VCDS support for Skoda Fabia III
pab567
Poland
C?ID=233680
I will post here tweaks I made for Skoda Fabia III.
CORNERING LIGHTS VIA FOG LIGHTS
Module 09, Security Code, enter 31347, then Adaptations and change channels:
(5)-Leuchte12NL LB40-Light_Function_B_12 from not active to Abbiegelicht links
(5)-Leuchte13NL RB3-Light_Function_B_13 from not active to Abbiegelicht rechts
CHANGING COMING HOME / LEAVING HOME FROM LOW BEAM TO FOG LIGHTS
(4)-Comfort illumination-Coming Home Leuchten from Low beam to Fog light
(5)-Leuchte6ABL LB44-Light_Function_B_6 from ComingHome LeavingHome to not active
(5)-Leuchte7ABL RB5-Light_Function_B_7 from ComingHome LeavingHome to not active
ENABLING NEW "DRIVE GREEN" MENU IN BOLERO INFOTAINMANET UNIT
Module 5F, Adaptations, change channel:
(186)-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating
change from not activated to activated
ENABLING NEEDLE STAGING
Module 17, Long coding, change byte 1 bit 0 from 0 to 1
ENABLING REFUEL VOLUME IN MAXI-DOT
Module 17, Long coding, change byte 10 bit 4 from 0 to 1
razze76
Finland
C?ID=103741
I have a strange problem with my Fabia: I replaced the reverse lights with high-power LEDs and now I get a check light warning. I have learned that I should be able to set the load for each bulb individually, and also that the reverse lights should be Leuchte28. It is in fact the only one with a mention of "Rueckfahrlicht" in the entire module, but I do not have a channel "(1) Load type" for the Leuchte28 ?? In the latest beta, this channel shows up, but it is "Not activated" or something similar (I can't remember the exact wording), and I am not able to change the value.
Here is a full auto-scan from the car, and the relevant parts from the map scan:
Auto-scan
Wednesday,27,May,2015,22:04:21:63777
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
VIN: TMBEN6NJ3FZ0xxxxx   License Plate: xxx-xxx
Mileage: 3386   Repair Order:
Chassis Type: NJ (6C0)
Scan: 01 03 05 08 09 10 13 15 17 19 2B 44 5F 69
VIN: TMBEN6NJ3FZ025636
Address 01: Engine (J623-CJZD)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 027 BC    HW: 04E 907 309 AF
   Component: 1.2l R4 TSI   H21 8229
   Revision: R4H21---
   Coding: 01190032243415080000
   Shop #: WSC 73430 031 00045
   ASAM Dataset: EV_ECM12TFS01104E906027BC 001006
   ROD: EV_ECM12TFS_VW26.rod
   VCID: 66C8BB60999EEC11F43-8033
   Part No SW: 6C0 907 379 G    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0003
   Serial number: 08508261150116
   Coding: 41F5487D492533C5091A106C0057821292CC9008000DCBF98F00
   Shop #: WSC 13765 031 00045
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
   ROD: EV_Brake1ESP90iBOSCHPQ26_SE26.rod
   VCID: 336E12349ACC49B9A3D-8066
   Revision: 00021000    Serial number: 0358182678
   Coding: 030C0C
   Shop #: WSC 13765 790 00045
   ROD: EV_KessyHellaMQBAB_SK26.rod
   VCID: 3A703F10BDA6B8F160B-806F
   Part No SW: 6V0 907 044     HW: 6V0 907 044
   Component: Climatronic   H01 0105
   Serial number:  1501201A-0253
   Coding: 100000001011100001
   ASAM Dataset: EV_ACClimaValeoPQ26 003001
   ROD: EV_ACClimaValeoPQ26.rod
   VCID: 74ECD128DF420E817A7-8021
329476 - Motor for Fresh Air / Recirculated Air Flap
          B108B 71 [012] - Actuator stuck
