- May 23, 2021
- 8
- 3
- Tirana, Albania
- C?ID=434806
hi everyone iam a workshop working on this Audi a8 3.0 tfsi the car is not working properly.I have clean and changet the the throttle body of supercharger J808.soon as start the car works good after 1 min came start to shake and on the
dashboard appears epc mil.after I scan the car they jump those 3 codes.
Saturday,12,February,2022,11:51:33:22866
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
VIN: WAUAGAFD9DN004005 License Plate: JOAN 1
Mileage: 132897km-82578mi Repair Order:
Chassis Type: FD-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 19 34 36 3B 3C 42 46 47
52 53 55 56 5F 62 6C 6D 6F 72 81 85 88 89 8B 8E 8F 90
VIN: WAUAGAFD9DN004005 Mileage: 132897km-82578miles
3B-Sensor Elect. -- Status: Malfunction 0010
88-Multicont. Seat Driver -- Status: Malfunction 0010
89-Multicont. Seat Pass. -- Status: Malfunction 0010
Address 01: Engine (J623-CTUB) Labels:. 06E-907-551-CGW.clb
Part No SW: 4H0 907 551 G HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0002
Revision: --H07--- CVN: 9C654557
Coding: 0A2A0032056E01060000
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ECM30TFS0214H0907551G 001003
ROD: EV_ECM30TFS0214H0907551G.rod
VCID: 2E0504F47092D05B05D-807A
VINID: 9D19515D159425478000400014EB6409A5
6557 - Sensor Reference Voltage B
P0653 00 [167] - Voltage too High
Mileage: 132897 km
Date: 2022.02.12
Time: 12:46:48
Engine RPM: 648.00 /min
Normed load value: 16.9 %
Coolant temperature: 71 °C
Intake air temperature: 33 °C
Voltage terminal 30: 12.390 V
Engine speed: actual: 640 /min
MAF_ENVD: 152.51764 mg/stroke
Coolant temperature (unfiltered): 71.25 °C
Engine: operating status: IS
Battery voltage: 12.492188 V
Vehicle speed: actual: 0 km/h
9831 - Intake Air Regulating Flap
P10A4 00 [167] - Mechanical Malfunction
Mileage: 132897 km
Date: 2022.02.12
Time: 12:47:46
Engine RPM: 605.00 /min
Normed load value: 29.4 %
Coolant temperature: 74 °C
Intake air temperature: 31 °C
Voltage terminal 30: 12.999 V
Engine speed: actual: 608 /min
PDT_ENVD: 928.66211 hPa
RFP_SP_ENVD: 76.8898
RFP_AV_ENVD: 0.0000
VP_RFP_1_ENVD: 0.07813 V
RFPPWM_ENVD: 0.00000 %
7806 - Intake Air Regulating Flap
Mileage: 132897 km
Date: 2022.02.12
Time: 12:47:46
Engine RPM: 513.00 /min
Normed load value: 43.5 %
Voltage terminal 30: 12.085 V
Engine speed: actual: 480 /min
PDT_ENVD: 764.15625 hPa
RFP_SP_ENVD: 67.7953
RFP_AV_ENVD: 89.2913
VP_RFP_1_ENVD: 4.78516 V
RFPPWM_ENVD: 7.81250 %
Readiness: 1110 1100
Part No SW: 4H1 927 158 AR HW: 0BK 927 156 AG
Component: 0BK 30TFSIUSA H16 1005
Revision: --H16--- CVN: 33721114
Coding: 000002
ASAM Dataset: EV_TCMALX51011 002018
VCID: 00598A4C9A86962BA71-8054
12446 - Valve for Transmission Fluid Cooler
P2753 00 [039] - Open Circuit
Mileage: 132897 km
Date: 2022.02.12
Time: 12:46:50
Voltage terminal 30: 12.355 V
Voltage supply of regulator valves: 12.306 V
Current N215 Pressure control valve 1: 850.0 mA
Current N218 pressure reg.valve 4: 50.0 mA
Current N216 pressure reg.valve 2: 315.5 mA
Current N233 pressure reg.valve 5: 50.0 mA
Current N217 pressure reg.valve 3: 850.0 mA
Current N371 pressure reg. valve 6 lock-up clutch: 50.0 mA
Current N443 pressure reg.valve 7 main pressure: 703.2 mA
Current solenoid: 0.0 mA
Engine RPM: 710 /min
ATF temperature: 56 °C
Control Module temperature: 54 °C
selected gear: without traction
M008_Torque Converter Lockup Clutch State-Shift Type / Mode: 0
M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch: Open
M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag: Traction
M015_Time Normal Mode: 16 s
M019_Time Since Reset: 7650 ms
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 E HW: 4H0 907 379 E
Component: ESP PREMIUM H10 0352
Coding: 80E5B30001A7CD00E200
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremi 005013
