Bentley GT. High level stop lamp - disable instrument warning light.
Bentley
South Wales, UK
C?ID=263294
Hi, I've got a GT in where the HLSL brings on a warning for the first 10 - 20 mins of some journeys. Usually on cold days. The light works but I suspect the cable tape that goes through the screen seal may be failing.
Of course it wouldn't do it while it was in the workshop with me!
Just wondering if it is possible to turn off / code out the dash warning light? Thanks in Advance.
Thursday,11,November,2021,12:58:17:45172
VCDS Version: 21.3.0.0 (x64)  HEX-NET CB: 0.4543.4
Dealer/Shop Name: CMC
VIN: SCBDE23W27C046598   License Plate: ASH FIRST
Mileage: 63410km-39401mi   Repair Order:
Chassis Type: 3W (3W - Bentley Continental (2004 > 2007))
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 26 28 34 36
          37 38 46 47 53 54 57 65 66 68 69 6C 71 75 76 77
VIN: SCBDE23W27C046598   Mileage: 63410km-39401miles
Address 01: Engine        Labels: 07C-906-018-BWR1.clb
   Part No SW: 07C 906 018 EM    HW: 07C 906 018 EC
   Component: BY-6.0L-TT      G  ª0595
   Revision: --H01---    Serial number: VWZ3Z0F3548339
   Coding: 0011175
   Shop #: WSC 00083 790 00000
   VCID: F4A47DD0960BDB2B57-5160
006436 - Controller Pin Coding
               P1924 - 008 - Implausible Signal - Intermittent
                    Temperature: 30.0°C
                    Temperature: 23.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 11.684 V
005644 - Coolant Pump 2
               P160C - 004 - Open circuit - Intermittent
                    Mileage: 62768 km
                    RPM: 1285 /min
                    Load: 24.7 %
                    Speed: 255.0 km/h
                    Temperature: 18.0°C
                    Temperature: 18.0°C
                    Voltage: 11.684 V
001152 - Coolant Fan Control Circuit 1
               P0480 - 004 - Electrical Malfunction - Intermittent
                    Mileage: 62768 km
                    RPM: 1458 /min
                    Load: 28.6 %
                    Speed: 148.0 km/h
                    Temperature: 21.0°C
                    Temperature: 21.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 11.811 V
001153 - Coolant Fan Control Circuit 2
               P0481 - 004 - Electrical Malfunction - Intermittent
                    Mileage: 62768 km
                    RPM: 1458 /min
                    Load: 28.6 %
                    Speed: 148.0 km/h
                    Temperature: 21.0°C
                    Temperature: 21.0°C
                    Voltage: 11.811 V
006435 - Please Check DTC Memory of ECU Number 2
               P1923 - 008 -
                    Fault Status: 01101000
                    Mileage: 63414 km
                    Temperature: 78.0°C
                    Temperature: 68.0°C
                    Voltage: 11.176 V
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 09E 927 760 AA    HW: GS1 911 4
   Component: AG6 09E 6.0L W12TT  2811
   Revision: 00000001    Serial number:        0099399
   Coding: 0000111
   VCID: EFAE72BCFF2DF8F3AA-5160
Address 03: ABS Brakes        Labels: 3W0-614-517-V1.lbl
   Part No: 3W0 614 517 F
   Component: ESP 5.7 4WD     H01 0047
   Coding: 0007878
   Shop #: WSC 60751 000 00000
   VCID: B83C89E0CAE37F4BBB-51CE
   Part No SW: 3D0 909 137 D    HW: 5WK 485 05
   Component: 71 Kessy            6840
   Revision: 68406418    Serial number: VWZ3Z0F3548339
   Coding: 0422125
   VCID: A81C59A01A43EFCB2B-5160
Address 07: Control Head        Labels: 3D0-035-00x-07.lbl
   Part No: 3W0 035 007 K
   Component:    ZAB COCKPIT      2142
   Coding: 0400325
   VCID: B424BDD0D68B9B2B97-5160
Address 08: Auto HVAC        Labels: 3W7-907-040.clb
   Part No: 3W7 907 040
   Component: Climatronic BY615   2026
   Coding: 0000111
   VCID: F5A240D49D71C22360-5160
Address 09: Cent. Elect.        Labels: 3D0-937-049-V1.clb
