P0601 00 (036) memory check sum error - CAYB Golf 1.6 TDI
davidbp
C?ID=438179
Can anyone help, a couple of months back I replaced an injector on a CAYB Golf 1.6 TDI. yesterday the car was brought back to me with a diesel knock between 1250 and 2500 rpm, after 2500 rpm perfect. They reported the car broken down two days ago with the coil light on, they took a picture of the fault code before the mechanic cleared the code.
the fault was P0601 00 (036) memory check sum error.
After clearing the fault, the car seem to be fine and hasn't produced a code since. What concerning me is the diesel knock which is now present since the code been reset.
Other threads I have read quote its usually a permanent fault with a defective ecu, i notice Rosstech quote Low voltage - which you could relate to an intermittent fault but what's really confusing is how that would cause diesel knock.. any ideas would be greatly received, I cant find anything wrong.
Possible Causes​
  • Engine Control Unit (ECU) defective
  • Flash ROM (used in aftermarket "chips") defective
  • Low Voltage
Possible Solutions​
  • Replace ECU
  • Contact aftermarket chiptuner for repair of their chip
  • Check and test Battery and Charging system
JMR
Romania
C?ID=432218
please post an Auto-Scan , also verify injector compensation loss and post screenshot
Jef
HQ
Load test powers/grounds of ECM and verify there is no voltage drop under load. To that end, I personally suggest using the 180 LOADpro for this type of testing.
davidbp
C?ID=438179
The first thing I checked, was for corrosion on the ECU terminal and resistance on the main lines. I have not performed an insulation test, i cant find my tester. I will see if i can borrow one today.
davidbp
C?ID=438179
Hi JMR
Friday,21,January,2022,12:13:48:17866
VCDS Version: 21.9.0.2  HEX-V2 CB: 0.4555.4
VIN: WVWZZZ1KZAW083138   License Plate:
Mileage: 156140km-97020mi   Repair Order:
Chassis Type: 1K-VW36 (1K0)
VIN: WVWZZZ1KZAW083138   Mileage: 156140km-97020miles
Address 01: Engine (J623-CAYB)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 CQ    HW: 03L 906 023 A
   Component: 1,6l R4 CR td H23 4971
   Revision: --------    Serial number: 00000000000000 CVN: 48D6E9F5
   Coding: 00114014030500080000
   ASAM Dataset: EV_ECM16TDI02103L906023CQ 001004
   ROD: EV_ECM16TDI02103L906023CE.rod
   VCID: 77ABE151EF49181396B-8022
   VINID: 9E69EAAAA05BA919C0203043209C84C438
Readiness: 1010 0000
   Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 133B200D092A00FDC80C04E7902100803000
   VCID: 7EA5F475C0F3295BD5D-802A
   Part No SW: 3C8 907 336 H    HW: 3C8 907 336 H
   Component: Climatic      H13 0203
   Revision: 00006001
   Coding: 0000000000
   ASAM Dataset: EV_Climatic A01001
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 323D104544AB3D3B615-8066
   Part No SW: 1K0 937 085 D    HW: 1K0 937 085 D
   Component: BCM PQ35  B+  103 0541
   Revision: 00103 AE
   Coding: 40180A3A9025189044000080100000E443010088524D8160648000200000
   VCID: 30391A4D4A270F2B171-8064
   Component: Wischer 16070  21  0501
   Coding: 009795
   Part No SW: 5K0 959 655     HW: 5K0 959 655
   Component: AirbagVW10    035 0604
   Serial number: 003C2RA1JH49
   Coding: 00003230
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
   ROD: EV_AirbaVW10SMEVW360.rod
   Component: S.Sens.Fahr.V  U01 ----
   Serial number: 1F667049ZZZZZZZZZZZZ
   Component: S.Sens.Beif.V  U01 ----
   Serial number: 4A4E7549ZZZZZZZZZZZZ
   Serial number: 28523457ZZZZZZZZZZZZ
   Serial number: 264F3465ZZZZZZZZZZZZ
   Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
   Component: J0527           053 0111
   Coding: 0000004
   VCID: 03538581A71144B3BA3-8056
   Part No SW: 5K0 920 960 J    HW: 5K0 920 960 J
   Component: KOMBI         H06 0206
   Coding: 470B00
   VCID: 3431165DBEBF330B739-8060
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H16 5223
   Revision:   H16       Serial number: 4120K0972808DC
   Coding: E9801F06000202000003
   VCID: 6695BC15B463919B3DD-8032
                    Reset counter: 101
                    Mileage: 155046 km
01304 - Radio
                    Reset counter: 20
                    Mileage: 155046 km
   Component: IMMO          H06 0206
   Part No SW: 5K0 959 701 B    HW: 5K0 959 701 B
   Component: Tuer-SG         009 2110
   Coding: 0000564
   VCID: 313F1F494D2D062318F-8064
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 69     2901
   Revision: 00H17000
   VCID: 2F3B19315B1910D30EB-807A
   Part No SW: 5K0 959 702 D    HW: 5K0 959 702 D
   Component: Tuer-SG         009 2124
   Coding: 0000564
   VCID: 3431165DB23F330B739-8060
davidbp
C?ID=438179
JMR
Romania
C?ID=432218
You have 2 very bad injectors ( 1 and 2 )
davidbp
C?ID=438179
Hi JMR injector 1 is New, it was replaces late November 2021, main dealer supplied. I was not sure if it was just over compensating.. sound like it may not be..
recommendation, replace i take it, i take it..
iichel
Netherlands, Operation Market Garden
C?ID=284912
Had a similar case on a car some time ago on a similar Golf 6 1.6 TDI. Customer requested to replace a lot, with no avail. Replaced 2 injectors, DPF sensor etc etc even though I didn't think it was necessary...