ROD: EV_ESPPremi_005_AU64.rod
VCID: 3431169C9EBEFA8B739-8060
Part No SW: 4H0 907 064 DD HW: 4H0 907 064 CD
Component: BCM2 2.0 H32 0510
Coding: 0DA72046000000000000
Shop #: WSC 39220 001 1048576
VCID: 6E85C4F4B092905B45D-803A
Serial number: 2312000078419015
03286 - Sensor for Contact with Door Handle; Front Right
Fault Frequency: 42
Reset counter: 235
Mileage: 132711 km
Date: 2022.01.29
Time: 09:46:44
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-BFS H08 0153
Revision: AA000000 Serial number: 00000030391669
Coding: 0018320000047201000001010101112131313333282020
Shop #: WSC 02313 785 00200
VCID: 3431169C9E3EFA8B739-8060
Address 08: Auto HVAC (J255) Labels:| 4H0-820-043.clb
Part No SW: 4H0 820 043 G HW: 4H0 820 043 G
Component: Klima 2 Zonen H20 0120
Coding: 6601202E7C
ASAM Dataset: EV_AirCondiFront 001050
ROD: EV_AirCondiFront_001_AU64.rod
VCID: 2411E6DC2E5E6A0BE39-8070
0137 - Motor for Right Side Window Defrost Flap
B10D8 22 [009] - Signal Amplitude Too High
Fault Frequency: 48
Reset counter: 195
Mileage: 132706 km
Date: 2022.01.29
Time: 09:35:55
0148 - Motor for Rear Left Upper Body Vent
B10D3 31 [009] - No Signal
Reset counter: 185
Mileage: 132706 km
Date: 2022.01.29
Time: 09:35:55
0156 - Motor for Rear Right Upper Body Vent
B10D4 31 [009] - No Signal
Reset counter: 185
Mileage: 132706 km
Date: 2022.01.29
Time: 09:35:55
0164 - Motor for Left B-Pillar / Footwell Shut-Off Flap
B10D1 31 [009] - No Signal
Reset counter: 185
Mileage: 132706 km
Date: 2022.01.29
Time: 09:35:55
0172 - Motor for Right B-Pillar / Footwell Shut-Off Flap
B10D2 31 [009] - No Signal
Reset counter: 185
Mileage: 132706 km
Date: 2022.01.29
Time: 09:35:55
0378 - Coolant Circulation Pump
B10D0 04 [009] - Internal System Fault
Reset counter: 192
Mileage: 132706 km
Date: 2022.01.29
Time: 09:40:09
Part No SW: 4H0 907 063 CD HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0130
Revision: 15012002 Serial number: 00000001341269
Coding: 02002091163C9FE3CB008807A0003908009CD30886000121800008406000
VCID: 6C81CEFC868E624B6B9-8038
Subsystem 1 - Part No SW: 4H1 955 119 C HW: 4H1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS641 120305 H35 0080
Serial number: 120504123741
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 C HW: 8K0 955 559 C Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10258172
Coding: 025523
Subsystem 3 - Part No SW: 4H0 941 531 D HW: 4H0 941 531 D
Component: E1 - LDS H07 0044
Serial number: 18 05 2012 00000330
Component: USHL4.2 H30 0030
Serial number: 0000002274555R1WQ202
Subsystem 5 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA102896000001215895
Coding: 020300
Subsystem 6 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 69080F26000000000001
00003 - Control Module
Fault Status: 00111110
Mileage: 17638 km
Date: 2014.07.19
Time: 21:09:00
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AG HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0072
Revision: 11001001 Serial number: 61061214800289
Coding: A80B02
ASAM Dataset: EV_EPHVA18AU57X0000 003008
ROD: EV_EPHVA18AU57X0000_003.rod
VCID: 77ABE190CF48D19396B-8022
Part No SW: 4H0 907 561 B HW: 4H0 907 561
Component: ACC3 H17 0400
Coding: 7E01010201
ASAM Dataset: EV_AdaptCruisContrAU64X 002021
ROD: EV_AdaptCruisContrAU64X_002.rod
VCID: 2A0D08E44C7ABC7BD95-807E
82688 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[FAULT_CIS_TSK_FAIL]
Fault Frequency: 39
Reset counter: 195
Mileage: 132887 km
Date: 2022.02.06
Time: 12:44:19
Control Module temperature: 21 °C
Voltage terminal 15: 14.434 V
93440 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[FAULT_CIS_VIDEO_FAIL]
Fault Frequency: 84
Reset counter: 195
Mileage: 132706 km
Date: 2022.01.29
Time: 09:35:55
Control Module temperature: 10 °C
Voltage terminal 15: 11.645 V
