Active Lane Assist Retrofit - 5C Lane Maintain Coding
Mrclopec
Nipomo, CA
C?ID=149231
Hello. I have added the necessary components to a 2015 Q5 3.0 TDI to retrofit Active Lane Assist except the replacement windshield. This option is available ROW but not in NA. I am having trouble coding module 5C. I have installed the new Multifunction switch on the steering column with the Lane Assist activation button. I have also added the Lane Maintenance control module (Camera). I have coded the following modules to reflect the changes and they do not give any errors: 16, 17, 19, 44, 5F. When I get all of the control modules coded correctly I will be replacing the windscreen and performing the calibration. After that I will be doing a complete writeup including photos and procedures. I found some information online regarding Lane Assist on a B4 but using that coding model doesn't seem to be working. From MY09-12 the feature was just "Lane Assist" and used part number 8K0 907 217. FROM MY13-Current it became "Active Lane Assist" which provides steering corrections and uses part number 8T0 907 217 A am really hoping someone here might have an idea on where the coding fault in 5C is and can help me input the correct 7 digit value. I do have the necessary steering components already fitted to the car by the factory. Below I have attached a scan before I did any retrofitting or coding as well as a scan after all modules and components were fitted and coded. Thank you greatly for any information anyone might have.
Vehicle info.
1. Q5
2.USA
3.Adaptive Cruise Control (13)
4.No Adaptive Chassis Control
5.Trailer provisions
6.Lane Change Assist (3C)
7.Navigation High
8.CAN High
Before any modification or retrofit scan:
Thursday,09,April,2015,11:04:40:00104
VCDS Version: 14.10.2.0
Data version: 20150311
VIN: WA1WMBFP6FAxxxxxx   License Plate:
Mileage: 16350km-10159mi   Repair Order:
Chassis Type: FP (8R0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 1B 20 36 3C 42 44 46 47 52
          53 56 5F 62 69 6C 6D 72 AC
VIN: WA1WMBFP6FA048050   Mileage: 16350km-10159miles
Address 01: Engine (J623-CPNB)       Labels: 059-907-311-CLA.clb
   Part No SW: 8K5 907 401 S    HW: 4G0 907 401 E
   Component: 3.0TDI EDC17  H14 0001
   Revision: 58H14---
   Coding: 2A2A4012057603050000
   Shop #: WSC 55440 001 1048576
   ASAM Dataset: EV_ECM30TDI0118K5907401S 001003
   ROD: EV_ECM30TDI0118K5907401S.rod
   VCID: 408F6B65DB83AB212EF-8015
8812 - Cylinder 2 Internal Pressure Sensor
          P13D1 00 [047] - Short to Plus
                    Mileage: 12828 km
                    Date: 2015.03.14
                    Time: 10:40:38
Address 02: Auto Trans (J217)       Labels: 0BK-927-156.clb
   Part No SW: 8R0 927 158 Q    HW: 0BK 927 156 AM
   Component: 0BK 30 TDIUSA H19 1003
   Revision: --H19---
   ROD: EV_TCMAL551211_AU48.rod
   VCID: 4B954C49E2C57879CBD-801E
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 8R0 907 379 AS    HW: 8R0 907 379 AS
   Component: ESP8 quattro  H09 0020
   Coding: 23AD1C03
   VCID: 11299E21C86912A9F11-8044
   Part No SW: 8K0 907 064 KP    HW: 8K0 907 064 KP
   Component: BCM2 2.0      H15 0711
   Coding: 0DA54040000000000000
   Shop #: WSC 06335 000 00000
   VCID: 081FB345BB33536126F-805D
   Part No SW: 8K1 820 043 AQ    HW: 8K1 820 043 AQ
   Revision: C1000000    Serial number: 01190920141164
   Coding: 3621228080
   VCID: 77FDC0B9C6CD2C995F5-8022
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00000893404802
   Coding: 26000091867CAFF21100488300003D0D4F9CE708A6090221000008004000010200040034000000
   VCID: 7AFBD98DF5DF31F120B-802F
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 140827  H12 0050
   Coding: 01DD13
   Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Component: USHL4.2  H30 0030
   Subsystem 5 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Subsystem 6 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
Address 13: Auto Dist. Reg (J428)       Labels: Redir Fail!
