Help needed - 2011 Tiguan CJAA swap ABS Coding
tb1985
Vernon, BC, Canada
C?ID=90797
I am looking for help with the coding of the ABS module. I have installed a CJAA from a 2011 Golf into the Tiguan, but kept all of the original drivetrain and 4motion setup. The coding in the ECU has been corrected to match the current setup in the vehicle, but I have been unable to find any list of coding options for the older (C4 450) ABS system in this vehicle. If anyone is able to help out with this I would appreciate it!
I have tried:
0026951 - closest so far
0010528 - stock coding with CCTA
0026911
0014623
0002308
0011551
0015623
0026914
0038203
0054337
0076097
0014636
0011554
0002356
0031023
0011567
0010543
0010564
The Vin for the Tiguan is: WVGBV7AX9BW546015
Please ignore the ECU faults. They are being repaired/deleted...
Tuesday,01,February,2022,16:29:13:07498
VCDS Version: 21.9.0.2 (x64)  HEX-NET2 CB: 0.4555.4
Dealer/Shop Name: Vernon Volkswagen
Workshop Code: 000 91474 000000
VIN: 3VWDL7AJ6BM052027   License Plate:
Mileage: 190570km-118414mi   Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 2E 42 44 46 4F 52 53 56 62
          72 77
VIN: 3VWDL7AJ6BM052027   Mileage: 190570km-118414miles
4F-Centr. Electr. II -- Sta:tus: OK 0000
   Part No SW: 03L 997 030 P    HW: 03L 906 019 DA
   Component: R4 2.0l TDI G000AG  9983
   Revision: 12H13---    Serial number:
   Coding: 0050175
   Shop #: WSC 91474 000 00000
   VCID: 3B285E8EBF647473B23-806E
   VINID: 0E69D470745A1927401420021C4F172664
012333 - Relay for High Heater Output
               P302D - 000 - Short to Ground
                    Mileage: 190362 km
                    Voltage: 12.31 V
                    (no units): 0.0
                    Temperature: 48.6°C
                    Bin. Bits: 00011100
                    Temperature: 0.9°C
000899 - Glow Plug Control Module
               P0383 - 000 - Short to Ground - Intermittent - MIL ON
                    Fault Status: 10100000
                    Fault Frequency: 26
                    Mileage: 190487 km
                    Date: 2016.06.23
                    Time: 16:27:57
                    RPM: 1058 /min
                    Voltage: 11.55 V
                    Temperature: 40.5°C
                    Bin. Bits: 11111111
                    Time: 0.00 s
                    Temperature: 36.0°C
001648 - Glow Plug Module 1; Glow Plug Circuit
               P0670 - 000 - Electrical Malfunction - Intermittent - MIL ON
                    Fault Frequency: 14
                    Mileage: 190365 km
                    Date: 2016.06.20
                    Time: 03:34:40
                    RPM: 2185 /min
                    Speed: 94.0 km/h
                    Voltage: 14.14 V
                    Temperature: 72.0°C
                    Bin. Bits: 11111111
                    Time: 0.00 s
                    Temperature: 18.0°C
Readiness: 1 2 0 X X
   Part No SW: 09G 927 750 LQ    HW: 09G 927 750 LQ
   Component: AQ 250 6F           1771
   Revision: 00H90000    Serial number:
   Coding: 0000840
   Shop #: WSC 35914 005 1048576
   VCID: 0B48CE4EAF4484F3C23-805E
Address 03: ABS Brakes        Labels: 5N0-614-109-C4.clb
   Part No SW: 5N0 614 109 Q    HW: 5N0 614 109 Q
   Component: J104    C4 450 V24A 0006
   Revision: --H28---    Serial number: 00000003755289
   Coding: 0026951
   VCID: 39244486B5584663A0F-806C
03190 - Incorrect Vehicle Type
                    Reset counter: 74
                    Mileage: 190571 km
                    Date: 2016.06.24
                    Time: 16:22:60
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 11.25 V
                    Bin. Bits: 00011111
                    Count: 246
                    Hex Value: 0x0000
   Part No SW: 7N0 907 426 L    HW: 7N0 907 426 L
   Component: AC Manuell    H17 0202
   Revision: 00012001
   Coding: 0000000002
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 3D2C5096ADF07A438C7-8068
   Part No SW: 5K0 937 086 L    HW: 5K0 937 086 L
   Component: BCM PQ35 M    011 0046
   Revision: BJ011001
   Coding: 6D580ABB84232EC4008800819000030440015186524D85605C8000000040
   VCID: 3D2C5096AD707A438C7-8068
   Subsystem 1 - Part No SW: 5N1 955 119     HW:              Labels: 1KX-955-119.CLB
   Component: Wischer 14021  013 0203
   Serial number: N1955119   °203!