Part No SW: 4H0 959 655 D HW: 4H0 959 655 D
Component: Airbag10.43 H44 0041
Revision: -------- Serial number: 003JS001AE9+
Coding: 303143303230303030314A55304C34483053
VCID: 372B21908FC8119356B-8062
Subsystem 1 - Part No SW: 4H0 959 339 A HW: 4H0 959 339 A
Component: BF-Gewichtss. H03 0040
Serial number: 5850000R1251003NWF
Serial number: 3575HRB405J1D5MS80OW
Serial number: 3585HRB405F0IDFS7GVD
Serial number: 3515JRB405F197FGI10X
Serial number: 3525JRB405B197FGBGTO
Serial number: 3554VRB40184UEIMD1E0
Serial number: 3564VRB400A4UH26H1JP
7 Faults Found:
9442587 - Igniter for battery interrupt
B1015 1B [137] - Resistance Too High
Mileage: 132706 km
Date: 2022.01.29
Time: 09:36:01
B1006 1B [137] - Resistance Too High
Mileage: 132706 km
Date: 2022.01.29
Time: 09:36:01
9441819 - Safety belt tensioner igniter; rear; center
B1012 1B [137] - Resistance Too High
Mileage: 132706 km
Date: 2022.01.29
Time: 09:36:01
9439515 - Seat Belt Tensioner Igniter; rear; driver's side
B1009 1B [137] - Resistance Too High
Mileage: 132706 km
Date: 2022.01.29
Time: 09:36:01
9439259 - Igniter for Seat Belt Tensioner; Rear Passenger's Side
B1008 1B [137] - Resistance Too High
Mileage: 132706 km
Date: 2022.01.29
Time: 09:36:01
9438235 - Igniter for Front passenger's Head Curtain Airbag
B1004 1B [137] - Resistance Too High
Mileage: 132706 km
Date: 2022.01.29
Time: 09:36:01
9441307 - Rear; passenger's side; side-airbag igniter
B1010 1B [137] - Resistance Too High
Mileage: 132706 km
Date: 2022.01.29
Time: 09:36:01
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Revision: -------- Serial number: 90372NFI000FG
Coding: 0000BC
Shop #: WSC 39104 001 1048576
VCID: 382922AC82561EEB5F1-806C
Subsystem 1 - Part No SW: 4H0 951 528 L HW: 4H0 951 528 L
Component: E221 - MFL H09 0009
Serial number: 05 04 2012 B1046168
Part No SW: 4H0 920 980 K HW: 4H0 920 980 K
Component: TBenUSAACC--- H71 0515
Revision: 35081077 Serial number: 658220512592016
Coding: 0B4708015F408805020000
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K_AU64.rod (VIN: N/A)
VCID: 333315809BB0FDB36A3-8066
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 H HW: 4H0 919 204 H
Component: Analoguhr D4 H05 0224
Serial number: 1120524002354
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4H0 907 468 AB HW: 4H0 907 468 AA
Component: J533--Gateway H10 0028
Revision: -------- Serial number: 00000000539489
Coding: 00CD075200
GVL: FFAFE80CFEE3E0CCC000
ASAM Dataset: EV_GatewPkoUDS 001013
ROD: EV_GatewPkoUDS_001_AU57.rod (VIN: N/A)
VCID: 71BFDF88A12C8FA358F-8024
Subsystem 1 - Part No SW: 4H0 915 181 F HW: 4H0 915 181 F
Component: J367-BDM H08 0181
Serial number: 00000000004970278590
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 C HW: 8K0 959 663 C
Serial number: 12137000713011200410
U140B 00 [009] - -
[Powermanagement active]
Reset counter: 234
Mileage: 132897 km
Date: 2022.02.11
Time: 12:18:25
Voltage terminal 30: 10.1 V
Voltage terminal 15: 10.1 V
Control Module temperature: 20 °C
System status: Terminal 15 on
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status: On
Datenfeld: 1
Part No SW: 4H0 907 553 E HW: 4H0 907 553
Component: LUFE-DAEMPFER H17 0099
Coding: 008002
ASAM Dataset: EV_AirSuspe 003024
ROD: EV_AirSuspe_VW51.rod
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00000030391696
Coding: 00183B0000057201000001010101112131313333202020
03327 - Switch for Headrest Adjustment: Down
Fault Status: 00100011
Reset counter: 235
Mileage: 132897 km
Date: 2022.02.12
Time: 12:44:15
Part No SW: 4H0 907 637 K HW: 4H0 907 637 F
Component: SARA 6D H02 0053
Revision: -------- Serial number: EJ1BPA77000RC4
ASAM Dataset: EV_SARA2 005011
ROD: EV_SARA2.rod
1048848 - Internal Voltage Measurement
U1408 00 [008] - Implausible Signal
[Undervoltage at internal 5 Volt supply.]
