E-golf 85kW 2015/16 Sporadically AC functioning, and charging problems.
isakhansen
Norway
C?ID=448568
Thursday,09,December,2021,17:13:21:31688
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
Address BD: Hi Volt. Batt. Charg. Labels: None
Control Module Part Number: 5QE 915 022 J HW: 12E 915 022 C
Component and/or Version: LMSG H08 1084
Software Coding: CA0913040400
Work Shop Code: WSC 01357 011 00200
ASAM Dataset: EV_HVChargManagVWMQB 002002 (VW37)
ROD: EV_HVChargManagVWMQB_002.rod
VCID: 48C9518DF23447CB2F1-801C
2098720 - AirConditioning not possible because Battery SOC too Low
P33EF 00 [008] - -
Reset counter: 91
Mileage: 67163 km
Date: 2021.12.09
Time: 14:30:00
HV battery charge state: 100.0 %
Westbury, UK
We need a full Auto-Scan not just that small edited section.
Have you checked the SOC of the 12V battery?
isakhansen
Norway
C?ID=448568
No i have not.
So the "Battery SOC too low" refers to the 12V battery`s state of charge??
And why does the fault appear under the adress "Address BD: Hi Volt. Batt. Charg." if its the 12V battery?
I assumed that was the High voltage battery charger?
How do I check the SOC? Just measuring with a voltmeter or is there a parameter for that?
Here is the auto-scan
Wednesday,08,December,2021,15:25:54:31688
VIN: WVWZZZAUZGW907342   License Plate: EL84532
Mileage: 67118km-41705mi   Repair Order:
Chassis Type: AU-VW37 (5QE)
Scan: 01 03 05 08 09 10 13 15 16 17 19 23 2B 42 44 51 52 55 5F 75
          8C BD C5 C6
VIN: WVWZZZAUZGW907342   Mileage: 67118km-41705miles
BD-Hi Volt. Batt. Charg. -- Status: Malfunction 0010
C5-Therm. mgt. -- Status: Malfunction 0010
Address 01: Engine (J623-EAGA)       Labels:. 0EA-907-309-V1.clb
   Part No SW: 0EA 906 016 A    HW: 0EA 907 309 A
   Component: E-Vehicle     H23 8343
   Revision: WMH23---    CVN: A20C7889
   Coding: 000D0016006404003000
   ASAM Dataset: EV_VCU00XXX0110EA906016A 002015
   ROD: EV_VCU00XXX0110EA906016A_002.rod
   VCID: 2D0700197D9682E33C7-8078
   VINID: 9E69EAAAA465A979C90070C408727E9DAB
13821 - Engine Hood Switch Circuit
          P254F 00 [032] - Electrical Malfunction
25439 - Implausible Data Received from Battery Energy Control Module 2
          U0413 00 [032] - -
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 907 379 AK    HW: 5Q0 907 379 H
   Component: ESC           H31 0809
   Revision: 00000000    Serial number: 63145000000218 CVN: 5BC82836
   Coding: 01FA40A12C203173037A060441C5298002348CC0608294B3F8815078C242
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 001001
   ROD: EV_Brake1UDSContiMK100OMG_001.rod
   VCID: 055798B985A69AA3947-8050
16401 - Tire Pressure Warning
          C102D 00 [032] - -
   Revision: 00021000    Serial number: 0386832750
   Coding: 030C0C
   VCID: 3A2D3B45BCD8255BA95-806E
   Part No SW: 5GE 907 044 AD    HW: 5GE 907 044 AD
   Component: Climatronic   H02 1104
   Revision: 00001K07
   Coding: 00022200200100010005000200101003
   ASAM Dataset: EV_ACClimaBHBVW37X 005134
   VCID: 7EA5F755E070C97BD5D-802A
   Air quality sensor:
328199 - Position Sensor for Right Temperature Flap Motor
          B1095 15 [008] - Open or Short to Plus
                    Reset counter: 90
                    Mileage: 59958 km
                    Date: 2021.09.10
                    Time: 17:38:31
                    Voltage terminal 30: 13.4 V
                    Outside temperature: 24.5 °C
                    Inside temperature: 26.4 °C
                    Right temperature flap: actual value: 24
                    Right temperature flap: actual value: 0.0 %
                    Temperature door right - Specified value: 24
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Serial number: 01061529400835
   Coding: 00011A66C34102F36BEC4000001C07201800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 094F9489A9BEFEC3F0F-805C
   Component: WWS    151028  043 0551
   Serial number:         151114190318
   Component: RLHS  037 0059
