Sticky Post up your scans please!
Sticky
If you have a HEX-NET and a Windows PC, we'd greatly appreciate it if you'd run two Auto-Scans and post 'em both, one with VCDS connected to the HEX-NET via USB and another with it connected via WiFi with the HEX-NET in Access Point mode. Of course, please make sure you're using the latest versions
Don't post 'em here, start a new thread for each car please.
I think we've made substantial progress over the last few weeks and we need to know what (if any) issues remain when using VCDS with a HEX-NET interface.
Thanks!
jyoung8607
FoRT
Garrettsville, OH
C?ID=25607
I should have a HEX-NET in a few days. I have access to a 2014 Beetle, a 2004 Passat GLX and a 2006 Phaeton W12.
For comparison, is it of any value to capture a third scan with my traditional HEX-USB+CAN?
Yes, if you have one, there certainly is value in posting it as a "reference" scan. That allows us to use a file comparison program to look for minor
FWIW, I expect the Beetle will work well, the Passat probably too, but the Phaeton may well have issues the HEX-NET.
Bump for more scans with the just-published Codeblock 0.4019 and VCDS Beta 14.4.1
stroker351w
C?ID=88386
Are you still looking for more comparison Scans? I will do it tonight on my '08 S6 if needed.
Scans are always good. Of course, please make sure you use current versions of all software / firmware.
jakematic
NC USA
C?ID=129085
Speaking of which, I'm desperately late in getting an updated set. Apologies.
Hoping to do this week - we're closing a quarter over here and it's been a wee bit of chaos lately...
hans j
Utah
C?ID=60436
This one that told me some ROD files were missing:
Wednesday,02,September,2015,15:11:08:05734
VCDS Version: 15.7.0.2 (x64)
Data version: 20150820
Dealer/Shop Name: Utah Imports hj
VIN: WVGFF9BP3BD007202   License Plate:
Mileage: 69222km-43012mi   Repair Order:
Chassis Type: BP (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 65
          69 6D 72
VIN: WVGFF9BP3BD007202   Mileage: 69222km-43012miles
Address 01: Engine (J623-CGRA)       Labels: None
   Part No SW: 03H 906 023 B    HW: 03H 907 309
   Component: 3,6 FSI ULEV2 H15 8643
   Revision: M7H15---
   Coding: 002A0012433600000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM36FSI01103H906023B 002005
   ROD: EV_ECM36FSI01103H906023B.rod
   VCID: A15AA51AB0DF0C36FA-80F4
5582 - Oil Pressure Switch for reduced Oil Pressure
          P164D 00 [032] - Malfunction
14690 - Loading Mode active
          P169A 00 [032] - -
7666 - EVAP System
          P0456 00 [096] - Very Small Leak Detected
Address 02: Auto Trans (J217)       Labels: 0C8-927-750.clb
   Part No SW: 0C8 927 750 A    HW: 0C8 927 750 A
   Component: AL1000 AISIN  001 1870
   Coding: 001368
   ASAM Dataset: EV_TCMAL991031 001001
   ROD: N/A
   VCID: AA484236CDE9CF6EAB-80FE
No ASAM data for: "EV_TCMAL991031" ()
Address 03: ABS Brakes (J104)       Labels: 7P0-907-379.clb
   Part No SW: 7P0 907 379 K    HW: 7P0 907 379 A
   Component: MK25A         H36 0418
   Revision: --------    Serial number: 411910010EC010
   Coding: 5B7613C34924255ADAF6C89392D4A4407700
   ASAM Dataset: EV_MK25AXT 007001
   ROD: EV_ESPMK25A01000.rod
   VCID: C592118A44B70016A6-8090
   Slave 1:
   Part No SW: 4H0 907 064 AK    HW: 4H0 907 064 AK
   Component: BCM2 2.0      H24 0217
   Coding: 09860000000000000000
   VCID: F2F89A562DB9C7AED3-80A6
   Subsystem 1 - Part No SW: 7P6 959 754 M    HW: 7P6 959 754 M
   Component: FBSTOUAREGIDG  H04 0051
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Component: J764 ELV MLB  H38 0044
