Golf 7 2014 ACC/CAM upgrade
sers77
Norway
C?ID=26140
Have a frontcam 3Q0980654L (HW12 SW0610) and a radar 3QF907561 (H10 SW0620) that is supposed to go into the car, but what else do I need for this to work?
The heater from old radar will be moved to the new one, so the beam will stay warm during winter :p
Will a 3Q0907530L 5323 (Continental 3Q0907530C 518) work with this car and be all that is needed (except front window)?
Hope I don´t "have" to change the MIB1 for now, unless this retrofit/upgrade needs it?
Saturday,24,July,2021,10:01:33:21522
VCDS Version: 21.3.0.0 (x64)  HEX-NET CB: 0.4544.4
Workshop Code: 666 12345 045678
VIN: WVWZZZAUZEW111212   License Plate: PIPPIRULL2.0
Mileage: 100921km-62709mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 2B 3C 42 44 52 55 5F
          69 A5
VIN: WVWZZZAUZEW111212   Mileage: 100921km-62709miles
Address 01: Engine (J623-CPTA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 AD    HW: 04E 907 309 G
   Component: R4 1.4l TFS   H02 9225
   Revision: WKH02---
   Coding: 0125003A247405083000
Shop #: WSC 61962 003 1048576
ASAM Dataset: EV_ECM14TFS01104E906016AD 002015
   ROD: EV_ECM14TFS01104E906016AD.rod
   VCID: E4840921EF0F2DABC7-80B0
Readiness: 1110 0001
   Part No SW: 0CW 300 045     HW: 0AM 927 769 G
Component: GSG DQ200-MQB H43 5240
   Revision: 00043014    Serial number: CU501308185463
   ROD: EV_TCMDQ200021_VW26.rod
   VCID: F6A043694993AF3B69-80A2
   Revision: 00000000    Serial number: 61136000001318
   Coding: 01FA6AA12421116D0779060141C52980562488E0608294F33822506890A2
Shop #: WSC 12345 666 45678
   VCID: FAB857597D8BCB5B0D-80AE
   Revision: 00021000    Serial number: 0194304581
   Coding: 030C1C
   VCID: BA3897593D0B0B5B4D-80EE
   Part No SW: 5G0 907 044 AB    HW: 5G0 907 044 AB
   Component: Climatronic   H02 0705
   Revision: 00001K06
   Coding: 00020004204101011105004000101000
   VCID: E79E1E2D1E3946B3E2-80B2
   Air quality sensor:
   Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 AA
Component: BCM MQBAB H H14 0112
   Serial number: 00011324200143
   Coding: 00031E46C24122FB4BE44000001C07081C0A000000000000000000000000
   ROD: EV_BCMBOSCH_011.rod
   VCID: F7BE4E6D4E99D63372-80A2
   Component: WWS    130811  042 0551
   Serial number:         130820192717
   Coding: 0E4DFD
Component: RLFS 024 0042
   Serial number: Y13M09D03H00M40S31S1
   Coding: 06A8DD
   Part No SW: 5QA 919 298 E    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0452
   Serial number: 000308417617305
   Coding: 0251065951
ASAM Dataset: EV_EPHVA2CAU3700000 009038
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: D2E8DFF985BBD31BA5-8086
   Part No SW: 5Q0 907 572 A    HW: 5Q0 907 572 A
Component: ACC Bosch MQB H03 0141
   Serial number: 12071376510039
   Coding: 001C1D00FE033B
ASAM Dataset: EV_ACCMRRBoschVW372 001013
   VCID: B52284651415E423A0-80E0
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR005HKT
   Coding: 98FCC0C0000000005C5400CF004800000065
   VCID: FF4EA64D66A9EE733A-80AA
   Left seat belt tensioner:
   Component: BeltPretRevFL  H35 0340
   Serial number: 34169667B05091371397
   Coding: 333135
   Right seat belt tensioner:
   Component: BeltPretRevFR  H35 0340
   Serial number: 34169668B06091350561
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 708 13
   Serial number: 357670000008CC597D08
   Subsystem 4 - Part No SW: -----------    HW: 480 001 708 13
   Serial number: 35867000000AE2488D02
   Subsystem 5 - Part No SW: -----------    HW: 480 402 908 13
   Serial number: 3516502B71088B1140F3
   Subsystem 6 - Part No SW: -----------    HW: 480 402 908 13
   Serial number: 3526502A71088B1101B$
   Subsystem 7 - Part No SW: -----------    HW: 480 402 408 13
   Serial number: 3556502C510EDE4302FN
   Part No SW: 5Q0 953 507 BM    HW: 5Q0 953 549
   Revision: --------    Serial number: 23081308490093
   Coding: 0C00
