- Apr 10, 2016
- 216
- 184
- United Kingdom
- C?ID=219022
Lovely... the morning of the annual inspection I start the car to find these ABS faults. Had to cancel the inspection as any warning lights is a failure. I quick scan show these:-
I guess I need a replacement steering angle sensor.
A full unedited scan (ignore the MMI errors as I have the optical loop unplugged and the ACC errors).
It does baffle me as to the cause of the steering angle sensor. The car hasn't moved and was connected to a Ctek maintainer. What did happen the evening prior was a power surge, could that be a cause?
The car drives horrible now as the air suspension has hardened up as it's also complaining about the steering angle sensor.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 A HW: 4E0 614 517 A
Component: ESP 5.7 allrad H29 0420
Coding: 0008597
Shop #: WSC 02313 000 00000
VCID: 2149FC83F8DBE6816E-8074
02083 - Message for Delay Request
014 - Defective
Thursday,06,January,2022,10:58:38:04620
VCDS Version: 21.9.0.2 (x64)
VIN: WAUZZZ4E04N008970 License Plate:
Mileage: 154210km-95821mi Repair Order: a
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0F 13 15 16 17 19 1E 25 34 36 37 38
42 46 47 4F 52 53 55 56 57 61 62 72 76
VIN: WAUZZZ4E04N008970 Mileage: 154210km-95821miles
07-Control Head -- Status: Cannot be reached 1100
0F-Digital Radio -- Status: Cannot be reached 1100
13-Auto Dist. Reg -- Status: Cannot be reached 1100
1E-Media Player 2 -- Status: Cannot be reached 1100
37-Navigation -- Status: Cannot be reached 1100
38-Roof Electronics -- Status: OK 0000
47-Sound System -- Status: Cannot be reached 1100
57-TV Tuner -- Status: Cannot be reached 1100
Address 01: Engine Labels: User\4E0-910-560-H.lbl
Part No SW: 4E0 910 560 H HW: 4E0 907 560
Component: 3.7L V8/5V G 0020
Revision: 00000000 Serial number: AUX3Z0C8121858
Coding: 0011773
Shop #: WSC 02313 785 00200
VCID: 2643EF9F91F501B91B-8072
VINID: 9D196AAAA115004780008247005A7D9D10
17981 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit - Intermittent
17983 - Right Engine Mount Solenoid Valve (N145)
P1575 - 001 - Short to Plus
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 D HW: 09E 927 156 A
Component: AG6 09E 3,7L5V RdW 0070
Revision: 00000001 Serial number: 0019919
Coding: 0000001
VCID: 2345F68BE2C7F4917C-8076
Coding: 0008597
014 - Defective
Address 05: Acc/Start Auth. Labels: User\4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131
Component: FBS AUDID3 H03 0120
Revision: 01203603 Serial number: AUX3Z0C8121858
Coding: 0264192
Shop #: WSC 02311 785 00200
VCID: 58BF9167EB01674959-800C
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H06 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063328
Address 07: Control Head
Address 08: Auto HVAC Labels: User\4E0-910-043.lbl
Part No SW: 4E0 910 043 HW: 4E0 820 043 A
Component: KLIMAAUTOMAT 015 0240
Revision: 00000018 Serial number: 00000000023996
Coding: 1069057
VCID: 5ABB8B6F950D75596F-800E
Address 09: Cent. Elect. Labels: User\4E0-910-279.lbl
Part No SW: 4E0 910 279 E HW: 4E0 907 279 E
Component: ILM Fahrer H11 0100
Coding: 0110001
VCID: 2A5B1BAF85ED25D93F-807E
Subsystem 1 - Part No: 4E2 910 113 B
Component: Wischer WWS D3 H50 0420
Coding: 00000042
Shop #: WSC 02311
Address 0F: Digital Radio
Address 13: Auto Dist. Reg Labels: User\4E0-910-561.lbl
Part No SW: 4E0 910 561 C HW: 4E0 907 561 C
Component: ABSTANDSREGELUNG 0010
Coding: 0021158
VCID: 224BF38FFDDDFD9977-8076
Fault Status: 11111101
Reset counter: 239
Mileage: 153612 km
Date: 2003.10.08
Temperature: 13.0°C
Voltage: 11.65 V
Bin. Bits: 00000000
Fault Frequency: 14
Reset counter: 239
Mileage: 153600 km
Date: 2005.07.13
Time: 17:24:00
Temperature: 7.0°C
Voltage: 11.65 V
Bin. Bits: 00000000
