fridaforsbilservice
Hey!
I have a car that we changed the control unit for the parking brake on because the right rear brake did not work. when we were going to do a coding with our bosch tool, it hung and the car lost the coding on both the control unit for the parking brake and the ABS control unit's coding. we have a VCDS tool with, I have done an autoscan on the car after it lost the codes. can someone get the codes for ABS and for Parking brake?
The car is a Vw passat 2007 Engine code BVY
onsdag,05,Januari,2022,13:56:07:20017
VCDS -- Windows-baserad VAG/VAS-emulator Tändningen Windows 10 x64
VCDS version: AER 21.9.0.6
Dataversion: 20211208 DS330.0
www.vcds.se
VIN: WVWZZZ3CZ7E055055 Reg.nr: OOL405
Mätarställning: 161260km Rep.order:
Chassityp: 3C (3C0)
Skanna: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 69 72
VIN: WVWZZZ3CZ7E055055 Mätarställning: 161260km
00-Givare styrvinkel -- Status: OK 0000
01-Motor -- Status: OK 0000
03-Bromselektronik -- Status: Felfunktion 0010
08-Klimatanläggning -- Status: OK 0000
09-Elektron. elcentral -- Status: OK 0000
15-Krockkuddar -- Status: Felfunktion 0010
16-Rattelektronik -- Status: OK 0000
17-Instrument -- Status: OK 0000
25-Startspärr -- Status: OK 0000
42-Dörrel. förare -- Status: Felfunktion 0010
44-Styrservo -- Status: OK 0000
46-Komfortcentral -- Status: OK 0000
52-Dörrelektr. pass. -- Status: OK 0000
53-Parkeringsbroms -- Status: Felfunktion 0010
56-Radio -- Status: Felfunktion 0010
62-Dörr, Vä Bak -- Status: OK 0000
69-Släpvagn -- Status: Felfunktion 0010
72-Dörr hö bak -- Status: OK 0000
Adress 01: Motor Labels: Textfil saknas
Artikelnr SW: 06F 906 056 FB HW: 06F 906 056 EK
Komponent: MED9.5.10 G00 9162
Revision: --H03--- Serienummer: VWZCZ000000000
Kodning: 0000072
Verkstad #: WSC 05311 000 00000
VCID: 6ED738C179D934F9A7-803A
VINID: 9E69EAAAA0D3A8754014500514BC545025
Ingen felkod funnen.
Readiness: 1110 0101
Adress 03: Bromselektronik Labels:. AER\3C0-614-095-C2.clb
Artikelnr SW: 3C0 614 095 S HW: 3C0 614 095 S
Komponent: ESP 440 C2 H015 0004
Revision: H015 Serienummer: 0460019465
Kodning: 0001287
VCID: 326FECB1AD61501983-8066
2 Funna fel:
01314 - Motorstyrdon
frysta data:
Felstatus: 01100000
Felprioritet: 2
Felfrekvens: 1
Reset-räknare: 255
Mätarställning: 161269 km
Tidsindikering: 0
Datum: 2022.01.05
Tid: 13:54:52
01044 - Styrdonet är felaktigt kodat
frysta data:
Felstatus: 01100000
Felprioritet: 2
Felfrekvens: 1
Reset-räknare: 255
Tidsindikering: 0
Datum: 2022.01.05
Tid: 13:54:52
Adress 08: Klimatanläggning Labels: AER\3C0-907-044.lbl
Artikelnr SW: 3C0 907 044 AH HW: 3C0 907 044 AH
Komponent: ClimatronicPQ46 050 0505
Revision: 00050005 Serienummer: 00000000000000
