23-Dimming_EF_1,0 ,16
ENG124862-ENG115049-Leuchte1BLK VRB23-Dimming_GH_1,0 ,16
ENG124862-ENG126571-Leuchte1BLK VRB23-Fehlerort_mittleres_Byte_DTC-DFCC_1,21 ,16
ENG124862-ENG115732-Leuchte1BLK VRB23-Lampendefektbit_Position_1,62 ,16
ENG124862-ENG115038-Leuchte1BLK VRB23-Light_Control_HD_AB_1,Always ,16
ENG124862-ENG115035-Leuchte1BLK VRB23-Light_Function_A_1,Blinken_rechts_Hellphase ,16
ENG124862-ENG115036-Leuchte1BLK VRB23-Light_Function_B_1,not_activ ,16
ENG124862-ENG115039-Leuchte1BLK VRB23-Light_Function_C_1,not_activ ,16
ENG124862-ENG115040-Leuchte1BLK VRB23-Light_Function_D_1,not_activ ,16
ENG124862-ENG115043-Leuchte1BLK VRB23-Light_Function_E_1,not_activ ,16
ENG124862-ENG115044-Leuchte1BLK VRB23-Light_Function_F_1,not_activ ,16
ENG124862-ENG115047-Leuchte1BLK VRB23-Light_Function_G_1,not_activ ,16
ENG124862-ENG115048-Leuchte1BLK VRB23-Light_Function_H_1,not_activ ,16
ENG124862-ENG115032-Leuchte1BLK VRB23-Type_Of_Load_1,Blinkleuchten ,16
ENG124881-ENG115347-Leuchte20BR LA70-Dimming_AB_20,127 ,16
ENG124881-ENG115351-Leuchte20BR LA70-Dimming_CD_20,0 ,16
ENG124881-ENG115352-Leuchte20BR LA70-Dimming_Direction_CD_20,maximize ,16
ENG124881-ENG115356-Leuchte20BR LA70-Dimming_Direction_EF_20,maximize ,16
ENG124881-ENG115360-Leuchte20BR LA70-Dimming_Direction_GH_20,maximize ,16
ENG124881-ENG115355-Leuchte20BR LA70-Dimming_EF_20,0 ,16
ENG124881-ENG115359-Leuchte20BR LA70-Dimming_GH_20,0 ,16
ENG124881-ENG126595-Leuchte20BR LA70-Fehlerort_mittleres_Byte_DTC-DFCC_20,43 ,16
ENG124881-ENG115629-Leuchte20BR LA70-Lampendefektbit_Position_20,9 ,16
ENG124881-ENG115348-Leuchte20BR LA70-Light_Control_HD_AB_20,Always ,16
ENG124881-ENG115345-Leuchte20BR LA70-Light_Function_A_20,Brake lamp ,16
ENG124881-ENG115346-Leuchte20BR LA70-Light_Function_B_20,not_activ ,16
ENG124881-ENG115349-Leuchte20BR LA70-Light_Function_C_20,not_activ ,16
ENG124881-ENG115350-Leuchte20BR LA70-Light_Function_D_20,not_activ ,16
ENG124881-ENG115353-Leuchte20BR LA70-Light_Function_E_20,not_activ ,16
ENG124881-ENG115354-Leuchte20BR LA70-Light_Function_F_20,not_activ ,16
ENG124881-ENG115357-Leuchte20BR LA70-Light_Function_G_20,not_activ ,16
ENG124881-ENG115358-Leuchte20BR LA70-Light_Function_H_20,not_activ ,16
ENG124881-ENG115342-Leuchte20BR LA70-Type_Of_Load_20,LED Bremsleuchten_mit_Ueberspg_absch ,16
ENG116957-ENG115366-Leuchte21BR RC8-Dimming_AB_21,127 ,16
ENG116957-ENG115370-Leuchte21BR RC8-Dimming_CD_21,0 ,16
ENG116957-ENG115371-Leuchte21BR RC8-Dimming_Direction_CD_21,maximize ,16
ENG116957-ENG115375-Leuchte21BR RC8-Dimming_Direction_EF_21,maximize ,16
ENG116957-ENG115379-Leuchte21BR RC8-Dimming_Direction_GH_21,maximize ,16
ENG116957-ENG115374-Leuchte21BR RC8-Dimming_EF_21,0 ,16
ENG116957-ENG115378-Leuchte21BR RC8-Dimming_GH_21,0 ,16
ENG116957-ENG126596-Leuchte21BR RC8-Fehlerort_mittleres_Byte_DTC-DFCC_21,45 ,16
ENG116957-ENG115811-Leuchte21BR RC8-Lampendefektbit_Position_21,25 ,16
ENG116957-ENG115367-Leuchte21BR RC8-Light_Control_HD_AB_21,Always ,16
ENG116957-ENG115364-Leuchte21BR RC8-Light_Function_A_21,Brake lamp ,16
ENG116957-ENG115365-Leuchte21BR RC8-Light_Function_B_21,not_activ ,16
ENG116957-ENG115368-Leuchte21BR RC8-Light_Function_C_21,not_activ ,16
ENG116957-ENG115369-Leuchte21BR RC8-Light_Function_D_21,not_activ ,16
ENG116957-ENG115372-Leuchte21BR RC8-Light_Function_E_21,not_activ ,16
ENG116957-ENG115373-Leuchte21BR RC8-Light_Function_F_21,not_activ ,16
ENG116957-ENG115376-Leuchte21BR RC8-Light_Function_G_21,not_activ ,16
ENG116957-ENG115377-Leuchte21BR RC8-Light_Function_H_21,not_activ ,16
ENG116957-ENG115361-Leuchte21BR RC8-Type_Of_Load_21,LED Bremsleuchten_mit_Ueberspg_absch ,16
ENG124882-ENG115385-Leuchte22BR MC9-Dimming_AB_22,100 ,16
ENG124882-ENG115389-Leuchte22BR MC9-Dimming_CD_22,0 ,16
ENG124882-ENG115390-Leuchte22BR MC9-Dimming_Direction_CD_22,maximize ,16
ENG124882-ENG115394-Leuchte22BR MC9-Dimming_Direction_EF_22,maximize ,16
ENG124882-ENG115398-Leuchte22BR MC9-Dimming_Direction_GH_22,maximize ,16
ENG124882-ENG115393-Leuchte22BR MC9-Dimming_EF_22,0 ,16
ENG124882-ENG115397-Leuchte22BR MC9-Dimming_GH_22,0 ,16
ENG124882-ENG126597-Leuchte22BR MC9-Fehlerort_mittleres_Byte_DTC-DFCC_22,44 ,16
ENG124882-ENG115780-Leuchte22BR MC9-Lampendefektbit_Position_22,41 ,16
ENG124882-ENG115386-Leuchte22BR MC9-Light_Control_HD_AB_22,Always ,16
ENG124882-ENG115383-Leuchte22BR MC9-Light_Function_A_22,Brake lamp ,16
ENG124882-ENG115384-Leuchte22BR MC9-Light_Function_B_22,not_activ ,16
ENG124882-ENG115387-Leuchte22BR MC9-Light_Function_C_22,not_activ ,16
ENG124882-ENG115388-Leuchte22BR MC9-Light_Function_D_22,not_activ ,16
ENG124882-ENG115391-Leuchte22BR MC9-Light_Function_E_22,not_activ ,16
ENG124882-ENG115392-Leuchte22BR MC9-Light_Function_F_22,not_activ ,16
ENG124882-ENG115395-Leuchte22BR MC9-Light_Function_G_22,not_activ ,16
ENG124882-ENG115396-Leuchte22BR MC9-Light_Function_H_22,not_activ ,16
ENG124882-ENG115380-Leuchte22BR MC9-Type_Of_Load_22,LED dritte Bremsleuchte ,16
ENG124883-ENG115404-Leuchte23SL HLC7-Dimming_AB_23,127 ,16
ENG124883-ENG115408-Leuchte23SL HLC7-Dimming_CD_23,0 ,16
ENG124883-ENG115409-Leuchte23SL HLC7-Dimming_Direction_CD_23,maximize ,16
ENG124883-ENG115413-Leuchte23SL HLC7-Dimming_Direction_EF_23,maximize ,16
ENG124883-ENG115417-Leuchte23SL HLC7-Dimming_Direction_GH_23,maximize ,16
ENG124883-ENG115412-Leuchte23SL HLC7-Dimming_EF_23,0 ,16
ENG124883-ENG115416-Leuchte23SL HLC7-Dimming_GH_23,0 ,16
ENG124883-ENG126598-Leuchte23SL HLC7-Fehlerort_mittleres_Byte_DTC-DFCC_23,41 ,16
ENG124883-ENG115781-Leuchte23SL HLC7-Lampendefektbit_Position_23,10 ,16
ENG124883-ENG115405-Leuchte23SL HLC7-Light_Control_HD_AB_23,Always ,16
ENG124883-ENG115402-Leuchte23SL HLC7-Light_Function_A_23,Position lamps ,16
ENG124883-ENG115403-Leuchte23SL HLC7-Light_Function_B_23,Parklichtlinks ,16
ENG124883-ENG115406-Leuchte23SL HLC7-Light_Function_C_23,not_activ ,16
ENG124883-ENG115407-Leuchte23SL HLC7-Light_Function_D_23,not_activ ,16
ENG124883-ENG115410-Leuchte23SL HLC7-Light_Function_E_23,not_activ ,16
ENG124883-ENG115411-Leuchte23SL HLC7-Light_Function_F_23,not_activ ,16
ENG124883-ENG115414-Leuchte23SL HLC7-Light_Function_G_23,not_activ ,16
ENG124883-ENG115415-Leuchte23SL HLC7-Light_Function_H_23,not_activ ,16
ENG124883-ENG115399-Leuchte23SL HLC7-Type_Of_Load_23,allgemeine_LED_12W ,16
ENG124884-ENG115423-Leuchte24SL HRA69-Dimming_AB_24,127 ,16
ENG124884-ENG115427-Leuchte24SL HRA69-Dimming_CD_24,0 ,16
ENG124884-ENG115428-Leuchte24SL HRA69-Dimming_Direction_CD_24,maximize ,16
ENG124884-ENG115432-Leuchte24SL HRA69-Dimming_Direction_EF_24,maximize ,16
ENG124884-ENG115436-Leuchte24SL HRA69-Dimming_Direction_GH_24,maximize ,16
ENG124884-ENG115431-Leuchte24SL HRA69-Dimming_EF_24,0 ,16
ENG124884-ENG115435-Leuchte24SL HRA69-Dimming_GH_24,0 ,16
ENG124884-ENG126599-Leuchte24SL HRA69-Fehlerort_mittleres_Byte_DTC-DFCC_24,42 ,16
ENG124884-ENG115669-Leuchte24SL HRA69-Lampendefektbit_Position_24,26 ,16
ENG124884-ENG115424-Leuchte24SL HRA69-Light_Control_HD_AB_24,Always ,16
ENG124884-ENG115421-Leuchte24SL HRA69-Light_Function_A_24,Position lamps ,16
ENG124884-ENG115422-Leuchte24SL HRA69-Light_Function_B_24,Parklichtrechts ,16
ENG124884-ENG115425-Leuchte24SL HRA69-Light_Function_C_24,not_activ ,16
ENG124884-ENG115426-Leuchte24SL HRA69-Light_Function_D_24,not_activ ,16
ENG124884-ENG115429-Leuchte24SL HRA69-Light_Function_E_24,not_activ ,16
ENG124884-ENG115430-Leuchte24SL HRA69-Light_Function_F_24,not_activ ,16
ENG124884-ENG115433-Leuchte24SL HRA69-Light_Function_G_24,not_activ ,16
ENG124884-ENG115434-Leuchte24SL HRA69-Light_Function_H_24,not_activ ,16
ENG124884-ENG115418-Leuchte24SL HRA69-Type_Of_Load_24,allgemeine_LED_12W ,16
ENG124885-ENG115442-Leuchte25KZL HA60-Dimming_AB_25,127 ,16
ENG124885-ENG115446-Leuchte25KZL HA60-Dimming_CD_25,0 ,16
ENG124885-ENG115447-Leuchte25KZL HA60-Dimming_Direction_CD_25,maximize ,16
ENG124885-ENG115451-Leuchte25KZL HA60-Dimming_Direction_EF_25,maximize ,16
ENG124885-ENG115455-Leuchte25KZL HA60-Dimming_Direction_GH_25,maximize ,16
ENG124885-ENG115450-Leuchte25KZL HA60-Dimming_EF_25,0 ,16
ENG124885-ENG115454-Leuchte25KZL HA60-Dimming_GH_25,0 ,16
ENG124885-ENG126600-Leuchte25KZL HA60-Fehlerort_mittleres_Byte_DTC-DFCC_25,48 ,16
ENG124885-ENG115725-Leuchte25KZL HA60-Lampendefektbit_Position_25,40 ,16
ENG124885-ENG115443-Leuchte25KZL HA60-Light_Control_HD_AB_25,Always ,16
ENG124885-ENG115440-Leuchte25KZL HA60-Light_Function_A_25,Position lamps ,16
ENG124885-ENG115441-Leuchte25KZL HA60-Light_Function_B_25,not_activ ,16
ENG124885-ENG115444-Leuchte25KZL HA60-Light_Function_C_25,not_activ ,16
ENG124885-ENG115445-Leuchte25KZL HA60-Light_Function_D_25,not_activ ,16
ENG124885-ENG115448-Leuchte25KZL HA60-Light_Function_E_25,not_activ ,16
ENG124885-ENG115449-Leuchte25KZL HA60-Light_Function_F_25,not_activ ,16
ENG124885-ENG115452-Leuchte25KZL HA60-Light_Function_G_25,not_activ ,16
ENG124885-ENG115453-Leuchte25KZL HA60-Light_Function_H_25,not_activ ,16
ENG124885-ENG115437-Leuchte25KZL HA60-Type_Of_Load_25,allgemeine_LED_12W ,16
ENG124886-ENG115461-Leuchte26NSL A65-Dimming_AB_26,127 ,16
ENG124886-ENG115465-Leuchte26NSL A65-Dimming_CD_26,0 ,16
ENG124886-ENG115466-Leuchte26NSL A65-Dimming_Direction_CD_26,maximize ,16
ENG124886-ENG115470-Leuchte26NSL A65-Dimming_Direction_EF_26,maximize ,16
ENG124886-ENG115474-Leuchte26NSL A65-Dimming_Direction_GH_26,maximize ,16
ENG124886-ENG115469-Leuchte26NSL A65-Dimming_EF_26,0 ,16
ENG124886-ENG115473-Leuchte26NSL A65-Dimming_GH_26,0 ,16
ENG124886-ENG126601-Leuchte26NSL A65-Fehlerort_mittleres_Byte_DTC-DFCC_26,46 ,16
ENG124886-ENG115627-Leuchte26NSL A65-Lampendefektbit_Position_26,12 ,16
ENG124886-ENG115462-Leuchte26NSL A65-Light_Control_HD_AB_26,Always ,16
ENG124886-ENG115459-Leuchte26NSL A65-Light_Function_A_26,Nebel_schlusslicht ,16
ENG124886-ENG115460-Leuchte26NSL A65-Light_Function_B_26,not_activ ,16
ENG124886-ENG115463-Leuchte26NSL A65-Light_Function_C_26,not_activ ,16
ENG124886-ENG115464-Leuchte26NSL A65-Light_Function_D_26,not_activ ,16
ENG124886-ENG115467-Leuchte26NSL A65-Light_Function_E_26,not_activ ,16
ENG124886-ENG115468-Leuchte26NSL A65-Light_Function_F_26,not_activ ,16
ENG124886-ENG115471-Leuchte26NSL A65-Light_Function_G_26,not_activ ,16
ENG124886-ENG115472-Leuchte26NSL A65-Light_Function_H_26,not_activ ,16
ENG124886-ENG115456-Leuchte26NSL A65-Type_Of_Load_26,allgemeine_LED_6W ,16
ENG124887-ENG115480-Leuchte27 KL58XS C67-Dimming_AB_27,100 ,16
ENG124887-ENG115484-Leuchte27 KL58XS C67-Dimming_CD_27,0 ,16
ENG124887-ENG115485-Leuchte27 KL58XS C67-Dimming_Direction_CD_27,maximize ,16
ENG124887-ENG115489-Leuchte27 KL58XS C67-Dimming_Direction_EF_27,maximize ,16
ENG124887-ENG115493-Leuchte27 KL58XS C67-Dimming_Direction_GH_27,maximize ,16
ENG124887-ENG115488-Leuchte27 KL58XS C67-Dimming_EF_27,0 ,16
ENG124887-ENG115492-Leuchte27 KL58XS C67-Dimming_GH_27,0 ,16
ENG124887-ENG126602-Leuchte27 KL58XS C67-Fehlerort_mittleres_Byte_DTC-DFCC_27,8 ,16
ENG124887-ENG115648-Leuchte27 KL58XS C67-Lampendefektbit_Position_27,0 ,16
ENG124887-ENG115481-Leuchte27 KL58XS C67-Light_Control_HD_AB_27,Always ,16
ENG124887-ENG115478-Leuchte27 KL58XS C67-Light_Function_A_27,Dimmung_Klemme_58_xs ,16
ENG124887-ENG115479-Leuchte27 KL58XS C67-Light_Function_B_27,not_activ ,16
ENG124887-ENG115482-Leuchte27 KL58XS C67-Light_Function_C_27,not_activ ,16
ENG124887-ENG115483-Leuchte27 KL58XS C67-Light_Function_D_27,not_activ ,16
ENG124887-ENG115486-Leuchte27 KL58XS C67-Light_Function_E_27,not_activ ,16
ENG124887-ENG115487-Leuchte27 KL58XS C67-Light_Function_F_27,not_activ ,16
ENG124887-ENG115490-Leuchte27 KL58XS C67-Light_Function_G_27,not_activ ,16
ENG124887-ENG115491-Leuchte27 KL58XS C67-Light_Function_H_27,not_activ ,16
ENG124887-ENG115475-Leuchte27 KL58XS C67-Type_Of_Load_27,LED_Kleinleistung_ohne_OL_mitUeberspg_absch ,16
ENG124888-ENG115499-Leuchte28RFL C3-Dimming_AB_28,100 ,16
ENG124888-ENG115503-Leuchte28RFL C3-Dimming_CD_28,0 ,16
ENG124888-ENG115504-Leuchte28RFL C3-Dimming_Direction_CD_28,maximize ,16
ENG124888-ENG115508-Leuchte28RFL C3-Dimming_Direction_EF_28,maximize ,16
ENG124888-ENG115512-Leuchte28RFL C3-Dimming_Direction_GH_28,maximize ,16
ENG124888-ENG115507-Leuchte28RFL C3-Dimming_EF_28,0 ,16
ENG124888-ENG115511-Leuchte28RFL C3-Dimming_GH_28,0 ,16
ENG124888-ENG126603-Leuchte28RFL C3-Fehlerort_mittleres_Byte_DTC-DFCC_28,52 ,16
ENG124888-ENG115647-Leuchte28RFL C3-Lampendefektbit_Position_28,43 ,16
ENG124888-ENG115500-Leuchte28RFL C3-Light_Control_HD_AB_28,Always ,16
ENG124888-ENG115497-Leuchte28RFL C3-Light_Function_A_28,Rueckfahrlicht ,16
ENG124888-ENG115498-Leuchte28RFL C3-Light_Function_B_28,not_activ ,16
ENG124888-ENG115501-Leuchte28RFL C3-Light_Function_C_28,not_activ ,16
ENG124888-ENG115502-Leuchte28RFL C3-Light_Function_D_28,not_activ ,16
ENG124888-ENG115505-Leuchte28RFL C3-Light_Function_E_28,not_activ ,16
ENG124888-ENG115506-Leuchte28RFL C3-Light_Function_F_28,not_activ ,16
ENG124888-ENG115509-Leuchte28RFL C3-Light_Function_G_28,not_activ ,16
ENG124888-ENG115510-Leuchte28RFL C3-Light_Function_H_28,not_activ ,16
ENG124888-ENG115494-Leuchte28RFL C3-Type_Of_Load_28,2*21W_Nebelschluss_Rueckfahrleuchte_mit_Teilausfallerkennung ,16
ENG124889-ENG115518-Leuchte29 KL30G A69-Dimming_AB_29,100 ,16
ENG124889-ENG115522-Leuchte29 KL30G A69-Dimming_CD_29,0 ,16
ENG124889-ENG115523-Leuchte29 KL30G A69-Dimming_Direction_CD_29,maximize ,16
ENG124889-ENG115527-Leuchte29 KL30G A69-Dimming_Direction_EF_29,maximize ,16
ENG124889-ENG115531-Leuchte29 KL30G A69-Dimming_Direction_GH_29,maximize ,16
ENG124889-ENG115526-Leuchte29 KL30G A69-Dimming_EF_29,0 ,16
ENG124889-ENG115530-Leuchte29 KL30G A69-Dimming_GH_29,0 ,16
ENG124889-ENG126604-Leuchte29 KL30G A69-Fehlerort_mittleres_Byte_DTC-DFCC_29,1 ,16
ENG124889-ENG115764-Leuchte29 KL30G A69-Lampendefektbit_Position_29,0 ,16
ENG124889-ENG115520-Leuchte29 KL30G A69-Light_Control_HD_AB_29,Always ,16
ENG124889-ENG115516-Leuchte29 KL30G A69-Light_Function_A_29,Klemme_30_G ,16
ENG124889-ENG115517-Leuchte29 KL30G A69-Light_Function_B_29,not_activ ,16
ENG124889-ENG115519-Leuchte29 KL30G A69-Light_Function_C_29,not_activ ,16
ENG124889-ENG115521-Leuchte29 KL30G A69-Light_Function_D_29,not_activ ,16
ENG124889-ENG115524-Leuchte29 KL30G A69-Light_Function_E_29,not_activ ,16
ENG124889-ENG115525-Leuchte29 KL30G A69-Light_Function_F_29,not_activ ,16
ENG124889-ENG115528-Leuchte29 KL30G A69-Light_Function_G_29,not_activ ,16
ENG124889-ENG115529-Leuchte29 KL30G A69-Light_Function_H_29,not_activ ,16
ENG124889-ENG115513-Leuchte29 KL30G A69-Type_Of_Load_29,allgemeine_Gluehlampe12W ,16
ENG124863-ENG115056-Leuchte2SL VLB22-Dimming_AB_2,127 ,16
ENG124863-ENG115060-Leuchte2SL VLB22-Dimming_CD_2,0 ,16
ENG124863-ENG115061-Leuchte2SL VLB22-Dimming_Direction_CD_2,maximize ,16
ENG124863-ENG115065-Leuchte2SL VLB22-Dimming_Direction_EF_2,maximize ,16
ENG124863-ENG115069-Leuchte2SL VLB22-Dimming_Direction_GH_2,maximize ,16
ENG124863-ENG115064-Leuchte2SL VLB22-Dimming_EF_2,0 ,16
ENG124863-ENG115068-Leuchte2SL VLB22-Dimming_GH_2,0 ,16
ENG124863-ENG126577-Leuchte2SL VLB22-Fehlerort_mittleres_Byte_DTC-DFCC_2,38 ,16
ENG124863-ENG115726-Leuchte2SL VLB22-Lampendefektbit_Position_2,53 ,16
ENG124863-ENG115057-Leuchte2SL VLB22-Light_Control_HD_AB_2,Always ,16
ENG124863-ENG115054-Leuchte2SL VLB22-Light_Function_A_2,Position lamps ,16
ENG124863-ENG115055-Leuchte2SL VLB22-Light_Function_B_2,Parklichtlinks ,16
ENG124863-ENG115058-Leuchte2SL VLB22-Light_Function_C_2,not_activ ,16
ENG124863-ENG115059-Leuchte2SL VLB22-Light_Function_D_2,not_activ ,16
ENG124863-ENG115062-Leuchte2SL VLB22-Light_Function_E_2,not_activ ,16
ENG124863-ENG115063-Leuchte2SL VLB22-Light_Function_F_2,not_activ ,16
ENG124863-ENG115066-Leuchte2SL VLB22-Light_Function_G_2,not_activ ,16
ENG124863-ENG115067-Leuchte2SL VLB22-Light_Function_H_2,not_activ ,16
ENG124863-ENG115051-Leuchte2SL VLB22-Type_Of_Load_2,allgemeine_LED_6W ,16
ENG124890-ENG115537-Leuchte30 INNENLICHT A68-Dimming_AB_30,126 ,16
ENG124890-ENG115541-Leuchte30 INNENLICHT A68-Dimming_CD_30,0 ,16
ENG124890-ENG115542-Leuchte30 INNENLICHT A68-Dimming_Direction_CD_30,maximize ,16
ENG124890-ENG115546-Leuchte30 INNENLICHT A68-Dimming_Direction_EF_30,maximize ,16
ENG124890-ENG115550-Leuchte30 INNENLICHT A68-Dimming_Direction_GH_30,maximize ,16
ENG124890-ENG115545-Leuchte30 INNENLICHT A68-Dimming_EF_30,0 ,16
ENG124890-ENG115549-Leuchte30 INNENLICHT A68-Dimming_GH_30,0 ,16
ENG124890-ENG126605-Leuchte30 INNENLICHT A68-Fehlerort_mittleres_Byte_DTC-DFCC_30,7 ,16
ENG124890-ENG115797-Leuchte30 INNENLICHT A68-Lampendefektbit_Position_30,0 ,16
ENG124890-ENG115538-Leuchte30 INNENLICHT A68-Light_Control_HD_AB_30,Always ,16
ENG124890-ENG115535-Leuchte30 INNENLICHT A68-Light_Function_A_30,Interior lighting ,16
ENG124890-ENG115536-Leuchte30 INNENLICHT A68-Light_Function_B_30,not_activ ,16
ENG124890-ENG115539-Leuchte30 INNENLICHT A68-Light_Function_C_30,not_activ ,16
ENG124890-ENG115540-Leuchte30 INNENLICHT A68-Light_Function_D_30,not_activ ,16
ENG124890-ENG115543-Leuchte30 INNENLICHT A68-Light_Function_E_30,not_activ ,16
ENG124890-ENG115544-Leuchte30 INNENLICHT A68-Light_Function_F_30,not_activ ,16
ENG124890-ENG115547-Leuchte30 INNENLICHT A68-Light_Function_G_30,not_activ ,16
ENG124890-ENG115548-Leuchte30 INNENLICHT A68-Light_Function_H_30,not_activ ,16
ENG124890-ENG115532-Leuchte30 INNENLICHT A68-Type_Of_Load_30,allgemeine_Gluehlampe12W ,16
ENG124891-ENG115556-Leuchte31AMBL 1C65-Dimming_AB_31,0 ,16
ENG124891-ENG115560-Leuchte31AMBL 1C65-Dimming_CD_31,0 ,16
ENG124891-ENG115561-Leuchte31AMBL 1C65-Dimming_Direction_CD_31,maximize ,16
ENG124891-ENG115565-Leuchte31AMBL 1C65-Dimming_Direction_EF_31,maximize ,16
ENG124891-ENG115569-Leuchte31AMBL 1C65-Dimming_Direction_GH_31,maximize ,16
ENG124891-ENG115564-Leuchte31AMBL 1C65-Dimming_EF_31,0 ,16
ENG124891-ENG115568-Leuchte31AMBL 1C65-Dimming_GH_31,0 ,16
ENG124891-ENG126606-Leuchte31AMBL 1C65-Fehlerort_mittleres_Byte_DTC-DFCC_31,0 ,16
ENG124891-ENG115707-Leuchte31AMBL 1C65-Lampendefektbit_Position_31,0 ,16
ENG124891-ENG115557-Leuchte31AMBL 1C65-Light_Control_HD_AB_31,Always ,16
ENG124891-ENG115554-Leuchte31AMBL 1C65-Light_Function_A_31,not_activ ,16
ENG124891-ENG115555-Leuchte31AMBL 1C65-Light_Function_B_31,not_activ ,16
ENG124891-ENG115558-Leuchte31AMBL 1C65-Light_Function_C_31,not_activ ,16
ENG124891-ENG115559-Leuchte31AMBL 1C65-Light_Function_D_31,not_activ ,16
ENG124891-ENG115562-Leuchte31AMBL 1C65-Light_Function_E_31,not_activ ,16
ENG124891-ENG115563-Leuchte31AMBL 1C65-Light_Function_F_31,not_activ ,16
ENG124891-ENG115566-Leuchte31AMBL 1C65-Light_Function_G_31,not_activ ,16
ENG124891-ENG115567-Leuchte31AMBL 1C65-Light_Function_H_31,not_activ ,16
ENG124891-ENG115551-Leuchte31AMBL 1C65-Type_Of_Load_31,not_active ,16
ENG124892-ENG115575-Leuchte32AMBL 2C64-Dimming_AB_32,0 ,16
ENG124892-ENG115579-Leuchte32AMBL 2C64-Dimming_CD_32,0 ,16
ENG124892-ENG115580-Leuchte32AMBL 2C64-Dimming_Direction_CD_32,maximize ,16
ENG124892-ENG115584-Leuchte32AMBL 2C64-Dimming_Direction_EF_32,maximize ,16
ENG124892-ENG115588-Leuchte32AMBL 2C64-Dimming_Direction_GH_32,maximize ,16
ENG124892-ENG115583-Leuchte32AMBL 2C64-Dimming_EF_32,0 ,16
ENG124892-ENG115587-Leuchte32AMBL 2C64-Dimming_GH_32,0 ,16
ENG124892-ENG126607-Leuchte32AMBL 2C64-Fehlerort_mittleres_Byte_DTC-DFCC_32,0 ,16
ENG124892-ENG115654-Leuchte32AMBL 2C64-Lampendefektbit_Position_32,0 ,16
ENG124892-ENG115576-Leuchte32AMBL 2C64-Light_Control_HD_AB_32,Always ,16
ENG124892-ENG115573-Leuchte32AMBL 2C64-Light_Function_A_32,not_activ ,16
ENG124892-ENG115574-Leuchte32AMBL 2C64-Light_Function_B_32,not_activ ,16
ENG124892-ENG115577-Leuchte32AMBL 2C64-Light_Function_C_32,not_activ ,16
ENG124892-ENG115578-Leuchte32AMBL 2C64-Light_Function_D_32,not_activ ,16
ENG124892-ENG115581-Leuchte32AMBL 2C64-Light_Function_E_32,not_activ ,16
ENG124892-ENG115582-Leuchte32AMBL 2C64-Light_Function_F_32,not_activ ,16
ENG124892-ENG115585-Leuchte32AMBL 2C64-Light_Function_G_32,not_activ ,16
ENG124892-ENG115586-Leuchte32AMBL 2C64-Light_Function_H_32,not_activ ,16
ENG124892-ENG115570-Leuchte32AMBL 2C64-Type_Of_Load_32,not_active ,16
ENG124893-ENG115594-Leuchte33AMBL 3C72-Dimming_AB_33,0 ,16
ENG124893-ENG115598-Leuchte33AMBL 3C72-Dimming_CD_33,0 ,16
ENG124893-ENG115599-Leuchte33AMBL 3C72-Dimming_Direction_CD_33,maximize ,16
ENG124893-ENG115603-Leuchte33AMBL 3C72-Dimming_Direction_EF_33,maximize ,16
ENG124893-ENG115607-Leuchte33AMBL 3C72-Dimming_Direction_GH_33,maximize ,16
ENG124893-ENG115602-Leuchte33AMBL 3C72-Dimming_EF_33,0 ,16
ENG124893-ENG115606-Leuchte33AMBL 3C72-Dimming_GH_33,0 ,16
ENG124893-ENG126608-Leuchte33AMBL 3C72-Fehlerort_mittleres_Byte_DTC-DFCC_33,0 ,16
ENG124893-ENG115655-Leuchte33AMBL 3C72-Lampendefektbit_Position_33,0 ,16
ENG124893-ENG115595-Leuchte33AMBL 3C72-Light_Control_HD_AB_33,Always ,16
ENG124893-ENG115592-Leuchte33AMBL 3C72-Light_Function_A_33,not_activ ,16
ENG124893-ENG115593-Leuchte33AMBL 3C72-Light_Function_B_33,not_activ ,16
ENG124893-ENG115596-Leuchte33AMBL 3C72-Light_Function_C_33,not_activ ,16
ENG124893-ENG115597-Leuchte33AMBL 3C72-Light_Function_D_33,not_activ ,16
ENG124893-ENG115600-Leuchte33AMBL 3C72-Light_Function_E_33,not_activ ,16
ENG124893-ENG115601-Leuchte33AMBL 3C72-Light_Function_F_33,not_activ ,16
ENG124893-ENG115604-Leuchte33AMBL 3C72-Light_Function_G_33,not_activ ,16
ENG124893-ENG115605-Leuchte33AMBL 3C72-Light_Function_H_33,not_activ ,16
ENG124893-ENG115589-Leuchte33AMBL 3C72-Type_Of_Load_33,not_active ,16
ENG124894-ENG115613-Leuchte34AMBL 4C71-Dimming_AB_34,0 ,16
ENG124894-ENG115617-Leuchte34AMBL 4C71-Dimming_CD_34,0 ,16
ENG124894-ENG115618-Leuchte34AMBL 4C71-Dimming_Direction_CD_34,maximize ,16
ENG124894-ENG115622-Leuchte34AMBL 4C71-Dimming_Direction_EF_34,maximize ,16
ENG124894-ENG115626-Leuchte34AMBL 4C71-Dimming_Direction_GH_34,maximize ,16
ENG124894-ENG115621-Leuchte34AMBL 4C71-Dimming_EF_34,0 ,16
ENG124894-ENG115625-Leuchte34AMBL 4C71-Dimming_GH_34,0 ,16
ENG124894-ENG126609-Leuchte34AMBL 4C71-Fehlerort_mittleres_Byte_DTC-DFCC_34,0 ,16
ENG124894-ENG115796-Leuchte34AMBL 4C71-Lampendefektbit_Position_34,0 ,16
ENG124894-ENG115614-Leuchte34AMBL 4C71-Light_Control_HD_AB_34,Always ,16
ENG124894-ENG115611-Leuchte34AMBL 4C71-Light_Function_A_34,not_activ ,16
ENG124894-ENG115612-Leuchte34AMBL 4C71-Light_Function_B_34,not_activ ,16
ENG124894-ENG115615-Leuchte34AMBL 4C71-Light_Function_C_34,not_activ ,16
ENG124894-ENG115616-Leuchte34AMBL 4C71-Light_Function_D_34,not_activ ,16
ENG124894-ENG115619-Leuchte34AMBL 4C71-Light_Function_E_34,not_activ ,16
ENG124894-ENG115620-Leuchte34AMBL 4C71-Light_Function_F_34,not_activ ,16
ENG124894-ENG115623-Leuchte34AMBL 4C71-Light_Function_G_34,not_activ ,16
ENG124894-ENG115624-Leuchte34AMBL 4C71-Light_Function_H_34,not_activ ,16
ENG124894-ENG115608-Leuchte34AMBL 4C71-Type_Of_Load_34,not_active ,16
ENG124864-ENG115075-Leuchte3SL VRB36-Dimming_AB_3,127 ,16
ENG124864-ENG115079-Leuchte3SL VRB36-Dimming_CD_3,0 ,16
ENG124864-ENG115080-Leuchte3SL VRB36-Dimming_Direction_CD_3,maximize ,16
ENG124864-ENG115084-Leuchte3SL VRB36-Dimming_Direction_EF_3,maximize ,16
ENG124864-ENG115088-Leuchte3SL VRB36-Dimming_Direction_GH_3,maximize ,16