Reset counter: 234
DCU_Internal_DTC: 10 01 10
Ignition Cycle Count: 62947
DCU Temperature: -32768 °C
Voltage terminal 30: 0.0 V
Voltage VBG 22: 0.0 V
Debug Data: 00 00 00 00 00 00 00 00
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4H0 907 566 A HW: 4G0 907 566
Component: J769 SWA MasterH02 0040
Revision: 00H02000 Serial number: 6PZ 010 287-07
Coding: 0000001
VCID: 2E0504F47C12D05B05D-807A
Subsystem 1 - Part No: 4H0 907 568 A
Component: J770 SWA Slave H02 0040
Subsystem 2 - Serial number: 6PZ 010 287-27
Subsystem 3 - Serial number: 5F01.06.1200H020003CX25489ÿ
Subsystem 4 - Serial number: X25489ÿ
Part No SW: 4H0 959 793 R HW: 4H0 959 793 G
Component: TSG FA H06 0263
Revision: -------- Serial number: 0000127856265
Coding: 011F1F005E00628202003013
VCID: 48C9526CF2B66E6B2F1-801C
Revision: 00002001 Serial number: 0177595819
Coding: 0106023A00FA7585B0B0C7C40203010F0000000000000000000000000000
Subsystem 1 - Part No SW: 4H0 959 719 HW: 4H0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000086649
Subsystem 3 - Part No SW: 4H0 959 591 HW: 4H0 959 591
Component: J245 PS50.030 H07 0006
Serial number: WOO16504583
Coding: 101F00
Subsystem 4 - Part No SW: 4H0 947 135 BK HW: 4H0 947 135 BK
Component: Dachelektroni H11 0080
Serial number: A2012000000000576474
Subsystem 5 - Part No SW: 4H0 959 591 A HW: 4H0 959 591 A
Component: V252 PS010 H05 0005
Serial number: WOO1000PF0F
Subsystem 6 - Part No SW: 3AA 962 243 HW: 3AA 962 243
Component: GEB.F.Heckoef H12 0719
Serial number: 84261238
014 - Defective
Fault Status: 01101110
Reset counter: 185
Mileage: 132706 km
Date: 2022.01.29
Time: 09:35:56
03634 - Switch for Window Shade Illumination; Front
Fault Status: 00101100
Reset counter: 234
Mileage: 132897 km
Date: 2022.02.11
Time: 18:07:38
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000058941
Coding: 030000
VCID: 1D67D3380DB45BC3AC7-8048
00871 - Bass Speaker Front Right (R23)
Fault Status: 00111011
Reset counter: 235
Part No SW: 4H0 959 792 G HW: 4H0 959 792 G
Component: TSG BF H06 0261
Revision: -------- Serial number: 0000122703961
Coding: 011F1F005E00628202003003
Shop #: WSC 44280 758 45725
VCID: 3C213EBCB66E32CBBB9-8068
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: EPB-4 H03 0013
Revision: -------- Serial number: 00000000369205
ROD: EV_ParkiBrake_VW51.rod
VCID: 2B030DE04380A573223-807E
Address 55: Headlight Range (J431) Labels:| 4H4-907-357-V1.clb
Part No SW: 4H4 907 357 C HW: 4H4 907 357 A
Component: ....AFS13.... H01 0020
Serial number: 120530-0004-027
Coding: 12116F33701AA500
ASAM Dataset: EV_AdvanFrontSyste 005001
ROD: EV_AdvanFrontSyste_AU21.rod
VCID: 323D108464AAF4BB615-8066
H02 0009
Coding: 1C0000
H02 0009
Coding: 1C0000
Part No SW: 4H0 035 082 D HW: 4H0 035 082
Component: Radio U SIRIU H60 0112
Revision: AB001007 Serial number: 155EW0C7520428
Coding: 020007010000000001
VCID: 221DE0C434CA643B915-8076
Part No SW: 4H0 035 746 C HW: 4H0 035 746 C
Component: H-BNT-NA H49 0549
Revision: -------- Serial number: 183FQ0C7501160
Coding: 020200000001F9EF7D128B1E00000003140001000000000000
VCID: 2809F2EC52F68E6BCF1-807C
Subsystem 1 - Part No: 8R0 060 884 AM
Component: NAR 2012 0605
Subsystem 2 - Part No SW: 4H0 919 604 F HW: 4H0 919 604 F
Component: DU8 D4 SV NB H47 0021
Serial number: AUZ8ZDC9300K7JT
Subsystem 3 - Part No SW: 4H1 919 600 H HW: 4H1 919 600
Component: E380 BDT D4 H09 0065
Serial number: 00000000082442
