2000 TDI Jetta, just getting verified and wrapping my head around all this
Wrenchly
Pacific Northwest, USA
I'm still getting the initial setup finalized, but here goes with doing things backwards! A full auto-scan:
Sunday,05,December,2021,13:37:30:18691
VCDS Version: 21.9.0.2  HEX-V2 CB: 0.4555.4
Mileage: 530510km-329643mi   Repair Order:
Chassis Type: 9M - VW Jetta IV (1998 > 2014)
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
          75 76
   Mileage: 530510km-329643miles
Address 01: Engine        Labels: 038-906-012-AGR.clb
   Part No: 038 906 012 BD
   Component: 1,9l R4 EDC G000SG  2507
   Coding: 00002
   Shop #: WSC 00066
   VCID: 53F37796B2E1D8A34A3-4B3C
16955 - Brake Switch (F)
            P0571 - 35-00 - Implausible Signal
17964 - Charge Pressure Control
            P1556 - 35-10 - Negative Deviation - Intermittent
16764 - Glow Plug/Heater (Q6) Circuit
            P0380 - 35-10 - Malfunction - Intermittent
Readiness: 1 2 0 0 0
Address 03: ABS Brakes        Labels: 1J0-907-37x-ABS.clb
   Part No: 1J0 907 379 P
   Component: ABS     20 IE CAN  0001
   Coding: 03504
   Shop #: WSC 00066
   VCID: 3E253622296325CB95D-4B00
00283 - ABS Wheel Speed Sensor; Front Left  (G47)
            35-10 - - - Intermittent
            16-10 - Signal Outside Specifications - Intermittent
   Part No: 6Q0 909 605 A
   Component: 09 AIRBAG VW5       0003
   Coding: 12345
   Shop #: WSC 00066
   VCID: 3537290E1C55E693447-4B3C
Address 17: Instruments        Labels: 1J0-920-xx0-17.lbl
   Part No: 1J0 920 900 L
   Component: A4-KOMBIINSTR. VDO V54
   Coding: 07242
   Shop #: WSC 00066
   VCID: 2B030F76CA11A063223-5184
   Subsystem 1 - Part No: IMMO
   Component: IDENTNR: VWZ7Z0X1303660
   IMMO-IDENTNR: VWZ7Z0X1303660
01039 - Coolant Temperature Sensor (G2)
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 00066
   VCID: 70B9D81A23B783BB571-5184
   Part No: 1J0 959 799 AJ
   Component: 61 Zentral-SG Komf. 0001
   Coding: 04096
   Shop #: WSC 00066
   VCID: 06559EC23133BD0B9DD-4B1E
   Subsystem 1 - Part No: 1J1959801C
   Component: 61 Tõrsteuerger. FS0002r
   Subsystem 2 - Part No: 1J1959802D
   Component: 61 Tõrsteuerger. BF0002r
   Subsystem 3 - Part No: 1J4959811C
   Component: 61 Tõrsteuerger. HL0002H
   Subsystem 4 - Part No: 1J4959812C
   Component: 61 Tõrsteuerger. HR0002r
00953 - Interior Light Time limit
            25-10 - Unknown Switch Condition - Intermittent
End----(Elapsed Time: 05:25, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
The primary reason I bought in to this was to get some old keys deleted from the car, but I guess that's not really what I should be worried about! And it seems I need a PIN to deal with that, but I'm PIN-less at this point so I guess that can wait for another day
The car has a number of things that need work, and I had only known about a couple items the scan is listing. I knew about the turbo boost going negative, and the glow plug heater circuit. All the rest is new territory for me
The combo coolant temp sensor seems to have a bad connection at the harness connector, still haven't sprayed some contact cleaner in that. The dash gauge stops working at times, but after unplugging & plugging it back in, was 'fixed' for a while
Every now & then, the brakes make a really bad grinding noise and the pedal feels like a bucket of gravel went through the caliper
And my most favorite problem, the turbo never gets past 2.8lbs most days. But on random cold starts, will jump to 10 lbs in 2nd & 3rd. I do wish it would always hit 10 lbs everytime I floor the car. I'm thinking there's probably a ton of gunk in the works that needs to get cleaned out the hard way
However, if anybody knows what it takes to shut down the radio for the key fob remotes, I'd like to look into that at some point. Thanks!
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
For start your car is 2000 not 99.5.
-At 300k Most likely you need turbo. If this car was driven like old lady does it , then Turbo on those cars get lot of carbon at exhaust side and actuator start getting stuck at some points, if this keep going for long time it will damage rod inside turbo and there is no way to fix it , 99% this is your problem.
-Brake switch is know problem on Mk4 cars , So I suggest change it, they are relatively cheap , maybe $20.