ENG124864-ENG115083-Leuchte3SL VRB36-Dimming_EF_3,0 ,16
ENG124864-ENG115087-Leuchte3SL VRB36-Dimming_GH_3,0 ,16
ENG124864-ENG126578-Leuchte3SL VRB36-Fehlerort_mittleres_Byte_DTC-DFCC_3,39 ,16
ENG124864-ENG115645-Leuchte3SL VRB36-Lampendefektbit_Position_3,63 ,16
ENG124864-ENG115076-Leuchte3SL VRB36-Light_Control_HD_AB_3,Always ,16
ENG124864-ENG115073-Leuchte3SL VRB36-Light_Function_A_3,Position lamps ,16
ENG124864-ENG115074-Leuchte3SL VRB36-Light_Function_B_3,Parklichtrechts ,16
ENG124864-ENG115077-Leuchte3SL VRB36-Light_Function_C_3,not_activ ,16
ENG124864-ENG115078-Leuchte3SL VRB36-Light_Function_D_3,not_activ ,16
ENG124864-ENG115081-Leuchte3SL VRB36-Light_Function_E_3,not_activ ,16
ENG124864-ENG115082-Leuchte3SL VRB36-Light_Function_F_3,not_activ ,16
ENG124864-ENG115085-Leuchte3SL VRB36-Light_Function_G_3,not_activ ,16
ENG124864-ENG115086-Leuchte3SL VRB36-Light_Function_H_3,not_activ ,16
ENG124864-ENG115070-Leuchte3SL VRB36-Type_Of_Load_3,allgemeine_LED_6W ,16
ENG124865-ENG115094-Leuchte4TFL LB43-Dimming_AB_4,127 ,16
ENG124865-ENG115098-Leuchte4TFL LB43-Dimming_CD_4,0 ,16
ENG124865-ENG115099-Leuchte4TFL LB43-Dimming_Direction_CD_4,minimize ,16
ENG124865-ENG115103-Leuchte4TFL LB43-Dimming_Direction_EF_4,maximize ,16
ENG124865-ENG115107-Leuchte4TFL LB43-Dimming_Direction_GH_4,maximize ,16
ENG124865-ENG115102-Leuchte4TFL LB43-Dimming_EF_4,0 ,16
ENG124865-ENG115106-Leuchte4TFL LB43-Dimming_GH_4,0 ,16
ENG124865-ENG126579-Leuchte4TFL LB43-Fehlerort_mittleres_Byte_DTC-DFCC_4,32 ,16
ENG124865-ENG115808-Leuchte4TFL LB43-Lampendefektbit_Position_4,58 ,16
ENG124865-ENG115095-Leuchte4TFL LB43-Light_Control_HD_AB_4,Always ,16
ENG124865-ENG115092-Leuchte4TFL LB43-Light_Function_A_4,Daytime running lamps ,16
ENG124865-ENG115093-Leuchte4TFL LB43-Light_Function_B_4,not_activ ,16
ENG124865-ENG115096-Leuchte4TFL LB43-Light_Function_C_4,Nebel_licht_links ,16
ENG124865-ENG115097-Leuchte4TFL LB43-Light_Function_D_4,not_activ ,16
ENG124865-ENG115100-Leuchte4TFL LB43-Light_Function_E_4,not_activ ,16
ENG124865-ENG115101-Leuchte4TFL LB43-Light_Function_F_4,not_activ ,16
ENG124865-ENG115104-Leuchte4TFL LB43-Light_Function_G_4,not_activ ,16
ENG124865-ENG115105-Leuchte4TFL LB43-Light_Function_H_4,not_activ ,16
ENG124865-ENG115089-Leuchte4TFL LB43-Type_Of_Load_4,allgemeine_LED_6W ,16
ENG124866-ENG114977-Leuchte5 TFL RB6-Dimming_AB_5,127 ,16
ENG124866-ENG114981-Leuchte5 TFL RB6-Dimming_CD_5,0 ,16
ENG124866-ENG114982-Leuchte5 TFL RB6-Dimming_Direction_CD_5,minimize ,16
ENG124866-ENG114986-Leuchte5 TFL RB6-Dimming_Direction_EF_5,maximize ,16
ENG124866-ENG114990-Leuchte5 TFL RB6-Dimming_Direction_GH_5,maximize ,16
ENG124866-ENG114985-Leuchte5 TFL RB6-Dimming_EF_5,0 ,16
ENG124866-ENG114989-Leuchte5 TFL RB6-Dimming_GH_5,0 ,16
ENG124866-ENG126580-Leuchte5 TFL RB6-Fehlerort_mittleres_Byte_DTC-DFCC_5,33 ,16
ENG124866-ENG114974-Leuchte5 TFL RB6-Lampendefektbit_Position_5,68 ,16
ENG124866-ENG114978-Leuchte5 TFL RB6-Light_Control_HD_AB_5,Always ,16
ENG124866-ENG114975-Leuchte5 TFL RB6-Light_Function_A_5,Daytime running lamps ,16
ENG124866-ENG114976-Leuchte5 TFL RB6-Light_Function_B_5,not_activ ,16
ENG124866-ENG114979-Leuchte5 TFL RB6-Light_Function_C_5,Nebellichtrechts ,16
ENG124866-ENG114980-Leuchte5 TFL RB6-Light_Function_D_5,not_activ ,16
ENG124866-ENG114983-Leuchte5 TFL RB6-Light_Function_E_5,not_activ ,16
ENG124866-ENG114984-Leuchte5 TFL RB6-Light_Function_F_5,not_activ ,16
ENG124866-ENG114987-Leuchte5 TFL RB6-Light_Function_G_5,not_activ ,16
ENG124866-ENG114988-Leuchte5 TFL RB6-Light_Function_H_5,not_activ ,16
ENG124866-ENG114973-Leuchte5 TFL RB6-Type_Of_Load_5,allgemeine_LED_6W ,16
ENG124867-ENG115115-Leuchte6ABL LB44-Dimming_AB_6,100 ,16
ENG124867-ENG115119-Leuchte6ABL LB44-Dimming_CD_6,0 ,16
ENG124867-ENG115120-Leuchte6ABL LB44-Dimming_Direction_CD_6,maximize ,16
ENG124867-ENG115124-Leuchte6ABL LB44-Dimming_Direction_EF_6,maximize ,16
ENG124867-ENG115128-Leuchte6ABL LB44-Dimming_Direction_GH_6,maximize ,16
ENG124867-ENG115123-Leuchte6ABL LB44-Dimming_EF_6,0 ,16
ENG124867-ENG115127-Leuchte6ABL LB44-Dimming_GH_6,0 ,16
ENG124867-ENG126581-Leuchte6ABL LB44-Fehlerort_mittleres_Byte_DTC-DFCC_6,26 ,16
ENG124867-ENG115765-Leuchte6ABL LB44-Lampendefektbit_Position_6,54 ,16
ENG124867-ENG115116-Leuchte6ABL LB44-Light_Control_HD_AB_6,Always ,16
ENG124867-ENG115113-Leuchte6ABL LB44-Light_Function_A_6,Abblendlichtlinks ,16
ENG124867-ENG115114-Leuchte6ABL LB44-Light_Function_B_6,coming_home_leaving_home ,16
ENG124867-ENG115117-Leuchte6ABL LB44-Light_Function_C_6,not_activ ,16
ENG124867-ENG115118-Leuchte6ABL LB44-Light_Function_D_6,not_activ ,16
ENG124867-ENG115121-Leuchte6ABL LB44-Light_Function_E_6,not_activ ,16
ENG124867-ENG115122-Leuchte6ABL LB44-Light_Function_F_6,not_activ ,16
ENG124867-ENG115125-Leuchte6ABL LB44-Light_Function_G_6,not_activ ,16
ENG124867-ENG115126-Leuchte6ABL LB44-Light_Function_H_6,not_activ ,16
ENG124867-ENG115110-Leuchte6ABL LB44-Type_Of_Load_6,Low beam ,16
ENG124868-ENG115134-Leuchte7ABL RB5-Dimming_AB_7,100 ,16
ENG124868-ENG115138-Leuchte7ABL RB5-Dimming_CD_7,0 ,16
ENG124868-ENG115139-Leuchte7ABL RB5-Dimming_Direction_CD_7,maximize ,16
ENG124868-ENG115143-Leuchte7ABL RB5-Dimming_Direction_EF_7,maximize ,16
ENG124868-ENG115147-Leuchte7ABL RB5-Dimming_Direction_GH_7,maximize ,16
ENG124868-ENG115142-Leuchte7ABL RB5-Dimming_EF_7,0 ,16
ENG124868-ENG115146-Leuchte7ABL RB5-Dimming_GH_7,0 ,16
ENG124868-ENG126582-Leuchte7ABL RB5-Fehlerort_mittleres_Byte_DTC-DFCC_7,27 ,16
ENG124868-ENG115807-Leuchte7ABL RB5-Lampendefektbit_Position_7,64 ,16
ENG124868-ENG115135-Leuchte7ABL RB5-Light_Control_HD_AB_7,Always ,16
ENG124868-ENG115132-Leuchte7ABL RB5-Light_Function_A_7,Abblendlichtrechts ,16
ENG124868-ENG115133-Leuchte7ABL RB5-Light_Function_B_7,coming_home_leaving_home ,16
ENG124868-ENG115136-Leuchte7ABL RB5-Light_Function_C_7,not_activ ,16
ENG124868-ENG115137-Leuchte7ABL RB5-Light_Function_D_7,not_activ ,16
ENG124868-ENG115140-Leuchte7ABL RB5-Light_Function_E_7,not_activ ,16
ENG124868-ENG115141-Leuchte7ABL RB5-Light_Function_F_7,not_activ ,16
ENG124868-ENG115144-Leuchte7ABL RB5-Light_Function_G_7,not_activ ,16
ENG124868-ENG115145-Leuchte7ABL RB5-Light_Function_H_7,not_activ ,16
ENG124868-ENG115129-Leuchte7ABL RB5-Type_Of_Load_7,Low beam ,16
ENG124869-ENG115153-Leuchte8FL LB42-Dimming_AB_8,100 ,16
ENG124869-ENG115157-Leuchte8FL LB42-Dimming_CD_8,0 ,16
ENG124869-ENG115158-Leuchte8FL LB42-Dimming_Direction_CD_8,maximize ,16
ENG124869-ENG115162-Leuchte8FL LB42-Dimming_Direction_EF_8,maximize ,16
ENG124869-ENG115147-Leuchte8FL LB42-Dimming_Direction_GH_7,maximize ,16
ENG124869-ENG115161-Leuchte8FL LB42-Dimming_EF_8,0 ,16
ENG124869-ENG115165-Leuchte8FL LB42-Dimming_GH_8,0 ,16
ENG124869-ENG126583-Leuchte8FL LB42-Fehlerort_mittleres_Byte_DTC-DFCC_8,28 ,16
ENG124869-ENG115798-Leuchte8FL LB42-Lampendefektbit_Position_8,55 ,16
ENG124869-ENG115154-Leuchte8FL LB42-Light_Control_HD_AB_8,Always ,16
ENG124869-ENG115151-Leuchte8FL LB42-Light_Function_A_8,Fernlichtlinks ,16
ENG124869-ENG115152-Leuchte8FL LB42-Light_Function_B_8,Headlamp flasher ,16
ENG124869-ENG115155-Leuchte8FL LB42-Light_Function_C_8,not_activ ,16
ENG124869-ENG115156-Leuchte8FL LB42-Light_Function_D_8,not_activ ,16
ENG124869-ENG115159-Leuchte8FL LB42-Light_Function_E_8,not_activ ,16
ENG124869-ENG115160-Leuchte8FL LB42-Light_Function_F_8,not_activ ,16
ENG124869-ENG115163-Leuchte8FL LB42-Light_Function_G_8,not_activ ,16
ENG124869-ENG115164-Leuchte8FL LB42-Light_Function_H_8,not_activ ,16
ENG124869-ENG115148-Leuchte8FL LB42-Type_Of_Load_8,allgemeine_Scheinwerfer_ohne_Abschaltung ,16
ENG124870-ENG115172-Leuchte9FL RB7-Dimming_AB_9,100 ,16
ENG124870-ENG115176-Leuchte9FL RB7-Dimming_CD_9,0 ,16
ENG124870-ENG115177-Leuchte9FL RB7-Dimming_Direction_CD_9,maximize ,16
ENG124870-ENG115181-Leuchte9FL RB7-Dimming_Direction_EF_9,maximize ,16
ENG124870-ENG115185-Leuchte9FL RB7-Dimming_Direction_GH_9,maximize ,16
ENG124870-ENG115180-Leuchte9FL RB7-Dimming_EF_9,0 ,16
ENG124870-ENG115184-Leuchte9FL RB7-Dimming_GH_9,0 ,16
ENG124870-ENG126584-Leuchte9FL RB7-Fehlerort_mittleres_Byte_DTC-DFCC_9,29 ,16
ENG124870-ENG115804-Leuchte9FL RB7-Lampendefektbit_Position_9,65 ,16
ENG124870-ENG115173-Leuchte9FL RB7-Light_Control_HD_AB_9,Always ,16
ENG124870-ENG115170-Leuchte9FL RB7-Light_Function_A_9,Fernlichtrechts ,16
ENG124870-ENG115171-Leuchte9FL RB7-Light_Function_B_9,Headlamp flasher ,16
ENG124870-ENG115174-Leuchte9FL RB7-Light_Function_C_9,not_activ ,16
ENG124870-ENG115175-Leuchte9FL RB7-Light_Function_D_9,not_activ ,16
ENG124870-ENG115178-Leuchte9FL RB7-Light_Function_E_9,not_activ ,16
ENG124870-ENG115179-Leuchte9FL RB7-Light_Function_F_9,not_activ ,16
ENG124870-ENG115182-Leuchte9FL RB7-Light_Function_G_9,not_activ ,16
ENG124870-ENG115183-Leuchte9FL RB7-Light_Function_H_9,not_activ ,16
ENG124870-ENG115167-Leuchte9FL RB7-Type_Of_Load_9,allgemeine_Scheinwerfer_ohne_Abschaltung ,16
ENG124875-ENG115233-Leuchten14LOCKUNLOCKC61-Dimming_AB_14,100 ,16
ENG124875-ENG115237-Leuchten14LOCKUNLOCKC61-Dimming_CD_14,0 ,16
ENG124875-ENG115238-Leuchten14LOCKUNLOCKC61-Dimming_Direction_CD_14,maximize ,16
ENG124875-ENG115242-Leuchten14LOCKUNLOCKC61-Dimming_Direction_EF_14,maximize ,16
ENG124875-ENG115246-Leuchten14LOCKUNLOCKC61-Dimming_Direction_GH_14,maximize ,16
ENG124875-ENG115241-Leuchten14LOCKUNLOCKC61-Dimming_EF_14,0 ,16
ENG124875-ENG115245-Leuchten14LOCKUNLOCKC61-Dimming_GH_14,0 ,16
ENG124875-ENG126589-Leuchten14LOCKUNLOCKC61-Fehlerort_mittleres_Byte_DTC-DFCC_14,0 ,16
ENG124875-ENG115786-Leuchten14LOCKUNLOCKC61-Lampendefektbit_Position_14,0 ,16
ENG124875-ENG115234-Leuchten14LOCKUNLOCKC61-Light_Control_HD_AB_14,Always ,16
ENG124875-ENG115231-Leuchten14LOCKUNLOCKC61-Light_Function_A_14,Lock_Unlock_LED ,16
ENG124875-ENG115232-Leuchten14LOCKUNLOCKC61-Light_Function_B_14,not_activ ,16
ENG124875-ENG115235-Leuchten14LOCKUNLOCKC61-Light_Function_C_14,not_activ ,16
ENG124875-ENG115236-Leuchten14LOCKUNLOCKC61-Light_Function_D_14,not_activ ,16
ENG124875-ENG115239-Leuchten14LOCKUNLOCKC61-Light_Function_E_14,not_activ ,16
ENG124875-ENG115240-Leuchten14LOCKUNLOCKC61-Light_Function_F_14,not_activ ,16
ENG124875-ENG115243-Leuchten14LOCKUNLOCKC61-Light_Function_G_14,not_activ ,16
ENG124875-ENG115244-Leuchten14LOCKUNLOCKC61-Light_Function_H_14,not_activ ,16
ENG124875-ENG115228-Leuchten14LOCKUNLOCKC61-Type_Of_Load_14,LED_Kleinleistung_ohne_OL_mitUeberspg_absch ,16
ENG148593-Leuchtenkonfiguration (Aussenlicht Heck),0C 08 00 16 02 00 64 00 00 00 00 00 00 00 00 00 0C 18 00 18 04 00 64 00 00 00 00 00 00 00 00 00 27 09 00 2B 18 00 7F 00 00 00 00 00 00 00 00 00 27 19 00 2D 18 00 7F 00 00 00 00 00 00 00 00 00 2A 29 00 2C 18 00 64 00 00 00 00 00 00 00 00 00 20 0A 00 29 08 09 7F 00 00 00 00 00 00 00 00 00 20 1A 00 2A 08 0A 7F 00 00 00 00 00 00 00 00 00 20 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2D 0C 00 2E 1A 00 7F 00 00 00 00 00 00 00 00 00 1A 2B 00 34 19 00 64 00 00 00 00 00 00 00 00 00 ,160
ENG148594-Leuchtenkonfiguration (Sonstiges),24 00 00 00 3E 00 64 00 00 00 00 00 00 00 00 00 24 00 00 00 3F 00 64 00 00 00 00 00 00 00 00 00 24 00 00 00 40 00 7F 00 00 00 00 00 00 00 00 00 24 00 00 00 02 00 64 00 00 00 00 00 00 00 00 00 24 00 00 00 04 00 64 00 00 00 00 00 00 00 00 00 24 00 00 08 26 00 64 00 00 00 00 00 00 00 00 00 08 00 00 01 25 00 64 00 00 00 00 00 00 00 00 00 08 00 00 07 29 00 7E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,192
ENG126648-MAS02526-LIN-Mirrormode-Activation,not active ,1
ENG126648-ENG149044-LIN-Mirrormode-LIN4,not active ,1
ENG126648-ENG149045-LIN-Mirrormode-LIN5,not active ,1
ENG148592-ENG115658-LuB_Lichtrouter_Kennlinie_1-x0,0.0 %,12
ENG148592-ENG101574-LuB_Lichtrouter_Kennlinie_1-X1,0.0 %,12
ENG148592-ENG99557-LuB_Lichtrouter_Kennlinie_1-X2,0.0 %,12
ENG148592-ENG102140-LuB_Lichtrouter_Kennlinie_1-X3,0.0 %,12
ENG148592-ENG102936-LuB_Lichtrouter_Kennlinie_1-X4,0.0 %,12
ENG148592-ENG103548-LuB_Lichtrouter_Kennlinie_1-X5,0.0 %,12
ENG148592-ENG115659-LuB_Lichtrouter_Kennlinie_1-y0,0.0 %,12
ENG148592-ENG99777-LuB_Lichtrouter_Kennlinie_1-Y1,0.0 %,12
ENG148592-ENG100480-LuB_Lichtrouter_Kennlinie_1-Y2,0.0 %,12
ENG148592-ENG100773-LuB_Lichtrouter_Kennlinie_1-Y3,0.0 %,12
ENG148592-ENG100631-LuB_Lichtrouter_Kennlinie_1-Y4,0.0 %,12
ENG148592-ENG102174-LuB_Lichtrouter_Kennlinie_1-Y5,0.0 %,12
ENG122979-MAS00075-Networking-ABS Control Module,installed ,8
ENG122979-MAS00798-Networking-Transmission Control Module (TCM),not installed ,8
ENG122979-MAS01374-Networking-Trailer,installed ,8
ENG122979-MAS03175-Networking-Extended data bus,not installed ,8
ENG122979-MAS09880-Networking-Interval potentiometer,installed ,8
ENG122979-MAS09882-Networking-MFA button on BCM,not installed ,8
ENG122979-MAS10518-Networking-A/C electronics,installed ,8
ENG122979-MAS10570-Networking-Window lift type,MQB_window_regulator ,8
ENG122979-ENG149007-Networking-Door LIN,installed ,8
ENG122979-ENG252084-Networking-KL30_weckfaehig,wakable ,8
ENG122979-ENG149008-Networking-Roof LIN,not installed ,8
ENG122979-ENG149009-Networking-Sounder LIN,not installed ,8
ENG122979-ENG149010-Networking-Wiper LIN,not installed ,8
ENG124714-ENG142044-OCU-DWA_push,active ,8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,active ,8
ENG124714-OCU-,installed ,8
ENG124714-ENG179221-OCU-Remote Lock Unlock Timer s0,15 s,8
ENG124714-ENG179222-OCU-Remote Lock Unlock Timer s2,15 s,8
ENG124714-ENG179223-OCU-Remote Lock Unlock Timer s4,15 s,8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock,Via BAP / Fazit ,8
ENG124714-ENG154722-OCU-RHF_Panikalarm,active ,8
ENG117304-ENG148862-Patch_Code_Driver_Side_Rear-Parameter_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG117304-ENG148865-Patch_Code_Driver_Side_Rear-Parameter_2,00 00 ,128
ENG117308-ENG148862-Patch_Code_Passenger_Side_Rear-Parameter_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG117308-ENG148865-Patch_Code_Passenger_Side_Rear-Parameter_2,00 00 ,128
ENG141646-MAS00481-Querschnitts_funktionen-BAP,active ,5
ENG141646-MAS01065-Querschnitts_funktionen-Brand,VW ,5
ENG141646-MAS04194-Querschnitts_funktionen-Driver side,Left ,5
ENG141646-MAS10509-Querschnitts_funktionen-Traffic,Right ,5
ENG141646-MAS10511-Querschnitts_funktionen-Personalization transfer,not installed ,5
ENG141646-MAS10527-Querschnitts_funktionen-Tracking System,not active ,5
ENG141646-ENG252090-Querschnitts_funktionen-anhaengerrangierassistent,not active ,5
ENG141646-ENG149084-Querschnitts_funktionen-CAN_Wecken_bei_Softtouchbetaetigung,not active ,5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Sollspannungsanforderung 13.5 ,5
ENG141646-ENG149085-Querschnitts_funktionen-Klemmenfehler_auf_CAN_ausgeben,not active ,5
ENG141646-ENG126575-Querschnitts_funktionen-mute_mode_aktiv,not active ,5
ENG141646-ENG148952-Querschnitts_funktionen-P_locked,not installed ,5
ENG141646-ENG125011-Querschnitts_funktionen-pa_Funktion_2aus3,not installed ,5
ENG115729-IDE05534-Scheinwerferreinigung-Headlamp washer system,not installed ,10
ENG115729-ENG149254-Scheinwerferreinigung-Adaptives_Nachwischen_bei_SRA,active ,10
ENG115729-ENG149255-Scheinwerferreinigung-Anzahl_Betaetigungen_Frontwaschanlage_pro_SRA_Aktivierung,10 ,10
ENG115729-ENG149253-Scheinwerferreinigung-SRA_bei_Waschwassermangel,active ,10
ENG115729-ENG149258-Scheinwerferreinigung-SRA_Einweichpausenzeit,2000 ms,10
ENG115729-ENG149259-Scheinwerferreinigung-SRA_Nachwaschzeit,800 ms,10
ENG115729-ENG149260-Scheinwerferreinigung-SRA_Pausenzeit,10000 ms,10
ENG115729-ENG149256-Scheinwerferreinigung-SRA_Verzoegerungszeit,0 ms,10
ENG115729-ENG149257-Scheinwerferreinigung-SRA_Waschzeit,800 ms,10
ENG115729-ENG148897-Scheinwerferreinigung-windshield_washer_system,not installed ,10
ENG116588-MAS10520-Sonderfunktionen-Special function 1,not installed ,4
ENG116588-ENG273845-Sonderfunktionen-Blinkerueberwachung_MFG,not installed ,4
ENG116588-ENG130186-Sonderfunktionen-Signalprioritaet_fuer_Blinker,SMLS ,4
ENG116588-ENG126568-Sonderfunktionen-Sonderfunktionen_2,not enabled ,4
ENG141635-ENG149220-Spiegelverstellung-Funk_Spiegelanklappen,not active ,5
ENG141635-ENG149221-Spiegelverstellung-Funk_Spiegelanklappung_Modus,by_convenience_operation_via_remote_control_key ,5
ENG141635-ENG149219-Spiegelverstellung-Menue__Spiegel_absenkung,not active ,5
ENG141635-ENG149222-Spiegelverstellung-Menuesteuerung_Funk_Spiegel_anklappen,not active ,5
ENG141635-ENG149043-Spiegelverstellung-only_ECU_FHSG_Driver_side,not installed ,5
ENG141635-ENG149223-Spiegelverstellung-Profilfunktion_fuer_Anklappung_der_Aussenspiegel,active ,5
ENG141635-ENG155908-Spiegelverstellung-Spiegel_ausklappen_ueber_FFB_auf,not active ,5
ENG141635-ENG149218-Spiegelverstellung-Spiegelabsenkung_bei_Rueckwaertsfahrt,not active ,5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung,not active ,5
ENG141635-ENG149224-Spiegelverstellung-Spiegelanklappung_geschwindigkeitsabhaengig,not active ,5
ENG141635-ENG149041-Spiegelverstellung-window_regulator_node_adress,getauscht ,5
ENG153969-ENG115658-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-x0,0.0 lx,10
ENG153969-ENG101574-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X1,8.0 lx,10
ENG153969-ENG99557-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X2,50.0 lx,10
ENG153969-ENG102140-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X3,80.0 lx,10
ENG153969-ENG102936-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X4,100.0 lx,10
ENG153969-ENG115659-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-y0,6.0 ,10
ENG153969-ENG99777-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y1,6.0 ,10
ENG153969-ENG100480-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y2,20.0 ,10
ENG153969-ENG100773-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y3,50.0 ,10
ENG153969-ENG100631-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y4,100.0 ,10
ENG153971-ENG115658-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-x0,0.0 lx,10
ENG153971-ENG101574-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X1,8.0 lx,10
ENG153971-ENG99557-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X2,50.0 lx,10
ENG153971-ENG102140-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X3,80.0 lx,10
ENG153971-ENG102936-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X4,100.0 lx,10
ENG153971-ENG115659-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-y0,6.0 ,10
ENG153971-ENG99777-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y1,6.0 ,10
ENG153971-ENG100480-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y2,20.0 ,10
ENG153971-ENG100773-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y3,50.0 ,10
ENG153971-ENG100631-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y4,100.0 ,10
ENG141632-MAS10512-Sunroof-Sunroof module MD1,not installed ,4
ENG141632-MAS10513-Sunroof-Sunroof module MD shade,not installed ,4
ENG141632-ENG149217-Sunroof-SAD_Komfort_oeffnen,not active ,4
ENG141632-ENG149216-Sunroof-SAD_Komfort_schliessen,not active ,4
ENG141632-ENG149215-Sunroof-SAD_Richtung_Komfortoeffnen,Open ,4
ENG248473-ENG261749-Türen HBFS-pa_NFZ_Funktion_HBFS_1,not active ,2
ENG248473-ENG248779-Türen HBFS-pa_Schiebetür_HBFS,No ,2
ENG248473-ENG248781-Türen HBFS-pa_schlosstyp_HBFS,No ,2
ENG248473-ENG248785-Türen HBFS-pa_tuerkontaktmodul_hbfs,ohne TKM ,2
ENG248474-ENG261743-Türen HFS-pa_NFZ_Funktion_HFS_1,not active ,2
ENG248474-ENG248780-Türen HFS-pa_Schiebetür_HFS,No ,2
ENG248474-ENG248783-Türen HFS-pa_schlosstyp_HFS,No ,2
ENG248474-ENG248786-Türen HFS-pa_tuerkontaktmodul_hfs,ohne TKM ,2
ENG148611-MAS10548-Verbau Personalisierung-Profile function,Key profile ,8
ENG148611-ENG252096-Verbau Personalisierung-Aktiver_Teilnehmer_Doorlocking_aktiviert,active ,8
ENG148611-ENG252051-Verbau Personalisierung-Aktiver_Teilnehmer_ExteriorLight_aktiviert,active ,8
ENG148611-ENG252071-Verbau Personalisierung-Aktiver_Teilnehmer_InteriorLight_aktiviert,active ,8
ENG148611-ENG252085-Verbau Personalisierung-Aktiver_Teilnehmer_Mirror_aktiviert,active ,8
ENG148611-ENG252072-Verbau Personalisierung-Aktiver_Teilnehmer_WiperComfort_aktiviert,active ,8
ENG148611-ENG126849-Verbau Personalisierung-Aktivierungsoption_im_HMI-Menue_sichtbar,active ,8
ENG148611-ENG133401-Verbau Personalisierung-Anzahl_Benutzerkonten,7 ,8
ENG148611-ENG133402-Verbau Personalisierung-Automatische_ Schluesselzuordnung,not active ,8
ENG148611-ENG126850-Verbau Personalisierung-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,active ,8
ENG148611-ENG246970-Verbau Personalisierung-IAA -Nutzer_management,installed ,8
ENG148611-ENG246991-Verbau Personalisierung-pa_Two_Keys,active ,8
ENG148611-ENG126848-Verbau Personalisierung-Personalisierung_aktiv,active ,8
ENG148611-ENG126851-Verbau Personalisierung-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,active ,8
ENG148611-ENG142030-Verbau Personalisierung-Profil_Variante,Konto (v. 2.x) ,8
ENG148611-ENG133403-Verbau Personalisierung-PSO_FSG_Setup2_Bit_0,active ,8
ENG148611-ENG133404-Verbau Personalisierung-PSO_FSG_Setup2_Bit_1,active ,8
ENG148611-ENG133405-Verbau Personalisierung-PSO_FSG_Setup2_Bit_2,not active ,8
ENG148611-ENG133406-Verbau Personalisierung-PSO_FSG_Setup2_Bit_3,not active ,8
ENG148611-ENG133407-Verbau Personalisierung-PSO_FSG_Setup2_Bit_4,not active ,8
ENG148611-ENG133408-Verbau Personalisierung-PSO_FSG_Setup2_Bit_5,not active ,8
ENG148611-ENG133409-Verbau Personalisierung-PSO_FSG_Setup2_Bit_6,not active ,8
ENG148611-ENG133410-Verbau Personalisierung-PSO_FSG_Setup2_Bit_7,not active ,8
ENG148610-ENG148877-Vernetzungs-_Diagnosefunktionen-can_msg_1,00 00 ,20
ENG148610-ENG148878-Vernetzungs-_Diagnosefunktionen-can_msg_2,00 00 ,20
ENG148610-ENG148879-Vernetzungs-_Diagnosefunktionen-can_msg_3,00 00 ,20
ENG148610-ENG148880-Vernetzungs-_Diagnosefunktionen-can_msg_4,00 00 ,20
ENG148610-ENG148881-Vernetzungs-_Diagnosefunktionen-lin_msg_1,00 00 ,20
ENG148610-ENG148882-Vernetzungs-_Diagnosefunktionen-lin_msg_2,00 00 ,20
ENG148610-ENG148883-Vernetzungs-_Diagnosefunktionen-lin_msg_3,00 00 ,20
ENG148610-ENG148884-Vernetzungs-_Diagnosefunktionen-lin_msg_4,00 00 ,20
ENG148610-ENG148885-Vernetzungs-_Diagnosefunktionen-lin_msg_5,00 00 ,20
ENG148610-ENG148886-Vernetzungs-_Diagnosefunktionen-lin_msg_6,00 00 ,20
ENG148612-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_1-Parameter_1,04 04 90 19 02 00 00 00 FF BE FF 07 D0 10 10 F6 00 C8 32 0B 0F 03 84 01 90 F0 F0 F0 00 20 FC 7C 00 14 00 0A 01 2C 07 00 00 01 5E 04 07 0C 14 32 0F 9A 00 02 98 10 00 02 51 C0 00 B4 00 0C 00 0C 00 27 00 50 00 89 00 D1 01 29 01 7B 04 04 03 01 03 07 03 E8 00 00 05 05 0F 2D 50 73 04 04 27 10 19 04 C0 70 D3 00 4E 53 12 12 0C 03 00 EF 01 00 00 07 5A 0B 00 0E 53 6D 03 00 10 80 0C 00 ,128
ENG148612-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_1-Parameter_2,4F CA ,128
ENG148613-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_2-Parameter_1,03 84 02 EE 14 1E EC 01 0B 02 08 05 00 28 0A 05 46 02 1E 19 0A 00 0A F4 32 1E 10 00 03 FD 0A 0A F6 12 0D 00 00 00 00 00 00 00 00 00 00 00 00 00 28 00 2A 1E 20 1E 32 64 D8 C4 F1 F6 28 1E 05 1E 00 00 32 06 37 0E 10 0C 32 C8 F6 E7 F6 FB 19 14 00 0C 14 01 5E 06 41 0E 10 0E 32 64 F6 E7 F1 F6 14 12 00 0B 14 19 19 96 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG148613-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_2-Parameter_2,06 90 ,128