Subsystem 4 - Part No: 8R0 060 961 D
Component: CD-Database 4353
02168 - Left Front Microphone (R140)
Fault Frequency: 17
Reset counter: 194
Mileage: 132706 km
Date: 2022.01.29
Time: 09:35:57
Voltage: 11.20 V
03787 - Rotation Mechanism for Display Module Front
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 192
Mileage: 132881 km
Date: 2022.02.03
Time: 11:33:35
Voltage: 12.80 V
Fault Status: 01100011
Reset counter: 192
Mileage: 132706 km
Date: 2022.01.29
Time: 09:35:55
Voltage: 11.30 V
Part No SW: 4H0 959 795 D HW: 4H0 959 795 D
Component: TSG HL H06 0262
Revision: -------- Serial number: 0000128180689
Coding: 010F1F004000628202003003
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4H0 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H06--- Serial number: 525 PA8J25D05U
Coding: 1080002
VCID: 2615FCD454E2981BFDD-8072
Address 6D: Trunk Elect. (----) Labels:* None
Part No SW: 4H0 959 107 R HW: 4H0 959 107 M
Component: HDSG-Modul H11 0039
Revision: 10011001 Serial number: 139200964
Coding: 0210044100
ASAM Dataset: EV_DeckLidContrUnit 001025
ROD: EV_DeckLidContrUnit.rod
VCID: 3D2733B8ADF43BC38C7-8068
Address 6F: Centr. Conv. II (J773) Labels:* None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial number: 000000075192
Coding: 200000
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: 6393A5C06BD02D33DA3-8036
Component: TSG HR H06 0262
Revision: -------- Serial number: 0000128180686
Address 81: Gear Shift (J587) Labels: 3Y0-927-731.clb
Part No SW: 4H1 927 731 A HW: 4H1 927 731 A
Component: GSM-LL H08 0083
Revision: 0L0D5013 Serial number: SN120407 0171
ROD: EV_GSM2x3Mono_AU64.rod
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H25 0038
Coding: E9060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 2615FCD45862981BFDD-8072
Address 88: Multicont. Seat Driver (J873) Labels:* None
Part No SW: 4H0 907 182 G HW: 4H0 907 182 G
Component: IVB H08 0042
Serial number: 00006526194302
Coding: 602FF2
ROD: EV_IVBDriveSideFrnt.rod
0004 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Reset counter: 234
Address 89: Multicont. Seat Pass. (J872) Labels:* None
Serial number: 00006526194201
Coding: 202FF2
U1400 00 [008] - -
Reset counter: 234
Part No SW: 4H0 907 541 B HW: 4H0 907 541
Coding: 7E01010201
ASAM Dataset: EV_AdaptCruisContr2AU64X 002018
ROD: EV_AdaptCruisContr2AU64X_002.rod
VCID: 2809F2EC52768E6BCF1-807C
U1113 00 [009] - -
Fault Frequency: 39
Reset counter: 195
Mileage: 132887 km
Date: 2022.02.06
Time: 12:44:19
Voltage terminal 15: 14.487 V
Velocity_vehicle_reference: -0.00 m/s
Part No SW: 4G0 907 107 D HW: 4H0 907 107
Component: BV-SG H30 0038
Serial number: 005000053005127
Coding: 01A19A000111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
VCID: 270BF1D05F688113C6B-8072
0161 - Video Cable for Image Processing
C1107 02 [009] - Signal Failure
[No_camera_found_on_startup]
Reset counter: 195
Mileage: 132897 km
Date: 2022.02.12
Time: 11:33:27
Outside temperature: 12.0 °C
Voltage terminal 15: 12.9 V
Control Module temperature: 13.0 °C
Part No SW: 4H0 980 945 B HW: 4H0 980 945 B
Component: RGS-VL H13 0080
Coding: 0066F609031F037E070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 313F1F8861ACCFA318F-8064
Part No SW: 4H0 980 946 B HW: 4H0 980 946 B
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
End----------(Elapsed Time: 03:13, VBatt start/end: 13.6V/13.5V)-----------
