2004 bentley continental GT Air suspension light removal
Chrisdxb82
United Arab Emirates
C?ID=495103
Folks, hoping someone here can help me with my issue.
I have an '04 Bentley continental GT. Had a ton of work done bringing it upto par all new Vac Lines fuel lines turbos were replaced. I also decatted it and had it mapped.
Whilst all this was going on i also ripped out the Air suspension and replaced it with Ceika Coilovers. Yeah i know not in keeping with a bentley but i want to make it my bentley. I've bought VCDS to code out the Air suspension but won't lie I'm very aware of the fact that as much i could make the issue go away. I'm more likely to cause myself more issues if i just jump in feet first.
If anyone has done the above and could point me in the right direction i would be very grateful
Thanks Chris
  • Wow
Reactions: JMR
Chrisdxb82
C?ID=495103
😂 😂 That'll be a long post. I'll try and keep it short and on point to the task at hand.
Westbury, UK
Not if you use the </> icon in the forum editor to post the Auto-Scan - that opens a window which you past the text of the scan into and will then be enclosed in code tags.
Chrisdxb82
C?ID=495103
I meant with regards to all the fault codes. That are stored in the car. It's a 17yr old Bentley
Clear them. Any that are important/relevant will be back soon enough.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
You're right, doesn't seem in keeping with Bentley, but as you say, your car your call.
I'm afraid the change you've made is difficult to finish cleanly.
Like Phaeton, I don't think there are Bentley CGTs or Flying Spurs that came without air suspension. @DrPeter correct me if I'm wrong. People have looked into this before and there's not really coding options to entirely tear it out. I don't think refresh of GVL without the suspension module actually works, or at least, I don't think it works to suppress alerts in the instrument cluster. Feel free to try.
Also, the autoleveling HIDs on Phaeton depend on level sensor input from the suspension control module to work correctly. I don't know, but I'd assume Bentleys have autoleveling HIDs as well. Technically you could recode them for Touareg without air suspension, but I think that just moves the chassis level sensor input to some other sensor/input, something only Touareg has and only when it doesn't have air suspension. I don't remember the details.
There are outfits that make light-out kits for air suspension deletes, you could look at one of those from one of the vendors that's done this before on Phaeton or Bentley. Here's an example:
I don't know how it works, in fact, I kind of wonder given that there's only four wires coming out of the thing. You'll need to do some research.
If I had to do this on my Phaeton for some reason, like if parts stopped being available, I'd mock up something with a microcontroller with two CAN interfaces to sit between the suspension controller and the rest of the car, so I could keep the controller and the level sensors in place, and keep my autoleveling HIDs working, but MITM the status messages to the instrument cluster to tell it everything's fine instead of faulted. But that's just how I'd come at the problem using my own skillsets and preferences.
People have certainly retrofit level sensors into cars that didn't have them when retrofitting HID lights, so that part is doable. The question is whether the headlight range controller in this car supports the separate sensor inputs. Some do, some don't. For example the C5 Allroad had a headlight range controller that did not, so the only way to make that work was to install a controller from more pedestrian A6.
An Auto-Scan is called for here so we can see how this car is equipped.