ENG130135-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_3-Parameter_1,29 02 25 05 0B FD 00 6E 0D 10 3F 50 50 50 5C 64 80 A7 50 5C 4B 4B 4B 4B 0A 0A 0A 0A FF FF 00 00 32 32 64 64 00 02 0A 02 32 06 64 0A DC 50 FD 64 F0 0D 00 02 02 00 00 00 00 00 00 01 E0 3C 02 28 00 00 02 02 01 01 20 28 14 02 31 40 02 11 24 38 52 28 13 06 4D 26 11 06 54 2A 14 06 5C 33 1A 09 05 DC 05 DC 00 05 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130135-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_3-Parameter_2,92 E6 ,128
ENG117302-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1-Parameter_1,00 00 14 83 2B 14 F0 F0 F0 00 20 00 FC 7C 00 14 00 05 06 64 01 F4 32 0F 00 07 80 00 00 07 3F 80 00 B4 00 0C 00 0C 00 27 00 50 00 89 00 D1 01 29 01 7B 04 04 03 01 03 07 03 E8 0B B8 32 05 0F 2D 50 73 04 04 9A 3C 09 1A 36 63 00 83 E0 E7 04 4E 53 70 C0 00 03 00 0C 00 AF 01 6E 5A 01 90 85 07 D0 10 10 00 14 00 14 03 84 27 10 53 6D 03 00 10 80 0C 0F FF BF FF 00 00 00 0A 01 00 00 00 ,128
ENG117302-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1-Parameter_2,24 23 ,128
ENG117303-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_Rear_2-Parameter_1,03 20 02 BC 14 EC 04 02 02 0A 02 02 00 0A 05 28 02 14 19 0F 00 05 EC 19 1E 14 00 05 FB 05 05 FB 12 0D 00 00 00 00 FF 00 00 00 00 FF 00 1E 00 19 1E 20 1E FA E2 CE F1 F6 28 1E 32 08 1E 00 00 28 02 20 0E 14 12 C8 EC E2 F1 F6 19 14 28 00 0B 28 01 2C 02 20 0E 14 12 FA EC E2 F1 F6 19 14 28 00 0B 28 0A 28 0A 0A 28 23 05 0A 28 1E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG117303-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_Rear_2-Parameter_2,F9 74 ,128
ENG130138-ENG148862-Window_Regulator_Supplier_Settings_Passener_Side_1-Parameter_1,04 04 90 19 02 00 00 00 FF BE FF 07 D0 10 10 F6 00 C8 32 0B 0F 03 84 01 90 F0 F0 F0 00 20 FC 7C 00 14 00 0A 01 2C 07 00 00 01 5E 04 07 0C 14 32 0F 9A 00 02 98 10 00 02 51 C0 00 B4 00 0C 00 0C 00 27 00 50 00 89 00 D1 01 29 01 7B 04 04 03 01 03 07 03 E8 00 00 05 05 0F 2D 50 73 04 04 27 10 19 04 C0 70 D3 00 4E 53 12 12 0C 03 00 8F 01 00 00 07 5A 0B 00 0E 53 6D 03 00 10 80 0C 00 ,128
ENG130138-ENG148865-Window_Regulator_Supplier_Settings_Passener_Side_1-Parameter_2,0B CC ,128
ENG130139-ENG148862-Window_Regulator_Supplier_Settings_Passener_Side_2-Parameter_1,03 84 02 EE 14 1E EC 01 0B 02 08 05 00 28 0A 05 46 02 1E 19 0A 00 0A F4 32 1E 10 00 03 FD 0A 0A F6 12 0D 00 00 00 00 00 00 00 00 00 00 00 00 00 28 00 2A 1E 20 1E 32 64 D8 C4 F1 F6 28 1E 05 1E 00 00 32 06 37 0E 10 0C 32 C8 F6 E7 F6 FB 19 14 00 0C 14 01 5E 06 41 0E 10 0E 32 64 F6 E7 F1 F6 14 12 00 0B 14 19 19 96 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130139-ENG148865-Window_Regulator_Supplier_Settings_Passener_Side_2-Parameter_2,06 90 ,128
ENG130140-ENG148862-Window_Regulator_Supplier_Settings_Passener_Side_3-Parameter_1,29 02 25 05 0B FD 00 6E 0D 10 3F 50 50 50 5C 64 80 A7 50 5C 4B 4B 4B 4B 0A 0A 0A 0A FF FF 00 00 32 32 64 64 00 02 0A 02 32 06 64 0A DC 50 FD 64 F0 0D 00 02 02 00 00 00 00 00 00 01 E0 3C 02 28 00 00 02 02 01 01 20 28 14 02 31 40 02 11 24 38 52 28 13 06 4D 26 11 06 54 2A 14 06 5C 33 1A 09 05 DC 05 DC 0E 05 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130140-ENG148865-Window_Regulator_Supplier_Settings_Passener_Side_3-Parameter_2,78 6E ,128
ENG117306-ENG148862-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1-Parameter_1,00 00 14 83 2B 14 F0 F0 F0 00 20 00 FC 7C 00 14 00 05 06 64 01 F4 32 0F 00 07 80 00 00 07 3F 80 00 B4 00 0C 00 0C 00 27 00 50 00 89 00 D1 01 29 01 7B 04 04 03 01 03 07 03 E8 0B B8 32 05 0F 2D 50 73 04 04 9A 3C 09 1A 36 63 00 83 E0 E7 04 4E 53 70 C0 00 03 00 0C 00 0F 01 6E 5A 01 90 85 07 D0 10 10 00 14 00 14 03 84 27 10 53 6D 03 00 10 80 0C 0F FF BF FF 00 00 00 0A 01 00 00 00 ,128
ENG117306-ENG148865-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1-Parameter_2,77 AB ,128
ENG117307-ENG148862-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_2-Parameter_1,03 20 02 BC 14 EC 04 02 02 0A 02 02 00 0A 05 28 02 14 19 0F 00 05 EC 19 1E 14 00 05 FB 05 05 FB 12 0D 00 00 00 00 FF 00 00 00 00 FF 00 1E 00 19 1E 20 1E FA E2 CE F1 F6 28 1E 32 08 1E 00 00 28 02 20 0E 14 12 C8 EC E2 F1 F6 19 14 28 00 0B 28 01 2C 02 20 0E 14 12 FA EC E2 F1 F6 19 14 28 00 0B 28 0A 28 0A 0A 28 23 05 0A 28 1E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG117307-ENG148865-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_2-Parameter_2,F9 74 ,128
ENG124895-Window_Regulator_VW_Settings_Driver_Side,F0 08 FF F0 00 10 C8 19 0F 00 14 14 00 14 C8 28 32 32 03 01 00 00 00 00 01 A4 01 B8 00 09 64 00 00 00 00 00 00 00 00 00 00 00 00 86 96 96 06 C8 4E 4D 79 32 14 1E CD C6 14 0A 60 E6 6D D9 64 14 32 0A 0A 0B 0F 0F 1E 0F 3C 50 00 64 55 3A 06 00 B4 01 00 0A 00 14 00 00 ,128
ENG117301-Window_Regulator_VW_Settings_Driver_Side_Rear,F6 00 F0 00 10 19 0F 03 F0 08 00 14 C8 00 00 00 01 5E 01 72 09 64 23 C8 23 00 32 32 01 90 00 00 00 00 00 00 00 A0 00 00 32 3C C8 00 4E 00 4D 79 64 64 32 60 CD 6D C6 64 14 32 0A 0A 60 E6 6D D9 64 14 32 0A 0A 14 00 00 42 44 32 37 01 00 00 00 00 00 00 00 00 00 F0 B8 ,88
ENG130137-Window_Regulator_VW_Settings_Passenger_Side,F0 08 FF F0 00 10 C8 19 0F 00 14 14 00 14 C8 28 32 32 03 01 00 00 00 00 01 A4 01 B8 00 09 64 00 00 00 00 00 00 00 00 00 00 00 00 86 32 32 06 C8 4E 4D 79 32 14 1E CD C6 14 0A 60 E6 6D D9 64 14 32 0A 0A 0B 0F 0F 1E 0F 3C 50 00 64 55 3A 06 00 E1 01 00 0A 00 14 00 00 ,128
ENG117305-Window_Regulator_VW_Settings_Passenger_Side_Rear,F6 00 F0 00 10 19 0F 03 F0 08 00 14 C8 00 00 00 01 5E 01 72 09 64 23 C8 23 00 32 32 01 90 00 00 00 00 00 00 00 A0 00 00 32 3C C8 00 4E 00 4D 79 00 00 32 60 CD 6D C6 64 14 32 0A 0A 60 E6 6D D9 64 14 32 0A 0A 14 00 00 42 44 32 37 01 00 00 00 00 00 00 00 00 00 FD 3E ,88
ENG148493-ENG115721-Windshield wiper-Frontwischer,Sollspannungsanforderung 13.5 ,6
ENG148493-ENG133394-Windshield wiper-Frontwischer_Abtauposition,keine_Abtaupostition ,6
ENG148493-ENG149235-Windshield wiper-Frontwischer_Referenzlauf,active ,6
ENG148493-ENG126573-Windshield wiper-Frontwischer_Serviceposition,active ,6
ENG148493-ENG149241-Windshield wiper-Geschwindigkeitsabhaengige_Wischstufenrueckschaltung,active ,6
ENG148493-ENG149239-Windshield wiper-Menuesteuerung_Frontwischer,not active ,6
ENG148493-ENG154706-Windshield wiper-Mindestwaschzeit_Frontwischer,0 ms,6
ENG148493-ENG149042-Windshield wiper-rain_sensor_function,not installed ,6
ENG148493-ENG149238-Windshield wiper-Regensensor_aktivieren,not active ,6
ENG148493-ENG149242-Windshield wiper-Traenenwischen_Front_Status,not active ,6
ENG148493-ENG126844-Windshield wiper-Washer_Tipwiping_Variant,active ,6
ENG148493-ENG148995-Windshield wiper-windshield_wiper_typ,Direct ,6
ENG148493-ENG149237-Windshield wiper-Wischer_abparken_bei_Oeffnen_der_Motorhaube,not active ,6
ENG148493-ENG149236-Windshield wiper-Wischer_stop_bei_KL15_aus,not active ,6
ENG148493-ENG149244-Windshield wiper-Wischer_stop_bei_Motorstart,immer_Wischerstopp ,6
ENG148493-ENG149243-Windshield wiper-Wischer_Stopp_bei_Oeffnen_der_Motorhaube,active ,6
ENG141651-MAS10522-ZV allgemein-Lock/unlock: direct button,Rocker sw. ,5
ENG141651-MAS10546-ZV allgemein-Radio freq.,434.42MHz ,5
ENG141651-MAS10554-ZV allgemein-Central locking without SAFE function,installed ,5
ENG141651-ENG179102-ZV allgemein-Abgesichertes Safen,not active ,5
ENG141651-ENG252045-ZV allgemein-Anti_theft_alarm_diagnostic_connection_monitoring,not active ,5
ENG141651-ENG248507-ZV allgemein-Auswertung_Batt_TranspID_Telegramm,not active ,5
ENG141651-ENG179106-ZV allgemein-Autolock_nur_bei_Motorlauf,not active ,5
ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,not active ,5
ENG141651-ENG252065-ZV allgemein-FFB_Sbt_Entriegelt,No ,5
ENG141651-ENG149179-ZV allgemein-Funk_bei_Klemme_15_ein,not active ,5
ENG141651-ENG179144-ZV allgemein-Kessy Wiederentriegelung mit Außenhaut,not active ,5
ENG141651-ENG149181-ZV allgemein-Menuesteuerung_Tuerentriegelung,active ,5
ENG141651-ENG115755-ZV allgemein-Notschließfunktion,active ,5
ENG141651-ENG179092-ZV allgemein-Schlossansteuerung,all_doors_connected_directly ,5
ENG141651-ENG149384-ZV allgemein-seitenselektive_Oeffnung,Yes ,5
ENG141651-ENG149180-ZV allgemein-ZV_Tuerentriegelung,Globale_Entriegelung ,5
ENG141654-ENG149213-ZV Autolock-Autolock_Autounlock_wirkt_auf_Heck,active ,5
ENG141654-ENG149211-ZV Autolock-automatisches_Entriegeln,active ,5
ENG141654-ENG149210-ZV Autolock-Automatisches_Verriegeln_bei_Geschwindigkeit,active ,5
ENG141654-ENG149212-ZV Autolock-Autounlock_NAR,not active ,5
ENG141654-ENG149214-ZV Autolock-Menuesteuerung_ZV_Autolock-Unlock,not active ,5
ENG141655-ENG149225-ZV Crash-Heckdeckel-Bedienstellen_nachCrash_temporaer_sperren,active ,4
ENG141655-ENG149227-ZV Crash-SAD_PreCrash_Konturschliessen,active ,4
ENG141655-ENG149226-ZV Crash-ZV-Entriegelung_nach_Seitencrash,not active ,4
ENG141653-MAS07515-ZV Heck-Trunk lid remote unlocking: int. button,not installed ,5
ENG141653-MAS10551-ZV Heck-Rear lid lock control,Contact control ,5
ENG141653-MAS10555-ZV Heck-Central locking: rear lock type,1 or 2 notch rear actuator ,5
ENG141653-MAS10561-ZV Heck-Rear lock with safety catch,Yes ,5
ENG141653-ENG149183-ZV Heck-Direkter_Auswurf_des_Heckdeckels,active ,5
ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active ,5
ENG141653-ENG149185-ZV Heck-Freigabenachlauf_Heck_nach_Einzeloeffnung_ueber_HDF-Funktaster,not active ,5
ENG141653-ENG149187-ZV Heck-Hecksteuerung_ohne_ZV,not active ,5
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster,0.0 s,5
ENG141653-ENG261746-ZV Heck-Rear_lock_control_min_aktiv,not active ,5
ENG141653-ENG126630-ZV Heck-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,5
ENG141653-ENG155905-ZV Heck-Softtouch_Auswertung,digitale_Logik ,5
ENG141653-ENG252095-ZV Heck-Zentralverrieglung_ohne_Heckdeckel,not active ,5
ENG141653-ENG149182-ZV Heck-ZV_entriegelt_auch_Heckdeckel,active ,5
ENG141653-ENG149184-ZV Heck-ZV_Heck_nur_direkt_auswerfen,not active ,5
ENG148616-IDE02021-ZV Komfort (Fensterheber)-Comfort closing,active ,7
ENG148616-IDE02022-ZV Komfort (Fensterheber)-Comfort opening,not active ,7
ENG148616-MAS10525-ZV Komfort (Fensterheber)-Electrical window lift: front,active ,7
ENG148616-MAS10526-ZV Komfort (Fensterheber)-Electrical window left: rear,Yes ,7
ENG148616-ENG154964-ZV Komfort (Fensterheber)-BAP_Komfortschließen,not active ,7
ENG148616-ENG248524-ZV Komfort (Fensterheber)-Busruhe_bei_Fensterheberfreigabenachlauf,not active ,7
ENG148616-ENG149202-ZV Komfort (Fensterheber)-Fahrertuerbedienung_Fensterheber_oeffnen,active ,7
ENG148616-ENG149206-ZV Komfort (Fensterheber)-Fahrertuerbedienung_Fensterheber_schliessen,active ,7
ENG148616-ENG149203-ZV Komfort (Fensterheber)-FH_SAD_Kl15Aus_Freigabezeit,600 s,7
ENG148616-ENG149196-ZV Komfort (Fensterheber)-Freigabenachlauf_FH_bei_Kl_15_aus,active ,7
ENG148616-ENG149197-ZV Komfort (Fensterheber)-Freigabenachlauf_FH_bei_Tueroeffnen,active ,7
ENG148616-ENG149201-ZV Komfort (Fensterheber)-Funk_Komfort_oeffnen,active ,7
ENG148616-ENG149205-ZV Komfort (Fensterheber)-Funk_Komfort_schliessen,active ,7
ENG148616-ENG155240-ZV Komfort (Fensterheber)-Kindersicherung_Beifahrerfenster,not active ,7
ENG148616-ENG149198-ZV Komfort (Fensterheber)-Komfortbedienung_global,active ,7
ENG148616-ENG149199-ZV Komfort (Fensterheber)-Komfortoeffnen_nur_FH_Fahrertuer,not active ,7
ENG148616-ENG155244-ZV Komfort (Fensterheber)-Komfortschliessen_Brasilien,not active ,7
ENG148616-ENG149209-ZV Komfort (Fensterheber)-Manuelle_ZV_Variantenprogrammierung,not active ,7
ENG148616-ENG149207-ZV Komfort (Fensterheber)-Menuesteuerung_Komfortbedienung_einstellbar,adjustable ,7
ENG148616-ENG149200-ZV Komfort (Fensterheber)-Schliesszylinder_Komfort_oeffnen,active ,7
ENG148616-ENG149204-ZV Komfort (Fensterheber)-Schliesszylinder_Komfort_schliessen,active ,7
ENG141652-MAS01914-ZV Türkonfiguration-Type of lock,1 Motor locks without Safe (NAR locks) ,5
ENG141652-MAS06443-ZV Türkonfiguration-Lock cylinder passenger door,not installed ,5
ENG141652-MAS10567-ZV Türkonfiguration-Four-door,Yes ,5
ENG141652-ENG273805-ZV Türkonfiguration-schliesszylinderlogik_lbs,active ,5
Elapsed Time: 01:25
adap-map 19
;SW:2Q0-909-901-D   HW:2Q0-937-089-C ---  CAN Gateway
;Component:GW MQB A0     H11 0943, Coding:030100046F08560022000048080F00010001070000000000000000000000
;EV_GatewA0,013026,EV_GatewA0_VW27.rod
;Friday,04,March,2022,14:22:57:13091
;VCDS Version: Release 22.3.0 (x64)  Data version: 20220225 DS336.1
;VCID: 3333E315CBB65AA3020-8066
IDE01457-Energy management deactivation stage,Mode not active ,1
IDE01844-Increase idle speed request,Mode not active ,1
IDE01996-SFT00001-Installation list: specified installations-Engine Electronics,coded ,32
IDE01996-SFT00002-Installation list: specified installations-Transmission Electronics,Not coded ,32
IDE01996-SFT00003-Installation list: specified installations-Brake electronics,coded ,32
IDE01996-SFT00006-Installation list: specified installations-Seat adjustment: passenger's side,Not coded ,32
IDE01996-SFT00008-Installation list: specified installations-Climate Control Module,coded ,32
IDE01996-SFT00009-Installation list: specified installations-Electronic central electric,coded ,32
IDE01996-SFT00014-Installation list: specified installations-Media Player 1,Not coded ,32
IDE01996-SFT00019-Installation list: specified installations-Distance Regulation,coded ,32
IDE01996-SFT00020-Installation list: specified installations-Wheel Damping Electronics,Not coded ,32
IDE01996-SFT00022-Installation list: specified installations-Steering column electronics systems,Not coded ,32
IDE01996-SFT00023-Installation list: specified installations-Instrument cluster,coded ,32
IDE01996-SFT00024-Installation list: specified installations-Auxiliary/parking heating,Not coded ,32
IDE01996-SFT00025-Installation list: specified installations-Data Bus OBD Interface,1 ,32
IDE01996-SFT00032-Installation list: specified installations-High beam assistant,Not coded ,32
IDE01996-SFT00033-Installation list: specified installations-Battery management 2,Not coded ,32
IDE01996-SFT00034-Installation list: specified installations-All-wheel drive electronics,Not coded ,32
IDE01996-SFT00038-Installation list: specified installations-Convertible top operation,Not coded ,32
IDE01996-SFT00043-Installation list: specified installations-Steering column lock,Not coded ,32
IDE01996-SFT00050-Installation list: specified installations-Differential lock electronics,Not coded ,32
IDE01996-SFT00054-Installation list: specified installations-Seat adjustment: driver side,Not coded ,32
IDE01996-SFT00060-Installation list: specified installations-Lane change assistance,Not coded ,32
IDE01996-SFT00064-Installation list: specified installations-A/C compressor,Not coded ,32
IDE01996-SFT00066-Installation list: specified installations-Driver's door electronics,Not coded ,32
IDE01996-SFT00068-Installation list: specified installations-Power steering,coded ,32
IDE01996-SFT00071-Installation list: specified installations-Sound System,Not coded ,32
IDE01996-SFT00075-Installation list: specified installations-Multi-function module,Not coded ,32
IDE01996-SFT00081-Installation list: specified installations-Electric drive,Not coded ,32
IDE01996-SFT00082-Installation list: specified installations-Passenger's door electronics,Not coded ,32
IDE01996-SFT00085-Installation list: specified installations-Headlamp range control,Not coded ,32
IDE01996-SFT00095-Installation list: specified installations-Information electronics 1,coded ,32
IDE01996-SFT00096-Installation list: specified installations-Trip recorder,Not coded ,32
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring System (TPMS),Not coded ,32
IDE01996-SFT00105-Installation list: specified installations-Trailer Function,coded ,32
IDE01996-SFT00108-Installation list: specified installations-Rear view camera system,Not coded ,32
IDE01996-SFT00109-Installation list: specified installations-Rear lid electronics,Not coded ,32
IDE01996-SFT00117-Installation list: specified installations-Emergency call module and communication unit,coded ,32
IDE01996-SFT00118-Installation list: specified installations-Parking aid,coded ,32
IDE01996-SFT00128-Installation list: specified installations-Battery control additional memory 1,Not coded ,32
IDE01996-SFT00130-Installation list: specified installations-Head-Up-Display,Not coded ,32
IDE01996-SFT00140-Installation list: specified installations-Hybrid Battery Management,Not coded ,32
IDE01996-SFT00165-Installation list: specified installations-Front sensor for drivers assistant systems,coded ,32
IDE01996-SFT00166-Installation list: specified installations-Microphone control module,Not coded ,32
IDE01996-SFT00169-Installation list: specified installations-Structure-borne sound actuator,Not coded ,32
IDE01996-SFT00183-Installation list: specified installations-Interface for access/start system,Not coded ,32
IDE01996-SFT00187-Installation list: specified installations-Rear drivers side door electronics,Not coded ,32
IDE01996-SFT00188-Installation list: specified installations-Rear passenger side door electronics,Not coded ,32
IDE01996-SFT00189-Installation list: specified installations-High-voltage battery charging management,Not coded ,32
IDE01996-SFT00190-Installation list: specified installations-Left rear sliding door,Not coded ,32
IDE01996-SFT00191-Installation list: specified installations-Right rear sliding door,Not coded ,32
IDE01996-SFT00198-Installation list: specified installations-High-voltage battery charger,Not coded ,32
IDE01996-SFT00202-Installation list: specified installations-Sunroof control module,Not coded ,32
IDE01996-SFT00204-Installation list: specified installations-Starter generator,Not coded ,32
IDE01996-SFT00207-Installation list: specified installations-Lane Change Assistant 2,Not coded ,32
IDE01996-ENG118300-Installation list: specified installations-Node_0x82,Not coded ,32
IDE01996-ENG118301-Installation list: specified installations-Node_0x83,Not coded ,32
IDE01996-ENG118318-Installation list: specified installations-Node_0x96,Not coded ,32
IDE01996-ENG118319-Installation list: specified installations-Node_0x97,Not coded ,32
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,49 Ah,15
IDE03256-MAS06106-Battery adaptation-Battery technology,EFB+ ,15
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,JCB ,15
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,1111111111 ,15
IDE03903-Production process data 1,80 EF ,2
IDE04159-Deactivation of start/stop function,Mode not active ,1
IDE04330-Transfer of release code for a SWaP function,00 EF 4A 43 42 31 31 31 31 31 31 31 31 31 31 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 21 22 23 24 25 26 27 28 29 2A 2B 2C 2D 2E 2F 30 31 32 33 34 35 36 37 38 39 3A 3B 3C 3D 3E 3F 40 41 42 43 44 45 46 47 48 49 4A 4B 4C 4D 4E 4F 50 51 52 53 54 55 56 57 58 59 5A 5B 5C 5D 5E 5F 60 61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 7B 7C 7D 7E 7F 80 81 82 83 84 85 86 87 88 89 8A 8B 8C 8D 8E 8F 90 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3 A4 A5 A6 A7 A8 A9 AA AB AC AD AE AF B0 B1 B2 B3 B4 B5 B6 B7 B8 B9 BA BB BC BD BE BF C0 C1 C2 C3 C4 C5 C6 C7 C8 C9 CA CB CC CD CE CF D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 DA DB DC DD DE DF E0 E1 E2 E3 E4 E5 E6 E7 E8 E9 EA EB EC ED EE EF F0 F1 F2 F3 F4 F5 F6 F7 F8 F9 FA FB FC FD FE FF 30 30 30 2A 2A 43 30 30 30 39 38 2A 30 30 30 35 35 2A 30 30 30 33 35 2A 30 30 30 32 39 2A 30 30 30 32 32 2A 30 30 30 31 38 2A 30 30 30 32 35 2A 30 30 30 31 34 2A 30 30 30 30 35 2A 30 30 30 33 37 2A 30 30 30 30 30 2A 2A 30 31 2D 30 31 2D 30 30 3A 30 30 2A 30 30 30 2E 30 2A 30 30 2E 30 2A 30 30 2E 30 2A 30 30 30 30 2E 30 2A 2A 22 32 30 30 30 2D 30 31 2D 30 31 2D 30 30 3A 30 30 2A 30 ,384
IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM,activated ,4
IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start,activated ,4
IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch),activated ,4
IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system,activated ,4
IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system,activated ,4
IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill,activated ,4
IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button),activated ,4
IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill,activated ,4
IDE06753-MAS06294-Efficiency program display-Comfort use rear heater,activated ,4
IDE06753-MAS06295-Efficiency program display-Comfort use fog light,activated ,4
IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light,not activated ,4
IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater,activated ,4
IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater,activated ,4
IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation,activated ,4
IDE06753-MAS14430-Efficiency program display-Dependence of ECO tips on driver profile selection,ECO tips independent of driver profile selection ,4
IDE06753-MAS19094-Efficiency program display-Rear A/C System blower convenience consumption,activated ,4
IDE06753-MAS19095-Efficiency program display-Convenience consumption outer mirror heater dependency,Separate from exterior temperature without switch ,4
IDE08348-Start/stop start voltage limit,7.6 V,1
IDE10735-Number requests autonomous recharging,9 ,1
IDE10748-MAS11262-Range gain-Range gain AC system,not activated ,3
IDE10748-MAS11263-Range gain-Range gain auxiliary heater,activated ,3
IDE10748-MAS11264-Range gain-Range gain window defogger,activated ,3
IDE10748-MAS11265-Range gain-Range gain seat heater front,activated ,3
IDE10748-MAS11266-Range gain-Range gain front set ventilation,activated ,3
IDE10748-MAS11267-Range gain-Range gain rear heater,activated ,3
IDE10748-MAS11268-Range gain-Range gain fog light,activated ,3
IDE10748-MAS11269-Range gain-Range gain rear fog light,not activated ,3
IDE10748-MAS11270-Range gain-Range gain windshield heating,activated ,3
IDE10748-MAS11271-Range gain-Range gain steering wheel heater,activated ,3
IDE10748-MAS11272-Range gain-Range gain mirror heater,activated ,3
IDE10748-MAS11273-Range gain-Range gain rear seat heater,activated ,3
IDE10748-MAS11274-Range gain-Range gain rear seat heater,activated ,3
IDE10748-MAS11275-Range gain-Windshield heater consumption in AC system,not activated ,3
IDE10748-MAS11276-Range gain-Windshield heater range gain in AC system,not activated ,3
IDE10748-MAS11277-Range gain-PTC(low voltage) consumption,not activated ,3
IDE10748-MAS11278-Range gain-PTC(low voltage) range gain,not activated ,3
IDE10748-MAS11279-Range gain-List at engine still stand,activated ,3
IDE10748-MAS12689-Range gain-Catalogue range display,activated ,3
IDE10748-MAS12690-Range gain-Loading condition catalogue range display,activated ,3
IDE10748-MAS13161-Range gain-List display absolute values ??with weighting,activated ,3