   VCID: 82482FB9155B839B55-80D6
   Part No SW: 5G1 920 758 A    HW: 5G1 920 758 A
   Component: KOMBI         302 6420
   Coding: 032509186F8C00081D827A0B4401000000000000
   VCID: AD12AC05FC45ACE3D8-80F8
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 B    HW: 5Q0 963 272 B
Component: STH-MQB 006 0069
   Coding: 1309
ASAM Dataset: EV_AuxilParkiHeateWOS 002014
   Auxiliary heating remote control:
   Subsystem 1 - Part No SW: 5Q0 963 513     HW: 5Q0 963 513
Component: R149 T91-LIN 003 0301
   Serial number: 00000000000000655100
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
Component: GW MQB High 125 1244
   Revision: --------    Serial number: 0000846596
   Coding: 030100342B086400EF00065E1C0F00010001000000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: F9BA4855788DC04304-80AC
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0040
   Serial number: 29150001466590015304
   Coding: 2DFFFF
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 3637991103
   Part No SW: 5Q0 905 861     HW: 5Q0 905 861
   Component: ELV-MQBA      H06 0010
   Revision: 00000000    Serial number: 13000185018004
   Coding: 4900000000000000
ASAM Dataset: EV_ELVMarquMQB 003008
   ROD: EV_ELVMarquMQB_003.rod
   VCID: F3A67A7D5AE1BA134E-80A6
   Serial number: 0402084260
   Coding: 02032103
   ROD: EV_HREntryHella_VW37.rod
   VCID: BC349141373F356B5F-80E8
   Component: HRE_Slave  H11 0071
   Serial number: 0388577079
   Coding: 020321
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
Component: TSG FS 012 0006
   Serial number: 18081302090615
   Coding: 003F1320D000048000001001
   VCID: BFCEE64D26292E737A-80EA
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000002561162
   Part No SW: 3Q0 909 144 D    HW: 3Q0 909 144 E
   Component: EPS_MQB_ZFLS  502 5011
   Coding: 1301
ASAM Dataset: EV_SteerAssisMQB 009026
   ROD: EV_SteerAssisMQB_009_VW37.rod
   VCID: B326BA7D1A61FA138E-80E6
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
Component: TSG BFS 012 0006
   Serial number: 16081303110333
   Coding: 003F11205E00048000801001
   VCID: BE309B492123277B71-80EA
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000002497037
   Coding: 090000
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
   Coding: 029A01105F010200
   VCID: BD329C452C253C6368-80E8
   Subsystem 1 - Part No SW: 3D0 941 329 A    HW: 3D0 941 329 A  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H05 0012
   Coding: 900000
   Subsystem 2 - Part No SW: 3D0 941 329 A    HW: 3D0 941 329 A  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H05 0012
   Coding: 900000
   Part No SW: 5G0 035 020 H    HW: 5G0 035 020
   Component: MU-H-ND-EU    H40 0192
   Serial number: A458H0D7500229
   Coding: 027300010000000021111202002800001F0100340100010097
ASAM Dataset: EV_MUHig4CHBAS 001040
   ROD: EV_MUHig4CHBAS_VW37.rod
   VCID: 9E707BC981E3477B51-80CA
   Component: ABT_High  H42 0020
   Serial number: VWZ8Z9N2300V09
   Subsystem 2 - Part No SW: V03 959 806 MR    HW: -----------
   Component: ECE 2021  --- 0189
   Compact disc data bank:
   Component: Gracenote  --- 1008
   Part No SW: 5Q0 907 383 A    HW: 5Q0 907 383 A
   Component: Anhaenger     H11 0030
   Revision: 6B001003    Serial number: 00000194338091
   Coding: 0100000200000000
ASAM Dataset: EV_TrailFunctPivotHella 001001
   ROD: EV_TrailFunctDemouHella.rod
   Part No SW: 5Q0 980 653 E    HW: 5Q0 980 653
   Component: MQB_MFK       H05 0051
   Serial number: 00000107988
   Coding: 0101020001020303000401010100000101
   ROD: EV_MFKBoschAU370.rod
End----------(Elapsed Time: 01:25, VBatt start/end: 13.6V/13.6V)-----------
downtime
Finland
C?ID=280813
I you plan to do predictive ACC with that, you need to have mib2.5 unit. Also 3Q0 camera does not work with MIB1 very well, if at all. If I remember correctly MIB1 is not able to provide PSD1.5 route data that 3Q0 needs.
