Hello!
While back instrument cluster of my Audi A3 died and went completely dark without any prior signs or a good reason why. After checking all the fuses and wires, I got another instrument cluster (with the same part number) from a scrapyard and tried it on to see if the fault really is with the old cluster. The new cluster lit up and so I got the old one fixed. After the repair, car starts and drives fine. Many of the previous dtc's disappeared but still few of them remain and they have a warning light on the dash. I added the scan of the current situation below along with advancedID's.
Since it was mentioned in the post give any info about the work done previosly: I have also retrofitted A5 3-spoke mfsw and foglights with the different lightswitch. Also the CAN-gateway dtc is not related here I think.
So it seems I need coding for the ABS module to continue. I also added the information here I think you will need.
info:
Audi A3 2009 sportback WAUZZZ8P19A104830
2.0tdi CBAB
6-speed manual
312mm, 282mm
No PLA sensors, no TPMS
Anyones help is greatly appreciated!
Thanks in advance
Auto scan of the current situation after clearing all the dtc's and running it again.
AdvancedID engine
AdvancedID Immobiliser
info:
2.0tdi CBAB
6-speed manual
312mm, 282mm
Thanks in advance
Monday,17,January,2022,17:14:32:13641
VCDS Version: 21.9.0.2 (x64) HEX-NET2 CB: 0.4555.4
Dealer/Shop Name:
Workshop Code: 007 00007 000007
VIN: WAUZZZ8P19A104830 License Plate:
Mileage: 281550km-174947mi Repair Order:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 47 52 55 56 62 69 72
VIN: WAUZZZ8P19A104830 Mileage: 281550km-174947miles
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 EA HW: 03L 906 022 BQ
Component: R4 2.0l TDI G000SG 9978
Revision: 13H01--- Serial number: AUX7Z0I0FNE0WQ
Coding: 0000172
Shop #: WSC 00007 007 00007
VCID: 6882D2DEEE708FDB0F1-803C
VINID: 9D196AAAA2200494410042030050D2935A
U0155 - 000 - - Intermittent
Fault Frequency: 48
Mileage: 281546 km
Date: 2021.11.24
Time: 00:56:52
Temperature: -0.9°C
Voltage: 11.86 V
Bin. Bits: 00000000
Torque: 126.0 Nm
Temperature: 16.2°C
001299 - Incorrect Immobilizer Key
P0513 - 000 - - Intermittent
Mileage: 234126 km
Date: 2019.06.26
Time: 00:00:10
RPM: 943 /min
Voltage: 11.32 V
Absolute Pres.: 958.8 mbar
Absolute Pres.: 938.4 mbar
Temperature: 3.6°C
Temperature: 24.3°C
053284 - Please Check Fault Codes in Instrument Cluster
U1024 - 000 - - Intermittent
Mileage: 281546 km
Time: 31:63:63
Voltage: 11.40 V
Temperature: 74.7°C
Temperature: 49.5°C
Temperature: 29.7°C
Temperature: 88.2°C
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 CE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0120
Revision: 00H35001
Coding: 000000000000000000000000000000000000
Shop #: WSC 44608 002 1048576
VCID: 77A081A2BFCE102396B-8022
Reset counter: 117
Mileage: 281550 km
Date: 2021.11.24
Time: 00:02:30
Count: 7
Count: 195
Count: 41728
Fault Status: 01100101
Reset counter: 117
Mileage: 281550 km
Date: 2021.11.24
Time: 00:02:30
Count: 7
Count: 279
Count: 41728
Reset counter: 117
Mileage: 281550 km
Date: 2021.11.24
Time: 00:02:30
Count: 7
Count: 295
Count: 41728
Reset counter: 117
Mileage: 281550 km
Date: 2021.11.24
Time: 00:02:30
Count: 7
Count: 270
Count: 41728
Part No SW: 8P0 820 043 BH HW: 8P0 820 043 BH
Component: KlimavollautomatH09 0100
Revision: 000141 Serial number: 8P0820043BH
VCID: 73B8B5B2A7B67C03AA3-8026
Fault Status: 01101000
Reset counter: 117
Mileage: 234128 km
Date: 2019.06.26
Time: 00:11:18
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000009309624
Coding: 2B0A0F83801413806F0000640000000064084A056406020B642800000000
VCID: 48C2325E8EB0AFDB2F1-801C
Subsystem 1 - Part No: 8P1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056627
Shop #: WSC 00007
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003CA004LV72
Coding: 303142383038303030354A55304C38503053
Shop #: WSC 06314 000 00000
ROD: EV_Airba10AURB4.rod
VCID: 49C4375A993A56D330F-801C
Serial number: 3572DRB4000086D502BV
Serial number: 3582DRB4000086D9396+
Serial number: 35128RB400004ACD61CX
Serial number: 35228RB400004ACC93E/