   Part No SW: 8R0 907 561 A    HW: 8R0 907 561 A
   Component: ACC3          H11 0100
   Coding: 008157
   VCID: 377D00B9864DEC999F5-8062
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 R    HW: 8K0 959 655 R
   Component: AirbagVW-AU10 H51 0812
   Serial number: 003NED12HYXB
   Coding: 303334313432383132304A55304C38523053
   ASAM Dataset: EV_AirbaECUVWAUDI010 003114
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 4C974F55E7CB7F41C27-8019
   Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
   Serial number: 5810000R140000GX4R
   Serial number: 6334MSME480E2C00D
   Serial number: 6344MSME4879646DV
   Serial number: 6352QSME5C460456J
   Serial number: 6362QSME4747316EO
   Serial number: 63732SME40443466U
   Serial number: 63832SME64424D44+
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372NIG000A4
   Coding: 00003F
   VCID: 44876775C79BB7010A7-8011
Address 17: Instruments (J285)       Labels: 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 982 B    HW: 8R0 920 982 B
   Component: KOMBIINSTR.   H35 0564
   Revision: 00400000    Serial number: ZDC27399F
   Coding: 8BBF22002F01D705020000
   VCID: 3A7B198DB55FF1F160B-806F
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0060
   Revision: 1Z120030    Serial number: 3041Z149050B6E
   Coding: 80CF07FF00
   VCID: 4C974F55EFCB7F41C27-8019
   Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
   Component: J367-BDMHella  H07 8043
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
   Part No SW: 8K0 907 144 M    HW: 8K0 907 144 M
   Component: DYNAMIKLENK.  H06 0730
   Revision: 52001005    Serial number: --------------
   Coding: 020100
   VCID: 39790681B059FAE9691-806C
Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
   Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD
   Component: FLA           H04 0012
   Revision: AA001002
   Coding: 02019164747464545425363E00
   Shop #: WSC 06325 000 00000
   VCID: 7CF7DF95FFEB0FC1327-8029
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0077
   Revision: AA000000    Serial number: 00000114744385
   Coding: 01581B00000000000000
   VCID: 428B616DDD8FB93138B-8017
Address 3C: Lane Change (J769)       Labels: 5Q0-907-566.clb
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Serial number: 0346139735
   Coding: 010221
   ROD: EV_LaneChangAssis.rod
   VCID: 3F8D6899A67DD4D9575-806A
   Lane Change Assistant 2:
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000116313843
   Coding: 011D13215E00440004
   VCID: 4FAD58591EDD4459A75-801A
Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
   Part No SW: 8R0 909 144 J    HW: 8R0 909 144 B
   Component: RCEPS         H41 0509
   Revision: 00001000    Serial number: 0030925634
   Coding: 010000010001
   Shop #: WSC 06334 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008016
   ROD: EV_RCEPSAU48X.rod
   Revision: 00002001    Serial number: 0347056755
   Coding: 0126063A20FA709584A0053600040047
   Component: GTO BF  H01 0080
   Subsystem 3 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H03 0090
   Subsystem 4 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H03 0090
Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
   Revision: 00005001    Serial number: 94813034061406
   VCID: 2D5122D174115649F59-8078
   Component: TSG BF        H02 0510
   Revision:             Serial number: 0000117929946
   VCID: 4E93455D19D74D51AC3-801B
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 30000000264223
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A7B198DBD5FF1F160B-806F
   Revision: AB001007    Serial number: 156I20E8065591
   Coding: 020007010000000001
   VCID: 2447C7F527DB97012A7-8071
   Part No SW: 8R1 035 746 F    HW: 8R1 035 746 D
   Component: H-BNT-NA      H41 0812
   Revision: --------    Serial number: 204I10E7679622
   Coding: 160200060005E9EF7502AF5E00000403140000000000000000
   Subsystem 1 - Part No: 8R0 060 884 CA
   Component: NAR 2014  1002
   Component: DU7 High  H42 0104
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Component: CD-Database  5950
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000117821679
