MK5 GTI DSG Issues.
mattjj65
Brisbane, Australia
C?ID=451235
Hi All,
We have a new MK5 Golf GTI in the family. I have purchased one for my teenage daughter after she wrote off the previous MK6 118 TSI.
She only got it yesterday and it seemed to drive fine at the start but had a bit of a glitch when changing up from 2nd to 3rd, it was barely noticeable.
The problem occurred last night, she was backing out of a carpark and the car actually stalled. It also happened in forward going over a speed hump at low speed. Once she restarted it everything was ok but I have a feeling there might be an underlying issue with the DSG.
You will see from the autoscan that I did that there is a clutch pressure adaptation error.
My question is, should I be looking at trying the reset the values in the clutch pressure adaptation first or should I be looking at changing out the solenoids in the Mechatronics unit?
Any advice would be greatly appreciated.
There is also a problem with both rear doors not opening on the key open but they will open when the button on the driver's door is pushed.
This is only a minor issue, the big one is the transmission at the moment.
Wednesday,05,January,2022,12:38:49:04739
VCDS Version: 21.9.0.2 (x64)  HEX-V2 CB: 0.4555.4
VIN: WVWZZZ1KZ7U012353   License Plate:
Mileage: 100150km-62230mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72 76
VIN: WVWZZZ1KZ7U012353   Mileage: 100150km-62230miles
   Part No SW: 1K0 907 115 J    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0030
   Revision: 5BH14---    Serial number: VWZ7Z0F8097311
   Coding: 040300431C070160
   Shop #: WSC 30067 959 05130
   VCID: 2D070040211016533C7-8078
   VINID: 9E69EAAAA05BA879400420C50C97341A34
Readiness: 0110 0001
   Part No SW: 02E 300 043 C    HW: 02E 927 770 AE
   Component: GSG DSG         070 1111
   Revision: 04507000    Serial number: 00000607111137
   Shop #: WSC 44551 111 44551
   VCID: 1471B5A4A27AA79B139-8040
18149 - Clutch Pressure Adaptation
            P1741 - 002 - Limit Reached
                    Fault Status: 01100010
                    Fault Frequency: 255
                    Reset counter: 2
                    Mileage: 100157 km
   Revision: 00H11001
   Coding: 0004738
   Shop #: WSC 00046 412 00000
   VCID: 73B3D63887B400A3AA3-8026
   Part No SW: 1K0 907 044 BJ    HW: 1K0 907 044 BJ
   Component: ClimatronicPQ35 090 0909
   Revision: 00090016    Serial number: 00000000000000
   VCID: 70B9D934F6A23BBB571-8024
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Revision: 00H37000    Serial number: 00000006012769
   Coding: E58D8F2700041500001400001400000000087F075C
   VCID: 2B030E581F041863223-807E
   Component: Wischer 270906 020  0501
   Coding: 00049109
   Shop #: WSC 00046
   Subsystem 2 - Part No: 1K0 955 559 AE  Labels: 1K0-955-559-AF.CLB
   Component: RLS     200706 014  1201
   Coding: 00208933
   Shop #: WSC 00046
   Component: 1P AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD0NN1LV
   Coding: 0012624
   VCID: 3D273000F17086D38C7-8068
   Subsystem 1 - Serial number: 6332MSME121B60620
   Subsystem 2 - Serial number: 6342MSME1218473EC
   Subsystem 3 - Serial number: 6352QSME115C7805G
   Subsystem 4 - Serial number: 6362QSME126D4729M
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Component: J0527           636 0070
   Coding: 0012122
   VCID: 015F8CF0CD082233A8F-8054
   Part No SW: 1K6 920 863     HW: 1K6 920 863
   Revision: V0003000    Serial number: VWZ7Z0F8097311
   Coding: 0003703
   Shop #: WSC 05970 002 1048576
   VCID: 6E85C74CEC962D4B45D-803A
   Part No SW: 1K0 907 530 H    HW: 1K0 907 951
   Component: J533__Gateway   H12 0150
   Revision:   H12       Serial number: 31001067148765
   Coding: 3F3F074207000003
   VCID: 2C010D441A0A1F5B2B9-8078
   Component: IMMO            VDD 1610
   Part No SW: 1K0 959 701 N    HW: 1K0 959 701 N
   Component: Tuer-SG         005 0970
   Coding: 0000692
   VCID: 392F2410E558BAF3A0F-806C
01552 - Motor for Central Locking; Drivers Door (V56); Lock
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.069 H07 1806
   VCID: 35372820C9405E93447-8060
   Component:    KSG PQ35 G2  020 0202
   Coding: 019002005103087F2D0484057008DFC690F8A0
   VCID: 035386F8D7143023BA3-8056
   Subsystem 2 - Part No: 1K0 951 178
   Component: Neigungssensor  001 0101
   Subsystem 3 - Part No: 1K0 951 178
   Component: Innenraumueberw.001 0101
                    Reset counter: 11
                    Mileage: 100157 km
                    Time: 14:51:15
00896 - Trunk Lock Unit (F256)
                    Fault Status: 01101000
                    Reset counter: 11
                    Mileage: 100157 km
                    Time: 15:34:57
                    Reset counter: 51
                    Mileage: 100158 km
                    Time: 13:15:36
00323 - Vehicle Inclination Sensor (G384)
                    Reset counter: 51
                    Mileage: 100158 km
                    Time: 13:15:36
Address 47: Sound System        Labels: 3C0-035-456.clb
   Part No: 1K6 035 456 A
   Component: 08K Audioverst.     0005
   Revision: 00003000    Serial number: 00000000002045
   VCID: 2A0D0B5C10FE016BD95-807E
   Part No SW: 1K0 959 702 N    HW: 1K0 959 702 N
   Coding: 0000948
   VCID: 3A2D3B1CE05EB1EBA95-806E
01553 - Motor for Central Locking; Passenger Door (V57); Lock
Address 56: Radio        Labels: 1K0-035-1xx-56.clb
   Part No SW: 3C0 035 195 C    HW: 3C0 035 195 C
   Component: Radio PM6       012 0019
   Revision: 00012000    Serial number: VWZ5Z7H1160089
   Coding: 0010020
   Shop #: WSC 30067 959 69521
   VCID: 2019E97466C2CB3B871-8074
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         005 0912
   Coding: 0000144
   Shop #: WSC 00046 412 1012544
   VCID: 38292114DE52A3FB5F1-806C
   Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
   Coding: 0000144
            014 - Defective
Address 76: Park Assist        Labels: 1K0-919-283.lbl
   Part No: 1K0 919 283 A
   Component: 22 Einparkhilfe     0101
End----------(Elapsed Time: 01:22, VBatt start/end: 13.8V/13.6V)-----------
JMR
Romania , EU
C?ID=432218
mattjj65
Brisbane, Australia
C?ID=451235
Thanks JMR,
I have ordered a new filter and fluid, I will change it out and then readapt it.
Hopefully that fixes it.
Thanks heaps for your advice.
