- Feb 24, 2022
- 40
- 7
- New Zealand
- C?ID=434586
I'd like to see a complete Auto-Scan for context. I can't tell if it had loaded a ROD file or not from that snippet.
Friday,25,February,2022,10:42:43:48194
VCDS Version: 21.9.0.2 (x64) HEX-NET2 CB: 0.4555.4
VIN: WV1ZZZSYZJ9005909 License Plate:
Chassis Type: SY-VN54 (3Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 3C 42 44 52 5F 69 BB
VIN: WV1ZZZSYZJ9005909 Mileage: 125346km-77886miles
Address 01: Engine (J623-DAVA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 AR HW: 04L 907 445 C
Component: R4 2.0l BTD H01 5225
Revision: 23201001
Coding: 002A40346324050800000000000000000000000000000000
Shop #: WSC 00069 790 00013
ASAM Dataset: EV_ECM20BTD03004L906056AR 005004
ROD: EV_ECM20BTD03004L906056AR_005.rod
VCID: 7DAC938F9D7AAAC3CC7-8028
VINID: 9E606AAAA8E9A9A24000524024589DE0C8
24838 - ROD - Unknown Error Code
- 00 [039]
Mileage: 125346 km
Date: 2022.02.24
Time: 05:22:18
Engine RPM: 830.75 /min
Normed load value: 59.6 %
Coolant temperature: 64 °C
Intake air temperature: 27 °C
Voltage terminal 30: 14.609 V
Accelerator pedal travel: raw value: 0.00 %
Cylinder 3 bank 1 internal moment: -25.0 Nm
Cylinder head: controller internal moment 3 bank 1: limit stat.-Controller output of the foc.posit.contr. limited to min.value: No
Cylinder head: controller internal moment 3 bank 1: limit stat.-Controller output of the foc.posit.contr. limited to max.value: Yes
Cylinder head: controller internal moment 3 bank 1: limit stat.-Offset combustion focus position < min. threshold: No
Cylinder head: controller internal moment 3 bank 1: limit stat.-Offset combustion focus position >max. threshold: Yes
Cylinder head: controller internal moment 3 bank 1: limit stat.: 34
O2 sens. 1 bank 1 upstrm oxi cat: raw value: 1.000 counts
Setpoint generation interior torque: 85.2 Nm
24840 - ROD - Unknown Error Code
- 00 [100]
Mileage: 125346 km
Date: 2022.02.24
Time: 21:49:50
Engine RPM: 832.25 /min
Normed load value: 74.9 %
Coolant temperature: 51 °C
Intake air temperature: 23 °C
Voltage terminal 30: 14.546 V
Cylinder 4 bank 1 internal moment: 63.7 Nm
Cylinder head: controller internal moment 4 bank 1: limit stat.-Controller output of the foc.posit.contr. limited to min.value: No
Cylinder head: controller internal moment 4 bank 1: limit stat.-Controller output of the foc.posit.contr. limited to max.value: Yes
Cylinder head: controller internal moment 4 bank 1: limit stat.-Offset combustion focus position < min. threshold: No
Cylinder head: controller internal moment 4 bank 1: limit stat.-Offset combustion focus position >max. threshold: Yes
Cylinder head: controller internal moment 4 bank 1: limit stat.: 34
Setpoint generation interior torque: 108.0 Nm
Readiness: N/A
Address 02: Auto Trans (J217) Labels: 09G-927-749-V2.clb
Part No SW: 09G 927 158 M HW: 09G 927 158
Component: AISIN AQ8 206 3381
CVN: 99B61759
Coding: 0000000100000000010000000000000000000000
ROD: EV_TCMAQ450031_VN54.rod
VCID: 3D2C538FDDFA6AC38C7-8068
Part No SW: 2N0 907 379 C HW: 2N0 907 379 C
Component: ESC_base H02 0850
Serial number: 08503507170623
Coding: 25A82477483DB687A4502460124C6D463DF1407A
ASAM Dataset: EV_Brake1ESP90iBOSCHVN54X 701028
ROD: EV_Brake1ESP90iBOSCHVN54X_701.rod
VCID: 363E4CA3F8CCB99B4DD-8062
Address 08: Auto HVAC (J301) Labels:* None
Part No SW: 7C0 907 426 K HW: 7C0 907 426 K
Component: AC Manuell H01 0201
Coding: A03110000800000001000800500101000000000000010000000000000000
Shop #: WSC 00069 790 00011
ASAM Dataset: EV_AirCondiBHTCVN54X 003018
ROD: EV_AirCondiBHTCVN54X_003_VN54.rod
VCID: 31347FBF11A29EA318F-8064
Part No SW: 5Q0 937 084 CM HW: 5Q0 937 084 CD
Component: BCM MQBAB B H36 0253
Serial number: 01001717000188
ROD: EV_BCMBOSCH_018.rod
VCID: 055CFB6FF5AAE203947-8050
Subsystem 1 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 042 0105
Serial number: S8Y17M06D19H08M11S38
Coding: 0038DD
Address 10: Park/Steer Assist (J791) Labels:* None
Part No SW: 2N0 919 300 A HW: 2N0 919 300
Component: aFLS 16KH04 0103
Serial number: 000310350617129
Coding: 057116D071
ASAM Dataset: EV_EPHVA2FVN54X0000 009034
ROD: EV_EPHVA2FVN54X0000.rod
VCID: 270091E72F66D013C6B-8072
Part No SW: 2Q0 907 572 M HW: 2Q0 907 572 B
Component: ACCCONTIMQB H02 0233
Coding: 3200400900FF8448949C814D003087
VCID: 3E2E5483D0FC71DB95D-806A
Part No SW: 3Q0 959 655 BG HW: 3Q0 959 655 BG
Component: Airbag VW21 006 0703
Revision: -------- Serial number: 003W3PD2HE3Q
Coding: 8800C00000000000400000CF008800000065
ROD: EV_AirbaVW21TS6VW48X_VN54.rod
VCID: 045AE66BFE90DB0B839-8050
Subsystem 1 - Part No SW: ----------- HW: 454 800 607 17
Component: FrontSensor_D 305 0109
Serial number: 355005FEC2610000000P
Subsystem 2 - Part No SW: ----------- HW: 454 800 607 17
Component: FrontSensor_P 305 0109
Serial number: 3560031E626100000004
Part No SW: 5Q0 953 521 HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF034034 Serial number: 20170622500986
Coding: 0010
ROD: EV_SMLSVALEOMQB.rod
VCID: 6FB0B9C7C716C8534EB-803A
Part No SW: 7C0 920 741 A HW: 7C0 920 741 A
Component: KOMBI 204 0310
Coding: 27A411082088000800882A095401000000000000
ROD: EV_DashBoardVDDMQBAB_VW27.rod
VCID: 221680F34444353B915-8076
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW MQB High 433 4303
Revision: -------- Serial number: 0006483537
Coding: 030100344F05730000000000000F00010001070000000000000000000000
GVL: 01543C0000000000C04C80000000C80000000000000000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 333875B7EBBEACB36A3-8066
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0103
Serial number: 39170001657440027237
Coding: 28FFFF
Subsystem 3 - Part No SW: 2N0 915 181 HW: 2N0 915 181
Serial number: 75884900001706170006
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0080
Serial number: 0443152018
Coding: 02012203
ROD: EV_HREntryHella_SE27.rod
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0080
Serial number: 0442612117
Coding: 020122
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 011 0032
Serial number: 0000263453710
Coding: 00300B20D001040000001000
VCID: 47C031678F26301326B-8012
Address 44: Steering Assist (J500) Labels:| 2N0-909-143.clb
Part No SW: 2N0 909 143 E HW: 2N0 909 143 C
Component: EPS_MQB_ZFLS 701 7021
Coding: 0107
ASAM Dataset: EV_SteerAssisMNB 002001
ROD: EV_SteerAssisMNB.rod
VCID: 2F3079C7079688530EB-807A
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 011 0032
Serial number: 0000264124835
Coding: 00300B20D001040100001000
VCID: 46DE3C63882C291BDDD-8012
Part No SW: 3Q0 035 824 C HW: 3Q0 035 824 C
Component: MU-S--ER 721 0842
Coding: 064500003C00000051510001000808001F0500D60120050003
ROD: EV_MUStd4CDELP_VW27.rod
VCID: 2D0C63CF0D9AFA433C7-8078
Subsystem 1 - Part No SW: 7C0 919 606 HW: 7C0 919 606
Component: ABT_HIGH H54 1031
Serial number: VWZ8Z9TGY01G3X
Part No SW: 6C0 907 383 G HW: 6C0 907 383 G
Component: Anhaenger H27 0260
Revision: 8D001004 Serial number: 0437992044
Coding: 0100000202000000
ROD: EV_TrailFunctGener2Hella_VW27.rod
VCID: 2E0E64C3009C815B05D-807A
Part No SW: 5Q4 959 395 E HW: 5Q4 959 395 B
Component: TSG HFS 012 0032
Serial number: 0000263825120
Coding: 000001200101020000000000
ASAM Dataset: EV_DCURearDriveMAXCONT 006001
End----------(Elapsed Time: 01:04, VBatt start/end: 14.7V/14.5V)-----------
