Hi everyone,
Im currently working on a VW Golf Mk5 1.6 petrol 2004.
I've replaced the Lambda O2 sensor before cat and now I get Open Circuit and Short To Ground in my scans.
Does anyone have any tips on what I can do to find the culprit for the issue?
Before replacement, Short To Ground never appeared in my scans, only after i replaced the O2 with a brand new one.
Also to add, the new O2 sensor has the same amount of pins (5 pin" connector and they're all in the same place.
Thanks in advance, scan below is after clearing all codes once, and going for a quick drive around (scan below is 2nd scan after installing the new sensor)
Saturday,22,January,2022,21:00:14:18868
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
VIN: WVWZZZ1KZ5P012752 License Plate: DANNY LAMBDA AFTER TRIP
Mileage: 141100km-87675mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ5P012752 Mileage: 141100km-87675miles
Address 01: Engine Labels: 06A-906-033-BGU.lbl
Part No: 06A 906 033 CA
Component: SIMOS71 1.6l 2V 5755
Revision: --H03--- Serial number: VWZ7Z0D0068814
Coding: 0000071
Shop #: WSC 00028 028 00001
VCID: 6099A06FF647384BC71-8034
VINID: 9E69EAAAA05BA858000421C5082BD95511
17524 - Oxygen (Lambda) Sensor Heating; B1 S1
P1116 - 009 - Open Circuit
RPM: 608 /min
Mass Air / Rev.: 87.2 mg/str
Voltage: 2.100 V
Voltage: 13.97 V
17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2
P1117 - 007 - Short to Ground
RPM: 1792 /min
Mass Air / Rev.: 179.9 mg/str
Voltage: 0.520 V
Voltage: 14.48 V
Readiness: 1110 1101
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0019073
VCID: 3A2D3207305B029BA95-806E
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 AC
Component: ClimatronicPQ35 066 0404
VCID: 6889B84F1E77400B0F1-803C
00710 - Defroster Flap Positioning Motor (V107)
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 S HW: 1K0 937 049 S*
Component: Bordnetz-SG 1.0 H30 0704
Revision: 00030000 Serial number: 00000000836442
Coding: EC8F8F0600041800001400001400000000
VCID: 3FDB43132B7927B39EB-806A
Subsystem 1 - Part No: 1K1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Subsystem 2 - Part No: 1K0 955 559 M Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 005 0605
Coding: 00217125
Part No SW: 1K0 909 605 D HW: 1K0 909 605 D
Component: 01 AIRBAG VW8 022 0600
Revision: 05022000 Serial number: 0033JD0EZSD%
Coding: 0012337
VCID: 2D07095BF115A5233C7-8078
Subsystem 1 - Serial number: 6332MSME30104603
Subsystem 2 - Serial number: 6342MSME7A325B02
Subsystem 3 - Serial number: 6351HSME06541903
Subsystem 4 - Serial number: 6361HSME7E590D03
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 012 0030
Coding: 0000012
VCID: 3039102FE627C8CB171-8064
Part No: 1K0 920 861 A
Component: KOMBIINSTRUMENT VDD 0814
Coding: 0007103
Shop #: WSC 00032 218 21235
VCID: 270BFB73D3E98F73C6B-8072
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 270010460303E2
Coding: 3D3F0340070002
VCID: 290FFD4BC5FDB903D0F-807C
Component: IMMO VDD 0814
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1K0 959 701 E
Component: Tuersteuergeraet 09 0147
Coding: 0000052
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 G
Component: EPS_ZFLS Kl.1 1401
VCID: 2F3B1353FB19D7330EB-807A
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 BL
Component: 01 KSG 0301
Coding: 80C802087F2D8404084F01E010
VCID: 7BA3F7037FE1FB93F23-802E
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1K0 959 702 E
Coding: 0000052
VCID: 313F152BED2DC1C318F-8064
Address 56: Radio Labels: 1K0-035-1xx-56.clb
Part No: 1K0 035 186 J
Component: Radio GR0 0014
Revision: 0001002S Serial number: VWZ2Z2D2009287
Coding: 0020200
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 C
Component: Tuersteuergeraet 06 0202
Coding: 0000016
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 C
Coding: 0000016
End----------(Elapsed Time: 00:59, VBatt start/end: 14.3V/14.3V)-----------