Finally decided to replace a full set ECU/key/cluster but then the customer decided to bail on me since things were getting too expensive.
To quote, I was enabling him to replace a lot of unnecessary parts.
Good thing is, I'm now the proud owner of two brand new CAY injectors and a key/ECU/cluster set :cool:
JMR
Romania
C?ID=432218
Injector 1 and 2 compensation rate are nowhere near acceptable limits.
Please check my thread for injector rates
https://forums.ross-tech.com/index.php?threads/30550/
And here is another procedure which might help you getting a better injector rates provided that they are first mechanically set to the best rate .
JMR
Romania
C?ID=432218
^ that thread is for PD injectors, the CAY engine is common rail.
No matter , injector rates on pd or common rail is the same trust me. There is also an Audi A6 2.7 common rail..see injector rates.
davidbp
C?ID=438179
HI JMR - I tried to carry out the injector minimum quantity deviation adaptation back in November but it doesn't seem to be available for CAYB on VCDS, I had previously raised this with Uwe @rosstech after being advised to do this adaption when fitting a new injector.
Not sure why it not available.
  • Informative
Reactions: JMR
JMR
Romania
C?ID=432218
you can also adjust injector mechanically..there is a video on YT about that too
davidbp
C?ID=438179
Hi JMR, I tried to find that video but it like trying to find a needle in a haystack on YT. If you got a link it would be much appreciated.
Picked up two new injector's today from a VDO repair centre, ouch, why do they have to be so expensive.. speaking to the guys there, it a common issue, they sell loads.. asked about a repair, they quote, No genuine spares are available so it cant be done.
They did show me an injector which had be overhauled with imported Chinese parts, owner didn't get a year, what a mess.
JMR
Romania
C?ID=432218
I will try and find a vid for ou but i ve seen mechanics twisting the head nut at the top of the injector while checking out a vcds injector rate ..until it got to the best injection compensation rate ( usually under 0.99 mg/stroke ). However fixing one injector might throw off the balance of others so you have to play around a bit with it .
davidbp
C?ID=438179
Hi JMR, i've had some fun today, I replaced both injector cylinder 1 & 2 with two new VDO / Continental A2C9626040080 ( New ) purchased direct from VDO dealer / Repair centre.. Coded up, reset the deviation values and let the car idle for 15 mins, and then took the car for a 20 min run.. once back i fired up VCDS and received the following deviations Deviation image
The car runs perfect, I contacted VDO dealer awaiting a call back, I called the local VW Dealer they advised changing all four as a set..i almost fell over
the car worth £2500 ish , in two months the customer has spent £1500 on replacement injectors, £200 on tyres, £120 rear pads and discs, M.O.T and a service in total about £2000.
Now i need to tell him he need another 2 injectors at £800, plus today a scan identified 7286 - Turbocharger Boost Control Position Sensor Circuit..
The car, that just keeps on giving.
VIN: WVWZZZ1KZAW083138   Mileage: 156220km-97070miles
          P2563 00 [175] - Implausible Signal
                    Mileage: 156228 km
                    Date: 2022.01.25
                    Time: 15:50:02
                    Engine RPM: 1039.25 /min
                    Normed load value: 22.0 %
                    Coolant temperature: 30 °C
                    Intake air temperature: 7 °C
                    Voltage terminal 30: 14.231 V
                    Freeze frame conditions-AD_BPA_MMV_ENVD: 84.2 %
                    Freeze frame conditions-ANG_BPA_ENVD: 54.4 %
                    Freeze frame conditions-ANG_SP_BPA_ENVD: 84.7 %
                    Freeze frame conditions-BPA_PWM_ENVD: 84.7 %
                    Freeze frame conditions-V_BPA_ENVD: 2.46 V
                    Freeze frame conditions-V_BPA_BOL_ENVD: 0.49 V
                    Freeze frame conditions-V_BPA_TOL_ENVD: 3.54 V
                    Freeze frame conditions-FRF_OFF_ADP_BPA_ACT: 1
                    Freeze frame conditions-TEG_TUR_UP_ENVD: 20.0781 °C
   Revision: 00H45001
   Revision: 00006001
   Coding: 0000000000
   Revision: 00103 AE
   Coding: 009795
   Coding: 00003230
   Coding: 0000004
   Coding: 470B00
                    Reset counter: 107
                    Mileage: 155046 km
01304 - Radio
                    Reset counter: 20
                    Mileage: 155046 km
   Coding: 0000564
   Revision: 00H17000
   Coding: 0000564
Address 56: Radio
