New user to the forum - some queries about dsg and one or two other faults on an A3
redshell
Anglesey, Wales, UK
C?ID=492558
2010 Audi A3 2.0tdi s-line reporting faults with dsg, longditudinal acceleration sensor and dpf
I am fairly certain that I am just going to have to remove the gearbox and have it serviced but have found conflicting informnation regarding the acceleration sensor's presence in non awd vehicles.
any experience of these particular faults and subsequent suggestions appreciated.
Thursday,07,October,2021,10:27:32:29179
VCDS Version: 21.9.0.2 (x64)  HEX-NET2 CB: 0.4555.4
VIN: WAUZZZ8P3BA022765   License Plate:
Chassis Type: 8P-AU35 (8P0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56 61 62 69 72
          77
VIN: WAUZZZ8P3BA022765   Mileage: 223710km-139006miles
Address 01: Engine (J623-CFGB)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 AK    HW: 03L 906 018 AG
   Component: R4 2.0l TDI   H21 9979
   Revision: 41H21---    Serial number: AUX7Z0J5FNU0MQ CVN: C5FC9B1A
   Coding: 001D0012041501080000
   Shop #: WSC 43079 002 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018AK 003007
   ROD: EV_ECM20TDI01103L906018AK.rod
   VCID: 73B8B7D83B323723AA3-8026
   VINID: 9D196AAAA2200D24400821C614271225DF
5253 - Particulate Filter; Differential Pressure Sensor
          P2452 00 [175] - Elect. Malfunction
                    Mileage: 223705 km
                    Date: 2021.10.01
                    Time: 09:19:56
                    Engine RPM: 0.00 /min
                    Coolant temperature: 12 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 12.140 V
                    Sensor for particle filter differential press: raw value: 1057 hPa
                    Particle filter: difference pressure: 0 hPa
                    DPF: offset for differential pressure: 42 hPa
                    Particle filter: differential pressure: dynamic offset: 0 hPa
                    Outside temperature: 10.5 °C
                    Particle filter: soot mass measured: 11.10 g
                    Particle filter: soot mass calculated: 11.12 g
5250 - Function Restriction due to Faults in Other Modules
          U1113 00 [047] - -
                    Mileage: 223705 km
                    Date: 2021.10.01
                    Time: 09:19:56
                    ACC specified acceleration: 0.000 m/s²
                    ACC control module: received status-Bits 0-7: 0
                    Status of ACC/CCS acceleration interface-Bits 0-7: 0
                    Acceleration: 0.000 m/s²
                    Engine status: COENG_READY
4984 - Cylinder 1 Glow Plug Circuit (Q10)
          P0671 00 [109] - Electrical Fault
                    Mileage: 223705 km
                    Date: 2021.10.01
                    Time: 09:30:31
                    Engine RPM: 928.00 /min
                    Normed load value: 41.2 %
                    Voltage terminal 30: 11.920 V
                    Electric auxiliary heater: shut-off conditions-Bits 0-7: 2
                    Electric auxiliary heater: shut-off conditions-Bits 0-7: 20
                    Electric auxiliary heater: relay activation-Bits 0-7: 0
                    Pre-glow time: 2100 ms
                    Glow status-Bits 0-7: 0
                    Time since ignition off: 64939 s
4985 - Cylinder 2 Glow Plug Circuit (Q11)
          P0672 00 [109] - Electrical Fault
                    Mileage: 223705 km
                    Date: 2021.10.01
                    Time: 09:30:31
4987 - Cylinder 4 Glow Plug Circuit (Q13)
          P0674 00 [109] - Electrical Fault
                    Mileage: 223705 km
                    Date: 2021.10.01
                    Time: 09:30:31
Readiness: 1 1 0 0 0
   Part No SW: 02E 300 052 H    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2209
   Revision: 05151112    Serial number: 00001006190830
   Shop #: WSC 06314 000 00000
   VCID: 1964A570F59EAD7340F-804C
18149 - Clutch Pressure Adaptation
            P1741 - 001 - Limit Reached
                    Fault Status: 01100001
                    Fault Frequency: 255
                    Reset counter: 2
                    Mileage: 223705 km
                    Date: 2021.10.01
                    Time: 09:22:52
            P1741 - 002 - Limit Reached
                    Fault Status: 01100010
                    Reset counter: 2
                    Mileage: 223705 km
                    Date: 2021.10.01
                    Time: 09:22:52
   Part No SW: 1K0 907 379 AT    HW: 1K0 907 379 AT
   Component: ESP MK60EC1   H30 0105
   Revision: 00H30001
   Coding: 16426012092400FC681206EA901E0092390800
   VCID: 045AE4046E1C009B839-8050
                    Fault Status: 01101000
                    Reset counter: 75
