VCDS in Beta mode ,20.10 , cb4608
JMR
Romania , EU
C?ID=432218
As per Uwe' s advice i' ve been using the VCDS in Beta mode ( had few issues in Rrelease ).
Would like to report that it is working very good so far, no issues.
Is it the autoscan a LOT faster in Beta or is it just me ? It seems that it is flying through all modules :)
I think that part is just you. :)
Of course the current interfaces (HEX-NET and HEX-V2) are a lot faster on modern cars that use CAN (as opposed to K-Lines) than the HEX+CAN you were previously using.
JMR
Romania , EU
C?ID=432218
just about 1 min 30 secs ,it seemed fast
Saturday,04,December,2021,14:48:30:31189
VCDS Version: 21.12.0.0  HEX-NET2 CB: 0.4608.4
Data version: 20211022 DS334.0
Workshop Code: 999 99999 999999
VIN: WVWZZZ6RZAY050357   License Plate: IF 97 BEB
Mileage: 209320km-130065mi   Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 02 03 04 08 09 15 17 19 25 44 56
VIN: WVWZZZ6RZAY050357   Mileage: 209320km-130065miles
Address 01: Engine (J623-CAYB)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 AH    HW: 03L 906 023 D
   Component: 1,6l R4 CR td H13 9342
   Revision: --H13---    Serial number:                CVN: C5427B17
   Coding: 00254014000400080000
   Shop #: WSC 124697 483 00190
   ASAM Dataset: EV_ECM16TDI02103L906023AH 003008
   ROD: EV_ECM16TDI02103L906023AH_003.rod
   VCID: 6C8AAE90E60C6A3B7FB-8038
   VINID: 9E69EAAAA1A2A91A401400C51C567AFBFA
   Part No SW: 0AM 300 049     HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 9060
   Revision: 00043014    Serial number: CU501409145662
   Shop #: WSC 04940 001 00001
   VCID: 6E8EA498DC80982B51F-513C
006011 - Clutch 1
               P177B - 003 - Tolerance Limit Reached - Intermittent
                    Fault Status: 00100011
                    Reset counter: 7
                    Mileage: 209238 km
                    Date: 2016.04.26
                    Time: 17:18:58
006013 - Dual Clutch
               P177D - 000 - Torque too High - Intermittent
                    Reset counter: 7
                    Mileage: 209256 km
                    Date: 2016.04.26
                    Time: 14:15:53
006012 - Clutch 2
               P177C - 003 - Tolerance Limit Reached - Intermittent
                    Reset counter: 9
                    Mileage: 209285 km
                    Date: 2016.04.26
                    Time: 00:08:49
   Part No SW: 6R0 907 379 R    HW: 6R0 907 379 R
   Component: ESP8.2i front H04 0002
   Revision: --------
   Coding: 210228E3417200B2842814E782D800421300
   Shop #: WSC 02069 000 00000
   VCID: 4DCC03147D968333085-8018
02214 - Tire Pressure Warning
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 225
                    Mileage: 209312 km
                    Date: 2016.04.26
                    Time: 00:58:09
                    Hex Value: 0x4007
                    Hex Value: 0x0000
                    Hex Value: 0x3203
                    Hex Value: 0x2BB8
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F10
                    Hex Value: 0x0000
                    Fault Frequency: 30
                    Reset counter: 8
                    Mileage: 209089 km
                    Date: 2016.04.26
                    Time: 11:51:27
                    Hex Value: 0x0000
                    Hex Value: 0x8000
                    Hex Value: 0x1214
                    Hex Value: 0x1BBA
                    Hex Value: 0x267B
                    Hex Value: 0x7E80
                    Hex Value: 0x8200
                    Hex Value: 0x0000
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AP.clb
   Part No SW: 6R0 820 045 A    HW: 6R0 820 045 A
   Component: Climatic       23 0500
   Revision: 00 09 23
   VCID: 2C0A6E90260CAA3B3FB-8078
16372 - Control Module; Unspecified Internal Error
            014 - Defective
                    Fault Status: 01101110
                    Mileage: 200124 km
                    Date: 2016.04.26
                    Time: 11:55:02
   Part No SW: 6R0 937 087 B    HW: 6R0 937 087 B
   Component: PQ25 BCM      H08 0029
   Revision: BF008001    Serial number: 9955A191091378
   Coding: 3EB02BBF08A10000013000003C2B0ED00000410F608400002000
   Shop #: WSC 00396 002 1048576
   VCID: 3C2A5ED0D66C3ABBAFB-8068
   Component: RLS 300709 05  54  0402
   Coding: 0005F3
   Subsystem 2 - Part No SW: 6R0 959 801 H    HW: 6R0 959 801 H  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  002 0803
   Serial number: KU0-KU004.08.0911012
   Coding: 08BC30
   Subsystem 3 - Part No SW: 6R0 959 802 K    HW: 6R0 959 802 K  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 0803
   Serial number: KU0-KU004.08.0913483
   Coding: 08BC30
   Subsystem 4 - Part No SW: 6R0 959 811 B    HW: 6R0 959 811 B
   Component: J388__TSG_HL  002 0803
   Serial number: KU0-KU028.07.0912144
   Coding: 08BC32
   Subsystem 5 - Part No SW: 6R0 959 812 B    HW: 6R0 959 812 B
   Component: J389__TSG_HR  003 0803
   Serial number: KU0-KU005.08.0913383
   Coding: 08BC32
                    Reset counter: 8
03587 - Control Circuit for Starter Lock Lock
                    Fault Status: 00100111
                    Reset counter: 6
                    Mileage: 209253 km
                    Date: 2016.04.26
                    Time: 12:45:11
   Part No SW: 6R0 959 655 C    HW: 6R0 959 655 C
   Component: VW10Airbag008 H09 0018
   Revision: --------    Serial number: 003DW005CU1A
   Coding: 003038
   ROD: EV_AirbaVW10BPAVW250_VW25.rod
   VCID: 42D62028B4084C4BE57-8016
   Serial number: 3572SRB40000932109AZ
   Serial number: 3582SRB400009524C999
   Serial number: 3516GRB401T9G013BBR9
   Serial number: 3526GRB401V9G012UJAL
   Part No SW: 6R0 920 861 B    HW: 6R0 920 861 B
   Component: KOMBI         H23 0110
   Coding: 140A00
   VCID: 343A76F0FEBCF2FB67B-8060
   Part No SW: 6N0 909 901     HW: 6R0 937 087 B
   Component: GW-K-CAN TP20 0029
   Coding: 002200
   VCID: 70B2BAE0CAA48EDB433-8024
   Component: IMMO          H23 0110
   Part No: 6R0 423 156 A
   Component: LenkhilfeTRW        V275
   Coding: 10130
   VCID: 2E0E64981950D82B11F-807A
   Part No SW: 5M0 035 186 AA    HW: 5M0 035 186 AA
   Component: Radio RCD310  013 0036
   Revision: 01000000    Serial number: VWZ1Z2I6806705
   Coding: 0500040002
   VCID: 6B88AD8CE3826D03761-803E
                    Reset counter: 195
                    Mileage: 203629 km
                    Date: 2016.04.26
                    Time: 11:38:21
03138 - Input AUX IN
                    Fault Status: 00101011
                    Reset counter: 7
                    Mileage: 203629 km
                    Date: 2016.04.26
                    Time: 11:38:26
End----------(Elapsed Time: 01:30, VBatt start/end: 14.3V/14.2V)-----------