IDE10748-MAS19099-Range gain-Convenience consumption socket,not activated ,3
IDE10748-MAS19100-Range gain-A/C System blower manual convenience consumption,activated ,3
IDE10748-MAS19132-Range gain-Outer mirror heater consumption in rear window heating,not activated ,3
IDE15331-Multifunction steering wheel extended adaptation,Configuration 4 ,3
SFT271921-IDE02583-Multifunction steering wheel control module-Steering wheel Tiptronic switch,not installed ,3
SFT271921-MAS02311-Multifunction steering wheel control module-Steering wheel heating button,not active ,3
SFT271921-MAS04733-Multifunction steering wheel control module-Two-stage,not active ,3
SFT271921-MAS06614-Multifunction steering wheel control module-Variant,CCS ,3
SFT271921-MAS09758-Multifunction steering wheel control module-Temperature sensor,not installed ,3
SFT271921-MAS13892-Multifunction steering wheel control module-Platform,MQB ,3
SFT271921-MAS19104-Multifunction steering wheel control module-Alarm horn wake-up function,active ,3
SFT271921-ENG258379-Multifunction steering wheel control module-clamp behaviour,active with terminal 58 ,3
SFT271921-ENG260738-Multifunction steering wheel control module-FoD ACC,automatic ,3
SFT271921-ENG258784-Multifunction steering wheel control module-FoD Travel Assist,automatic ,3
SFT271921-ENG262857-Multifunction steering wheel control module-Kombi_02_gueltig,not active ,3
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,255000 ms,12
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,500 ms,12
ENG137060-ENG113874-EM_energy_management_warning_displays-Battery reports,Mode not active ,4
ENG137060-ENG98711-EM_energy_management_warning_displays-State of Charge (SOC),Mode not active ,4
ENG137075-EM_heating_power_quota_adjustment,1000 W,1
ENG137058-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Electronics,activated ,32
ENG137058-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Electronics,activated ,32
ENG137058-SFT00003-GW_Enable_CAN_Timeout_DTC-Brake electronics,not activated ,32
ENG137058-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat adjustment: passenger's side,activated ,32
ENG137058-SFT00008-GW_Enable_CAN_Timeout_DTC-Climate Control Module,activated ,32
ENG137058-SFT00009-GW_Enable_CAN_Timeout_DTC-Electronic central electric,activated ,32
ENG137058-SFT00011-GW_Enable_CAN_Timeout_DTC-Auxiliary Air Heater,activated ,32
ENG137058-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player 1,activated ,32
ENG137058-SFT00019-GW_Enable_CAN_Timeout_DTC-Distance Regulation,activated ,32
ENG137058-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Damping Electronics,activated ,32
ENG137058-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag,not activated ,32
ENG137058-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering column electronics systems,activated ,32
ENG137058-SFT00023-GW_Enable_CAN_Timeout_DTC-Instrument cluster,activated ,32
ENG137058-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary/parking heating,activated ,32
ENG137058-SFT00025-GW_Enable_CAN_Timeout_DTC-Data Bus OBD Interface,not activated ,32
ENG137058-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection,activated ,32
ENG137058-SFT00032-GW_Enable_CAN_Timeout_DTC-High beam assistant,activated ,32
ENG137058-SFT00033-GW_Enable_CAN_Timeout_DTC-Battery management 2,activated ,32
ENG137058-SFT00034-GW_Enable_CAN_Timeout_DTC-All-wheel drive electronics,activated ,32
ENG137058-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost,activated ,32
ENG137058-SFT00038-GW_Enable_CAN_Timeout_DTC-Convertible top operation,activated ,32
ENG137058-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering column lock,activated ,32
ENG137058-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2,activated ,32
ENG137058-SFT00050-GW_Enable_CAN_Timeout_DTC-Differential lock electronics,activated ,32
ENG137058-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat adjustment: driver side,activated ,32
ENG137058-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane change assistance,activated ,32
ENG137058-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function,activated ,32
ENG137058-SFT00064-GW_Enable_CAN_Timeout_DTC-A/C compressor,activated ,32
ENG137058-SFT00066-GW_Enable_CAN_Timeout_DTC-Driver's door electronics,activated ,32
ENG137058-SFT00068-GW_Enable_CAN_Timeout_DTC-Power steering,activated ,32
ENG137058-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System,activated ,32
ENG137058-SFT00075-GW_Enable_CAN_Timeout_DTC-Multi-function module,activated ,32
ENG137058-SFT00081-GW_Enable_CAN_Timeout_DTC-Electric drive,activated ,32
ENG137058-SFT00082-GW_Enable_CAN_Timeout_DTC-Passenger's door electronics,activated ,32
ENG137058-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlamp range control,activated ,32
ENG137058-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio,activated ,32
ENG137058-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner,activated ,32
ENG137058-SFT00095-GW_Enable_CAN_Timeout_DTC-Information electronics 1,activated ,32
ENG137058-SFT00096-GW_Enable_CAN_Timeout_DTC-Trip recorder,activated ,32
ENG137058-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring System (TPMS),activated ,32
ENG137058-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function,activated ,32
ENG137058-SFT00108-GW_Enable_CAN_Timeout_DTC-Rear view camera system,activated ,32
ENG137058-SFT00109-GW_Enable_CAN_Timeout_DTC-Rear lid electronics,activated ,32
ENG137058-SFT00117-GW_Enable_CAN_Timeout_DTC-Emergency call module and communication unit,activated ,32
ENG137058-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking aid,activated ,32
ENG137058-SFT00128-GW_Enable_CAN_Timeout_DTC-Battery control additional memory 1,activated ,32
ENG137058-SFT00130-GW_Enable_CAN_Timeout_DTC-Head-Up-Display,activated ,32
ENG137058-SFT00140-GW_Enable_CAN_Timeout_DTC-Hybrid Battery Management,activated ,32
ENG137058-SFT00165-GW_Enable_CAN_Timeout_DTC-Front sensor for drivers assistant systems,activated ,32
ENG137058-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone control module,activated ,32
ENG137058-SFT00169-GW_Enable_CAN_Timeout_DTC-Structure-borne sound actuator,activated ,32
ENG137058-SFT00183-GW_Enable_CAN_Timeout_DTC-Interface for access/start system,activated ,32
ENG137058-SFT00187-GW_Enable_CAN_Timeout_DTC-Rear drivers side door electronics,activated ,32
ENG137058-SFT00188-GW_Enable_CAN_Timeout_DTC-Rear passenger side door electronics,activated ,32
ENG137058-SFT00189-GW_Enable_CAN_Timeout_DTC-High-voltage battery charging management,activated ,32
ENG137058-SFT00190-GW_Enable_CAN_Timeout_DTC-Left rear sliding door,activated ,32
ENG137058-SFT00191-GW_Enable_CAN_Timeout_DTC-Right rear sliding door,activated ,32
ENG137058-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise,activated ,32
ENG137058-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management,activated ,32
ENG137058-SFT00198-GW_Enable_CAN_Timeout_DTC-High-voltage battery charger,activated ,32
ENG137058-SFT00202-GW_Enable_CAN_Timeout_DTC-Sunroof control module,activated ,32
ENG137058-SFT00204-GW_Enable_CAN_Timeout_DTC-Starter generator,activated ,32
ENG137058-SFT00207-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant 2,activated ,32
ENG137058-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00,activated ,32
ENG137058-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01,activated ,32
ENG137058-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02,activated ,32
ENG137058-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03,activated ,32
ENG137058-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04,activated ,32
ENG137058-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05,activated ,32
ENG137058-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06,activated ,32
ENG137058-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07,activated ,32
ENG137058-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08,activated ,32
ENG137058-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D,activated ,32
ENG137058-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11,activated ,32
ENG137058-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16,activated ,32
ENG137058-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17,activated ,32
ENG137058-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A,activated ,32
ENG137058-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D,activated ,32
ENG137058-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F,activated ,32
ENG137058-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20,activated ,32
ENG137058-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21,activated ,32
ENG137058-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22,activated ,32
ENG137058-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24,activated ,32
ENG137058-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25,activated ,32
ENG137058-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26,activated ,32
ENG137058-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27,activated ,32
ENG137058-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28,activated ,32
ENG137058-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29,activated ,32
ENG137058-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A,activated ,32
ENG137058-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E,activated ,32
ENG137058-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F,activated ,32
ENG137058-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35,activated ,32
ENG137058-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36,activated ,32
ENG137058-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37,activated ,32
ENG137058-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38,activated ,32
ENG137058-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39,activated ,32
ENG137058-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A,activated ,32
ENG137058-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C,activated ,32
ENG137058-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D,activated ,32
ENG137058-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40,activated ,32
ENG137058-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41,activated ,32
ENG137058-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43,activated ,32
ENG137058-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45,activated ,32
ENG137058-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48,activated ,32
ENG137058-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49,activated ,32
ENG137058-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51,activated ,32
ENG137058-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52,activated ,32
ENG137058-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53,activated ,32
ENG137058-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55,activated ,32
ENG137058-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56,activated ,32
ENG137058-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58,activated ,32
ENG137058-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59,activated ,32
ENG137058-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A,activated ,32
ENG137058-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B,activated ,32
ENG137058-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C,activated ,32
ENG137058-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D,activated ,32
ENG137058-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E,activated ,32
ENG137058-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F,activated ,32
ENG137058-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60,activated ,32
ENG137058-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61,activated ,32
ENG137058-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62,activated ,32
ENG137058-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66,activated ,32
ENG137058-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68,activated ,32
ENG137058-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B,activated ,32
ENG137058-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C,activated ,32
ENG137058-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E,activated ,32
ENG137058-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74,activated ,32
ENG137058-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75,activated ,32
ENG137058-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78,activated ,32
ENG137058-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79,activated ,32
ENG137058-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A,activated ,32
ENG137058-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D,activated ,32
ENG137058-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E,activated ,32
ENG137058-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F,activated ,32
ENG137058-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80,activated ,32
ENG137058-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81,activated ,32
ENG137058-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82,activated ,32
ENG137058-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83,activated ,32
ENG137058-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86,activated ,32
ENG137058-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87,activated ,32
ENG137058-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88,activated ,32
ENG137058-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89,activated ,32
ENG137058-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B,activated ,32
ENG137058-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C,activated ,32
ENG137058-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D,activated ,32
ENG137058-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E,activated ,32
ENG137058-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F,activated ,32
ENG137058-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90,activated ,32
ENG137058-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91,activated ,32
ENG137058-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92,activated ,32
ENG137058-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93,activated ,32
ENG137058-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94,activated ,32
ENG137058-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95,activated ,32
ENG137058-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96,activated ,32
ENG137058-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97,activated ,32
ENG137058-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98,activated ,32
ENG137058-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99,activated ,32
ENG137058-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A,activated ,32
ENG137058-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B,activated ,32
ENG137058-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D,activated ,32
ENG137058-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E,activated ,32
ENG137058-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F,activated ,32
ENG137058-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0,activated ,32
ENG137058-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1,activated ,32
ENG137058-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2,activated ,32
ENG137058-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3,activated ,32
ENG137058-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5,activated ,32
ENG137058-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6,activated ,32
ENG137058-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7,activated ,32
ENG137058-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8,activated ,32
ENG137058-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA,activated ,32
ENG137058-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB,activated ,32
ENG137058-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC,activated ,32
ENG137058-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD,activated ,32
ENG137058-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF,activated ,32
ENG137058-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0,activated ,32
ENG137058-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1,activated ,32
ENG137058-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2,activated ,32
ENG137058-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3,activated ,32
ENG137058-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4,activated ,32
ENG137058-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5,activated ,32
ENG137058-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6,activated ,32
ENG137058-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7,activated ,32
ENG137058-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8,activated ,32
ENG137058-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9,activated ,32
ENG137058-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA,activated ,32
ENG137058-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB,activated ,32
ENG137058-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC,activated ,32
ENG137058-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD,activated ,32
ENG137058-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE,activated ,32
ENG137058-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF,activated ,32
ENG137058-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0,activated ,32
ENG137058-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1,activated ,32
ENG137058-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2,activated ,32
ENG137058-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3,activated ,32
ENG137058-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4,activated ,32
ENG137058-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5,activated ,32
ENG137058-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6,activated ,32
ENG137058-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7,activated ,32
ENG137058-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8,activated ,32
ENG137058-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9,activated ,32
ENG137058-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA,activated ,32
ENG137058-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB,activated ,32
ENG137058-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC,activated ,32
ENG137058-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD,activated ,32
ENG137058-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE,activated ,32
ENG137058-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF,activated ,32
ENG137058-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0,activated ,32
ENG137058-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1,activated ,32
ENG137058-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2,activated ,32
ENG137058-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3,activated ,32
ENG137058-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4,activated ,32
ENG137058-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5,activated ,32
ENG137058-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6,activated ,32
ENG137058-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7,activated ,32
ENG137058-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8,activated ,32
ENG137058-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9,activated ,32
ENG137058-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA,activated ,32
ENG137058-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB,activated ,32
ENG137058-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC,activated ,32
ENG137058-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD,activated ,32
ENG137058-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE,activated ,32
ENG137058-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF,activated ,32
ENG137058-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0,activated ,32
ENG137058-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1,activated ,32
ENG137058-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2,activated ,32
ENG137058-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3,activated ,32
ENG137058-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4,activated ,32
ENG137058-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5,activated ,32
ENG137058-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6,activated ,32
ENG137058-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7,activated ,32
ENG137058-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8,activated ,32
ENG137058-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9,activated ,32
ENG137058-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA,activated ,32
ENG137058-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB,activated ,32
ENG137058-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC,activated ,32
ENG137058-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED,activated ,32
ENG137058-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE,activated ,32
ENG137058-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF,activated ,32
ENG137058-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0,activated ,32
ENG137058-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1,activated ,32
ENG137058-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2,activated ,32
ENG137058-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3,activated ,32
ENG137058-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4,activated ,32
ENG137058-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5,activated ,32
ENG137058-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6,activated ,32
ENG137058-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7,activated ,32
ENG137058-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8,activated ,32
ENG137058-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9,activated ,32
ENG137058-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA,activated ,32
ENG137058-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB,activated ,32
ENG137058-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC,activated ,32
ENG137058-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD,activated ,32
ENG137058-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE,activated ,32
ENG137058-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF,activated ,32
ENG137059-ENG118464-GW_mirror_mode-mirror_mode_bus,Powertrain data bus ,2
ENG118774-ENG152567-WakeUpMonitor_Activation-Open_Filter_Activate,not activated ,1
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100 ,5
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s,5
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s,5
Elapsed Time: 00:27
adap-map 5F
;SW:3G5-035-820-E   HW:3G5-035-820-E ---  Information Electr.
