Cannot set (2AI) secondary Air injection
Zshark53
California, USA
C?ID=505328
Hello: I am a newbie and struggling with the secondary air test. Let me give an explanation of what I have done so far and the history. This is for a 2007 New Beetle
1) Started with The check engine light came on with an 02 bank 1 sensor 1 error.
2) Replaced sensor and cleared error code.
3) Car was driven based on recommended prescribed procedure for car to be ready.
Did not look at the ready icons on the code reader before going to get the car smoged.
Went to get the car smoged and it failed SAI stating it was "not ready" was informed to replace the air pump
4) The air pump and conbi valve was replaced.
5) Car was driven based on recommended prescribed procedure for car to be ready.
The code reader was used to check the ready status of the secondary air and it still indicated "not ready"
I decided to purchase the Ross-tech software to set ready as no codes are showing up only the "not ready" icon continues to show.
6) I ran an auto scan and this is what it shows (see below). When I go to the secondary air test section, it doesnt respond. It doesnt start at all.
Please can someone review and let me know what could be happening and any guidance towards what I may need to fix to get the secondary air to be ready.
Monday,03,January,2022,12:36:05:37410
VCDS Version: 21.9.0.2 (x64)  HEX-V2 CB: 0.4555.4
VIN: 3VWRG31C37M504690   License Plate:
Readiness Status: 0010 1000
Exhaust Gas Recirculation: Passed
Oxygen Sensor Heating: Passed
Oxygen Sensor(s): Failed or Incomplete
Air Conditioning: Passed
Secondary Air Injection: Failed or Incomplete
Evaporative Emissions: Passed
Catalyst Heating: Passed
Catalytic Converter(s): Passed
Saturday,15,January,2022,17:07:47:37410
Chassis Type: 1C (1C - VW New Beetle (1998 > 2010))
Scan: 01 02 03 08 15 17 19 25 29 35 37 39 46 54 56 65 75
Address 01: Engine        Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 AA    HW: 07K 906 032 AA
   Component: NB R5 AT        G   9654
   Revision: --H01---    Serial number: VWZ5Z0F8157014
   Coding: 0000003
   Shop #: WSC 00066 000 00000
   VCID: 6889B7214E7AF96B0F1-803C
   VINID: 0E69E25C30530C7745004189003348377F
Readiness: 0000 1000
   Part No SW: 09G 927 750 FM    HW: 09G 927 750 FM
   Component: AQ 250 6F           0921
   Revision: 00H27000    Serial number:
   Coding: 0000008
   VCID: 015F8A854D102823A8F-5160
01045 - Tiptronic Switch (F189)
                    Reset counter: 0
                    Mileage: 110345 km
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379 Q
   Coding: 0019978
   VCID: 382927615E4AA9EB5F1-5160
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No: 6Q0 909 605 AK
   Component: 01 AIRBAG VW71      0911
   Coding: 0012337
   VCID: 00598F81464A212BA71-8054
   Subsystem 1 - Component: BF-Gewichtsens.
00591 - Seat Belt Switch; Driver (E24)
            006 - Short to Plus - Intermittent
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    V022
   Coding: 00006
   Shop #: WSC 00066
   VCID: 70B9DF4173BA31AB571-4B1E
Address 25: Immobilizer        Labels: 1C0-920-xxx-25.clb
   Part No SW: 1C0 920 803 C    HW: 1C0 920 803 C
   Component: IMMO                X007
   Revision: xxxxxxxx    Serial number: VWZ5Z0F8157014
   VCID: 1D67D6F5D1A8ECC3AC7-5160
   Part No: 1C0 959 799 G
   Component: 2K Komfortgerát HLO 0004
   Coding: 00064
   Shop #: WSC 00066
   VCID: 3B23386D6A7C82F3B23-4B00
   Subsystem 1 - Part No: 1C2959802A
   Component: 2K Tõrsteuer.FS KLO 0202
   Subsystem 2 - Part No: 1C2959801A
   Component: 2K Tõrsteuer.BF KLO 0202
            27-00 - Implausible Signal
Address 56: Radio        Labels: 1J0-035-18x-56.clb
   Part No: 1C0 035 196 BG
   Component:  RADIO DE2         0006
   Coding: 06031
   Shop #: WSC 00066
   VCID: 6597BE15BC78E403347-51CE
End----(Elapsed Time: 03:41, VBatt start/end: 12.0V/11.9V. VIgn 11.7V)-----
Getting the readiness to complete can be a quick or slow and frustrating job and it varies from car to car. Are you doing the tests manually or in auto? From memory the SAI system is Basic Settings 074, often I find that a lambda sensor readiness failure will not let the SAI complete because the sensors measure the systems affect so you need to complete that readiness first and I think it is BS 044 ish? If you ever run through the blocks manually from 001 to 256 you can find a few other tests not shown and some which have no explanation often right up in the 200’s BUT if you ever do this, DO NOT carry out Basic Settings 060 with the engine running or you will store a throttle body code and clearing it will clear the readiness settings you have completed. I find that carrying out adaptations 001 to clear learnt values (I do this three times) and then clear the codes, set the TB in BS 060 and then set the readiness a block at a time starting with 028 makes it work. Obviously on later systems you can’t do this.
