Hey fellas-
Im new to the forum but not the car world, I am extremely excited to have my VAGCOM finally but NEED HELP PLEASE!
Ac is not working AT ALL.
replaced the g395 pressure sensor (but wondering if they sent me a generic sensor and not a true oem, hence still getting the Implausible signal)
When i ran the individual component checks, THE AC DID BLOW COLD WHEN THE N280 VALVE SAW CURRENT.
Please please can anyone help?
I know there is a TSB on this issue, which is what originally led me to change the pressure sensor.
Also I did have the system pumped(not flushed just dumped) and refilled with the computerized machine to Audi specs.
VCDS Version: Release 14.10.2 (x64)
Data version: 20150311
Saturday,30,May,2015,19:16:56:07369
Chassis Type: FL (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 6C
72
VIN: WAUEFAFL0AN047123 Mileage: 87960km-54655miles
55-Headlight Range -- Status: Cannot be reached 1100
Address 01: Engine (DL0MA-CAEB) Labels: 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AL HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H16 0001
Revision: E1H16---
Coding: 0104010A02070160
Shop #: WSC 05136 444 12160
ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
ROD: EV_ECM20TFS0118K2907115AL.rod
VCID: 79F9A4A8F8C59BE9291-802C
Readiness: 1110 0101
Address 02: Auto Trans (J217) Labels: 0AW-927-156.clb
Part No SW: 8K1 927 155 J HW: 0AW 927 156 H
Component: 0AW 20TAVSUSA H04 0003
Revision: --H04--- Serial number: 0000000118
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_TCMVL381 A02017
ROD: EV_TCMVL381_AU48.rod
VCID: 3B757EA0B27969F97BD-806E
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 BT HW: 8K0 907 379 BT
Component: ESP8 front H04 0010
Coding: 080D18
Shop #: WSC 02391 823 56573
VCID: 0C17ED7CAF579E41027-8059
Reset counter: 92
Mileage: 87961 km
Date: 2015.05.30
Time: 17:30:26
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0035
Hex Value: 0x4097
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 DG HW: 8K0 907 064 DG
Component: BCM2 1.1 H02 0327
Coding: 090100
Shop #: WSC 02399 823 56573
VCID: 78FFA1ACCBCF82E156F-802D
Subsystem 1 - Part No SW: 8T0 959 754 G HW: 8T0 959 754 G
Component: FBSAUDIB8 IDG H61 0072
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Component: KLIMA 3 ZONEN H08 0171
Revision: C1000000 Serial number: 01150120101817
Coding: 64102000
VCID: 000FC94C931FCA216EF-8055
Fault Status: 01101000
Reset counter: 92
Mileage: 87962 km
Date: 2015.05.30
Time: 19:09:54
Temperature: 31.0°C
00457 - Control Module for Network (J519)
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 92
Mileage: 87962 km
Date: 2015.05.30
Time: 19:09:54
00797 - Sunlight Photo Sensor (G107)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 92
Mileage: 87962 km
Date: 2015.05.30
Time: 19:09:55
Temperature: 33.0°C
Temperature: 31.0°C
Output: 300 W
Output: 300 W
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H25 0380
Revision: 10025001 Serial number: 00000000559680
Coding: 26001091063CAF010000080300003D0D0F1C520800010161000000
VCID: 3C777DBCBF776EC1727-8069
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 140110 H06 0070
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Reset counter: 92
Mileage: 87960 km
Date: 2015.05.30
Time: 17:11:00
02258 - Door Opener Transmitter
Reset counter: 92
Mileage: 87960 km
Date: 2015.05.30
Time: 17:11:00
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 Q HW: 8K0 919 475
Component: PARKHILFE 4K H06 0070
Revision: 11001001 Serial number: 51291001503758
Coding: 200103
VCID: 479D1250F6B13D19EF5-8012
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 H HW: 8K0 959 655 H
Component: AirbagVW-AU10 H39 0560
Serial number: 003EGD05F4F%
Coding: 303836354230303030304A55304C384B3053
Shop #: WSC 02135 785 00200
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 428B0344D593183138B-8017
Subsystem 1 - Part No SW: 8K0 959 339 B HW: 8K0 959 339 B
Component: BF-Gewichtss. H01 0030
Serial number: 5810000R0900005WDS
Serial number: 6334MSME4E420E15H
Serial number: 6344MSME4F32416CL
Serial number: 6352QSME624C5322D
Serial number: 6362QSME734B3A28Q
Serial number: 63732SME5B4A0F067
Serial number: 63832SME1B4A040E1
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90304JAI000DU
Coding: 000036
VCID: 3D7170B8A46D67C9459-8068
Component: E221 - MFL H02 0010
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 980 M HW: 8K0 920 980 M
Component: KOMBIINSTR. H20 0255
Revision: 00100000 Serial number: CIX33131A
Coding: 8B1609000300D705020000
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 T HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0105
Revision: EB800053 Serial number: 5300E101128020
Coding: 00C303
VCID: 52AB33040DF388B188B-8007
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
Reset counter: 92
Mileage: 87962 km
Date: 2015.05.30
Time: 19:13:14
Bin. Bits: 10111
Voltage: 11.80 V
Count: 6
Bin. Bits: 10011
Time: 25.40 s
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000009905426
Coding: 011C03204000410001
VCID: 45811858CCBD2F091D9-8010
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0125749502
Coding: 0106023A007A440400B0013200000000
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0050
Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J245 PS045 H07 0041
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000009932986
VCID: 4487055CC78716010A7-8011
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000540912
VCID: 3467559C9727A681BA7-8061
Address 55: Headlight Range
Part No SW: 4F0 035 082 A HW: 4F0 035 082
Component: Radio U SIRIU H45 0021
Revision: AB001007 Serial number: 335AU0A7547550
Coding: 020000020100000001
VCID: 1D31903804AD07C9659-8048
02246 - Loudspeaker; Center
Reset counter: 92
Mileage: 87960 km
Date: 2015.05.30
Time: 17:07:44
Voltage: 11.80 V
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8T1 035 664 B HW: 8T1 035 664 B
Component: H-BN-NA H47 0042
Revision: -------- Serial number: 490AW0A7543554
Coding: 010200000006A1EF01000B0E000000030000
VCID: 377D629086514D999F5-8062
Subsystem 1 - Part No: 8R0 060 884 F
Component: NAR 2009/2010 5304
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Subsystem 3 - Part No SW: 8T0 919 609 F HW: 8T0 919 609 F
Component: E0380 Bedient H08 0100
Component: CD-Database 1293
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000102685070
Coding: 010C03204000210001
VCID: 428B0344DD93183138B-8017
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Revision: --H03--- Serial number: 525PA8-J9Z90PW
Coding: 1000006
VCID: 387F61AC4B4F42E196F-806D
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000102685067
End-------------------------(Elapsed Time: 03:11)--------------------------