;Component:MU-O-ND-EU    H22 0278, Coding:22160000000000000000000000000000000000000000000000
;EV_MUOIMQB,001001,EV_MUOIMQB_VW27.rod
;Friday,04,March,2022,14:25:11:13091
;VCID: 26150A4108643F0B95E-8072
IDE00001-ENG248499-Production mode-air_condition_operation,not activated ,3
IDE00001-ENG154175-Production mode-Bluetooth,not activated ,3
IDE00001-ENG248636-Production mode-display_1_move,not activated ,3
IDE00001-ENG248637-Production mode-display_1_on_off,not activated ,3
IDE00001-ENG248638-Production mode-display_2_move,not activated ,3
IDE00001-ENG248639-Production mode-display_2_on_off,not activated ,3
IDE00001-ENG251560-Production mode-display_3_on_off,not activated ,3
IDE00001-ENG282031-Production mode-Display_4_on_off,not activated ,3
IDE00001-ENG252053-Production mode-early_audio,not activated ,3
IDE00001-ENG248670-Production mode-extendible_tweeters,not activated ,3
IDE00001-ENG175909-Production mode-FPK,not activated ,3
IDE00001-ENG248687-Production mode-fpk_display,not activated ,3
IDE00001-ENG248690-Production mode-frequency_modification,not activated ,3
IDE00001-ENG146079-Production mode-Operation,not activated ,3
IDE00001-ENG248771-Production mode-p_mode_id_13,not activated ,3
IDE00001-ENG248772-Production mode-p_mode_id_14,not activated ,3
IDE00001-ENG248485-Production mode-Parameter_21,not activated ,3
IDE00001-ENG248486-Production mode-Parameter_22,not activated ,3
IDE00001-ENG248487-Production mode-Parameter_23,not activated ,3
IDE00001-ENG248791-Production mode-paramter_24,not activated ,3
IDE00001-ENG248796-Production mode-radio_link_esim,not activated ,3
IDE00001-ENG248480-Production mode-SDS,not activated ,3
IDE00001-ENG168106-Production mode-volume_control,not activated ,3
IDE00001-ENG248489-Production mode-Wifi,not activated ,3
IDE00346-Summertime-automatic,Europe ,1
IDE00768-Country identification: country of sale,HR ,2
IDE00769-Call number 1 for info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00770-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00820-MAS03180-Activating and deactivating all development messages-Local data bus,OFF ,1
IDE00820-MAS05583-Activating and deactivating all development messages-Data bus,OFF ,1
IDE02125-MAS08233-Voice operation for telephone-other,installed ,1
IDE02125-MAS18502-Voice operation for telephone-Apple device,not installed ,1
IDE02330-Call number 2 for info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02331-Number 2 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02476-MAS03001-Electrical test of speakers-Mode,automatic ,121
IDE02476-ENG248529-Electrical test of speakers-channel_1_lower_threshold,255 ,121
IDE02476-ENG248531-Electrical test of speakers-channel_1_upper_threshold,255 ,121
IDE02476-ENG248533-Electrical test of speakers-channel_10_lower_threshold,255 ,121
IDE02476-ENG248535-Electrical test of speakers-channel_10_upper_threshold,255 ,121
IDE02476-ENG248537-Electrical test of speakers-channel_11_lower_threshold,255 ,121
IDE02476-ENG248539-Electrical test of speakers-channel_11_upper_threshold,255 ,121
IDE02476-ENG248541-Electrical test of speakers-channel_12_lower_threshold,255 ,121
IDE02476-ENG248543-Electrical test of speakers-channel_12_upper_threshold,255 ,121
IDE02476-ENG248545-Electrical test of speakers-channel_13_lower_threshold,255 ,121
IDE02476-ENG248547-Electrical test of speakers-channel_13_upper_threshold,255 ,121
IDE02476-ENG248549-Electrical test of speakers-channel_14_lower_threshold,255 ,121
IDE02476-ENG248551-Electrical test of speakers-channel_14_upper_threshold,255 ,121
IDE02476-ENG248553-Electrical test of speakers-channel_15_lower_threshold,255 ,121
IDE02476-ENG248555-Electrical test of speakers-channel_15_upper_threshold,255 ,121
IDE02476-ENG248557-Electrical test of speakers-channel_16_lower_threshold,255 ,121
IDE02476-ENG248559-Electrical test of speakers-channel_16_upper_threshold,255 ,121
IDE02476-ENG248561-Electrical test of speakers-channel_17_lower_threshold,255 ,121
IDE02476-ENG248563-Electrical test of speakers-channel_17_upper_threshold,255 ,121
IDE02476-ENG248565-Electrical test of speakers-channel_18_lower_threshold,255 ,121
IDE02476-ENG248567-Electrical test of speakers-channel_18_upper_threshold,255 ,121
IDE02476-ENG248569-Electrical test of speakers-channel_19_lower_threshold,255 ,121
IDE02476-ENG248570-Electrical test of speakers-channel_19_upper_threshold,255 ,121
IDE02476-ENG248573-Electrical test of speakers-channel_2_lower_threshold,255 ,121
IDE02476-ENG248575-Electrical test of speakers-channel_2_upper_threshold,255 ,121
IDE02476-ENG248577-Electrical test of speakers-channel_20_lower_threshold,255 ,121
IDE02476-ENG248579-Electrical test of speakers-channel_20_upper_threshold,255 ,121
IDE02476-ENG248581-Electrical test of speakers-channel_21_lower_threshold,255 ,121
IDE02476-ENG248583-Electrical test of speakers-channel_21_upper_threshold,255 ,121
IDE02476-ENG248585-Electrical test of speakers-channel_22_lower_threshold,255 ,121
IDE02476-ENG248587-Electrical test of speakers-channel_22_upper_threshold,255 ,121
IDE02476-ENG248589-Electrical test of speakers-channel_23_lower_threshold,255 ,121
IDE02476-ENG248591-Electrical test of speakers-channel_23_upper_threshold,255 ,121
IDE02476-ENG248593-Electrical test of speakers-channel_24_lower_threshold,255 ,121
IDE02476-ENG248595-Electrical test of speakers-channel_24_upper_threshold,255 ,121
IDE02476-ENG248599-Electrical test of speakers-channel_3_lower_threshold,255 ,121
IDE02476-ENG248601-Electrical test of speakers-channel_3_upper_threshold,255 ,121
IDE02476-ENG248603-Electrical test of speakers-channel_4_lower_threshold,255 ,121
IDE02476-ENG248605-Electrical test of speakers-channel_4_upper_threshold,255 ,121
IDE02476-ENG248607-Electrical test of speakers-channel_5_lower_threshold,255 ,121
IDE02476-ENG248609-Electrical test of speakers-channel_5_upper_threshold,255 ,121
IDE02476-ENG248611-Electrical test of speakers-channel_6_lower_threshold,255 ,121
IDE02476-ENG248613-Electrical test of speakers-channel_6_upper_threshold,255 ,121
IDE02476-ENG248615-Electrical test of speakers-channel_7_lower_threshold,255 ,121
IDE02476-ENG248617-Electrical test of speakers-channel_7_upper_threshold,255 ,121
IDE02476-ENG248619-Electrical test of speakers-channel_8_lower_threshold,255 ,121
IDE02476-ENG248621-Electrical test of speakers-channel_8_upper_threshold,255 ,121
IDE02476-ENG248623-Electrical test of speakers-channel_9_lower_threshold,255 ,121
IDE02476-ENG248625-Electrical test of speakers-channel_9_upper_threshold,255 ,121
IDE02476-ENG117360-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,121
IDE02476-ENG117361-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,49 ,121
IDE02476-ENG117378-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,121
IDE02476-ENG117379-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,49 ,121
IDE02476-ENG117380-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,121
IDE02476-ENG117381-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,49 ,121
IDE02476-ENG117382-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,121
IDE02476-ENG117383-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,49 ,121
IDE02476-ENG117384-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,121
IDE02476-ENG117385-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,49 ,121
IDE02476-ENG117386-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,121
IDE02476-ENG117387-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,49 ,121
IDE02476-ENG117388-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,121
IDE02476-ENG117389-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,49 ,121
IDE02476-ENG117390-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,121
IDE02476-ENG117391-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,49 ,121
IDE02476-ENG126164-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_17_Test_Frequency,19000 Hz,121
IDE02476-ENG126165-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_17_Test_Volume,49 ,121
IDE02476-ENG126166-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_18_Test_Frequency,19000 Hz,121
IDE02476-ENG126167-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_18_Test_Volume,49 ,121
IDE02476-ENG126168-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_19_Test_Frequency,19000 Hz,121
IDE02476-ENG126169-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_19_Test_Volume,49 ,121
IDE02476-ENG117362-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,121
IDE02476-ENG117363-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,49 ,121
IDE02476-ENG126170-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_20_Test_Frequency,19000 Hz,121
IDE02476-ENG126171-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_20_Test_Volume,49 ,121
IDE02476-ENG126172-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_21_Test_Frequency,19000 Hz,121
IDE02476-ENG126173-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_21_Test_Volume,49 ,121
IDE02476-ENG126174-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_22_Test_Frequency,19000 Hz,121
IDE02476-ENG126175-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_22_Test_Volume,49 ,121
IDE02476-ENG126176-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_23_Test_Frequency,19000 Hz,121
IDE02476-ENG126177-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_23_Test_Volume,49 ,121
IDE02476-ENG126178-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_24_Test_Frequency,19000 Hz,121
IDE02476-ENG126179-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_24_Test_Volume,49 ,121
IDE02476-ENG117364-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,121
IDE02476-ENG117365-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,49 ,121
IDE02476-ENG117366-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,121
IDE02476-ENG117367-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,49 ,121
IDE02476-ENG117368-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,121
IDE02476-ENG117369-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,49 ,121
IDE02476-ENG117370-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,121
IDE02476-ENG117371-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,49 ,121
IDE02476-ENG117372-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,121
IDE02476-ENG117373-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,49 ,121
IDE02476-ENG117374-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,121
IDE02476-ENG117375-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,49 ,121
IDE02476-ENG117376-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,121
IDE02476-ENG117377-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,49 ,121
IDE02502-Confirmation of installation change,8B 9A ,2
IDE02506-MAS03229-Copy multimedia data-Data carrier,On ,1
IDE02506-MAS03230-Copy multimedia data-Optical drive,OFF ,1
IDE02699-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02701-Number 1 (roaming) for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE04298-MAS01779-Vehicle dimensions-Length,0 mm,6
IDE04298-MAS01780-Vehicle dimensions-Width,0 mm,6
IDE04298-MAS02230-Vehicle dimensions-Height,0 mm,6
IDE04300-ENG252089-Vehicle menu operation-menu_ambient_illumination_2,not activated ,256
IDE04300-ENG252074-Vehicle menu operation-menu_ambient_illumination_2_after_disclaimer,not activated ,256
IDE04300-ENG252062-Vehicle menu operation-menu_ambient_illumination_2_clamp_15_off,not activated ,256
IDE04300-ENG252061-Vehicle menu operation-menu_ambient_illumination_2_over_threshold_high,not activated ,256
IDE04300-ENG252091-Vehicle menu operation-menu_ambient_illumination_2_stillstand,not activated ,256
IDE04300-ENG125811-Vehicle menu operation-menu_auxiliary_climatization,not activated ,256
IDE04300-ENG125814-Vehicle menu operation-menu_auxiliary_climatization_after_disclaimer,not activated ,256
IDE04300-ENG126995-Vehicle menu operation-menu_auxiliary_climatization_clamp_15_off,not activated ,256
IDE04300-ENG125812-Vehicle menu operation-menu_auxiliary_climatization_over_threshold_high,not activated ,256
IDE04300-ENG125813-Vehicle menu operation-menu_auxiliary_climatization_standstill,not activated ,256
IDE04300-ENG152538-Vehicle menu operation-menu_auxiliary_ventilation,not activated ,256
IDE04300-ENG152539-Vehicle menu operation-menu_auxiliary_ventilation_after_disclaimer,not activated ,256
IDE04300-ENG152540-Vehicle menu operation-menu_auxiliary_ventilation_clamp_15_off,not activated ,256
IDE04300-ENG152541-Vehicle menu operation-menu_auxiliary_ventilation_over_threshold_high,not activated ,256
IDE04300-ENG152542-Vehicle menu operation-menu_auxiliary_ventilation_standstill,not activated ,256
IDE04300-ENG297698-Vehicle menu operation-menu_BSIS,not activated ,256
IDE04300-ENG297699-Vehicle menu operation-menu_BSIS_after_disclaimer,not activated ,256
IDE04300-ENG297700-Vehicle menu operation-menu_BSIS_clamp_15_off,not activated ,256
IDE04300-ENG297701-Vehicle menu operation-menu_BSIS_over_threshold_high,not activated ,256
IDE04300-ENG297702-Vehicle menu operation-menu_BSIS_standstill,not activated ,256
IDE04300-ENG248728-Vehicle menu operation-menu_Car2X,not activated ,256
IDE04300-ENG248729-Vehicle menu operation-menu_Car2X_after_disclaimer,not activated ,256
IDE04300-ENG248730-Vehicle menu operation-menu_Car2X_clamp_15_off,not activated ,256
IDE04300-ENG248731-Vehicle menu operation-menu_Car2X_over_threshold_high,not activated ,256
IDE04300-ENG248732-Vehicle menu operation-menu_Car2X_stillstand,not activated ,256
IDE04300-ENG249906-Vehicle menu operation-menu_chassis_control,not activated ,256
IDE04300-ENG249907-Vehicle menu operation-menu_chassis_control_after_disclaimer,not activated ,256
IDE04300-ENG249908-Vehicle menu operation-menu_chassis_control_clamp_15_off,not activated ,256
IDE04300-ENG249909-Vehicle menu operation-menu_chassis_control_over_threshold_high,not activated ,256
IDE04300-ENG282005-Vehicle menu operation-menu_chassis_control_standstill,not activated ,256
IDE04300-ENG152495-Vehicle menu operation-menu_connection_manager,not activated ,256
IDE04300-ENG152499-Vehicle menu operation-menu_connection_manager_after_disclaimer,not activated ,256
IDE04300-ENG152496-Vehicle menu operation-menu_connection_manager_clamp_15_off,not activated ,256
IDE04300-ENG152497-Vehicle menu operation-menu_connection_manager_over_threshold_high,not activated ,256
IDE04300-ENG152498-Vehicle menu operation-menu_connection_manager_standstill,not activated ,256
IDE04300-ENG152543-Vehicle menu operation-menu_crossroad_assistent,not activated ,256
IDE04300-ENG152544-Vehicle menu operation-menu_crossroad_assistent_after_disclaimer,not activated ,256
IDE04300-ENG152545-Vehicle menu operation-menu_crossroad_assistent_clamp_15_off,not activated ,256
IDE04300-ENG152546-Vehicle menu operation-menu_crossroad_assistent_over_threshold_high,not activated ,256
IDE04300-ENG152547-Vehicle menu operation-menu_crossroad_assistent_standstill,not activated ,256
IDE04300-ENG152548-Vehicle menu operation-menu_daf_profile,not activated ,256
IDE04300-ENG152549-Vehicle menu operation-menu_daf_profile_after_disclaimer,not activated ,256
IDE04300-ENG152550-Vehicle menu operation-menu_daf_profile_clamp_15_off,not activated ,256
IDE04300-ENG152551-Vehicle menu operation-menu_daf_profile_over_threshold_high,not activated ,256
IDE04300-ENG152552-Vehicle menu operation-menu_daf_profile_stillstand,not activated ,256
IDE04300-ENG251562-Vehicle menu operation-menu_DCC_monitor,not activated ,256
IDE04300-ENG251561-Vehicle menu operation-menu_DCC_monitor_after_disclaimer,not activated ,256
IDE04300-ENG251559-Vehicle menu operation-menu_DCC_monitor_clamp_15_off,not activated ,256
IDE04300-ENG251557-Vehicle menu operation-menu_DCC_monitor_over_threshold_high,not activated ,256
IDE04300-ENG251558-Vehicle menu operation-menu_DCC_monitor_stillstand,not activated ,256
IDE04300-ENG117486-Vehicle menu operation-menu_display_ACC,not activated ,256
IDE04300-ENG117490-Vehicle menu operation-menu_display_ACC_after_disclaimer,not activated ,256
IDE04300-ENG117487-Vehicle menu operation-menu_display_ACC_operation_clamp_15_off,not activated ,256
IDE04300-ENG117488-Vehicle menu operation-menu_display_ACC_over_threshold_high,not activated ,256
IDE04300-ENG117489-Vehicle menu operation-menu_display_ACC_standstill,not activated ,256
IDE04300-ENG117646-Vehicle menu operation-menu_display_adaptive_key,not activated ,256
IDE04300-ENG117650-Vehicle menu operation-menu_display_adaptive_key_after_disclaimer,not activated ,256
IDE04300-ENG117647-Vehicle menu operation-menu_display_adaptive_key_clamp_15_off,not activated ,256
IDE04300-ENG117648-Vehicle menu operation-menu_display_adaptive_key_over_threshold_high,not activated ,256
IDE04300-ENG117649-Vehicle menu operation-menu_display_adaptive_key_standstill,not activated ,256
IDE04300-ENG126152-Vehicle menu operation-menu_display_Adblue,not activated ,256
IDE04300-ENG126155-Vehicle menu operation-menu_display_Adblue_after_disclaimer,not activated ,256
IDE04300-ENG127002-Vehicle menu operation-menu_display_Adblue_clamp_15_off,not activated ,256
IDE04300-ENG126153-Vehicle menu operation-menu_display_Adblue_over_threshold_high,not activated ,256
IDE04300-ENG126154-Vehicle menu operation-menu_display_Adblue_standstill,not activated ,256
IDE04300-ENG117591-Vehicle menu operation-menu_display_air_damper,not activated ,256
IDE04300-ENG117595-Vehicle menu operation-menu_display_air_damper_after_disclaimer,not activated ,256
IDE04300-ENG117592-Vehicle menu operation-menu_display_air_damper_clamp_15_off,not activated ,256
IDE04300-ENG117593-Vehicle menu operation-menu_display_air_damper_over_threshold_high,not activated ,256
IDE04300-ENG117594-Vehicle menu operation-menu_display_air_damper_standstill,not activated ,256
IDE04300-ENG117491-Vehicle menu operation-menu_display_ambient_illumination,activated ,256
IDE04300-ENG117495-Vehicle menu operation-menu_display_ambient_illumination_after_disclaimer,not activated ,256
IDE04300-ENG117492-Vehicle menu operation-menu_display_ambient_illumination_clamp_15_off,not activated ,256
IDE04300-ENG117493-Vehicle menu operation-menu_display_ambient_illumination_over_threshold_high,activated ,256
IDE04300-ENG117494-Vehicle menu operation-menu_display_ambient_illumination_standstill,not activated ,256
IDE04300-ENG122296-Vehicle menu operation-menu_display_angle_of_slope,not activated ,256
IDE04300-ENG122300-Vehicle menu operation-menu_display_angle_of_slope_after_disclaimer,not activated ,256
IDE04300-ENG122297-Vehicle menu operation-menu_display_angle_of_slope_clamp_15_off,not activated ,256
IDE04300-ENG122298-Vehicle menu operation-menu_display_angle_of_slope_over_threshold_high,not activated ,256
IDE04300-ENG122299-Vehicle menu operation-menu_display_angle_of_slope_standstill,not activated ,256
IDE04300-ENG117641-Vehicle menu operation-menu_display_attention_identification,not activated ,256
IDE04300-ENG117645-Vehicle menu operation-menu_display_attention_identification_after_disclaimer,not activated ,256
IDE04300-ENG117642-Vehicle menu operation-menu_display_attention_identification_clamp_15_off,not activated ,256
IDE04300-ENG117643-Vehicle menu operation-menu_display_attention_identification_over_threshold_high,not activated ,256
IDE04300-ENG117644-Vehicle menu operation-menu_display_attention_identification_standstill,not activated ,256
IDE04300-ENG117531-Vehicle menu operation-menu_display_auxiliary_heating,not activated ,256
IDE04300-ENG117535-Vehicle menu operation-menu_display_auxiliary_heating_after_disclaimer,not activated ,256
IDE04300-ENG117532-Vehicle menu operation-menu_display_auxiliary_heating_clamp_15_off,not activated ,256
IDE04300-ENG117533-Vehicle menu operation-menu_display_auxiliary_heating_over_threshold_high,not activated ,256
IDE04300-ENG117534-Vehicle menu operation-menu_display_auxiliary_heating_standstill,not activated ,256
IDE04300-ENG117501-Vehicle menu operation-menu_display_awv,activated ,256
IDE04300-ENG117505-Vehicle menu operation-menu_display_awv_after_disclaimer,not activated ,256
IDE04300-ENG117502-Vehicle menu operation-menu_display_awv_clamp_15_off,not activated ,256
IDE04300-ENG117503-Vehicle menu operation-menu_display_awv_over_threshold_high,activated ,256
IDE04300-ENG117504-Vehicle menu operation-menu_display_awv_standstill,not activated ,256
IDE04300-ENG122301-Vehicle menu operation-menu_display_battery_management,not activated ,256
IDE04300-ENG122305-Vehicle menu operation-menu_display_battery_management_after_disclaimer,not activated ,256
IDE04300-ENG122302-Vehicle menu operation-menu_display_battery_management_clamp_15_off,not activated ,256
IDE04300-ENG122303-Vehicle menu operation-menu_display_battery_management_over_threshold_high,not activated ,256
IDE04300-ENG122304-Vehicle menu operation-menu_display_battery_management_standstill,not activated ,256
IDE04300-ENG117666-Vehicle menu operation-menu_display_BCmE,activated ,256
IDE04300-ENG117670-Vehicle menu operation-menu_display_BCmE_after_disclaimer,not activated ,256
IDE04300-ENG117667-Vehicle menu operation-menu_display_BCmE_clamp_15_off,not activated ,256
IDE04300-ENG117668-Vehicle menu operation-menu_display_BCmE_over_threshold_high,activated ,256
IDE04300-ENG117669-Vehicle menu operation-menu_display_BCmE_standstill,not activated ,256
IDE04300-ENG117536-Vehicle menu operation-menu_display_board_computer,activated ,256
IDE04300-ENG117540-Vehicle menu operation-menu_display_board_computer_after_disclaimer,not activated ,256
IDE04300-ENG117537-Vehicle menu operation-menu_display_board_computer_clamp_15_off,not activated ,256
IDE04300-ENG117538-Vehicle menu operation-menu_display_board_computer_over_threshold_high,activated ,256
IDE04300-ENG117539-Vehicle menu operation-menu_display_board_computer_standstill,not activated ,256
IDE04300-ENG117671-Vehicle menu operation-menu_display_Brake_Function,activated ,256
IDE04300-ENG117675-Vehicle menu operation-menu_display_Brake_Function_after_disclaimer,not activated ,256
IDE04300-ENG117672-Vehicle menu operation-menu_display_Brake_Function_clamp_15_off,not activated ,256
IDE04300-ENG117673-Vehicle menu operation-menu_display_Brake_Function_over_threshold_high,activated ,256
IDE04300-ENG117674-Vehicle menu operation-menu_display_Brake_Function_standstill,not activated ,256
IDE04300-ENG117651-Vehicle menu operation-menu_display_car_mirror,activated ,256
IDE04300-ENG117655-Vehicle menu operation-menu_display_car_mirror_after_disclaimer,not activated ,256
IDE04300-ENG117652-Vehicle menu operation-menu_display_car_mirror_clamp_15_off,not activated ,256
IDE04300-ENG117653-Vehicle menu operation-menu_display_car_mirror_over_threshold_high,activated ,256
IDE04300-ENG117654-Vehicle menu operation-menu_display_car_mirror_standstill,not activated ,256
IDE04300-ENG117561-Vehicle menu operation-menu_display_central_locking,activated ,256
IDE04300-ENG117565-Vehicle menu operation-menu_display_central_locking_after_disclaimer,not activated ,256
IDE04300-ENG117562-Vehicle menu operation-menu_display_central_locking_clamp_15_off,not activated ,256
IDE04300-ENG117563-Vehicle menu operation-menu_display_central_locking_over_threshold_high,activated ,256
IDE04300-ENG117564-Vehicle menu operation-menu_display_central_locking_standstill,not activated ,256
IDE04300-ENG117601-Vehicle menu operation-menu_display_central_unit_master,activated ,256
IDE04300-ENG117605-Vehicle menu operation-menu_display_central_unit_master_after_disclaimer,not activated ,256
IDE04300-ENG117602-Vehicle menu operation-menu_display_central_unit_master_clamp_15_off,not activated ,256
IDE04300-ENG117603-Vehicle menu operation-menu_display_central_unit_master_over_threshold_high,activated ,256
IDE04300-ENG117604-Vehicle menu operation-menu_display_central_unit_master_standstill,not activated ,256
IDE04300-ENG117571-Vehicle menu operation-menu_display_charisma,not activated ,256
IDE04300-ENG117575-Vehicle menu operation-menu_display_charisma_after_disclaimer,not activated ,256
IDE04300-ENG117572-Vehicle menu operation-menu_display_charisma_clamp_15_off,not activated ,256
IDE04300-ENG117573-Vehicle menu operation-menu_display_charisma_over_threshold_high,not activated ,256
IDE04300-ENG117574-Vehicle menu operation-menu_display_charisma_standstill,not activated ,256
IDE04300-ENG117526-Vehicle menu operation-menu_display_clima_configuration,not activated ,256
IDE04300-ENG117530-Vehicle menu operation-menu_display_clima_configuration_after_disclaimer,not activated ,256
IDE04300-ENG117527-Vehicle menu operation-menu_display_clima_configuration_clamp_15_off,not activated ,256
IDE04300-ENG117528-Vehicle menu operation-menu_display_clima_configuration_over_threshold_high,not activated ,256
IDE04300-ENG117529-Vehicle menu operation-menu_display_clima_configuration_standstill,not activated ,256
IDE04300-ENG117586-Vehicle menu operation-menu_display_clock,activated ,256
IDE04300-ENG117590-Vehicle menu operation-menu_display_clock_after_disclaimer,not activated ,256
IDE04300-ENG117587-Vehicle menu operation-menu_display_clock_clamp_15_off,not activated ,256
IDE04300-ENG117588-Vehicle menu operation-menu_display_clock_over_threshold_high,activated ,256
IDE04300-ENG117589-Vehicle menu operation-menu_display_clock_standstill,not activated ,256
IDE04300-ENG117566-Vehicle menu operation-menu_display_compass,activated ,256
IDE04300-ENG117570-Vehicle menu operation-menu_display_compass_after_disclaimer,not activated ,256
IDE04300-ENG117567-Vehicle menu operation-menu_display_compass_clamp_15_off,not activated ,256
IDE04300-ENG117568-Vehicle menu operation-menu_display_compass_over_threshold_high,activated ,256
IDE04300-ENG117569-Vehicle menu operation-menu_display_compass_standstill,not activated ,256
IDE04300-ENG125823-Vehicle menu operation-menu_display_Curve_Assist,not activated ,256
IDE04300-ENG125826-Vehicle menu operation-menu_display_Curve_Assist_after_disclaimer,not activated ,256
IDE04300-ENG126998-Vehicle menu operation-menu_display_Curve_Assist_clamp_15_off,not activated ,256
IDE04300-ENG125824-Vehicle menu operation-menu_display_Curve_Assist_over_threshold_high,not activated ,256
IDE04300-ENG125825-Vehicle menu operation-menu_display_Curve_Assist_standstill,not activated ,256
IDE04300-ENG142087-Vehicle menu operation-menu_display_Display_Configuration,not activated ,256
IDE04300-ENG142091-Vehicle menu operation-menu_display_Display_Configuration_after_disclaimer,not activated ,256
IDE04300-ENG142088-Vehicle menu operation-menu_display_Display_Configuration_clamp_15_off,not activated ,256
IDE04300-ENG142089-Vehicle menu operation-menu_display_Display_Configuration_over_threshold_high,not activated ,256
IDE04300-ENG142090-Vehicle menu operation-menu_display_Display_Configuration_standstill,not activated ,256
IDE04300-ENG117656-Vehicle menu operation-menu_display_driving_school,not activated ,256
IDE04300-ENG117660-Vehicle menu operation-menu_display_driving_school_after_disclaimer,not activated ,256
IDE04300-ENG117657-Vehicle menu operation-menu_display_driving_school_clamp_15_off,not activated ,256
IDE04300-ENG117658-Vehicle menu operation-menu_display_driving_school_over_threshold_high,not activated ,256
IDE04300-ENG117659-Vehicle menu operation-menu_display_driving_school_standstill,not activated ,256
IDE04300-ENG125034-Vehicle menu operation-menu_display_Ecall,activated ,256
IDE04300-ENG125038-Vehicle menu operation-menu_display_Ecall_after_disclaimer,not activated ,256
IDE04300-ENG126999-Vehicle menu operation-menu_display_eCall_clamp_15_off,not activated ,256