Serial number: 35547RB400004A3DA4BZ
Serial number: 35647RB400004A3DAE6+
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0002041
VCID: 41D42F7AAD8A9E93E8F-8014
Component: E0221 H02 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 931 S HW: 8P0 920 931 S
Component: KOMBIINSTR. VDO H19 0860
Revision: D0H19007 Serial number: 2240I007068620
Coding: 0005128
VCID: 43D82572B7968C83FA3-8016
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K091190A62
Coding: E9837F46100202002102
VCID: 372041A2F34ED02356B-8062
Reset counter: 117
Mileage: 281550 km
Date: 2021.11.24
Time: 00:02:32
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0BR 907 554 A HW: 0BR 907 554 A
Component: Haldex 4Motion 3016
Coding: 0000005
Revision: D0H19007 Serial number: AUX7Z0I0FNE0WQ
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0060
Coding: 0000180
Part No: 1K0 909 144 E
Component: EPS_ZFLS Kl. 233 2501
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2C0A6ECE3A0863FB2B9-8078
Fault Status: 11100101
Mileage: 281550 km
Date: 2021.11.24
Time: 00:02:28
Battery Volts: 11.5 V
DD
Temperature: 23.0°C
Count: 3
Steering Angle: 0.00°
Count: 1
SteerAng n.Init
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 L
Component: KSG H11 0080
Coding: 0080200002087F0985054C8F0167
VCID: 45DC3B6AB9A2B2B3D47-8010
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 D HW: 8P4 035 382 D
Component: AB2 SUBWOOFERBOXH06 0180
Revision: 00005 Serial number: 30674803185823
VCID: 353C4BAAE9422233447-8060
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000180
VCID: 44DA266EB2988BBBC39-8010
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P3 907 357
Component: Dynamische LWR H01 0010
Coding: 0000013
VCID: 7AA6989680DC0D4BE95-802E
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 P HW: 8P0 035 186 P
Component: R Concert2+ H03 0270
Revision: 00H03000 Serial number: AUZ1Z3I9718042
Coding: 0110231
VCID: 3FD02982DB7EE8639EB-806A
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0000144
Shop #: WSC 06314 000 1012544
Address 69: Trailer
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0000144
VCID: 42D62076A88C858BF15-8016
End----(Elapsed Time: 01:22, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
Address 03,1K0 907 379 CE,recoded (Long Coding),from,000000000000000000000000000000000000,to,13424012092300FDC80F02E6901D00810000,(00007/007/00007),
Control Module Part Number: 1K0 907 379 CE
Component and/or Version: ESP MK60EC1 H35 0120
Software Coding: 000000000000000000000000000000000000
Work Shop Code: WSC 44608
Advanced Identification
Flash Status
Programming Status: 00000000
Flash Date: 2017.10.24
Flash Tool Code: 1048576 002 44608
Misc.
Hardware number: 1K0 907 379 AE
Workshop System Name: -----
VCDS Info:
Labels: 1K0-907-379-60EC1F.clb
Flash Status
Misc.
VCDS Info:
Flash Status
Misc.
VCDS Info:
Flash Status
Misc.
VCDS Info:
Address 01: Engine
Control Module Part Number: 03L 906 022 EA
Component and/or Version: R4 2.0l TDI G000SG 9978
Software Coding: 0000172
Work Shop Code: WSC 00007
Identification: BPG-810
Revision: 13H01---
Date: 14.01.09
Test stand number: 1335
Manufacturer number: 0263
Flash Status
Programming Attempts: 2
Successful Attempts: 2
Required Conditions: 00000000
Flash Tool Code: 15728640 002 40195
Flash Date: 27.03.17
Software
Misc.
Hardware number: 03L 906 022 BQ
Lot Number: 78
Type Lock:
Car Info
Chassis Number: WAUZZZ8P19A104830
Engine code: CBA
VCDS Info:
Readiness: No script available
AdvancedID engine
Thursday,20,January,2022,16:56:43:13641
Dealer/Shop Name:
Address 01: Engine
Revision: 13H01---
Date: 14.01.09
Flash Status
Software
Misc.
Lot Number: 78
Type Lock:
Car Info
Engine code: CBA
VCDS Info:
Thursday,20,January,2022,16:42:29:13641
Dealer/Shop Name:
Control Module Part Number: 8P0 920 931 S
Component and/or Version: KOMBIINSTR. VDO H19 0860
Software Coding:
Work Shop Code: WSC 00000
Identification: VDD-024
Revision: D0H19007
Date: 14.01.09
Test stand number: 7601
Manufacturer number: 1178
Misc.
Hardware number: 8P0 920 931 S
Lot Number:
Type Lock: VDD-
Immo Challenge: 5B 12 4C BA
Car Info
VCDS Info:
