convenience key defective
marc5
Singapore
C?ID=119198
hi there,
i change my battery on the key when it showed low battery and now, i cant use my convenience key to unlock at the door sensor nor can i start the car.
it was working fine before.
i thought it might be the antenna in the center console so i changed that but no joy.
heres my scan.
thanks for having a look.
marc
Tuesday,26,May,2015,09:46:24:24120
VCDS Version: 14.10.2.0
Data version: 20150311
VIN: WAUZZZ8T4AA052997   License Plate: 7929
Mileage: 79130km-49169mi   Repair Order:
Chassis Type: 8T (8T0)
Scan: 01 02 03 05 06 08 09 0E 10 14 15 16 17 19 1B 36 42 46 47 52
          53 55 56 5F 6C
VIN: WAUZZZ8T4AA052997   Mileage: 79130km-49169miles
Address 01: Engine (J623-CCWA)       Labels: 059-907-401-CAP.clb
   Part No SW: 8R0 907 401 J    HW: 8K1 907 401 A
   Component: 3.0TDI EDC17  H03 0008
   Revision: 15H03---
   Coding: 0114002C240F0128
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM30TDI0118R0907401J 001008
   ROD: EV_ECM30TDI0118R0907401J.rod
   VCID: 3973DDEEB807AAE9691-806C
Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
   Part No SW: 8K1 927 156 AB    HW: 0B5 927 156 E
   Component: 0B5 30 TDIRdW H04 0003
   Revision: --H04---    Serial number: 0000000706
   Shop #: WSC 00102 771 03147
   ASAM Dataset: EV_TCMDL501 A02087
   ROD: EV_TCMDL501.rod
   VCID: 75EB11DED49F0E894D9-8020
Address 03: ABS Brakes        Labels: None
   VCID: 55AB715EBC5F6E896D9-FFFF
No Faults Found
   Part No SW: 8K0 907 064 DQ    HW: 8K0 907 064 DQ
   Component: BCM2 1.1      H02 0327
   Coding: 051000
   VCID: 02017A029D51293178B-8057
   Subsystem 1 - Part No SW: 8T0 959 754 K    HW: 8T0 959 754 K
   Component: FBSAUDIB8 IDG  H38 0060
00183 - Interior Access/Start Authorization Antenna 1 (R138)
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 236
                    Mileage: 79124 km
                    Date: 2015.05.25
                    Time: 14:41:01
Address 06: Seat Mem. Pass (J521)       Labels: 8T0-959-760.clb
   Part No SW: 8T0 959 760 C    HW: 8T0 959 760 C
   Component: MEM-BFS       H10 0074
   Revision: AA000000    Serial number: 00001010057755
   Coding: 08217025002400001000
   VCID: 438FBF06C2CBE03933D-8016
   Part No SW: 8T2 820 043 AF    HW: 8T2 820 043 AF
   Component: KLIMA 3 ZONEN H08 0171
   Revision: D0000000    Serial number: 01210120100790
   Coding: 36166000
   VCID: 76E916D2C1990591443-8023
   Part No SW: 8K0 907 063 N    HW: 8K0 907 063 N
   Component: BCM1 1.0      H25 0380
   Revision: 09025001    Serial number: 00000000563810
   Coding: 2600D09100348F311F09000000005D5D4F9DC3C800010141000000
   Shop #: WSC 06325 123 12345
   VCID: 3A71C2E2B501A1F160B-806F
   Subsystem 1 - Part No SW: 8T2 955 119 D    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 190110  H12 0070
   Coding: 00FD11
   Component: RLS  H04 0003
   Coding: 02532C
   Component: E1 - LDS  H08 0090
Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 110 L    HW: 4E0 035 110 A
   Component: CDC-MP3-Pana  H49 0050
   Revision: 00000015
   VCID: 2143158E3897D229411-8074
Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
   Part No SW: 8K0 919 475 R    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0070
   Revision: 11001001    Serial number: 50931002203867
   Coding: 300101
   VCID: 4895A82AFBEDC361E6F-801D
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 8R0 907 364 B    HW: 8K0 907 364
   Component: DAEMPFUNGS-SG H09 0053
   Revision: 00000000    Serial number: 20011002580001
   Coding: 050181
   VCID: 3973DDEEB007AAE9691-806C
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 G    HW: 8K0 959 655 G
   Component: AirbagVW-AU10 H39 0560
   Serial number: 003EFD0B16R4
   Coding: 30323433363030303030554A305238543053
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 4183B50ED0D7F229211-8014
   Serial number: 6334MSME4F324746I
   Serial number: 6344MSME4F326E10J
   Serial number: 6352QSME604B3D2EU
   Serial number: 6362QSME47491C02H
   Serial number: 63732SME404A4902W
   Serial number: 63832SME464A4722$
   Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
   Revision: --------    Serial number: 90304JA8000KF
   Coding: 000036
   VCID: 3E79CEF2A9298DD15C3-806B
   Component: E221 - MFL  H06 0003
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8T0 920 931 D    HW: 8T0 920 931 D
   Component: KOMBIINSTR.   H36 0255
   Revision: 00000000    Serial number: CSF761N1A
   Coding: 230F01003B000008010800
   VCID: 3875D8EA8B0DB3E196F-806D