   Serial number: S2Y15M11D28H02M43S40
   Coding: 90A8DD
204290 - Remote key 1
          B1479 18 [008] - Current Too Low
                    Reset counter: 54
                    Mileage: 62589 km
                    Date: 2021.10.10
                    Time: 18:40:48
   Revision: --------    Serial number: 39391532703696
   Coding: 2071151011
   VCID: 43D346A1CB126493FA3-8016
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 20111503274522
   Coding: 001C2300FE0739
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
1542 - Sensor for Automatic Distance Control
          C110B F0 [008] - Limited Visibility
          [FAULT_RADAR_BLIND]
                    Reset counter: 83
                    Mileage: 66407 km
                    Date: 2021.11.30
                    Time: 06:36:51
                    Control Module temperature: 17 °C
                    Voltage terminal 15: 14.7 V
                    Vehicle speed: 18.45 m/s
                    Acceleration: -0.22 m/s²
   Part No SW: 5Q0 959 655 S    HW: 5Q0 959 655 S
   Component: AirbagVW20    010 0870
   Serial number: 003MFR01K9AL
   Coding: 98CCC000002000005C0000CF004800000065
   VCID: 50F979ED0A648F0B771-8004
   Left seat belt tensioner:
   Serial number: 34169667B25111550356
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34169668B25111541176
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 011 15
   Serial number: 35700000000CB579671U
   Subsystem 4 - Part No SW: -----------    HW: 480 001 011 15
   Serial number: 3580000000076679671M
   Subsystem 5 - Part No SW: -----------    HW: 480 402 108 15
   Serial number: 3510002AF1CB0C01C1CC
   Subsystem 6 - Part No SW: -----------    HW: 480 400 809 15
   Serial number: 35200029F1CB0C22B2EH
   Subsystem 7 - Part No SW: -----------    HW: 480 401 711 15
   Serial number: 3550002A51E34432A29$
   Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 21111504401066
   Coding: 0410
   ASAM Dataset: EV_SMLSKLOMQB 020001
   ROD: EV_SMLSKLOMQB_018_VW37.rod
   VCID: 074B92B1BFAA88B3E6B-8052
   Part No SW: 5GE 920 755 A    HW: 5GE 920 755 A
   Component: KOMBI         302 6420
   Coding: 072518182F800008018868011600002000000000
   VCID: 3E253755A0F0097B95D-806A
Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
   Part No SW: 5QE 907 530 E    HW: 5QE 907 530 A
   Component: GW MQB EV     312 3244
   Revision: --------    Serial number: 09111510520124
   Coding: 0201001706F81000FB001210081F00000001050100030000000300000000
   GVL: 01543C0000000608540C9000A000481800000000000000000000000000000000
   ASAM Dataset: EV_GatewEVConti 013020
   ROD: EV_GatewEVConti_013.rod
   Subsystem 1 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0040
   Serial number: 29150002298150035465
   Coding: 2CFFFF
   Subsystem 2 - Part No SW: 5Q0 915 181 G    HW: 5Q0 915 181 G
   Serial number: 6162308503
Address 23: Brake Booster (J539)       Labels:* None
   Part No SW: 5QE 909 059 D    HW: 5QE 909 059 B
   Component: EBKV          H14 0182
   Serial number:   085430010683
   Coding: 01720100321900030002000500
   ASAM Dataset: EV_BrakeBoostBoschMQBOMG 003001
   ROD: EV_BrakeBoostBoschMQBOMG_003_VW37.rod
   VCID: 4FFB7A91175A90F36EB-801A
   Brake pressure reservoir:
   Subsystem 1 - Part No SW: 5QE 909 057 C    HW: 5QE 909 057 A
   Component: VX70BrakeAssi  H04 0152
   Serial number: 05802861171115080032
   Revision: 00000000    Serial number: 15000245947002
   Coding: 7900000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3431157D9EBCD32B739-8060
   Serial number: 290915BIS11269
   Coding: 003F1320D000048000001000
   Serial number: 00000000000008167066
   Coding: 110000
   Part No SW: 5Q0 909 144 S    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  126 1063
   Coding: C102
   VCID: 44D145BDCE1C63ABC39-8010
   Part No SW: 5QE 907 080 D    HW: 5QE 907 080 D
   Component: VW370E2615020 H07 2470
   Revision: 00H07000    CVN: CE55C6DB
