Difficult start when wheather is cold and surconsommation of gazole
firesun
France
HUC-2H
My engine doesn't start easily when the wheather is cold ( around 0° celcius°) and most of all consomation of gazole is very excessive.
I have also prblms with my wipes and electrics glasses (just the right side)
VCDS shows that i have a pblm with the glow plug module J179!
Do i have to change it or anything else?
I changed already it a few years now ( 2 years) and now i have pblms with it again
Does anybody knows how to solve this problem definitely?
Here's the full scan i have done today
          67 69 75 76 77
VIN: WAUZZZ8EX8A068858   Mileage: 248410km-154354miles
Address 01: Engine        Labels: 03G-906-016-BKE.clb
   Part No SW: 03G 906 016 JA    HW: 03G 906 016 JA
   Component: R4 1,9L EDC G000SG  8692
   Revision: --H05---    Serial number: XXXXXXXXXXXXXX
   Coding: 0000071
   Shop #: WSC 06335 000 00000
   VCID: 6BD059D64A602ED184-803E
   VINID: 9D196AAAA215A08440188205203F1C510F
001668 - Glow Plug Control Module (J179)
               P0684 - 000 - Implausible Signal
                    Mileage: 248388 km
                    RPM: 882 /min
                    Voltage: 12.08 V
                    Bin. Bits: 00101100
                    Temperature: 19.8°C
                    Bin. Bits: 10110000
Readiness: 1 1 0 0 0
   Part No SW: 8E0 910 517 H    HW: 8E0 614 517 BF
   Component: ESP8 FRONT      H06 0140
   Coding: 0004401
   VCID: 2C529ACA8FEEE9E9CD-8078
   Part No: 8E0 820 043 BL
   Component:   A4 Klimaautomat   3233
   Coding: 00000
   VCID: 6CD25ACA1C6E29E98D-5140
00716 - Air recirculation Flap Positioning Motor (V113)
            41-00 - Blocked or No Voltage
   Part No: 8E0 907 279 N
   Component: int. Lastmodul  ECE 0907
   Coding: 11001
   Shop #: WSC 06325
   VCID: 3D74A78E379470616A-4B08
01498 - Bulb for Parking Lamps; Right (M3)
            30-00 - Open or Short to Plus
   Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
   Component:    Airbag 9.41  H14 4230
   Revision: 91H14423    Serial number: 0036M0G9XCFU
   Coding: 0030612
   VCID: 3B70A9967A807E5154-806E
   Subsystem 1 - Serial number: 6332DRB405C0CA27V
   Subsystem 2 - Serial number: 6342DRB405D38B18X
   Subsystem 3 - Serial number: 6352ARB402D038EF.
   Subsystem 4 - Serial number: 6362ARB402DC77E1$
   Subsystem 5 - Serial number: 63729RB402A6D34DY
   Subsystem 6 - Serial number: 63829RB402A646DAZ
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0701
   Coding: 02022
   Shop #: WSC 06335
   VCID: 418CDB7E4B6C14810E-4AEE
   Part No SW: 8E0 920 901 H    HW: 8E0 920 901 H
   Component: KOMBI+WFS 4     H14 0200
   Revision: 0200        Serial number: 00000000000000
   Coding: 0006104
   Shop #: WSC 11111 111 11111
   VCID: 2A5E9CD2861AF7D93F-5122
   Coding: 0006104
   VCID: 2A5E9CD2861AF7D93F-515C
   Part No: 8E0 959 433 CL
   Component: Komfortgerát T01    4236
   Coding: 07008
   Shop #: WSC 06335
   VCID: 7DF4678E7714B0612A-4B20
   Subsystem 1 - Part No: 8E1959801H
   Component: Tõrsteuer.FS BRM 0606
   Subsystem 2 - Part No: 8E1959802H
   Component: Tõrsteuer.BF BRM 0606
   Component: Tõrsteuer.HL BRM 0606
   Subsystem 4 - Part No: 8E0959802E
   Component: Tõrsteuer.HR BRM 0606
   Part No SW: 8E0 035 186 AK    HW: 8E0 035 186 AK
   Component: R Concert2+     H04 0240
   Revision: 00H04000    Serial number: AUZ1Z3G5369689
   Coding: 0210221
   VCID: 70EA4EBA6046CD09B1-5140
Address 76: Park Assist        Labels: 8E0-919-283-8EC.lbl
   Part No SW: 8E0 919 283 D    HW: 8E0 919 283 D
   Component: Parkhilfe 4-Kan H06 0010
   Revision: 00H06000    Serial number: 00067802030721
   Coding: 0000014
   VCID: 316C8BBEABCC8401FE-5140
End-------------------------(Elapsed Time: 06:41)--------------------------
DrPeter
16.4905° S, 151.7375° W
Thanks for posting on the Ross-Tech forum.
If the weather is cold enough, an inoperative Glow Plug system is going to make it difficult to start a cold engine.
"Temperature: 19.8°C" was listed in the fault code freeze frame data, has it been colder than this?
You should also check the coolant temperature sensor. You can use VCDS to check the 'Engine Coolant Temperature - G62' when the engine is cold (over night) and verify the G62 sensor is reading correctly. The coolant temperature should be the about the same as the ambient temperature.
If the temperature reading is not correct, it could contributing to the 'hard start' condition and if the temperature sensor is not reading correctly when the engine is warm, it could also explain the excessive fuel consumption (surconsommation of gazole).
When connected to the [01-Engine] controller, use the Measuring Value Block Group [001], field (4) to display the current value of the "Coolant Temperature (G62)".