Verkstad #: WSC 00000 000 00000
VCID: 67D94DE55623E5B1E4-8032
Adress 09: Elektron. elcentral Labels:. AER\3C0-937-049-23-H.lbl
Artikelnr SW: 3C0 937 049 J HW: 3C0 937 049 J
Komponent: Bordnetz-SG H37 1301
Revision: 00H37000 Serienummer: 00000005984301
Kodning: 088E8F0700041A00000A00000F00000000085D435C0000
VCID: 306BE6B9A36D6209F5-8064
Subsystem 1 - Artikelnr: 3C1 955 119 A Labels: AER\1KX-955-119.CLB
Komponent: Wischer VW461 012 0503
Kodning: 00063445
Adress 15: Krockkuddar Labels: AER\3C0-909-605.lbl
Artikelnr SW: 3C0 909 605 M HW: 3C0 909 605 M
Komponent: 03 AIRBAG VW8 030 2522
Revision: 10030000 Serienummer: 003B1PEQ7F5L
Kodning: 0012339
Subsystem 1 - Serienummer: 6332MSME11225D59
Subsystem 2 - Serienummer: 6342MSME12116602
Subsystem 3 - Serienummer: 6351HTS6PLLIS9L2
Subsystem 4 - Serienummer: 6361HTS6PLLIGQ43
Subsystem 5 - Serienummer: 00000000000000000
Subsystem 6 - Serienummer: 00000000000000000
1 fel funnet:
01578 - Kontrollampa för airbag från: pass.sidan (K145)
009 - Avbrott eller kortsluten till jord - Fellampa(MIL) tänd
Adress 16: Rattelektronik Labels: AER\3C0-953-549-SW20.lbl
Artikelnr SW: 3C0 953 549 E HW: 3C0 953 549 E
Komponent: J0527 0015
Revision: 00007000 Serienummer: 3C9953507P
Kodning: 0000112
VCID: 2E57F8C1B95974F9E7-807A
Subsystem 1 - Artikelnr: XXXXXXXXXXX
Komponent: E0221 002 0010
Adress 17: Instrument Labels: AER\3C0-920-xxx-17.lbl
Artikelnr SW: 3C0 920 870 T HW: 3C0 920 870 T
Komponent: KOMBIINSTRUMENT VD1 1614
Revision: X0006000 Serienummer: 00000000000000
Kodning: 0007105
Verkstad #: WSC 80093 222 69422
VCID: 3463EAA957755E2991-8060
Adress 19: CAN Gateway Labels:. AER\3C0-907-530-V1.clb
Artikelnr SW: 3C0 907 530 C HW: 3C0 907 951 A
Komponent: Gateway 007 0040
Revision: 00007000 Serienummer: 0700C067100B5A
Kodning: 3DFD8C04C22002
VCID: 214D13FDF887DB816A-8074
Adress 25: Startspärr Labels: AER\3C0-959-433-25.clb
Artikelnr SW: 3C0 959 433 R HW: 3C0 959 433 R
Komponent: IMMO 042 0383
Revision: 00042000 Serienummer: VWZCZ000000000
Verkstad #: WSC 131071 1023 2097151
VCID: 397DDB9D7017A34142-806C
Subsystem 1 - Artikelnr: 3C0 905 861 F
Komponent: ELV 026 0380
3C0905861F ELV 026 0380
Adress 42: Dörrel. förare Labels: AER\1K0-959-701-MAX3.lbl
Artikelnr SW: 1K0 959 701 AE HW: 1K0 959 793 P
Komponent: J386 TUER-SG FT 1517
Revision: 71009005 Serienummer: 00000288388624
Kodning: 0000181
Verkstad #: WSC 56373 004 1048576
VCID: 71ED23BD68E72B01BA-8024
1 fel funnet:
00943 - Uppvärmbar utvändig backspegel: förarsidan (Z4)
012 - Elfel i strömkrets - Intermittent fel
frysta data:
Felstatus: 00101100
Felprioritet: 4
Felfrekvens: 3
Reset-räknare: 101
Mätarställning: 161265 km
Tidsindikering: 0
Datum: 2022.01.04
Tid: 14:14:02
