Hex net ...talking to the cloud ....
Spacewalker
Poland
C?ID=159607
Is there anyway to disable that ?
I am away car , car is with a WiFi range .....
try to do diag and ......."Hex Net I talking to the clud ....
ok, waiting.......5 min later ..... " Is talking to the cloud ....
ok , pick up my ass, walk to the car, reconnect from OBD , back to the office - do a Quick Self test - and ..... "interface is bussy - talking to the cloud"
I use Fix IP .
it happen very random , some time do 5-10 diagnostic, and next one is ....."talking to the cloud ".....
some time after 1st diagnostic .. pushing me to take a bigger brake , and bigger coffie
Shaun
Probably you have log files or something that it is trying to sync, check your [View Saved Files] page. I would suggest leaving it plugged in on the wifi inside some time when you don't need to use it, and let it finish whatever it's doing. Then see if you experience the problem after that.
Spacewalker
Poland
C?ID=159607
Ok, deleted all from C:\Ross-Tech\VCDS-Beta\Debug
few days was ok, today , it start again but that is empty
even if i swich to USB ...also bussy
why is always happen when I need it urgent ?
Shaun
These are not the files I mean. You need to check [View Saved Files] in VCDS-Mobile.
Spacewalker
Poland
C?ID=159607
why it happen only when is over WiFi ? or I not see that it happen over USB ?
can I permanent disable function to save a log ? I do many test on the bench , most of them always warning me - unknow version - do you want to save a log ..... and if i go into module 10-15 times I might do mistake and click YES (to save a log)
but at all , no need that LOG and You also no need it :)
golfi_vend
Tartu, Estonia
C?ID=195131
I see it daily. Annoying but what You gonna do.
For example. If LCode stays open and you unplug HEX-NET. VCDS program will crash 9/10 times. Then You open VCDS again, but don't close LCode, same message until you close LCode.
Spacewalker
Poland
C?ID=159607
hmm..... I need advanced user version, not end of customers ...