   Part No: 3D0 937 049 H
   Component: STG.Bordnetz        5101
   Coding: 0000107
   VCID: AF2EB2BC3FADB8F3EA-5160
Address 11: Engine II        Labels: 07C-906-018-BWR2.clb
   Coding: 0011175
001672 - ECM Power Relay Load Circuit
               P0688 - 002 - Open Circuit - Intermittent
                    Mileage: 62805 km
                    Temperature: 93.0°C
                    Temperature: 24.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 0.127 V
Address 15: Airbags        Labels: 3W7-909-601.clb
   Part No SW: 3W7 909 601     HW: 3W7 909 601
   Component: 07 Airbag 9.42  H09 0050
   Revision: 92H09005    Serial number: 003880002TRY
   Coding: 0012343
   VCID: FAB853E8B46FAD5B0D-5160
   Subsystem 1 - Serial number: 63328RB401D4056FM
   Subsystem 2 - Serial number: 63428RB401D404AFQ
   Subsystem 3 - Serial number: 63700RB4        I
   Subsystem 4 - Serial number: 63800RB4        J
                    Fault Frequency: 127
                    Reset counter: 39
Address 16: Steering wheel        Labels: 3D0-953-549.lbl
   Part No: 3D0 953 549 E
   Coding: 0000212
Address 17: Instruments        Labels: 3Wx-920-xxx-17.lbl
   Part No: 3W7 920 840
   Component: KOMBIINSTRUMENT RB8 0610
   Coding: 0021403
   VCID: F8BC49E08A63BF4B7B-5160
16 Faults Found:
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
00477 - Control Module; Display & Input; Comfort CAN; Front (J523)
00830 - Convertible Top Control Module (J256)
00459 - Control Module for Display and Input; Front (J523)
   Part No: 6N0 909 901
   Coding: 0000006
   VCID: F0AC71C0E213E70BB3-5160
24 Faults Found:
00461 - Control Module for Seat Memory; Passenger (J521)
00908 - Control Module for Wiper Motor
01308 - Control Module for Roof Electronics (J528)
01327 - Control Module for Parking Aid (J446)
01335 - Drivers Seat/Mirror Position Control Module (J543)
02174 - Analog/Digital clock
Address 26: Auto Roof        Labels: 3W7-959-255.clb
   Part No: 3W7 959 255
   Component:  VSG  BY615         0509
   Revision: 00005000    Serial number: 00000007500200
   Shop #: WSC 00159 106 183163
   VCID: 84442D10C6ABEBAB67-5160
Address 34: Level Control        Labels: 3Wx-907-553-34.clb
   Part No: 3W7 907 553
   Component: LUFTFDR.-CDC- 3C3V0 7405
   Coding: 0005581
   Shop #: WSC 53587 000 1048576
   VCID: FEB05FF8A847817B31-5160
Address 36: Seat Mem. Drvr        Labels: 3W0-959-759.clb
   Part No: 3W0 959 760 B
   Component:    CM Seat Driver   0017
   Coding: 0000002
   Shop #: WSC 21471 002 1048576
   VCID: C0CCE1009233378B03-5160
01174 - Driver Seat Height Adjustment Motor (V138)
01903 - Seat Tilt Adjustment Motor (V231)
Address 37: Navigation        Labels: None
   Part No: 3W0 919 887 E
   Component:    NAVIGATION       2136
   Coding: 0000000
   VCID: C9DAFC24A109F6C3D4-5160
00003 - Control Module
            014 - Defective
Address 38: Roof Electronics        Labels: None
   Part No: 3W0 907 135 E
   Component: Dachmodul           0707
   Coding: 0001981
   VCID: B83C89E0CAE37F4BBB-5160
Address 46: Central Conv.        Labels: 3D0-959-933.lbl
   Part No: 3D0 959 933 J
   Component: 99 HSG              8125
   Coding: 0000040
   VCID: B73E8ADCC7FD7033B2-4B1E
   Subsystem 1 - Part No: 3W7 959 701 A
   Component: Tuersteuergeraet FS 1103
   Subsystem 2 - Part No: 3W7 959 702 A
   Component: Tuersteuergeraet BF 1103
   Subsystem 3 - Part No: 3W7 959 703
   Component: Tuersteuergeraet HL 0602
   Subsystem 4 - Part No: 3W7 959 704
   Component: Tuersteuergeraet HR 0602
   Subsystem 5 - Part No: 3W0 909 610 H
   Component: 15 HDSG             2013
   Subsystem 6 - Part No: 7L0 907 719 A
   Component:    Neigungssensor   000
01699 - Motor for Central Locking; Hatch/Trunk (V53)
   Part No: 3W7 035 456 A
   Component: 12K-AUDIOVERST      5001
   VCID: B93A8CE4F1E9664344-5160
Address 65: Tire Pressure        Labels: Redir Fail!