   Coding: C0020000000000000000
   ASAM Dataset: EV_DMCM09550115QE907080D 001021
   ROD: EV_DMCM09550115QE907080C.rod
   VCID: 47CB52B1FF2A48B326B-8012
   Serial number: 021015BJ113027
   Coding: 003F1120DE00048000001000
   VCID: 42DD43A5D4086D9BF15-8016
   Serial number: 00000000000008138622
   Coding: 090000
   Coding: 051A000001010000
   VCID: 75B7E879D5468A23847-8020
   Part No SW: 3G0 035 020 J    HW: 3G0 035 020
   Component: MU-H-ND-EU    H50 0343
   Serial number: A682K0FB005354
   Coding: 02737001FF00000051111101008808001F0105D401200100DE
   VCID: 1E65D7D50030697BB5D-804A
   Component: ABT_High  H62 0031
   Serial number: VWZ8Z9RU3046MB
   Subsystem 2 - Part No SW: V03 959 800 QN    HW: -----------
   Component: ECE 2016  --- 0134
   Compact disc data bank:
   Component: Gracenote2  --- 1012
1637 - Interface for External Media
          U11B8 00 [008] - No Communications
          [USB - communication error]
                    Fault Frequency: 8
                    Reset counter: 62
                    Mileage: 52714 km
                    Date: 2021.06.06
                    Time: 12:29:13
                    Voltage terminal 30: 13.3 V
                    Interface for external media: status-Status: Open circuit
   Part No SW: 5QE 035 284 C    HW: 5QE 035 284 C
   Component: OCULowMQBEU   012 0715
   Coding: 0273700110829A0100F800000000
   ROD: EV_OCULowMQB.rod
Address 8C: HV Battery (J840)       Labels: 5QE-915-227.clb
   Part No SW: 5QE 915 227 M    HW: 5QE 915 227 H
   Component: K8C           H13 0731
   Serial number: VWADFLS00H     CVN: F113BE7D
   ASAM Dataset: EV_BECM08820215QE915227M 003016
   ROD: EV_BECM08820215QE915227H.rod
   VCID: 52FD73E50468FD1B415-8006
Address BD: Hi Volt. Batt. Charg. (J966)       Labels:* None
   Part No SW: 5QE 915 022 J    HW: 12E 915 022 C
   Component: LMSG          H08 1084
   Serial number: 00920054510067
2097168 - Battery Charging Malfunction
          P33EA 00 [008] - -
                    Fault Frequency: 46
                    Reset counter: 83
                    Mileage: 63049 km
                    Date: 2021.10.15
                    Time: 11:01:36
                    Ready to charge-Operational readiness in H-V system: not active
                    Ready to charge-Status charge readiness: engine: not operational
                    Ready to charge-Status charge readiness charge mngmt.: operational
                    Spec. mode: load mgmnt.: Standby
2098176 - DC Quick-Charge; Charging Station Initialization Error
          P33E5 00 [008] - -
                    Reset counter: 71
                    Mileage: 64870 km
                    Date: 2021.11.10
                    Time: 20:06:25
                    Chademo version-Vehicle: 0
                    Chademo version-Charging Station: 0
                    DC charging PLC-Malfunction status: 0
                    DC charging PLC-Current: actual value: 0.0 A
                    DC charging PLC-Connection status: not installed
                    DC charging PLC-Minimum voltage: 0.0 V
                    DC charging PLC-Maximum voltage: 0.0 V
                    DC charging PLC-Minimum current: 0.0 A
                    DC charging PLC-Maximum current: 0.0 A
                    DC charging PLC-Actual Voltage: 0.0 V
                    Status of actuator test: not active
          P33EF 00 [008] - -
                    Fault Frequency: 118
                    Reset counter: 90
                    Mileage: 56943 km
                    Date: 2021.08.02
                    Time: 05:45:00
Address C5: Therm. mgt. (J1024)       Labels: None
   Part No SW: 5GE 907 458 A    HW: 5GE 907 458
   Component: TME-Min       H04 0109
   Serial number: 0014711
   ASAM Dataset: EV_ThermContrVISAU49X 001009
   ROD: EV_ThermContrVISAU49X_VW37.rod
   Subsystem 1 - Part No SW: 4M0 959 603     HW: 4M0 959 603
   Component: G395 pT-Sens1  H61 0006
