- Aug 5, 2021
- 18
- 6
- Brisbane, Australia
- C?ID=451235
Hi All,
Our new Golf seems to be lacking power, I'm no expert so could someone please tell me if the turbo measuring block numbers look ok?
I took some screen shots of the turbo measuring blocks, one at low rpm and one at higher rpm, to my untrained eye I see that the Boost Pressure Actual barely moves and it is twice the Boost Pressure Specified.
Also the Boost Pressure Control (N75) stays at zero.
Do these values look ok or is there an underlying problem?
I would appreciate any feedback.
Saturday,08,January,2022,09:49:06:04739
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
VIN: WVWZZZ1KZ7U012353 License Plate: 250DE6
Mileage: 100370km-62367mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72 76
VIN: WVWZZZ1KZ7U012353 Mileage: 100370km-62367miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 J HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0030
Revision: 5BH14--- Serial number: VWZ7Z0F8097311
Coding: 040300431C070160
Shop #: WSC 30067 959 05130
VCID: 2D070040211016533C7-8078
VINID: 9E69EAAAA05BA879400420C50C97341A34
008568 - Bank 1; System Too Rich off Idle
P2178 - 002 - - MIL ON
Fault Status: 11100010
Mileage: 100167 km
Time: 09:28:01
RPM: 1724 /min
Load: 38.8 %
Speed: 34.0 km/h
Temperature: 63.0°C
Temperature: 36.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.097 V
Readiness: 0000 0001
Part No SW: 02E 300 043 C HW: 02E 927 770 AE
Component: GSG DSG 070 1111
Revision: 04507000 Serial number: 00000607111137
Shop #: WSC 44551 111 44551
VCID: 1471B5A4A27AA79B139-8040
18149 - Clutch Pressure Adaptation
P1741 - 002 - Limit Reached - Intermittent
Fault Frequency: 255
Reset counter: 2
Mileage: 100157 km
P1741 - 001 - Limit Reached
Fault Status: 01100001
Reset counter: 2
Mileage: 100199 km
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0004738
Shop #: WSC 00046 412 00000
VCID: 73B3D63887B400A3AA3-8026
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BJ HW: 1K0 907 044 BJ
Component: ClimatronicPQ35 090 0909
Revision: 00090016 Serial number: 00000000000000
VCID: 70B9D934F6A23BBB571-8024
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000006012769
Coding: E58D8F2700041500001400001400000000087F075C
VCID: 2B030E581F041863223-807E
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 270906 020 0501
Coding: 00049109
Shop #: WSC 00046
Subsystem 2 - Part No: 1K0 955 559 AE Labels: 1K0-955-559-AF.CLB
Component: RLS 200706 014 1201
Coding: 00208933
Shop #: WSC 00046
Component: 1P AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD0NN1LV
Coding: 0012624
VCID: 3D273000F17086D38C7-8068
Subsystem 1 - Serial number: 6332MSME121B60620
Subsystem 2 - Serial number: 6342MSME1218473EC
Subsystem 3 - Serial number: 6352QSME115C7805G
Subsystem 4 - Serial number: 6362QSME126D4729M
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527 636 0070
Coding: 0012122
VCID: 015F8CF0CD082233A8F-8054
Component: E0221 002 0010
Part No SW: 1K6 920 863 HW: 1K6 920 863
Revision: V0003000 Serial number: VWZ7Z0F8097311
Coding: 0003703
Shop #: WSC 05970 002 1048576
VCID: 6E85C74CEC962D4B45D-803A
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001067148765
Coding: 3F3F074207000003
VCID: 2C010D441A0A1F5B2B9-8078
Component: IMMO VDD 1610
Part No SW: 1K0 959 701 N HW: 1K0 959 701 N
Component: Tuer-SG 005 0970
Coding: 0000692
VCID: 392F2410E558BAF3A0F-806C
01552 - Motor for Central Locking; Drivers Door (V56); Lock
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.069 H07 1806
VCID: 35372820C9405E93447-8060
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0202
Revision: 00020000 Serial number: 00000000000000
Coding: 019002005103087F2D0484057008DFC690F8A0
VCID: 035386F8D7143023BA3-8056
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Part No: 1K0 951 178
Component: Neigungssensor 001 0101
Subsystem 3 - Part No: 1K0 951 178
Component: Innenraumueberw.001 0101
Reset counter: 11
Mileage: 100157 km
Time: 14:51:15
00896 - Trunk Lock Unit (F256)
Fault Status: 01101000
Fault Frequency: 22
Reset counter: 11
Mileage: 100157 km
Time: 15:34:57
Reset counter: 52
Mileage: 100158 km
Time: 13:15:36
00323 - Vehicle Inclination Sensor (G384)
Reset counter: 52
Mileage: 100158 km
Time: 13:15:36
Address 47: Sound System Labels: 3C0-035-456.clb
Part No: 1K6 035 456 A
Component: 08K Audioverst. 0005
Revision: 00003000 Serial number: 00000000002045
VCID: 2A0D0B5C10FE016BD95-807E
Part No SW: 1K0 959 702 N HW: 1K0 959 702 N
Coding: 0000948
VCID: 3A2D3B1CE05EB1EBA95-806E
01553 - Motor for Central Locking; Passenger Door (V57); Lock
Address 56: Radio Labels: 1K0-035-1xx-56.clb
Part No SW: 3C0 035 195 C HW: 3C0 035 195 C
Component: Radio PM6 012 0019
Revision: 00012000 Serial number: VWZ5Z7H1160089
Coding: 0010020
Shop #: WSC 30067 959 69521
VCID: 2019E97466C2CB3B871-8074
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 005 0912
Coding: 0000144
Shop #: WSC 00046 412 1012544
VCID: 38292114DE52A3FB5F1-806C
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0000144
014 - Defective
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 1K0 919 283 A
Component: 22 Einparkhilfe 0101
End----------(Elapsed Time: 01:23, VBatt start/end: 14.2V/14.1V)-----------
Address 01: DTCs cleared
