Coding not accepted, Request out of range
Thats a shame.
I am just looking through my 09 module from my 22 Caddy and i have found the adaptation, however i am just wondering if there is also a menu setting somewhere buried in the adaptations as i seem to remember a Golf 7.5 i had, had the option to turn comfort flashing on and off, and also select how many times.
Having said that, i may not be remembering correctly!
When you have time, would you post up an admap of your 09 module please?
Jason: Hi
If your question is about mirror-tilt-on-reverse, then as intimated earlier - it's fundamentally a question about whether the mirror module has a memory (not a seat-memory module in the BCM -but rather, memory in the hex52 module).
Of course you are free to pursue whatever other option you might consider worthy - but as a base requirement, mirror tilt won't work successfully (and in lots of cases, won't work at all) without memory because there is no facility to hold the mirror's starting co-ordinates for mirror return.
So, purely as a suggestion and before you pursue other options - try these values on your passenger side mirror (enter "mirror" into the search box on the upper RHS):
If the values are as shown above - don't bother with this tweak because your passenger side mirror module is dumb!!
However, if your results are like this:
Then a mirror memory module is fitted !! Note: the X/Y coordinate values can be different to those shown in my picture (it depends on the mirror position) - but the values can't be 255!
jasons6930
C?ID=304798
Jason: Hi
Thanks Don.
Must admit i haven't looked at that, this was more about being able to change some basic functionality which, even with SFD access does not seem to work on newer modules as far as i am aware.
My 09 module has a different SW & HW number to Owner TR (although mine is 2022 model), although the ad map seems to contain many of the same, although i think his vehicle is a people carrier rather than mine which is a van with no rear seats.
It does appear that VW are really stamping down hard on third party diagnostic equipment at the moment, and are hard coding a lot of functions regardless of adaptation listing.
I only have my 09 admap for now which i will post in the other thread and i'll do the rest when i get time later.
   #24
OwnerTR
Turkey
C?ID=493252
Yes, people carrier.
   #25
jasons6930
C?ID=304798
That looks really good in that colour!
Can you do me a favour when you get time?
Could you take a picture of your rain & light sensor through the windscreen and post it up?
I am trying to locate the correct one but the only one i can find with your part number also says i may need to replace the windscreen as well!
This is mine currently..
The circle at the bottom of the image looks like it has a blank installed where the rain sensing part should go.
Cheers
   #26
OwnerTR
Turkey
C?ID=493252
Cheers
I've added two pictures as it's not clear.
   #27
jasons6930
C?ID=304798
Looks like it’s two sensors in the round part and the screen looks the same as mine so should be ok.
Thanks!
   #28
OwnerTR
Turkey
C?ID=493252
Thanks!
I colored the cockpit a little by doing the ambient lighting. Did you do it?
   #29
jasons6930
C?ID=304798
   #30
OwnerTR
Turkey
C?ID=493252
Ooooooooo how did you do that??
Since Caddy 5 and Golf 8 infrastructure are the same, I examined the Golf 8 codes and made it.
This is the video I took
jasons6930
C?ID=304798
Forgot about this but when i tried to change the comfort flashers with the 'other' diag tool, i only had the option of 1-3.