   Subsystem 2 - Part No SW: 12E 963 231 F    HW: 12E 963 231 F
   Component: J848 HV-PTC  H09 0206
   Serial number: LM161343003807000240
   A/C compressor sub:
   Subsystem 3 - Part No SW: 5QE 820 803 A    HW: 5QE 820 803 A
   Component: J842 eKK  H03 0007
   A/C pressure/coolant temperature sensor 2:
   Subsystem 4 - Part No SW: 4M0 959 603     HW: 4M0 959 603
   Component: G826 pT-Sens2  H61 0006
   A/C pressure/coolant temperature sensor 3:
   Subsystem 5 - Part No SW: 4M0 959 603     HW: 4M0 959 603
   Component: G827 pT-Sens3  H61 0006
   A/C pressure/coolant temperature sensor 5:
   Subsystem 6 - Part No SW: 4M0 959 603     HW: 4M0 959 603
   Component: G829 pT-Sens5  H61 0006
   Expansion valve 1 for refrigerant:
   Subsystem 7 - Part No SW: 4M0 816 682 D    HW: 4M0 816 682 D
   Component: N636 EV1_KaMi  H10 0102
   Serial number: 00000000000120079490
   Expansion valve 2 for refrigerant:
   Subsystem 8 - Part No SW: 4M0 816 682 D    HW: 4M0 816 682 D
   Component: N637 EV2_KaMi  H10 0102
   Serial number: 00000000000120079483
   Expansion valve 3 for refrigerant:
   Subsystem 9 - Part No SW: 4M0 816 682 D    HW: 4M0 816 682 D
   Component: N638 EV3_KaMi  H10 0102
   Serial number: 00000000000120079493
   Shut-off valve 1 for refrigerant:
   Subsystem 10 - Part No SW: 4M0 816 703 B    HW: 4M0 816 703 B
   Component: V424 AV1_KaMi  H10 0102
   Serial number: 00000000000140079265
   Shut-off valve 4 for refrigerant:
   Subsystem 11 - Part No SW: 4M0 816 703 B    HW: 4M0 816 703 B
   Component: N642 AV4_KaMi  H10 0102
   Serial number: 00000000000140079070
   Shut-off valve 5 for refrigerant:
   Subsystem 12 - Part No SW: 4M0 816 703 A    HW: 4M0 816 703 A
   Component: N643 AV5_KaMi  H09 0102
   Serial number: 00000000000040075262
11 Faults Found:
4118 - Refrigerant Pressure/Temperature Sensor 4
          P1C62 00 [101] - Faulty
                    Mileage: 52798 km
                    Date: 2021.06.07
                    Time: 14:18:15
4132 - ROD - Unknown Error Code
          - 00 [040]
                    Fault Frequency: 62
                    Mileage: 60468 km
                    Date: 2021.09.17
                    Time: 06:10:16
4136 - Refrigerant Shut-Off Valve 4
          P1C32 00 [109] - Mechanical Malfunction
                    Mileage: 52389 km
                    Date: 2021.06.03
                    Time: 15:20:22
32837 - HV Electronics Coolant Pump Control
          P0CEB 00 [032] - Short to GND
                    Fault Frequency: 149
                    Mileage: 52601 km
                    Date: 2021.06.05
                    Time: 09:57:02
36919 - Databus
          U1123 00 [046] - Received Error Message
          [Klima_EV_05: KL_TaupEps_Korr empfangener Fehlerwert]
                    Fault Frequency: 57
                    Mileage: 56913 km
                    Date: 2021.07.31
                    Time: 17:08:59
37017 - Refrigerant Pressure/Temperature Sensor 4
          P1C63 00 [047] - No Signal
                    Mileage: 52389 km
                    Date: 2021.06.03
                    Time: 15:03:55
37096 - Automatic addressing Sub Bus 1
          B1484 21 [047] - Signal Amplitude Too Low
                    Mileage: 52389 km
                    Date: 2021.06.03
                    Time: 15:20:26
59042 - Refrigerant Pressure/Temperature Sensor 5
          P1C65 00 [047] - Faulty
                    Mileage: 52389 km
                    Date: 2021.06.03
                    Time: 15:03:55
59043 - Refrigerant Pressure/Temperature Sensor 5
                    Mileage: 52389 km
                    Date: 2021.06.03
                    Time: 15:03:55
59079 - Refrigerant Shut-Off Valve 1
          P1C1A 00 [032] - Mechanical Malfunction
59103 - Refrigerant Shut-Off Valve 4
          P1C32 00 [032] - Mechanical Malfunction
Address C6: Batt. Chrg. (J1050)       Labels: 5QE-915-681.clb
