- May 20, 2015
- 63
- 18
- South Africa
- C?ID=163752
Hi friends
very first post here
my name is Shafiq and im from south Africa! I co own an auto electrical business with my dad..been running for the past 30 years..
lotsa electrical experience on vags so please don't hesitate to ask for any help from me
today however I need some serious assistance.
car is a 2009 golf 5 gti
customer initially took vehicle to a mechanic who diagnosed a faulty abs module. a brand new module was ordered via vin from VW.. mechanic fitted module and then took vehicle to VW for coding..
vw informed him that the module will not accept the basic settings and a new pump was required at a BIG cost..customer then brought vehicle to me
my current scan
ive had success with EVERY basic Setting besides the Setting for Hydraulic Unit Intake Valves and disconnecting valves
I get to this point-
The control module will display the required pressure range in brackets.
If Imp. VL [116/129] >000< Press Pedal 005 is displayed, press the pedal until the actual reading is within 116 ~ 129 and maintain that pressure until [000/000] is shown.
but the issue is that it keeps asking me to input the same value..over and over. done it for over 15 minutes but the asking value only changed on 1 occasion..ive let the car cool down ive tried EVERYTHING...also I can see that the actual value is meeting the requested..
so my question is do you guys think the pump could be causing this?does it need to get out of the function test before I can do adaption?
the old modules part number- 1K0 903 379 AD
I WOULD REALLY APPRECIATE ANY HELP
thanx in advance
shafiq
my current scan
VCDS Version: Release 14.10.2 (x64)
Data version: 20150311
Monday,25,May,2015,17:11:08:48700
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: AAVZZZ1KZ9U009743 Mileage: 119710km-74384miles
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1K0 907 115 R HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWX7Z0H73N67ZU
Coding: 0403001018070160
Shop #: WSC 00046 412 31414
VCID: 356799535CFF4A898D9-8060
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
Readiness: 0110 0001
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AN HW: 1K0 907 379 AN
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Coding: 163B600D09220003681206E8901C00813000
Shop #: WSC 39100 001 1048576
VCID: 7EF5467FE94949D11C3-802B
01486 - System Function Test Activated
Reset counter: 217
Mileage: 119713 km
Count: 3
Count: 2
Count: 12800
Count: 320
Count: 43264
00003 - Control Module
Fault Status: 01100101
Reset counter: 217
Mileage: 119713 km
Count: 3
Count: 2
Count: 12800
Count: 143
Count: 43264
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 DE HW: 1K0 907 044 DE
Component: ClimatronicPQ35 130 1213
Revision: 00130023 Serial number: 00000000000000
VCID: 6DD77133742FC249B59-8038
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Revision: 00H54000 Serial number: 00000008896852
Coding: E58D8F2700041500471400001400000000097F075C000100000000000000
VCID: 3363A74B528B54B9A3D-8066
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 041108 020 0501
Coding: 00049109
Shop #: WSC 00046
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 280808 046 0204
Coding: 00208933
Shop #: WSC 00046
Component: 3A AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD260KH8
Coding: 0013121
VCID: 3D77817364CF92C9459-8068
Subsystem 1 - Serial number: 6332MSME3E63231AD
Subsystem 2 - Serial number: 6342MSME375132250
Subsystem 3 - Serial number: 6352QSME35023E38F
Subsystem 4 - Serial number: 6362QSME4F070730E
Part No SW: 1K0 953 549 BN HW: 1K0 953 549 BN
Component: J0527 752 0101
Coding: 0000042
Shop #: WSC 00000 000 31414
VCID: 7F0BBB7B2E4340D9175-802A
Part No SW: 1K6 920 874 HW: 1K6 920 874
Component: KOMBIINSTRUMENT VDD 2416
Revision: V0002000 Serial number: VWX7Z0H73N67ZU
Coding: 0000103
Shop #: WSC 05147 996 88872
VCID: 70E96847631D2FA19EF-8025
Reset counter: 254
Mileage: 119707 km
Time: 00:00:34
Coding: 0000103
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 5063
Revision: H07 01 Serial number: 200808F1000109
Coding: E9807F060002020003
Component: IMMO VDD 2416
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 1210
Coding: 0000692
VCID: 387990674BEDB7E196F-806D
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.069 H08 1901
VCID: 36659E5F41F94191843-8063
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 199002005103087F2D040F0F70085FC690FC00
VCID: 0303378B42AB243973D-8056
Subsystem 2 - Part No: 1K0 951 178 A
Component: Neigungssensor 003 0203
Subsystem 3 - Part No: 1K0 951 178 A
Component: Innenraumueberw.003 0203
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000692
VCID: 397F956370E7AEE9691-806C
Part No: 1K0 035 186 AF
Component: Radio GR0 036 0034
Revision: 0003606S Serial number: VWZ2Z2H1224136
Coding: 0040400
VCID: 6ADD7A2F45C1D571D0B-803F
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1301
Coding: 0000144
Shop #: WSC 00046 412 1012566
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0000144
thanx in advance
shafiq