IDE04300-ENG125036-Vehicle menu operation-menu_display_Ecall_over_threshold_high,activated ,256
IDE04300-ENG125037-Vehicle menu operation-menu_display_Ecall_standstill,not activated ,256
IDE04300-ENG126160-Vehicle menu operation-menu_display_Efficiency_Assist,not activated ,256
IDE04300-ENG126163-Vehicle menu operation-menu_display_Efficiency_Assist_after_disclaimer,not activated ,256
IDE04300-ENG127004-Vehicle menu operation-menu_display_Efficiency_Assist_clamp_15_off,not activated ,256
IDE04300-ENG126161-Vehicle menu operation-menu_display_Efficiency_Assist_over_threshold_high,not activated ,256
IDE04300-ENG126162-Vehicle menu operation-menu_display_Efficiency_Assist_standstill,not activated ,256
IDE04300-ENG126144-Vehicle menu operation-menu_display_ENI,activated ,256
IDE04300-ENG126147-Vehicle menu operation-menu_display_ENI_after_disclaimer,not activated ,256
IDE04300-ENG127000-Vehicle menu operation-menu_display_ENI_clamp_15_off,not activated ,256
IDE04300-ENG126145-Vehicle menu operation-menu_display_ENI_over_threshold_high,activated ,256
IDE04300-ENG126146-Vehicle menu operation-menu_display_ENI_standstill,not activated ,256
IDE04300-ENG117516-Vehicle menu operation-menu_display_exterior_illumination,activated ,256
IDE04300-ENG117520-Vehicle menu operation-menu_display_exterior_illumination_after_disclaimer,not activated ,256
IDE04300-ENG117517-Vehicle menu operation-menu_display_exterior_illumination_clamp_15_off,not activated ,256
IDE04300-ENG117518-Vehicle menu operation-menu_display_exterior_illumination_over_threshold_high,activated ,256
IDE04300-ENG117519-Vehicle menu operation-menu_display_exterior_illumination_standstill,not activated ,256
IDE04300-ENG117596-Vehicle menu operation-menu_display_headup_display,not activated ,256
IDE04300-ENG117600-Vehicle menu operation-menu_display_headup_display_after_disclaimer,not activated ,256
IDE04300-ENG117597-Vehicle menu operation-menu_display_headup_display_clamp_15_off,not activated ,256
IDE04300-ENG117598-Vehicle menu operation-menu_display_headup_display_over_threshold_high,not activated ,256
IDE04300-ENG117599-Vehicle menu operation-menu_display_headup_display_standstill,not activated ,256
IDE04300-ENG117606-Vehicle menu operation-menu_display_hybrid,not activated ,256
IDE04300-ENG117610-Vehicle menu operation-menu_display_hybrid_after_disclaimer,not activated ,256
IDE04300-ENG117607-Vehicle menu operation-menu_display_hybrid_clamp_15_off,not activated ,256
IDE04300-ENG117608-Vehicle menu operation-menu_display_hybrid_over_threshold_high,not activated ,256
IDE04300-ENG117609-Vehicle menu operation-menu_display_hybrid_standstill,not activated ,256
IDE04300-ENG125805-Vehicle menu operation-menu_display_lane_assistant,not activated ,256
IDE04300-ENG125809-Vehicle menu operation-menu_display_lane_assistant_after_disclaimer,not activated ,256
IDE04300-ENG125806-Vehicle menu operation-menu_display_lane_assistant_clamp_15_off,not activated ,256
IDE04300-ENG125807-Vehicle menu operation-menu_display_lane_assistant_over_threshold_high,not activated ,256
IDE04300-ENG125808-Vehicle menu operation-menu_display_lane_assistant_standstill,not activated ,256
IDE04300-ENG117506-Vehicle menu operation-menu_display_Lane_Departure_Warning,activated ,256
IDE04300-ENG117510-Vehicle menu operation-menu_display_Lane_Departure_Warning_after_disclaimer,not activated ,256
IDE04300-ENG117507-Vehicle menu operation-menu_display_Lane_Departure_Warning_clamp_15_off,not activated ,256
IDE04300-ENG117508-Vehicle menu operation-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,256
IDE04300-ENG117509-Vehicle menu operation-menu_display_Lane_Departure_Warning_standstill,not activated ,256
IDE04300-ENG117631-Vehicle menu operation-menu_display_MFL_jocker,not activated ,256
IDE04300-ENG117635-Vehicle menu operation-menu_display_MFL_jocker_after_disclaimer,not activated ,256
IDE04300-ENG117632-Vehicle menu operation-menu_display_MFL_jocker_clamp_15_off,not activated ,256
IDE04300-ENG117633-Vehicle menu operation-menu_display_MFL_jocker_over_threshold_high,not activated ,256
IDE04300-ENG117634-Vehicle menu operation-menu_display_MFL_jocker_standstill,not activated ,256
IDE04300-ENG117616-Vehicle menu operation-menu_display_night_vision,not activated ,256
IDE04300-ENG117620-Vehicle menu operation-menu_display_night_vision_after_disclaimer,not activated ,256
IDE04300-ENG117617-Vehicle menu operation-menu_display_night_vision_clamp_15_off,not activated ,256
IDE04300-ENG117618-Vehicle menu operation-menu_display_night_vision_over_threshold_high,not activated ,256
IDE04300-ENG117619-Vehicle menu operation-menu_display_night_vision_standstill,not activated ,256
IDE04300-ENG117576-Vehicle menu operation-menu_display_oil_level,not activated ,256
IDE04300-ENG117580-Vehicle menu operation-menu_display_oil_level_after_disclaimer,not activated ,256
IDE04300-ENG117577-Vehicle menu operation-menu_display_oil_level_clamp_15_off,not activated ,256
IDE04300-ENG117578-Vehicle menu operation-menu_display_oil_level_over_threshold_high,not activated ,256
IDE04300-ENG117579-Vehicle menu operation-menu_display_oil_level_standstill,not activated ,256
IDE04300-ENG117496-Vehicle menu operation-menu_display_pdc,activated ,256
IDE04300-ENG117500-Vehicle menu operation-menu_display_pdc_after_disclaimer,not activated ,256
IDE04300-ENG117497-Vehicle menu operation-menu_display_pdc_clamp_15_off,not activated ,256
IDE04300-ENG117498-Vehicle menu operation-menu_display_pdc_over_threshold_high,activated ,256
IDE04300-ENG117499-Vehicle menu operation-menu_display_pdc_standstill,not activated ,256
IDE04300-ENG125815-Vehicle menu operation-menu_display_Pedestrian_Assist,not activated ,256
IDE04300-ENG125818-Vehicle menu operation-menu_display_Pedestrian_Assist_after_disclaimer,not activated ,256
IDE04300-ENG126996-Vehicle menu operation-menu_display_Pedestrian_Assist_clamp_15_off,not activated ,256
IDE04300-ENG125816-Vehicle menu operation-menu_display_Pedestrian_Assist_over_threshold_high,not activated ,256
IDE04300-ENG125817-Vehicle menu operation-menu_display_Pedestrian_Assist_standstill,not activated ,256
IDE04300-ENG117541-Vehicle menu operation-menu_display_rdk,activated ,256
IDE04300-ENG117545-Vehicle menu operation-menu_display_rdk_after_disclaimer,not activated ,256
IDE04300-ENG117542-Vehicle menu operation-menu_display_rdk_clamp_15_off,not activated ,256
IDE04300-ENG117543-Vehicle menu operation-menu_display_rdk_over_threshold_high,activated ,256
IDE04300-ENG117544-Vehicle menu operation-menu_display_rdk_standstill,not activated ,256
IDE04300-ENG122306-Vehicle menu operation-menu_display_RearSeatEntertainment,not activated ,256
IDE04300-ENG122310-Vehicle menu operation-menu_display_RearSeatEntertainment_after_disclaimer,not activated ,256
IDE04300-ENG122307-Vehicle menu operation-menu_display_RearSeatEntertainment_clamp_15_off,not activated ,256
IDE04300-ENG122308-Vehicle menu operation-menu_display_RearSeatEntertainment_over_threshold_high,not activated ,256
IDE04300-ENG122309-Vehicle menu operation-menu_display_RearSeatEntertainment_standstill,not activated ,256
IDE04300-ENG117626-Vehicle menu operation-menu_display_reversible_belt_pre_load,not activated ,256
IDE04300-ENG117630-Vehicle menu operation-menu_display_reversible_belt_pre_load_after_disclaimer,not activated ,256
IDE04300-ENG117627-Vehicle menu operation-menu_display_reversible_belt_pre_load_clamp_15_off,not activated ,256
IDE04300-ENG117628-Vehicle menu operation-menu_display_reversible_belt_pre_load_over_threshold_high,not activated ,256
IDE04300-ENG117629-Vehicle menu operation-menu_display_reversible_belt_pre_load_standstill,not activated ,256
IDE04300-ENG117636-Vehicle menu operation-menu_display_road_sign_identification,not activated ,256
IDE04300-ENG117640-Vehicle menu operation-menu_display_road_sign_identification_after_disclaimer,not activated ,256
IDE04300-ENG117637-Vehicle menu operation-menu_display_road_sign_identification_clamp_15_off,not activated ,256
IDE04300-ENG117638-Vehicle menu operation-menu_display_road_sign_identification_over_threshold_high,not activated ,256
IDE04300-ENG117639-Vehicle menu operation-menu_display_road_sign_identification_standstill,not activated ,256
IDE04300-ENG117556-Vehicle menu operation-menu_display_seat_configuration,not activated ,256
IDE04300-ENG117560-Vehicle menu operation-menu_display_seat_configuration_after_disclaimer,not activated ,256
IDE04300-ENG117557-Vehicle menu operation-menu_display_seat_configuration_clamp_15_off,not activated ,256
IDE04300-ENG117558-Vehicle menu operation-menu_display_seat_configuration_over_threshold_high,not activated ,256
IDE04300-ENG117559-Vehicle menu operation-menu_display_seat_configuration_standstill,not activated ,256
IDE04300-ENG125819-Vehicle menu operation-menu_display_Seat_Pneumatic,not activated ,256
IDE04300-ENG125822-Vehicle menu operation-menu_display_Seat_Pneumatic_after_disclaimer,not activated ,256
IDE04300-ENG126997-Vehicle menu operation-menu_display_Seat_Pneumatic_clamp_15_off,not activated ,256
IDE04300-ENG125820-Vehicle menu operation-menu_display_Seat_Pneumatic_over_threshold_high,not activated ,256
IDE04300-ENG125821-Vehicle menu operation-menu_display_Seat_Pneumatic_standstill,not activated ,256
IDE04300-ENG117551-Vehicle menu operation-menu_display_sia,activated ,256
IDE04300-ENG117555-Vehicle menu operation-menu_display_sia_after_disclaimer,not activated ,256
IDE04300-ENG117552-Vehicle menu operation-menu_display_sia_clamp_15_off,not activated ,256
IDE04300-ENG117553-Vehicle menu operation-menu_display_sia_over_threshold_high,activated ,256
IDE04300-ENG117554-Vehicle menu operation-menu_display_sia_standstill,not activated ,256
IDE04300-ENG117621-Vehicle menu operation-menu_display_side_view,not activated ,256
IDE04300-ENG117625-Vehicle menu operation-menu_display_side_view_after_disclaimer,not activated ,256
IDE04300-ENG117622-Vehicle menu operation-menu_display_side_view_clamp_15_off,not activated ,256
IDE04300-ENG117623-Vehicle menu operation-menu_display_side_view_over_threshold_high,not activated ,256
IDE04300-ENG117624-Vehicle menu operation-menu_display_side_view_standstill,not activated ,256
IDE04300-ENG122311-Vehicle menu operation-menu_display_special_functions,not activated ,256
IDE04300-ENG122314-Vehicle menu operation-menu_display_special_functions_after_disclaimer,not activated ,256
IDE04300-ENG125810-Vehicle menu operation-menu_display_special_functions_clamp_15_off,not activated ,256
IDE04300-ENG122312-Vehicle menu operation-menu_display_special_functions_over_threshold_high,not activated ,256
IDE04300-ENG122313-Vehicle menu operation-menu_display_special_functions_standstill,not activated ,256
IDE04300-ENG142082-Vehicle menu operation-menu_display_Spoiler,not activated ,256
IDE04300-ENG142086-Vehicle menu operation-menu_display_Spoiler_after_disclaimer,not activated ,256
IDE04300-ENG142083-Vehicle menu operation-menu_display_Spoiler_clamp_15_off,not activated ,256
IDE04300-ENG142084-Vehicle menu operation-menu_display_Spoiler_over_threshold_high,not activated ,256
IDE04300-ENG142085-Vehicle menu operation-menu_display_Spoiler_standstill,not activated ,256
IDE04300-ENG126148-Vehicle menu operation-menu_display_SportHMI,not activated ,256
IDE04300-ENG126151-Vehicle menu operation-menu_display_SportHMI_after_disclaimer,not activated ,256
IDE04300-ENG127001-Vehicle menu operation-menu_display_SportHMI_clamp_15_off,not activated ,256
IDE04300-ENG126149-Vehicle menu operation-menu_display_SportHMI_over_threshold_high,not activated ,256
IDE04300-ENG126150-Vehicle menu operation-menu_display_SportHMI_standstill,not activated ,256
IDE04300-ENG117676-Vehicle menu operation-menu_display_Start_Stop_reasons,not activated ,256
IDE04300-ENG117680-Vehicle menu operation-menu_display_Start_Stop_reasons_after_disclaimer,not activated ,256
IDE04300-ENG117677-Vehicle menu operation-menu_display_Start_Stop_reasons_clamp_15_off,not activated ,256
IDE04300-ENG117678-Vehicle menu operation-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,256
IDE04300-ENG117679-Vehicle menu operation-menu_display_Start_Stop_reasons_standstill,not activated ,256
IDE04300-ENG122315-Vehicle menu operation-menu_display_trailer_assistant,not activated ,256
IDE04300-ENG122319-Vehicle menu operation-menu_display_trailer_assistant_after_disclaimer,not activated ,256
IDE04300-ENG122316-Vehicle menu operation-menu_display_trailer_assistant_clamp_15_off,not activated ,256
IDE04300-ENG122317-Vehicle menu operation-menu_display_trailer_assistant_over_threshold_high,not activated ,256
IDE04300-ENG122318-Vehicle menu operation-menu_display_trailer_assistant_standstill,not activated ,256
IDE04300-ENG122320-Vehicle menu operation-menu_display_TV_tuner,not activated ,256
IDE04300-ENG122324-Vehicle menu operation-menu_display_TV_tuner_after_disclaimer,not activated ,256
IDE04300-ENG122321-Vehicle menu operation-menu_display_TV_tuner_clamp_15_off,not activated ,256
IDE04300-ENG122322-Vehicle menu operation-menu_display_TV_tuner_over_threshold_high,not activated ,256
IDE04300-ENG122323-Vehicle menu operation-menu_display_TV_tuner_standstill,not activated ,256
IDE04300-ENG117611-Vehicle menu operation-menu_display_ugdo,not activated ,256
IDE04300-ENG117615-Vehicle menu operation-menu_display_ugdo_after_disclaimer,not activated ,256
IDE04300-ENG117612-Vehicle menu operation-menu_display_ugdo_clamp_15_off,not activated ,256
IDE04300-ENG117613-Vehicle menu operation-menu_display_ugdo_over_threshold_high,not activated ,256
IDE04300-ENG117614-Vehicle menu operation-menu_display_ugdo_standstill,not activated ,256
IDE04300-ENG122291-Vehicle menu operation-menu_display_user_eco_rating,not activated ,256
IDE04300-ENG122295-Vehicle menu operation-menu_display_user_eco_rating_after_disclaimer,not activated ,256
IDE04300-ENG122292-Vehicle menu operation-menu_display_user_eco_rating_clamp_15_off,not activated ,256
IDE04300-ENG122293-Vehicle menu operation-menu_display_user_eco_rating_over_threshold_high,not activated ,256
IDE04300-ENG122294-Vehicle menu operation-menu_display_user_eco_rating_standstill,not activated ,256
IDE04300-ENG117581-Vehicle menu operation-menu_display_vin,activated ,256
IDE04300-ENG117585-Vehicle menu operation-menu_display_vin_after_disclaimer,not activated ,256
IDE04300-ENG117582-Vehicle menu operation-menu_display_vin_clamp_15_off,not activated ,256
IDE04300-ENG117583-Vehicle menu operation-menu_display_vin_over_threshold_high,activated ,256
IDE04300-ENG117584-Vehicle menu operation-menu_display_vin_standstill,not activated ,256
IDE04300-ENG117661-Vehicle menu operation-menu_display_weariness_recognition,not activated ,256
IDE04300-ENG117665-Vehicle menu operation-menu_display_weariness_recognition_after_disclaimer,not activated ,256
IDE04300-ENG117662-Vehicle menu operation-menu_display_weariness_recognition_clamp_15_off,not activated ,256
IDE04300-ENG117663-Vehicle menu operation-menu_display_weariness_recognition_over_threshold_high,not activated ,256
IDE04300-ENG117664-Vehicle menu operation-menu_display_weariness_recognition_standstill,not activated ,256
IDE04300-ENG117521-Vehicle menu operation-menu_display_windows,activated ,256
IDE04300-ENG117525-Vehicle menu operation-menu_display_windows_after_disclaimer,not activated ,256
IDE04300-ENG117522-Vehicle menu operation-menu_display_windows_clamp_15_off,not activated ,256
IDE04300-ENG117523-Vehicle menu operation-menu_display_windows_over_threshold_high,activated ,256
IDE04300-ENG117524-Vehicle menu operation-menu_display_windows_standstill,not activated ,256
IDE04300-ENG117546-Vehicle menu operation-menu_display_wiper,activated ,256
IDE04300-ENG117550-Vehicle menu operation-menu_display_wiper_after_disclaimer,not activated ,256
IDE04300-ENG117547-Vehicle menu operation-menu_display_wiper_clamp_15_off,not activated ,256
IDE04300-ENG117548-Vehicle menu operation-menu_display_wiper_over_threshold_high,activated ,256
IDE04300-ENG117549-Vehicle menu operation-menu_display_wiper_standstill,not activated ,256
IDE04300-ENG297703-Vehicle menu operation-menu_Doorlocking_2nd,not activated ,256
IDE04300-ENG297704-Vehicle menu operation-menu_Doorlocking_2nd_after_disclaimer,not activated ,256
IDE04300-ENG297705-Vehicle menu operation-menu_Doorlocking_2nd_clamp_15_off,not activated ,256
IDE04300-ENG297706-Vehicle menu operation-menu_Doorlocking_2nd_over_threshold_high,not activated ,256
IDE04300-ENG297707-Vehicle menu operation-menu_Doorlocking_2nd_standstill,not activated ,256
IDE04300-ENG302732-Vehicle menu operation-menu_DrivingDynamics,not activated ,256
IDE04300-ENG302733-Vehicle menu operation-menu_DrivingDynamics_after_disclaimer,not activated ,256
IDE04300-ENG302734-Vehicle menu operation-menu_DrivingDynamics_clamp_15_off,not activated ,256
IDE04300-ENG302735-Vehicle menu operation-menu_DrivingDynamics_over_threshold_high,not activated ,256
IDE04300-ENG302736-Vehicle menu operation-menu_DrivingDynamics_standstill,not activated ,256
IDE04300-ENG248733-Vehicle menu operation-menu_EngineFunctions,not activated ,256
IDE04300-ENG248734-Vehicle menu operation-menu_EngineFunctions_after_disclaimer,not activated ,256
IDE04300-ENG248735-Vehicle menu operation-menu_EngineFunctions_clamp_15_off,not activated ,256
IDE04300-ENG248736-Vehicle menu operation-menu_EngineFunctions_over_threshold_high,not activated ,256
IDE04300-ENG248737-Vehicle menu operation-menu_EngineFunctions_stillstand,not activated ,256
IDE04300-ENG252067-Vehicle menu operation-menu_exterior_illumination_2,not activated ,256
IDE04300-ENG252055-Vehicle menu operation-menu_exterior_illumination_2_after_disclaimer,not activated ,256
IDE04300-ENG252059-Vehicle menu operation-menu_exterior_illumination_2_clamp_15_off,not activated ,256
IDE04300-ENG252069-Vehicle menu operation-menu_exterior_illumination_2_over_threshold_high,not activated ,256
IDE04300-ENG252082-Vehicle menu operation-menu_exterior_illumination_2_stillstand,not activated ,256
IDE04300-ENG152515-Vehicle menu operation-menu_fas_profile,not activated ,256
IDE04300-ENG152519-Vehicle menu operation-menu_fas_profile_after_disclaimer,not activated ,256
IDE04300-ENG152516-Vehicle menu operation-menu_fas_profile_clamp_15_off,not activated ,256
IDE04300-ENG152517-Vehicle menu operation-menu_fas_profile_over_threshold_high,not activated ,256
IDE04300-ENG248738-Vehicle menu operation-menu_fas_profile_stillstand,not activated ,256
IDE04300-ENG185798-Vehicle menu operation-menu_fod,not activated ,256
IDE04300-ENG185799-Vehicle menu operation-menu_fod_after_disclaimer,not activated ,256
IDE04300-ENG185800-Vehicle menu operation-menu_fod_clamp_15_off,not activated ,256
IDE04300-ENG185801-Vehicle menu operation-menu_fod_over_threshold_high,not activated ,256
IDE04300-ENG185802-Vehicle menu operation-menu_fod_stillstand,not activated ,256
IDE04300-ENG248739-Vehicle menu operation-menu_IAA_PSO,activated ,256
IDE04300-ENG248740-Vehicle menu operation-menu_IAA_PSO_after_disclaimer,not activated ,256
IDE04300-ENG248741-Vehicle menu operation-menu_IAA_PSO_clamp_15_off,not activated ,256
IDE04300-ENG248742-Vehicle menu operation-menu_IAA_PSO_over_threshold_high,activated ,256
IDE04300-ENG248743-Vehicle menu operation-menu_IAA_PSO_stillstand,not activated ,256
IDE04300-ENG248744-Vehicle menu operation-menu_ITM,not activated ,256
IDE04300-ENG248745-Vehicle menu operation-menu_ITM_after_disclaimer,not activated ,256
IDE04300-ENG248746-Vehicle menu operation-menu_ITM_clamp_15_off,not activated ,256
IDE04300-ENG248747-Vehicle menu operation-menu_ITM_over_threshold_high,not activated ,256
IDE04300-ENG248748-Vehicle menu operation-menu_ITM_stillstand,not activated ,256
IDE04300-ENG249916-Vehicle menu operation-menu_lift,not activated ,256
IDE04300-ENG249917-Vehicle menu operation-menu_lift_after_disclaimer,not activated ,256
IDE04300-ENG249918-Vehicle menu operation-menu_lift_clamp_15_off,not activated ,256
IDE04300-ENG249919-Vehicle menu operation-menu_lift_over_threshold_high,not activated ,256
IDE04300-ENG249920-Vehicle menu operation-menu_lift_stillstand,not activated ,256
IDE04300-ENG281916-Vehicle menu operation-menu_LLCC,not activated ,256
IDE04300-ENG281940-Vehicle menu operation-menu_LLCC_after_disclaimer,not activated ,256
IDE04300-ENG282002-Vehicle menu operation-menu_LLCC_clamp_15_off,not activated ,256
IDE04300-ENG281920-Vehicle menu operation-menu_LLCC_over_threshold_high,not activated ,256
IDE04300-ENG281919-Vehicle menu operation-menu_LLCC_standstill,not activated ,256
IDE04300-ENG184478-Vehicle menu operation-menu_mascot,not activated ,256
IDE04300-ENG184479-Vehicle menu operation-menu_mascot_after_disclaimer,not activated ,256
IDE04300-ENG184480-Vehicle menu operation-menu_mascot_clamp_15_off,not activated ,256
IDE04300-ENG184481-Vehicle menu operation-menu_mascot_over_threshold_high,not activated ,256
IDE04300-ENG184482-Vehicle menu operation-menu_mascot_stillstand,not activated ,256
IDE04300-ENG152562-Vehicle menu operation-menu_mobile_device_key_profile,not activated ,256
IDE04300-ENG152563-Vehicle menu operation-menu_mobile_device_key_profile_after_disclaimer,not activated ,256
IDE04300-ENG152564-Vehicle menu operation-menu_mobile_device_key_profile_clamp_15_off,not activated ,256
IDE04300-ENG152565-Vehicle menu operation-menu_mobile_device_key_profile_over_threshold_high,not activated ,256
IDE04300-ENG152566-Vehicle menu operation-menu_mobile_device_key_profile_stillstand,not activated ,256
IDE04300-ENG297708-Vehicle menu operation-menu_MOIS,not activated ,256
IDE04300-ENG297709-Vehicle menu operation-menu_MOIS_after_disclaimer,not activated ,256
IDE04300-ENG297710-Vehicle menu operation-menu_MOIS_clamp_15_off,not activated ,256
IDE04300-ENG297711-Vehicle menu operation-menu_MOIS_over_threshold_high,not activated ,256
IDE04300-ENG297712-Vehicle menu operation-menu_MOIS_standstill,not activated ,256
IDE04300-ENG248749-Vehicle menu operation-menu_PaCo,not activated ,256
IDE04300-ENG248750-Vehicle menu operation-menu_PaCo_after_disclaimer,not activated ,256
IDE04300-ENG248751-Vehicle menu operation-menu_PaCo_clamp_15_off,not activated ,256
IDE04300-ENG248752-Vehicle menu operation-menu_PaCo_over_threshold_high,not activated ,256
IDE04300-ENG248753-Vehicle menu operation-menu_PaCo_stillstand,not activated ,256
IDE04300-ENG302737-Vehicle menu operation-menu_RollingAbility,not activated ,256
IDE04300-ENG302738-Vehicle menu operation-menu_RollingAbility_after_disclaimer,not activated ,256
IDE04300-ENG302739-Vehicle menu operation-menu_RollingAbility_clamp_15_off,not activated ,256
IDE04300-ENG302740-Vehicle menu operation-menu_RollingAbility_over_threshold_high,not activated ,256
IDE04300-ENG302741-Vehicle menu operation-menu_RollingAbility_standstill,not activated ,256
IDE04300-ENG297713-Vehicle menu operation-menu_RushhourPilot,not activated ,256
IDE04300-ENG297714-Vehicle menu operation-menu_RushhourPilot_after_disclaimer,not activated ,256
IDE04300-ENG297715-Vehicle menu operation-menu_RushhourPilot_clamp_15_off,not activated ,256
IDE04300-ENG297716-Vehicle menu operation-menu_RushhourPilot_over_threshold_high,not activated ,256
IDE04300-ENG297717-Vehicle menu operation-menu_RushhourPilot_standstill,not activated ,256
IDE04300-ENG142092-Vehicle menu operation-menu_soundcontrol,not activated ,256
IDE04300-ENG248754-Vehicle menu operation-menu_SoundControl_2,not activated ,256
IDE04300-ENG248755-Vehicle menu operation-menu_SoundControl_2_after_disclaimer,not activated ,256
IDE04300-ENG248756-Vehicle menu operation-menu_SoundControl_2_clamp_15_off,not activated ,256
IDE04300-ENG248757-Vehicle menu operation-menu_SoundControl_2_over_threshold_high,not activated ,256
IDE04300-ENG248758-Vehicle menu operation-menu_SoundControl_2_stillstand,not activated ,256
IDE04300-ENG142096-Vehicle menu operation-menu_soundcontrol_after_disclaimer,not activated ,256
IDE04300-ENG142093-Vehicle menu operation-menu_soundcontrol_clamp_15_off,not activated ,256
IDE04300-ENG142094-Vehicle menu operation-menu_soundcontrol_over_threshold_high,not activated ,256
IDE04300-ENG142095-Vehicle menu operation-menu_soundcontrol_standstill,not activated ,256
IDE04300-ENG152505-Vehicle menu operation-menu_statistic,not activated ,256
IDE04300-ENG152509-Vehicle menu operation-menu_statistic_after_disclaimer,not activated ,256
IDE04300-ENG152506-Vehicle menu operation-menu_statistic_clamp_15_off,not activated ,256
IDE04300-ENG152507-Vehicle menu operation-menu_statistic_over_threshold_high,not activated ,256
IDE04300-ENG248759-Vehicle menu operation-menu_statistic_stillstand,not activated ,256
IDE04300-ENG152510-Vehicle menu operation-menu_sunroof,not activated ,256
IDE04300-ENG152514-Vehicle menu operation-menu_sunroof_after_disclaimer,not activated ,256
IDE04300-ENG152511-Vehicle menu operation-menu_sunroof_clamp_15_off,not activated ,256
IDE04300-ENG152512-Vehicle menu operation-menu_sunroof_over_threshold_high,not activated ,256
IDE04300-ENG248760-Vehicle menu operation-menu_sunroof_stillstand,not activated ,256
IDE04300-ENG185803-Vehicle menu operation-menu_vas,not activated ,256
IDE04300-ENG185804-Vehicle menu operation-menu_vas_after_disclaimer,not activated ,256
IDE04300-ENG185805-Vehicle menu operation-menu_vas_clamp_15_off,not activated ,256
IDE04300-ENG185806-Vehicle menu operation-menu_vas_over_threshold_high,not activated ,256
IDE04300-ENG185807-Vehicle menu operation-menu_vas_stillstand,not activated ,256
IDE04300-ENG152500-Vehicle menu operation-menu_wireless_charging,not activated ,256
IDE04300-ENG152504-Vehicle menu operation-menu_wireless_charging_after_disclaimer,not activated ,256
IDE04300-ENG152501-Vehicle menu operation-menu_wireless_charging_clamp_15_off,not activated ,256
IDE04300-ENG152502-Vehicle menu operation-menu_wireless_charging_over_threshold_high,not activated ,256
IDE04300-ENG152503-Vehicle menu operation-menu_wireless_charging_standstill,not activated ,256
IDE04307-ENG117700-Vehicle function list BAP-ACC_0x05,not activated ,256
IDE04307-ENG117701-Vehicle function list BAP-ACC_0x05_msg_bus,Extended data bus ,256
IDE04307-ENG117702-Vehicle function list BAP-air_suspension_0x06,not activated ,256
IDE04307-ENG117703-Vehicle function list BAP-air_suspension_0x06_msg_bus,not activated ,256
IDE04307-ENG117764-Vehicle function list BAP-Amplifier_0x2D,not activated ,256
IDE04307-ENG117765-Vehicle function list BAP-Amplifier_0x2D_msg_bus,not activated ,256
IDE04307-ENG122334-Vehicle function list BAP-Angle_Of_Slope_0x24,not activated ,256
IDE04307-ENG122335-Vehicle function list BAP-Angle_Of_Slope_0x24_msg_bus,not activated ,256
IDE04307-ENG117696-Vehicle function list BAP-auxilary_heating_0x03,not activated ,256
IDE04307-ENG117697-Vehicle function list BAP-auxilary_heating_0x03_msg_bus,not activated ,256
IDE04307-ENG117744-Vehicle function list BAP-AWV_0x1B,activated ,256
IDE04307-ENG117745-Vehicle function list BAP-AWV_0x1B_msg_bus,Extended data bus ,256
IDE04307-ENG122336-Vehicle function list BAP-Battery_Management_0x25,not activated ,256
IDE04307-ENG122337-Vehicle function list BAP-Battery_Management_0x25_msg_bus,Powertrain data bus ,256
IDE04307-ENG117758-Vehicle function list BAP-BCmE_0x23,activated ,256
IDE04307-ENG117759-Vehicle function list BAP-BCmE_0x23_msg_bus,Comfort data bus ,256
IDE04307-ENG117760-Vehicle function list BAP-Brake_0x26,activated ,256
IDE04307-ENG117761-Vehicle function list BAP-Brake_0x26_msg_bus,Powertrain data bus ,256
IDE04307-ENG297672-Vehicle function list BAP-BSMOIS_0x76,not activated ,256
