VW CC 2016 steering cluster module
dd1
C?ID=826
hi to all, i have replaced the steering cluster module and coded with the help of the VCDS, i used the original coding data from the bad module. now i have this code only 03375 and the steering yellow light is on. the fault code is in the steering assist. posting the logs and hopefully someone can help me out with this issue. thank you in advance
Wednesday,02,February,2022,01:45:12:50448
VCDS Version: 21.9.0.2  HEX-NET CB: 0.4555.4
VIN: WVWBP7ANXGE518315   License Plate: BULGAR
Mileage: 201740km-125355mi   Repair Order:
Chassis Type: AN-VW46 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 4F 52 53 55 5F 62 65
          6C 72 75
VIN: WVWBP7ANXGE518315   Mileage: 201740km-125355miles
Address 01: Engine (CBF)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 06J 906 027 JK    HW: 06J 907 309 B
   Component: MED17.5.2        06 1336
   Revision: PAH05---    Serial number: VWZCZ000000000
   Coding: 040401081C070160
   Shop #: WSC 05314 000 00001
   VCID: 7DB207B324347E612A-8028
   VINID: 9E69D280745EA175450480C11493996331
Readiness: 0110 1101
   Part No SW: 02E 300 062 C    HW: 02E 927 770 AL
   Component: GSG DSG AG6     531 4032
   Revision: 06253104    Serial number: 00001602051367
   Shop #: WSC 05311 000 00001
   VCID: 15623F133C44862182-8040
   Part No SW: 3AA 614 109 BM    HW: 3AA 614 109 BM
   Component: J104   C2 450M VDCF 0040
   Revision: --H07---    Serial number: 00000009166702
   Coding: 0004495
   Shop #: WSC 05311 000 08193
   VCID: 79BA13A3301C424106-802C
   Part No SW: 1K8 907 044 BM    HW: 1K8 907 044 BM
   Component: Climatronic   H07 0405
   Revision: 00001K04
   Coding: 0714019048
   Shop #: WSC 00015 115 08193
   VCID: 7BB609ABF220705114-802E
Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
   Part No SW: 3AA 937 087 R    HW: 3AA 937 087 R
   Component: BCM PQ47 H++  422 0477
   Revision: BD422001
   Coding: 0008000000000000008C028194000D4C20550B0844200D20E484402400C0
   VCID: 49DAA363E07C12C1D6-801C
   Subsystem 1 - Part No SW: 3C8 955 119 H    HW: 3C8 955 119 H  Labels: 1KX-955-119.CLB
   Component: WWS464 010316  024 0644
   Serial number: 16022403004441
   Coding: 044D9D
   Component: RLHS  037 0059
   Serial number: S3Y16M03D07H01M26S12
   Coding: 0228DD
   Part No SW: 5N0 959 655 AC    HW: 5N0 959 655 AC
   Component: J234__702 VW10 HI   5418
   Revision: 35022000    Serial number: 003MBP6XNHEP
   Coding: 0012338
   VCID: 7EB000BF2932657933-802A
   Subsystem 1 - Part No: 3C8 959 339 A
   Subsystem 2 - Serial number: 0000000000NAN7
   Subsystem 3 - Serial number: 0014.12.150000300000640025ÿ†63
   Subsystem 4 - Serial number: 640025ÿ†6332MTS660450446 ÿ†63
   Subsystem 5 - Serial number: 50446 ÿ†6342MTS620230606 ÿ†63
   Subsystem 6 - Serial number: 30606 ÿ†6351HTS6EUF87EKR ÿ†63
   Subsystem 7 - Serial number: 87EKR ÿ†6361HTS68UA77EKR ÿ†63
   Subsystem 8 - Serial number: 77EKR ÿ†63727TS6EU2G5EKR ÿ†63
   Subsystem 9 - Serial number: G5EKR ÿ†63827TS62U2G5EKR ÿ
   Subsystem 10 - Serial number: G5EKR ÿ
   Part No SW: 5K0 953 569 AS    HW: 5K0 953 569 AS
   Revision: --X01---    Serial number: 20211015200441
   Coding: 099A270001
   Shop #: WSC 00015 115 00001
   VCID: 095A6363A8FC52C116-805C
   Component: E221__MFL-TK6  H07 0023
   Serial number: 70000000000000904450
   Coding: E30000
   Part No SW: 3C8 920 971 L    HW: 3C8 920 971 L
   Component: KOMBI         H05 1008
   Coding: 240F000000
   Shop #: WSC 05314 115 00001
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW32.rod
   VCID: 3620D89F89826D39AB-8062
   Part No SW: 7N0 907 530 BG    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1673
   Revision:   H56       Serial number: 020416F1001118
   Coding: 469036
   VCID: 76A0189FC1022D396B-8022