   Part No: 3W7 907 273
   Component: Reifendruckueberw.  0003
   Coding: 0090311
   VCID: FDB258F4A5419A6328-5160
Address 68: Wiper Electr.        Labels: 3Wx-955-023.clb
   Part No: 3W2 955 023 E
   Component: Wische&
   Shop #: WSC 00000 725 65552
7 Faults Found:
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
Address 71: Battery Charger        Labels: 3D0-915-181.lbl
   Part No: 3D0 915 181 D
   Component: Batteriemanagement  2800
   VCID: A4044D90666B0BAB07-5160
Address 75: Telematics        Labels:
   VCID: D5E220542CB1A22340-5286
   Note: Excessive Comm Errors
Address 76: Park Assist        Labels: 3W0-919-283-V1.clb
   Part No: 3W0 919 283 A
   Component: 02 Einparkhilfe     0303
   VCID: BB3696ECFBD5545356-5160
Address 77: Telephone        Labels: 3W7-035-385.lbl
   Part No SW: 3W7 035 385 R    HW: 3W7 035 385 R
   Component: rSAP ECU            0054
   Coding: 0000272
   VCID: CBD6C62CAB75E4D3E6-5160
End----(Elapsed Time: 08:04, VBatt start/end: 13.7V/13.7V. VIgn 0.0V)------
Address 01: DTCs cleared
Address 02: DTCs cleared
Address 03: DTCs cleared
Address 05: DTCs cleared
Address 06: DTCs cleared
Address 07: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 11: DTCs cleared
Address 15: DTCs cleared
Address 17: DTCs cleared
Address 19: DTCs cleared
Address 26: DTCs cleared
Address 34: DTCs cleared
Address 36: DTCs cleared
Address 37: DTCs cleared
Address 38: DTCs cleared
Address 46: DTCs cleared
Address 47: DTCs cleared
Address 65: DTCs cleared
Address 68: DTCs cleared
Address 71: DTCs cleared
Address 77: DTCs cleared
   Coding: 0011175
               P1923 - 008 -
                    Mileage: 63418 km
                    RPM: 558 /min
                    Load: 23.1 %
                    Temperature: 96.0°C
                    Temperature: 51.0°C
                    Voltage: 13.208 V
Readiness: 0110 1101
   Coding: 0000111
   Coding: 0007878
   Coding: 0422125
Address 06: Seat Mem. Pass        Labels: 3W0-959-759.clb
   Part No: 3W0 959 759 A
   Component:    CM Seat Pass.    0009
   Coding: 0000002
   VCID: C7DEFA1CB71D00B3C2-5160
   Coding: 0400325
   Coding: 0000111
   Coding: 0000107
   Coding: 0011175
   Coding: 0012343
   Coding: 0021403
   Coding: 0000006
   Coding: 0005581
   Coding: 0000002
   Coding: 0000000
   Coding: 0001981
   Coding: 0000040
   Coding: 0090311
   Component: Wischermodul       ª9326
   VCID: D5E829082C0AD1E30C5-5286
   Coding: 0000272
End----(Elapsed Time: 09:43, VBatt start/end: 13.5V/12.0V. VIgn 0.0V)------
Address 36,3W0 959 760 B,channel 0,adapted from,---,to,000,
Control Module Part Number: 3W0 959 760 B
  Component and/or Version:    CM Seat Driver   0017
           Software Coding: 0000002
            Work Shop Code: WSC 21471 002 1048576
Curious that there is no fault code for it anywhere?
I don't see an obvious way to code it out.
Bentley
South Wales, UK
C?ID=263294
Thank you Uwe,
It may not be obvious, but that scan shows why you shouldn't go posting last thing at night.
doh. The owner has a GTC and another GT (with the HLSL fault). I've posted the wrong one!
I'll get one off the correct car. 🙈
