2005 tdi jetta dsg long crank no start no tach new to ross tech and vw
mk5 tdi
C?ID=505433
6:19490
VCDS Version: 21.9.0.2 (x64)  HEX-V2 CB: 0.4555.4
VIN: 3VWCT71K36M057213   License Plate:
Mileage: 277620km-172505mi   Repair Order: 1
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 47 52 56 62 65
          72 7D
VIN: 3VWCT71K36M057213   Mileage: 277620km-172505miles
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine        Labels: 038-906-016-BEW.lbl
   Part No SW: 03G 906 016 AC    HW: 028 101 223 9
   Component: R4 1,9L EDC G000DG  7551
   Revision: --H05---    Serial number: VWZ7Z0F4594402
   Coding: 0050078
   Shop #: WSC 00066 000 00000
   VCID: 6491A315B25F7D0B239-8030
   VINID: 0E69D390705B0C67401470810C49848FC4
000802 - Engine Speed Sensor (G28)
               P0322 - 000 - No Signal - MIL ON
                    Fault Status: 11110000
                    Mileage: 277621 km
                    Time: 00:37:21
                    Voltage: 9.50 V
                    Bin. Bits: 00001000
                    Idle Stabilization: 0.0°KW
                    RPM: 42 /min
Address 02: Auto Trans        Labels:
   VCID: 55F78ED1EC059483A47-FFFE
   Revision: 00H11001
   Coding: 0021122
   VCID: 73B3D04907B1EAB3AA3-8026
   Part No: 1K0 820 047 FQ
   Component: Climatic PQ35   120 0606
   VCID: 78A9E7651ED789EB9F1-802C
   Part No SW: 3C0 937 049 Q    HW: 3C0 937 049 Q
   Component: Bordnetz-SG     H46 1501
   Revision: 00H46000    Serial number: 00000000469820
   Coding: 14018E234004150007140000001400000028770B5C0000
   VCID: 372B24595349469356B-8062
   Component: Wischer 260906 020  0501
   Coding: 00038805
   Shop #: WSC 00066
   Part No SW: 8E0 035 593 D    HW: 8E0 035 593 D
   Component: SDAR SIRIUS     H03 0060
   Revision: 00000000    Serial number: AUZ4Z7F7022876
   VCID: 2A0D0D2D90FBEB7BD95-807E
                    Reset counter: 57
                    Mileage: 277621 km
                    Time: 00:37:20
                    Voltage: 8.00 V
                    Reset counter: 17
                    Mileage: 277621 km
                    Time: 00:35:02
   Component: 6A AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D05WDWT
   Coding: 0013889
   VCID: 6C81CB355A8F354B6B9-8038
   Subsystem 1 - Part No: 1K0 959 339 F
   Component: BF-Gewichtsens. 007 0005
   Subsystem 2 - Serial number: 6332MSME12034347
   Subsystem 3 - Serial number: 6342MSME1239213F8
   Subsystem 4 - Serial number: 6351HSME041C115A1
   Subsystem 5 - Serial number: 6361HSME0A684012%
   Subsystem 6 - Serial number: 63727SME0A5F0C6CK
   Subsystem 7 - Serial number: 63827SME0A5C6040+
   Part No SW: 1K0 953 549 AS    HW: 1K0 953 549 AS
   Component: J0527           035 0070
   Coding: 0012021
   VCID: 035380895711DA33BA3-8056
   Part No SW: 1K0 920 973 D    HW: 1K0 920 973 D
   Component: KOMBIINSTRUMENT 3HL 1610
   Revision: V0003000    Serial number: VWZ7Z0F4594402
   Coding: 0023203
   Shop #: WSC 03160 067 57207
   VCID: 2E05013DAC13875B05D-807A
   Part No SW: 1K0 907 530 H    HW: 1K0 907 951
   Component: J533__Gateway   H12 0150
   Revision:   H12       Serial number: 31001067250521
   Coding: 3FBF0B620F001002
   VCID: 2C010B359A0FF54B2B9-8078
   Part No SW: 1K5 919 965 A    HW: 1K5 919 965 A
   Component: Kompass         005 0003
   Revision: 00005000    Serial number: 1293324T25C503
   Coding: 0000003
   VCID: 392F2261655D50E3A0F-806C
   Component: IMMO            3HL 1610
   Component: J386  TUER-SG FT    1127
   Revision: 12007001    Serial number: 00000540668916
   Coding: 0001205
   VCID: 3B2338696F6162F3B23-806E
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.070 H07 1806
   Shop #: WSC 02069 000 90108
   VCID: 34311355423FAD8B739-8060
                    Mileage: 277610 km
                    Temperature: 11.0°C
                    Voltage: 11.40 V
                    Voltage: 11.20 V
   Part No SW: 1K0 959 433 CD    HW: 1K0 959 433 CD
   Component:    KSG PQ35 RDK 051 0215
   Revision: 00051000    Serial number: 00000000000000
   Coding: 13900F880186281B0904058FB0880F0488DC00
   VCID: 74B1D35502BFED8BB39-8020
Address 47: Sound System        Labels: 3C0-035-456.clb
   Part No: 1K6 035 456 A
   Component: 08K Audioverst.     0005
   Revision: 00003000    Serial number: 00000000011958
00877 - Treble Speaker Rear Right (R16)
   Component: J387  TUER-SG BT    1127
   Revision: 12007001    Serial number: 00000020568917
   Coding: 0001204
   VCID: 3C213B756A6F65CBBB9-8068
Address 56: Radio        Labels: 1K0-035-1xx-56.clb
   Part No SW: 1K0 035 180 G    HW: 1K0 035 180 G
   Component: Radio DE2       145 0176
   Revision: 00145000    Serial number: VWZ4Z7F2128801
   Coding: 0010400
