The question you always need to ask is not, "what can VCDS check", but "what does the car know?"Does VCDS able to check unit injectors?
... Because VCDS can only tell you what the car knows.
Perhaps you might find this thread of interest:
PD and CR Injectors -- Normal Compensation Rates for Reference Comparison
Seeing how many diesel engine users wonder what a good injector compensation rate should look like on a PD / CR injector , here are my happy numbers ( from 0.00 to 0.99 mg/str). Ideally these compensation rate readings should be done at about 80-90 degrees C warm engine at idle. Will try to...
forums.ross-tech.com