   Coding: 010C13204000240004
   VCID: 46837D7DF1A78511143-8013
Address 69: Trailer (J345)       Labels: 8K0-907-383.clb
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Revision: 1A001001    Serial number: 00008200724693
   Coding: 0200000000000000
   VCID: 36630DBD81471591843-8063
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H09---    Serial number: 525PA8-J47A2YG
   Coding: 1031010
   VCID: 346737B5573B0781BA7-8061
   Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
   Component: J605  Master  H56 0330
   Revision: --------    Serial number: 8R0827851D
   VCID: 3D711291A471C6C9459-8068
   Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
   Component: J756  Slave  H56 0330
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000116472682
Address AC: Reductant Control (J880)       Labels: None
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 142460205
   ROD: EV_RDCMA00100.rod
   VCID: 2D5122D17C115649F59-8078
End-------------------------(Elapsed Time: 04:43)--------------------------
After Retrofit and coding 16, 17, 19, 44, 5F
Wednesday,27,May,2015,09:53:42:00104
Mileage: 17380km-10799mi   Repair Order:
          53 56 5C 5F 62 69 6C 6D 72 AC
VIN: WA1WMBFP6FA048050   Mileage: 17380km-10799miles
5C-Lane Maintain. -- Status: Malfunction 0010
   Revision: 58H14---
          P13D1 00 [109] - Short to Plus
                    Mileage: 17382 km
                    Date: 2015.05.26
                    Time: 01:38:04
Readiness: 0 0 0 1 1
   Revision: --H19---
   Coding: 23AD1C03
   Coding: 3621228080
   Coding: 01DD13
   Coding: 02005C
H05 0012
H05 0012
   Coding: 008157
   Coding: 0000FF
   Coding: 8BBF22006F01D705020000
   Coding: 80CF07FF00
   Coding: 020100
   Revision: AA001002
   Coding: 010221
   Coding: 010001010001
Address 5C: Lane Maintain.        Labels: None
   Part No SW: 8T0 907 217 A    HW: 4E0 907 217 C
   Component: J759 HC             0040
   Revision: 00H08006    Serial number: 600213910000FA
   Coding: 0102104
   VCID: 377D00B9464DEC999F5-8062
02797 - Control Module for Directional Stabilization Assistance (J759)
                    Fault Status: 01100101
                    Reset counter: 237
                    Mileage: 17382 km
                    Date: 2015.05.26
                    Time: 21:01:37
            000 -  -
                    Reset counter: 237
                    Mileage: 17382 km
                    Date: 2015.05.26
                    Time: 21:01:37
02858 - Windshield Heater for Directional Stabilization Assistance (Z67)
                    Reset counter: 237
                    Mileage: 17382 km
                    Date: 2015.05.26
                    Time: 21:01:38
   Coding: 160200060005E9EF7D02AF5E00000403140000000000000000
   Coding: 1031010
End-------------------------(Elapsed Time: 05:11)--------------------------
NEtech
Denmark
C?ID=56995
Have you tried to change to zero values in importer, device no., like explained here before coding with the same coding.
If you have and want to test (I am not 100% sure), I would try either 0132104 or 0122104.
I guess you have not mounted the Windshield Heater (Z67) or it is not correct connected.
Mrclopec
Nipomo, CA
C?ID=149231
0132104 WORKS! From what I found online the 5th digit relates to Navigation and Advanced Key(ROW-USA)/Fingerprint Reader(Japan). My car has both Advanced key and Navigation High so it was the "3" that did it. I am in the process of making the calibration board (VAS6430). As soon as it is complete and the project is finished I will be doing a full writeup. Thank you for your help!
Chris
Mrclopec
Nipomo, CA
C?ID=149231
Would anyone happen to have the security access code to 5C? I'd like to access the adaptation channels and poke around but there isn't a label file on this module. The security access section states that a vehicles access codes can be found in its factory repair manual. I have ELSAWIN and cant seem to find them in it anywhere...
Mrclopec
Nipomo, CA
C?ID=149231
Thanks to Dana at Ross-tech. The code is 01111.
NEtech
Denmark
C?ID=56995
And you then get access to channels 60...68 ?