   Part No SW: 12E 915 682 R    HW: 12E 915 682 R
   Component: OBC KOSTAL    H22 0146
   Revision: --------    Serial number: 1811150JR0007E
   ASAM Dataset: EV_OBCSinglPhaseKLOVW3707 003001
   ROD: EV_OBCSinglPhaseKLOVW120_004.rod
   VCID: 392F2449B9DE2E43A0F-806C
14745861 - Internal Control Module Memory Check Sum Error
          B2000 00 [009] - -
          [HV-DC-current_sensor_implausible_value]
                    Mileage: 66478 km
                    Date: 2021.12.01
                    Time: 06:43:07
End----------(Elapsed Time: 02:06, VBatt start/end: 14.9V/14.9V)-----------
Gateway Installation List:  5QE 907 530 E
BD-Hi Volt. Batt. Charg. -- Status: OK 0000
Wednesday,08,December,2021,15:30:55:31688
          8C BD C5 C6
   Coding: 030C0C
   Revision: 00001K07
   Air quality sensor:
   Coding: 90A8DD
   Coding: 2071151011
   Coding: 333135
   Coding: 333135
   Coding: 0410
   Coding: 2CFFFF
   Coding: 110000
   Coding: C102
   Coding: 090000
   A/C compressor sub:
          P1C63 00 [039] - No Signal
                    Mileage: 67118 km
                    Date: 2021.12.08
                    Time: 15:26:46
          P1C65 00 [039] - Faulty
                    Mileage: 67118 km
                    Date: 2021.12.08
                    Time: 15:26:47
                    Mileage: 67118 km
                    Date: 2021.12.08
                    Time: 15:26:47
          B2000 00 [009] - -
                    Mileage: 66478 km
                    Date: 2021.12.01
                    Time: 06:43:07
End----------(Elapsed Time: 01:59, VBatt start/end: 14.9V/15.0V)-----------
Westbury, UK
Look at the voltage shown at the end of the full Auto-Scan, 14.9/15.0V is IMHO abnormally hgh for any type of 12V battery (charging normally stops at approx. 14.5V).
isakhansen
Norway
C?ID=448568
I agree
The problem is probably in the 12V battery charger then?
Thanks for reply btw:)
Westbury, UK
I agree
There are several other problems shown in the Auto-Scan, I don't think they are all 12V battery voltage related (e.g. one remote key needs a new battery, auto distance sensor limited visibilty, ...)
isakhansen
Norway
C?ID=448568
Yes, most of them are intermittent and have not appeared again after I cleared them. I have also changed the remote key battery.
In the question above I am referring to the problem about the departure time function that does not always work. (AC sporadically working).
In the auto-scan I did after clearing DTC's, the fault (AC Departure time) did not show.
Altough it does not fix the problem, it has occured after clearing them, and then it shows in the auto-scan again.
Auto-scan after clearing all DTC's
Wednesday,08,December,2021,15:29:33:31688
          8C BD C5 C6
   Coding: 030C0C
   Revision: 00001K07
   Air quality sensor:
   Coding: 90A8DD
   Coding: 2071151011
   Coding: 333135
   Coding: 333135
   Coding: 0410
   Coding: 2CFFFF
   Coding: 110000
   Coding: C102
   Coding: 090000
   A/C compressor sub:
                    Mileage: 67118 km
                    Date: 2021.12.08
                    Time: 15:26:46
                    Mileage: 67118 km
                    Date: 2021.12.08
                    Time: 15:26:47
                    Mileage: 67118 km
                    Date: 2021.12.08
                    Time: 15:26:47
          B2000 00 [009] - -
                    Mileage: 66478 km
                    Date: 2021.12.01
                    Time: 06:43:07
Westbury, UK
The three "Refrigerant Pressure/Temperature Sensor" errors in #C5 suggest a problem in the HV battery temperature management system - I'm not familiar with that system so could only make 'wild guess' suggestions but what I will say is that I reckon this needs fixing.
The "Internal Control Module Check Sum Error" in #C6 also needs fixing since the "HV-DC-current_sensor-implausibe-value" suggests that the SoC of the HV battery cannot be correctly determined.
