T6.1 Aux heater to Parking heater
Scuderia Kanrell AB
Sweden
C?ID=357960
We are trying to upgrade the Aux heater with a remote control but only gets halfway.
We have mounted an original antenna module and paired it with a original remote.
After we changed coding in heater and climate control the heater registers the signal from the remote with good quality and the climate starts the fan.
But the heater doesn’t start. No pump, nu glow plug and no combustion air blower.
We borrowed another T6.1 with original equipped parking heater but can’t find the difference.
Only for the coolant shut off valve which this car won’t have. Does anyone have any ideas where we should look more then in heater and climate?
The car we are retrofitting Caravelle T6.1
;SW:5WA-963-271-A   HW:5WA-963-271-A ---  Aux. Heat
;Component:STH-VW37x     006 0010, Coding:3543221854121512DCE519
;EV_AuxilHeateWOSVW38X,001009,EV_AuxilHeateWOSVW38X_001.rod
;Tuesday,28,December,2021,08:28:52:39992
;VCDS Version: Release 21.9.0 (x64)  Data version: 20210903 DS330.0
;VCID: 4AD86040ED2331D9DF-801E
IDE00470-Initial fuel filling,Yes ,1
IDE06640-MAS01167-Transfer fuel pump-Actuation time,20 s,3
IDE06640-MAS05080-Transfer fuel pump-Maximum standing time,0.0 H,3
IDE06640-MAS05689-Transfer fuel pump-Activation delay,10 s,3
IDE06642-IDE15463-Coolant change-over valve-Activation delay: medium-voltage holding voltage,10 s,3
IDE06642-MAS05071-Coolant change-over valve-Temperature difference: engine/parking heater,0 °C,3
IDE06642-MAS05073-Coolant change-over valve-Residual heat: threshold,-40 °C,3
IDE06686-Insufficient voltage threshold,11.3 V,1
IDE06687-CO2 setting,175 ,1
IDE06689-Low voltage detection: time limit,20.0 s,1
IDE06690-MAS05059-Auxil. heat control parameters-Lower temperature threshold: ambient temperature,5.0 °C,2
IDE06690-MAS05060-Auxil. heat control parameters-Upper temperature threshold: ambient temperature,12.0 °C,2
IDE06692-Note request for aux. heater from A/C system,Do not ignore ,1
IDE06693-Evaluate air pressure via CAN,Yes ,1
IDE06694-MAS05076-Minimum burn time-Time,160 s,2
IDE06694-MAS05077-Minimum burn time-Temperature threshold offset,1 °C,2
IDE07160-MAS04357-Control module switch-off: switch-off time-Time 1,140 min,2
IDE07160-MAS04358-Control module switch-off: switch-off time-Time 2,20 min,2
IDE11710-MAS03980-Heating time limitation-Maximum heating time,180 min,2
IDE11710-MAS13122-Heating time limitation-Activation function heating time exceedance,active ,2
MAS01488-MAS05072-recirc. pump-Maximum engine rpm,12750 /min,4
MAS01488-MAS06093-recirc. pump-Lowest temperature for request of exterior water pump,-20 °C,4
MAS01488-MAS06094-recirc. pump-Lowest activation temperat. for request of exterior water pump,150 s,4
MAS01488-MAS06095-recirc. pump-Maximum temperature for request of exterior water pump,180 s,4
MAS05075-Evaluate ethanol content,Yes ,1
MAS09096-Recirc. pump locking mechan.,1 ,1
ENG119729-activacion_of_simulated_flamme_run_for_emv_measuring,No ,1
ENG119721-development_data_on_CAN,not active ,1
;SW:7LA-907-040-A   HW:7LA-907-040-A ---  Auto HVAC
;Component:Climatronic   H01 0502, Coding:B030100008101100010009005040010500000000000B1101A08000000000
;EV_AirCondiBHTCT6PA,001004,EV_AirCondiBHTCT6PA.rod
;Tuesday,28,December,2021,08:26:33:39992
;VCID: 393A2F8CB8C5AA4146-806C
IDE01067-Retention of driver's seat heater level,active for 10 minutes ,1
IDE01476-Store air recirculation setting with terminal 15 OFF,Matching coding ,1
IDE01482-After-run of parking heater or parking ventilation,activated ,1
IDE01483-Blower voltage with voice control,not activated ,1
IDE01495-After-run time of auxiliary heater with air conditioner off,120 s,1
IDE01503-Running time of basic setting for compressor break-in,120 s,1
IDE01536-Post heating of auxiliary heating,10 min,1
IDE03176-Duration of compressor run in,0 s,1
IDE03252-Window condensation parameter for start/stop function,5 ,1
IDE03253-A/C comfort parameter for start/stop function,5 ,1