Mrclopec
Nipomo, CA
C?ID=149231
Alright so heres some info. When I access the control module and click on 16 - Security access and type 01111 it will say Accepted or something to that effect. I have run both adaptation maps with and w/o the SA code and they are the same...
Without SA:
;SW:8T0-907-217-A   HW:4E0-907-217-C ---  Lane Maintain.
;Component:J759 HC             0040, Coding:0132004
;Wednesday,03,June,2015,12:08:57:00104
;VCDS Version: Release 14.10.2  Data version: 20150311
;VCID: 377D00B9464DEC999F5-8062
Channel,,Field 1,Field 2,Field 3,Field 4,
01,,ERROR:,Channel 01,Not,Available,
02,,ERROR:,Channel 02,Not,Available,
03,,ERROR:,Channel 03,Not,Available,
04,,ERROR:,Channel 04,Not,Available,
05,,ERROR:,Security,access,required,
06,1,N/A,N/A,N/A,N/A,
07,5,2.0,OFF,OFF,N/A,
08,0,N/A,N/A,N/A,N/A,
09,0,N/A,N/A,N/A,N/A,
10,0,N/A,N/A,N/A,N/A,
11,,ERROR:,Channel 11,Not,Available,
12,,ERROR:,Channel 12,Not,Available,
13,,ERROR:,Channel 13,Not,Available,
14,,ERROR:,Channel 14,Not,Available,
15,,ERROR:,Channel 15,Not,Available,
16,,ERROR:,Channel 16,Not,Available,
17,,ERROR:,Channel 17,Not,Available,
18,,ERROR:,Channel 18,Not,Available,
19,,ERROR:,Channel 19,Not,Available,
20,,ERROR:,Channel 20,Not,Available,
21,,ERROR:,Channel 21,Not,Available,
22,,ERROR:,Channel 22,Not,Available,
23,,ERROR:,Channel 23,Not,Available,
24,,ERROR:,Channel 24,Not,Available,
25,,ERROR:,Channel 25,Not,Available,
26,,ERROR:,Channel 26,Not,Available,
27,,ERROR:,Channel 27,Not,Available,
28,3252,3252,3252,3252,3252,
29,3252,3252,3252,3252,3252,
30,3252,3252,3252,3252,3252,
31,3252,3252,3252,3252,3252,
32,,ERROR:,Channel 32,Not,Available,
33,,ERROR:,Channel 33,Not,Available,
34,,ERROR:,Channel 34,Not,Available,
35,,ERROR:,Channel 35,Not,Available,
36,,ERROR:,Channel 36,Not,Available,
37,,ERROR:,Channel 37,Not,Available,
38,,ERROR:,Channel 38,Not,Available,
39,,ERROR:,Channel 39,Not,Available,
40,,ERROR:,Channel 40,Not,Available,
41,,ERROR:,Channel 41,Not,Available,
42,,ERROR:,Channel 42,Not,Available,
43,,ERROR:,Channel 43,Not,Available,
44,,ERROR:,Channel 44,Not,Available,
45,,ERROR:,Channel 45,Not,Available,
46,,ERROR:,Channel 46,Not,Available,
47,,ERROR:,Channel 47,Not,Available,
48,,ERROR:,Channel 48,Not,Available,
49,,ERROR:,Channel 49,Not,Available,
50,,ERROR:,Channel 50,Not,Available,
51,,ERROR:,Security,access,required,
52,,ERROR:,Security,access,required,
53,,ERROR:,Security,access,required,
54,,ERROR:,Channel 54,Not,Available,
55,,ERROR:,Channel 55,Not,Available,
56,,ERROR:,Channel 56,Not,Available,
57,,ERROR:,Channel 57,Not,Available,
58,,ERROR:,Channel 58,Not,Available,
59,,ERROR:,Channel 59,Not,Available,
60,,ERROR:,Security,access,required,
61,,ERROR:,Security,access,required,
62,,ERROR:,Security,access,required,
63,,ERROR:,Security,access,required,
64,,ERROR:,Security,access,required,
65,,ERROR:,Security,access,required,
66,,ERROR:,Security,access,required,
67,,ERROR:,Security,access,required,
68,,ERROR:,Security,access,required,
69,,ERROR:,Channel 69,Not,Available,
70,,ERROR:,Channel 70,Not,Available,