With these errors present it seems entirely plausible that the departure time feature won't be reliable and/or work correctly.
isakhansen
Norway
C?ID=448568
That makes sense, thanks:)
Do you have in tips on how to fix "Internal Control Module Check Sum Error" in #C6 ?
isakhansen
Norway
C?ID=448568
I have an E-golf 85kW mod. first registered in November 2015
During my ownership of this car (about 7 months) I have encounterd a couple of problems
#1 From time to time I have an issue with the AC sporadically working. (Low heating and cooling performance or none at all. Altough this is not permanent, sometimes it works perfectly)
(Could that be due to the faulty "Refrigerant Pressure/Temperature Sensors" in Adress C5?)
#2 When I charge from a wall socket I occasionally return to a car that has stopped charging for some reason, which I can't figure out. The led in the carging port on the car is blinking red. (According to the service manual a red blinking light indicates a problem in the onboard charger. Could that be the case, that I need to replace the onboard charger in the car?)
This has happened at different times during the day, in other sockets and locations (has also happened at work).
Although if i happen to notice that the charging has stopped, and plug the charging cable in and out it starts charging just fine, until the battery is full.
What wonders me the most is that the car can charge fine everday for weeks at a time. Then one day out of the blue it has stopped, but has zero problems for weeks again. This seems to go on and on.
          8C BD C5 C6
   Coding: 030C0C
   Revision: 00001K07
   Air quality sensor:
   Coding: 90A8DD
   Coding: 2071151011
   Coding: 333135
   Coding: 333135
   Coding: 0410
   Coding: 2CFFFF
   Coding: 110000
   Coding: C102
   Coding: 090000
   A/C compressor sub:
                    Mileage: 67118 km
                    Date: 2021.12.08
                    Time: 15:26:46
                    Mileage: 67118 km
                    Date: 2021.12.08
                    Time: 15:26:47
                    Mileage: 67118 km
                    Date: 2021.12.08
                    Time: 15:26:47
          B2000 00 [009] - -
                    Mileage: 66478 km
                    Date: 2021.12.01
                    Time: 06:43:07
@isakhansen: Hi. Apropos of the hex C6 DTC, a checksum is a type of "health check" of the veracity of the dataset values in module's digital memory.
A check sum is number that is calculated when the module's dataset is created by an algorithm based on the values in the memory locations that are being monitored. This number is loaded into the module together with the dataset and it is used initially as a check that the module program has been successfully transferred.
In daily use, whenever a health check of the module's dataset is undertaken (this is a regular process), a new checksum number is calculated (using the same algorithm) and the new value is compared against the original number. If the 2 x numbers are not the same, a checksum error is generated indicating that there has been a corruption of the stored values in digital memory
In your case, notice the date/mileage stamp on the DTC - compare these with the date/mileage stamp of the entire auto-scan. Fault Frequency=1 means that the checksum error has NOT re-occurred on a subsequent ignition cycle until the auto-scan was created. So an infrequent fault!! Nevertheless, the DTC is present as a "confirmed" error - which indicates an internal problem with the module.
@isakhansen: hmm......... with my apology to @PetrolDave for unknowingly stealing his thunder - you have created 2 x posts for the same problems. This is a no-no - which can sometimes incur the terrible wrath of a fearsome forum member!!! :D
Anyhow - maybe read my response on your duplicate thread!
Threads merged.
isakhansen
Norway
C?ID=448568
My apologies
isakhansen
Norway
C?ID=448568
Does that mean I have to replace the module?
@isakhansen : I'm not familiar with your particular hexC6 module - but my general rule of thumb is to only change modules if I'm relatively sure that it's necessary.
One of the many problems with "remote" diagnostics on forums is just that (i.e. it's done remotely)! This invariably means that conclusions are based on scant pieces of information and without the invaluable benefit of actual access to the part/car.
The compelling evidence of the DTC descriptor - which indicates that the problem relates to a checksum- is highly suggestive that either some part(s) of module dataset itself, or the memory location(s) inside the module that hold the dataset has become corrupted. In addition, your story regarding interruptions to the charging cycle tends to substantiate the hypothesis that the hexc6 module is problematic.
