Saturday,06,August,2022,15:01:42:45159
-- Windows Based VAG/VAS Emulator Running on Windows 11 x64
Version: 22.3.1.4 (x64) HEX-NET2 : 0.4623.4
VIN: TMBBD7NE6G0197907 License Plate:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 36 42 44 47 52 55 5F
A5
VIN: TMBBD7NE6G0197907 Mileage: 72429km-45005miles
03- Brakes -- Status: OK 0000
05-/Start Auth. -- Status: OK 0000
Address 01: Engine (J623-CJSA) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 264 H HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0003
Revision: --H13--- : 7C95FAEF
Coding: 0C2500322464010B1000
Shop #: 73430 031 00000
Dataset: EV_ECM18TFS0208V0906264H 001005
: EV_ECM18TFS0208V0906264H.
VCID: 41D42E4DD102CC73801-8014
VINID: 91D4925077951970012472401C50BC9287
20636 - Oxygen (Lambda) Sensor B1 S2
P0138 00 [096] - Signal too High
Mileage: 72319 km
Date: 2022.04.13
Time: 09:15:22
Engine RPM: 1412.50 /min
Normed load value: 24.3 %
Coolant temperature: 27 °C
Intake air temperature: 24 °C
Voltage terminal 30: 11.503 V
Unlearning counter according OBD: 30
Engine: operating status: IS
STATE_LS_SAE[1]: OL_CDN
T_AST_SAE: 0 s
MAP_MES_SAE: 57 kPa
VLS_DOWN_SAE[1]: 1.275 V
Lambda probe heater: resistance: bank 1: probe 2: 65535 Ohm
TEG_DYN_LS_DOWN[1]: 16.4750 °C
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 048 M HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 0610
Revision: 00005005 Serial number: CU501602045295 : 931EF1BB
Shop #: 73430 031 00063
Dataset: EV_TCMDQ200021 001001
: EV_TCMDQ200021_VW26.
VCID: 46DE3D51F82CEB4BB53-8012
Address 03: Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 60346000000183
Coding: 1A078A91342929730080060041CA2958512C9400608294F416415072C002
Dataset: EV_Brake1UDSContiMK100IPB 034036
: EV_Brake1UDSContiMK100IPB_034_VW37.
VCID: 7AA699A1FC545FAB81B-802E
Address 05: /Start Auth. (J518) Labels:| 5Q0-959-435.clb
Revision: 00021000 Serial number: 0393317616
Coding: 030C0C
Shop #: 73430 790 00000
Dataset: EV_KessyHellaMQBAB 002011
: EV_KessyHellaMQBAB_002.
VCID: 3A2659A1BCD49FABC1B-806E
Part No SW: 5E0 907 044 R HW: 5E0 907 044 R
Component: Climatronic H04 1002
Revision: 00001K07
Coding: 01110004000100011005000000101000
Dataset: EV_ACClimaBHBVW37X 004131
: EV_ACClimaBHBVW37X_004_VW37.
VCID: 343A77999EB069DB1B7-8060
Air quality sensor:
Part No SW: 5Q0 937 084 CL HW: 5Q0 937 084 AN
Component: MQBAB H H24 0175
Serial number: 01061603603355
Coding: 0F011B46C24722FB07A04082B10C07280800000000000000000000000000
Dataset: EV_BCMMQB 015001
: EV_BCMBOSCH_015.
VCID: 045AE7598E90195BEB7-8050
Subsystem 1 - Part No SW: 5E2 955 119 HW: 5E2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 151221 041 0570
Serial number: 160118180534
Coding: 065DDD
Component: 037 0059
Serial number: S2Y16M02D11H19M21S27
Coding: 00885D
Subsystem 3 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Serial number: 000000000ZY153153C2T
Serial number: 00000000000034487123
Part No SW: 5Q0 919 298 K HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0054
Revision: -------- Serial number: 39491602604954
Coding: 0131061051
Shop #: 73430 790 00063
Dataset: EV_EPHVA2CAU3700000 003021
: EV_EPHVA2CAU3700000_003.
VCID: 47C03055FF26F2434E5-8012
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 F
Component: Bosch H05 0400
Serial number: 17011603213278
Coding: 000C1600FE0339
Dataset: EV_ACCMRRBoschVW372 001016
: EV_ACCMRRBoschVW372_VW26.
Part No SW: 3Q0 959 655 AS HW: 3Q0 959 655 AS
Component: Airbag VW20 013 0200
Revision: -------- Serial number: 003SQP29VYJ5
Coding: 98CCC000000000005C5400CC008800000065
Dataset: EV_AirbaVW20TS6VW48X 001116
: EV_AirbaVW20TS6VW48X.