-16764 - Glow Plug/Heater (Q6) Circuit----- Either Harness is bad or glow plugs , Look at your harness and if you see braking in peaces , need harness.
- Coolant Temperature Sensor fault in Cluster , also know problem on those cars , Change sensor and make sure you buy original form VW Dealer, OEM or Aftermarket are junk.
-For ABS, check sensor .
Wrenchly
Well there you go, first basic mistake! Had to go & look at the registration, but you got that right, it's a 2000. Might just write that on the dash where I can see it, for every time I stop in at the parts store. Funny thing is there's this tag in the binder that has the owners manual, says in green letters 'MY 2000'
I see a range of years on that scan log, but nothing that specifically states it's a 2000. How can you tell from that?
Previous owner was an old lady who drove drunk a lot. Lots of interior damage, passenger mirror broken off & missing, right rear door badly dented but still opens & closes. Few other little things like the thermostat was missing. I had thought the temp gauge was broken the first month until I realized the coolant wasn't really hot enough. I think the car was driven like that for a long while. It made more power after I put in a thermostat. I'm expecting that turbo is more than just clogged a bit
The dash gauge worked after fiddling with the connector. I had unplugged it to see if there was power to each glowplug. I guess it couldn't hurt to just change that out, but it also couldn't hurt to spray it down with some contact cleaner 1st. Would it work to just get a sensor from the outfit I bought the Hex-V2? They looked pretty serious for everything else they were selling. That was Cascade German in Gresham Oregon
I checked the resistance on the glowplugs, and they're all in spec and pretty close to exactly the same value
The plastic insulation on the glowplug harness fell apart when I checked for power, I actually had forgotten to look for one of those. It's connected with aftermarket inline crimps, so I think it's been changed out once already. I think that would be the 1st thing to try
Looking at the wheel speed sensor is on my mind, but so is this freezing cold rain out in the muddy yard I'm working in...
Wrenchly
From Part numbers of modules .
Ok, so the modules in each model year get unique part numbers? I would have expected something like that to only change between the generations
How do you use the part number to find a year? I don't see anything in those that would indicate the number '2000', so the obvious is out
Westbury, UK
The suffix of part numbers changes too - indicating newer versions either for a model update (including but not restricted to model year changes) or an update for a new model.
Wrenchly
The suffix is like a version number? There should be a list of all known part numbers somewhere
Westbury, UK
Yes like, but not only, a version number. And, importantly, a later version is in many cases NOT a suitable replacement...
Lists of version numbers seems to be a closely guarded VAG secret - the best available are lists of superceded parts and their suggested replacements.
Yes, it's confusing but VAG seem to like it that way :facepalm:
Wrenchly
Ok, well I think a list of superceded/replacement parts is pretty much what I was thinking of - being that would be what we would know for sure
Wouldn't a 'suggested replacement' be a case where sometimes the later version isn't suitable? I'm assuming that these part numbers only concern logic control modules installed on my car, which I would assume can be a bit finicky when hardware isn't exactly the same as what the firmware expects to see, right?
There was a huge transition between MY 1999 and MY 2000. These cars got internal CAN buses during that transition, and the instrument cluster is a dead give-away. 1J0-920-... is a CAN bus instrument cluster found only on MY2000 and newer, whereas 1999 and earlier had 1J0-919-... clusters.
There are other clues as well. The fact that your have "Address 19: CAN Gateway". MY 1999 and earlier simply didn't have that. Plus the fact that your cluster shows IMMO data. 1999 and earlier NAR cars didn't have that either.
Wrenchly
Ok, but how did you know I didn't have a 2001 or newer Mk4?
Westbury, UK
You could have avoided the possible confusion by posting the UNEDITED Auto-Scan (i.e. not removing the VIN :thanks:).
In many fault conditions the VIN can be important, which is why we always ask for an UNEDITED Auto-Scan.
Wrenchly
I didn't do any editing to the saved log file, I had assumed the VIN was not there because the software had been updated to no longer include it. I see enough tutorial videos on how to use software, in which the current version is changed in various ways without the video itself having been updated, I just thought it was that sort of thing
I'll do another auto-scan and see if it looks any different before exporting to a text file
Not in this case. MY 2000 and 2001 Mk.4 cars used Immo-2 and did not know their own VIN, hence VCDS has no way of knowing it or including it in the scan.
Without careful, detailed research of the part numbers, it could indeed be a 2001, but not a 2002 or newer because those use Immo-3 and do know their own VIN. They would also show Immo data under the ECU, which yours does not.
Wrenchly
Well that seems to settle that! All part of being very familiar with VCDS I would think
Wrenchly
Maybe the Ross-Tech software could include a placeholder to show that the VIN is missing due to this, and not edited out?
Westbury, UK
I did not know that, I had *assumed* that knowing the VIN was mandatory for OBD vehicles - good to know otherwise.