   Part No SW: 3AA 959 799 G    HW: 3AA 959 799 G
   Component:    IMMO         091 0429
   Revision: 00091000    Serial number: VWZCZ000000000
   VCID: 4CD49A772F0E07E9ED-8018
   Part No SW: 3C8 959 701 A    HW: 3C0 959 793 J
   Component: TUER-SG FT    002 0603
   Revision: 12100010    Serial number: 0010488135
   Coding: 0004B7
   Shop #: WSC 05311 115 08193
   ASAM Dataset: EV_TSGFPQ35BRFVW46X A04004
   VCID: 2E10F0FF71D255F9E3-807A
   Slave Driver:
   Subsystem 1 - Part No SW: 3C8 959 703 D    HW: 3C8 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  006 0503
   Serial number: 00000004237050
   Coding: 010490
          B11EC 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 207
   Part No SW: 5N1 909 144 S    HW: 5N1 909 148 K
   Component: J500__APA-BS KL.303 1501
   Revision: 1BH04740    Serial number: 00160680082501
   Coding: 0000258
   VCID: 42C8B44F1D4AC19917-8016
03375 - Steering Motor
            003 - Mechanical Failure - MIL ON
                    Fault Status: 11100011
                    Reset counter: 207
                    Mileage: 201743 km
                    Date: 2016.06.25
                    Time: 00:14:57
                    (no units): 7.0
                    Steering Angle: 0.00°
                        OK
                    (no units): 4
Address 46: Central Conv.        Labels:. 3C0-959-799-46.clb
   Component:    KESSY PQ47   091 0414
   Coding: 1B910F8001862E521204143FF08A0F0E10780203042498
   Subsystem 4 - Component:       ViP n.mounted
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AN
   Component: EZE_2         H56 1673
   Coding: 00000008
   VCID: 6FAE2DFBBE581CF1A8-803A
   Subsystem 1 - Part No SW: 3C8 919 204 A    HW: 3C8 919 204 A
   Component: Analoguhr  005 0005
   Part No SW: 3C8 959 702 A    HW: 3C0 959 792 J
   Component: TUER-SG BT    002 0603
   Revision: 14100010    Serial number: 0010484486
   Coding: 0004B6
   ASAM Dataset: EV_TSGBPQ35BRFVW46X A04004
   VCID: 2F2EEDFB76D85CF1E8-807A
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C8 959 704 D    HW: 3C8 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  006 0503
   Serial number: 00000004234582
   Coding: 010490
                    Reset counter: 207
   Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
   Component: J540 EPB4  VW-63206 0012
   Revision:   H20       Serial number: 00000000076067
   Coding: 0022156
   VCID: 383CD6A74B969B49B9-806C
   Component: AFS-ECU       H05 0111
   Coding: 071200010B000400
   ROD: EV_HeadlRegulVWAFSPt_VW46.rod
   VCID: 373ED59B8E889431B0-8062
   Subsystem 1 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0011
   Coding: 350000
   Subsystem 2 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0011
   Coding: 350000
   Part No SW: 5C0 035 684     HW: 5C0 035 684
   Component: MU-S-NS-US    H22 0247
   Serial number: VWZAZ2S0136677
   Coding: 02740402FF00000051220001001808001F0100C400200105C6
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 628854CF758AA19937-8036
   Subsystem 1 - Part No SW: 3G0 919 866 R    HW: -----------
   Component: NAR 2016  --- 0321
          B11CF 53 [009] - Deactivated
                    Reset counter: 207
                    Mileage: 201744 km
                    Date: 2022.02.02
                    Time: 01:31:55
                    Voltage terminal 30: 12.1 V
                    SDARS_tuner_status_2-Satellite radio antenna status: electrically OK
                    SDARS_tuner_status_2-Audio Signal: Not available
                    SDARS_tuner_status_2-Antenna current: 0 mA
                    SDARS_tuner_status_2-Reception quality: No_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 00
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 00
   Part No SW: 3AA 907 273 H    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0012