   Coding: 009795
   Part No SW: 5N0 959 655 P    HW: 5N0 959 655 P
   Component: J234__204 VW10 HI   1918
   Revision: 22014000    Serial number: 003GJP1ELFF0
   Coding: 0012340
   VCID: 4AC60B4AE0BEDDFB395-801E
   Subsystem 1 - Part No: 5N0 959 339 B
   Subsystem 2 - Serial number: 00000000003UPF
   Subsystem 3 - Serial number: 0005.01.110000300000650023ÿ†63
   Subsystem 4 - Serial number: 650023ÿ†6332MTS626360281 ÿ†63
   Subsystem 5 - Serial number: 60281 ÿ†6342MTS649220271 ÿ†63
   Subsystem 6 - Serial number: 20271 ÿ†6351HTS616U4O9KR ÿ†63
   Subsystem 7 - Serial number: 4O9KR ÿ†6361HTS60F74O9KR ÿ†63
   Subsystem 8 - Serial number: 4O9KR ÿ†63727TS6VTVQM9KR ÿ†63
   Subsystem 9 - Serial number: QM9KR ÿ†63827TS6DOJ6M9KJ ÿ
   Subsystem 10 - Serial number: 6M9KJ ÿ
03551 - Functional Restriction of Seat Occupied Recognition
            000 - - - MIL ON
                    Fault Status: 11100000
                    Mileage: 190571 km
                    Date: 2016.06.24
                    Time: 16:21:31
   Part No SW: 5K0 953 501 AT    HW: 5K0 953 569 H
   Revision: FF010040    Serial number: 20110216201142
   Coding: 198A140000
   VCID: 7CAA9D92F66AB34BFB9-8028
   Component: E221__MFL-TAS  H07 0013
   Coding: 820000
   Part No SW: 5N0 920 872     HW: 5N0 920 872
   Coding: 110F01
   VCID: 6FB0BADEB71CD8D34EB-803A
   Part No SW: 7N0 907 530 D    HW: 1K0 907 951
   Component: J533  Gateway H35 0614
   Revision:   H35       Serial number: 190211F2001797
   Coding: 356002
   VCID: 31347CA661288E2318F-8064
01304 - Radio
                    Reset counter: 114
                    Mileage: 190487 km
                    Date: 2016.06.23
                    Time: 16:48:41
   Part No SW: 0AY 907 554 D    HW: 0AY 907 554 D
   Component: Haldex 4Motion      0042
   Coding: 0000005
   VCID: 4CCA0D52EACAC3CB0B9-8018
   Component: IMMO          H20 0420
   VCID: 6A86ABCA8CFE3DFB195-803E
9456681 - Key
          B104C 29 [009] - Implausible Signal
                    Mileage: 190362 km
                    Date: 2022.01.28
                    Time: 02:12:04
   Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
   Revision: A1001003    Serial number: 7669404846
   VCID: 280291C252F2CFEBCF1-807C
   Part No SW: 5N0 959 701 D    HW: 5N0 959 701 D
   Component: Tuer-SG         009 2112
   Coding: 0001205
   VCID: 363E4FBA8446A91B4DD-8062
   Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.286 0802
   Revision: 1AH03831    Serial number: 00110320129701
   Coding: 0000258
   Shop #: WSC 00000 028 00001
   Component: EZE_2         H35 0614
   Coding: 05030100
   VCID: 6FB0BADEB79CD8D34EB-803A
   Component: J245EE20SKB13  H02 0220
   Part No SW: 5N0 959 702 D    HW: 5N0 959 702 D
   Component: Tuer-SG         009 2111
   Coding: 0001204
   VCID: 372042BE834C501356B-8062
   Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
   Component: J540 EPB4  VW-55183 0007
   Revision:   H18       Serial number: 00000000187677
   Coding: 0010000
   VCID: 333876AE9734BC336A3-8066
                    Fault Status: 01110000
                    Reset counter: 74
                    Mileage: 190361 km
                    Date: 2016.06.19
                    Time: 14:32:54
                    Voltage: 14.30 V
                    Count: 98
                    Hex Value: 0x1250
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Fault Status: 01110101
                    Reset counter: 74
                    Mileage: 190265 km
                    Date: 2016.06.11
                    Time: 04:58:36
                    Voltage: 14.30 V
                    Count: 99