71,,ERROR:,Channel 71,Not,Available,
72,,ERROR:,Channel 72,Not,Available,
73,,ERROR:,Channel 73,Not,Available,
74,,ERROR:,Channel 74,Not,Available,
75,,ERROR:,Channel 75,Not,Available,
76,,ERROR:,Channel 76,Not,Available,
77,,ERROR:,Channel 77,Not,Available,
78,,ERROR:,Channel 78,Not,Available,
79,,ERROR:,Channel 79,Not,Available,
80,,ERROR:,Channel 80,Not,Available,
81,,ERROR:,Channel 81,Not,Available,
82,,ERROR:,Channel 82,Not,Available,
83,,ERROR:,Channel 83,Not,Available,
84,,ERROR:,Channel 84,Not,Available,
85,,ERROR:,Channel 85,Not,Available,
86,,ERROR:,Channel 86,Not,Available,
87,,ERROR:,Channel 87,Not,Available,
88,,ERROR:,Channel 88,Not,Available,
89,,ERROR:,Channel 89,Not,Available,
90,,ERROR:,Channel 90,Not,Available,
91,,ERROR:,Channel 91,Not,Available,
92,,ERROR:,Channel 92,Not,Available,
93,,ERROR:,Channel 93,Not,Available,
94,,ERROR:,Channel 94,Not,Available,
95,,ERROR:,Channel 95,Not,Available,
96,,ERROR:,Channel 96,Not,Available,
97,,ERROR:,Channel 97,Not,Available,
98,,ERROR:,Channel 98,Not,Available,
99,,ERROR:,Channel 99,Not,Available,
100,,ERROR:,Channel 100,Not,Available,
101,,ERROR:,Channel 101,Not,Available,
102,,ERROR:,Channel 102,Not,Available,
103,,ERROR:,Channel 103,Not,Available,
104,,ERROR:,Channel 104,Not,Available,
105,,ERROR:,Channel 105,Not,Available,
106,,ERROR:,Channel 106,Not,Available,
107,,ERROR:,Channel 107,Not,Available,
108,,ERROR:,Channel 108,Not,Available,
109,,ERROR:,Channel 109,Not,Available,
110,,ERROR:,Channel 110,Not,Available,
111,,ERROR:,Channel 111,Not,Available,
112,,ERROR:,Channel 112,Not,Available,
113,,ERROR:,Channel 113,Not,Available,
114,,ERROR:,Channel 114,Not,Available,
115,,ERROR:,Channel 115,Not,Available,
116,,ERROR:,Channel 116,Not,Available,
117,,ERROR:,Channel 117,Not,Available,
118,,ERROR:,Channel 118,Not,Available,
119,,ERROR:,Channel 119,Not,Available,
120,,ERROR:,Channel 120,Not,Available,
121,,ERROR:,Channel 121,Not,Available,
122,,ERROR:,Channel 122,Not,Available,
123,,ERROR:,Channel 123,Not,Available,
124,,ERROR:,Channel 124,Not,Available,
125,,ERROR:,Channel 125,Not,Available,
126,,ERROR:,Channel 126,Not,Available,
127,,ERROR:,Channel 127,Not,Available,
128,,ERROR:,Channel 128,Not,Available,
129,,ERROR:,Channel 129,Not,Available,
130,,ERROR:,Channel 130,Not,Available,
131,,ERROR:,Channel 131,Not,Available,
132,,ERROR:,Channel 132,Not,Available,
133,,ERROR:,Channel 133,Not,Available,
134,,ERROR:,Channel 134,Not,Available,
135,,ERROR:,Channel 135,Not,Available,
136,,ERROR:,Channel 136,Not,Available,
137,,ERROR:,Channel 137,Not,Available,
138,,ERROR:,Channel 138,Not,Available,
139,,ERROR:,Channel 139,Not,Available,
140,,ERROR:,Channel 140,Not,Available,
141,,ERROR:,Channel 141,Not,Available,
142,,ERROR:,Channel 142,Not,Available,
143,,ERROR:,Channel 143,Not,Available,
144,,ERROR:,Channel 144,Not,Available,
145,,ERROR:,Channel 145,Not,Available,
146,,ERROR:,Channel 146,Not,Available,
147,,ERROR:,Channel 147,Not,Available,
148,,ERROR:,Channel 148,Not,Available,
149,,ERROR:,Channel 149,Not,Available,
150,,ERROR:,Channel 150,Not,Available,
