2016 Caddy MIB upgrade
bsa500
Norway
C?ID=142452
Hi, i am in need of support regarding retrofit of MIB unit in vw caddy 2016.
The unit was bought secondhand and the component protection is taken care of by the vw dealer.
The old unit is part number 1K083515E.
The new second hand unit is part number 5K7035200K, and was provided with original backup camera from same car, the camera is installed with wiring harness from kufateck.com.
The unit is in function with but many restriction;
  1. Backup cam seems to be ok and functional, but the vcds have no connection to the module? Maybe do to the wiring?
  2. The amount of radiostations (DAB) is very restricted, and the logo`s is missing.
  3. Bluethooth connection for handsfree telephone not working, it is searching but can`t find any bluethooth device.
  4. Navigation not active.
  5. Apple carplay no active.
There is a list of FEC/SWAP codes in the display, is this possible to activate with VCDS?
  1. Supported codes but in grey, 00040100
00050000
00060100
00060200
00060300
00060400
00060800
00060900
00060b00?
00070400
  1. Installed codes, but temporary dismissed;
00050000
00030000
00060300
00060800
00060900
00060100
Attached latest autoscan.
Friday,10,December,2021,17:11:58:40200
VCDS Version: 21.9.0.2 (x64)
Dealer/Shop Name: kb
VIN: WV1ZZZ2KZGX056779   License Plate: RAGNAR 1
Mileage: 83150km-51667mi   Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 02 03 08 09 10 13 15 16 17 18 19 22 25 42 44 46 52 5F 61
          69
VIN: WV1ZZZ2KZGX056779   Mileage: 83150km-51667miles
Address 01: Engine (J623-DFSB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 016 BS    HW: 04L 907 309 K
   Component: R4 2.0l TDI   H20 4644
   Revision: 8AH20---    CVN: 4EDD926592F1EF3C
   Coding: 011D001A043615090000
   Shop #: WSC 00535 218 00000
   ASAM Dataset: EV_ECM20TDI01104L906016BS 004005
   ROD: EV_ECM20TDI01104L906016BS_004.rod
   VCID: 7BFFDDC2F278685114-802E
   VINID: 9E606AAAA09BA97A001461C724E7CE8808
   Part No SW: 02E 300 016 J    HW: 02E 927 770 AL
   Component: GSG DSG AG6     531 4902
   Revision: 06253104    Serial number: 00001509081337
   Shop #: WSC 35110 377 08192
   VCID: 1B3FFD42DA38C851B4-804E
   Component: ESC           H05 0132
   Revision: 00000000    Serial number: 42765000000806
   Coding: 1079809BB367A484087C017DCD8B25A378F150
   Shop #: WSC 35110 790 50316
   VCID: 3F8769D2A6E0B47178-806A
0128 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 23
                    Mileage: 83159 km
                    Date: 2021.12.10
                    Time: 05:07:41
0297 - Steering angle sensor
          B1168 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 23
                    Mileage: 83159 km
                    Date: 2021.12.10
                    Time: 04:52:51
   Part No SW: 1K8 907 426 AE    HW: 1K8 907 426 AE
   Component: AC Manuell    H20 0808
   Revision: 00001002
   Coding: 0010004003
   VCID: 76E9CCF6C95A35396B-8022
   Part No SW: 5K0 937 085 AD    HW: 5K0 937 085 AD
   Component: BCM PQ35 B+   122 0183
   Revision: BB122001
   Coding: 611A0A3A8025086F088800809000086C03850008424DAD20E48487000041
   VCID: 75EBCBFADC5C3E2162-8020
   Subsystem 1 - Part No: 1T1 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 07101  27  0512
   Coding: 009795
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-283.clb
   Part No SW: 1K8 919 465     HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0479
   Revision: --------    Serial number: 39231528304669
   Coding: 0001050111
   ASAM Dataset: EV_EPHVA14VW364GP00 001006
   ROD: EV_EPHVA14VW364GP00_VW36.rod
   Part No SW: 7N0 907 572 A    HW: 7N0 907 572
   Component: ACC Bosch PQx H03 0111
   Serial number: 26101577090518
   Coding: 00001800FE0339
   ASAM Dataset: EV_ACCBEGVW361 001004
   ROD: EV_ACCBEGVW361.rod
   VCID: 346D36FE9FA6672995-8060
1058 - Databus
                    Reset counter: 24
                    Mileage: 83159 km
                    Date: 2021.12.10
                    Time: 04:52:50
                    Control Module temperature: 25 °C
                    Voltage terminal 15: 11.5 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