Chrisdxb82
C?ID=495103
please see the full auto scan
Monday,07,February,2022,13:05:26:14703
VCDS Version: 21.9.0.2 (x64)  HEX-V2 CB: 0.4555.4
VIN: SCBCE63W34C023250   License Plate:
Mileage: 163790km   Repair Order: low pdc
Chassis Type: 3W (3W - Bentley Continental (2004 > 2007))
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 26 28 34 36
          37 38 46 47 53 54 57 65 66 68 69 6C 71 75 76 77
VIN: SCBCE63W34C023250   Mileage: 163790km-101774miles
Address 01: Engine        Labels: 07C-906-018-BEB1.clb
   Part No SW: 07C 906 018 AC    HW:
   Component: BY-6.0L-TT      G  ª6238
   Coding: 0000173
   Shop #: WSC 00000 000 08192
   VCID: 6695BE1124745BCB3DD-513C
   VINID: 8D34935460E70C44C008308500A4BA4B17
18331 - Please Check DTC Memory of ECU Number 2
            P1923 - 008 -
17964 - Charge Pressure Control
            P1556 - 002 - Negative Deviation - Intermittent
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 09E 927 760 A    HW: GS1 904 1
   Component: AG6 09E 6.0L W12TT  1005
   Coding: 0000101
   Shop #: WSC 00083 000 00000
   VCID: 2E050631CC04D38B05D-5160
Address 03: ABS Brakes        Labels: 3W0-614-517-V1.lbl
   Part No: 3W0 614 517 B
   Component: ESP 5.7 4WD     H01 0011
   Coding: 0007878
   Shop #: WSC 07800 000 00000
   VCID: 343114592228F95B739-51F2
   Part No SW: 3D0 909 137 C    HW: 5WK 484 99
   Component: 43 Kessy            6700
   Revision: 67005715    Serial number: VWZ3Z0D7188356
   Coding: 0405741
   Shop #: WSC 00083 001 00001
   VCID: 270BF315E3FE82C3C6B-5160
00955 - Key 1
01049 - Supply Voltage Term 50
00183 - Interior Access/Start Authorization Antenna 1 (R138)
Address 06: Seat Mem. Pass        Labels: 3W0-959-759.clb
   Part No: 3W0 959 759 A
   Component:    CM Seat Pass.    0009
   Coding: 0000002
   Shop #: WSC 07800 107 64591
   VCID: 47CB539543BE62C326B-5160
Address 08: Auto HVAC        Labels: 3W7-907-040.clb
   Part No: 3W0 907 040 B
   Component: Climatronic BY614   0030
   Coding: 0000001
   Shop #: WSC 00001 000 00000
   VCID: 30391849D630C57B171-5160
00716 - Air recirculation Flap Positioning Motor (V113)
            014 - Defective
            014 - Defective
00477 - Control Module; Display & Input; Comfort CAN; Front (J523)
Address 09: Cent. Elect.        Labels: 3D0-937-049-V1.clb
   Part No: 3D0 937 049 G
   Component: STG.Bordnetz        5001
   Coding: 0000107
01494 - Bulb for Parking Lamps; Left (M1)
01498 - Bulb for Parking Lamps; Right (M3)
Address 11: Engine II        Labels: 07C-906-018-BEB2.clb
   Coding: 0000173
17963 - Charge Pressure
            P1555 - 001 - Maximum Limit Exceeded
   Part No: 3D0 909 601 E
   Component: 0P Airbag 8.4E+ H10 0936
   Coding: 0012368
   VCID: 2517F91D99F290D3F47-5160
Address 16: Steering wheel        Labels: 3D0-953-549.lbl
   Part No: 3D0 953 549 D
   Coding: 0000012
Address 17: Instruments        Labels: 3Wx-920-xxx-17.lbl
   Part No: 3W8 920 840 B
   Component: KOMBIINSTRUMENT RB8 0610
   Coding: 0021103
   Shop #: WSC 07800 107 59862
   VCID: 3B233F650F763623B23-5160
00459 - Control Module for Display and Input; Front (J523)
   Part No: 6N0 909 901
   Coding: 0000006
   VCID: 70B9D84916B0857B571-5160
02174 - Analog/Digital clock
Address 34: Level Control        Labels: 3Wx-907-553-34.clb
   Part No: 3W0 907 553 A
   Component: LUFTFDR.-CDC- 3C3V0 7203
   Coding: 0005561
   Shop #: WSC 12345 123 82495
   VCID: 382920693E401D3B5F1-5160
01780 - Sensor for Vehicle Leveling
Address 36: Seat Mem. Drvr        Labels: 3W0-959-759.clb
   Part No: 3W0 959 760 A
   Component:    CM Seat Driver   0008
   Coding: 0000002
   Shop #: WSC 07800 107 52154
   VCID: 3FDB4B751B6E2A039EB-5160
01971 - Adjuster for Seat Heating & Ventilation (E399)
Address 38: Roof Electronics        Labels: None
   Part No: 3W0 907 135 C
   Component: Dachmodul           0703