IDE04307-ENG297673-Vehicle function list BAP-BSMOIS_0x76_msg_bus,not activated ,256
IDE04307-ENG297674-Vehicle function list BAP-BSMOIS2_0x7A,not activated ,256
IDE04307-ENG297675-Vehicle function list BAP-BSMOIS2_0x7A_msg_bus,not activated ,256
IDE04307-ENG297676-Vehicle function list BAP-BSMOIS3_0x7B,not activated ,256
IDE04307-ENG297677-Vehicle function list BAP-BSMOIS3_0x7B_msg_bus,not activated ,256
IDE04307-ENG248526-Vehicle function list BAP-Car2X_0x61,not activated ,256
IDE04307-ENG248527-Vehicle function list BAP-Car2X_0x61_msg_bus,not activated ,256
IDE04307-ENG117717-Vehicle function list BAP-central_locking_0x0D,activated ,256
IDE04307-ENG117716-Vehicle function list BAP-central_locking_0x0D_msg_bus,Comfort data bus ,256
IDE04307-ENG117736-Vehicle function list BAP-charisma_0x17,not activated ,256
IDE04307-ENG117737-Vehicle function list BAP-charisma_0x17_msg_bus,Comfort data bus ,256
IDE04307-ENG282048-Vehicle function list BAP-ChassisControl_0x57,not activated ,256
IDE04307-ENG282008-Vehicle function list BAP-ChassisControl_0x57_msg_bus,not activated ,256
IDE04307-ENG117734-Vehicle function list BAP-clima_slave_2_0x16,not activated ,256
IDE04307-ENG117735-Vehicle function list BAP-clima_slave_2_0x16_msg_bus,not activated ,256
IDE04307-ENG248490-Vehicle function list BAP-climate_master_0x42,not activated ,256
IDE04307-ENG248630-Vehicle function list BAP-climate_master_0x42_msg_bus,not activated ,256
IDE04307-ENG117692-Vehicle function list BAP-climatic_master_0x01,not activated ,256
IDE04307-ENG117693-Vehicle function list BAP-climatic_master_0x01_msg_bus,not activated ,256
IDE04307-ENG117694-Vehicle function list BAP-climatic_slave_0x02,not activated ,256
IDE04307-ENG117695-Vehicle function list BAP-climatic_slave_0x02_msg_bus,not activated ,256
IDE04307-ENG117724-Vehicle function list BAP-clock_0x11,activated ,256
IDE04307-ENG117725-Vehicle function list BAP-clock_0x11_msg_bus,Comfort data bus ,256
IDE04307-ENG117732-Vehicle function list BAP-compass_0x15,activated ,256
IDE04307-ENG117733-Vehicle function list BAP-compass_0x15_msg_bus,not activated ,256
IDE04307-ENG142158-Vehicle function list BAP-connection_manager_0x47,not activated ,256
IDE04307-ENG142159-Vehicle function list BAP-connection_manager_0x47_msg_bus,not activated ,256
IDE04307-ENG152529-Vehicle function list BAP-daf_profile_0x51,not activated ,256
IDE04307-ENG152530-Vehicle function list BAP-daf_profile_0x51_msg_bus,not activated ,256
IDE04307-ENG137043-Vehicle function list BAP-display_configuration_0x45,not activated ,256
IDE04307-ENG137044-Vehicle function list BAP-display_configuration_0x45_msg_bus,not activated ,256
IDE04307-ENG297681-Vehicle function list BAP-Doorlocking_2nd_0x79,not activated ,256
IDE04307-ENG297682-Vehicle function list BAP-Doorlocking_2nd_0x79_msg_bus,not activated ,256
IDE04307-ENG117722-Vehicle function list BAP-driver_seat_0x10,not activated ,256
IDE04307-ENG117723-Vehicle function list BAP-driver_seat_0x10_msg_bus,Comfort data bus ,256
IDE04307-ENG302721-Vehicle function list BAP-DrivingDynamics_0x7E,not activated ,256
IDE04307-ENG302722-Vehicle function list BAP-DrivingDynamics_0x7E_msg_bus,not activated ,256
IDE04307-ENG125039-Vehicle function list BAP-Ecall_0x33,activated ,256
IDE04307-ENG125828-Vehicle function list BAP-eCall_0x33_msg_bus,Comfort data bus ,256
IDE04307-ENG127500-Vehicle function list BAP-efficiency_assis_msg_bus_0x3C,not activated ,256
IDE04307-ENG127499-Vehicle function list BAP-efficiency_assist_0x3C,not activated ,256
IDE04307-ENG248657-Vehicle function list BAP-EngineFunctions_0x5D,not activated ,256
IDE04307-ENG248658-Vehicle function list BAP-EngineFunctions_0x5D_msg_bus,not activated ,256
IDE04307-ENG125829-Vehicle function list BAP-ENI_0x37,activated ,256
IDE04307-ENG125830-Vehicle function list BAP-ENI_0x37_msg_bus,Comfort data bus ,256
IDE04307-ENG264168-Vehicle function list BAP-ENI2_0x58,not activated ,256
IDE04307-ENG264169-Vehicle function list BAP-ENI2_0x58_msg_bus,not activated ,256
IDE04307-ENG264170-Vehicle function list BAP-ENI3_0x6E,not activated ,256
IDE04307-ENG264171-Vehicle function list BAP-ENI3_0x6E_msg_bus,not activated ,256
IDE04307-ENG264172-Vehicle function list BAP-ENI4_0x6F,not activated ,256
IDE04307-ENG264173-Vehicle function list BAP-ENI4_0x6F_msg_bus,not activated ,256
IDE04307-ENG117708-Vehicle function list BAP-exterieur_light_0x09,activated ,256
IDE04307-ENG117709-Vehicle function list BAP-exterieur_light_0x09_msg_bus,Comfort data bus ,256
IDE04307-ENG252073-Vehicle function list BAP-exterieur_light_2_0x6B,not activated ,256
IDE04307-ENG252076-Vehicle function list BAP-exterieur_light_2_0x6B_msg_bus,not activated ,256
IDE04307-ENG142168-Vehicle function list BAP-fas_profile_0x4D,not activated ,256
IDE04307-ENG142169-Vehicle function list BAP-fas_profile_0x4D_msg_bus,not activated ,256
IDE04307-ENG142154-Vehicle function list BAP-front_traffic_assist_0x41,not activated ,256
IDE04307-ENG142155-Vehicle function list BAP-front_traffic_assist_0x41_msg_bus,not activated ,256
IDE04307-ENG117698-Vehicle function list BAP-headup_displ_0x04,not activated ,256
IDE04307-ENG117699-Vehicle function list BAP-headup_displ_0x04_msg_bus,not activated ,256
IDE04307-ENG117746-Vehicle function list BAP-Hybrid_0x1D,not activated ,256
IDE04307-ENG117747-Vehicle function list BAP-Hybrid_0x1D_msg_bus,Powertrain data bus ,256
IDE04307-ENG248711-Vehicle function list BAP-IAA_PSO_0x52,activated ,256
IDE04307-ENG248712-Vehicle function list BAP-IAA_PSO_0x52_msg_bus,Comfort data bus ,256
IDE04307-ENG152535-Vehicle function list BAP-infotainmentsettings_profile_0x50,not activated ,256
IDE04307-ENG152536-Vehicle function list BAP-infotainmentsettings_profile_0x50_msg_bus,not activated ,256
IDE04307-ENG117706-Vehicle function list BAP-interieur_light_0x08,activated ,256
IDE04307-ENG117707-Vehicle function list BAP-interieur_light_0x08_msg_bus,Comfort data bus ,256
IDE04307-ENG252052-Vehicle function list BAP-interieur_light_2_0x6A,not activated ,256
IDE04307-ENG252047-Vehicle function list BAP-interieur_light_2_0x6A_msg_bus,not activated ,256
IDE04307-ENG248719-Vehicle function list BAP-ITM_0x65,not activated ,256
IDE04307-ENG248720-Vehicle function list BAP-ITM_0x65_msg_bus,not activated ,256
IDE04307-ENG117740-Vehicle function list BAP-LDW_HCA_0x19,activated ,256
IDE04307-ENG117741-Vehicle function list BAP-LDW_HCA_0x19_msg_bus,Extended data bus ,256
IDE04307-ENG249902-Vehicle function list BAP-lift_0x64,not activated ,256
IDE04307-ENG249903-Vehicle function list BAP-lift_0x64_msg_bus,not activated ,256
IDE04307-ENG281905-Vehicle function list BAP-LLCC_0x78,not activated ,256
IDE04307-ENG281994-Vehicle function list BAP-LLCC_0x78_msg_bus,not activated ,256
IDE04307-ENG248726-Vehicle function list BAP-Mascot_0x53,not activated ,256
IDE04307-ENG248727-Vehicle function list BAP-Mascot_0x53_msg_bus,not activated ,256
IDE04307-ENG117720-Vehicle function list BAP-MFA_0x0F,activated ,256
IDE04307-ENG117721-Vehicle function list BAP-MFA_0x0F_msg_bus,Comfort data bus ,256
IDE04307-ENG117767-Vehicle function list BAP-MFL_Jocker_0x34,not activated ,256
IDE04307-ENG117766-Vehicle function list BAP-MFL_Jocker_msg_bus_0x34,not activated ,256
IDE04307-ENG117719-Vehicle function list BAP-mirror_0x0E,activated ,256
IDE04307-ENG117718-Vehicle function list BAP-mirror_0x0E_msg_bus,Comfort data bus ,256
IDE04307-ENG117738-Vehicle function list BAP-Night_Vision_0x18,not activated ,256
IDE04307-ENG117739-Vehicle function list BAP-Night_Vision_0x18_msg_bus,not activated ,256
IDE04307-ENG248788-Vehicle function list BAP-PaCo_0x55,not activated ,256
IDE04307-ENG248789-Vehicle function list BAP-PaCo_0x55_msg_bus,not activated ,256
IDE04307-ENG117710-Vehicle function list BAP-parking_assist_0x0A,activated ,256
IDE04307-ENG117711-Vehicle function list BAP-parking_assist_0x0A_msg_bus,Terminal 15 ,256
IDE04307-ENG117752-Vehicle function list BAP-Passenger_Seat_0x20,not activated ,256
IDE04307-ENG117753-Vehicle function list BAP-Passenger_Seat_0x20_msg_bus,not activated ,256
IDE04307-ENG125831-Vehicle function list BAP-Pedestrian_Assist_0x3A,not activated ,256
IDE04307-ENG125832-Vehicle function list BAP-Pedestrian_Assist_msg_bus_0x3A,not activated ,256
IDE04307-ENG122333-Vehicle function list BAP-Range_Data_0x39,not activated ,256
IDE04307-ENG125827-Vehicle function list BAP-Range_Data_msg_bus_0x39,Comfort data bus ,256
IDE04307-ENG122327-Vehicle function list BAP-RearSeatEntertainment_0x2E,not activated ,256
IDE04307-ENG122328-Vehicle function list BAP-RearSeatEntertainment_0x2E_msg_bus,not activated ,256
IDE04307-ENG248801-Vehicle function list BAP-remote_services_0x4E,not activated ,256
IDE04307-ENG248802-Vehicle function list BAP-remote_services_0x4E_msg_bus,not activated ,256
IDE04307-ENG117750-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F,not activated ,256
IDE04307-ENG117751-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Powertrain data bus ,256
IDE04307-ENG297722-Vehicle function list BAP-RushhourPilot_0x7C,not activated ,256
IDE04307-ENG297723-Vehicle function list BAP-RushhourPilot_0x7C_msg_bus,not activated ,256
IDE04307-ENG125833-Vehicle function list BAP-Seat_Pneumatic_0x3B,not activated ,256
IDE04307-ENG125834-Vehicle function list BAP-Seat_Pneumatic_msg_bus_0x3B,not activated ,256
IDE04307-ENG139200-Vehicle function list BAP-Seatmemory_codriver_rear_0x3F,not activated ,256
IDE04307-ENG139201-Vehicle function list BAP-Seatmemory_codriver_rear_msg_bus_0x3F,not activated ,256
IDE04307-ENG139198-Vehicle function list BAP-Seatmemory_driver_rear_0x3E,not activated ,256
IDE04307-ENG139199-Vehicle function list BAP-Seatmemory_driver_rear_msg_bus_0x3E,not activated ,256
IDE04307-ENG117726-Vehicle function list BAP-service_interval_display_0x12,activated ,256
IDE04307-ENG117727-Vehicle function list BAP-service_interval_display_0x12_msg_bus,Comfort data bus ,256
IDE04307-ENG117748-Vehicle function list BAP-SideView_0x1E,not activated ,256
IDE04307-ENG117749-Vehicle function list BAP-SideView_0x1E_msg_bus,not activated ,256
IDE04307-ENG139202-Vehicle function list BAP-Soundcontrol_0x44,not activated ,256
IDE04307-ENG139203-Vehicle function list BAP-Soundcontrol_0x44_msg_bus,not activated ,256
IDE04307-ENG248819-Vehicle function list BAP-SoundControl2_0x66,not activated ,256
IDE04307-ENG248820-Vehicle function list BAP-SoundControl2_0x66_msg_bus,not activated ,256
IDE04307-ENG122329-Vehicle function list BAP-Special_Functions_0x35,not activated ,256
IDE04307-ENG122330-Vehicle function list BAP-Special_Functions_msg_bus_0x35,not activated ,256
IDE04307-ENG127678-Vehicle function list BAP-spoiler_0x40,not activated ,256
IDE04307-ENG127679-Vehicle function list BAP-spoiler_0x40_msg_bus,not activated ,256
IDE04307-ENG117762-Vehicle function list BAP-Start_Stop_reasons_0x27,not activated ,256
IDE04307-ENG117763-Vehicle function list BAP-Start_Stop_reasons_0x27_msg_bus,not activated ,256
IDE04307-ENG142162-Vehicle function list BAP-statistic_0x4A,not activated ,256
IDE04307-ENG142163-Vehicle function list BAP-statistic_0x4A_msg_bus,not activated ,256
IDE04307-ENG142164-Vehicle function list BAP-sunroof_front_0x4B,not activated ,256
IDE04307-ENG142165-Vehicle function list BAP-sunroof_front_0x4B_msg_bus,not activated ,256
IDE04307-ENG142166-Vehicle function list BAP-sunroof_rear_0x4C,not activated ,256
IDE04307-ENG142167-Vehicle function list BAP-sunroof_rear_0x4C_msg_bus,not activated ,256
IDE04307-ENG117742-Vehicle function list BAP-SWA_0x1A,not activated ,256
IDE04307-ENG117743-Vehicle function list BAP-SWA_0x1A_msg_bus,Extended data bus ,256
IDE04307-ENG117704-Vehicle function list BAP-tire_pressure_system_0x07,activated ,256
IDE04307-ENG117705-Vehicle function list BAP-tire_pressure_system_0x07_msg_bus,Powertrain data bus ,256
IDE04307-ENG117754-Vehicle function list BAP-traffic_sign_recognition_0x21,not activated ,256
IDE04307-ENG117755-Vehicle function list BAP-traffic_sign_recognition_0x21_msg_bus,Extended data bus ,256
IDE04307-ENG122331-Vehicle function list BAP-Trailer_Assistant_0x36,not activated ,256
IDE04307-ENG122332-Vehicle function list BAP-Trailer_Assistant_msg_bus_0x36,not activated ,256
IDE04307-ENG260744-Vehicle function list BAP-Trained_Park_Assist_0x5F,not activated ,256
IDE04307-ENG258630-Vehicle function list BAP-Trained_Park_Assist_0x5F_msg_bus,not activated ,256
IDE04307-ENG122325-Vehicle function list BAP-TV_tuner_0x2C,not activated ,256
IDE04307-ENG122326-Vehicle function list BAP-TV_tuner_0x2C_msg_bus,not activated ,256
IDE04307-ENG117730-Vehicle function list BAP-UGDO_0x14,not activated ,256
IDE04307-ENG117731-Vehicle function list BAP-UGDO_0x14_msg_bus,not activated ,256
IDE04307-ENG117728-Vehicle function list BAP-unit_master_0x13,activated ,256
IDE04307-ENG117729-Vehicle function list BAP-unit_master_0x13_msg_bus,Comfort data bus ,256
IDE04307-ENG185817-Vehicle function list BAP-vas_0x54,not activated ,256
IDE04307-ENG185818-Vehicle function list BAP-vas_0x54_msg_bus,not activated ,256
IDE04307-ENG117712-Vehicle function list BAP-VPS_0x0B,not activated ,256
IDE04307-ENG117713-Vehicle function list BAP-VPS_0x0B_msg_bus,not activated ,256
IDE04307-ENG117756-Vehicle function list BAP-weariness_rcognition_0x22,not activated ,256
IDE04307-ENG117757-Vehicle function list BAP-weariness_rcognition_0x22_msg_bus,Comfort data bus ,256
IDE04307-ENG117714-Vehicle function list BAP-wiper_comfort_0x0C,activated ,256
IDE04307-ENG117715-Vehicle function list BAP-wiper_comfort_0x0C_msg_bus,Comfort data bus ,256
IDE04307-ENG142160-Vehicle function list BAP-wireless_charging_0x48,not activated ,256
IDE04307-ENG142161-Vehicle function list BAP-wireless_charging_0x48_msg_bus,not activated ,256
IDE04550-Bluetooth: Sniff mode,On ,1
IDE06698-MAS00839-Audio management input gain-TV Tuner,-128 dB,34
IDE06698-MAS00846-Audio management input gain-Satellite radio,-128 dB,34
IDE06698-MAS01984-Audio management input gain-Radio (FM),-128 dB,34
IDE06698-MAS01985-Audio management input gain-Radio (AM),-128 dB,34
IDE06698-MAS01986-Audio management input gain-Digital radio (DAB),-128 dB,34
IDE06698-ENG125854-Audio management input gain-Exbox_DMB,-128 dB,34
IDE06698-ENG117430-Audio management input gain-HFP,-128 dB,34
IDE06698-ENG125846-Audio management input gain-Media_Airplay,-128 dB,34
IDE06698-ENG125837-Audio management input gain-Media_AUX_Adapter,-128 dB,34
IDE06698-ENG125836-Audio management input gain-Media_AUXIN,-128 dB,34
IDE06698-ENG125843-Audio management input gain-Media_Bluray,-128 dB,34
IDE06698-ENG125841-Audio management input gain-Media_BTDevice,-128 dB,34
IDE06698-ENG125838-Audio management input gain-Media_CDA,-128 dB,34
IDE06698-ENG125848-Audio management input gain-Media_Cloud,-128 dB,34
IDE06698-ENG125839-Audio management input gain-Media_DVD,-128 dB,34
IDE06698-ENG125844-Audio management input gain-Media_HDMI,-128 dB,34
IDE06698-ENG125840-Audio management input gain-Media_MFP,-128 dB,34
IDE06698-ENG125847-Audio management input gain-Media_UPNP,-128 dB,34
IDE06698-ENG125855-Audio management input gain-Mirrorlink,-128 dB,34
IDE06698-ENG125859-Audio management input gain-Phone_Ringer_MFP,-128 dB,34
IDE06698-ENG125860-Audio management input gain-Phone_Ringer_OB,-128 dB,34
IDE06698-ENG125858-Audio management input gain-Phone_Voice,-128 dB,34
IDE06698-ENG125842-Audio management input gain-TA_Tuner_FM,-128 dB,34
IDE06698-ENG125850-Audio management input gain-Tone_Beep,-128 dB,34
IDE06698-ENG125853-Audio management input gain-Tone_Messaging,-128 dB,34
IDE06698-ENG125852-Audio management input gain-Tone_Touchscreen,-128 dB,34
IDE06698-ENG125851-Audio management input gain-Tone_Warning,-128 dB,34
IDE06698-ENG251556-Audio management input gain-touch_screen_player,0 dB,34
IDE06698-ENG125856-Audio management input gain-TTS_Nav,-128 dB,34
IDE06698-ENG125857-Audio management input gain-TTS_SDS,-128 dB,34
IDE06698-ENG125845-Audio management input gain-Tuner_Online,-128 dB,34
IDE06698-ENG125849-Audio management input gain-Tuner_Personal,-128 dB,34
IDE06698-ENG125835-Audio management input gain-Tuner_TI,-128 dB,34
IDE06698-ENG125861-Audio management input gain-TV_AV_IN,-128 dB,34
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,not activated ,2
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,not activated ,2
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,not activated ,2
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,not activated ,2
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,not activated ,2
IDE08814-MAS14301-Navigation receiver GNSS configuration-external GPS receiver via bus,activated ,2
IDE08814-MAS15014-Navigation receiver GNSS configuration-Beidou,not activated ,2
IDE08814-MAS18801-Navigation receiver GNSS configuration-external GPS receiver 2 via bus,not activated ,2
IDE08814-MAS18802-Navigation receiver GNSS configuration-Gnss update rate,10 ,2
IDE08814-ENG259336-Navigation receiver GNSS configuration-GNSS_over_ethernet,not activated ,2
IDE10604-Menu entries for mobile online services,activated ,1
IDE11104-MAS18803-FM tuner: mono/stereo setting-lower HF stereo threshold in dBµV,23 ,3
IDE11104-MAS18804-FM tuner: mono/stereo setting-Maximum NF stereo channel separation in dB,35 ,3
IDE11104-MAS18805-FM tuner: mono/stereo setting-lower HF stereo threshold in seconds,15.00 s,3
IDE11122-Country identification: country of sale HMI,HR ,2
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,23
IDE11502-ENG127602-Locked menu contents-FB_CAR_1,non_blocked ,23
IDE11502-ENG127611-Locked menu contents-FB_CAR_10,non_blocked ,23
IDE11502-ENG127612-Locked menu contents-FB_CAR_11,non_blocked ,23
IDE11502-ENG127613-Locked menu contents-FB_CAR_12,non_blocked ,23
IDE11502-ENG127614-Locked menu contents-FB_CAR_13,non_blocked ,23
IDE11502-ENG127615-Locked menu contents-FB_CAR_14,non_blocked ,23
IDE11502-ENG127616-Locked menu contents-FB_CAR_15,non_blocked ,23
IDE11502-ENG127617-Locked menu contents-FB_CAR_16,non_blocked ,23
IDE11502-ENG127618-Locked menu contents-FB_CAR_17,non_blocked ,23
IDE11502-ENG127619-Locked menu contents-FB_CAR_18,non_blocked ,23
IDE11502-ENG127620-Locked menu contents-FB_CAR_19,non_blocked ,23
IDE11502-ENG127603-Locked menu contents-FB_CAR_2,non_blocked ,23
IDE11502-ENG127621-Locked menu contents-FB_CAR_20,non_blocked ,23
IDE11502-ENG127622-Locked menu contents-FB_CAR_21,non_blocked ,23
IDE11502-ENG127623-Locked menu contents-FB_CAR_22,non_blocked ,23
IDE11502-ENG127624-Locked menu contents-FB_CAR_23,non_blocked ,23
IDE11502-ENG127604-Locked menu contents-FB_CAR_3,non_blocked ,23
IDE11502-ENG127605-Locked menu contents-FB_CAR_4,non_blocked ,23
IDE11502-ENG127606-Locked menu contents-FB_CAR_5,non_blocked ,23
IDE11502-ENG127607-Locked menu contents-FB_CAR_6,non_blocked ,23
IDE11502-ENG127608-Locked menu contents-FB_CAR_7,non_blocked ,23
IDE11502-ENG127609-Locked menu contents-FB_CAR_8,non_blocked ,23
IDE11502-ENG127610-Locked menu contents-FB_CAR_9,non_blocked ,23
IDE11502-ENG248673-Locked menu contents-FB_HELP_0,non_blocked ,23
IDE11502-ENG248674-Locked menu contents-FB_HELP_1,non_blocked ,23
IDE11502-ENG248675-Locked menu contents-FB_HELP_2,non_blocked ,23
IDE11502-ENG248676-Locked menu contents-FB_HELP_3,non_blocked ,23
IDE11502-ENG248677-Locked menu contents-FB_HELP_4,non_blocked ,23
IDE11502-ENG248678-Locked menu contents-FB_HELP_5,non_blocked ,23
IDE11502-ENG248679-Locked menu contents-FB_HELP_6,non_blocked ,23
IDE11502-ENG248680-Locked menu contents-FB_HELP_7,non_blocked ,23
IDE11502-ENG248681-Locked menu contents-FB_HELP_8,non_blocked ,23
IDE11502-ENG248682-Locked menu contents-FB_HELP_9,non_blocked ,23
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,non_blocked ,23
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,23
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked ,23
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked ,23
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked ,23
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked ,23
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14,non_blocked ,23
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,non_blocked ,23
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16,non_blocked ,23
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17,non_blocked ,23
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18,non_blocked ,23
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19,blocked ,23
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2,non_blocked ,23
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20,non_blocked ,23
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21,non_blocked ,23
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22,non_blocked ,23
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23,non_blocked ,23
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,non_blocked ,23
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,non_blocked ,23
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked ,23
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6,non_blocked ,23
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7,non_blocked ,23
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,non_blocked ,23
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked ,23
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,23
IDE11502-ENG127626-Locked menu contents-FB_MISC_1,non_blocked ,23
IDE11502-ENG127635-Locked menu contents-FB_MISC_10,non_blocked ,23
IDE11502-ENG127636-Locked menu contents-FB_MISC_11,non_blocked ,23
IDE11502-ENG127637-Locked menu contents-FB_MISC_12,non_blocked ,23
IDE11502-ENG127638-Locked menu contents-FB_MISC_13,non_blocked ,23
IDE11502-ENG127639-Locked menu contents-FB_MISC_14,blocked ,23
IDE11502-ENG127640-Locked menu contents-FB_MISC_15,non_blocked ,23
IDE11502-ENG127641-Locked menu contents-FB_MISC_16,non_blocked ,23
IDE11502-ENG127642-Locked menu contents-FB_MISC_17,non_blocked ,23
IDE11502-ENG127643-Locked menu contents-FB_MISC_18,non_blocked ,23
IDE11502-ENG127644-Locked menu contents-FB_MISC_19,non_blocked ,23
IDE11502-ENG127627-Locked menu contents-FB_MISC_2,non_blocked ,23
IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked ,23
IDE11502-ENG127646-Locked menu contents-FB_MISC_21,non_blocked ,23
IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked ,23
IDE11502-ENG127648-Locked menu contents-FB_MISC_23,non_blocked ,23
IDE11502-ENG127649-Locked menu contents-FB_MISC_24,non_blocked ,23
IDE11502-ENG127650-Locked menu contents-FB_MISC_25,blocked ,23
IDE11502-ENG127651-Locked menu contents-FB_MISC_26,non_blocked ,23
IDE11502-ENG127652-Locked menu contents-FB_MISC_27,non_blocked ,23
IDE11502-ENG127653-Locked menu contents-FB_MISC_28,non_blocked ,23
IDE11502-ENG127654-Locked menu contents-FB_MISC_29,non_blocked ,23
IDE11502-ENG127628-Locked menu contents-FB_MISC_3,non_blocked ,23
IDE11502-ENG127655-Locked menu contents-FB_MISC_30,non_blocked ,23
IDE11502-ENG127656-Locked menu contents-FB_MISC_31,blocked ,23
IDE11502-ENG127657-Locked menu contents-FB_MISC_32,non_blocked ,23
IDE11502-ENG127658-Locked menu contents-FB_MISC_33,non_blocked ,23
IDE11502-ENG127659-Locked menu contents-FB_MISC_34,non_blocked ,23
IDE11502-ENG127660-Locked menu contents-FB_MISC_35,non_blocked ,23
IDE11502-ENG127661-Locked menu contents-FB_MISC_36,non_blocked ,23
IDE11502-ENG127662-Locked menu contents-FB_MISC_37,non_blocked ,23
IDE11502-ENG127663-Locked menu contents-FB_MISC_38,non_blocked ,23
IDE11502-ENG127664-Locked menu contents-FB_MISC_39,non_blocked ,23
IDE11502-ENG127629-Locked menu contents-FB_MISC_4,non_blocked ,23
IDE11502-ENG127665-Locked menu contents-FB_MISC_40,non_blocked ,23
IDE11502-ENG127666-Locked menu contents-FB_MISC_41,blocked ,23
IDE11502-ENG127667-Locked menu contents-FB_MISC_42,non_blocked ,23
IDE11502-ENG127668-Locked menu contents-FB_MISC_43,non_blocked ,23
IDE11502-ENG127669-Locked menu contents-FB_MISC_44,non_blocked ,23
IDE11502-ENG127670-Locked menu contents-FB_MISC_45,non_blocked ,23
IDE11502-ENG127671-Locked menu contents-FB_MISC_46,non_blocked ,23
IDE11502-ENG127672-Locked menu contents-FB_MISC_47,non_blocked ,23
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,23
IDE11502-ENG127631-Locked menu contents-FB_MISC_6,non_blocked ,23
IDE11502-ENG127632-Locked menu contents-FB_MISC_7,non_blocked ,23
IDE11502-ENG127633-Locked menu contents-FB_MISC_8,non_blocked ,23
IDE11502-ENG127634-Locked menu contents-FB_MISC_9,non_blocked ,23
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,23
IDE11502-ENG127562-Locked menu contents-FB_NAV_1,non_blocked ,23
IDE11502-ENG127571-Locked menu contents-FB_NAV_10,non_blocked ,23
IDE11502-ENG127572-Locked menu contents-FB_NAV_11,non_blocked ,23
IDE11502-ENG127573-Locked menu contents-FB_NAV_12,non_blocked ,23
IDE11502-ENG127574-Locked menu contents-FB_NAV_13,non_blocked ,23
IDE11502-ENG127575-Locked menu contents-FB_NAV_14,non_blocked ,23
IDE11502-ENG127576-Locked menu contents-FB_NAV_15,non_blocked ,23
IDE11502-ENG127577-Locked menu contents-FB_NAV_16,non_blocked ,23
IDE11502-ENG127578-Locked menu contents-FB_NAV_17,non_blocked ,23
IDE11502-ENG127579-Locked menu contents-FB_NAV_18,non_blocked ,23
IDE11502-ENG127580-Locked menu contents-FB_NAV_19,non_blocked ,23
IDE11502-ENG127563-Locked menu contents-FB_NAV_2,non_blocked ,23
IDE11502-ENG127581-Locked menu contents-FB_NAV_20,non_blocked ,23
IDE11502-ENG127582-Locked menu contents-FB_NAV_21,non_blocked ,23
IDE11502-ENG127583-Locked menu contents-FB_NAV_22,non_blocked ,23
IDE11502-ENG127584-Locked menu contents-FB_NAV_23,non_blocked ,23
IDE11502-ENG127585-Locked menu contents-FB_NAV_24,non_blocked ,23
IDE11502-ENG127586-Locked menu contents-FB_NAV_25,non_blocked ,23
IDE11502-ENG127587-Locked menu contents-FB_NAV_26,non_blocked ,23
IDE11502-ENG127588-Locked menu contents-FB_NAV_27,non_blocked ,23
IDE11502-ENG127589-Locked menu contents-FB_NAV_28,non_blocked ,23
IDE11502-ENG127590-Locked menu contents-FB_NAV_29,non_blocked ,23
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,23
IDE11502-ENG127591-Locked menu contents-FB_NAV_30,non_blocked ,23
IDE11502-ENG127592-Locked menu contents-FB_NAV_31,non_blocked ,23
IDE11502-ENG127593-Locked menu contents-FB_NAV_32,non_blocked ,23
IDE11502-ENG127594-Locked menu contents-FB_NAV_33,non_blocked ,23
IDE11502-ENG127595-Locked menu contents-FB_NAV_34,non_blocked ,23
IDE11502-ENG127596-Locked menu contents-FB_NAV_35,non_blocked ,23
IDE11502-ENG127597-Locked menu contents-FB_NAV_36,non_blocked ,23
IDE11502-ENG127598-Locked menu contents-FB_NAV_37,non_blocked ,23
IDE11502-ENG127599-Locked menu contents-FB_NAV_38,non_blocked ,23
IDE11502-ENG127600-Locked menu contents-FB_NAV_39,non_blocked ,23
IDE11502-ENG127565-Locked menu contents-FB_NAV_4,non_blocked ,23
IDE11502-ENG127566-Locked menu contents-FB_NAV_5,non_blocked ,23
IDE11502-ENG127567-Locked menu contents-FB_NAV_6,non_blocked ,23
IDE11502-ENG127568-Locked menu contents-FB_NAV_7,non_blocked ,23
IDE11502-ENG127569-Locked menu contents-FB_NAV_8,non_blocked ,23
IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked ,23
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,23
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1,non_blocked ,23
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10,non_blocked ,23
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11,non_blocked ,23
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12,non_blocked ,23
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13,non_blocked ,23
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14,non_blocked ,23