   Serial number: 40000000051391
   ROD: EV_RDKBERU30_006_VW36.rod
   VCID: 393AD3A3B89C824146-806C
   Part No SW: 7N0 907 441 B    HW: 7N0 907 441 B
   Component: VW428 RVC Mid H04 0040
   Coding: 016404016001000700
   Shop #: WSC 05311 000 00305
   ASAM Dataset: EV_CamSysRearPANAVW428 002002
   ROD: EV_CamSysRearPANAVW428.rod
   VCID: 302CEE876BE64309F1-8064
   Part No SW: 561 035 285 A    HW: 561 035 285 A
   Component: OCULowUSA     020 0158
   Serial number: 000003554140549
   Coding: 02640402C24212107F1606000000
   ASAM Dataset: EV_OCULow 002010
   ROD: EV_OCULow_002.rod
   VCID: 14644217FFBE9F29F5-8040
End----------(Elapsed Time: 01:37, VBatt start/end: 13.7V/13.6V)-----------
EuroX
Northern NJ USA
C?ID=208579
Why was the dash changed?? According to this log the steering motor is not working. Did you check if power steering motor has terminal 30 and getting terminal 15 power ??Was steering wheel removed??
  • Agree
Reactions: JMR
siLc
Tallinn, Estonia
C?ID=330192
What exactly is the "steering cluster module"?
Module 16 or the SWCM. That's the B7/CC classic 569AS replacement part whose serial number start implies its 5 years younger than the vehicle itself.
Since there are no "G85 basic settings missing" DTC-s in module 44, which is standard after replacing module 16, I'm guessing OP was able to carry out G85 basic settings but then the steering rack's motor failed. I think it's just a coincidence.
Reactions: JMR
dd1
C?ID=826
hello, the steering cluster module is the SWCM, yes and we replaced that bc of the air bag stage one fault. now, the air bag code is gone but the steering came and stayed on. no issues before. and the steering is soft and smooth, just light the rack-n-pinion is working ok. i am puzzled. please help.
dd1
C?ID=826
steering control module was replaced, not the actual dash. the air bag light was on for the stage 1 i think and that is why was replaced. now, only steering wheel yellow light is on.
n4s
Portugal
C?ID=351319
Have you seen the error in Scan?
Reset counter: 207
Mileage: 201743 km
Date: 2016.06.25
Time: 00:14:57
(no units): 7.0
OK
(no units): 4
EuroX
Northern NJ USA
C?ID=208579
Ok so steering column control module was changed. Can you verify that coding is the same??Also is the new unit the same exact part number as old unit?? Is that fault static or can it be cleared?? I would assume steering angle sensors needs to be calibrated and end stops on the rack. If ends stops cannot be adapted It looks like you may need a steering rack or possibly a reflash of the J500 control module to see if the rack can be saved.
dd1
C?ID=826
Reset counter: 207
Mileage: 201743 km
Date: 2016.06.25
Time: 00:14:57
(no units): 7.0
OK
(no units): 4
no codes were there before except the air bag light. this fault code appeared as soon as i coded the module, steering module.
dd1
C?ID=826
it wont adapt, now how am i going to explain this to the client??????????????????????????? disaster
EuroX
Northern NJ USA
C?ID=208579
Why woun't it adapt?? Please tell me what procedure your using to adapt. Also have end stops been adapted?? Is the unit the same exact part number as old unit or a compatible superseded unit?? Also what does it say when you try to adapt it??
EuroX
Northern NJ USA
C?ID=208579
Crickets???? Bueller?Bueller?
dd1
C?ID=826
thank you, the new is from the dealer and the part number was verified from the dealer. i do this codings and adapting with no issues, even ODIS online, and also the stops have been adapted. this one was a strange one. in any case, the client took it to the dealer.
EuroX
Northern NJ USA
C?ID=208579
Sounds like user error or not all codings or basic settings were done. Either way im sure the dealer was able to get it done.