1059 - Databus
                    Reset counter: 24
                    Mileage: 83159 km
                    Date: 2021.12.10
                    Time: 04:52:50
0077 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 24
                    Mileage: 83159 km
                    Date: 2021.12.10
                    Time: 05:07:39
                    Control Module temperature: 32 °C
                    Voltage terminal 15: 8.7 V
   Part No SW: 2K5 959 655     HW: 2K5 959 655
   Component: VW10Airbag00H 008 0016
   Revision: --------    Serial number: 003QV000WBCT
   Coding: 000000000000000000000000000000003048
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 79F3C7CAF8445A4106-802C
   Serial number: 3497ARB405D3J79MJ909
   Serial number: 3507ARB404T3L7J0NOB-
   Part No SW: 5K0 953 521 FF    HW: 5K0 953 569 BB
   Revision: FF010042    Serial number: 20151008200795
   Coding: 5880160010
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 75EBCBFAD45C3E2162-8020
   Part No SW: 2K5 920 876 A    HW: 2K5 920 876 A
   Component: KOMBI         H04 1009
   Coding: 180A001100
   VCID: 336F35E29AA860118C-8066
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 7N0 963 272 E
   Component: Standheizer     044 4941
   Revision: 00044000    Serial number: 09028239000000
   Coding: 0031032
   Shop #: WSC 35110 377 00171
   VCID: 377701F246D08C31B0-8062
   Part No SW: 7N0 907 530 BG    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1674
   Revision:   H56       Serial number: 201015F1000856
   Coding: 357420
   Shop #: WSC 00000 416 13619
   VCID: 76E9CCF6C15A35396B-8022
   Part No SW: 0AY 907 554 J    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7540
   Serial number: HA1-00027.08.15
   Coding: 0501
   VCID: 52A1506605724919A7-8006
   Component: IMMO          H04 1009
   VCID: 6AD1E8868DE2E1D9FF-803E
   Part No SW: 2K5 959 701     HW: 2K5 959 701
   Component: Tuer-SG         009 2143
   Coding: 0132144
   VCID: 71E3FFEA68341201BE-8024
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 140    3501
   Revision: 00H22000
   VCID: 397307CA70C49A4146-806C
   Part No SW: 2K5 959 702     HW: 2K5 959 702
   Coding: 0132144
   VCID: 72E1F0E66D32291947-8026
   Part No SW: 5K7 035 200 K    HW: 5K7 035 200 K
   Component: MU-S-D-ER     H41 0475
   Serial number: VWZAZ2W0751330
   Coding: 063307003C00000011111101008808001F0100D40020010002
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 2C5D2E9E47963FE9CD-8078
1637 - Interface for External Media
          U11B8 00 [009] - No Communications
                    Reset counter: 239
                    Mileage: 83159 km
                    Date: 2021.12.10
                    Time: 05:14:17
                    Voltage terminal 30: 12.4 V
                    Interface for external media: status-Status: Open circuit
   Component: Batt.regelung H56 1674
   Coding: 330F1873
   VCID: 71E3FFEAA8341201BE-8024
   Component: J367-BDM  H07 0180
   Serial number: 42287H16451491882284
   Part No SW: 1K0 907 383 H    HW: 1K0 907 383 G
   Component: Anhaenger     H12 0130
   Revision: 3B001001    Serial number: 00000382517163
   Coding: 010D000103000000
   VCID: 326130E66DB2691987-8066
End-------------------------(Elapsed Time: 03:06)--------------------------
kamold
Australia
C?ID=241363
Removing Component protection is not enough, you also need to deal with the FEC (licenses) which you have listed above.
Note that you have for example 00050000 rejected - this is for bluetooth.
Similarly 0060300 (mirrorlink) 00030000 (USB interface) 00060800 (Apple carplay) 00060900 (Android Auto) 00401000 (navigation) and 00060100 (vehicle interface).
Without these licenses being valid, none of these functions will work.
These issues cannot be resolved with VCDS. There are other resources which will allow you to address this, or you can send the unit to someone near you to fix them and send it back.
bsa500
Norway
C?ID=142452
Thanks for your reply, which other resources will do the job?
Westbury, UK
Non VCDS ones which should probably be discussed by private messages not on this VCDS forum?