                    Reset counter: 33
                    Mileage: 11 km
                    Date: 2015.03.03
                    Time: 09:13:44
1179905 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 8
                    Mileage: 3032 km
                    Date: 2015.05.13
                    Time: 20:14:50
   Part No SW: 6C0 937 090 B    HW: 6C0 937 090
   Component: BCM PQ26 HiKR H07 0065
   Serial number: 001108006926
   Coding: 0C03085042150AFB43804000402F07080800D900D30A3500000000000000
   Shop #: WSC 73430 790 00045
   ASAM Dataset: EV_BCMA0 004008
   ROD: EV_BCMA0_SK26.rod
   VCID: 2756F6645E1435190F5-8072
   Slave 2:
   Subsystem 1 - Part No SW: 5Q0 955 547 A    HW: 5Q0 955 547 A
   Component: RLHS  037 0059
   Serial number: S5Y15M01D28H17M24S34
   Coding: 00185E
   Subsystem 2 - Part No SW: 6V1 959 801 B    HW: 6V1 959 801 B
   Component: FHSG DRV  007 0001
   Serial number: 00000000000000733403
   Coding: 011200
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 D    HW: 5Q0 919 283
   Component: PARKHILFE 3K  H10 0048
   Revision: --------    Serial number: 39231502402235
   Coding: 0001050101
   ASAM Dataset: EV_EPHVA14AU3700000 002022
   ROD: EV_EPHVA14AU3700000_AU37.rod
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Serial number: 18121403212312
   Coding: 00000800FE0739
   ROD: EV_ACCMRRBoschVW372_AU37.rod
   VCID: 3874251883AAAAE196F-806D
Address 15: Airbags (J234)       Labels: 6C0-959-655.clb
   Part No SW: 6C0 959 655 F    HW: 6C0 959 655 F
   Component: VW20Airbag023 001 0340
   Revision: --------    Serial number: 003RJ000L0E+
   Coding: 88CCC000000000005C5400CF000800000000
   ROD: EV_AirbaVW20BPAVW26X_SK26.rod
   VCID: 36682B2089BE5C91843-8063
   Subsystem 1 - Part No SW: -----------    HW: 410 822 101 15
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00C116DB7D0D0C/
   Subsystem 2 - Part No SW: -----------    HW: 410 822 101 15
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H00AF18F34B0C2B1
   Subsystem 3 - Part No SW: -----------    HW: 442 152 501 15
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00A7183BFD540DU
   Subsystem 4 - Part No SW: -----------    HW: 442 152 501 15
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00A7183BFD4543P
Address 17: Instruments (J285)       Labels: None
   Part No SW: 6V0 920 740     HW: 6V0 920 740
   Component: KOMBI         214 0290
   Coding: 072401102180000801882A011000000000000000
   ROD: EV_DashBoardVDDMQBAB_SE25.rod
   VCID: 72E0D730A55600B168B-8027
   Part No SW: 6C0 909 901     HW: 6C0 937 090
   Component: GW MQB A0     H07 0065
   Revision: --------    Serial number: 001108006926
   Coding: 030100342F0A640000000000000000010001050000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 001001
   ROD: EV_GatewA0Lear_SK26.rod
   VCID: 65CABC6C6498E709FD9-8030
   Subsystem 1 - Part No SW: 5E0 919 719 A    HW: 5E0 919 719 A
   Component: E221__MFL-PR6  H05 0130
   Serial number: 000000000C0332230115
   Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: 62016I56432821347447
   Revision: 00000000    Serial number: 15000004170002
   Coding: 5500000000000000
   ROD: EV_ELVMarquMQB_SE25.rod
   VCID: 346C11289FC24E81BA7-8061
Address 44: Steering Assist (J792)       Labels: Redir Fail!
