2001 Audi A6 4.2L
daisy
C?ID=290770
The car has bad battery, I am trying to unlock it today with no luck using the original key, of course it did not work with the remote control, thus I tried inserting the key in the driver's door keyhole and turning it manually, but that had no luck too.
I am not a AAA member, so this is not an option I want to explore at this moment, but maybe as a last resort I would. I am also not looking for people to suggest to brake anything off my vehicle, please save me your unnecessary comments if you can't actually help me out with this SERIOUSLY I am looking for positive feedback and ultimately solution to my problem- a safe way to open the vehicle and replace the battery!
Thanks for reading my post!
HMC
C?ID=28246
Hi Daisy,
If you can get the car jacked up (safely using stands) you may be able to get to the main starter lead and connect a starter pack or jump leads to that and earth and the car will be powered.
Regards HMC
daisy
C?ID=290770
Thanks for the help. Problem is solved!
Quintus Rotam
EU
C?ID=490177
Can you elaborate? Was it solved by following HMC's advice or something else? If it ever happens again to someone, your experience could be useful. Thanks