   Coding: 0000157
   VCID: 36352E513454EB4B4DD-5160
Address 46: Central Conv.        Labels: 3D0-959-933.lbl
   Part No: 3D0 959 933 F
   Component: 1G HSG              0101
   Coding: 0000032
   VCID: 333317452726FE636A3-4AE0
   Subsystem 1 - Part No: 3W1 959 701
   Component: Tuersteuergeraet FS 0702
   Subsystem 2 - Part No: 3W1 959 702
   Component: Tuersteuergeraet BF 0702
   Subsystem 3 - Component:    TSG HL No Answer
   Subsystem 4 - Part No: 3W3 959 704
   Component: Tuersteuergeraet HR 0702
   Subsystem 5 - Part No: 7L0 907 719
01503 - Bulb for 3rd Brake Light (M25)
   Part No: 3W0 035 456 C
   Component: 12K-AUDIOVERST      4121
   VCID: 343114592228F95B739-5160
00871 - Bass Speaker Front Right (R23)
Address 53: Parking Brake        Labels: 3W0-907-801.clb
   Part No SW: 3W0 907 801 B    HW: 3W0 907 801 B
   Component: EPB  BC6HX23    HC6 X230
   Coding: 0022413
   VCID: 3537295D2952E053447-5160
                    Reset counter: 167
                    Voltage: 11.80 V
                    Count: 241
Address 54: Rear Spoiler        Labels: 1C0-959-733.lbl
   Part No: 1C0 959 733 D
   Component: Heckspoiler         0002
   VCID: 2C010C39FF18A19B2B9-51CE
01507 - Initialization Not Successful
            35-10 - - - Intermittent
Address 57: TV Tuner        Labels: 3D0-919-146.lbl
   Part No: 3D0 919 146
   Component: TV Tuner        H07 1205
   Coding: 0000010
   VCID: 6597B91DD97250D3347-5160
02239 - Audio / Video Output 1
Address 65: Tire Pressure        Labels: None
   Part No: 3W0 907 273 A
   Component: Reifendruckueberw.  0022
   Coding: 0010344
   Shop #: WSC 07800 107 183435
   VCID: 372B2355335E124356B-5160
01477 - System Switched Off
Address 68: Wiper Electr.        Labels: 3Wx-955-023.clb
   Part No: 3W1 955 023 C
   Component: WischeX
   Shop #: WSC 00000 725 65552
Address 71: Battery Charger        Labels: 3D0-915-181.lbl
   Part No: 3D0 915 181 C
   Component: Batteriemanagement  2700
   VCID: 2313E70597C66EE39A3-5160
Address 76: Park Assist        Labels: 3W0-919-283-V1.clb
   Part No: 3W0 919 283
   Component: 02 Einparkhilfe     0203
   VCID: 7AADFA6140CCCF2BE95-5160
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
            014 - Defective
00433 - Parking Aid Button (E266)
Address 77: Telephone        Labels:
   VCID: 55F789DD8C02C053A47-5160
   Note: Excessive Comm Errors
End----(Elapsed Time: 07:40, VBatt start/end: 12.2V/12.1V. VIgn 0.0V)------
DrPeter
16.4905° S, 151.7375° W
I personally have never seen a 'modern' Bentley, (2004 - >>) with a steel spring suspension system.
Also, looking at the Auto-Scan I do not see a clear path to "code" out the [34-Level Control] system.
In the [34-Level Control] controller, there is an Adaptation, channel [010] for the "Level Control System Deactivation".
Save a new value of (0) for "Level Control System inactive". This maybe a temporary function and may automatically activate once the vehicle speed exceeds 80 km/h (50 MPH). But worth a try?
Since the Bentley is such a large vehicle, you could build a small model of the vehicle (1/8 scale?) with level sensors and resistors to simulate the [34-Level Control] systems components. Put it in the boot and after you calibrate it, it should be fine. Maybe??
- All kidding aside, building a simulator could be a solution, just thinking out side the box here.
Hope this helps,
drpeter
Bentley
South Wales, UK
C?ID=263294
I'm pretty sure that just switches on JACK MODE and, as you say, it will turn off at speed.
You'll also get the jack mode symbol up. You could possibly just lock the sensors in a position where the ride height is correct and it may be happy with that. Or it may come up with implausible signals warnings?
Yes a model in the boot is a good idea :) . . . I'd probably fit air springs and go for a model for the passenger seat instead. ;)