151,,ERROR:,Channel 151,Not,Available,
152,,ERROR:,Channel 152,Not,Available,
153,,ERROR:,Channel 153,Not,Available,
154,,ERROR:,Channel 154,Not,Available,
155,,ERROR:,Channel 155,Not,Available,
156,,ERROR:,Channel 156,Not,Available,
157,,ERROR:,Channel 157,Not,Available,
158,,ERROR:,Channel 158,Not,Available,
159,,ERROR:,Channel 159,Not,Available,
160,,ERROR:,Channel 160,Not,Available,
161,,ERROR:,Channel 161,Not,Available,
162,,ERROR:,Channel 162,Not,Available,
163,,ERROR:,Channel 163,Not,Available,
164,,ERROR:,Channel 164,Not,Available,
165,,ERROR:,Channel 165,Not,Available,
166,,ERROR:,Channel 166,Not,Available,
167,,ERROR:,Channel 167,Not,Available,
168,,ERROR:,Channel 168,Not,Available,
169,,ERROR:,Channel 169,Not,Available,
170,,ERROR:,Channel 170,Not,Available,
171,,ERROR:,Channel 171,Not,Available,
172,,ERROR:,Channel 172,Not,Available,
173,,ERROR:,Channel 173,Not,Available,
174,,ERROR:,Channel 174,Not,Available,
175,,ERROR:,Channel 175,Not,Available,
176,,ERROR:,Channel 176,Not,Available,
177,,ERROR:,Channel 177,Not,Available,
178,,ERROR:,Channel 178,Not,Available,
179,,ERROR:,Channel 179,Not,Available,
180,,ERROR:,Channel 180,Not,Available,
181,,ERROR:,Channel 181,Not,Available,
182,,ERROR:,Channel 182,Not,Available,
183,,ERROR:,Channel 183,Not,Available,
184,,ERROR:,Channel 184,Not,Available,
185,,ERROR:,Channel 185,Not,Available,
186,,ERROR:,Channel 186,Not,Available,
187,,ERROR:,Channel 187,Not,Available,
188,,ERROR:,Channel 188,Not,Available,
189,,ERROR:,Channel 189,Not,Available,
190,,ERROR:,Channel 190,Not,Available,
191,,ERROR:,Channel 191,Not,Available,
192,,ERROR:,Channel 192,Not,Available,
193,,ERROR:,Channel 193,Not,Available,
194,,ERROR:,Channel 194,Not,Available,
195,,ERROR:,Channel 195,Not,Available,
196,,ERROR:,Channel 196,Not,Available,
197,,ERROR:,Channel 197,Not,Available,
198,,ERROR:,Channel 198,Not,Available,
199,,ERROR:,Channel 199,Not,Available,
200,,ERROR:,Channel 200,Not,Available,
201,,ERROR:,Channel 201,Not,Available,
202,,ERROR:,Channel 202,Not,Available,
203,,ERROR:,Channel 203,Not,Available,
204,,ERROR:,Channel 204,Not,Available,
205,,ERROR:,Channel 205,Not,Available,
206,,ERROR:,Channel 206,Not,Available,
207,,ERROR:,Channel 207,Not,Available,
208,,ERROR:,Channel 208,Not,Available,
209,,ERROR:,Channel 209,Not,Available,
210,,ERROR:,Channel 210,Not,Available,
211,,ERROR:,Channel 211,Not,Available,
212,,ERROR:,Channel 212,Not,Available,
213,,ERROR:,Channel 213,Not,Available,
214,,ERROR:,Channel 214,Not,Available,
215,,ERROR:,Channel 215,Not,Available,
216,,ERROR:,Channel 216,Not,Available,
217,,ERROR:,Channel 217,Not,Available,
218,,ERROR:,Channel 218,Not,Available,
219,,ERROR:,Channel 219,Not,Available,
220,,ERROR:,Channel 220,Not,Available,
221,,ERROR:,Channel 221,Not,Available,
222,,ERROR:,Channel 222,Not,Available,
223,,ERROR:,Channel 223,Not,Available,
224,,ERROR:,Channel 224,Not,Available,
225,,ERROR:,Channel 225,Not,Available,
226,,ERROR:,Channel 226,Not,Available,
227,,ERROR:,Channel 227,Not,Available,
228,,ERROR:,Channel 228,Not,Available,