However, if I had access to the car, I would prefer to investigate "HV-DC-current_sensor_implausible_value" further. This suggests (to me at least) that the problem could reside in a "pick-up coil" somewhere. Now, I have no idea where this transducer could be located (it may be inside the module housing) and I'm purely guessing!!! And of course, there is the question of cause-and-effect to consider!!
As I said, my personal approach to these type of issues is to collect as much information as possible before I throw money at a new module - but I'm also a devout believer in the holy doctrine of Occam's razor (it's a much undervalued principle in diagnostics - IMO)!
It's entirely your decision - you could keep an eye on the Fault Frequency and confirm that any further charging difficulties align with an increasing value in this number, maybe?
This said, what is relatively clear (IMO, of course) from the information provided is that the role of VCDS in regard to the hex6C module is purely one of DTC monitoring!
isakhansen
Norway
C?ID=448568
Thanks for reply:)
Two days ago I witnessed the charging problem. (Date: 15/12-21 Time: 21:00)
I plug the charging cable in a wall outlet at home, then I plugged it in the charging port in the car. The car starts to charge as it should with a pulsating green light in the charging port.
Then, I happened to be in the garage just long enough to hear the charging is interrupted. (I can hear the car charger under the panser click). This occured roughly 20 seconds after I plugged the charging cable in the car, and it started to charge.
After about 10 seconds the car apptemts charging again (on its own), and it does. 20 seconds later is stops again.
This repeats itself 3 times. Then it stops completely and the led in the charging port is blinking red.
Frustrated, I take the cable out of the car and plug it in again. To my surprise the cars starts charging, just fine until the battery is full. (Not less frustrated btw, I feel that the charging is not reliable. The We connect app comes in handy here, being able to monitor it, altough the app itsoelf does not work perfect all the time.)
Minutes after i do an Auto-scan hoping to discover something. I can not see any new DTC's In the Adress C6. Neither are there any DTC's dated to the same date and time this problem occured.
The Fault frequency of "HV-DC-current_sensor_implausible_value" is not changed.
Altough there is a DTC in the adress BD "Battery charging malfunction". But the date does not match there neither. Nor the Fault Frequency
Just want to add that all response is highly appreciated. Even if it does not offer an exact solution, I do like to know more about why the car behaves as it does.
So again,
Thank you :)
Wednesday,15,December,2021,21:08:15:31688
Mileage: 67650km-42035mi   Repair Order:
          8C BD C5 C6
VIN: WVWZZZAUZGW907342   Mileage: 67650km-42035miles
   Coding: 030C0C
   Revision: 00001K07
   Air quality sensor:
   Coding: 90A8DD
   Coding: 2071151011
   Coding: 333135
   Coding: 333135
   Coding: 0410
   Coding: 2CFFFF
   Coding: 110000
   Coding: C102
   Coding: 090000
          P33EA 00 [008] - -
                    Reset counter: 95
                    Mileage: 67343 km
                    Date: 2021.12.11
                    Time: 17:04:48
          P33EF 00 [008] - -
                    Fault Frequency: 8
                    Reset counter: 95
                    Mileage: 67163 km
                    Date: 2021.12.09
                    Time: 14:30:00
   A/C compressor sub:
7 Faults Found:
          - 00 [040]
                    Mileage: 67163 km
                    Date: 2021.12.09
                    Time: 14:38:01
                    Mileage: 67305 km
                    Date: 2021.12.10
                    Time: 19:29:08
36919 - Databus
          U1123 00 [040] - Received Error Message
                    Fault Frequency: 9
                    Mileage: 67203 km
                    Date: 2021.12.09
                    Time: 21:00:26
                    Fault Frequency: 41
                    Mileage: 67118 km
                    Date: 2021.12.08
                    Time: 19:21:56
                    Mileage: 67118 km
                    Date: 2021.12.08
                    Time: 19:24:02
                    Mileage: 67118 km
                    Date: 2021.12.08
                    Time: 19:21:56
                    Mileage: 67118 km
                    Date: 2021.12.08
                    Time: 19:21:56
          B2000 00 [009] - -
                    Mileage: 66478 km
                    Date: 2021.12.01
                    Time: 06:43:07
End----------(Elapsed Time: 02:03, VBatt start/end: 13.1V/13.1V)-----------
  • Informative
@isakhansen: hmm.... thanks for the additional information (each piece of new data adds extra flesh to the diagnostic skeleton - so always a good thing!!)