   VCID: 2411E315F2DF3D0BE39-8070
00871 - Bass Speaker Front Right (R23)
00003 - Control Module
            014 - Defective
   Component: J388   TUER-SG HL   1115
   Revision: 12004001    Serial number: 00000000297803
   Coding: 0001168
   VCID: 3E25317D7C7377DB95D-806A
   Component:    RDK              0420
   Coding: 0100101
   Component: J389   TUER-SG HR   1115
   Revision: 12005001    Serial number: 00000000369151
   Coding: 0001168
   VCID: 3FDB4C797B797ED39EB-806A
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
   VCID: 2D070631A115FC433C7-8078
00361 - Heater Element for Auxiliary Heater (Z35)
            014 - Defective
End----(Elapsed Time: 01:44, VBatt start/end: 11.5V/11.6V. VIgn 11.6V)-----
Hi and welcome.
The symptoms described are consistent with the "No Signal" from the Engine Speed Sensor (G28). Check/verify wiring between that sensor and the ECU, and replace the sensor wiring is OK.
mk5 tdi
C?ID=505433
I replaced the sensor with one from the auto parts oem import brand still no signal the sensor is grey in color same as the one I took off but I am unsure if it is original so
I checked the wiring harness and found bad wires so I replaced the engine harness with a used one off a running parts car and inspected the harness before installing it and have the same problem and codes. I purchased this car used from an auction and have no info on previous work but I did find a recite for a new serpentine belt, tensioner and a timing belt set in the car. When the car starts it runs smooth but does have a slight rattle at idle I'm guessing dmf, could this be causing any of the engine speed sensor issues? I am considering replacing the rear main seal and crank sensor and dmf any recommendations on where to get quality parts? I also hate to go through all the work of a dmf swap and still have issues with the engine speed sensor. I would rather fix the speed sensor issue first unless it could be rear main seal related since the signal ring is in the seal.
mk5 tdi
C?ID=505433
also i pulled the ecm and tried swapping it with another one and the immobilizer light came on but still no crank signal while cranking and when running before immobilizer shut it off
Have you checked/verified the wiring between that sensor and the ECU?
mk5 tdi
C?ID=505433
that's the harness I replaced off a running car with working tach but I didn't check since installed
JMR
Romania
C?ID=432218
also you need a battery, that 9.50 v doesn't help at all, ecu is dizzy at that voltage...jesus
I suspect that fault (and the Freeze-Frame data associated with it) were set during cranking. I'm not convinced he needs a battery, but his battery definitely needs to be charged:
JMR
Romania
C?ID=432218
or what you say , correct...i meant that he needs good voltage/batt ery
mk5 tdi
C?ID=505433
It has a new battery that was after having the key on without a charger but the volts do drop cause of the long cranking to start and I did multiple starts when testing. I had the charger on but it was my big jump/charger and i was getting codes for high voltage so I took it off and must have run the battery down low.
mk5 tdi
C?ID=505433
Could it be my transmission speed sensor? I have read they both work together but I would think the tach would work. It shows rpms on vcds when running so I swapped the gauge cluster and still no tach
No. That would not keep the engine from running, nor would it set an explicit Engine Speed Sensor fault.
Fred's Imports
Vermont, USA
C?ID=16454
Wiring harness on those Mexican cars are problematic. Check where it flexes by the radiator and under/ around the tandem pump. FORGET that you replaced it with a USED part!
Also green death at the ECM.
mk5 tdi
C?ID=505433
I pulled the new used harness off and inspected it and didn't see any problems so I installed the original harness and run jumper wires to the ecm and still no tach. The pins on the ecm and harness both look good. Is it possible I got a bad sensor or the pick up ring the sensor reads is bad.
HMC
C?ID=28246
You need to check the signal with an oscilloscope.
Regards HMC
JMR
Romania
C?ID=432218
so let me understand..you have rpm signal on vcds , but not on tacho ?
There could be an issue in the wiring between ecu/ instrument cluster. Can you perform a instrument cluster activation ( speed, tacho, temp , etc etc )? See if they work ...
mk5 tdi
C?ID=505433
Yeah when it start I have rpm on vcds but no tach and engine speed sensor code.
I was told it will default to the cam position sensor if the crank sensor reads out of parameter. I will check on the cluster activation in the next couple days we got hit with a winter storm and I have been working a lot of overtime