IDE06544-Speed shut-off threshold for compressor break-in (engine speed),1500 /min,1
IDE07865-Automatic activation of front windshield defroster at MAX-Defrost,active ,1
IDE07948-Retention of frt.pass. seat heater level,not active ,1
IDE12351-AUTO display for manual recirculation,Matching coding ,1
IDE12352-Fresh air/air recirculation door active during OFF operation,active ,1
The car we have copied Transporter T6.1
;SW:5WA-963-272-A   HW:5WA-963-272-A ---  Aux. Heat
;Component:STH-VW37x     006 0010, Coding:3543222054121512DCE519
;Tuesday,28,December,2021,13:02:11:39992
;VCID: 4BD66544E25928D1E4-801E
Group,Description,Actual
IDE00021,Engine RPM,0, /min
IDE00025,Coolant temperature,31, °C
IDE00310-IDE00075,Outside temperature-Vehicle speed,0.00, km/h
IDE00310-IDE02642,Outside temperature-Outside temp.: displayed value,-0.5, °C
IDE00310-MAS01632,Outside temperature-Status,filtered,
IDE00310-MAS05093,Outside temperature-Outside air temperature: raw value (unfiltered),3.5, °C
IDE00310-MAS05094,Outside temperature-Value used,-0.5, °C
IDE00588,Fuel tank fill level,59, l
IDE00707,Operating mode,OFF,
IDE00989-MAS01489,Blower status-Fresh air blower,OFF,
IDE00989-MAS02926,Blower status-Maximum wait time,0, s
IDE01011,Data record,09033854J11,
IDE01263,Coolant temperature of parking heater,6, °C
IDE01348-IDE00002,Switch-on conditions for auxiliary heater-Transport mode,not active,
IDE01348-IDE00025,Switch-on conditions for auxiliary heater-Coolant temperature,OK,
IDE01348-IDE00310,Switch-on conditions for auxiliary heater-Outside temperature,OK,
IDE01348-IDE01211,Switch-on conditions for auxiliary heater-Static current measuring mode,not active,
IDE01348-IDE06425,Switch-on conditions for auxiliary heater-Dynamometer mode: functional,not active,
IDE01348-MAS01468,Switch-on conditions for auxiliary heater-Terminal 15,active,
IDE01348-MAS01486,Switch-on conditions for auxiliary heater-Aux. heat.,supported,
IDE01348-MAS02575,Switch-on conditions for auxiliary heater-Initiation,detected,
IDE01348-MAS04447,Switch-on conditions for auxiliary heater-Engine running status,not detected,
IDE01348-MAS05009,Switch-on conditions for auxiliary heater-A/C request: auxil. heat mode,not active,
IDE01348-MAS05010,Switch-on conditions for auxiliary heater-Heater locked,not locked,
IDE01348-MAS05693,Switch-on conditions for auxiliary heater-Fault that prevents starting,not active,
IDE01463-MAS01458,Parking heater: operating condition-Operating condition,OFF,
IDE01463-MAS05031,Parking heater: operating condition-Heating performance,0, %
IDE01834,Battery voltage,12.120, V
IDE01839,Battery charge level,BEM_Release,
IDE02667-MAS02545,Cut-out requirements-Last,Timeout,
IDE02667-MAS02546,Cut-out requirements-Second to last,Timeout,
IDE02667-MAS02547,Cut-out requirements-Third to last,Timeout,
IDE02667-MAS02548,Cut-out requirements-Fourth to last,Timeout,
IDE06615,Combustion Air Blower,0, /min
IDE06616-MAS01580,Glow plug with flame monitoring-Activation,0.0, %
IDE06616-MAS05030,Glow plug with flame monitoring-Resistance,0.000, Ohm
IDE06617,Metering pump,0.00, Hz
;SW:7LA-907-426-A   HW:7LA-907-426-A ---  Auto HVAC
;Component:AC Manuell    H01 0502, Coding:D03010000810100001000800504001050000000000011000A00000000000
;Tuesday,28,December,2021,12:58:36:39992
;VCID: 41CA476CD015F2810E-8014
VWT6
Finland
C?ID=295527
The parking heater seems to have a different software loaded in: 5WA-963-272-A (vs. aux heater's ...271-A). Unfortunately also the hardware numbers differ, possibly just because of missing coolant change-over valve.
On T6 the same "retrofit" has been done just by reflashing the software with the correct one... so perhaps the same principle works also for T6.1.
The different HW number wasn't an issue on T6 (also missing the coolant change-over valve).
Reactions: JMR
freedomlives
Slovakia
C?ID=191048
Do y'all know if reflashing will be neccesary if one just wants to install a timer module (I picked up a Webasto 1530 timer quite cheap)? Granted I have a T5, but also with a Thermo Top C installed as an aux heater.