   Part No SW: 8T0 907 468 T    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0105
   Revision: EB800053    Serial number: 5300E1011401DC
   Coding: 00C303
   VCID: 52A18A420DB179B188B-8007
   Component: J367-BDM  H07 0170
   Part No SW: 8K0 907 144 D    HW: 8K0 907 144 D
   Component: DYNAMIKLENK.  H06 0570
   Revision: 50001005    Serial number: --------------
   Coding: 040000
   Shop #: WSC 06324 000 00000
   VCID: 3065E0CA637D6BA1DEF-8065
Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
   Component: MEM-FS        H10 0074
   Revision: AA000000    Serial number: 00001010057900
   Coding: 08397B25002400001000
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8T0 959 793 J    HW: 8T0 959 793 D
   Component: TSG FA        H07 1201
   Coding: 011C12225E01120102
   VCID: 50A5804A03BD0BA1BEF-8005
   Revision: 00002001    Serial number: 0125903218
   Coding: 01040E80003905810320003280000000
Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
   Part No SW: 8T0 035 223 AN    HW: 8T0 035 223 AK
   Component: DSP Prem      H10 0190
   Revision: 00010001    Serial number: 34882000991001
   VCID: 7AF102E2F58161F120B-802F
   Part No SW: 8T0 959 792 J    HW: 8T0 959 792 D
   Component: TSG BF        H07 1201
   VCID: 4FA783361E831459A75-801A
   Revision: 00000003    Serial number: 10000000411913
   VCID: 346DECDA97655781BA7-8061
Address 55: Headlight Range        Labels: 8T0-907-357.clb
   Part No SW: 8H0 907 357 A    HW: 8H0 907 357
   Coding: 0000018
   VCID: 3065E0CAA37D6BA1DEF-8065
   Subsystem 1 - Part No: 7L6 941 329 C
   Component: AFS-Modul links H01 0004
   Subsystem 2 - Part No: 7L6 941 329 C
   Component: AFS-Modul rechtsH01 0004
   Part No SW: 4F0 035 053 K    HW: 4F0 035 053
   Component: Radio U Basic H45 0074
   Revision: AB001007    Serial number: 341A 0A7695467
   Coding: 070003010000000001
   VCID: 254B019E2CBF3E093D9-8070
   Part No SW: 8T2 035 754 K    HW: 8T2 035 754 D
   Component: H-BN-RW       H46 0180
   Revision: --------    Serial number: 485AX0A7513752
   Coding: 010801020106E1FF47000F0E000000030001
   VCID: 4183B50ED8D7F229211-8014
   Subsystem 1 - Part No: 8R0 060 884 D
   Component: ROW 2009/2010  5103
   Component: DU7 High  H43 0306
   Subsystem 3 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
   Component: CD-Database  1293
03175 - Invalid Data Set
            000 -  -
                    Reset counter: 236
                    Mileage: 79091 km
                    Date: 2015.05.25
                    Time: 12:49:08
                    Voltage: 14.10 V
   Part No SW: 8T0 907 441 D    HW: 8T0 907 441 D
   Component: J772__Rearview      0140
   Revision: --H06---    Serial number: 525PA8-J2190H5
   Coding: 1001008
   Shop #: WSC 98765 666 38384
   VCID: 3973DDEE7007AAE9691-806C
End-------------------------(Elapsed Time: 03:32)--------------------------
Zenerdiode
Newcastle, England
C?ID=24330
Fundamentals first. Have you got the battery orientated as mine?
Does the LED give a strong red when the battery is pushed back in?
Does the LED flash when you press a button?
Does the car unlock when you press the unlock?
Does the LED flash when you put your hand around the door handle?
Does the LED flash when you press the Engine START/STOP button?
Do you hear the very feignt 'tweep-tweep-tweep' when you push to start?
Was that fault in 05-Acc/Start Auth caused by you disconnecting the antenna; or was it there before?
Do you still have this fault?
marc5
Singapore
C?ID=119198
Hi, thanks for having a look.
first to answer Zeners questions.
Battery orientation is correct.
led lights up when pushed in.
led flashes strongly when pressed.
car unlocks and boot opens when buttons are pressed.
led does NOT flash when touching the handle, nor does it flash when start/stop button is pressed.
I've never heard the faint tweep ever before.
And as to the fault, I only did a scan after the key stopped working. and yes it is still there even after the antenna change.
clearing it doesn't help as, after i press the start button, it comes back.
and to add further, the start button works if the key is inserted into the ignition. once inserted, i can start and stop the engine.
marc
NostraJackAss
The reason the key runs in ignition is it sees the key coil antenna.
The R138 antenna is in the center console.
Attempt recoding and defaulting the module and readapting the antenna ....or after the short to ground is corrected.
Verify in WD on page 23
Check wires T32/e 16 & T32/e 15 to pins 1 and 2 of the antenna.
