T6 Start/Stop battery replacement
C_V
England, UK
C?ID=337088
Good evening,
We've just had a customers 2017 T6 come in that has had a new battery fitted and apparently since this new battery was fitted an error comes on the MFD - "Start Stop Error". I believe its because the battery wasn't coded in at the time of replacement. How do you do this with VCDS? Its currently showing an error in the 67 - Battery Regulator. I've been into this module and long adaption and found Battery info/replacement, I tried test & save because as far as I know they are both 70ah batteries. I've also gone into Coding - Long coding helper and copied the code into new code and saved it too. But still no joy.
There is also another error in the 01 Engine module - 25796 - BCM (Central Electrics) - No communications - Didn't know if this was linked.
Scan attached. Thanks in advance
Monday,07,March,2022,16:24:01:53043
VCDS Version: 21.9.0.2 (x64)  HEX-V2 CB: 0.4555.4
VIN: WV1ZZZ7HZHH129664   License Plate: BRF
Mileage: 69370km-43104mi   Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 09 15 17 19 25 5F 61 69 0B
VIN: WV1ZZZ7HZHH129664   Mileage: 69370km-43104miles
Address 01: Engine (2D2D2-CXGA)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 JS    HW: 04L 907 445
   Component: R4 2.0l TDI   H02 4044
   Revision: 23002001
   Coding: 00114010430501090000
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_ECM20TDI03004L906056JS 004004
   ROD: EV_ECM20TDI03004L906056JS_004.rod
   VCID: 074A6EA41FA1C703E6B-8052
   VINID: 9E606AAAA1D8A98601089186104D3AF628
25796 - Body Control Module (Central Electric)
          U0140 00 [039] - No Communications
                    Mileage: 69373 km
                    Date: 2057.01.08
                    Time: 05:42:01
                    Engine RPM: 0.00 /min
                    Coolant temperature: 45 °C
                    Intake air temperature: 12 °C
                    Voltage terminal 30: 12.304 V
                    Accelerator pedal travel: raw value: 0.00 %
                    CAN status - engine control module: 0
                    Cruise Control System (CCS): status: main switch off
                    selected gear: Shifting process active
Readiness: N/A
   Revision: 00000000    Serial number: 40447000001309
   Coding: 517E4098256484878A7B027CA48621E6790000
   Shop #: WSC 02739 790 50316
   VCID: 3FDAB64407F14FC39EB-806A
   Serial number: 08011713471586
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA40B40407B86CBD5D-802A
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 037170949
   Coding: E0A4303A0A212031002009742C2B8C500F00708F60464D60320400220800
   Shop #: WSC 02737 022 1650977
   VCID: 2A0CF710ECF3DA6BD95-807E
   Subsystem 1 - Part No SW: 7E0 959 801 P    HW: 7E0 959 801 P  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 0653
   Serial number: KU0KU008021770396456
   Coding: 1400B0
   Subsystem 2 - Part No SW: 7E0 959 802 P    HW: 7E0 959 802 P  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  003 0653
   Serial number: KU0KU008021770397494
   Coding: 0400A0
   Part No SW: 7E0 959 655 G    HW: 7E0 959 655 G
   Component: VW10Airbag021 H08 0018
   Revision: --------    Serial number: 003V3003S3F0
   Coding: 000000000000000000000000000000003231
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3A2CC7501CD36AEBA95-806E
   Part No SW: 7E0 920 960 S    HW: 7E0 920 960 S
   Coding: 450B010300
   VCID: 392ED85C19D561F3A0F-806C
   Part No SW: 7E0 909 901     HW: 7E0 937 090
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 042305
   VCID: 68884D18327F287B0F1-803C
   Component: IMMO          H03 1104
   VCID: 6A8C37102CF31A6B195-803E
   Part No SW: 1K8 035 150 L    HW: 1K8 035 150 L
   Component: MU-E-D-ER     055 7085
   Serial number: 12011700012914
   Coding: 02210000BE00000041111101008000001F0000C60000010001
   ROD: EV_MUEnt4CGen2LGE_VW32.rod
   VCID: 2E04FB00D09BB64B05D-807A
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H81 0744
   Coding: 030B7A73
   Shop #: WSC 09999 999 999999
   Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
   Serial number: 75410903921701244865
02252 - Generator
                    Reset counter: 175
   Component: ConWysTrailer H07 0100
   Revision: 3A001001    Serial number: 00000132425721
   Coding: 0100000100000000
   Shop #: WSC 00007 223 174336
   VCID: 3038E578CA2FA0BB171-8064
End----------(Elapsed Time: 01:04, VBatt start/end: 12.2V/12.2V)-----------
On this battery management module:
Format: AAA BBB NNNNNNNNNN
AAA = Battery Size in Ah
BBB = Battery Vendor
NNNNNNNNNN = Battery Serial Number
Battery Vendor List:
5DO = Boading
TU3 = Exide
MLA = Moll
JCB = JCI
VA0 = Varta
UM5 = Akuma
If in doubt, just make sure the Battery Size is correct and change the serial number. The Vendor code doesn't really matter. Changing anything in that channel will tell the battery management that a new battery has been installed.
Adding to the above, please do code/adapt the new battery but I see this causing a problem:
02252 - Generator​
004 - No Signal/Communication​
If that returns I would look into the cause. I believe address 61 is coded correctly so there may be a wiring problem in-between 61 and the alternator.
VWT6
Finland
C?ID=295527
Thanks Matti! I was not aware of that thread/feedback.
@C_V If you end up finding broken wiring at that LIN splice please try to take a photo and upload it to a cloud/drive based service so the link can be shared. That will allow us to link it from a Wiki page which may save the next guy some time. I use Google Photos (since all of my Android based phones over the years have backup to that service) but this thread may be helpful:
C_V
England, UK
C?ID=337088
Thanks everyone - it was damage to the LIN wire between alternator and module, picture attached.
ToNNfBv
C_V
England, UK
C?ID=337088
ToNNfBv
C_V
England, UK
C?ID=337088
@Dana Sorry its not posting?
I have lost count of the number of these we have done, and I still can't work out what it is there for but we also have found that when it breaks it can damage the battery monitoring unit, the body control module and the alternator. If after repairing the wire there are no repeat codes and the stop/start works then it should be OK.