Address 08: Auto HVAC (J255)       Labels: 7P6-907-040.clb
   Part No SW: 7P6 907 040 AG    HW: 7P6 907 040 AG
   Component: Klima 2 Zonen H18 0613
   Coding: 4606200880
   ROD: N/A
   VCID: F9EAAD7A78CFB4F692-80AC
No ASAM data for: "EV_AirCondiFront" ()
15360256 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 63
                    Mileage: 66483 km
                    Date: 2015.08.18
                    Time: 14:50:54
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063-V1.clb
   Part No SW: 4H0 907 063 L    HW: 4H0 907 063 D
   Component: BCM1 2.0      H12 0092
   Revision: 15012002    Serial number: 00000001053618
   Coding: 26001012973C5D010020180300005D0C431C660882010261000000020000
   VCID: B17A555AE83FBCB66A-80E4
   Subsystem 1 - Part No SW: 7P0 955 119     HW: 7P0 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    110430  31  0020
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 D    HW: 7P0 955 559 D  Labels: 8K0-955-559.CLB
   Component: RLFS  H09 0011
   Coding: 035223
   Subsystem 3 - Part No SW: 7P6 941 431 E    HW: 7P6 941 431 E
   Component: E1 - LDS  H04 0031
   Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
   Component: USHL4.2  H30 0020
Address 10: Park/Steer Assist (J446)       Labels: 7P6-919-475.clb
   Part No SW: 7P6 919 475     HW: 7P6 919 475
   Component: PARKHILFE 8K  H03 0016
   Revision: --------    Serial number: 55901112001647
   Coding: 118501
   ASAM Dataset: EV_VW526ParkiAssis2 001008
   ROD: EV_VW526ParkiAssis2.rod
   VCID: D5B2C1CAB417B096D6-8080
   Part No SW: 7P0 959 655 B    HW: 7P0 959 655 B
   Component: VW10Airbag02D H05 0023
   Revision: --------    Serial number: 003JX002K0RI
   Coding: 000000000000000000000000000000003244
   ROD: EV_AirbaVW10BPAVW526.rod
   VCID: C09C009E5B95253E95-8094
   Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
   Component: BF-Gewichtss.  003 0005
   Serial number: 5850000R10B09024B2
   Serial number: 3575LRB404R0HM78D11B
   Serial number: 3585LRB404P0HM78E0DM
   Serial number: 3515RRB40570I70G394N
   Serial number: 3525RRB40550I70G90CR
   Serial number: 3555NRB405B0GR36DGOW
   Serial number: 3565NRB405B0GR365PMW
Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
   Part No SW: 4H0 953 568 A    HW: 7P6 953 507
   Component: Lenks.Modul   H08 0007
   Revision: --------    Serial number: 90815KE20001F
   Coding: 000015
   Subsystem 1 - Part No SW: 7P6 959 542     HW: 7P6 959 542
   Component: E221__MFL-TAS  H03 0027
Address 17: Instruments (J285)       Labels: 7P6-920-xxx-17.clb
   Part No SW: 7P6 920 980 M    HW: 7P6 920 980 M
   Component: Kombi         H13 0239
   Revision: 11240062    Serial number: 658090511593038
   Coding: 8B6732022B00CF05020004
   ASAM Dataset: EV_KombiUDSRBVW526 001013
   ROD: EV_KombiUDSRBVW526.rod
   VCID: C690168679B10B0EAF-8092
   Part No SW: 7P6 907 530 C    HW: 7P6 907 530 A
   Component: GW-CAN-L-MOST H08 5202
   Revision: --------    Serial number: 00000000145245
   Coding: 0021032600
   ASAM Dataset: EV_GatewVW526UDS 001006
   ROD: EV_GatewUDS_VW52.rod
   VCID: B86C687E03456DFE2D-80EC
   Subsystem 1 - Part No SW: 7P0 915 181 A    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0140
   Serial number: 00000000005650393878
   Part No SW: 4H0 959 793 F    HW: 4H0 959 793 F
   Component: TSG FA        H07 0162
   Revision: --------    Serial number: 0000116218451
   Coding: 011D07200000453005080000
   VCID: BC64746E3F7D41DEC9-80E8
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0149433405
   Coding: 0186123A28B9500080B00620210000000000000000000000000000000000
   Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
   Component: GTO BT  H19 0059
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0162
   Revision: --------    Serial number: 0000115964630
   VCID: BB6677723A7346E6C0-80EE
Address 53: Parking Brake (J540-)       Labels: 7P0-907-801.clb
   Part No SW: 7P0 907 801 E    HW: 7P0 907 801 E
   Component: EPB           H51 1100
   Revision: 00000000    Serial number: A11409001BF
   Coding: 01040000
   Shop #: WSC 40306 001 1048576
   ROD: EV_ParkbA7.rod
   VCID: B572614A1457909636-80E0
   Slave 3:
0033 - Dynamic Start Assist Function Not Available
          C10DE 00 [008] -  -
                    Reset counter: 71
                    Mileage: 67228 km
                    Date: 2015.08.26
                    Time: 14:55:11
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Coding: 010A00010F000400
   ASAM Dataset: EV_HeadlRegulVWAFS 005006
   ROD: N/A
   VCID: FCE4B46E77FD81DE89-80A8
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0001
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0001
   Coding: 130000
No ASAM data for: "EV_HeadlRegulVWAFS" ()
   Part No SW: 4G0 035 082     HW: 4G0 035 082
   Component: Radio U SIRIU H51 0052
   Revision: AB001007    Serial number: 471E 0B7577036
   Coding: 020007020100000001
   VCID: DDA2D9EAC42768D69E-8088
   Part No SW: 7P6 035 664     HW: 7P6 035 664
   Component: H-BN-NA       H43 0170
   Revision: --------    Serial number: 445EX0B7514444
   Coding: 010200050040E1ED01022B0E00000003F0080101
   VCID: F5F2A14A5CD7D096F6-80A0
   Subsystem 1 - Part No: 8R0 060 884 P
   Component: NAR 2010  0407
   Subsystem 2 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: DU8 SV Touch  H24 0045
   Subsystem 3 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: CD-Database  1886
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0162
   Revision: --------    Serial number: 0000116084265
   Coding: 011C07200000253005080000
   VCID: BA68727635497FEEDB-80EE
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
   Component: RDKBERU25     H09 0008
   Serial number: 10000000029523
   ASAM Dataset: EV_RDKBERU25 003006
   ROD: N/A
   VCID: BF9E0362266B5AC6EC-80EA
No ASAM data for: "EV_RDKBERU25" ()
Address 69: Trailer (J345)       Labels: None
   Part No SW: 7P0 907 383 F    HW: 7P0 907 383 B
   Component: Anhaenger     H09 0110
   Revision: 5A001001    Serial number: 00000147065897
   Coding: 020D000000000000
Address 6D: Trunk Elect. (----)       Labels: 7N0-959-107.clb
   Part No SW: 7P6 959 107     HW: 7P6 959 107
   Component: HDSG-Modul    H10 0611
   Revision: 22010001    Serial number: 116100021
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202135
   ROD: EV_HeckkTouar.rod
   Component: TSG HR        H09 0162
   Revision: --------    Serial number: 0000116085283
End-------------------------(Elapsed Time: 02:39)--------------------------
Check the UDS_EV folder please and look at the date stamp on the Chassis.clb file.
hans j
Utah
C?ID=60436
8/12/15 6:15 am
OK, please replace that file with the one in this ZIP archive, I believe that will fix your missing ROD file issues.
For any lurkers, the issue with that file only affects NAR 7P Touaregs, (with 'BP' in the the 7th & 8th digits of the VIN), so unless you have a 2011 or newer NAR Touareg AND you have the file dated 8/12/15, you don't need this.
hans j
Utah
C?ID=60436
Thanks Uwe, I might not get a chance to recheck it as this was the customers first visit for a post purchase inspection on the vehicle.