VCID: 0F70D875D7D66A03465-805A
Subsystem 1 - Part No SW: ----------- HW: 454 002 401 16
Serial number: 3576U000000BC37CC81V
Subsystem 2 - Part No SW: ----------- HW: 454 002 301 16
Serial number: 3586U000000B4B8CC81X
Subsystem 3 - Part No SW: ----------- HW: 454 801 201 16
Serial number: 3516R00BBD6090000006
Subsystem 4 - Part No SW: ----------- HW: 454 801 301 16
Serial number: 3526RE8A1D609000000I
Subsystem 5 - Part No SW: ----------- HW: 454 801 612 15
Serial number: 3556VD1955D09000000J
Part No SW: 5Q0 953 507 JB HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0120
Revision: -------- Serial number: 10011608491334
Coding: 6410
Dataset: EV_SMLSKLOMQB 020001
: EV_SMLSKLOMQB_020_VW37.
VCID: 7F5068B5E7767A83B65-802A
Part No SW: 5E0 920 910 B HW: 5E0 920 910 B
Component: KOMBI 324 6422
Coding: 27A401186D90A600018B6A031000000000000000
Dataset: EV_DashBoardVDDMQBAB 009046
: EV_DashBoardVDDMQBAB_009_VW26.
VCID: 21148ECD3142EC73E01-8074
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 F
Component: GW High 128 1244
Revision: -------- Serial number: 0004457625
Coding: 030100047F085900EB00025A1C0F00010001050000000000000000000000
: 01543C0000000600409C90000000C80000000000000000000000000000000000
Dataset: EV_GatewLear 013020
: EV_GatewLear_013.
VCID: 79A486ADF95254B3881-802C
Generator:
Subsystem 2 - Part No SW: 3V0 919 719 A HW: 3V0 919 719 A
Component: E221__MFL-PR6 H02 0150
Serial number: 000000000B0801010216
Subsystem 3 - Part No SW: 5Q0 915 181 H HW: 5Q0 915 181 H
Component: J367-BDMConti H02 1011
Serial number: 74185704001601290189
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000012455001
Coding: 5D00000000000000
Dataset: EV_ELVMarquMQB 004111
: EV_ELVMarquMQB.
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 B HW: 5Q0 959 760 B
Component: Sitzmemory H07 0020
Serial number: Y0006PA716224
Coding: 0014000000000500018480808080000000008181000000D400
Dataset: EV_SeatMemorDriveSide 002021
: EV_SeatMemorDriveSide.
VCID: 3C2A5FB9B6E0A19BD37-8068
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: FS 010 0031
Serial number: 0000186155669
Coding: 001D0020DE01040000001100
Dataset: EV_DCUDriveSideEWMAXCONT 006001
: EV_DCUDriveSideEWMAXCONT.
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000008796398
Coding: 1D0200
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1063
Coding: 9303
Dataset: EV_SteerAssisMQB 012140
: EV_SteerAssisMQB_012_VW37.
VCID: 44DA2759CE10D95BAB7-8010
Address 47: Sound System (J525) Labels:| 3Q0-035-466.clb
Part No SW: 3Q0 035 466 A HW: 3Q0 035 466 A
Component: MIB2_amp_P_SK H02 0250
Revision: 00000001 Serial number: SKZ8Z1FAS01697V
Coding: 0373010000AA002AAA0000000000
Dataset: EV_AMPMst16C4Gen2ALPI 001001
: EV_AMPMst16C4Gen2ALPI.
VCID: 2D0C62FD7D9A3813549-8078
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: BFS 010 0031
Serial number: 0000186009810
Dataset: EV_DCUPasseSideEWMAXCONT 006001
: EV_DCUPasseSideEWMAXCONT.
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000008751448
Coding: 050200
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: - H07 0090
Coding: 03DE00003F000000
Dataset: EV_HeadlRegulVWAFSMQB 001120
: EV_HeadlRegulVWAFSMQB.
VCID: 40D22B49DA08C57B8FF-8014
Subsystem 1 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo links H06 0009
Coding: 3E0000
Subsystem 2 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo rechts H06 0009
Coding: 3E0000
Address 5F: Information Electr. (J794) Labels:| 3V0-035--STD2.clb
Part No SW: 5Q0 035 874 A HW: 5Q0 035 874 A
Component: MU-S-ND-ER H25 0245
Serial number: SKZAZ2S5004232
Coding: 037301010000000011111202008800002F0203E601200100C6
Dataset: EV_MUStd4CTSAT 001022
: EV_MUStd4CTSAT_VW37.
VCID: 3236718164A467EB09B-8066
Subsystem 1 - Part No SW: 5E0 919 605 J HW: 5E0 919 605 J
Component: ABT_Std-2_Nav H41 1028
Serial number: SKZ8Z9SBT01PTK
6678 - Digital sound System control module
U106A 00 [008] - No Communication
[Control module for sound system: no communication]
Reset counter: 135
Mileage: 72263 km
Date: 2022.03.01
Time: 15:41:14
Voltage terminal 30: 12.1 V
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 5Q0-980-653.clb
Part No SW: 5Q0 980 653 G HW: 5Q0 980 653
Component: MQB_MFK H07 0060
Serial number: 10000499658
Coding: 0100010001030306000400000100010100
Dataset: EV_MFKBoschAU370 001001
: EV_MFKBoschAU370.
End----(Elapsed Time: 01:50, VBatt start/end: 11.7V/11.8V. VIgn 11.9V)-----
