Volkswagen T5 ABS coding.
Pasa34
Wales, UK
C?ID=497689
Hi, I have a VW T5 with all the related ABS fault light on. I plugged in VCDS and it keeps saying both rear wheel sensors have no electrical contact and am unable to clear the fault.
I contacted a repair company and said they have had the same unit in for repair and unfortunately was not repairable.
I have bought a used replacement ABS unit identical to the one fitted.
is there a step by step guide anyone can offer me to code the new unit to the van
many thanks.
Westbury, UK
Not all T5s are built the same, so you need to post an Auto-Scan of your T5 so we can see how it is configured so we can advise.
Pasa34
Wales, UK
C?ID=497689
Ok thanks I’ll give it a go later.
Pasa34
Wales, UK
C?ID=497689
Hi, you will have to bear with me on this one im new to this!! i did the autoscan then cicked on save but i cant find it to paste on here!!
I took some pictures put I cant find a way of pasting them onto here either??
Westbury, UK
VCDS auto-saves scans into the folder C:\Ross-Tech\VCDS\Scans - open the text file using Notepad then select all and copy. Then start a reply in this thread, click on the </> icon on the editor tool bar and paste the scan into ther.
To post a picture you must save it to an image sharing site (I use imgur) then click on the direct image link and paste that into the reply using the Insert Image icon on the editor tool bar.
Pasa34
Wales, UK
C?ID=497689
Saturday,22,January,2022,11:12:01:05453
VCDS Version: 21.9.0.2 (x64)  HEX-V2 CB: 0.4555.4
VIN: WV1ZZZ7HZCH054454   License Plate:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 56 0B
VIN: WV1ZZZ7HZCH054454   Mileage: 292150km-181533miles
Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 022 CH    HW: 03L 907 309 K
   Component: R4 2,0L EDC   H43 9126
   Revision: 26H43---    Serial number: 00000000000000 CVN: FA2BB036
   Coding: 01194012230400080000
   Shop #: WSC 02736 790 50316
   ASAM Dataset: EV_ECM20TDI01103L906022CH 002012
   ROD: EV_ECM20TDI01103L906022CH_002.rod
   VCID: 6D87C173AD10AAB37C7-8038
   VINID: 9E606AAAA1D8A9360014410510405A48F4
5174 - Fuel Pressure Regulation
          P1065 00 [101] - Regulation Discrepancy
                    Mileage: 292150 km
                    Date: 2022.01.18
                    Time: 21:38:26
                    Engine RPM: 1746.50 /min
                    Normed load value: 47.1 %
                    Vehicle speed: 11 km/h
                    Coolant temperature: 13 °C
                    Intake air temperature: 8 °C
                    Voltage terminal 30: 14.700 V
                    Engine status: COENG_RUNNING
                    Fuel temperature: 8.4 °C
                    Mean injection quantity: 28.60 mg/stroke
                    Pressure control valve adaptation factor: 1.3000
                    Fuel pressure regulator valve: specified value rail pressure: 1098300 hPa
                    High fuel pressure: specified value: 1119900 hPa
                    Fuel high-pressure: actual value: 1117200 hPa
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 H    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0107
   Revision: 00H43001
   Coding: 508724AD89A90A9924A69176A96210
   Shop #: WSC 02736 790 49152
   VCID: 372B231B9F4CD06356B-8062
                    Fault Status: 01101100
                    Reset counter: 117
                    Mileage: 292150 km
                    Date: 2016.06.10
                    Time: 21:37:23
                    Count: 16512
                    Count: 769
                    Count: 80
                    Count: 512
                    Reset counter: 117
                    Mileage: 292150 km
                    Date: 2016.06.10
                    Time: 21:37:23
                    Count: 16512
                    Count: 769
                    Count: 64
                    Count: 512
   Part No SW: 7E5 907 047 BC    HW: 7E5 907 047 BC
   Component: Climatic-T5   H19 0404
   Revision: 00001009
   Coding: 0000000002
   ROD: EV_ClimaT5Basis.rod
   VCID: 71BFDD03B1284E5358F-8024
9480465 - Control Circuit for A/C Compressor
          B10A9 11 [009] - Short to Ground
                    Reset counter: 117
                    Mileage: 292149 km
                    Date: 2022.01.05
                    Time: 22:26:26
   Part No SW: 7H0 937 086 H    HW: 7H0 937 086
   Component: BCM T5GP M++4 H47 0251
   Revision: BM047001    Serial number: 0428 278110792
   Coding: A0A0393A0E212013002008102C2B8C540000430F60060000300000000000
   Shop #: WSC 02736 790 00000
   VCID: 382920279252DF1B5F1-806C
   Subsystem 1 - Part No SW: 7E0 959 801 C    HW: 7E0 959 801 C  Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  003 3311
   Coding: 050000