Also no need to move any heaters. 3QF has heated front face, it's just a matter of enabling or disabling it in adaptations and coding.
Do you know how to do the ACC enabling?
sers77
Norway
C?ID=26140
"Do you know how to do the ACC enabling?"
I have all files that are needed, just don`t know exactly what parameter file to flash it with (Golf7_FL_up?).
Also have GEKO, and the FEC`s...
Plan was to not activate the pACC and PSD FEC`s yet..
Worried that the cluster and the front door modules are to old aswell?
Found these while (and the SWAP calc) googling around:
FEC
10009001 MRR-Paket 1: ACClow (Basis-ACC) + FrontAssist inkl. CityANB
10009002 MRR-Paket 2: ACClow (ACC FTS) + FrontAssist inkl. CityANB
10009003 MRR-Paket 3: ACClow (ACC S&G) + FrontAssist inkl. CityANB
10009004 MRR-Paket 4: FrontAssist inkl. CityANB (Without ACC)
10009005 MRR-Paket 5: CityANB (Without ACC)
10009006 MRR-Paket 6: ACChigh (Basis-ACC) + FrontAssist inkl. CityANB
10009007 MRR-Paket 7: ACChigh (ACC FTS) + FrontAssist inkl. CityANB
10009008 MRR-Paket 8: ACChigh (ACC S&G) + FrontAssist inkl. CityANB
10009201 AWV-Auspraegung "AWV1,2 - Visual and Auditory Warning Only"
10009202 AWV-Auspraegung "AWV1,2"
10009203 AWV-Auspraegung "AWV1,2,3"
10009204 AWV-Auspraegung "AWV1,2,3, vFGS
10009205 AWV-Auspraegung „AWV1,2,3, vFGS, vRFS“
10009301 AWV-Feature Extension-Paket "Electronic Parking Brake"
10009301 AWV-Feature Extension-Paket "Emergency Assist"
10009302 AWV-Feature Extension-Paket "Curve Assist"
10009303 AWV-Feature Extension-Paket "AWV-Gegenverkehr"
10009304 AWV-Feature Extension-Paket "Curve Assist & AWV-Gegenverkehr"
10009305 AWV-Feature Extension-Paket "EmergencyAssist & AWV-Gegenverkehr"
10009306 AWV-Feature Extension-Paket "EmergencyAssist & Curve Assist"
10009307 AWV-Feature Extension-Paket "EmergencyAssist & Curve Assist & AWV-Gegenverkehr"
10009101 ACC-Feature Extension-Paket "Predictive ACC"
10009102 ACC-Feature Extension-Paket "Traffic Jam Assist"
10009103 ACC-Feature Extension-Paket "Predictive ACC & Traffic Jam Assist"
10009500 Traffic Sign Recognition (VZE)
10009600 Pedestrian Assist (VFS) - FCWP
downtime
Finland
C?ID=280813
Yes, front door modules need to be E index. Otherwise the ACC does not work. Cluster might be that it's too old, at some point in 2014 the clusters started supporting ACC graphics. You'll see when you have it installed if it works or not. Change the cluster if neeeded.
And of course you should enable pACC already now. You can disable the pACC functions from car driving assist menu if you don't want to have them on. Then it acts like normal ACC.
3QF supports 8150 so you can enable these as maximum :
It does not support any higher, so for example the AWV feature expansions don't work.
And as parameters the Golf7_Up works fine.
sers77
Norway
C?ID=26140
Cluster is R-Line from 2016, had to change it for the side-assist and PLA3.0 retrofit..
downtime
Finland
C?ID=280813
Then it should work fine
sers77
Norway
C?ID=26140
Discover pro on the way with AID, but I'm gonna stay with the R-cluster..
Looking at gateways and as the car has a Lear gateway, should I look for Lear 3Q0 gateway or is Continental 3Q0 a safer way to go?
downtime
Finland
C?ID=280813
Either one works. Also 5Q0 gateway works if you upgrade it to AM. Of course needs parameters after that.
sers77
Norway
C?ID=26140
Am is Continental?, so I need new anyway..
Found a cheap Lear 3Q0907530AA 4367, it should solve the problems to come :rolleyes:
downtime
Finland
C?ID=280813
Yes, easiest to switch to 3Q0 gateway. And if you get one from similar car than yours, no even need to parameterise it.
sers77
Norway
C?ID=26140
Went with 3Q0907530L from another Golf (2018) and also 5Q0959592E and 5Q0959593E from the same car..
F door modules (cars from 2019) is not plug&play, as the pin layout is not the same..
downtime
Finland
C?ID=280813
Yes, E is the highest you can go without physical changes.
Was the Golf with similar engine (gasoline or diesel) and gearbox? Reason is that thet alternator parameters are different if the donor car has different size alternator.
sers77
Norway
C?ID=26140
Golf 1.0tfsi dsg and 140A alternator... If not, I'll just use vcp..
Now, only a few more gray hairs and some glass awaits.. Getting close.. :rolleyes:
sers77
Norway
C?ID=26140
MIB and gateway retrofitted and some strange things have happened (where did Address 47 come from?)... Also, no sound..:p
Monday,23,May,2022,23:36:05:21522
VCDS Version: 22.3.1.1  HEX-NET CB: 0.4615.4
Data version: 20220401 DS337.0
VIN: WVWZZZAUZEW111212   License Plate: PIPRULLE
Mileage: 104371km-64853mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 2B 3C 42 44 47 52 55
          5F 69 A5
VIN: WVWZZZAUZEW111212   Mileage: 104371km-64853miles
47-Sound System -- Status: Not registered 0001
   Revision: WKH02---    CVN: 8445B2BE
   VCID: 648489216F0FADAF4E-8030
   VINID: 9E69EAAAA465A959C104108108EB9EE8C7
   Component: GSG DQ200-MQB H43 5245
   Revision: 00043014    Serial number: CU501308185463 CVN: 00003808
   VCID: 76A0C369C9932F3FE0-8022
   ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
   VCID: 7AB8D759FD8B4B5F84-802E
   Coding: 030C1C
   VCID: 3A381759BD0B8B5FC4-806E
   Revision: 00001K06
   VCID: 679E9E2D9E39C6B76B-8032
   Air quality sensor:
   VCID: 77BECE6DCE995637FB-8022
   Coding: 0E4DFD
   Component: RLHS  037 0059
   Serial number: S5Y15M02D25H18M50S10
   Coding: 90A8DD
   Coding: 0251065951
   VCID: 52E85FF905BB531F2C-8006
   VCID: 352204659415642729-8060
   VCID: 7F4E264DE6A96E77B3-802A
   Coding: 333135
   Coding: 333135
   Coding: 0C00
   VCID: 0248AFB9955B039FDC-8056
   VCID: 2D122C057C452CE751-8078
   Coding: 1309
   Component: GW MQB High   436 4326
   Revision: --------    Serial number: 0008050469
   Coding: 030100047F086400BB00025E1C0F00010001070000000000000000000000
   GVL: 01563C0000000600C0CC90000004C80000000000000000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF_VW37.rod
   VCID: 383C0D518307994F32-806C
   Generator:
   Coding: 2DFFFF
131593 - Multifunction Module
          U1301 00 [009] - No Communication at Second Databus Connection
          [Time_out_node_0x09_multifunction_module_on_second_bus]
                    Reset counter: 213
                    Mileage: 104371 km
                    Date: 2022.05.23
                    Time: 23:30:26
                    Terminal 30 power supply: 13.4 V
                    Terminal 15: On
          U1101 00 [009] - Active
                    Reset counter: 213
                    Mileage: 104371 km
                    Date: 2022.05.23
                    Time: 23:30:26
                    Terminal 30 power supply: 13.3 V
                    Terminal 15: On
   VCID: 73A6FA7DDAE13A17C7-8026
   Coding: 02032103
   VCID: 3C341141B73FB56FD6-8068
   Coding: 020321
   VCID: 3FCE664DA629AE77F3-806A
   Coding: 1301
   VCID: 33263A7D9A617A1707-8066
Address 47: Sound System (J525)       Labels:| 5G0-035-456.clb
   Part No SW: 5G0 035 456     HW: 5G0 035 456
   Component: MIB_lite_amp  H30 0042
   Serial number: VWZ8Z1DC400L0S5
   Coding: 120000008AAA8A0000
   ASAM Dataset: EV_AMPMst12C1ALPI 001005
   ROD: EV_AMPMst12C1ALPI.rod
   VCID: 63868A3D6A01AA97B7-8036
15360768 - Component Protection
          U1101 00 [143] - Active
          [Anti-theft protection - component protection active (0xEA6300)]
                    Reset counter: 213
                    Mileage: 104371 km