Verify all fuses for CCM J393
marc5
Singapore
C?ID=119198
Thanks for looking jack.
So is the r138 on the right door if my car is a rhd? I looked in the service manual and it shows r138 to be in the centre.
And I'm sorry but after that your post gets confusing. So its the j393 unit in the boot is it not? I don't really have or know what WD is.
Ah you meant wiring diagram. I'll have a look
marc5
Singapore
C?ID=119198
I just had a look at the WD. There are only 2 antennas on the j393. One in the centre console and one in the boot. Is that correct or am I confusing it with something else. I'll try and post a screen capture.
[/IMG]
marc: is this the aerial that you replaced?
Could it be that in trying to solve your key problem, an inadvertent second issue has arisen (i.e. the shorted Aerial). Sounds like you have taken Jack's sage advice with the WD. Can you check the two wires (perhaps remove the 2 wires from pins 15 & 16 on J393 and using a high impedance multimeter measure their resistance to the car body)? The WD indicates that both these wires should totally disconnected from battery earth. It's hard to see how such a simple device could be shorted to ground unless the wiring insulation has been compromised in the replacement process. If it isn't a wiring issue, then my experience has been that aerials (the car type, or otherwise) are difficult to repair without specialised equipment (problem is that they need to be tested at the IF operating frequency), Do you still have the original aerial that you could try putting-back?
I suspect that you will need to fix the error message in the auto-scan report first before proceeding with your substantive issue
marc5
Singapore
C?ID=119198
hi dv52, it seems too much of a coincidence that the antenna issue popped up after the key issue. but you'll never know. stranger things have happened.
i tried the original antenna no joy.i did see a service bulletin by audi while trawling the internet. let me see if i can find it. i'll try the multimeter as well.
marc
marc5
Singapore
C?ID=119198
This TSB applies to 2000 to 2014 Audi models including the Q5, R8, A6, A8, Q7, A4, A3, TT, Allroad, A5 and A7.
Central locking via the remote control does not work either sporadically or permanently, but the locks can still be operated manually. Missing synchronization between the remote control key and vehicle may occur because the battery has been disconnected or the battery in the remote control has been replaced. If other senders operate in the same frequency range (mobile phones, TV stations, wireless headphones etc.), the remote control key may have been temporarily switched off because a clear indication of the remote control key is not possible. This is necessary to prevent an unintentional unlocking of the vehicle by other unrelated senders.
Perform the synchronization between each remote control key and the vehicle:
2000-2008 A4
Open the vehicle mechanically with the key.
Press the unlock button of the remote control key.
Insert the key into the ignition switch and switch to the ON position.
Switch the key OFF again and remove the key.
Press the unlock button or the locking button of the remote control key.
Model year 2002 or later: If the synchronization procedure was not successful, adapt the remote control key(s) to the Central Comfort System control module (address word 46) using the VAS scan tool. Follow test plan J393-central control module for comfort system, adapting remote control key via adaptation (channel 21). Sometimes following the “erase all memory positions first” test plan produces better results.
R8, TT, A3, A6
Press one of the buttons on the remote control key.
Lock or unlock the vehicle once mechanically with the key.
The complete process must not take longer than 30 seconds.
Up to and including model year 2009: If the synchronization procedure was not successful, adapt the remote control key(s) to the Central Comfort System control module (address word 46) using the VAS scan tool. Follow test plan J393-central control module for comfort system, adapting remote control key(s). Sometimes following “erase all memory positions first” test plan produces better results. From model year 2010: If the synchronization procedure was not successful, adapt the remote control key(s) to the BCM2 (vehicle electrical system control unit), address word 09, using the VAS scan tool. Follow test plan J519-Vehicle electrical system control module, adapting remote control key(s).
2009-2014 A42008-2014 A5, 2014 A5 Cabriolet, 2009-2014 Q5, 2011-2014 A8, 2012-2014 A7 and 2012-2014 A6
Press a button on the remote control key within the range of the vehicle.
If necessary, open the vehicle with the emergency key on the door lock.
Switch the ignition ON and OFF.
A6, A8 and Q7
a. Open the vehicle mechanically with the key.
b. Insert the key into the ignition switch and switch to the ON position.
c. Switch the ignition OFF again.
1. If the synchronization does not help, check the battery of the remote control. The battery voltage must be 3.0 V or higher.
If the remote battery voltage is below 3.0 V, replace the battery and perform synchronization again.
Check whether there are any interfering senders nearby.
Check whether there are any interfering senders in the vehicle.
If interference was responsible for the condition, explain this to the customer.
marc5
Singapore
C?ID=119198
tried the above and no joy. a little confused about switching the ignition on and off though, does it refer to the start button or the keyhole ignition.
NostraJackAss
Unplug the antenna and see if the DTC changes from short to ground....... to short to open or B+
Did you check all fuses?
marc5
Singapore
C?ID=119198
well, some closure to this fault. i sent it to some guy who claims to know what to do with it and it seems he changed the FET on the convenience board. works great. similar to what some volkswagens guys have been doing to their KESSY problems.