P0684 - Glow Plug Control Module (J179): Implausible Signal
- This fault code can set when there is a missing message from the 'Automatic Glow Time Control Module - J179' or the J179 sends an 'Error' message to the ECM.
The Official Factory Repair Information recommends to check the J179, its connections to the ECM, the power and ground to the J179 and if all the above are correct, you may need to test with a known good J179.
Have a look at this Ross-Tech wiki page for the fault code above... http://wiki.ross-tech.com/wiki/index.php/01498
Hope this helps,
drpeter
firesun
France
HUC-2H
Hello Dr Peter,
Thank you for your fast reply first!
Secondly i need to know if a fautly G62 may affect the J179 defaut?
I mean is there a direct relation beetwen the two or no?
Thank you
DrPeter
Hello again...
Good question... I would think... No, not to the best of my knowledge. I say this because a failing or inaccurate G62 sensor should not cause an "Implausible Signal" fault for the J179, relay.
As mentioned above, the 'signal' out of the J179 is either missing or with error, hence the "Implausible" or 'Not possible' part of the fault code.
This can be confirmed of course by verifying the accuracy of the G62, clearing the fault codes and see if the P0684 code still comes back.
Again, hope this helps,
drpeter
firesun
France
HUC-2H
Thanks for your reply and your very best reflexion!
I just take the measure of the value of G62 while the weather was 5° celcius and the VCDS shows the water was 22.5° celcius
Tomorrow that means in 8 hours i will turn back and re take a new measure of G62 indication to confirm it's fautly.
For the glow plug i will have to wait for changing G62 for conclude thatis fautly two
JMR
Romania
C?ID=432218
was it a genuine OEM part? Or aftermarket? Also , I agree with @DrPeter , bad water sensor throws a wrench in the starting of the engine. Also, you could have a shortcircuited glow plug and that could throw the J179 in the dark. You could check your plugs by taking them out and hook them to a 12 V battery for 2-3 seconds see it the tip gets glowing red.
firesun
France
HUC-2H
Hello Jammer,
It was a used condition BOSCH relay!
Ok today i will control my plugs!
Thanks for your post
firesun
France
HUC-2H
Hello again all,
I take the measure of the G62 this morning and i have 2.7° celcius while the ambient temperature was 1.5° celcius!
I think my G62 is nearly good! What do you think?
And now i'm going to control my glow plugs first and replace them in case they need to be changed.
After this i'm gonna check my control modul J179 and search one brand new and one of the best quality!
I will post the informations back asap!
Thank you all!
  • Agree
Reactions: JMR
firesun
France
HUC-2H
I check my glow plugs and they are correct!
I think my control module glow plug is definetively faulty because i have many functions that does not work in my car ( electric right glass rear wipe...)
Does somebody able to tell me his thinking about my G62 sensor?
Is it correct or faulty?
Best regards
Westbury, UK
The module that controls the glow plugs is NOT the same module that controls things like the rear wash/wipe - so you need to look for either a common failure point or you have more than one failure.
firesun
France
HUC-2H
Here is the part number 0 281 003 085 BOSCH
Last time when i had to change my control module the symptoms where the same as now
And once i change it the whole pblms disappear
Are you sure of what you say?
If yes i have to push my check further away!
Please confirm it to me and tell me what control module makes working the glasses
Westbury, UK
Yes 100% sure, look at your Auto-Scan for the information.
The glow plug control module is controlled by the engine ECU at address #1, but things like the rear light fault etc are controlled by the CECM at address #9and the rear wash/wipe by the SCSM at address #16.
BTW I owned various models of 8E A4/S4/RS4 for 13 years ...
firesun
France
HUC-2H
Thank you for your fast and sure confirmation!
Can you explain me why there are so many pins in that relay?
And have you an explication for the glasses which worked again once i have changed this relay?
What do you call CECM?
firesun
France
HUC-2H
I wasn't clear perhaps:
i mean alimentation relay of options of the car.
I'm not talking about coding module
Have i been understood?
Thank you again for your cooperation
Westbury, UK
It sounds like you need a wiring diagram (see how that is bold? that means it's a link telling where to get a wiring diagram).
As I said the CECM is at address #9 in the Auto-Scan, the label says "Cent. Elect." which means Central Electric Control Module (CECM for short) - which you can also see if you hover your mouse over CECM (see how that is green bold and underlined?)
firesun
France
HUC-2H
Ok i understand you now!
I have to think why control module glow plug doesn't work fine at the same time of cecm!
Another pleasure party omg!
Quintus Rotam
EU
C?ID=490177
I was hoping it was just a faulty G62 sending pumped-up temperature readings to the J179, but your measurement seems to show that G62 is working correctly (at least it did so when you tested it).
You say you had J179 replaced 2 years ago, and the unit you had installed was a used one - not a surprise to see it go after 2 years.
I agree with @PetrolDave that glow plugs shouldn't have anything to do with right-side mirrors or wipers, but maybe they share a fuse or some other electrical element. And you do have a bulb fault code on the right-hand side as well.
Wiring diagram sounds like a very good idea.
firesun
France
HUC-2H
Thank you for your reply Quintus Rotam!
I'm going to study the wiring diagram and come back to you asap!
Thank you all!
firesun
France
HUC-2H
firesun
France
HUC-2H
Your silence means i'm still wrong i suppose lol
Anyway i have ordered the control module glow plug online and as soon as i will receive it i will test and reply to you if you want!
After this i will check my cecm and get back to you too
Thank you for all for your precious helping