As I said, my first response was purely about the hex 6C module - but a further observation regarding your latest chronology of events might be useful (maybe?). And, please accept my apology in advance if you already know this stuff and my further apology if my amateur explanation differs from the official version - but here goes:
I suspect a good place to start is to make sure that there is a proper understanding of the anatomy of the Freeze Frame information that accompanies (some) DTCs. Here is an example of the details from your auto-scan:
Freeze Frame:​
Fault Status: 00000001​
Fault Priority: 6​
Fault Frequency: 8​
Reset counter: 95​
Mileage: 67163 km​
Date: 2021.12.09​
Time: 14:30:00​
Whilst Freeze Frame might appear at first blush to be VCDS thing, the information and the underlying data structure is in reality a product of the underpinning OBD Standards (in your case, OBD-II/EOBD). VCDS really is nothing more than the messenger extracting reports that the module has been designed to spit-out when certain events occur.
In my first response, I told you a "porkie" in that I suggested that the Freeze Frame information is related to an "ignition cycle". This was a (little) white-lie that I used for simplicity. In truth, the foundational basis for Freeze Frame data is a construct that the OBD Standard calls a Drive Cycle, which differs from an ignition cycle - but for ease of understanding, let's not worry about the pedant details of the variations.
So - like death-and-taxes, modules are programmed to undertake a range of self-test exercises with monotonous certainty and regularity whenever the ignition is turned-on (Drive cycle). If a set of predefined thresholds is exceeded as a result of these tests, a DTC will be registered and elements of Freeze Frame information may be populated/updated as shown above.
Date/Time = self explanatory albeit sometimes (not infrequently with older modules?) these data-stamps can be wrong. In your case, these fields appear to be correct
Mileage = self explanatory
Fault Status: This is a single Byte (meaning that it has 8 x Bits of information) that indicates the timing of the DTC occurrence in regard to current/previous test cycle. For example, in the DTC above, Bit 0 is set (Bytes are read from right-to-left), which means that the test failed on the current operation cycle
Fault Priority: This is measure of fault severity defined as follows:
#Explanation
1The fault has a strong influence on drivability, an immediate stop is required.
2The fault requires an immediate service appointment.
3The fault doesn’t require an immediate service appointment, but it should be corrected with the next service appointment.
4The fault recommends an action to be taken, otherwise drivability might be affected.
5The fault has no influence on drivability.
6The fault has a long term influence on drivability.
7The fault has an influence on the comfort functions but doesn’t influence the car’s drivability.
Counters- Fault Frequency and Reset Counter : I've coupled these "counters" together because they really measure the same thing - but in opposite directions! If self-test process is undertaken in an ignition cycle and a DTC has been registered in a previous ignition cycle:
  • if the same fault is evident, the Fault Frequency number will increase
  • if the same fault is not evident, the Reset Counter will decrease
    • the initial number for Reset Counter is established when the DTC is first registered depending on the nature of the fault.
    • When the number for Reset Counter decreases to zero, the DTC is cleared automatically
So - what does this all mean? Well.... it means that according to your explanation of events, unless a DTC happened for the first time on "Date: 15/12-21 Time: 21:00", your auto-scan won't report that particular date/time stamp. Instead, and again if the same event happened earlier - any new occurrence will simply increase the Fault Frequency number.
You could try clearing the DTCs - which will then reset the Freeze Frame counters and the date/time stamp. So any new registration of the DTC will show the new date/time
isakhansen
Norway
C?ID=448568
Freeze Frame:​
Fault Priority: 6​
Fault Frequency: 8​
Reset counter: 95​
Mileage: 67163 km​
Date: 2021.12.09​
Time: 14:30:00​
#Explanation
I will try clearing the DTC's so I can se which DTC's I get when the problem occurs again.
Thanks again:)
isakhansen
Norway
C?ID=448568
Update
After a couple of days with heavy rain the car would not charge at all.
The problems related to charging, is according to VW dealer, caused by bad insulation in the charging port and/ or cable mounted in the car. This is also sets DTC "HV-DC-current_sensor_implausible_value" in the adress C6
Their answer to why the insulation is bad is; "Due to water intrusion over time".
When the chargin port is mounted downwords, combined with chargin outside in the rain, this seems like a likely problem that could occur over time....
I will try to remove the chargin port in the car and dry and clean it.
If anyone has a Techincal bulletin on changin chargin port on VW e-golf 2016 it is highly appreciated:)
VW dealer takes 26 000 NOK to fix it.
  • Informative