   Part No SW: 6C1 909 144 M    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  311 3211
   Serial number: CF1Q0865
   Coding: 0007
   ASAM Dataset: EV_SteerAssisUDSTRW 011021
   ROD: EV_SteerAssisUDSTRW_SK26.rod
   VCID: 3260173065D640B1A8B-8067
   Part No SW: 5Q0 035 819     HW: 5Q0 035 819
   Component: MU-S--ER      H11 0135
   Serial number: SKZAZ2R0010231
   Coding: 03620000BE00000011110004000808002F0100C40120010000
   ASAM Dataset: EV_MUStd4CTSAT 001018
   ROD: EV_MUStd4CTSAT_SK26.rod
   VCID: 70E4DD38AB5A32A19EF-8025
   Media Player Position 1:
   Subsystem 1 - Part No SW: 6V0 919 604     HW: 6V0 919 604
   Component: ABTm_Std2  H40 1022
   Serial number: SKZ8Z9RH30067B
1637 - Interface for External Media
          U11B8 00 [008] - No Communications
                    Fault Frequency: 91
                    Reset counter: 30
                    Mileage: 123 km
                    Date: 2015.03.11
                    Time: 19:53:14
Address 69: Trailer (J345)       Labels: 5Q0-907-383.clb
   Part No SW: 5Q0 907 383 E    HW: 5Q0 907 383 B
   Component: Anhaenger     H14 0137
   Revision: 8C001001    Serial number: 0358097400
   Coding: 0100000202000000
   ROD: EV_TrailFunctGener2Hella.rod
   VCID: 3972201CB8A0B3E9691-806C
End-------------------------(Elapsed Time: 02:58)--------------------------
the map channels for Leuchte28 and Leuchte29:
(19)-Leuchte27 KL58XS C67-Dimming_Direction_GH_27,maximize
(2)-Leuchte28RFL C3-Lampendefektbit_Position_28,2B
(3)-Leuchte28RFL C3-Fehlerort_mittleres_Byte_DTC-DFCC_28,34
(4)-Leuchte28RFL C3-Light_Function_A_28,Rueckfahrlicht
(5)-Leuchte28RFL C3-Light_Function_B_28,not active
(6)-Leuchte28RFL C3-Dimming_AB_28,100
(7)-Leuchte28RFL C3-Light_Control_HD_AB_28,Always
(8)-Leuchte28RFL C3-Light_Function_C_28,not active
(9)-Leuchte28RFL C3-Light_Function_D_28,not active
(10)-Leuchte28RFL C3-Dimming_CD_28,0
(11)-Leuchte28RFL C3-Dimming_Direction_CD_28,maximize
(12)-Leuchte28RFL C3-Light_Function_E_28,not active
(13)-Leuchte28RFL C3-Light_Function_F_28,not active
(14)-Leuchte28RFL C3-Dimming_EF_28,0
(15)-Leuchte28RFL C3-Dimming_Direction_EF_28,maximize
(16)-Leuchte28RFL C3-Light_Function_G_28,not active
(17)-Leuchte28RFL C3-Light_Function_H_28,not active
(18)-Leuchte28RFL C3-Dimming_GH_28,0
(19)-Leuchte28RFL C3-Dimming_Direction_GH_28,maximize
(1)-Leuchte29 KL30G A69-Type_Of_Load_29,allgemeineGluehlampe12W
(2)-Leuchte29 KL30G A69-Lampendefektbit_Position_29,00
(3)-Leuchte29 KL30G A69-Fehlerort_mittleres_Byte_DTC-DFCC_29,01
(4)-Leuchte29 KL30G A69-Light_Function_A_29,Klemme 30G
(5)-Leuchte29 KL30G A69-Light_Function_B_29,not active
(6)-Leuchte29 KL30G A69-Dimming_AB_29,100
(7)-Leuchte29 KL30G A69-Light_Control_HD_AB_29,Always
(8)-Leuchte29 KL30G A69-Light_Function_C_29,not active
(9)-Leuchte29 KL30G A69-Light_Function_D_29,not active
(10)-Leuchte29 KL30G A69-Dimming_CD_29,0
(11)-Leuchte29 KL30G A69-Dimming_Direction_CD_29,maximize
(12)-Leuchte29 KL30G A69-Light_Function_E_29,not active
(13)-Leuchte29 KL30G A69-Light_Function_F_29,not active
(14)-Leuchte29 KL30G A69-Dimming_EF_29,0
(15)-Leuchte29 KL30G A69-Dimming_Direction_EF_29,maximize
(16)-Leuchte29 KL30G A69-Light_Function_G_29,not active
(17)-Leuchte29 KL30G A69-Light_Function_H_29,not active
(18)-Leuchte29 KL30G A69-Dimming_GH_29,0
(19)-Leuchte29 KL30G A69-Dimming_Direction_GH_29,maximize
(1)-Leuchte2SL VLB22-Type_Of_Load_2,LED Tagfahrlichtmodul Signal
(2)-Leuchte2SL VLB22-Lampendefektbit_Position_2,48
Is it possible to somehow change the load type for the Leuchte28, or to disable the light check altogether for this bulb, or do I just have to live with the error or switch back to traditional bulbs for the reversing lights. Based on advice I have tried changing the load type for Leuchte29, but that did not do any good.
razze76
Finland
C?ID=103741
I moved my question to a new separate thread, since it is really a problem, and not coding tips for the Fabia III. I was not able to edit the previous post to remove it...