Adress 44: Styrservo Labels: AER\1Kx-909-144-G2V3.clb
Artikelnr: 1K1 909 144 L
Komponent: EPS_ZFLS Kl.133 H07 1806
Verkstad #: WSC 02069 000 90108
Adress 46: Komfortcentral Labels:. AER\3C0-959-433-46.clb
Komponent: KSG PQ46 ELV 042 0472
Kodning: 0091020051030E763004941570084F0B607C00
Subsystem 1 - Komponent: Sounder n.mounted
Subsystem 2 - Komponent: NGS n.mounted
Subsystem 3 - Komponent: IRUE n.mounted
Adress 52: Dörrelektr. pass. Labels: AER\1K0-959-702-MIN3.lbl
Artikelnr SW: 1K0 959 702 P HW: 1K0 959 792 L
Komponent: J387 TUER-SG BT 1123
Revision: 12006001 Serienummer: 00000511968720
Kodning: 0000180
VCID: 3C73C2897F25966959-8068
Adress 53: Parkeringsbroms Labels: AER\3C0-907-801-53.clb
Artikelnr SW: 3C0 907 801 B HW: 3C0 907 801 B
Komponent: EPB VC8HC001 013 0001
Revision: 013
Kodning: 0000012
2 Funna fel:
02442 - Funktionslampa i manöverdelen
frysta data:
Felstatus: 01101001
Felprioritet: 6
Felfrekvens: 2
Reset-räknare: 61
Mätarställning: 161264 km
Tidsindikering: 0
Datum: 2022.01.05
Tid: 11:58:58
frysta data:
Spänning: 13.66 V
Räkna: 65
01315 - Växellådstyrdon
004 - Ingen signal/förbindelse - Intermittent fel
frysta data:
Felstatus: 00100100
Felprioritet: 4
Felfrekvens: 3
Reset-räknare: 101
Tidsindikering: 0
Datum: 2022.01.05
Tid: 11:20:10
frysta data:
Spänning: 14.18 V
Räkna: 243
Adress 56: Radio Labels: AER\1K0-035-1xx-56.lbl
Artikelnr SW: 3C0 035 195 B HW: 3C0 035 195 B
Komponent: Radio PM6 009 0015
Revision: 00009000 Serienummer: VWZ5Z7F1021143
Kodning: 0040400
Verkstad #: WSC 05314 000 00000
VCID: 1F491505CEF3ED715C-804A
1 fel funnet:
00875 - Diskanthögtalare: höger fram (R22)
011 - avbrott
frysta data:
Felstatus: 01101011
Felprioritet: 3
Felfrekvens: 1
Reset-räknare: 61
Tidsindikering: 0
Datum: 2022.01.04
Tid: 13:44:24
Adress 62: Dörr, Vä Bak Labels: AER\1K0-959-703-GEN3.lbl
Artikelnr SW: 1K0 959 703 P HW: 1K0 959 795 G
Komponent: J388 TUER-SG HL 1114
Revision: 11004001 Serienummer: 00000000335545
Kodning: 0000144
VCID: 3D75CF8D643F9F616E-8068
Adress 69: Släpvagn Labels: AER\1K0-907-383-V1.clb
Artikelnr SW: 1K0 907 383 HW: 1K0 907 383
Komponent: ANHAENGERELEKTR 003 0020
Kodning: 0000001
VCID: 6ADF34D14531D8D9FB-803E
1 fel funnet:
16347 - Styrdon EEPROM-fel
014 - felaktig
frysta data:
Felstatus: 01101110
Felprioritet: 2
Felfrekvens: 1
Reset-räknare: 255
Mätarställning: 262140 km
Tidsindikering: 0
Datum: 2022.01.05
Tid: 13:54:00
Adress 72: Dörr hö bak Labels: AER\1K0-959-704-GEN3.lbl
Artikelnr SW: 1K0 959 704 P HW: 1K0 959 794 G
Komponent: J389 TUER-SG HR 1114
Revision: 11004001 Serienummer: 00000000344903
Kodning: 0000144
VCID: 3E77C8816939847977-806A
Slut------------------------(Förfluten tid: 01:51)-------------------------