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15,non_blocked ,23
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2,non_blocked ,23
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3,non_blocked ,23
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,non_blocked ,23
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,non_blocked ,23
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,non_blocked ,23
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,non_blocked ,23
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8,non_blocked ,23
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9,non_blocked ,23
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0,non_blocked ,23
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1,non_blocked ,23
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10,non_blocked ,23
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11,non_blocked ,23
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12,non_blocked ,23
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13,non_blocked ,23
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14,non_blocked ,23
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15,non_blocked ,23
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2,non_blocked ,23
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,non_blocked ,23
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked ,23
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked ,23
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,non_blocked ,23
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,non_blocked ,23
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8,non_blocked ,23
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9,non_blocked ,23
IDE11638-Bluetooth Audio Codec,01 ,1
IDE12364-ENG122340-Head-Up-Display: configuration-crossroad_detail_map_compression_mode,RLE ,3
IDE12364-ENG122344-Head-Up-Display: configuration-crossroad_detail_map_resolution,0 ,3
IDE12364-ENG127006-Head-Up-Display: configuration-crossroad_detail_map_transmission_mode,OFF ,3
IDE14012-MAS18497-Ethernet: configuration-Ethernet activation: branch 1,Deactivated ,2
IDE14012-MAS18498-Ethernet: configuration-Ethernet activation: branch 2,Deactivated ,2
IDE14012-MAS18499-Ethernet: configuration-Ethernet activation: branch 3,Deactivated ,2
IDE14012-MAS18500-Ethernet: configuration-Ethernet activation: branch 4,Master ,2
MAS00951-Bluetooth,On ,1
MAS01968-Fan,normal ,1
MAS03782-WLAN,On ,1
ENG248412-5_ghz_wlan,OFF ,1
ENG248413-alphabetic_scrollbar,On ,1
ENG248422-ENG248496-calendar_reminder-acoustic_reminder,OFF ,1
ENG248422-ENG248696-calendar_reminder-haptic_reminder,OFF ,1
ENG252010-Car_net,we_connect ,1
ENG248423-channel_band_width_802_11ac,40MHz ,1
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps,No ,8
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,OFF ,8
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart,OFF ,8
ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution,0 ,8
ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode,OFF ,8
ENG122230-ENG142153-Dashboard_Display_Configuration-dynamic_icon,OFF ,8
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode,RLE ,8
ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution,0 ,8
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode,OFF ,8
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart,OFF ,8
ENG117915-ENG101574-Dimming_Functional_Illumination_for_Operating_Unit-X1,0 ,12
ENG117915-ENG99557-Dimming_Functional_Illumination_for_Operating_Unit-X2,10 ,12
ENG117915-ENG102140-Dimming_Functional_Illumination_for_Operating_Unit-X3,50 ,12
ENG117915-ENG102936-Dimming_Functional_Illumination_for_Operating_Unit-X4,100 ,12
ENG117915-ENG103548-Dimming_Functional_Illumination_for_Operating_Unit-X5,220 ,12
ENG117915-ENG113992-Dimming_Functional_Illumination_for_Operating_Unit-X6,253 ,12
ENG117915-ENG99777-Dimming_Functional_Illumination_for_Operating_Unit-Y1,2 %,12
ENG117915-ENG100480-Dimming_Functional_Illumination_for_Operating_Unit-Y2,2 %,12
ENG117915-ENG100773-Dimming_Functional_Illumination_for_Operating_Unit-Y3,6 %,12
ENG117915-ENG100631-Dimming_Functional_Illumination_for_Operating_Unit-Y4,10 %,12
ENG117915-ENG102174-Dimming_Functional_Illumination_for_Operating_Unit-Y5,80 %,12
ENG117915-ENG113993-Dimming_Functional_Illumination_for_Operating_Unit-Y6,100 %,12
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150 ,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,3 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,6 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,44 %,12
ENG122933-ENG248643-error_mask-dtc_dfcc_1,00 00 00 ,30
ENG122933-ENG248644-error_mask-dtc_dfcc_10,00 00 00 ,30
ENG122933-ENG248645-error_mask-dtc_dfcc_2,00 00 00 ,30
ENG122933-ENG248646-error_mask-dtc_dfcc_3,00 00 00 ,30
ENG122933-ENG248647-error_mask-dtc_dfcc_4,00 00 00 ,30
ENG122933-ENG248648-error_mask-dtc_dfcc_5,00 00 00 ,30
ENG122933-ENG248649-error_mask-dtc_dfcc_6,00 00 00 ,30
ENG122933-ENG248650-error_mask-dtc_dfcc_7,00 00 00 ,30
ENG122933-ENG248651-error_mask-dtc_dfcc_8,00 00 00 ,30
ENG122933-ENG248652-error_mask-dtc_dfcc_9,00 00 00 ,30
ENG248428-ENG248528-function_configuration_audio-channel_1_HT,not installed ,10
ENG248428-ENG248530-function_configuration_audio-channel_1_TT,installed ,10
ENG248428-ENG248532-function_configuration_audio-channel_10_HT,not installed ,10
ENG248428-ENG248534-function_configuration_audio-channel_10_TT,not installed ,10
ENG248428-ENG248536-function_configuration_audio-channel_11_HT,not installed ,10
ENG248428-ENG248538-function_configuration_audio-channel_11_TT,not installed ,10
ENG248428-ENG248540-function_configuration_audio-channel_12_HT,not installed ,10
ENG248428-ENG248542-function_configuration_audio-channel_12_TT,not installed ,10
ENG248428-ENG248544-function_configuration_audio-channel_13_HT,not installed ,10
ENG248428-ENG248546-function_configuration_audio-channel_13_TT,not installed ,10
ENG248428-ENG248548-function_configuration_audio-channel_14_HT,not installed ,10
ENG248428-ENG248550-function_configuration_audio-channel_14_TT,not installed ,10
ENG248428-ENG248552-function_configuration_audio-channel_15_HT,not installed ,10
ENG248428-ENG248554-function_configuration_audio-channel_15_TT,not installed ,10
ENG248428-ENG248556-function_configuration_audio-channel_16_HT,not installed ,10
ENG248428-ENG248558-function_configuration_audio-channel_16_TT,not installed ,10
ENG248428-ENG248560-function_configuration_audio-channel_17_HT,not installed ,10
ENG248428-ENG248562-function_configuration_audio-channel_17_TT,not installed ,10
ENG248428-ENG248564-function_configuration_audio-channel_18_HT,not installed ,10
ENG248428-ENG248566-function_configuration_audio-channel_18_TT,not installed ,10
ENG248428-ENG248568-function_configuration_audio-channel_19_HT,not installed ,10
ENG248428-ENG248571-function_configuration_audio-channel_19TT,not installed ,10
ENG248428-ENG248572-function_configuration_audio-channel_2_HT,installed ,10
ENG248428-ENG248574-function_configuration_audio-channel_2_TT,installed ,10
ENG248428-ENG248576-function_configuration_audio-channel_20_HT,not installed ,10
ENG248428-ENG248578-function_configuration_audio-channel_20_TT,not installed ,10
ENG248428-ENG248580-function_configuration_audio-channel_21_HT,not installed ,10
ENG248428-ENG248582-function_configuration_audio-channel_21_TT,not installed ,10
ENG248428-ENG248584-function_configuration_audio-channel_22_HT,not installed ,10
ENG248428-ENG248586-function_configuration_audio-channel_22_TT,not installed ,10
ENG248428-ENG248588-function_configuration_audio-channel_23_HT,not installed ,10
ENG248428-ENG248590-function_configuration_audio-channel_23_TT,not installed ,10
ENG248428-ENG248592-function_configuration_audio-channel_24_HT,not installed ,10
ENG248428-ENG248594-function_configuration_audio-channel_24_TT,not installed ,10
ENG248428-ENG248596-function_configuration_audio-channel_25_HT,not installed ,10
ENG248428-ENG248597-function_configuration_audio-channel_25_TT,not installed ,10
ENG248428-ENG248598-function_configuration_audio-channel_3_HT,installed ,10
ENG248428-ENG248600-function_configuration_audio-channel_3_TT,installed ,10
ENG248428-ENG248602-function_configuration_audio-channel_4_HT,not installed ,10
ENG248428-ENG248604-function_configuration_audio-channel_4_TT,installed ,10
ENG248428-ENG248606-function_configuration_audio-channel_5_HT,not installed ,10
ENG248428-ENG248608-function_configuration_audio-channel_5_TT,not installed ,10
ENG248428-ENG248610-function_configuration_audio-channel_6_HT,not installed ,10
ENG248428-ENG248612-function_configuration_audio-channel_6_TT,not installed ,10
ENG248428-ENG248614-function_configuration_audio-channel_7_HT,not installed ,10
ENG248428-ENG248616-function_configuration_audio-channel_7_TT,not installed ,10
ENG248428-ENG248618-function_configuration_audio-channel_8_HT,not installed ,10
ENG248428-ENG248620-function_configuration_audio-channel_8_TT,not installed ,10
ENG248428-ENG248622-function_configuration_audio-channel_9_HT,not installed ,10
ENG248428-ENG248624-function_configuration_audio-channel_9_TT,not installed ,10
ENG248428-ENG248653-function_configuration_audio-Early_engine_sound,OFF ,10
ENG248428-ENG248491-function_configuration_audio-microphone_1,installed ,10
ENG248428-ENG248492-function_configuration_audio-microphone_2,not installed ,10
ENG248428-ENG248763-function_configuration_audio-microphone_3,not installed ,10
ENG248428-ENG248764-function_configuration_audio-microphone_4,not installed ,10
ENG248428-ENG252056-function_configuration_audio-microphones_ANC,not installed ,10
ENG248428-ENG248818-function_configuration_audio-Signal_flow_topology,20 ,10
ENG248428-ENG248483-function_configuration_audio-Sound_system,internal ,10
ENG248428-ENG248830-function_configuration_audio-welcome_sound,OFF ,10
ENG248429-ENG248511-function_configuration_car-bap_online_functions,OFF ,2
ENG248429-ENG248512-function_configuration_car-bap_sds_sd,OFF ,2
ENG248429-ENG142151-function_configuration_car-conditioning_variant,0 ,2
ENG248429-ENG248635-function_configuration_car-dashboard_connection,BAP ,2
ENG248429-ENG302834-function_configuration_car-Rotary_Knobs_Function,not activated ,2
ENG248430-ENG248504-function_configuration_connectivity-app_connect_over_wifi,Yes ,6
ENG248430-ENG248506-function_configuration_connectivity-apple_car_play,On ,6
ENG248430-ENG152525-function_configuration_connectivity-Baidu_Car_Life,OFF ,6
ENG248430-ENG152559-function_configuration_connectivity-Baidu_Car_Life_ios,OFF ,6
ENG248430-ENG248518-function_configuration_connectivity-Bluetooth_Audio,Not available ,6
ENG248430-ENG248519-function_configuration_connectivity-Bluetooth_Availability,available_without_low_energy ,6
ENG248430-ENG248520-function_configuration_connectivity-Bluetooth_Headphones,Not available ,6
ENG248430-ENG248521-function_configuration_connectivity-Bluetooth_Multimedia_Functionality,Not available ,6
ENG248430-ENG248522-function_configuration_connectivity-Bluetooth_Phone,Not available ,6
ENG248430-ENG183597-function_configuration_connectivity-Bluetooth_visibility,On ,6
ENG248430-ENG248525-function_configuration_connectivity-calendar_via_ctn,OFF ,6
ENG248430-ENG248672-function_configuration_connectivity-external_wlan_antenna,none ,6
ENG248430-ENG248693-function_configuration_connectivity-google_android_auto,On ,6
ENG248430-ENG248761-function_configuration_connectivity-messaging_pagewise_scrolling,not installed ,6
ENG248430-ENG248762-function_configuration_connectivity-messaging_via_map,installed ,6
ENG248430-ENG138662-function_configuration_connectivity-Mirror_link,usb_only ,6
ENG248430-ENG248766-function_configuration_connectivity-mirror_link_country_code,EU ,6
ENG248430-ENG142150-function_configuration_connectivity-MirrorLink_RGB_Preference,RGB565 ,6
ENG248430-ENG127495-function_configuration_connectivity-online_media,OFF ,6
ENG248430-ENG101416-function_configuration_connectivity-Reserved_1,OFF ,6
ENG248430-ENG99458-function_configuration_connectivity-Reserved_2,not installed ,6
ENG248430-ENG248826-function_configuration_connectivity-viwi_access_mode,no_restriction ,6
ENG248430-ENG248827-function_configuration_connectivity-viwi_function,not installed ,6
ENG248430-ENG252048-function_configuration_connectivity-welink,OFF ,6
ENG248430-ENG248831-function_configuration_connectivity-wifi_client_mode_2_GHz,On ,6
ENG248430-ENG248832-function_configuration_connectivity-wifi_client_mode_5GHz,On ,6
ENG248430-ENG248833-function_configuration_connectivity-WIFI_Hotspot_2_4GHz,On ,6
ENG248430-ENG248834-function_configuration_connectivity-WIFI_Hotspot_5GHz,On ,6
ENG248430-ENG248835-function_configuration_connectivity-wlan_aps_to_ccu_routing,On ,6
ENG248430-ENG248836-function_configuration_connectivity-wlan_module,not activated ,6
ENG248430-ENG248837-function_configuration_connectivity-wlan_tethering_connection_check_via_disgnosis,On ,6
ENG248431-ENG248699-function_configuration_hmi-helpcontext_0,OFF ,5
ENG248431-ENG248700-function_configuration_hmi-helpcontext_1,OFF ,5
ENG248431-ENG248701-function_configuration_hmi-helpcontext_2,OFF ,5
ENG248431-ENG248702-function_configuration_hmi-helpcontext_3,OFF ,5
ENG248431-ENG248703-function_configuration_hmi-helpcontext_4,OFF ,5
ENG248431-ENG248704-function_configuration_hmi-helpcontext_5,OFF ,5
ENG248431-ENG248705-function_configuration_hmi-helpcontext_6,OFF ,5
ENG248431-ENG248706-function_configuration_hmi-helpcontext_7,OFF ,5
ENG248431-ENG248707-function_configuration_hmi-helpcontext_8,OFF ,5
ENG248431-ENG248708-function_configuration_hmi-helpcontext_9,OFF ,5
ENG248431-ENG248709-function_configuration_hmi-hmi_initial_disclaimer,OFF ,5
ENG248431-ENG248710-function_configuration_hmi-hmi_legal_disclaimer,OFF ,5
ENG248431-ENG248725-function_configuration_hmi-log_book,not_displayed ,5
ENG248431-ENG167525-function_configuration_hmi-Popup_if_GPS_services_in_use,OFF ,5
ENG248431-ENG248811-function_configuration_hmi-screenings,0 ,5
ENG248431-ENG248479-function_configuration_hmi-Skinning,1 ,5
ENG248431-ENG248821-function_configuration_hmi-speller,OFF ,5
ENG248432-ENG248505-function_configuration_media-app_start_automatically_on_customer_device,OFF ,3
ENG248432-ENG248481-function_configuration_media-aux_in,OFF ,3
ENG248432-ENG248671-function_configuration_media-external_cd_drive,OFF ,3
ENG248432-ENG249899-function_configuration_media-external_tv_tuner,OFF ,3
ENG248432-ENG117850-function_configuration_media-gracenote_local_coverarts,OFF ,3
ENG248432-ENG117851-function_configuration_media-gracenote_local_other,OFF ,3
ENG248432-ENG117848-function_configuration_media-gracenote_online_coverarts,OFF ,3
ENG248432-ENG117849-function_configuration_media-gracenote_online_other,OFF ,3
ENG248432-ENG248713-function_configuration_media-Import_Media_Data,not activated ,3
ENG248432-ENG248769-function_configuration_media-online_media_services,On ,3
ENG248432-ENG248770-function_configuration_media-online_tv,OFF ,3
ENG248432-ENG248794-function_configuration_media-picture_viewer,OFF ,3
ENG248432-ENG248804-function_configuration_media-Ripping_Media_Data,not activated ,3
ENG248432-ENG248482-function_configuration_media-USB,usb_ipod ,3
ENG248433-ENG117847-function_configuration_navigation-advanced_range_display,OFF ,4
ENG248433-ENG173863-function_configuration_navigation-Country_Navigation,EU ,4
ENG248433-ENG248692-function_configuration_navigation-gnns_antenna_Availability,not activated ,4
ENG248433-ENG127492-function_configuration_navigation-LGI,On ,4
ENG248433-ENG142152-function_configuration_navigation-Map_Style,0 ,4
ENG248433-ENG248488-function_configuration_navigation-Navigation_system,activated ,4
ENG248433-ENG103811-function_configuration_navigation-PSD,activated ,4
ENG248433-ENG126994-function_configuration_navigation-TPEG_availability,OFF ,4
ENG248433-ENG248824-function_configuration_navigation-ttraffic_information,On ,4
ENG248433-ENG248828-function_configuration_navigation-vza,activated ,4
ENG248433-ENG127494-function_configuration_navigation-VZO,OFF ,4
ENG248434-ENG142146-function_configuration_phone-allow_message_editing,On ,3
ENG248434-ENG281930-function_configuration_phone-BTLE_Messaging_support,OFF ,3
ENG248434-ENG125043-function_configuration_phone-Dtmf_without_active_call,OFF ,3
ENG248434-ENG142145-function_configuration_phone-esim_data_only_sms_support,OFF ,3
ENG248434-ENG248694-function_configuration_phone-GSM_Antenna_3,Deactivated ,3
ENG248434-ENG248695-function_configuration_phone-GSM_Antenna_4,Deactivated ,3
ENG248434-ENG248715-function_configuration_phone-interlink_box_antenna,not installed ,3
ENG248434-ENG248716-function_configuration_phone-interlink_box_nfc,not installed ,3
ENG248434-ENG248717-function_configuration_phone-interlink_box_pwm,not installed ,3
ENG248434-ENG248718-function_configuration_phone-interlink_box_wireless_charging,not installed ,3
ENG248434-ENG130246-function_configuration_phone-LTE_modul,Deactivated ,3
ENG248434-ENG142142-function_configuration_phone-map_email_support,On ,3
ENG248434-ENG142143-function_configuration_phone-map_instant_messaging_support,OFF ,3
ENG248434-ENG142141-function_configuration_phone-map_sms_support,On ,3
ENG248434-ENG248792-function_configuration_phone-phone_nad,not installed ,3
ENG248434-ENG125044-function_configuration_phone-Support_for_response_and_hold,OFF ,3
ENG248434-ENG125042-function_configuration_phone-Support_of_threeway_calling,On ,3
ENG248434-ENG130247-function_configuration_phone-Support_second_phone,none ,3
ENG248434-ENG248825-function_configuration_phone-user_menu_three_way_calling,not installed ,3
ENG248435-ENG251555-function_configuration_pso-iaa_function,activated ,2
ENG248435-ENG297696-function_configuration_pso-iaa_function_new,activated ,2
ENG248435-ENG248795-function_configuration_pso-pso_function,Deactivated ,2
ENG248436-ENG248497-function_configuration_radio-AF,persistent ,8
ENG248436-ENG248498-function_configuration_radio-af_hmi_switch_default_value,On ,8
ENG248436-ENG248500-function_configuration_radio-AM_disable,activated ,8
ENG248436-ENG248501-function_configuration_radio-am_fm_dab_antenna,not activated ,8
ENG248436-ENG248502-function_configuration_radio-am_hd_hmi_switch_default_value,not activated ,8
ENG248436-ENG248508-function_configuration_radio-band_settings_am_tuner,EU_RdW ,8
ENG248436-ENG248509-function_configuration_radio-band_settings_dab_tuner_band_1,EU_Band_III-N ,8
ENG248436-ENG248510-function_configuration_radio-band_settings_fm_tuner,EU_RdW ,8
ENG248436-ENG248633-function_configuration_radio-DAB_Alarm_Announcement,activated ,8
ENG248436-ENG248634-function_configuration_radio-dab_mode_antenna_mode_1,activated ,8
ENG248436-ENG248641-function_configuration_radio-drm_plus_fm,Deactivated ,8
ENG248436-ENG248642-function_configuration_radio-drm30_mf,Deactivated ,8
ENG248436-ENG248683-function_configuration_radio-FM_Antenna,available. ,8
ENG248436-ENG248684-function_configuration_radio-fm_hd_hmi_switch_default_value,not activated ,8
ENG248436-ENG248685-function_configuration_radio-FM_PTY31_Alarm,OFF ,8
ENG248436-ENG248686-function_configuration_radio-fm_radio_profiles,not_valid ,8
ENG248436-ENG248697-function_configuration_radio-HD_FM_Antenna_Mode,AM_FM_ANT ,8
ENG248436-ENG152533-function_configuration_radio-Hybrid_Radio_additional_online_data,Deactivated ,8
ENG248436-ENG152534-function_configuration_radio-Hybrid_Radio_Range_Extender,Deactivated ,8
ENG248436-ENG248767-function_configuration_radio-multiple_entry_switch,On ,8
ENG248436-ENG152553-function_configuration_radio-online_radio,native_hmi_only ,8
ENG248436-ENG248793-function_configuration_radio-PI_ignore,OFF ,8
ENG248436-ENG286264-function_configuration_radio-PTy switch default value,OFF ,8
ENG248436-ENG286265-function_configuration_radio-PTy_switch_visibility,OFF ,8
ENG248436-ENG248797-function_configuration_radio-Radio_Text_Plus,activated ,8
ENG248436-ENG248798-function_configuration_radio-rds_hmi_switch_default_value,On ,8
ENG248436-ENG248799-function_configuration_radio-rds_hmi_switch_visibility,OFF ,8
ENG248436-ENG248812-function_configuration_radio-SDARS_band_activation,Deactivated ,8
ENG248436-ENG249938-function_configuration_radio-SDARS_type,SAT_only ,8
ENG248436-ENG126993-function_configuration_radio-Station_Logo_DB_Mode,1 ,8
ENG248437-ENG248800-function_configuration_rvc-rear_view_low_rvc,not_active ,3
ENG248437-ENG245031-function_configuration_rvc-rvc_low_black_screen_trunk_open,not activated ,3
ENG248437-ENG244966-function_configuration_rvc-rvc_low_black_screen_velocity_threshold,not activated ,3
ENG248437-ENG245015-function_configuration_rvc-rvc_low_failsafe,not activated ,3
ENG248437-ENG248807-function_configuration_rvc-rvc_low_lid_close_delay_time,0 s,3
ENG248437-ENG248808-function_configuration_rvc-rvc_low_videofailure_detection_time,0 ,3
ENG248438-ENG248523-function_configuration_sound-brand_sound,No_Brand_Sound ,1
ENG248438-ENG248765-function_configuration_sound-Microphone_for_vehicle_noise_cancelation,not activated ,1
ENG248438-ENG248803-function_configuration_sound-retractable_tweeters,not activated ,1
ENG248438-ENG142149-function_configuration_sound-vehicle_leaving_sound,not activated ,1
ENG248438-ENG142147-function_configuration_sound-vehicle_readiness_sound,not activated ,1
ENG248439-ENG248632-function_configuration_speech-country_language_change,no_country ,2
ENG248439-ENG138660-function_configuration_speech-SDS_Region_Flag,no_region ,2
ENG244879-ENG137647-function_configuration_sw_update-UOTA,On ,1
ENG244879-ENG167532-function_configuration_sw_update-UOTA_2,OFF ,1
ENG244879-ENG249952-function_configuration_sw_update-UOTA_onboard_tester,Not available ,1
ENG244879-ENG297725-function_configuration_sw_update-UOTA_T_Box,Not available ,1
ENG248440-function_configuration_swap_fod,swap_not_active_fod_slave_master_active ,1
ENG248441-ENG248640-function_configuration_unit-Display_Turn_Out_Speed,normal ,1
ENG248441-ENG167523-function_configuration_unit-Pilot_Parking,Deactivated ,1
ENG248441-ENG249931-function_configuration_unit-reset_type_hardware_reset,IVI_partition_only ,1
ENG248441-ENG126143-function_configuration_unit-RVC_video_input,FBAS ,1
ENG248441-ENG248813-function_configuration_unit-second_display_via_lvds_connection,not connected ,1
ENG248441-ENG248822-function_configuration_unit-Suspend_to_RAM,Deactivated ,1
ENG248441-ENG248829-function_configuration_unit-web_app_plattform_side_loading,Deactivated ,1
ENG248442-geocoordinate_create,do_not_create ,1
ENG248443-geocoordinate_show,do_not show ,1
ENG248448-ENG248814-ipv4_address_of_subnet_1_on_ccu-segment_1,10 ,4
ENG248448-ENG248815-ipv4_address_of_subnet_1_on_ccu-segment_2,173 ,4
ENG248448-ENG248816-ipv4_address_of_subnet_1_on_ccu-segment_3,201 ,4
ENG248448-ENG248817-ipv4_address_of_subnet_1_on_ccu-segment_4,1 ,4
ENG248449-ENG248814-ipv4_address_of_subnet_1_on_mib-segment_1,10 ,4
ENG248449-ENG248815-ipv4_address_of_subnet_1_on_mib-segment_2,173 ,4
ENG248449-ENG248816-ipv4_address_of_subnet_1_on_mib-segment_3,201 ,4
ENG248449-ENG248817-ipv4_address_of_subnet_1_on_mib-segment_4,2 ,4
ENG248450-ENG248814-ipv4_address_of_subnet_2_on_ccu-segment_1,10 ,4
ENG248450-ENG248815-ipv4_address_of_subnet_2_on_ccu-segment_2,173 ,4
ENG248450-ENG248816-ipv4_address_of_subnet_2_on_ccu-segment_3,202 ,4
ENG248450-ENG248817-ipv4_address_of_subnet_2_on_ccu-segment_4,1 ,4
ENG248451-ENG248814-ipv4_address_of_subnet_2_on_mib-segment_1,10 ,4
ENG248451-ENG248815-ipv4_address_of_subnet_2_on_mib-segment_2,173 ,4
ENG248451-ENG248816-ipv4_address_of_subnet_2_on_mib-segment_3,202 ,4
ENG248451-ENG248817-ipv4_address_of_subnet_2_on_mib-segment_4,2 ,4
ENG248454-ENG248814-ipv4_address_of_subnet_4_on_ccu-segment_1,10 ,4
ENG248454-ENG248815-ipv4_address_of_subnet_4_on_ccu-segment_2,175 ,4
ENG248454-ENG248816-ipv4_address_of_subnet_4_on_ccu-segment_3,202 ,4
ENG248454-ENG248817-ipv4_address_of_subnet_4_on_ccu-segment_4,1 ,4
ENG248455-ENG248814-ipv4_address_of_subnet_4_on_mib-segment_1,10 ,4
ENG248455-ENG248815-ipv4_address_of_subnet_4_on_mib-segment_2,175 ,4
ENG248455-ENG248816-ipv4_address_of_subnet_4_on_mib-segment_3,202 ,4
ENG248455-ENG248817-ipv4_address_of_subnet_4_on_mib-segment_4,2 ,4
ENG248456-ENG248814-ipv4_address_of_the_wlan_ap-segment_1,10 ,4
ENG248456-ENG248815-ipv4_address_of_the_wlan_ap-segment_2,173 ,4
ENG248456-ENG248816-ipv4_address_of_the_wlan_ap-segment_3,189 ,4
ENG248456-ENG248817-ipv4_address_of_the_wlan_ap-segment_4,1 ,4
ENG248457-ENG248814-ipv6_address_of_subnet_1_on_ccu-segment_1,FD 30 ,8
ENG248457-ENG248815-ipv6_address_of_subnet_1_on_ccu-segment_2,E0 8E ,8
ENG248457-ENG248816-ipv6_address_of_subnet_1_on_ccu-segment_3,C0 31 ,8
ENG248457-ENG248817-ipv6_address_of_subnet_1_on_ccu-segment_4,00 01 ,8
ENG248458-ENG248814-ipv6_address_of_subnet_1_on_mib-segment_1,FD 30 ,8
ENG248458-ENG248815-ipv6_address_of_subnet_1_on_mib-segment_2,E0 8E ,8
ENG248458-ENG248816-ipv6_address_of_subnet_1_on_mib-segment_3,C0 31 ,8
ENG248458-ENG248817-ipv6_address_of_subnet_1_on_mib-segment_4,00 01 ,8
ENG248459-ENG248814-ipv6_address_of_subnet_2_on_ccu-segment_1,FD 30 ,8
ENG248459-ENG248815-ipv6_address_of_subnet_2_on_ccu-segment_2,E0 8E ,8
ENG248459-ENG248816-ipv6_address_of_subnet_2_on_ccu-segment_3,C0 31 ,8
ENG248459-ENG248817-ipv6_address_of_subnet_2_on_ccu-segment_4,00 02 ,8
ENG248460-ENG248814-ipv6_address_of_subnet_2_on_mib-segment_1,FD 30 ,8
ENG248460-ENG248815-ipv6_address_of_subnet_2_on_mib-segment_2,E0 8E ,8
ENG248460-ENG248816-ipv6_address_of_subnet_2_on_mib-segment_3,C0 31 ,8
ENG248460-ENG248817-ipv6_address_of_subnet_2_on_mib-segment_4,00 02 ,8
ENG248463-ENG248814-ipv6_address_of_subnet_4_on_ccu-segment_1,64816 ,8
ENG248463-ENG248815-ipv6_address_of_subnet_4_on_ccu-segment_2,57486 ,8
ENG248463-ENG248816-ipv6_address_of_subnet_4_on_ccu-segment_3,49201 ,8
ENG248463-ENG248817-ipv6_address_of_subnet_4_on_ccu-segment_4,512 ,8
ENG248464-ENG248814-ipv6_address_of_subnet_4_on_mib-segment_1,64816 ,8
ENG248464-ENG248815-ipv6_address_of_subnet_4_on_mib-segment_2,57486 ,8
ENG248464-ENG248816-ipv6_address_of_subnet_4_on_mib-segment_3,49201 ,8
ENG248464-ENG248817-ipv6_address_of_subnet_4_on_mib-segment_4,512 ,8
ENG248465-ENG248814-ipv6_address_of_the_wlan_ap-segment_1,FD 30 ,8
ENG248465-ENG248815-ipv6_address_of_the_wlan_ap-segment_2,E0 8E ,8
ENG248465-ENG248816-ipv6_address_of_the_wlan_ap-segment_3,C0 31 ,8
ENG248465-ENG248817-ipv6_address_of_the_wlan_ap-segment_4,01 03 ,8
ENG152375-ENG152428-Logging_Configuration-Interface,00 ,3
ENG152375-ENG152494-Logging_Configuration-loglevel,00 ,3
ENG152375-ENG98732-Logging_Configuration-Memory,00 ,3
ENG278389-Market_and_brand_specific_preInstSet_of_webapps,preinstallation_set_0 ,1
ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input,not activated ,5
ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard,not activated ,5
ENG248467-number_to_name_matching_algorithm,detect_numbers ,1
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,01 01 3C 02 3C 02 3C 02 50 02 50 02 64 02 6E 02 78 02 3C 02 3C 02 3C 02 50 02 1E 02 1E 02 1E 02 1E 02 02 02 02 14 05 5C ,40
ENG252007-ENG297686-Privacy_mode-globe_icon,not activated ,2
ENG252007-ENG252075-Privacy_mode-supress_privacy_mode,not activated ,2
ENG248469-same_ssid_for_2_4_and_5_ghz,Yes ,1
ENG248470-sortorder,sortorder_1 ,1
ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
ENG248475-wlan_ap_local_net_dhcp_lease_time,72 H,1
ENG244949-ENG248626-wlan_channel_numbers-channel_number_for_2_4GHz,6 ,1
ENG244949-ENG248627-wlan_channel_numbers-channel_number_for_5GHz,12 ,1
Elapsed Time: 00:59