   Subsystem 2 - Part No SW: 7E0 959 802 C    HW: 7E0 959 802 C  Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  003 3311
   Coding: 040000
7 Faults Found:
03430 - Terminal 30 for Turn Signals and Brake Lights
                    Fault Status: 00101011
                    Reset counter: 157
03303 - Response Closing Status of Rear Left Door
                    Fault Frequency: 68
                    Reset counter: 157
                    Mileage: 270785 km
                    Date: 2015.06.01
                    Time: 12:01:35
03304 - Response Closing Status of Rear Right Door
                    Reset counter: 157
                    Mileage: 292139 km
                    Date: 2016.04.19
                    Time: 00:02:41
                    Fault Frequency: 8
                    Reset counter: 157
                    Mileage: 292139 km
                    Date: 2016.04.03
                    Time: 22:12:57
                    Fault Frequency: 152
                    Reset counter: 157
00538 - Reference Voltage
                    Reset counter: 157
03589 - Switch for Driver Side Window Regulator
                    Fault Status: 00101110
                    Reset counter: 157
                    Mileage: 292131 km
                    Date: 2016.01.17
                    Time: 00:50:56
   Component: VW10Airbag009 H06 0013
   Revision: --------    Serial number: 003HL006Z9SX
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3537291385C02273447-8060
13635840 - Supply voltage
          [Powersupply lower threshold fall short of]
                    Reset counter: 157
                    Mileage: 292139 km
                    Date: 2021.11.25
                    Time: 01:40:34
   Part No SW: 7E0 920 960 E    HW: 7E0 920 960 E
   Component: KOMBI         H04 0305
   Coding: 460200
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   VCID: 2B030F6B53846483223-807E
   Part No SW: 6N0 909 901     HW: 7H0 937 086
   Component: GW-K-CAN TP20 H47 0251
   Revision: BM047001
   Coding: 042300
   VCID: 70B9D807BAA2475B571-8024
   Component: IMMO          H04 0305
   VCID: 6A8DCA6F9CFEBD8B195-803E
   Part No SW: 7E0 035 156 B    HW: 7E0 035 156 B
   Component: Radio         H42 0105
   Revision: R0000000    Serial number: VWZAZ1L2274396
   Coding: 0000020001
   Shop #: WSC 02734 790 00000
   VCID: 221DE24F24CEA5CB915-8076
                    Fault Status: 00110010
                    Reset counter: 157
                    Mileage: 292139 km
                    Date: 2016.04.04
                    Time: 00:02:10
                    Reset counter: 157
                    Mileage: 292139 km
                    Date: 2016.04.04
                    Time: 01:30:33
End----------(Elapsed Time: 01:37, VBatt start/end: 12.1V/12.1V)-----------
Is the above scan from with the old module installed or the replacement?
Pasa34
Wales, UK
C?ID=497689
Hi, thanks for the reply, the scan is with the old unit still fitted. Didn’t want to remove anything till I’m sure what I’m doing is correct.
Thanks again.
I haven't seen a "replacement" procedure for this exact ABS, but I imagine it's copy & paste the coding, then do the Basic Settings in Groups 060, 063, 066, and 069.
Pasa34
Wales, UK
C?ID=497689
Ok, thanks again for the reply, I’ll give it a try.
JMR
Romania
C?ID=432218
if you have space and you're a bit handy you can " split " the abs in 2 and just mount the ecu of the abs on your old hydraulic pump ( that way you dispense of brake bleeding, new fluid and all that headache ). However, before installing the new abs, just plug it in and do a scan, make sure the 2 errors have disappeared from scan ( plug in new/second hand abs module , turn ignition on, scan abs, clear codes, ignition off, ignition on, rescan abs, check for previous codes if are present). If still present, you have an electrical problem ( wires chaffed, broken )
Here is what i mean by splitting abs in 2 : minute 3:13 starting. The black unit is the abs ecu, you just plug it in over the old hydraulic unit present on the car.
Pasa34
Wales, UK
C?ID=497689
Hi, Thanks for the reply. Sounds like a good idea I’ll try it a bit later I have all ready had that section off to check for corrosion on the plugs. All was fine whith it and also checked the wiring to the back sensors as far as I could before committing to a replacement abs unit.
iichel
Netherlands, eastern part
C?ID=284912
is it possible to split the ABS while it's assembled in the car?
JMR
Romania
C?ID=432218
If you have space yes..why not ? It s held by 4-6 bolts
iichel
C?ID=284912
Yes, I know. But the question is often, do you have space :D
  • Agree
Reactions: JMR
Pasa34
Wales, UK
C?ID=497689
Hi, all sorted now, did as you posted JMR. On the T5 just enough room to separate the ABS unit.
I owe you all a beer👍 Big fan of the VCDS….
