Resolved 2012 MK6 JETTA S no steering angle communication
Resolved
lbonvino
Indianapolis, IN, USA
C?ID=254269
I need help with this,
terminal 1 on the plug has no power,
but also according to the wiring diagram power comes from fuse 35, and there nothing on that position, no fuse or wiring behind it
I did get a new clockspring ( which houses the sensor) and nothing
If I jump power to that wire, then I can get the angle sensor to work and do adaptation ,
Friday,20,August,2021,08:15:51:50799
VCDS Version: 21.3.0.0 (x64)
VIN: 3VW1K7AJXCM333223   License Plate:
Mileage: 203650km-126542mi   Repair Order:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 03 08 09 15 17 19 25 56
VIN: 3VW1K7AJXCM333223   Mileage: 203650km-126542miles
04-Steering Angle -- Status: Cannot be reached 1100
Address 01: Engine (CBP)       Labels: 06G-906-055-CBP.clb
   Part No SW: 06G 906 055 R    HW: 06G 906 055 B
   Component: 2.0l / 85 KW     01 1105
   Revision: T5H06---    Serial number:
   Coding: 0001012
   Shop #: WSC 20309 444 100664
   VCID: 387EA2FD4B95E44B3B-806C
049446 - No Communications with Steering Angle Sender (G85)
               U0126 - 000 -
                    Mileage: 203512 km
                    Date: 2015.12.30
                    Time: 08:36:32
                    RPM: 784 /min
                    Load: 42.3 %
                    Temperature: 101.0°C
                    Temperature: 54.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 13.589 V
   Revision: 00H31001
   Coding: B14B240C492508FD8D0D24E6921C1061A70000
   Shop #: WSC 00066 000 00000
   VCID: 7BF47DF1FA230F5396-802E
                    Reset counter: 53
                    Mileage: 203514 km
                    Date: 2015.12.31
                    Time: 00:43:49
                    Count: 3
                    Count: 12800
                    Count: 166
                    Count: 49152
                    Count: 252
                    Reset counter: 53
                    Mileage: 203514 km
                    Date: 2015.12.31
                    Time: 00:43:49
                    Count: 3
                    Count: 12800
                    Count: 16390
                    Count: 49152
                    Count: 252
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 AM    HW: 5C0 820 047 AM
   Component: J301  Klimaanlage   0203
   Revision: 2001010S    Serial number: 00000000557770
   VCID: 6BD44DB14A439FD306-803E
   Part No SW: 5C0 937 086 E    HW: 5C0 937 086 A
   Component: BCM25 JLB M3  H67 0251
   Revision: B0067001    Serial number: 04351261110183
   Coding: 7B994B1808AB0B0000302000240884D40042502E60000000300000000000
   VCID: 2E5284A579D12AFB61-807A
   Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  002 3464
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  002 3464
   Coding: 820000
   Subsystem 3 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3464
   Coding: 800000
   Subsystem 4 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3464
   Coding: 800000
   Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
   Component: AirbagVW10G   013 0807
   Serial number: 003GTM01WRWX
   Coding: 00003936
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01020
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 346696CD9FFD002B17-8060
   Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
   Component: BF-Gewichtss.  H10 0027
   Serial number: 6940000Y1100007HJR0$
   Coding: 303148
   Serial number: 3572MSME65280442ZZZO
   Serial number: 3582MSME07011642ZZZF
   Serial number: 3516KSME45232B11ZZZI
   Serial number: 3526KSME3E6C4011ZZZV
   Serial number: 3556LSME235F1512ZZZS
   Serial number: 3566LSME3F581512ZZZZ
   Part No SW: 5C6 920 951     HW: 5C6 920 951
   Component: KOMBI         H04 0604
   Coding: 270201
   Shop #: WSC 00066 000 00123
   VCID: 68DE32BD93B5B4CB6B-803C
   Part No SW: 6N0 909 901     HW: 5C0 937 086 A
   Component: GW-K-CAN TP20 H67 0251
   Revision: B0067001
   Coding: 102200
   VCID: 70EE5ADDA3657C0B33-8024
                    Reset counter: 66
                    Mileage: 189489 km
                    Date: 2014.08.25
                    Time: 15:44:54
   Component: IMMO          H04 0604
   VCID: 6ADA48B58DB986DB7D-803E
   Part No SW: 1K0 035 164 D    HW: 1K0 035 164 D
   Component: LOW NAR       H02 0004
   Revision: -----03S    Serial number: VWZ4Z6L3205629
   Coding: 05000400010006
   VCID: 2344659122139793FE-8076
End-------------------------(Elapsed Time: 01:46)--------------------------
Jef
HQ
Fuse SC27?
lbonvino
C?ID=254269
I will check again, I know is there and good, but I think it felt loose
JMR
EU
C?ID=432218
twist the fuse pins a bit for better connection
lbonvino
C?ID=254269
Fuse SC27?
BINGO
Actually the fuse was on position 26, moved it to 27 and now there is power to terminal one on the clock spring, and life is back on course
I fell so stupid that I was reading the wrong diagram ( alldataDYI)...
To make matters worst I took the car to the dealer Monday, and they want it to install a new clockspring, even though I told the service guy that I had just installed a new one.... I save my self of $580.16
Jef
HQ
.... added to the something for everyone thread....
