Two weeks ago removed MAF sensor to clean it. MPG was about 2 mpg low and I hadn't performed this maintenance in a while. The next day after an engine restart I received the following codes, G70, P0102. Removed and replaced the MAF with a BREMI MAF for this vehicle. Cleared the code. Took a 15 to 20 mile ride with no codes. Stopped and turned off the engine. As soon as I restarted the engine , "check engine" light was back on. Same codes:
Mass Air Flow Sensor (G70)
P0102 - 000 - Signal too Low
Not seeing any vacuum or intake hose leaks. Fuel mileage increased 3 to 4 miles per gallon. Air filter has about 25K miles on it.
Saturday,22,January,2022,13:03:29:32859
VCDS Version: 21.9.0.2 (x64)
VIN: 3VWST71KX6M628479 License Plate:
Mileage: 281320km-174804mi Repair Order: 2006_Jetta_TDI_01.22.22
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: 3VWST71KX6M628479 Mileage: 281320km-174804miles
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AC HW: 028 101 223 9
Component: R4 1,9L EDC G000DG 7551
Revision: --H01--- Serial number: VWZ7Z0E2329603
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 64C7FA0BA7DBE4A9C5-8030
VINID: 0E69E390705BA0674608810724D14B86E8
000258 - Mass Air Flow Sensor (G70)
Fault Status: 01110000
Mileage: 281230 km
RPM: 1008 /min
Duty Cycle: 100.6 %
Bin. Bits: 00101000
Mass Air / Rev.: 530.0 mg/str
Mass Air / Rev.: 0.0 mg/str
Readiness: 1 1 0 0 1
Part No SW: 02E 300 042 H HW: 02E 927 770 AD
Component: GSG DSG 070 0913
Revision: 04007000 Serial number: 00000505060581
VCID: 183F9EFB2B13F04999-804C
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Revision: 00T12001
Coding: 0021122
VCID: 408F169B1303988901-8014
Part No: 1K0 820 047 DL
Component: Climatic PQ35 090 0505
VCID: 71E9835F68294101BE-8024
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000105351
Coding: 14018E234004180000140000001400000008730B5C
Shop #: WSC 08287 444 58823
VCID: 2A5B5433857F72D93F-807E
Subsystem 1 - Part No: 1K1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 08287
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 D HW: 8E0 035 593 D
Component: SDAR SIRIUS H03 0060
Revision: 00000000 Serial number: AUZ4Z7E4009224
Reset counter: 54
Mileage: 281230 km
Time: 00:58:08
Part No SW: 1K0 909 605 E HW: 1K0 909 605 E
Component: 1S AIRBAG VW8R 024 6300
Revision: 03024000 Serial number: 0037KD02GVW
Coding: 0012627
VCID: 2E535823B9971EF9E3-807A
Subsystem 1 - Part No: 1K0 959 339 B
Component: BF-Gewichtsens. 006 0003
Subsystem 2 - Serial number: 6332MSME0A0D38038
Subsystem 3 - Serial number: 6342MSME0A0C4D3ES
Subsystem 4 - Serial number: 6351HSME07230F745
Subsystem 5 - Serial number: 6361HSME0707054B2
Subsystem 6 - Serial number: 63727SME07104A70W
Subsystem 7 - Serial number: 63827SME070F4F7CL
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 034 0070
Coding: 0010021
VCID: 78FFBE7B0B53104979-802C
Part No: 1K0 920 952 D
Component: KOMBIINSTRUMENT 3HL 1012
Coding: 0023203
VCID: 2B5551378A856BD1C4-807E
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 280010542184C5
Coding: 3F3F0B60071002
Component: IMMO 3HL 1012
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2339
Coding: 0001269
VCID: 3663704341C72639AB-8062
00109 - Left Mirror Turn Signal Lamp (L131)
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 326B4C53ADAF3A1987-8066
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AF
Component: KSG 0401
Coding: 137803281B09058F880F048051A0
VCID: 74E78A4B173B742955-8020
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001269
VCID: 377D7D4746CDDF31B0-8062
Address 56: Radio Labels: 1K0-035-1xx-56.clb
Part No SW: 1K0 035 180 C HW: 1K0 035 180 C
Component: Radio ZSW 016 0017
Revision: 00016000 Serial number: VWZ5Z7E6005506
Coding: 0040400
VCID: 204FB61BF343B88961-8074
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2416
Coding: 0000144
VCID: 3169435FA8A90101FE-8064
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
Component: PTC-Element 0404
VCID: 2D515F2FB49165E1DA-8078