                    Date: 2022.05.23
                    Time: 23:30:25
   VCID: 3E301B49A123A77FF8-806A
   Coding: 090000
   VCID: 3D321C45AC25BC67E1-8068
   Coding: 900000
   Coding: 900000
   Part No SW: 5NA 035 020 D    HW: 5NA 035 020
   Component: MU-H-ND-EU    H54 1367
   Serial number: A845L0HS026817
   Coding: 027310010000000021111202C08808001F01063401200400DE
   Shop #: WSC 41005 005 104857
   ASAM Dataset: EV_MUHig4CGen2AW7 001081
   ROD: EV_MUHig4CGen2AW7_VW37.rod
   VCID: 32283F79657B731F0C-8066
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H50 9130
   Serial number: VWZ6ZJT3505229
   Subsystem 2 - Part No SW: V03 959 809 PA    HW: -----------
   Component: ECE 2022  --- 0195
   Component: Gracenote2  --- 1016
          U1014 00 [009] - -
                    Reset counter: 213
                    Mileage: 104371 km
                    Date: 2022.05.23
                    Time: 23:30:29
                    Voltage terminal 30: 13.7 V
7170 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [A/C system (0x02) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 213
                    Mileage: 104371 km
                    Date: 2022.05.23
                    Time: 23:30:30
                    BAP-BAP_Function_ID: 02
7179 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Rear-view camera (0x0B) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 213
                    Mileage: 104371 km
                    Date: 2022.05.23
                    Time: 23:30:30
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H05 0060
   Coding: 0101020001020308000301010100000101
End----------(Elapsed Time: 01:25, VBatt start/end: 13.7V/13.7V)-----------
[CODE/]
@sers77 : Hi.
Hmm....... interesting - clearly not only does the CAN gateway believe that a hex47 module is installed - it has also read the actual details of a (apparently) physical module - together with requisite CP errors on both modules!
Are you saying that there is no physical hex 47 module on this car? How were the CP matters handled for the MIB/Gateway retrofits?
The "no sound" is understandable because the car believes that sound system is connected via a hex47 module, rather than directly through the MIB. This is confirmed by the status of the hex5F software switches on Byte 11 - which indicate an external sound-system via MOST is active (and yes, the MOST software switch is also set on Byte 19)
  • Agree
If there's no physically separate 47-Sound System ("amplifier") module in this car, then it is in-built in another module that he's added, because as you said, it definitely exists, and it even talks to VCDS. :)
Is it possible that it's part & parcel of the 5F module he's swapped in? I'm not familiar enough with these MIB units and all their variants to say...
@Uwe: I like the way that you think - excellent hypothesis!!
I'm not entirely sure either - but the auto-scan HERE (which has the same hex5F module installed) suggests not!!
@sers77 Module
Comparison module:
   Serial number: A845I0HS016595
   Coding: 02730201FF00000051110101008808001F0107F401200400DE
   Shop #: WSC 00046 123 12345
   VCID: 326B27E465ACF414C4-8066
It's not 100% the same. Different ASAM Dataset. Don't ask me why. Presumably a different parameter set?
¯\_(ツ)_/¯
kamold
Australia
C?ID=241363
MIB is configured for an amplifier on the MOST bus. So it shows up as a missing device.
Need to change coding in byte 4 (speaker config) byte 11 (amp config) and also in adaptations (digital sound system and also amplifier).
As it's coded for this the sound parameters will also be setup for an amp so running the speakers directly will result in very poor sound (clipped volume, lack of bass etc).
downtime
Finland
C?ID=280813
And to make things worse for the OP, the AMP probably needs to be swapped as well. Looks like the amp is for MIB1 unit and OP has retrofitted MIB2. MIB2 has different amp on it.
I think correct one would be :
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Component: MIB2_lite_amp