                    Hex Value: 0x1250
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Reset counter: 74
                    Mileage: 190361 km
                    Date: 2016.06.19
                    Time: 14:32:52
                    Voltage: 14.30 V
                    Count: 41
                    Hex Value: 0x1250
                    Hex Value: 0x0001
                    Hex Value: 0x0101
Address 56: Radio
   Part No SW: 5N0 959 703 E    HW: 5N0 959 703 E
   Component: Tuer-SG         007 2102
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
   Part No SW: 5N0 959 704 E    HW: 5N0 959 704 E
   Coding: 0001168
   VCID: 3A265B8AB05E4D7BA95-806E
   Part No SW: 5K0 035 730     HW: 5K0 035 730
   Component: TELEFON       H09 1020
   Revision: 1B001001    Serial number: 00007669331401
   Coding: 0A00000000010100
   ASAM Dataset: UHVNA A01009
   ROD: UHVNA.rod
   VCID: 6296C3EA74CE65BBD15-8036
          B104F 13 [009] - Short to GND
                    Reset counter: 74
                    Mileage: 190487 km
                    Date: 2022.01.31
                    Time: 16:49:47
          B104E 13 [009] - Short to GND
                    Reset counter: 72
                    Mileage: 190487 km
                    Date: 2022.01.31
                    Time: 16:49:45
0022 - Radio
          U1066 00 [000] - No Communication
          [Steuergerät Radio (RNS): kein Signal/Kommunikation]
End----(Elapsed Time: 01:21, VBatt start/end: 10.9V/10.9V. VIgn 10.8V)-----
JMR
Romania
C?ID=432218
I dont think it ll work , your car is a 7N0 chassis and the Abs is a 5N0 part..? I hope i am wrong... Do you happen to have an older scan or can you plug the original abs in the harness and see your old coding ?
tb1985
Vernon, BC, Canada
C?ID=90797
The car is a 5N chassis, the ECU is from a Golf with the immobilizer deleted. I put the CJAA in a 2011 Tiguan, everything is original to the vehicle except the engine/ECU.
The ABS was coded as 0010528 is stock trim with the CCTA, but the balance shaft was seized when I bought it, so I swapped the diesel in since we were never able to get the Tiguan is diesel trim here.
The ABS does currently function, just the lights are on and it has a static fault for incorrect vehicle.
  • Informative
kamold
Australia
C?ID=241363
This is a massive speculation - but what if you change the VIN in the ECU to a Tiguan VIN?
I'm guessing the ABS is reading the VIN CAN message and taking issue with the fact that it is seeing AJ where it would expect to see 5N.
tb1985
Vernon, BC, Canada
C?ID=90797
Its a possibility, the tuner I'm working with would like to keep that option as a last resort, just incase of any unintended consequences. But still something I may try.
I have also considered just getting an ABS module from a newer Tig from an auto recycler and seeing if it may code easier...
kamold
Australia
C?ID=241363
A newer ABS I don't think will be the answer. It will still be a TRW450, so will expect to be in a car that has an EPB (Tiguan or Passat). The ECU came from a Golf that has MK60EC1 ABS.
n4s
Portugal
C?ID=351319
The problem is the VIN, check that makes error appear. That coding might be for 5N
Reset counter: 74
Mileage: 190571 km
Date: 2016.06.24
Time: 16:22:60
In TRW450m, channel 63 if you disable it, it will disable this verification. Don't know if in TRW450 is the same but try it.
  • Informative
tb1985
Vernon, BC, Canada
C?ID=90797
Reset counter: 74
Mileage: 190571 km
Date: 2016.06.24
Time: 16:22:60
I will give it a shot! See what happens. Is this done through the adaptation menu?