Zshark53
California, USA
C?ID=505328
The source of the replacement was Rock-Auto
Zshark53
California, USA
C?ID=505328
I drove the car and upon return I checked the readiness status. They show all green except for secondary air. If you can explain why I would need to manually go back and manually run the tests on the 02 sensors to achieve the readiness on secondary air? I believe that the ECU is not sending the signal to the combi valve. But yet there is no code stating insufficient airflow??? Confusing.
I think it is group 074
Zshark53
California, USA
C?ID=505328
Hello: I am looking for a replacement ECM for my beetle. Any suggestions on where to buy or get it repaired? Any referrals? Anyone here selling one?
You're looking to replace the ECU because the it won't set one Readiness bit?
Context:
I'd replace the Oxygen Sensor that you got from Rock Auto with one from a VW dealer first! I seriously doubt that replacing the ECU is going to solve the problem in the above thread. I'm by no means certain that it's due to a dodgy replacement Oxygen Sensor, but I really doubt it's the ECU itself.
Zshark53
California, USA
C?ID=505328
Context:
I should have posted first, that I was not able to run an auto scan. Gateway communication fault. So, I ran installation list to get help with 2AI. Need car to pass smog. Could that fault stop the O2 sensor from becoming ready? Thanks for your help so far.
Well, you were able to run Auto-Scan by selecting the proper chassis, as evidenced by the Auto-Scan you posted in the other thread. As for "Gateway communication fault", something like that is expected if you try to use Auto-Detect on the Auto-Scan screen because the that generation of Beetle (1C chassis) does not have a Gateway Installation List.
No, but a Chinese Replacement Auto Part sensor from Rock Auto might. ;)
PS: I'm going to merge your threads.
Fred's Imports
Vermont, USA
C?ID=16454
Run the readiness monitors in the shop, clear codes and run ECM 01, then Basic Settings 04, then run 077 at idle, see if the SAI runs that way., process takes about 2 minutes, if SAI passes set the rest of the monitors in the shop.
If SAI monitor doesn't pass check the codes to see what failed.
vwtech
Verified Coal Cracker
Wilkes-Barre, PA
C?ID=7573
Auto scan / Chose the drop down. Select 1C the (7th and 8 digit of vin.)
No gateway as Uwe suggested.
Good Luck
Zshark53
California, USA
C?ID=505328
Installed O2 sensor purchased from dealer. Still can’t set ready for 2AI. First test does not change, no matter how long I let it run. The OBD adapter blinks green/ red. Is that normal? Do I need to send computer out for repair? Thanks for all your suggestions.
vwtech
Wilkes-Barre, PA
C?ID=7573
After trying to set SAI readiness you get no codes for SAI?
How about output tests. Does pump run? Does SAI kombi valve click?
Why no response about TSB https://static.nhtsa.gov/odi/tsbs/2019/MC-10159350-0001.pdf
If you believe ECU is not sending signal to Kombi valve do output tests for kombi valve.
You keep going back to bad ECU maybe? But swapping ECU isn't easy!
You need to know it's bad after checking wiring and output tests send no signal out to Kombi then maybe ECU?
Good Luck
Zshark53
California, USA
C?ID=505328
Good Luck
Last resort of the desperate, replace the ECU.
Zshark53
California, USA
C?ID=505328
The car dose not have a sensor at the location in the TSB. How is the air measured with my set-up? Also, I can set all of the Readiness, except SAi by driving the car. But not with the software. Some of the test I am able to achieve the last field, to move on to the next. Others do not indicate if the needs to be started by me . Or I need to initiate. Sorry I am a newbie. I know with practice I will understand and be able to use the software as intended. I enjoy problem solving and your suggestions are appreciated. What steps can I take to better understand coding and communications for Audi / VW. I just bought a Q5.