                    Mileage: 223710 km
                    Date: 2021.10.01
                    Time: 09:58:47
                    Count: 3
                    Count: 14
                    Count: 12800
                    Count: 209
                    Count: 52480
                    Count: 65280
                    Count: 1024
   Part No SW: 8P0 820 043 BM    HW: 8P0 820 043 BM
   Component: KlimavollautomatH09 0150
   Revision: 000259      Serial number: 8P0820043BM
   VCID: 78A280F42ED4547B9F1-802C
   Part No SW: 8P0 907 063 G    HW: 8P0 907 063 G
   Component: BCM PQ35  M   107 0615
   Revision: 00107 AF
   Coding: 4E000A2FA005F0C0207041E00000015C421A29AA004DC12AE4008FA00041
   VCID: 382240F46254947B5F1-806C
   Subsystem 1 - Part No SW: 8P2 955 119 F    HW: 8P2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350  H10 0040
   Coding: 00DD13
   Subsystem 2 - Part No: 8P0 951 177
   Component: Innenraumuebe  H04 0020
   Subsystem 4 - Part No: 1K0 907 719 C
   Component: Neigungssenso  005 0003
Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 P    HW: 8P0 959 655 P
   Component: Airbag AU1042 H07 0200
   Revision: --------    Serial number: 003FB007WHYX
   Coding: 30314238303830303037554A305238503053
   ROD: EV_Airba10AURB4.rod
   VCID: 4FF01B28F75A33C36EB-801A
   Serial number: 3572DRB40000BC4900AW
   Serial number: 3582DRB40000BC507B2Z
   Serial number: 35128RB400005B1D330B
   Serial number: 35228RB400005A17392D
   Serial number: 35547RB400005B5CDA6%
   Serial number: 35647RB400005B5C5B3X
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Coding: 0014112
   VCID: 46DE3E0C14A0F28BDDD-8012
   Component: E0221           H02 0100
   Part No SW: 8P0 920 982 H    HW: 8P0 920 982 H
   Component: KOMBIINSTR. VDO H01 0090
   Revision: D0H01003    Serial number: 2245J003002470
   Coding: 0256428
   Shop #: WSC 00999 444 64523
   VCID: 3E2E56EC4C70AA4B95D-806A
   Part No SW: 8P0 907 530 A    HW: 1K0 907 951
   Component: J533  Gateway   H33 0302
   Revision:   H33       Serial number: 250610F1000074
   Coding: ED807F4610060204002103
   VCID: 31347DD08D2E453318F-8064
   Revision: D0H01003    Serial number: AUX7Z0J5FNU0MQ
   Shop #: WSC 00097 210 87219
   Part No SW: 8P0 959 801 Q    HW: 8P0 959 801 Q
   Component: Tuer-SG         H04 0101
   Coding: 0131764
   VCID: 49C4353005BE1DF330F-801C
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 233    3001
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
                    Fault Status: 00101101
                    Reset counter: 115
                    Mileage: 223708 km
                    Date: 2021.10.01
                    Time: 09:48:38
                    Voltage: 14.50 V
                        DU
                    Temperature: 28.0°C
                    RPM: 2048 /min
                    Speed: 86.0 km/h
                    Speed: 87.0 km/h
Address 47: Sound System        Labels: 8Px-035-382.lbl
   Part No SW: 8P4 035 382 E    HW: 8P4 035 382 E
   Component: AB2 SUBWOOFERBOXH07 0180
   Revision: 00006       Serial number: 92158068195938
   VCID: 363E4ECC6440620B4DD-8062
   Part No SW: 8P0 959 802 Q    HW: 8P0 959 802 Q
   Coding: 0131764
   VCID: 4AC60A3C00B816EB395-801E
   Part No SW: 8P0 035 186 S    HW: 8P0 035 186 S
   Component: R Concert2+     H03 0280
   Revision: 00H03000    Serial number: AUZ1Z3K6056495
   Coding: 0710111
   VCID: 42D6221C3888CEABF15-8016
   Part No SW: 8P0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H33 0302
   Coding: 030B085A
   VCID: 74BAB4C43EBC301BB39-8020
   Subsystem 1 - Part No SW: 1K0 915 181 E    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650269666
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
   Component: Tuer-SG         H04 0050
   Coding: 0131216
   Shop #: WSC 06314 000 1012544
   Component: Anhaenger     H07 0100
   Revision: 3A001001    Serial number: 00000131401436
   Coding: 010D000100000000
   Shop #: WSC 25364 000 00000
   VCID: 303278D48A244C3B171-8064
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
   Coding: 0131216
   VCID: 43D827182792C7A3FA3-8016
   Part No SW: 8P1 862 335     HW: 8P1 862 335
   Component: FSE_256x BT     H41 0650
   Revision: 00000000    Serial number: 00000005316325
   Coding: 0001222
   VCID: 74BAB4C432BC301BB39-8020
End----------(Elapsed Time: 01:39, VBatt start/end: 12.2V/12.2V)-----------
The differential pressure sensor for the DPF may have failed. Verify wiring to it and if all to spec, replace the sensor.
Transmission: At 139,000 miles, it wouldn't surprise me if it needs the clutches done.
ABS: Is this the original module the car was built with?
redshell
Anglesey, Wales, UK
C?ID=492558
Yes everything on the vehicle is as standard
JMR
Romania , EU
C?ID=432218
if your car has esp it should have a G251