229,,ERROR:,Channel 229,Not,Available,
230,,ERROR:,Channel 230,Not,Available,
231,,ERROR:,Channel 231,Not,Available,
232,,ERROR:,Channel 232,Not,Available,
233,,ERROR:,Channel 233,Not,Available,
234,,ERROR:,Channel 234,Not,Available,
235,,ERROR:,Channel 235,Not,Available,
236,,ERROR:,Channel 236,Not,Available,
237,,ERROR:,Channel 237,Not,Available,
238,,ERROR:,Channel 238,Not,Available,
239,,ERROR:,Channel 239,Not,Available,
240,,ERROR:,Channel 240,Not,Available,
241,,ERROR:,Channel 241,Not,Available,
242,,ERROR:,Channel 242,Not,Available,
243,,ERROR:,Channel 243,Not,Available,
244,,ERROR:,Channel 244,Not,Available,
245,,ERROR:,Channel 245,Not,Available,
246,,ERROR:,Channel 246,Not,Available,
247,,ERROR:,Channel 247,Not,Available,
248,,ERROR:,Channel 248,Not,Available,
249,,ERROR:,Channel 249,Not,Available,
250,,ERROR:,Channel 250,Not,Available,
251,,ERROR:,Channel 251,Not,Available,
252,,ERROR:,Channel 252,Not,Available,
253,,ERROR:,Channel 253,Not,Available,
254,,ERROR:,Channel 254,Not,Available,
255,,ERROR:,Channel 255,Not,Available,
With SA:
;Wednesday,03,June,2015,09:44:05:00104
NEtech
Denmark
C?ID=56995
Yes I would guess that, I mean it is for Basic settings Camera Calibration (don't start that)
Do you have button [Coding II - 11] active ?
If so, would you try if that also accepts 01111
Mrclopec
Nipomo, CA
C?ID=149231
No. No coding II. I'm not too worried about having to re-calibrate as I have my own vas6430. I've been into VAS-PC and there are no adaptation options in there under 5C either.
NEtech
Denmark
C?ID=56995
Adaptation for heights should be 028...031, Basic Settings MWB 001 and 003.
But it is not possible with a procedure and of course the tools.
Mrclopec
Nipomo, CA
C?ID=149231
I'm looking for more of the settings as far as activation speed, driver sensing, etc. I'm not looking to calibrate as I already have the means to do so through VAS-PC. Im just looking to tweak some of its factory default settings.
NEtech
Denmark
C?ID=56995
Mrclopec
Nipomo, CA
C?ID=149231
Oh. Hehe. I see now. :-P is there a possibility there is a second security code to access the channels that still remain locked?
NEtech
Denmark
C?ID=56995
Yes I would think so.
Mrclopec
Nipomo, CA
C?ID=149231
You wouldnt happen to know the other code or another way to access the locked channels would you? ;)
Nope.
Moreover, when VWAG protects certain adaptation channels with a security access code, that means you REALLY shouldn't mess with them unless you KNOW what you're doing. This is true of Adaptation Channels in general, even when they're not protected by a security access code, but it's double or even quadruple true when they are.
Mrclopec
Nipomo, CA
C?ID=149231
Fair enough. Thank you for all of your help. :)
Yeah - and I couldn't locate any other codes either so we aren't holding out on you.
Mrclopec
Nipomo, CA
C?ID=149231
Haha. Oh I know, Dana. You guys were very helpful. It's all coded and working. I'm on my way to the dealership now to get my replacement windshield. Last step and it's all finished. Thank you again. :)