008 - Implausible Signal - MIL ON
Fault Status: 11111000
Fault Frequency: 14
Reset counter: 239
Mileage: 153600 km
Date: 2005.07.13
Time: 17:24:00
Temperature: 7.0°C
Voltage: 11.65 V
Bin. Bits: 00000000
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655
Component: Airbag 8.4E+ H09 0940
Coding: 0431707
VCID: 63C5B68BA247B4913C-8036
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H09 0030
Coding: 0112141
VCID: 65C1A893AC73CAA1D2-8030
Component: Lenkradmodul H02 0050
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 CX
Component: KOMBIINSTR. VDO H54 0090
Revision: D21 Serial number: AUDID3F7000147
Coding: 0000403
Shop #: WSC 77827 127 721924
VCID: 5CB78D779F398B697D-8008
Address 19: CAN Gateway Labels:. 4E0-910-468.clb
Part No SW: 4E0 910 468 HW: 4E0 907 468 B
Component: Gateway H07 0070
Revision: 07 Serial number: 1300403820020A
Coding: FEFE7BDC2B2D04
Shop #: WSC 00000 128 00289
01319 - Control Module for Distance Control (J428)
Fault Frequency: 132
Reset counter: 239
Mileage: 153602 km
Date: 2005.07.06
Time: 21:23:00
00384 - Optical Databus
Reset counter: 239
Mileage: 153602 km
Date: 2005.07.06
Time: 22:04:35
Address 1E: Media Player 2
Address 25: Immobilizer Labels: User\4E0-910-131.lbl
Coding: 0264192
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 34: Level Control Labels: User\4E0-910-553.lbl
Part No SW: 4E0 910 553 F HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 6260
Coding: 0015510
Fault Status: 11101000
Reset counter: 239
Mileage: 154213 km
Date: 2004.08.14
Time: 22:00:21
Component: Sitzmemory FS H06 0060
Coding: 4063330
Address 37: Navigation
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H01 0080
Serial number: 00000321700038
Coding: 0035968
VCID: 1D31C073C4A3C2614A-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E2 959 802
Component: Türsteuer.FS BRM005 0100
Coding: 0028454
VCID: 5EB3877F8925997913-800A
02111 - Motor for Window Regulator
Fault Status: 00100101
Reset counter: 24
Mileage: 154208 km
Date: 2004.08.21
Time: 22:10:42
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H03 0030
Revision: 00300003 Serial number: W040308140067
Coding: 0004313
VCID: 275DE29B96FF18B120-8072
Subsystem 1 - Part No: 4E0 907 719
Component: Neigungssensor H02 0020
Fault Status: 01101100
Fault Frequency: 213
Reset counter: 239
Reset counter: 239
Address 47: Sound System
Address 4F: Centr. Electr. II Labels: User\4E0-910-280.lbl
Part No SW: 4E0 910 280 HW: 4E0 907 280 A
Component: ILM Beifahrer H07 0070
Revision: Serial number: 00000000021465
Coding: 0010101
VCID: 5DB18073842382610A-8008
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E2 959 801
Component: Türsteuer.BF BRM005 0110
Coding: 0028454
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 B HW: 4E0 907 801 A
Component: EPB A22HC020 H02 0200
Revision: A22HC020
Coding: 0000331
VCID: 1E33C77FC9A5D97953-804A
Address 55: Headlight Range Labels: User\4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0030
Coding: 0000001
VCID: 62CBB38FBD5DBD9937-8036
Address 56: Radio
Address 57: TV Tuner
Address 61: Battery Regul. Labels: User\4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000010062
Shop #: WSC 55675 001 1048576
VCID: 204FF987F3D1EF8961-8074
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 331112C285
Coding: 344530393135313035412056413033333131313243323835
Shop #: WSC 18088 001 104857
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM005 0110
Coding: 0028454
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM005 0110
Coding: 0028454
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0020
Revision: 00H12000 Serial number: 08720519200155
Coding: 0201108
End-------------------------(Elapsed Time: 03:39)--------------------------
